Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @af231b4   12/06/97 15:43:26 Joel Sherrill Removed need for -follow option to find. 4.104.114.84.95
(edit) @ccb806c   12/06/97 15:12:07 Joel Sherrill Changed the uuencode line to work better with VPATH setups. 4.104.114.84.95
(edit) @01a5f6b2   12/06/97 15:09:30 Joel Sherrill Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were … 4.104.114.84.95
(edit) @b5fe39d   12/04/97 18:38:33 Joel Sherrill Reworked mkdir line to invoke smaller lines. 4.104.114.84.95
(edit) @744df795   12/04/97 18:38:05 Joel Sherrill Added better/more correct support for Linux and Solaris simulators. 4.104.114.84.95
(edit) @3013e18   12/02/97 16:27:15 Jennifer.Averett Modified SPARC to PowerPC. Modified specific requirements to be for … 4.104.114.84.95
(edit) @bfad6e2   12/02/97 16:02:45 Jennifer.Averett Added definations for serial_per_sec, serial_rate, and serial_xon_xoff. 4.104.114.84.95
(edit) @ba2d45e6   12/02/97 15:38:10 Jennifer.Averett Modified referances to SPARC to PowerPC. Updated the Information … 4.104.114.84.95
(edit) @7150f00f   12/01/97 22:06:48 Joel Sherrill Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto Romano … 4.104.114.84.95
(edit) @ba1a2af9   12/01/97 21:27:24 Joel Sherrill Fixed test for RTEMS_HAS_POSIX_API so the executive POSIX API related … 4.104.114.84.95
(edit) @b9ca4ba   12/01/97 17:07:52 Joel Sherrill Even more cleanup to make sure all the --enable/disable options avoid … 4.104.114.84.95
(edit) @f4cec63d   11/30/97 18:36:52 Joel Sherrill Since test suite Makefiles are not always generated, use wildcard to … 4.104.114.84.95
(edit) @0f39365   11/30/97 18:36:13 Joel Sherrill Corrected call to rtems_termios_open. 4.104.114.84.95
(edit) @68732ef3   11/30/97 18:35:22 Joel Sherrill Corrected comment. 4.104.114.84.95
(edit) @1f3ec87   11/30/97 18:34:29 Joel Sherrill Do not generate make/os at install point. 4.104.114.84.95
(edit) @37717818   11/30/97 18:34:11 Joel Sherrill Serious cleanup to reduce the number of explicitly listed Makefiles, … 4.104.114.84.95
(edit) @bbb2816   11/29/97 18:21:00 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @b4dfd17e   11/29/97 18:20:36 Joel Sherrill Added credit for host.cfg stuff from Ralf Corsepius … 4.104.114.84.95
(edit) @1670eede   11/29/97 18:20:04 Joel Sherrill Changes from Ralf Corsepius (corsepiu@…) to automatically … 4.104.114.84.95
(edit) @80868140   11/29/97 17:51:27 Joel Sherrill Patch from Chris Johns to filter out the trace bit on CPU models which … 4.104.114.84.95
(edit) @61fc72c   11/18/97 22:33:32 Joel Sherrill Removed warning. 4.104.114.84.95
(edit) @91daf55   11/18/97 22:33:17 Joel Sherrill New file. 4.104.114.84.95
(edit) @c7ca28cf   11/18/97 22:32:55 Joel Sherrill Removed warning under linux port. 4.104.114.84.95
(edit) @ce41c5b   11/18/97 22:32:38 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @405829bd   11/18/97 22:32:25 Joel Sherrill Added argument as required by new version of termios_open. 4.104.114.84.95
(edit) @53cea31   11/18/97 22:32:00 Joel Sherrill Fixed assignment to dereference ch. 4.104.114.84.95
(edit) @d54de3f   11/18/97 22:31:37 Joel Sherrill Changed from DOS style CR/LF to Unix style. 4.104.114.84.95
(edit) @cb4cf6a7   11/18/97 22:30:51 Joel Sherrill Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request. 4.104.114.84.95
(edit) @a50148a   11/18/97 22:29:32 Joel Sherrill Merged code from Ralf Corsepius <corsepiu@…> to generate … 4.104.114.84.95
(edit) @83bb778   11/18/97 22:28:45 Joel Sherrill Modified to rezongize CPU-rtemsXYZ rather than just CPU-rtems. 4.104.114.84.95
(edit) @b5ddb74   11/18/97 22:28:13 Joel Sherrill Submitted by Ralf Corsepius <corsepiu@…>. 4.104.114.84.95
(edit) @d24ceb3   11/15/97 18:15:36 Joel Sherrill interrupt driven change from Eric Norum 4.104.114.84.95
(edit) @a307f79   11/10/97 17:50:50 Joel Sherrill Fixed prototype 4.104.114.84.95
(edit) @52e1708   11/10/97 17:31:11 Joel Sherrill Set return code to avoid spurious errors. 4.104.114.84.95
(edit) @87926ab   10/31/97 19:44:42 Joel Sherrill Test document. 4.104.114.84.95
(edit) @f70c6adc   10/31/97 19:44:32 Joel Sherrill New test file. 4.104.114.84.95
(edit) @2744eec   10/31/97 19:44:23 Joel Sherrill Replaced the algorithm used to build the texinfo nodes and menus. … 4.104.114.84.95
(edit) @5a5bd13b   10/24/97 19:29:01 Joel Sherrill added katsutoshi Shibuya 4.104.114.84.95
(edit) @51eb8d5   10/23/97 18:49:34 Joel Sherrill Changed prototype of read routine. 4.104.114.84.95
(edit) @87d3d02   10/23/97 18:49:02 Joel Sherrill Switched to new style for read support routine. 4.104.114.84.95
(edit) @cfefaa6e   10/23/97 18:48:35 Joel Sherrill Added TOD driver from Katsutoshi Shibuya. 4.104.114.84.95
(edit) @51961e4   10/23/97 18:48:01 Joel Sherrill Removed GEN68360_INIT. 4.104.114.84.95
(edit) @4106f7f   10/23/97 18:47:43 Joel Sherrill Update from Eric Norum. 4.104.114.84.95
(edit) @aa239a7   10/23/97 18:47:23 Joel Sherrill Updated console driver to use new read routine conventions. 4.104.114.84.95
(edit) @208a922c   10/23/97 18:46:03 Joel Sherrill Added TOD code for MVME162 BSP from Katsutoshi Shibuya. 4.104.114.84.95
(edit) @514cf30   10/23/97 15:12:46 Joel Sherrill Added new test for termios style consoles from Eric Norum. 4.104.114.84.95
(edit) @5993d02   10/23/97 15:12:08 Joel Sherrill Added console_reserve_resources. 4.104.114.84.95
(edit) @edd1329f   10/23/97 15:11:27 Joel Sherrill Overhauled console driver to use termios and to simultaneously support … 4.104.114.84.95
(edit) @b628637   10/23/97 15:10:13 Joel Sherrill Added prototype for console_reserve_resources. 4.104.114.84.95
(edit) @ee9669f   10/23/97 15:09:50 Joel Sherrill Added termios test. 4.104.114.84.95
(edit) @3ee825e8   10/23/97 15:00:32 Joel Sherrill fixed comment 4.104.114.84.95
(edit) @118a812   10/23/97 13:13:46 Joel Sherrill New termios.c from Eric Norum. Added new entry point to add in per … 4.104.114.84.95
(edit) @3dbcece   10/21/97 18:41:36 Joel Sherrill Added test case for rtems_interrupt_catch checking that the pointer … 4.104.114.84.95
(edit) @a18ccfe   10/21/97 18:39:49 Joel Sherrill Fixed a number of warnings regarding comparisons between signed and … 4.104.114.84.95
(edit) @4822069   10/21/97 18:39:27 Joel Sherrill Fixed endian problem in printing object names. 4.104.114.84.95
(edit) @a7e2729   10/21/97 18:38:24 Joel Sherrill Converted to termios style device driver. 4.104.114.84.95
(edit) @cdfd74a5   10/21/97 18:37:58 Joel Sherrill Added check that return argument pointer for old_isr_handler was valid. 4.104.114.84.95
(edit) @d7072e5   10/21/97 18:37:32 Joel Sherrill Moved rtems directory up one directory in the install point. It was … 4.104.114.84.95
(edit) @97faafa5   10/21/97 18:36:48 Joel Sherrill Added termios submission from Eric Norum and Katsutoshi Shibuya. 4.104.114.84.95
(edit) @a75c783   10/21/97 17:03:18 Joel Sherrill Converted from using a message queue for the raw input queue to using … 4.104.114.84.95
(edit) @55e1322   10/21/97 17:03:17 Joel Sherrill Added termios submission from Eric Norum and Katsutoshi Shibuya. 4.104.114.84.95
(edit) @ae35953d   10/21/97 16:18:03 Joel Sherrill Added termios submission from Eric Norum and Katsutoshi Shibuya. 4.104.114.84.95
(edit) @4fd61795   10/21/97 16:17:12 Joel Sherrill Added casts and fixed line break. 4.104.114.84.95
(edit) @f33a3f2a   10/16/97 21:06:47 Joel Sherrill Control and Data addresses were swapped for port A. 4.104.114.84.95
(edit) @d17d4d2f   10/15/97 21:27:00 Joel Sherrill Moved selection of console port to custom file. 4.104.114.84.95
(edit) @84ff8b7b   10/13/97 17:38:18 Joel Sherrill New version of this file from Eric Norum. 4.104.114.84.95
(edit) @d9fe8e2   10/09/97 20:21:43 Joel Sherrill Fixed some spacing. 4.104.114.84.95
(edit) @f00108f   10/09/97 18:35:02 Joel Sherrill Fixed incorrect reference to RTEMS_BSP instead of RTEMS_BSP_FAMILY. 4.104.114.84.95
(edit) @a86443fb   10/09/97 18:33:46 Joel Sherrill Added search of libcpu and fpsp. 4.104.114.84.95
(edit) @c3a0358   10/08/97 20:09:58 Joel Sherrill Renamed mlink to make_subdir. Removed a junk line. 4.104.114.84.95
(edit) @b546242   10/08/97 19:52:47 Joel Sherrill Modified to search RTEMS library before Newlib C library. 4.104.114.84.95
(edit) @58e3dc79   10/08/97 18:25:30 Joel Sherrill Fix from Eric Norum so FPSP is installed before any FP code is … 4.104.114.84.95
(edit) @89f5f5a1   10/08/97 18:23:58 Joel Sherrill Fix from Eric Norum to assemble under COFF. 4.104.114.84.95
(edit) @7de0960   10/08/97 18:19:43 Joel Sherrill Update from Eric Norum: Change label names so they can be … 4.104.114.84.95
(edit) @6fd3979   10/08/97 17:57:04 Joel Sherrill Added comment about using --enable-gcc28 and --enable-libcdir options … 4.104.114.84.95
(edit) @98e4ebf5   10/08/97 15:45:54 Joel Sherrill Fixed typo in the pointer to the license terms. 4.104.114.84.95
(edit) @a2016b99   10/08/97 14:42:08 Joel Sherrill Removed include directory at "build" point and the link of this … 4.104.114.84.95
(edit) @f05f704   10/08/97 14:06:17 Joel Sherrill Updated information on building your own application. 4.104.114.84.95
(edit) @f5afb69   10/08/97 14:05:38 Joel Sherrill Reworked building of make subdirectory and contents in the object tree. 4.104.114.84.95
(edit) @0c618b67   10/07/97 20:47:49 Joel Sherrill Redid the installation of the "make" directory at the install point. … 4.104.114.84.95
(edit) @3a321e23   10/06/97 21:32:47 Joel Sherrill Fixed some weird line duplications. Thanks to Chris Johns. 4.104.114.84.95
(edit) @ffa6183   10/06/97 21:30:16 Joel Sherrill Increased interrupt stack space. 4.104.114.84.95
(edit) @b6770d1   10/06/97 21:29:29 Joel Sherrill Fixed comment. 4.104.114.84.95
(edit) @7e4938c   10/06/97 21:28:40 Joel Sherrill Make Post an atomic operation. 4.104.114.84.95
(edit) @d14418b   10/06/97 21:28:18 Joel Sherrill Added _Thread_Enable_dispatch to already_timedout path on Wait_support. 4.104.114.84.95
(edit) @7d5566e   10/06/97 21:26:11 Joel Sherrill Fixed bug where include not actually created. 4.104.114.84.95
(edit) @e8ee2f32   10/05/97 16:26:04 Joel Sherrill If the specified time period is less than a clock tick, then it is … 4.104.114.84.95
(edit) @8959fcc   09/30/97 14:49:56 Joel Sherrill fixed typo 4.104.114.84.95
(edit) @63cebf6   09/30/97 14:44:28 Joel Sherrill Fixed typos. 4.104.114.84.95
(edit) @f795ca90   09/21/97 17:44:50 Joel Sherrill Uncommented gettimeofday_r to resolve missing symbol. 4.104.114.84.95
(edit) @8cd3748   09/21/97 17:44:14 Joel Sherrill Removed duplicate listing of install in MTARGETS. Add monitor test. 4.104.114.84.95
(edit) @5beb562   09/21/97 16:58:57 Joel Sherrill Cleaned up as part of adding the Monitor test. 4.104.114.84.95
(edit) @f37e656d   09/21/97 16:57:46 Joel Sherrill Added Monitor test. 4.104.114.84.95
(edit) @8f367d6b   09/19/97 18:31:05 Joel Sherrill Bug fix from Eric Norum: After weeks of trying to figure why my … 4.104.114.84.95
(edit) @6b4ca31   09/18/97 16:01:52 Joel Sherrill Merged changes from Eric Norum: Enable 68360 watchdog. The … 4.104.114.84.95
(edit) @a72e3dd   09/16/97 13:08:58 Joel Sherrill updated 4.104.114.84.95
(edit) @fc4675f0   09/15/97 19:01:33 Joel Sherrill syslog added 4.104.114.84.95
(edit) @8f35817   09/15/97 18:52:26 Joel Sherrill eliminated potential for overfilling buffer on read 4.104.114.84.95
(edit) @8d05346   09/03/97 22:05:51 Joel Sherrill Fix from Eric Norum. Here is the comment: Enable SDMA … 4.104.114.84.95
(edit) @cf5ef6d   09/03/97 15:36:05 Joel Sherrill More specific information on error code. 4.104.114.84.95
