source: rtems
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @b8eae140   08/10/18 05:11:56 Sebastian Huber Add dummy PRI_MIN_KERN to <sys/priority.h> Update #3472. 5
(edit) @0e6f7dc4   08/10/18 05:10:20 Sebastian Huber bsps/sparc: Fix external variable declarations 5
(edit) @f4424cfb   08/09/18 07:20:33 Sebastian Huber bsps/sparc: Move polled APBUART functions This reduces the link-time … 5
(edit) @aac36d15   08/08/18 09:17:36 Sebastian Huber posix: Add configure check for mprotect() Update #3491. 5
(edit) @8e6cfcc   08/06/18 08:29:14 christian.mauderer bsp/atsam: Fix handling of slow SPI speeds. This patch fixes an … 5
(edit) @71948f76   08/08/18 05:52:18 Sebastian Huber sys/event.h: Update version FreeBSD tag Update #3472. 5
(edit) @ac824ff   07/18/18 13:04:03 dab Make the definition of struct kevent in event.h match what the man … 5
(edit) @96b32773   07/11/18 02:09:11 dab Address some (although not all) style(9) issues in event.h after … 5
(edit) @1d00acb1   06/28/18 20:37:17 dab Fix compilation error in r335765 under gcc 4.2.1. The anonymous … 5
(edit) @b37ef68   06/28/18 17:01:04 dab Remove potential identifier conflict in the EV_SET macro. PR43905 … 5
(edit) @bf026dd4   11/27/17 15:01:59 pfg sys/sys: further adoption of SPDX licensing ID tags. Mainly focus on … 5
(edit) @57c03363   11/25/17 04:49:12 jhb Decode kevent structures logged via ktrace(2) in kdump. - Add a new … 5
(edit) @e9b708a   06/17/17 00:57:26 kib Add abstime kqueue(2) timers and expand struct kevent members. This … 5
(edit) @f51aec8   04/08/17 04:34:18 pkelsey Fix typo. hist -> hint MFC after: 3 days 5
(edit) @fd27bae   08/07/18 04:25:47 Sebastian Huber CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE Make … 5
(edit) @97417bb   08/07/18 05:09:55 Sebastian Huber tests: Remove CONFIGURE_MAXIMUM_DRIVERS This configuration is … 5
(edit) @0b038bd4   08/04/18 08:38:48 Sebastian Huber libblock: Add RTEMS_DEPRECATED Close #3358. 5
(edit) @b152d33   08/06/18 04:26:50 Sebastian Huber fileio: Avoid deprecated rtems_disk_obtain() Update #3358. 5
(edit) @ab96aec   08/04/18 08:56:46 Sebastian Huber dosfs: Avoid deprecated routine Update #3358. 5
(edit) @dd66fda   08/04/18 08:47:56 Sebastian Huber tests: Avoid deprecated rtems_disk_io_initialize() Update #3358. 5
(edit) @1836c6a   08/04/18 08:45:19 Sebastian Huber bsp/gen5200: Avoid deprecated routine Update #3358. 5
(edit) @f7cecc33   08/03/18 20:53:40 Sebastian Huber libchip/ata: Use rtems_blkdev_create() Update #3358. 5
(edit) @698093d   08/03/18 20:39:42 Sebastian Huber libblock: Use rtems_blkdev_create_partition() Update #3358. 5
(edit) @bf80279   08/03/18 20:30:55 Sebastian Huber libtests/block15: Use rtems_blkdev_create() Update #3358. 5
(edit) @fa12e06d   08/03/18 20:28:31 Sebastian Huber libtests/block14: Use rtems_blkdev_create() Update #3358. 5
(edit) @3278d20   08/03/18 20:25:40 Sebastian Huber libtests/block13: Use rtems_blkdev_create() Update #3358. 5
(edit) @5e4bab7   08/03/18 20:21:20 Sebastian Huber libtests/block12: Use rtems_blkdev_create() Update #3358. 5
(edit) @6f34f13   08/03/18 20:16:32 Sebastian Huber libtests/block10: Use rtems_blkdev_create() Update #3358. 5
(edit) @5005bfc   08/03/18 19:19:19 Sebastian Huber libtests/block09: Use rtems_blkdev_create() Update #3358. 5
(edit) @117f7b1   08/03/18 16:18:56 Sebastian Huber libtests/block08: Use rtems_blkdev_create() Update #3358. 5
(edit) @bde8be2   08/01/18 04:38:41 Sebastian Huber libtests/block06: Use rtems_blkdev_create() Update #3358. 5
(edit) @6782771   08/04/18 12:24:05 Sebastian Huber libtests/block05: Avoid uninitialized variable Update #3358. 5
(edit) @d279e74   08/01/18 04:14:14 Sebastian Huber bsp/smdk2410: Use rtems_blkdev_create() Update #3358. 5
(edit) @1dec54f9   07/31/18 14:05:49 Sebastian Huber bsps/lm32: Use rtems_blkdev_create() Update #3358. 5
(edit) @0fe7133   07/31/18 14:01:17 Sebastian Huber flashdisk: Use rtems_blkdev_create() Update #3358. 5
(edit) @16f3f10   07/31/18 13:54:29 Sebastian Huber nvdisk: Use rtems_blkdev_create() Update #3358. 5
(edit) @24b94c4   07/30/18 04:39:09 Sebastian Huber ramdisk: Use rtems_blkdev_create() Update #3358. 5
(edit) @d56e68b   08/04/18 12:27:38 Sebastian Huber rfs: Remove erroneous call of rtems_disk_release() The function … 5
(edit) @32ccc01   08/03/18 12:03:39 Sebastian Huber bsps: Fix the generic IRQ support The genmcf548x partly uses is own … 5
(edit) @42f9963d   08/03/18 05:58:07 Sebastian Huber score: Remove superfluous semicolon This avoids warnings like this: … 5
(edit) @83ca9f0a   08/02/18 12:52:12 Sebastian Huber rtems: Relax partition buffer area alignment The partition buffer … 5
(edit) @27bbc05   08/02/18 12:49:01 Sebastian Huber score: Remove CPU_PARTITION_ALIGNMENT Use the CPU_SIZEOF_POINTER … 5
(edit) @141d502   08/02/18 11:23:26 Sebastian Huber bsp/riscv: Add missing BSP variant Update #3433. 5
(edit) @4c740de   08/02/18 12:13:25 Sebastian Huber bsp/riscv: Fix build with RTEMS_SMP undefined Update #3433. 5
(edit) @28b8cf9b   08/02/18 07:41:08 Sebastian Huber riscv: Fix CPU_ALIGNMENT Update #3433. 5
(edit) @3d11c1e   08/01/18 08:06:37 Sebastian Huber bsp/riscv: Fix a synchronization issue for PLIC Update #3433. 5
(edit) @dee2ebb   08/01/18 09:15:55 Sebastian Huber bsp/riscv: Remove unused variable Update #3433. 5
(edit) @56b0387   08/01/18 06:13:39 Sebastian Huber bsp/riscv: Add NS16750 support to console driver Update #3433. 5
(edit) @a7cd4b73   07/31/18 09:38:56 Sebastian Huber serial/ns16550: Precision clock synthesizer Set the FIFO control … 5
(edit) @8a78b784   07/31/18 08:45:41 Sebastian Huber serial/ns16550: Use standard register names Use the standard register … 5
(edit) @529154b   07/31/18 07:15:00 Sebastian Huber bsp/riscv: Initialize FPU depending on ISA Initialize fcsr to zero … 5
(edit) @48cbd63   07/31/18 05:19:33 Sebastian Huber bsp/riscv: Fix clock driver Do not assume that mtime is zero at boot … 5
(edit) @71284ce   08/01/18 05:41:49 Sebastian Huber bsps/sparc: Fix typo in start.S Fix typo in start.S introduced by … 5
(edit) @d906ce3   07/30/18 05:51:39 Sebastian Huber libtests: Use CONFIGURE_INIT_TASK_TABLE_SIZE Using … 5
(edit) @334e1d2   07/30/18 05:35:26 Sebastian Huber confdefs: Fix uniprocessor configuration Introduce a new internal … 5
(edit) @44c2d393   07/27/18 13:04:38 Sebastian Huber bsp/riscv: Fix inter-processor interrupts The previous version worked … 5
(edit) @cfc9573   07/27/18 12:47:17 Sebastian Huber riscv: Rework CPU counter support Update #3433. 5
(edit) @65f52d0   07/25/18 09:25:30 Sebastian Huber samples/minimum: Use default interrupt stack size Update #3433. 5
(edit) @581a0f88   07/24/18 12:47:05 Sebastian Huber bsp/riscv: Use interrupt driven NS16550 driver Update #3433. 5
(edit) @adede135   07/24/18 11:27:54 Sebastian Huber bsp/riscv: Add PLIC support Update #3433. 5
(edit) @bd560386   07/23/18 11:50:02 Sebastian Huber bsp/riscv: Add simple SMP support to clock driver This is a hack. … 5
(edit) @6552ba8   07/24/18 08:10:12 Sebastian Huber bsp/riscv: Use CPU counter btimer Update #3433. 5
(edit) @447fd89   07/20/18 11:11:04 Sebastian Huber bsp/riscv: Add basic SMP startup Update #3433. 5
(edit) @6b9ef09   07/20/18 08:57:59 Sebastian Huber riscv: Add CLINT and PLIC support The CLINT and PLIC need some … 5
(edit) @c2670de   07/20/18 07:07:40 Sebastian Huber riscv: Use wfi instruction for idle task Update #3433. 5
(edit) @f5fd8eb   07/19/18 13:12:11 Sebastian Huber bsps/riscv: Update linker-symbols.h Update #3433. 5
(edit) @dda6e06   07/19/18 12:45:47 Sebastian Huber bsp/riscv: Add reset via for SiFive? Test Finisher Update #3433. 5
(edit) @3a263a9b   07/19/18 12:38:44 Sebastian Huber bsp/riscv: Add and use riscv_fdt_get_address() Update #3433. 5
(edit) @791d9ac5   07/19/18 12:06:10 Sebastian Huber bsp/riscv: Disable HTIF support by default The HTIF is a legacy … 5
(edit) @7fe4855   07/19/18 11:58:12 Sebastian Huber bsp/riscv: Fix HTIF warnings Update #3433. 5
(edit) @8db3f0e   07/19/18 10:11:19 Sebastian Huber riscv: Rework exception handling Remove … 5
(edit) @5694b0c   07/19/18 08:15:53 Sebastian Huber riscv: New CPU_Exception_frame Use the CPU_Interrupt_frame for the … 5
(edit) @d779a1e2   07/19/18 07:35:54 Sebastian Huber riscv: Add exception codes Update #3433. 5
(edit) @5677883   07/24/18 07:09:06 Sebastian Huber score: _SMP_Inter_processor_interrupt_handler() Optimize … 5
(edit) @a1f7d7d   07/24/18 07:00:18 Sebastian Huber score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE() Add … 5
(edit) @406dd62   07/24/18 09:18:27 Sebastian Huber _SMP_Start_multitasking_on_secondary_processor() Pass current … 5
(edit) @4678d1a   07/24/18 08:50:39 Sebastian Huber bsps: bsp_start_on_secondary_processor() Pass current processor … 5
(edit) @0d362ff3   07/23/18 12:54:51 Sebastian Huber score: _SMP_Inter_processor_interrupt_handler() Pass current … 5
(edit) @f8d00a3   07/25/18 06:00:22 Sebastian Huber tm27: Fix prototype warnings 5
(edit) @05259de1   07/25/18 07:54:56 Sebastian Huber powerpc: Fix _CPU_Instruction_illegal() Apparently the .word … 5
(edit) @caccc5b   07/24/18 09:35:09 Sebastian Huber bsps: Fix function declaration warnings 5
(edit) @91f39a5   07/24/18 09:56:25 Sebastian Huber smptests: Fix format warnings 5
(edit) @bf199e0c   07/24/18 10:47:26 Sebastian Huber block05: Remove unused variable 5
(edit) @bded3f05   07/24/18 10:46:32 Sebastian Huber psxthreadname01: Fix out of bounds memory access 5
(edit) @001b9925   07/24/18 10:46:02 Sebastian Huber psxtimer02: Fix parameter type cast 5
(edit) @f133386   07/24/18 10:45:43 Sebastian Huber sptests/sp20: Remove unused variable 5
(edit) @c192109f   07/24/18 08:06:20 Sebastian Huber samples: Fix warnings 5
(edit) @61c51db   07/24/18 06:25:35 Sebastian Huber bsp/beagle: Fix warnings 5
(edit) @3a646426   07/19/18 10:53:34 Sebastian Huber score: Add _CPU_Instruction_illegal() On some … 5
(edit) @b74353e   07/20/18 06:06:46 Sebastian Huber score: Add _CPU_Instruction_no_operation() This helps to reduce the … 5
(edit) @42f2fdfd   07/20/18 05:56:43 Sebastian Huber score: Move context validation declarations The context validation … 5
(edit) @248ca7a   07/20/18 07:10:29 Sebastian Huber score: Remove obsolete CPU port defines 5
(edit) @1554a8c5   07/20/18 06:47:25 Sebastian Huber dtc: Update VERSION 5
(edit) @ec2de39   07/19/18 06:19:43 Sebastian Huber libfdt: fdt_address_cells() and fdt_size_cells() Add internal … 5
(edit) @513daa3   07/19/18 11:06:49 Sebastian Huber capture: Include missing header file 5
(edit) @b4f15d8   07/19/18 05:10:26 Sebastian Huber jffs2: Rename README to VERSION This makes it easer to find files … 5
(edit) @2af004e   07/18/18 07:32:28 Sebastian Huber dtc: Add VERSION file Close #3471. 5
(edit) @80eaf45   07/09/18 04:50:38 david libfdt: Add necessary header padding in fdt_create() At present … 5
(edit) @4fd05d3   07/07/18 19:57:19 sjg libfdt: Copy the struct region in fdt_resize() At present this … 5
(edit) @78ad048   06/21/18 05:32:40 david libfdt: Add helpers for accessing unaligned words This adds some … 5
