Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @9d0e65ed   02/07/05 13:19:45 Ralf Corsepius 2005-02-07 Ralf Corsepius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @4d3b1bb   02/07/05 13:16:15 Ralf Corsepius 2005-02-07 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @4fabd645   02/05/05 20:08:45 WENorum Fix typo. 4.104.114.84.95
(edit) @0eff7b8   02/05/05 19:58:45 WENorum Clean up the RAM/FLASH sizes/locations are specified. 4.104.114.84.95
(edit) @dbcb60a   02/05/05 02:49:02 Ralf Corsepius 2005-02-05 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @3d289f12   02/05/05 02:44:29 Ralf Corsepius 2005-02-05 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @fa39b174   02/04/05 20:29:42 WENorum Fix flash base address. Enable UART2. 4.104.114.84.95
(edit) @f5df587   02/04/05 16:35:30 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @4c92297a   02/04/05 16:35:05 Ralf Corsepius Misc. part. updates from FreeBSD. 4.104.114.84.95
(edit) @35e60150   02/04/05 16:27:16 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @de3311c   02/04/05 16:25:44 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @7cb25eb   02/04/05 16:19:59 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * make/bsp.mak: … 4.104.114.84.95
(edit) @f2a95293   02/04/05 16:18:45 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @d88c378   02/04/05 16:15:06 Ralf Corsepius Reformat. 4.104.114.84.95
(edit) @b1e04829   02/04/05 16:13:18 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @a7e6bc96   02/04/05 15:37:04 WENorum Clean up INTC0 initialization. EPORT1-7 sources are fixed level/priority. 4.104.114.84.95
(edit) @f7d4f0a   02/04/05 15:09:56 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @e7541849   02/04/05 15:09:39 Ralf Corsepius Use rtems_id for semaphores. 4.104.114.84.95
(edit) @a29d2e7   02/04/05 14:58:01 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @75a7f31   02/04/05 14:57:00 Ralf Corsepius New. 4.104.114.84.95
(edit) @376dfb1a   02/04/05 13:32:20 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @4bf6a9f2   02/04/05 12:47:44 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @f26145b   02/04/05 12:40:16 Ralf Corsepius 2005-02-03 Ralf Corsepius <ralf.corsepius@…> PR 756/rtems * … 4.104.114.84.95
(edit) @f26a9760   02/04/05 12:28:48 Ralf Corsepius New. 4.104.114.84.95
(edit) @0b2c943   02/04/05 08:46:43 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @be129f69   02/04/05 08:43:39 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @f6ed46df   02/04/05 05:40:52 Ralf Corsepius Header guards cleanup. 4.104.114.84.95
(edit) @b5cdddf   02/04/05 05:38:26 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @fa6b0f5   02/04/05 05:36:20 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @1f24914a   02/04/05 05:25:15 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> PR 754/rtems * … 4.104.114.84.95
(edit) @3479b8b1   02/04/05 00:40:43 Joel Sherrill Fixed formatting. 4.104.114.84.95
(edit) @d75023e   02/03/05 22:52:26 WENorum Add 'extended' BSP support (pseudo-VME) 4.104.114.84.95
(edit) @f8ac4fc7   02/03/05 22:08:15 WENorum Add memory probe support. 4.104.114.84.95
(edit) @f92f5f6   02/03/05 17:13:10 Ralf Corsepius 2005-02-03 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @2538e7ae   02/03/05 16:26:35 Ralf Corsepius 2005-02-03 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @5b6111b   02/03/05 16:01:04 WENorum Add support for interrupt controller allocation. This will provides a … 4.104.114.84.95
(edit) @0c20a46   02/03/05 15:58:18 Ralf Corsepius 2005-02-03 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @abb63593   02/03/05 06:46:57 Ralf Corsepius 2005-02-03 Ralf Corsepius <ralf.corsepius@…> PR 755/rtems * … 4.104.114.84.95
(edit) @e3022f5d   02/03/05 06:44:35 Ralf Corsepius Fix PR nr. in previous changelog entry. 4.104.114.84.95
(edit) @b90307a   02/03/05 05:49:30 Ralf Corsepius 2005-02-03 Ralf Corsepius <ralf.corsepius@…> PR 755/rtems * … 4.104.114.84.95
(edit) @4787739   02/03/05 05:35:38 Ralf Corsepius 2005-02-03 Ralf Corsepius <ralf.corsepius@…> PR 755/rtems * … 4.104.114.84.95
(edit) @2d9d8ff6   02/03/05 05:34:01 Ralf Corsepius New. 4.104.114.84.95
(edit) @2c2f7b6   02/03/05 05:33:38 Ralf Corsepius New (BSD compatibility). 4.104.114.84.95
(edit) @98653c6   02/02/05 19:55:59 WENorum Lock FEC/PHYS at 100 Mbs, full-duplex. 4.104.114.84.95
(edit) @12993b3   02/02/05 14:17:26 WENorum Clean up bootloader syscall handling. 4.104.114.84.95
(edit) @dd2f891   02/02/05 14:17:11 WENorum Provide 'last-ditch' hardware address. 4.104.114.84.95
(edit) @3f10bb3   02/02/05 10:12:47 Ralf Corsepius 2005-02-02 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @c58c2ca   02/02/05 10:11:10 Ralf Corsepius New header guards. 4.104.114.84.95
(edit) @6d4ffbb   02/02/05 10:08:05 Ralf Corsepius 2005-02-02 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @48e7abe6   02/02/05 09:59:50 Ralf Corsepius 2005-02-02 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @4aa8a23   02/02/05 03:06:41 Ralf Corsepius Include config.h. 4.104.114.84.95
(edit) @de462dd7   02/02/05 02:34:52 Ralf Corsepius 2005-02-02 Ralf Corsepius <ralf.corsepius@…> PR rtems/752 * … 4.104.114.84.95
(edit) @eca06939   02/02/05 02:34:03 Ralf Corsepius Remove. 4.104.114.84.95
(edit) @771c34d9   02/02/05 02:33:24 Ralf Corsepius New header guard. 4.104.114.84.95
(edit) @68f36fee   02/02/05 02:29:01 Ralf Corsepius 2005-02-02 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @043329e   02/02/05 01:21:05 WENorum Add interrupt assignment map. 4.104.114.84.95
(edit) @ce92867b   02/02/05 00:06:18 Joel Sherrill 2005-02-01 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @1d386ff   02/01/05 22:36:53 WENorum Want only two serial ports for now. 4.104.114.84.95
(edit) @c60eccb   02/01/05 20:05:00 WENorum Add EPICS information. 4.104.114.84.95
(edit) @7eab0f78   02/01/05 17:16:41 WENorum Add some bootrom system calls. 4.104.114.84.95
(edit) @891aa12e   02/01/05 16:06:39 Ralf Corsepius 2005-02-01 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @5236cf04   02/01/05 15:15:45 Ralf Corsepius 2005-02-01 Ralf Corsepius <ralf.corsepius@…> PR rtems/752 * … 4.104.114.84.95
(edit) @824efb6   02/01/05 15:15:33 Ralf Corsepius Remove. 4.104.114.84.95
(edit) @50fea8b   02/01/05 15:15:08 Ralf Corsepius New header guards 4.104.114.84.95
(edit) @7c7184a   02/01/05 15:12:55 WENorum Place FEC buffer descriptors in static RAM. No more cache concerns. 4.104.114.84.95
(edit) @7a6d1a3   02/01/05 15:11:11 Joel Sherrill 2005-02-01 Joel Sherrill <joel@…> * mcf5282/.cvsignore: … 4.104.114.84.95
(edit) @b41906f   02/01/05 01:02:51 Ralf Corsepius 2005-01-31 Ralf Corsepius <ralf.corsepius@…> PR rtems/752 * … 4.104.114.84.95
(edit) @671edd96   02/01/05 01:01:53 Ralf Corsepius Remove. 4.104.114.84.95
(edit) @9c858e56   01/31/05 22:21:19 Joel Sherrill 2005-01-31 Sergei Organov <osv@…> PR 771/pppd * … 4.104.114.84.95
(edit) @fa5dfe8   01/31/05 19:04:33 WENorum Remove diagnostic printf. 4.104.114.84.95
(edit) @518edef   01/31/05 19:03:41 WENorum Processor doesn't snoop FEC DMA so we must invalidate the cache … 4.104.114.84.95
(edit) @9be8c2d   01/31/05 18:59:24 WENorum Add ColdFire? cache information. 4.104.114.84.95
(edit) @7a2ebd3   01/31/05 14:37:51 Joel Sherrill Move entry to appropriate sub-ChangeLogs?. 4.104.114.84.95
(edit) @5579a28   01/31/05 14:37:33 Joel Sherrill 2005-01-28 Eric Norum <norume@…> * m68kpretaskinghook.c: … 4.104.114.84.95
(edit) @239b819   01/31/05 14:37:03 Joel Sherrill 2005-01-31 Joel Sherrill <joel@…> * .cvsignore: New file. 4.104.114.84.95
(edit) @098c4f9a   01/31/05 14:37:00 Joel Sherrill New file. 4.104.114.84.95
(edit) @d5f0a05   01/28/05 23:03:17 WENorum printk really does work! 4.104.114.84.95
(edit) @547b04f   01/28/05 19:52:19 WENorum Remove dead variable. 4.104.114.84.95
(edit) @fa9fa1e4   01/28/05 19:48:25 WENorum ColdFire? ISA A+ instructions. 4.104.114.84.95
(edit) @ed71774a   01/28/05 19:42:09 WENorum New BSP/CPU. 4.104.114.84.95
(edit) @dfbfe5df   01/28/05 19:38:47 WENorum Cosmetic. 4.104.114.84.95
(edit) @362c2bc2   01/28/05 19:38:20 WENorum New BSP. 4.104.114.84.95
(edit) @572484f   01/28/05 19:35:23 WENorum New BSP for Arcturus uCDIMM ColdFire? 5282. 4.104.114.84.95
(edit) @a69fb0c6   01/28/05 16:44:00 Joel Sherrill 2005-01-28 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @a30a08a   01/28/05 16:06:09 Ralf Corsepius New header guards. 4.104.114.84.95
(edit) @8e7f1a1   01/28/05 16:05:30 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * … 4.104.114.84.95
(edit) @7f70d1b7   01/28/05 15:56:09 Ralf Corsepius New header guard. 4.104.114.84.95
(edit) @86c827bd   01/28/05 15:53:44 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @e03ac8d   01/28/05 15:53:42 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @de7ebd06   01/28/05 15:53:40 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @731ea704   01/28/05 15:53:38 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @5592508   01/28/05 15:53:36 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @a8cb90e   01/28/05 15:53:34 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @5ff0481   01/28/05 15:53:32 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @c47d5214   01/28/05 15:53:29 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @1b6f58d   01/28/05 15:53:27 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @3a648a06   01/28/05 15:53:25 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @4c676d89   01/28/05 15:53:23 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @495a646   01/28/05 15:53:21 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
(edit) @60f6375c   01/28/05 15:53:18 Ralf Corsepius 2004-01-28 Ralf Corsepius <ralf.corsepiu@…> * asm.h, … 4.104.114.84.95
