@bf1f8764
08/25/14 21:52:45 |
Joel Sherrill |
gensh4/bsp_specs: Account for big/little endian
4.115
@e75907d
08/25/14 21:51:44 |
Joel Sherrill |
simsh4-testsuite.tcfg: new file
4.115
@d26cded
08/25/14 21:51:30 |
Joel Sherrill |
simsh2e-testsuite.tcfg: new file
4.115
@a4d355b4
08/25/14 21:50:13 |
Joel Sherrill |
shsim/bsp_specs: Account for big/little endian
4.115
@baa3c91
08/22/14 20:22:37 |
Hesham Almatary |
or1ksim BSP: Include cache manager stubs, and re-generate …
4.115
@e5f6ca8
08/22/14 20:22:04 |
Hesham Almatary |
Add or1k to the list of targets that use IEEE 754 in xdr_float.c
4.115
@9d92a43
08/22/14 20:21:35 |
Hesham Almatary |
Rename or1k_or1ksim BSP to or1ksim
4.115
@eeea9e30
08/22/14 20:20:47 |
Hesham Almatary |
libcpu: Add new entry for or1k cpu and include cache manager stubs.
4.115
@23b14f87
08/22/14 20:20:16 |
Hesham Almatary |
sptests/spcache01: Make inline assembly conditional to account for …
4.115
@4b104834
08/25/14 11:39:34 |
Sebastian Huber |
bsp/mpc55xx: Fix comment
4.115
@f3237a3c
08/25/14 07:30:53 |
Sebastian Huber |
bsp/mpc55xx: Add defines for MPC5668
4.115
@0a314839
08/25/14 07:09:45 |
Sebastian Huber |
bsp/mpc55xx: Limit flash support to MPC55[56]X
4.115
@f553c6e
08/22/14 14:39:47 |
Sebastian Huber |
rtems: Inline rtems_clock_get_ticks_since_boot()
Update documentation.
4.115
@e7a42a0c
08/25/14 06:48:17 |
cederman |
score: Add missing define to cache manager
4.115
@d13ce75
08/22/14 15:20:46 |
pisa |
bsp/tms570: implemented and tested initialization of Cortex-R …
4.115
@9a9ab85
07/03/14 14:42:24 |
cederman |
smptests/smpcache01: Test the SMP cache manager
Invokes SMP cache …
4.115
@ddbc3f8d
07/11/14 14:37:56 |
cederman |
score: Add SMP support to the cache manager
Adds functions that …
4.115
@62f373fb
08/11/14 08:02:13 |
cederman |
bsp/sparc: Flush only instruction cache
The flush instruction on LEON …
4.115
@bba83e5
07/11/14 14:09:41 |
cederman |
score/sparc: Add comment on icache flush after trap table update
4.115
@54f3476e
07/03/14 09:18:55 |
cederman |
bsp/sparc: Flush icache before first time enabling interrupts
A …
4.115
@aed38189
07/08/14 09:35:14 |
cederman |
score: Rename SMP broadcast message function
Change message type to …
4.115
@a68cc1b
07/08/14 09:33:55 |
cederman |
score: Add function to send a SMP message to a set of CPUs
4.115
@d5f5432
08/22/14 06:53:10 |
Christian.Mauderer |
libchip/dwmac: Make PHY address user configurable
This patch allows …
4.115
@66f1ca6
08/21/14 14:57:47 |
pisa |
bsp/tms570: disable huge memory demanding tests for internal RAM build …
4.115
@46265063
08/21/14 13:38:24 |
pisa |
bsp/tms570: implemented support functions to satisfy complete tests …
4.115
@5787188
08/20/14 23:47:02 |
Joel Sherrill |
Add configuration to detect toolset has sigaltstack() prototype
4.115
@dc661c8
08/20/14 22:08:23 |
dufault |
mpc55xx/misc/flash_support.c: Properly flush cache when writing.
4.115
@a7ec6fa
08/20/14 20:49:42 |
Joel Sherrill |
or1k.t: Fix spelling errors
4.115
@b088292
08/16/14 16:30:19 |
Hesham Almatary |
Add new documentation section for OpenRISC CPU architecture.
4.115
@2ed97d9
08/20/14 19:53:18 |
Joel Sherrill |
libbsp/arm/acinclude.m4: Regenerate for tms570
4.115
@fd57015
08/20/14 17:23:20 |
Hesham Almatary |
Add new (first) OpenRISC BSP called or1ksim.
This BSP is intended to …
4.115
@4407ee6
08/20/14 15:24:23 |
kom541000 |
BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137)
4.115
@0a66c126
08/16/14 14:15:17 |
Pavel Pisa |
lpc24xx/lpc17xx: lpc24xx_pin_set_function() keep LPC4088 W type pin in …
4.115
@bba3507
08/19/14 15:43:36 |
Sebastian Huber |
score: PR2179: Fix initially locked PI mutex
4.115
@3654667f
08/14/14 15:02:29 |
Kolja Waschk |
rtems_termios_puts: Copy and write more than one char at once
Renamed …
4.115
@de62e5d8
08/18/14 21:06:46 |
Hesham Almatary |
Add or1k tick timer register definitions
4.115
@1a2d3497
08/14/14 12:27:40 |
Sebastian Huber |
arm: PR2186: Fix compile error
4.115
@700f97e
08/12/14 18:46:49 |
Joel Sherrill |
or1k/.../preinstall.am: Add missing file
4.115
@94d45f6
08/12/14 15:57:42 |
Hesham Almatary |
Add support for OpenRISC - Fixed issues
This work is based on the old …
4.115
@6cdc090
08/10/14 16:35:27 |
Sebastian Huber |
bsp/lpc24xx: Add LPC40XX variants
4.115
@8ae37323
08/10/14 16:36:30 |
Sebastian Huber |
arm: Add support for FPv4-SP floating point unit
This floating point …
4.115
@81329f9
07/15/14 14:20:37 |
bsp/altera-cyclone-v: Add RTC driver.
4.115
@3f9cd87d
07/14/14 14:33:52 |
bsp/altera-cyclone-v: Add a simple I2C driver.
4.115
@1642d27e
07/18/14 10:29:29 |
bsp/altera-cyclone-v: Add socal from hwlib.
Some of the headers from …
4.115
@0b9fe3ec
08/07/14 17:41:25 |
Sebastian Huber |
sptests/sprbtree01: Add random ops test case
4.115
@0ef6e3bf
07/24/14 15:50:58 |
Sebastian Huber |
rbtree: Simplify _RBTree_Extract()
4.115
@993f5ac
07/23/14 11:03:54 |
Sebastian Huber |
rbtree: Simplify insert and extract
Simplify _RBTree_Insert() and …
4.115
@4752550f
07/23/14 11:19:09 |
Sebastian Huber |
rbtree: Simplify _RBTree_Rotate()
Add and use _RBTree_Direction().
4.115
@d472d21
08/05/14 12:07:07 |
Sebastian Huber |
sptests/sprbtree01: Check tree layout
4.115
@888edf6
08/05/14 11:52:45 |
Sebastian Huber |
sptests/sprbtree01: Reduce stack usage
4.115
@390cfcd
08/02/14 13:49:26 |
Sebastian Huber |
posix: Simplify key implementation
4.115
@60fe374
08/03/14 11:02:58 |
Sebastian Huber |
rbtree: Add and use RBTree_Compare_result
4.115
@40dcafa
08/02/14 14:22:31 |
Sebastian Huber |
Add and use RTEMS_CONTAINER_OF()
4.115
@b767683a
07/22/14 20:49:09 |
Sebastian Huber |
rbtree: Rename find header in find control
Simplify …
4.115
@6e93c836
07/22/14 17:42:54 |
Sebastian Huber |
rbtree: Simplify off-tree handling
Only use the parent pointer, since …
4.115
@4cd55724
07/26/14 10:52:22 |
Sebastian Huber |
Delete unused *_Is_null() functions
4.115
@639117f
07/22/14 12:50:07 |
Sebastian Huber |
rbtree: Update maximum node in LIFO order
The test sptests/sp35 …
4.115
@9113798c
07/23/14 20:39:17 |
Joel Sherrill |
todimpl.h: Add missing Doxygen
4.115
@0a84c298
07/23/14 20:37:03 |
Joel Sherrill |
coretod*.c: Fix Doxygen group and comment formatting
4.115
@875fff0a
07/23/14 20:35:35 |
Joel Sherrill |
Add _TOD_Adjust to SCORE TOD Handler.
This lays the proper structure …
4.115
@3b6352d
07/19/14 00:46:59 |
Joel Sherrill |
adjtime.c: Use timestamp math and simplify
4.115
@8abbbdde
07/21/14 16:29:00 |
Sebastian Huber |
rbtree: Do not set node off-tree in extract
4.115
@d7a94693
07/21/14 16:16:47 |
Sebastian Huber |
rbtree: Remove superfluous NULL pointer checks
4.115
@6b0a7efc
07/21/14 16:08:07 |
Sebastian Huber |
rbtree: Format
4.115
@87894c0
07/11/14 11:29:53 |
Sebastian Huber |
doc: Update console driver documentation
4.115
@742402b5
07/16/14 20:45:49 |
Joel Sherrill |
m68k/gen68360/include/tm27.h: Correct comment
4.115
@6e868d87
07/16/14 20:43:05 |
Joel Sherrill |
Add More Testsuite Configuration Files and Update Existing Ones
The …
4.115
@6832a560
07/16/14 00:45:32 |
Chris Johns |
Common ARM A8 code.
4.115
@0ea6d07
07/09/14 18:22:28 |
Joel Sherrill |
Use Shared Method for Thread Unblock Cleanup
When a thread is removed …
4.115
@3250664
07/15/14 17:37:36 |
Joel Sherrill |
Thread Queue: Merge discipline subroutines into main methods
There …
4.115
@ed7a028
07/07/14 19:26:13 |
Joel Sherrill |
Thread Queue Priority Discipline Reimplemented with RBTree
4.115
@64939bc
07/12/14 19:22:22 |
Sebastian Huber |
rbtree: Reduce RBTree_Control size
Remove compare function and is …
4.115
@7e119990
07/12/14 19:22:21 |
Sebastian Huber |
rbtree: Delete unused functions
4.115
@7e60b7d
07/12/14 22:04:19 |
Ben Gras |
uart-output-char.h: extra offset definition.
All,
This patch is …
4.115
@9ba76ed8
07/07/14 22:42:28 |
Joel Sherrill |
sp59: Fix typos
4.115
@764e8b11
07/07/14 19:23:24 |
Joel Sherrill |
scheduleredfunblock.c: Correct spacing
4.115
@3a01e8b
07/07/14 19:22:57 |
Joel Sherrill |
semdelete.c: Correct spacing
4.115
@b6343c6
07/10/14 19:20:39 |
Joel Sherrill |
Enhance Semaphore Blocking and Readying Time Test Cases
tm02 and tm03 …
4.115
@648c86c
07/14/14 18:12:31 |
Jennifer Averett |
capture01: Add include of assert.h.
4.115
@247118bf
07/10/14 16:55:04 |
Jennifer Averett |
smpschedsem01: new test.
This test verifies priority is inherited …
4.115
@7eb3fd47
07/10/14 16:45:58 |
Jennifer Averett |
smpschedaffinity05: Add test for worst case migration for affintiy …
4.115
@61d26f93
07/10/14 16:36:40 |
Jennifer Averett |
smpschedaffinity04: New test.
This test walks a secondary high …
4.115
@28d66749
07/10/14 16:18:02 |
Jennifer Averett |
smpschedaffinity03: New test.
This task walks the affinity of self …
4.115
@09293069
07/10/14 15:19:06 |
Jennifer Averett |
smpschedaffinity02: New test.
This test checks setting the affinity …
4.115
@d88b0e7f
05/22/14 14:00:14 |
Jennifer Averett |
smpschedaffinity01: New test.
This test verifies that affinity is …
4.115
@82d137ae
04/23/14 20:08:26 |
Jennifer Averett |
capture01: New non-interactive test for capture engine.
4.115
@463de59
04/16/14 14:42:37 |
Jennifer Averett |
capture: Fix capture engine to handle new extensions.
4.115
@1af8634a
04/11/14 15:18:20 |
Jennifer Averett |
capture: Update comment block style in capture engine.
Doxygen added …
4.115
@f0c8501
07/11/14 07:47:05 |
Sebastian Huber |
score: Scheduler helping proto for affinity sched
The priority …
4.115
@27783f6
07/10/14 12:27:42 |
Sebastian Huber |
score: Fix scheduler helping implementation
Do not extract the idle …
4.115
@333f9426
07/10/14 10:49:43 |
Sebastian Huber |
score: Fix assertions
4.115
@76ad756c
07/10/14 05:56:11 |
Chris Johns |
FreeBSD standard shell does not support substring expansion.
Switch …
4.115
@e1f446d3
07/09/14 13:53:31 |
Sebastian Huber |
bsps/sparc: Set best baud in APBUART driver
This prevents failures of …
4.115
@93726e5
07/09/14 13:44:13 |
Sebastian Huber |
termios: Add rtems_termios_set_best_baud()
4.115
@8074342c
07/03/14 10:55:42 |
termios: Add rtems_termios_get_termios()
4.115
@8448a4d
07/01/14 13:09:49 |
bsps/sparc: Move APBUART printk support
4.115
@21abc43
06/30/14 07:33:36 |
Sebastian Huber |
bsps/sparc: Add and use shared APBUART console
Move the APBUART …
4.115
@a0eb21e
06/27/14 14:20:44 |
Sebastian Huber |
bsps: Basic console driver for Termios devices
4.115
@a0fb29f
07/09/14 09:52:56 |
Sebastian Huber |
termios: PR1279: Use first open status
4.115
@32fc6a3
07/09/14 09:15:53 |
Sebastian Huber |
termios: PR1279: Use set attributes status
4.115
