Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @8f9efcb9   11/16/99 19:41:31 Joel Sherrill Added status chapter. 4.104.114.84.95
(edit) @71689d44   11/16/99 18:40:25 Joel Sherrill Added reference to rtems_get_class, rtems_get_node, and … 4.104.114.84.95
(edit) @dc2b337   11/16/99 18:28:20 Joel Sherrill Added task variable services. 4.104.114.84.95
(edit) @1dbf307   11/16/99 18:28:06 Joel Sherrill Added categorized list of constants in confdefs.h. 4.104.114.84.95
(edit) @90378e4   11/16/99 16:23:26 Joel Sherrill Added BSP_MAXIMUM_OPERATION_COUNT and BSP_ITERATION_COUNT which allow … 4.104.114.84.95
(edit) @4b960e5   11/16/99 16:21:00 Joel Sherrill Added code to the macros which checked directive status to also check … 4.104.114.84.95
(edit) @72d4b1d9   11/16/99 16:19:06 Joel Sherrill Use the miniIMFS to reduce code space. 4.104.114.84.95
(edit) @a20190a4   11/16/99 16:15:05 Joel Sherrill Added test cases for uname(). 4.104.114.84.95
(edit) @65a38bc   11/16/99 16:14:37 Joel Sherrill Web server uses the POSIX API. Therefor, it must be disabled when the … 4.104.114.84.95
(edit) @ce18601a   11/16/99 16:13:26 Joel Sherrill Removed start subdirectory and distributed contents to the appropriate … 4.104.114.84.95
(edit) @0cb7cb9   11/16/99 16:10:39 Joel Sherrill Added comments. 4.104.114.84.95
(edit) @d3fdf459   11/16/99 16:09:50 Joel Sherrill Now use _Thread_Reset(). 4.104.114.84.95
(edit) @88cb6b2   11/16/99 16:08:10 Joel Sherrill Added threadreset.c. 4.104.114.84.95
(edit) @f6d0821   11/16/99 16:07:52 Joel Sherrill Added prototype for _Thread_Reset() and numerous comments. 4.104.114.84.95
(edit) @c094542   11/16/99 16:07:17 Joel Sherrill Only check for System V IPC if multiprocessing is enabled. The unix … 4.104.114.84.95
(edit) @f4b76ab5   11/16/99 16:04:51 Joel Sherrill Fixed so can be included multiple times in the executive source. 4.104.114.84.95
(edit) @31473b7   11/16/99 16:03:21 Joel Sherrill Works now. Removed times() since the version in the C Library support … 4.104.114.84.95
(edit) @165fe39   11/16/99 16:01:54 Joel Sherrill Return a reasonable error other than ENOSYS. 4.104.114.84.95
(edit) @7fec3b7a   11/16/99 16:01:32 Joel Sherrill Added call to _Watchdog_Remove to remove the sporadic timer. It was … 4.104.114.84.95
(edit) @2c0e896e   11/16/99 16:00:11 Joel Sherrill Moved utsname from "build for now" (unimplemented files) to the main … 4.104.114.84.95
(edit) @d280ce18   11/16/99 15:58:21 Joel Sherrill Comment fixed when adding prototype for … 4.104.114.84.95
(edit) @bd462d1   11/16/99 15:52:49 Joel Sherrill New file. 4.104.114.84.95
(edit) @d6c83529   11/16/99 15:48:11 Joel Sherrill Patch rtems-rc-19991105-1.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @fa3346f   11/16/99 15:41:58 Jennifer.Averett Modified file to match seen output. 4.104.114.84.95
(edit) @f9879915   11/16/99 15:41:29 Jennifer.Averett Modified output file to match seen output. Added comment to all ino … 4.104.114.84.95
(edit) @e9b00d7   11/16/99 15:40:40 Jennifer.Averett Removed compiler warning. 4.104.114.84.95
(edit) @d37aa444   11/16/99 15:39:08 Jennifer.Averett Changed asserts to tmmacros. 4.104.114.84.95
(edit) @2d82857   11/16/99 15:38:44 Jennifer.Averett Updated scn file to match new output. Left out unemplemented parts as … 4.104.114.84.95
(edit) @47619951   11/16/99 15:33:10 Jennifer.Averett + Changed ID to 1. ( Compilation error introduced by modifications. ) 4.104.114.84.95
(edit) @1da9f4bd   11/16/99 15:30:04 Jennifer.Averett Modified scan file to match. 4.104.114.84.95
(edit) @817031f   11/16/99 15:28:03 Joel Sherrill New file. 4.104.114.84.95
(edit) @c7016198   11/16/99 15:27:52 Joel Sherrill Added. 4.104.114.84.95
(edit) @b88691c   11/16/99 15:26:29 Joel Sherrill Source and destination arguments to strncpy were swapped. This … 4.104.114.84.95
(edit) @c276c87   11/16/99 15:24:30 Joel Sherrill Added itron tests. 4.104.114.84.95
(edit) @3fb7b70b   11/16/99 14:39:56 Jennifer.Averett Changed to call tmmacros instead of assert. 4.104.114.84.95
(edit) @56e61bb8   11/16/99 14:24:50 Joel Sherrill Patch rtems-rc-19991105-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @ac656f2d   11/16/99 14:15:56 Joel Sherrill Moved start code from lib/start to libbsp. 4.104.114.84.95
(edit) @25f705e   11/16/99 13:55:35 Joel Sherrill Moved start code from lib/start to libbsp. 4.104.114.84.95
(edit) @1d04e16   11/16/99 13:45:51 Joel Sherrill Moved start code from lib/start to libbsp. 4.104.114.84.95
(edit) @7f93f772   11/16/99 13:37:49 Joel Sherrill Committed modifications from ITRON Task and Task Dependendent … 4.104.114.84.95
(edit) @a7d988a   11/16/99 13:37:25 Joel Sherrill Minor changes since new Makefile. 4.104.114.84.95
(edit) @14dbf50   11/16/99 13:34:41 Joel Sherrill Added start subdirectory. 4.104.114.84.95
(edit) @1bcdb3f6   11/16/99 13:31:13 Joel Sherrill Committed modifications from ITRON Task and Task Dependendent … 4.104.114.84.95
(edit) @80fd699   11/15/99 22:19:51 Joel Sherrill Removed nanosleep() since it is now in its own file. 4.104.114.84.95
(edit) @40aac29   11/15/99 21:37:56 Jennifer.Averett Returned third parameter for a NULL name to the objects open call. 4.104.114.84.95
(edit) @25789705   11/15/99 21:35:14 Jennifer.Averett + Fixed files to consistantly use a case of the location after calls … 4.104.114.84.95
(edit) @1ae60eb4   11/15/99 21:31:28 Jennifer.Averett + Modified to use new Thread_Reset routine instead of the restart method. 4.104.114.84.95
(edit) @e672263   11/15/99 21:28:21 Jennifer.Averett Fixed verificaiton checks to call correct macro if dispatch is disabled. 4.104.114.84.95
(edit) @06380cfe   11/15/99 21:25:53 Jennifer.Averett + Added check that a task could be sent to a dormant state then … 4.104.114.84.95
(edit) @0f88857   11/15/99 21:19:58 Jennifer.Averett + Changed preempt routine into two dummy tasks one that is in dormant … 4.104.114.84.95
(edit) @cb193710   11/15/99 21:04:01 Joel Sherrill Added paragraph describing SUSP. 4.104.114.84.95
(edit) @9da0994   11/15/99 17:15:58 Joel Sherrill Split ITRON Message Buffer Manager into multiple files. 4.104.114.84.95
(edit) @fb27af76   11/15/99 16:39:01 Joel Sherrill Split ITRON semaphore manager into multiple files. 4.104.114.84.95
(edit) @afb11f8   11/12/99 22:00:10 Joel Sherrill + Modified calls to use TSK_SLF for calls to self. + Modified calls to … 4.104.114.84.95
(edit) @624d7ca4   11/12/99 21:27:42 Joel Sherrill + Added comments on paths tested. 4.104.114.84.95
(edit) @e8c902c   11/12/99 21:26:54 Joel Sherrill + Added check for priority over 256. + Modified output to correctly … 4.104.114.84.95
(edit) @8ed3125d   11/12/99 21:24:56 Joel Sherrill Added comments for path's tested. 4.104.114.84.95
(edit) @d8f3f65b   11/12/99 21:23:34 Joel Sherrill + Changed validation of the_thread to validation of location. + … 4.104.114.84.95
(edit) @2979c28   11/12/99 21:21:09 Joel Sherrill + Changed validation of the_thread to validation of location. + … 4.104.114.84.95
(edit) @3971537   11/12/99 21:20:04 Joel Sherrill + Changed validation of the_thread to validation of location. 4.104.114.84.95
(edit) @037a7b1   11/12/99 21:18:36 Joel Sherrill + Moved error checks to before the disable dispatch where possible. 4.104.114.84.95
(edit) @0c5ab522   11/12/99 21:16:45 Joel Sherrill Added comment about the E_CTX error condition (Implementation dependent). 4.104.114.84.95
(edit) @c257429f   11/12/99 21:15:12 Joel Sherrill + Moved error checks to before the dispatch disable where possible. + … 4.104.114.84.95
(edit) @2183b65   11/12/99 21:13:52 Joel Sherrill + Modified correct return path to call _ITRON_return_errorno( E_OK ) … 4.104.114.84.95
(edit) @ea6bfcb   11/12/99 21:12:27 Joel Sherrill + Modified correct return path to call _ITRON_return_errorno( E_OK ) … 4.104.114.84.95
(edit) @6af81435   11/12/99 15:54:48 Joel Sherrill Corrected so now actually indexes into the allocation block. 4.104.114.84.95
(edit) @1925ec9b   11/12/99 15:54:07 Joel Sherrill Corrected remaining references to struct rtems_task_variable_t since … 4.104.114.84.95
(edit) @a8d72dea   11/12/99 15:53:29 Joel Sherrill Removed unnecessary 3rd parameter. 4.104.114.84.95
(edit) @6bd132e5   11/12/99 15:37:09 Joel Sherrill New file. 4.104.114.84.95
(edit) @95bb279   11/12/99 14:54:13 Joel Sherrill Used typedef so all "struct rtems_task_variable_t" uses are now just … 4.104.114.84.95
(edit) @884b460   11/12/99 14:52:36 Joel Sherrill Added per-task variable data stucture (rtems_task_variable_t), … 4.104.114.84.95
(edit) @f4771656   11/12/99 14:51:03 Joel Sherrill Test name changed to reflect placement after merger. 4.104.114.84.95
(edit) @ec0b5ce   11/12/99 14:50:42 Joel Sherrill Test name changed to reflect placement after merger. Changed output … 4.104.114.84.95
(edit) @3136f5c9   11/12/99 14:49:47 Joel Sherrill Test name changed to reflect placement after merger. Increased stack … 4.104.114.84.95
(edit) @5aa5560   11/12/99 14:38:19 Joel Sherrill Added per task variables based on patch from Eric Norum … 4.104.114.84.95
(edit) @3c49a508   11/12/99 14:15:50 Joel Sherrill Cleaned up style. 4.104.114.84.95
(edit) @3ad17f5   11/12/99 13:46:04 Joel Sherrill Removed redundant line. 4.104.114.84.95
(edit) @e972ff0   11/12/99 13:46:03 Joel Sherrill Merged message buffer code from CS595 projects. 4.104.114.84.95
(edit) @6977b38   11/12/99 13:45:39 Joel Sherrill Enabled after merging message buffer code. 4.104.114.84.95
(edit) @f9078d1   11/12/99 13:22:31 Joel Sherrill Added comment block and removed include of deleted file. 4.104.114.84.95
(edit) @33bbd74   11/11/99 02:51:31 Joel Sherrill Added information about the NTP servier field and included a copy of … 4.104.114.84.95
(edit) @d102810e   11/11/99 02:39:12 Joel Sherrill Updated. 4.104.114.84.95
(edit) @dc83752   11/11/99 02:23:26 Joel Sherrill Screen updated. 4.104.114.84.95
(edit) @458d4e66   11/11/99 02:23:04 Joel Sherrill Added new test sp28 to test the task variable directives. 4.104.114.84.95
(edit) @713b2ea   11/10/99 22:15:42 Joel Sherrill General cleanup. Test documentation improved. The message buffer … 4.104.114.84.95
(edit) @59d1127   11/10/99 22:14:26 Joel Sherrill Corrected to account for the way memory is divided up in … 4.104.114.84.95
(edit) @7d29dc7f   11/10/99 22:13:42 Joel Sherrill Added line to make sure HAS_ITRON_API is defined in Makefile. 4.104.114.84.95
(edit) @72719d2   11/10/99 20:37:01 Joel Sherrill Added call to _Thread_Enable_dispatch() and did some cleanup. 4.104.114.84.95
(edit) @74db82a   11/10/99 20:36:25 Joel Sherrill rtems_semaphore_flush test from Eric Norum <eric@…>. 4.104.114.84.95
(edit) @cbccd37   11/10/99 14:31:11 Joel Sherrill Patch from Eric Norum <eric@…> which includes: Patches … 4.104.114.84.95
(edit) @442d0478   11/10/99 14:19:55 Joel Sherrill Combination of committing some new files which had been overlooked and … 4.104.114.84.95
(edit) @eb02f47   11/10/99 13:48:27 Joel Sherrill Committed modifications from ITRON Task and Task Dependendent … 4.104.114.84.95
(edit) @dcc1f6b6   11/10/99 13:45:54 Joel Sherrill Added support for ITRON tests. 4.104.114.84.95
(edit) @a5f5acad   11/10/99 13:38:34 Joel Sherrill Updated to include more documentation from CS595. 4.104.114.84.95
(edit) @aff08f5   11/10/99 13:21:33 Joel Sherrill Better formatting. 4.104.114.84.95
(edit) @bab5ba44   11/09/99 23:28:04 Joel Sherrill Added more tasking tests. 4.104.114.84.95
(edit) @e099180   11/09/99 23:27:05 Joel Sherrill Merged tests from Task group. 4.104.114.84.95
(edit) @3d67661   11/09/99 23:10:48 Joel Sherrill Added nesting count for suspend/resume. 4.104.114.84.95
(edit) @70e9af9   11/09/99 22:45:35 Joel Sherrill Changed B, H, and W variables to BVar, HVar, and WVar to avoid … 4.104.114.84.95
(edit) @e18ba7f   11/09/99 22:25:55 Joel Sherrill Commented out single letter type names since they conflict with … 4.104.114.84.95
