Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @95c9861   12/07/08 11:26:10 Ralf Corsepius 2008-12-07 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @383871ac   12/07/08 11:25:55 Ralf Corsepius Fix typo. 4.104.115
(edit) @12f9e942   12/07/08 04:31:06 Ralf Corsepius 2008-12-07 Ralf Corsépius <ralf.corsepius@…> * bsp_specs: … 4.104.115
(edit) @3eb3c1ae   12/06/08 04:47:55 Ralf Corsepius Regenerate. 4.104.115
(edit) @b8cdbdb9   12/06/08 04:47:42 Ralf Corsepius newlib-1.16.0.cvs.20081205-rtems4.10-20081206.diff. 4.104.115
(edit) @40b6040b   12/06/08 04:46:31 Ralf Corsepius Add fix for the h8300/msx. 4.104.115
(edit) @6a614160   12/05/08 22:27:47 Joel Sherrill 2008-12-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @47ca8206   12/05/08 22:00:09 Joel Sherrill 2008-12-05 Joel Sherrill <joel.sherrill@…> * psim-shared, … 4.104.115
(edit) @3b3d0056   12/05/08 21:54:06 Joel Sherrill 2008-12-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @a7db5cd   12/05/08 19:15:47 Joel Sherrill 2008-12-05 Joel Sherrill <joel.sherrill@…> * .cvsignore: … 4.104.115
(edit) @2a0f6dc   12/05/08 13:37:47 Ralf Corsepius 2008-12-05 Ralf Corsépius <ralf.corsepius@…> * bsp_specs: … 4.104.115
(edit) @e83a477   12/05/08 13:33:20 Ralf Corsepius 2008-12-05 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.115
(edit) @8e51884   12/05/08 13:32:09 Ralf Corsepius 2008-12-05 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @dd95446   12/05/08 13:31:05 Ralf Corsepius 2008-12-05 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @d9eafed   12/05/08 13:12:26 Ralf Corsepius Regenerate. 4.104.115
(edit) @6ded73b   12/05/08 13:12:09 Ralf Corsepius gcc-core-4.3.2-rtems4.10-20081205.diff. 4.104.115
(edit) @f0c0efa4   12/05/08 13:09:59 Ralf Corsepius New. 4.104.115
(edit) @92651ada   12/05/08 13:08:45 Ralf Corsepius Regenerate. 4.104.115
(edit) @bea2a18   12/05/08 13:08:02 Ralf Corsepius GCC_RPMREL = 17, newlib-1.16.0.cvs.20081205. 4.104.115
(edit) @05ce7776   12/05/08 12:51:49 Ralf Corsepius New. 4.104.115
(edit) @08027bf   12/05/08 06:44:50 Ralf Corsepius 2008-12-05 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @1749cef   12/05/08 06:44:40 Ralf Corsepius Compile contents conditionally. 4.104.115
(edit) @73c56eea   12/05/08 06:42:51 Ralf Corsepius 2008-12-05 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @3541fe3   12/05/08 02:52:37 Ralf Corsepius 2008-12-05 Ralf Corsépius <ralf.corsepius@…> * bsp_specs: … 4.104.115
(edit) @83965d5b   12/05/08 02:51:18 Ralf Corsepius 2008-12-05 Ralf Corsépius <ralf.corsepius@…> * bsp_specs: … 4.104.115
(edit) @8f29088   12/05/08 02:49:54 Ralf Corsepius 2008-12-05 Ralf Corsépius <ralf.corsepius@…> * bsp_specs: … 4.104.115
(edit) @f6860278   12/04/08 23:04:58 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * … 4.104.115
(edit) @eeec0b82   12/04/08 23:04:26 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * … 4.104.115
(edit) @3c12db5f   12/04/08 22:57:10 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * … 4.104.115
(edit) @5485a4d7   12/04/08 22:56:09 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * Makefile.am: … 4.104.115
(edit) @74c6f36   12/04/08 22:55:42 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * ChangeLog?, … 4.104.115
(edit) @b1783062   12/04/08 22:55:13 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * ChangeLog?, … 4.104.115
(edit) @e44ffe5   12/04/08 22:54:49 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * ChangeLog?, … 4.104.115
(edit) @276abbf6   12/04/08 22:54:32 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * … 4.104.115
(edit) @15e44fd   12/04/08 22:53:33 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * … 4.104.115
(edit) @6b4d0b8   12/04/08 22:53:15 Joel Sherrill 2008-12-04 Jukka Pietarinen <jukka.pietarinen@…> * ChangeLog?, … 4.104.115
(edit) @f6c6e17d   12/04/08 21:26:44 Joel Sherrill 2008-12-04 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @df393962   12/04/08 20:34:02 Joel Sherrill 2008-12-04 Joel Sherrill <joel.sherrill@…> * bsp_specs: … 4.104.115
(edit) @212f7b0   12/04/08 20:33:50 Joel Sherrill 2008-12-04 Joel Sherrill <joel.sherrill@…> * bsp_specs, … 4.104.115
(edit) @087dd25   12/04/08 20:32:10 Joel Sherrill 2008-12-04 Joel Sherrill <joel.sherrill@…> * bsp_specs, … 4.104.115
(edit) @0a65ad6   12/04/08 20:26:45 Joel Sherrill 2008-12-04 Joel Sherrill <joel.sherrill@…> * psim-bottom, … 4.104.115
(edit) @75ed329   12/04/08 18:00:05 Joel Sherrill 2008-12-04 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @88ef1655   12/04/08 17:57:01 Joel Sherrill 2008-12-04 Joel Sherrill <joel.sherrill@…> PR 1344/bsps * … 4.104.115
(edit) @95112c5c   12/04/08 17:40:02 Ralf Corsepius 2008-12-04 Ralf Corsépius <ralf.corsepius@…> * bsp_specs: … 4.104.115
(edit) @c0b8d7b   12/04/08 17:19:03 Joel Sherrill 2008-12-04 Joel Sherrill <joel.sherrill@…> * psim-bottom, … 4.104.115
(edit) @447d2b40   12/04/08 17:08:50 Ralf Corsepius 2008-12-04 Ralf Corsépius <ralf.corsepius@…> * bsp_specs: … 4.104.115
(edit) @c563d40   12/04/08 16:39:26 Ralf Corsepius 2008-12-04 Ralf Corsépius <ralf.corsepius@…> * bsp_specs: … 4.104.115
(edit) @133622c   12/04/08 15:59:24 Ralf Corsepius 2008-12-04 Ralf Corsépius <ralf.corsepius@…> * bsp_specs: … 4.104.115
(edit) @2054c72b   12/04/08 15:59:16 Ralf Corsepius Use bool. 4.104.115
(edit) @55cfd8b4   12/04/08 15:59:03 Ralf Corsepius bsp_specs: Remove -u start -e start from %link. 4.104.115
(edit) @ed348c8   12/04/08 15:58:49 Joel Sherrill 2008-12-04 Joel Sherrill <joel.sherrill@…> PR 1348/cpukit … 4.104.115
(edit) @b0aefa4   12/04/08 15:58:26 Joel Sherrill 2008-12-04 Joel Sherrill <joel.sherrill@…> PR 1348/cpukit … 4.104.115
(edit) @f0a680b   12/04/08 15:51:20 Ralf Corsepius 2008-12-04 Ralf Corsépius <ralf.corsepius@…> * bsp_specs: … 4.104.115
(edit) @ab29fef   12/03/08 21:33:17 Joel Sherrill 2008-12-03 Joel Sherrill <joel.sherrill@…> * sp45/init.c: … 4.104.115
(edit) @a88e2dd   12/03/08 20:59:49 Joel Sherrill 2008-12-03 Joel Sherrill <joel.sherrill@…> PR 1347/cpukit … 4.104.115
(edit) @109ace3a   12/03/08 20:58:29 Joel Sherrill 2008-12-03 Joel Sherrill <joel.sherrill@…> PR 1347/cpukit … 4.104.115
(edit) @3a8335b   12/03/08 19:03:40 Joel Sherrill 2008-12-03 Joel Sherrill <joel.sherrill@…> PR 1346/cpukit … 4.104.115
(edit) @9efa012   12/03/08 17:38:21 Joel Sherrill 2008-12-03 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @b2d7d165   12/03/08 17:29:05 Joel Sherrill 2008-12-03 Joel Sherrill <joel.sherrill@…> Michael South … 4.104.115
(edit) @959f887a   12/03/08 17:28:10 Joel Sherrill 2008-12-03 Joel Sherrill <joel.sherrill@…> Michael South … 4.104.115
(edit) @c783c77   12/03/08 16:37:49 Joel Sherrill 2008-12-03 Joel Sherrill <joel.sherrill@…> PR 1345/Ada * … 4.104.115
(edit) @e23509c   12/02/08 22:49:17 Joel Sherrill 2008-12-02 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @50bac3ff   12/02/08 03:38:56 Ralf Corsepius Fix typo. 4.104.115
(edit) @0d90d52   12/02/08 02:32:14 Ralf Corsepius Rebuild GCC. 4.104.115
(edit) @79088f51   12/02/08 02:31:44 Ralf Corsepius Upgrade binutils. 4.104.115
(edit) @4c0d483b   12/01/08 23:28:53 Joel Sherrill 2008-12-01 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @d1200785   12/01/08 17:37:01 Joel Sherrill 2008-12-01 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @e65f596   12/01/08 17:31:11 Joel Sherrill 2008-12-01 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @63ca296   12/01/08 17:30:11 Joel Sherrill 2008-12-01 Joel Sherrill <joel.sherrill@…> * cpu.c: Links … 4.104.115
(edit) @979551b   12/01/08 17:30:05 Joel Sherrill 2008-12-01 Joel Sherrill <joel.sherrill@…> * bsp_specs, … 4.104.115
(edit) @86c3d41   12/01/08 16:14:41 Joel Sherrill 2008-12-01 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @2bf21fc8   12/01/08 16:07:40 Joel Sherrill 2008-12-01 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @2b90266   12/01/08 16:07:08 Joel Sherrill 2008-12-01 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @837cf465   11/29/08 03:00:39 Ralf Corsepius Remove (Obsolete). 4.104.115
(edit) @8493339   11/29/08 02:59:15 Ralf Corsepius Rebase patch against updated newlib-cvs. 4.104.115
(edit) @92862e81   11/28/08 03:31:59 Ralf Corsepius Regenerate. 4.104.115
(edit) @78a345f6   11/28/08 03:31:07 Ralf Corsepius newlib-1.16.0.cvs.20081128. 4.104.115
(edit) @b787ad8b   11/27/08 16:15:07 Ralf Corsepius Update. 4.104.115
(edit) @7b65330c   11/27/08 16:12:42 Ralf Corsepius Regenerate. 4.104.115
(edit) @5aea6380   11/27/08 16:11:52 Ralf Corsepius newlib-1.16.0.cvs.20081127 4.104.115
(edit) @ac1ddec6   11/27/08 16:11:37 Ralf Corsepius newlib-1.16.0.cvs.20081127--rtems4.10-20081127.diff 4.104.115
(edit) @f8c34e8d   11/27/08 16:09:20 Ralf Corsepius Bump GCC_RPMREL = 15%{?dist}. 4.104.115
(edit) @9d1af30   11/27/08 16:08:09 Ralf Corsepius Update to automake-1.10.2 4.104.115
(edit) @c8f7b4e6   11/26/08 16:38:06 Joel Sherrill 2008-11-26 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @274ee57   11/26/08 14:29:56 Joel Sherrill 2008-11-26 Joel Sherrill <joel.sherrill@…> * cpu.c, … 4.104.115
(edit) @b2d67fd   11/25/08 22:29:58 Joel Sherrill 2008-11-25 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @addd698   11/25/08 22:28:38 Joel Sherrill 2008-11-25 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @1ea0f9d   11/25/08 22:13:36 Joel Sherrill 2008-11-25 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @8856a19   11/25/08 06:24:01 Ralf Corsepius Regenerate. 4.104.115
(edit) @4120ad10   11/25/08 06:17:33 Ralf Corsepius Rebase patches against newlib-1.16.0.cvs.20081125. 4.104.115
(edit) @03073e3b   11/25/08 06:16:02 Ralf Corsepius newlib-1.16.0.cvs.20081125-rtems4.10-20081125.diff. 4.104.115
(edit) @1981cc5f   11/25/08 06:14:53 Ralf Corsepius GCC_RELVER = 14%{?dist}. NEWLIB_PKGVERS = $(NEWLIB_VERS).cvs.20081125. 4.104.115
(edit) @95e4d243   11/25/08 03:43:24 Ralf Corsepius Regenerate. 4.104.115
(edit) @c2352fc   11/25/08 03:42:40 Ralf Corsepius newlib-1.16.0.cvs.20081124-rtems4.10-20081124.diff 4.104.115
(edit) @1efc075   11/25/08 03:41:52 Ralf Corsepius newlib-1.16.0.cvs.20081124. GCC_RPMREL = 13%{?dist}. 4.104.115
(edit) @94a88c1c   11/24/08 19:50:06 Joel Sherrill 2008-11-24 Joel Sherrill <joel.sherrill@…> PR 1341/cpukit … 4.104.115
(edit) @ea5c9c6   11/24/08 16:41:02 Ralf Corsepius 2008-11-24 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.115
(edit) @e1871b9   11/24/08 16:39:04 Ralf Corsepius 2008-11-24 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @f4cc6c5   11/24/08 16:37:05 Ralf Corsepius Add AC_CHECK_FUNC's to check functions migrating into newlib. 4.104.115
(edit) @8d0fdc3   11/24/08 16:35:36 Joel Sherrill 2008-11-24 Joel Sherrill <joel.sherrill@…> * … 4.104.115
