@cba349c
08/17/18 18:30:19 |
joel |
bsps/m68k/shared/cache/cache.h: Fix warnings and clean up
5
@9e8bba5
08/29/18 05:53:02 |
Sebastian Huber |
score: Remove redundant #ifdef RTEMS_SMP
5
@a6fca76
08/29/18 05:46:31 |
Sebastian Huber |
bsp/qoriq: Remove README
Update #2854.
5
@6d70a11
08/27/18 05:33:29 |
Sebastian Huber |
Include <stdbool.h> in <machine/_kernel_types.h>
The FreeBSD kernel …
5
@27c89d7
08/08/18 09:52:09 |
Sebastian Huber |
Add FreeBSD kernel space header files
Move the kernel space content …
5
@97d2c44
06/29/18 12:24:58 |
Daniel Hellstrom |
spglobalcon01: LLVM optimization makes variable i always 1
Declare i …
5
@655108e4
06/28/18 12:43:38 |
Daniel Hellstrom |
psxfile01: floating point context required when calling fprintf
This …
5
@26c3f9f
06/28/18 12:42:11 |
Daniel Hellstrom |
psx13: floating point context required when calling fprintf
This …
5
@0d51b6d8
06/28/18 12:39:37 |
Daniel Hellstrom |
capture: prevent unaligned access when reading time
LLVM warns about …
5
@408fad3
06/20/18 07:23:31 |
Daniel Hellstrom |
leon,grspw_pkt: remove incorrect comment on SMP not being tested
To …
5
@aea3134e
06/15/18 06:49:31 |
Daniel Hellstrom |
leon,apbuart: replace termios c_cflag & CBAUD with c_{i,o}speed
ince …
5
@243ddb52
06/15/18 12:28:36 |
Daniel Hellstrom |
leon,greth: enable MAC filtering (promiscous mode, multicast)
It …
5
@2fbe2ef3
02/13/18 06:47:14 |
Daniel Hellstrom |
leon, greth: 10/100 MAC enable TX BD interrupt
Missed to enable …
5
@a87964d
08/23/18 09:13:44 |
Daniel Hellstrom |
sparc,smp: typo in start.S causing SMP not working
5
@59a0541c
07/12/18 07:15:55 |
cederman |
sparc: Restore npc when returning from the syscall_lazy_fp_switch trap …
5
@6695d02
08/23/18 12:39:33 |
Sebastian Huber |
Update FreeBSD kernel timespec support
This change is based on the …
5
@ba0e9631
08/10/18 05:34:03 |
Sebastian Huber |
score: Do not inline _Thread_Dispatch_enable()
This function is …
5
@a36aa86
08/23/18 12:32:07 |
Sebastian Huber |
Add dummy PI_SOFT to <sys/priority.h>
Update #3472.
5
@d14f934
08/10/18 05:22:43 |
Sebastian Huber |
score: Fix ISR enable in _Thread_Dispatch_enable()
This bug had …
5
@2cd3716
08/20/18 06:35:26 |
Sebastian Huber |
bsps/arm: Fix PL111 register define re-definition
Close #3502.
5
@dcaea71
08/15/18 10:26:13 |
christian.mauderer |
dev/sc16is752: Add name space for field names.
The field names for …
5
@da8b12bc
08/15/18 14:48:28 |
joel |
dl06/dl06-o1.c: Remove set, not used warning
5
@adbd7e7
08/15/18 14:47:53 |
joel |
fsdosfssync01/init.c: Remove unused variable
5
@bc731313
08/13/18 10:55:34 |
amaan.cheval |
bsps/x86_64: Add APIC timer based clock driver
The APIC timer is …
5
@6869321
08/13/18 10:50:38 |
amaan.cheval |
bsps/x86_64: Add support for RTEMS interrupts
Updates #2898.
5
@4544749e
08/13/18 10:33:12 |
amaan.cheval |
bsps/x86_64: Add paging support with 1GiB super pages
Updates #2898.
5
@6eccd0c
08/13/18 10:25:51 |
amaan.cheval |
bsps/x86_64: Reduce default RamSize? to 1GiB
Simulators may not always …
5
@ab971bf5
08/13/18 10:21:47 |
amaan.cheval |
bsps/x86_64: Reorganize header files and compile-options
Updates #2898.
5
@382d653
08/10/18 13:23:01 |
joel |
libtests/POSIX: Fix warnings and style.
5
@b3693f5
08/10/18 13:22:49 |
joel |
bsps/sparc/include/bsp/gradcdac.h: Fix nested comment warning
5
@d071d9a
08/10/18 13:22:02 |
joel |
qoriq/include/tm27.h: Fix prototype warning
5
@ebd1937
08/10/18 13:21:36 |
joel |
motorola_powerpc/include/tm27.h: Fix prototype warning
5
@3cff531f
08/10/18 13:21:09 |
joel |
bsps/powerpc/include/mpc83xx/mpc83xx.h: Fix nested comment warning
5
@5896da4
08/10/18 13:20:38 |
joel |
bsps/powerpc/include/bsp/tictac.h: Fix protototype warnings
5
@ae4fbf3b
08/10/18 13:20:07 |
joel |
gen83xx/include/tm27.h: Fix prototype warning
5
@ec8c955d
08/10/18 13:19:40 |
joel |
gen5200/include/tm27.h: Fix prototype warning
5
@7de51829
08/10/18 13:18:59 |
joel |
gen5200/include/bsp/ata.h: Fix warning
5
@0fc87d47
08/10/18 13:18:40 |
joel |
csb337/include/at91rm9200_dbgu.h: Fix nested comment warning
5
@b2de426
08/06/18 09:53:42 |
Sebastian Huber |
score: Fix _Addresses_Subtract()
Use architecture-specific integer …
5
@66cb142
08/06/18 08:51:00 |
Sebastian Huber |
rtems: Parameter types in rtems_partition_create()
Use uintptr_t to …
5
@b8eae140
08/10/18 05:11:56 |
Sebastian Huber |
Add dummy PRI_MIN_KERN to <sys/priority.h>
Update #3472.
5
@0e6f7dc4
08/10/18 05:10:20 |
Sebastian Huber |
bsps/sparc: Fix external variable declarations
5
@f4424cfb
08/09/18 07:20:33 |
Sebastian Huber |
bsps/sparc: Move polled APBUART functions
This reduces the link-time …
5
@aac36d15
08/08/18 09:17:36 |
Sebastian Huber |
posix: Add configure check for mprotect()
Update #3491.
5
@8e6cfcc
08/06/18 08:29:14 |
bsp/atsam: Fix handling of slow SPI speeds.
This patch fixes an …
5
@71948f76
08/08/18 05:52:18 |
Sebastian Huber |
sys/event.h: Update version FreeBSD tag
Update #3472.
5
@ac824ff
07/18/18 13:04:03 |
dab |
Make the definition of struct kevent in event.h match what the man …
5
@96b32773
07/11/18 02:09:11 |
dab |
Address some (although not all) style(9) issues in event.h after …
5
@1d00acb1
06/28/18 20:37:17 |
dab |
Fix compilation error in r335765 under gcc 4.2.1.
The anonymous …
5
@b37ef68
06/28/18 17:01:04 |
dab |
Remove potential identifier conflict in the EV_SET macro.
PR43905 …
5
@bf026dd4
11/27/17 15:01:59 |
pfg |
sys/sys: further adoption of SPDX licensing ID tags.
Mainly focus on …
5
@57c03363
11/25/17 04:49:12 |
jhb |
Decode kevent structures logged via ktrace(2) in kdump.
- Add a new …
5
@e9b708a
06/17/17 00:57:26 |
kib |
Add abstime kqueue(2) timers and expand struct kevent members.
This …
5
@f51aec8
04/08/17 04:34:18 |
pkelsey |
Fix typo.
hist -> hint
MFC after: 3 days
5
@fd27bae
08/07/18 04:25:47 |
Sebastian Huber |
CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
Make …
5
@97417bb
08/07/18 05:09:55 |
Sebastian Huber |
tests: Remove CONFIGURE_MAXIMUM_DRIVERS
This configuration is …
5
@0b038bd4
08/04/18 08:38:48 |
Sebastian Huber |
libblock: Add RTEMS_DEPRECATED
Close #3358.
5
@b152d33
08/06/18 04:26:50 |
Sebastian Huber |
fileio: Avoid deprecated rtems_disk_obtain()
Update #3358.
5
@ab96aec
08/04/18 08:56:46 |
Sebastian Huber |
dosfs: Avoid deprecated routine
Update #3358.
5
@dd66fda
08/04/18 08:47:56 |
Sebastian Huber |
tests: Avoid deprecated rtems_disk_io_initialize()
Update #3358.
5
@1836c6a
08/04/18 08:45:19 |
Sebastian Huber |
bsp/gen5200: Avoid deprecated routine
Update #3358.
5
@f7cecc33
08/03/18 20:53:40 |
Sebastian Huber |
libchip/ata: Use rtems_blkdev_create()
Update #3358.
5
@698093d
08/03/18 20:39:42 |
Sebastian Huber |
libblock: Use rtems_blkdev_create_partition()
Update #3358.
5
@bf80279
08/03/18 20:30:55 |
Sebastian Huber |
libtests/block15: Use rtems_blkdev_create()
Update #3358.
5
@fa12e06d
08/03/18 20:28:31 |
Sebastian Huber |
libtests/block14: Use rtems_blkdev_create()
Update #3358.
5
@3278d20
08/03/18 20:25:40 |
Sebastian Huber |
libtests/block13: Use rtems_blkdev_create()
Update #3358.
5
@5e4bab7
08/03/18 20:21:20 |
Sebastian Huber |
libtests/block12: Use rtems_blkdev_create()
Update #3358.
5
@6f34f13
08/03/18 20:16:32 |
Sebastian Huber |
libtests/block10: Use rtems_blkdev_create()
Update #3358.
5
@5005bfc
08/03/18 19:19:19 |
Sebastian Huber |
libtests/block09: Use rtems_blkdev_create()
Update #3358.
5
@117f7b1
08/03/18 16:18:56 |
Sebastian Huber |
libtests/block08: Use rtems_blkdev_create()
Update #3358.
5
@bde8be2
08/01/18 04:38:41 |
Sebastian Huber |
libtests/block06: Use rtems_blkdev_create()
Update #3358.
5
@6782771
08/04/18 12:24:05 |
Sebastian Huber |
libtests/block05: Avoid uninitialized variable
Update #3358.
5
@d279e74
08/01/18 04:14:14 |
Sebastian Huber |
bsp/smdk2410: Use rtems_blkdev_create()
Update #3358.
5
@1dec54f9
07/31/18 14:05:49 |
Sebastian Huber |
bsps/lm32: Use rtems_blkdev_create()
Update #3358.
5
@0fe7133
07/31/18 14:01:17 |
Sebastian Huber |
flashdisk: Use rtems_blkdev_create()
Update #3358.
5
@16f3f10
07/31/18 13:54:29 |
Sebastian Huber |
nvdisk: Use rtems_blkdev_create()
Update #3358.
5
@24b94c4
07/30/18 04:39:09 |
Sebastian Huber |
ramdisk: Use rtems_blkdev_create()
Update #3358.
5
@d56e68b
08/04/18 12:27:38 |
Sebastian Huber |
rfs: Remove erroneous call of rtems_disk_release()
The function …
5
@32ccc01
08/03/18 12:03:39 |
Sebastian Huber |
bsps: Fix the generic IRQ support
The genmcf548x partly uses is own …
5
@42f9963d
08/03/18 05:58:07 |
Sebastian Huber |
score: Remove superfluous semicolon
This avoids warnings like this:
5
@83ca9f0a
08/02/18 12:52:12 |
Sebastian Huber |
rtems: Relax partition buffer area alignment
The partition buffer …
5
@27bbc05
08/02/18 12:49:01 |
Sebastian Huber |
score: Remove CPU_PARTITION_ALIGNMENT
Use the CPU_SIZEOF_POINTER …
5
@141d502
08/02/18 11:23:26 |
Sebastian Huber |
bsp/riscv: Add missing BSP variant
Update #3433.
5
@4c740de
08/02/18 12:13:25 |
Sebastian Huber |
bsp/riscv: Fix build with RTEMS_SMP undefined
Update #3433.
5
@28b8cf9b
08/02/18 07:41:08 |
Sebastian Huber |
riscv: Fix CPU_ALIGNMENT
Update #3433.
5
@3d11c1e
08/01/18 08:06:37 |
Sebastian Huber |
bsp/riscv: Fix a synchronization issue for PLIC
Update #3433.
5
@dee2ebb
08/01/18 09:15:55 |
Sebastian Huber |
bsp/riscv: Remove unused variable
Update #3433.
5
@56b0387
08/01/18 06:13:39 |
Sebastian Huber |
bsp/riscv: Add NS16750 support to console driver
Update #3433.
5
@a7cd4b73
07/31/18 09:38:56 |
Sebastian Huber |
serial/ns16550: Precision clock synthesizer
Set the FIFO control …
5
@8a78b784
07/31/18 08:45:41 |
Sebastian Huber |
serial/ns16550: Use standard register names
Use the standard register …
5
@529154b
07/31/18 07:15:00 |
Sebastian Huber |
bsp/riscv: Initialize FPU depending on ISA
Initialize fcsr to zero …
5
@48cbd63
07/31/18 05:19:33 |
Sebastian Huber |
bsp/riscv: Fix clock driver
Do not assume that mtime is zero at boot …
5
@71284ce
08/01/18 05:41:49 |
Sebastian Huber |
bsps/sparc: Fix typo in start.S
Fix typo in start.S introduced by …
5
@d906ce3
07/30/18 05:51:39 |
Sebastian Huber |
libtests: Use CONFIGURE_INIT_TASK_TABLE_SIZE
Using …
5
@334e1d2
07/30/18 05:35:26 |
Sebastian Huber |
confdefs: Fix uniprocessor configuration
Introduce a new internal …
5
@44c2d393
07/27/18 13:04:38 |
Sebastian Huber |
bsp/riscv: Fix inter-processor interrupts
The previous version worked …
5
@cfc9573
07/27/18 12:47:17 |
Sebastian Huber |
riscv: Rework CPU counter support
Update #3433.
5
@65f52d0
07/25/18 09:25:30 |
Sebastian Huber |
samples/minimum: Use default interrupt stack size
Update #3433.
5
@581a0f88
07/24/18 12:47:05 |
Sebastian Huber |
bsp/riscv: Use interrupt driven NS16550 driver
Update #3433.
5
@adede135
07/24/18 11:27:54 |
Sebastian Huber |
bsp/riscv: Add PLIC support
Update #3433.
5
