@bde6ac20
11/20/18 15:45:51 |
kualeyidxa |
Misc: Minor English fixes (GCI 2018)
5
@edae517
11/20/18 01:11:58 |
himanshuwindows8.1 |
psxtmutexattr01: Added new POSIX timing suite (GCI 2018)
5
@0a6a4ddb
11/16/18 06:46:16 |
Sebastian Huber |
bsps/moxie: Use interrupt stack for init stack
Update #3459.
5
@38f81bfc
11/16/18 07:01:24 |
Sebastian Huber |
bsps/nios2: Use interrupt stack for init stack
Update #3459.
5
@0989001
11/15/18 05:40:35 |
Sebastian Huber |
bsps/sparc64: Use interrupt stack for init stack
Update #3459.
5
@5f5bbd1
11/16/18 07:55:30 |
Sebastian Huber |
bsps/x86_64: Use interrupt stack for init stack
Update #3459.
5
@0ce6bf3
11/16/18 05:39:49 |
Sebastian Huber |
bsps/epiphany: Use interrupt stack for init stack
Update #3459.
5
@a74ee417
11/16/18 05:36:28 |
Sebastian Huber |
bsps/bfin: Use interrupt stack for init stack
Update #3459.
5
@508f319e
11/16/18 06:43:51 |
Sebastian Huber |
bsps/mips: Use interrupt stack for init stack
Update #3459.
5
@84e59b7c
11/15/18 19:47:22 |
Sebastian Huber |
bsps/powerpc: Use interrupt stack for init stack
Move start.o to …
5
@cc61d5c
11/16/18 06:36:04 |
Sebastian Huber |
bsps/m68k: Use interrupt stack for init stack
Update #3459.
5
@edd366c
11/17/18 17:09:05 |
psxtmcleanup01: new POSIX timing suite (GCI 2018)
5
@f06c436
11/16/18 17:17:13 |
shashvatjain2002 |
psxtmtests_plan.csv: Update to reflect psxtmmqrcvblock01 (GCI 2018)
5
@ccf11ce
11/15/18 18:55:11 |
shashvatjain2002 |
psxtmmqrcvblock01: Add new POSIX timing test (GCI 2018)
5
@841b54e
11/15/18 22:31:21 |
psxtmthreadattr01: Correct mistakes in previous merge (GCI 2018)
Joel …
5
@8abb230b
11/15/18 06:18:48 |
psxtmthreadattr01: Add new test (GCI 2018)
5
@68c8a197
11/14/18 23:30:57 |
joel |
testsuites/psxtests/psxhdrs: Fix comment so copyright block is separate
5
@5247a214
11/14/18 22:48:56 |
pisa |
bsp/tms570: correct baudrate calculation.
5
@aefd4a2
11/14/18 22:46:43 |
pisa |
bsp/tms570: correct inclusion of header files for build with HW init.
5
@a13b89b
11/14/18 07:42:22 |
Sebastian Huber |
bsp/i386: Use interrupt stack for init stack
Update #3459.
5
@5f32da0
11/14/18 06:58:38 |
Sebastian Huber |
bsp/or1k: Use interrupt stack for init stack
Update #3459.
5
@dc563556
11/14/18 06:23:21 |
Sebastian Huber |
Include missing <sys/cpuset.h>
Update #3598.
5
@28bf4ca
11/14/18 06:00:59 |
Sebastian Huber |
or1k: Support GCC 9
Close #3602.
5
@9a029ce
11/09/18 12:06:52 |
Sebastian Huber |
bsps/irq: Use rtems_malloc()
5
@6efc831
11/09/18 11:11:11 |
Sebastian Huber |
Add rtems_malloc() and rtems_calloc()
Close #3583.
5
@c1f3c2b8
11/09/18 10:20:09 |
Sebastian Huber |
score: Add and use malloc() family attributes
Update #3583.
5
@4539e307
11/08/18 15:06:44 |
Sebastian Huber |
x86_64: Remove use of proc_ptr
Update #3585.
5
@70928bc9
11/09/18 07:12:49 |
Sebastian Huber |
sparc64: Remove use of proc_ptr
Update #3585.
5
@ce37237f
11/08/18 05:41:15 |
Sebastian Huber |
sparc: Remove use of proc_ptr
Update #3585.
5
@510fbfc3
11/08/18 14:31:03 |
Sebastian Huber |
sh: Remove use of proc_ptr
Update #3585.
5
@ed9da8e
11/09/18 06:56:48 |
Sebastian Huber |
powerpc: Remove use of proc_ptr
Update #3585.
5
@54c5ffc
11/08/18 14:05:22 |
Sebastian Huber |
or1k: Remove use of proc_ptr
Update #3585.
5
@12dfa5e2
11/08/18 15:03:10 |
Sebastian Huber |
nios2: Remove use of proc_ptr
Update #3585.
5
@264e128
11/09/18 07:04:23 |
Sebastian Huber |
moxie: Remove use of proc_ptr
Update #3585.
5
@b6be8f33
11/08/18 14:34:59 |
Sebastian Huber |
mips: Remove use of proc_ptr
Update #3585.
5
@5c6edee
11/08/18 14:44:56 |
Sebastian Huber |
m68k: Remove use of proc_ptr
Update #3585.
5
@0e16fa45
11/08/18 14:47:42 |
Sebastian Huber |
lm32: Remove use of proc_ptr
Update #3585.
5
@3c6a6e8
11/08/18 14:14:32 |
Sebastian Huber |
i386: Remove use of proc_ptr
Update #3585.
5
@a043ff8
11/08/18 14:33:47 |
Sebastian Huber |
epiphany: Remove use of proc_ptr
Update #3585.
5
@8203db45
11/09/18 06:59:57 |
Sebastian Huber |
bfin: Remove use of proc_ptr
Update #3585.
5
@685aa28
11/09/18 07:01:53 |
Sebastian Huber |
arm: Remove use of proc_ptr
Update #3585.
5
@d997aa1
11/09/18 06:54:31 |
Sebastian Huber |
no_cpu: Remove use of proc_ptr
Update #3585.
5
@3faa8459
11/08/18 05:25:32 |
Sebastian Huber |
rtems: Simplify rtems_interrupt_catch()
Remove casts and superfluous …
5
@b15b288
11/08/18 05:25:06 |
Sebastian Huber |
score: Deprecate proc_ptr
Update #3585.
5
@963c6c2
11/12/18 08:28:49 |
Sebastian Huber |
score: Move internal structures to userextdata.h
Update #3598.
5
@356b07e6
11/12/18 08:24:28 |
Sebastian Huber |
score: Includes in <rtems/score/smplockstats.h>
Include …
5
@3b69a0e2
11/12/18 08:23:32 |
Sebastian Huber |
rtems: Simplify includes in <rtems/rtems/cache.h>
Update #3598.
5
@a6e7d5e4
11/12/18 08:00:36 |
Sebastian Huber |
score: Move internal structures to objectdata.h
Update #3598.
5
@e897c7d
11/08/18 11:57:26 |
Sebastian Huber |
rtems: Avoid include of <rtems/score/scheduler.h>
Update #3598.
5
@2fa014db
11/08/18 11:05:44 |
Sebastian Huber |
rtems: Avoid include of <rtems/score/thread.h>
Update #3598.
5
@805f9c26
11/08/18 10:55:11 |
Sebastian Huber |
score: Avoid complex include in heap.h
Update #3598.
5
@9763245
11/08/18 10:53:12 |
Sebastian Huber |
rtems: Remove superfluous include
Update #3598.
5
@ccc6695
11/08/18 10:50:24 |
Sebastian Huber |
score: Introduce <rtems/score/watchdogticks.h>
Separate the …
5
@98c01a5
11/08/18 10:32:13 |
Sebastian Huber |
rtems: Avoid <rtems/score/timecounter.h> in API
Use a real function …
5
@a11b98c
11/08/18 12:12:32 |
Sebastian Huber |
score: Avoid include of <rtems/score/thread.h>
Update #3598.
5
@742d6db
11/08/18 10:14:04 |
Sebastian Huber |
score: Remove empty <rtems/score/tod.h>
Update #3598.
5
@5fc855d
11/08/18 12:17:37 |
Sebastian Huber |
rtems: Move internal structures to extensiondata.h
Update #3598.
5
@e1b7c188
11/08/18 10:07:57 |
Sebastian Huber |
rtems: Move internal structures to timerdata.h
Update #3598.
5
@b7af3e44
11/08/18 09:57:21 |
Sebastian Huber |
rtems: Move internal structures to tasksdata.h
Update #3598.
5
@739df1f5
11/08/18 09:45:44 |
Sebastian Huber |
rtems: Move internal structures to semdata.h
Update #3598.
5
@e8e914b3
11/08/18 09:37:22 |
Sebastian Huber |
rtems: Move internal structures to regiondata.h
Update #3598.
5
@f00c5c6
11/08/18 09:32:14 |
Sebastian Huber |
rtems: Move internal structures to partdata.h
Update #3598.
5
@257668d
11/08/18 09:28:49 |
Sebastian Huber |
rtems: Move internal structures to messagedata.h
Update #3598.
5
@efc227cd
11/08/18 09:24:19 |
Sebastian Huber |
rtems: Move internal structures to eventdata.h
Update #3598.
5
@72a4a42
11/08/18 09:19:39 |
Sebastian Huber |
rtems: Move internal structures to dpmemdata.h
Update #3598.
5
@395a49e1
11/08/18 09:12:21 |
Sebastian Huber |
rtems: Move internal structures to barrierdata.h
Update #3598.
5
@bdd4eb87
11/08/18 08:13:59 |
Sebastian Huber |
rtems: Remove Modes_Control
Use rtems_mode directly. This is in line …
5
@257cf74
11/08/18 08:03:47 |
Sebastian Huber |
rtems: Move internal structures to asrdata.h
Update #3598.
5
@78bbe59
11/07/18 13:12:52 |
Sebastian Huber |
rtems: Move internal structures to ratemondata.h
Update #3598.
5
@93fae332
11/12/18 08:33:04 |
Sebastian Huber |
Include missing <sys/types.h>
Update #3598.
5
@0a9378af
11/12/18 12:09:36 |
Sebastian Huber |
x86_64: Remove duplicate _CPU_Thread_Idle_body()
5
@bfcf1473
11/08/18 15:21:48 |
Sebastian Huber |
m32c: Remove this target
Update #3599.
5
@7ea7178
11/09/18 18:16:27 |
shashvatjain2002 |
arm/csb337: Update Doxygen (GCI 2018)
5
@62954aaf
11/11/18 15:12:51 |
joel |
psxtmtests_plan.csv: Add pthread cleanup and attr test cases
5
@b3c624d8
11/08/18 00:47:49 |
shashvatjain2002 |
arm/altera cyclone v: Update Doxygen (GCI 2018)
5
@84aedcae
11/08/18 12:49:38 |
Sebastian Huber |
Include missing <rtems/score/thread.h>
Update #3598.
5
@5841e0b
11/09/18 12:47:20 |
Sebastian Huber |
bsp/lpc32xx: Include missing <time.h>
Update #3598.
5
@fdd3b85
11/09/18 09:46:50 |
Sebastian Huber |
bsp/motorola_powerpc: Include <sys/param.h>
Update #3598.
5
@0288536
11/09/18 08:40:45 |
Sebastian Huber |
bsps: Include missing header files
Update #3598.
5
@efdb4a7
11/09/18 08:37:53 |
Sebastian Huber |
bsp/beatnik: Fix warnings
5
@1e039fb3
11/08/18 07:01:13 |
Sebastian Huber |
rtems: Deprecate rtems_rate_monotonic_period_time_t
The …
5
@aacc7a0
11/08/18 06:59:04 |
Sebastian Huber |
rtems: Deprecate rtems_thread_cpu_usage_t
The …
5
@d53862a
11/08/18 06:56:54 |
Sebastian Huber |
rtems: Deprecate region_information_block
The …
5
@7e86e00
11/08/18 06:54:03 |
Sebastian Huber |
rtems: Deprecate rtems_context_fp
The rtems_context_fp typedef as no …
5
@0ac4a77
11/08/18 06:53:14 |
Sebastian Huber |
The rtems_context typedef as no …
5
@06ced25
11/07/18 05:09:07 |
Chris Johns |
testsuite: Add python verison support to rtems-test-check.py
Closes #3579
5
@947b679
11/08/18 15:46:17 |
Sebastian Huber |
h8300: Remove left over files
Update #2452.
5
@942d52a
11/08/18 12:59:27 |
Sebastian Huber |
build: Fix library order
Update #3551.
5
@4f4ed2f0
11/08/18 12:11:54 |
Sebastian Huber |
rtems: Add missing include
Update #3598.
5
@ac8025c
11/08/18 12:09:54 |
Sebastian Huber |
libcsupport: Add missing include
Update #3598.
5
@2c8b87f
11/08/18 11:10:41 |
Sebastian Huber |
rtems: Move includes out of extern "C" scope
5
@795dfaac
11/08/18 09:49:43 |
Malte Münch |
small typo
5
@ea8cf79
11/08/18 11:00:12 |
Sebastian Huber |
config: Move includes out of extern "C" scope
5
@32953f90
11/08/18 07:38:24 |
Sebastian Huber |
bsp/realview-pbx-a9: Update headers.am
5
@ef30eb1
11/08/18 06:52:28 |
Sebastian Huber |
monitor: Remove dead code
Update #3587.
Update #3589.
5
@a9767a07
11/07/18 13:27:17 |
Sebastian Huber |
score: Use RTEMS_DEPRECATED for deprecated types
Update #3584.
5
@4fea054c
11/06/18 18:34:15 |
Sebastian Huber |
score: Remove _ISR_Dispatch()
This function was only used on some …
5
@ff081aee
11/06/18 15:58:02 |
Sebastian Huber |
score: Rename interrupt stack symbols
Rename
5
@e9f15be
11/07/18 18:09:00 |
joel |
psxtmtests_plan.csv: Add psxtmonce01
5
@98cc00e6
11/07/18 18:07:53 |
joel |
psxtmonce01/init.c: Use static and Simple Console
5
