@98cc00e6
11/07/18 18:07:53 |
joel |
psxtmonce01/init.c: Use static and Simple Console
5
@e94b73f
11/07/18 13:28:55 |
Sebastian Huber |
config: Include <rtems.h> for RTEMS_NEWLIB
5
@97a86719
11/06/18 15:57:21 |
Sebastian Huber |
config: Move definitions after includes
5
@2faea99
11/07/18 10:08:50 |
Sebastian Huber |
bsp/realview-pbx-a9: Fix printk() support
Avoid dependencies on the …
5
@e292beba
11/07/18 09:47:48 |
Sebastian Huber |
termios: Move default lock functions
Move …
5
@d1f7204
11/06/18 12:04:11 |
Sebastian Huber |
config: Fix CONFIGURE_DISABLE_NEWLIB_REENTRANCY
Move the getreent() …
5
@e71c097a
11/06/18 11:57:42 |
Sebastian Huber |
spconfig02: Check object methods in default config
Ensure that the …
5
@a818d13c
11/07/18 06:43:38 |
Sebastian Huber |
build: Remove superfluous psxtmonce01/Makefile.am
5
@99d6172
11/07/18 00:50:38 |
zenon.hans.taneka |
Correct minor spelling and grammar errors
This work was performed as …
5
@9bb39516
11/06/18 18:29:10 |
himanshuwindows8.1 |
psxtmonce01: New test written by Himanshu40 as part of GCI2018
5
@878487b0
11/05/18 08:53:04 |
Sebastian Huber |
score: Optimize Objects_Information
Reduce structure internal …
5
@d7c51da
11/05/18 20:48:20 |
Gedare Bloom |
altera-cyclone-v: tweak ingroup
5
@3b930548
11/03/18 20:45:50 |
44733601+ABR290B |
arm/altera-cyclone-v: update doxygen (GCI 2018)
5
@fa0adf36
10/30/18 10:53:46 |
Sebastian Huber |
ftpd: Avoid TOCTOU problem
Assume that opendir() returns only …
5
@8c3cd1e8
10/30/18 10:34:16 |
Sebastian Huber |
ftpd: Deal with too long command lines
Update #3530.
5
@706802f8
10/30/18 08:35:06 |
Sebastian Huber |
ftpd: Make send_dirline() more robust
Account for large file names.
5
@7e2aabd7
10/30/18 12:23:57 |
Sebastian Huber |
config: Fix check networking
This Autoconf macro used cache variables …
5
@bb3484c9
10/29/18 07:59:45 |
Sebastian Huber |
posix: Enable more sptests test cases by default
Update #2514.
5
@8dc1ed1
10/25/18 12:08:26 |
Sebastian Huber |
posix: Enable more psxtests by default
Update #2514.
5
@24f3e8f
10/25/18 12:02:23 |
Sebastian Huber |
posix: Enable more smptests tests by default
Update #2514.
5
@ef16a11
10/25/18 09:05:12 |
Sebastian Huber |
posix: Enable psxtmtests tests by default
Update #2514.
5
@54f35888
10/25/18 08:54:12 |
Sebastian Huber |
posix: Provide threads by default
Update #2514.
5
@033f31c8
10/25/18 08:26:40 |
Sebastian Huber |
posix: Hide POSIX_API_Control by default
Update #2514.
5
@fe7aefd5
10/25/18 08:12:39 |
Sebastian Huber |
posix: Provide message queues by default
Update #2514.
5
@701057e0
10/25/18 08:07:46 |
Sebastian Huber |
posix: Provide shared memory objects by default
Update #2514.
5
@9318cfb0
10/14/18 10:43:13 |
Sebastian Huber |
posix: Provide named semaphores by default
Update #2514.
5
@e97806a
10/14/18 17:20:05 |
Sebastian Huber |
posix: Split posix_api_configuration_table
Use separate configuration …
5
@55b69ed
10/15/18 06:33:45 |
Sebastian Huber |
Move default config to librtemsdefaultconfig.a
An RTEMS application …
5
@7038271
10/25/18 10:05:53 |
Sebastian Huber |
Remove RTEMS_SCORE_OBJECT_ENABLE_STRING_NAMES
Enable support for …
5
@5090a71b
10/25/18 09:32:01 |
Sebastian Huber |
score: Remove bogus thread object name support
Update #2514.
5
@0dbf67b
10/25/18 12:37:08 |
Sebastian Huber |
posix: Provide aio_suspend() by default
Update #2514.
5
@135cb10
10/25/18 07:56:02 |
Sebastian Huber |
posix: Provide more functions by default
Update #2514.
5
@4a7be22
10/25/18 08:03:46 |
Sebastian Huber |
posix: Fix build with POSIX API disabled
Update #2514.
5
@24b5807
10/24/18 05:35:51 |
Sebastian Huber |
config: Modify CONFIGURE_INTERRUPT_STACK_SIZE
Use …
5
@4b801ac
10/24/18 05:54:27 |
Sebastian Huber |
posix: Provide simple thread functions by default
Update #2514.
5
@c1ce9a2
10/24/18 05:40:23 |
Sebastian Huber |
posix: Provide get thread attributes by default
Update #2514.
5
@522d4b91
10/24/18 05:16:46 |
Sebastian Huber |
malloctest: Hide NULL pointer from compiler
Disabling a warning does …
5
@01595a4
10/24/18 08:17:58 |
Sebastian Huber |
bsp/imx: Adjust workspace according to device tree
5
@8ba76b9
10/12/18 15:20:39 |
Sebastian Huber |
tmonetoone: Add yield test case
5
@8d81622
10/14/18 15:10:32 |
Sebastian Huber |
posix: Provide non-thread functions by default
Update #2514.
5
@0b2808ce
10/14/18 10:41:22 |
Sebastian Huber |
posix: Provide scheduler support by default
Update #2514.
5
@dd804bb
10/14/18 10:36:22 |
Sebastian Huber |
posix: Provide cancel state/type by default
Sort POSIX sources …
5
@6da1bb0
10/18/18 12:58:31 |
Sebastian Huber |
Remove superfluous configure checks
The results of these checks are …
5
@167654e
10/18/18 12:45:24 |
Sebastian Huber |
Remove checks for flockfile(), etc. declarations
Declarations …
5
@f59edebf
10/18/18 12:39:09 |
Sebastian Huber |
Remove getcwd()
This function is provided by Newlib since 2000.
5
@79d145a7
10/18/18 12:36:44 |
Sebastian Huber |
Remove optional getrusage() declaration
Declaration provided by …
5
@e161767e
10/18/18 12:33:58 |
Sebastian Huber |
Remove ttyname()
5
@658ec75
10/18/18 12:28:17 |
Sebastian Huber |
Remove assert()
5
@87a9900f
10/18/18 12:22:46 |
Sebastian Huber |
Remove isatty()
These functions are provided by Newlib since 2000.
5
@3cf12c9
10/18/18 12:11:10 |
Sebastian Huber |
Remove strlcat(), strlcpy(), strsep(), readdir_r()
These functions …
5
@1ad26cd
10/18/18 10:38:58 |
Sebastian Huber |
Support O_NOFOLLOW open() flag
Close #3546.
5
@3825926
10/18/18 09:51:32 |
Sebastian Huber |
Support O_CLOEXEC open() flag
Make sure this flag is ignored and does …
5
@92e0eed
10/22/18 05:58:44 |
Sebastian Huber |
psxreaddir: Adjust test due to opendir() changes
Update #3545.
5
@b4043ea
09/24/18 14:32:49 |
joel |
check-networking.m4: Disable legacy stack for x86_64 and epiphany
5
@28fb5b71
09/05/18 23:02:30 |
joel |
mpc8260ads/start/bspstart.c: Fix unused function warning
5
@c1233a33
09/04/18 13:35:37 |
joel |
qemuppc/start/cmain.c: Cast args to memcpy and bzero to fix warnings
5
@156b77a
09/04/18 13:35:07 |
joel |
gen5200/mscan/mscan.c: Fix printf() format warning
5
@023bd1d
09/04/18 13:34:42 |
joel |
or1k/shared/cache/cache.c: Remove unused methods
5
@35eab84
09/04/18 13:34:22 |
joel |
gdbarmsim/include/bsp.h: Include <sys/stat.h> to fix warning
5
@4af18b3
10/11/18 08:51:21 |
Sebastian Huber |
Support O_DIRECTORY open() flag
Close #3545.
5
@68799dac
10/18/18 05:22:44 |
Sebastian Huber |
bsp/atsam: Add const qualifier to AES_SetInput()
5
@c980eaf
10/16/18 12:35:12 |
Sebastian Huber |
console: Be fair in simple console read
Wait for one tick in case no …
5
@143c8d0
10/17/18 07:43:55 |
Sebastian Huber |
serial/ns16550: Fix precision clock synthesizer
The precision clock …
5
@d7c13c8
10/16/18 12:34:38 |
Sebastian Huber |
bsp/imx7: Add getchark() support
5
@186a0b1
10/15/18 08:38:49 |
Sebastian Huber |
bsps/arm: Recognize .tm_clone_table input section
5
@1822649
10/15/18 06:44:52 |
pisa |
bsp/tms570: Simple fix to resolve macro redefinitions.
closes #3347
5
@fb12215
10/15/18 05:22:42 |
Sebastian Huber |
build: Remove specialized CPPFLAGS
Close #3375.
5
@632bb17
10/14/18 21:55:38 |
joel |
libtests/Makefile.am: Add CPU_CFLAGS to rtems-ld invocation
closes …
5
@cca7c40
10/12/18 12:48:45 |
Sebastian Huber |
tmtests: Fix unused variable warnings
5
@47b32a0
10/12/18 12:45:24 |
Sebastian Huber |
fsclose01: Fix uninitialized variable warning
5
@c6023b7
10/12/18 12:40:52 |
Sebastian Huber |
posix: Fix unused result warning
5
@9d1f17a9
10/11/18 17:34:35 |
Sebastian Huber |
build: Fix build on Windows
Avoid a long argument list while creating …
5
@ca056e3
10/11/18 04:12:16 |
Sebastian Huber |
tmtests/tmonetoone: New test program
5
@26b58b7e
10/10/18 11:12:50 |
Sebastian Huber |
telnetd: Add server port to configuration
Close #3543.
5
@0dc303f
10/10/18 08:40:21 |
Sebastian Huber |
telnetd: Create sessions at start
Update #3543.
5
@0f0e130
10/10/18 07:11:47 |
Sebastian Huber |
telnetd: Allocate the server context
Update #3543.
5
@bf4c7ff6
10/10/18 07:04:47 |
Sebastian Huber |
telnetd: Create server socket at start
Update #3543.
5
@1c567c5
10/09/18 13:42:42 |
Sebastian Huber |
telnetd: Rename shell_args to telnetd_session
Update #3543.
5
@6d3ec58a
10/09/18 13:31:46 |
Sebastian Huber |
telnetd: Simplify task spawn function
Use the minimum task size for …
5
@2548d14
09/10/18 15:38:14 |
Sebastian Huber |
build: Include header.am in cpukit/Makefile.am
Include all …
5
@629faf9
10/09/18 12:47:02 |
Sebastian Huber |
telnetd: Remove keep stdio feature
The Telnet service started via …
5
@477bca2
10/06/18 08:59:10 |
Sebastian Huber |
build: Remove local.am
5
@9da5d5fd
10/06/18 08:12:21 |
Sebastian Huber |
build: Directly reference libraries in tests
Remove use of …
5
@637546a
10/05/18 18:12:40 |
Sebastian Huber |
build: Merge score/cpu/*/Makefile.am
5
@96ad2b2
10/04/18 18:32:12 |
Sebastian Huber |
build: Merge libmisc/Makefile.am
5
@19b7db50
10/04/18 18:07:16 |
Sebastian Huber |
build: Merge libnetworking/Makefile.am
5
@a40bb03
10/04/18 15:58:48 |
Sebastian Huber |
build: Merge zlib/Makefile.am
5
@7f0eac30
10/04/18 15:48:23 |
Sebastian Huber |
build: Merge telnetd/Makefile.am
5
@1d93843
09/14/18 18:02:02 |
Sebastian Huber |
build: Merge score/Makefile.am
5
@640271f
09/14/18 17:55:00 |
Sebastian Huber |
build: Merge rtems/Makefile.am
5
@24312f34
09/14/18 17:51:38 |
Sebastian Huber |
build: Merge pppd/Makefile.am
5
@b3ef89f9
09/14/18 17:46:58 |
Sebastian Huber |
build: Merge posix/Makefile.am
5
@028b0ce
09/14/18 14:12:19 |
Sebastian Huber |
build: Merge mghttpd/Makefile.am
5
@a2a71b5
09/14/18 14:00:45 |
Sebastian Huber |
build: Merge libstdthreads/Makefile.am
5
@5079524
09/14/18 13:56:26 |
Sebastian Huber |
build: Merge librpc/Makefile.am
5
@c38d517
09/14/18 04:43:35 |
Sebastian Huber |
build: Merge libpci/Makefile.am
5
@e39642a4
09/14/18 04:41:27 |
Sebastian Huber |
build: Merge libmd/Makefile.am
5
@0c56264
09/14/18 04:38:50 |
Sebastian Huber |
build: Merge libi2c/Makefile.am
5
@8d677cf
09/14/18 04:35:59 |
Sebastian Huber |
build: Merge libgnat/Makefile.am
5
@b45a853
09/14/18 04:34:02 |
Sebastian Huber |
build: Merge libfs/Makefile.am
5
