@8cb2882
10/31/13 14:00:20 |
Sebastian Huber |
Filesystem: Add kernel event filter handler
This handler is necessary …
4.115
@16829460
10/31/13 14:00:14 |
Sebastian Huber |
Filesystem: Add poll() handler
This handler is necessary to implement …
4.115
@ffc862c
09/17/13 11:08:49 |
Sebastian Huber |
bsp/realview-pbx-a9: Add NULL pointer protection
Qemu Git version …
4.115
@b3211b5a
10/31/13 14:23:23 |
Daniel Hellstrom |
SPARC BSPs: disable interrupts as early as possible
There is no point …
4.115
@82e11be2
10/31/13 14:23:21 |
Daniel Hellstrom |
LEON3 SMP: remove compiler warning from delay() declaration
4.115
@bedfe13
10/31/13 14:23:20 |
Daniel Hellstrom |
LEON3 SMP: CPU ack irq on trap vector entry execution
4.115
@e1b53274
10/31/13 14:23:19 |
Daniel Hellstrom |
LEON3_MP ISR: shared-IRQ setup overwrite SMP/MP ISR trap handler
4.115
@ba120d1
10/31/13 13:17:57 |
Sebastian Huber |
Filesystem: Use ENOTTY for default ioctl() handler
This is in line …
4.115
@8d66446
10/31/13 12:56:19 |
Sebastian Huber |
Filesystem: Documentation
4.115
@44790069
10/31/13 12:50:49 |
Sebastian Huber |
libmd: Change MD5Update() prototype
This is in line with the FreeBSD …
4.115
@61e3d1a
10/25/13 09:51:10 |
Sebastian Huber |
Filesystem: Clear open flag early in close()
This helps to prevent …
4.115
@d44d31c
10/25/13 09:50:12 |
Sebastian Huber |
Filesystem: Zero flags in rtems_libio_free()
4.115
@b68cef17
10/23/13 11:29:17 |
Sebastian Huber |
score: New state STATES_WAITING_FOR_BSD_WAKEUP
This state is …
4.115
@fbed79b
10/27/13 18:35:16 |
Sebastian Huber |
bsps/arm: Add ARMV7_CP15_START_DEFAULT_SECTIONS
4.115
@f074a4d
10/27/13 18:27:44 |
Sebastian Huber |
bsps/arm: ARMV7_MMU_DATA_READ_WRITE_SHAREABLE
Delete …
4.115
@f619250
10/27/13 18:13:47 |
Sebastian Huber |
bsps: Add simple console output char
4.115
@7ad725f2
10/14/13 13:34:58 |
Hesham Almatary |
Modify raspberrypi mm_config_table to map GPIO and registers.
Changes …
4.115
@09d0c96b
10/27/13 17:58:42 |
Sebastian Huber |
bsps/arm: Move some MMU bit settings
The function …
4.115
@0f874ee
10/27/13 17:51:53 |
Sebastian Huber |
bsps/arm: Init trans tbl with invalid entries
4.115
@73e7345
10/27/13 17:49:01 |
Sebastian Huber |
IMFS: Use IMFS_mtime_ctime_update()
4.115
@24a6943
10/24/13 23:37:17 |
Joel Sherrill |
sparc all BSPs: Use function and data sections
This reduces the size …
4.115
@0255beaf
10/24/13 14:42:31 |
Christian.Mauderer |
bsp/stm32f4: Bugfix for I2C driver.
4.115
@c918737e
10/24/13 14:26:59 |
bsp/stm32f4: Add a simple I2C-driver.
4.115
@bb3f349
10/24/13 14:27:00 |
bsp/stm32f4: Bugfix for io-initialisation.
4.115
@c6f0efe2
10/24/13 14:17:35 |
bsp/stm32f4: Header for f10xxx EXTI.
4.115
@5fe19134
10/23/13 08:59:12 |
Sebastian Huber |
Filesystem: PR2146: Documentation
4.115
@8e8b18bb
10/22/13 09:00:04 |
Sebastian Huber |
libmd: New defines for FreeBSD compatibility
4.115
@e89ed92
10/18/13 16:08:00 |
ralf.kirchner |
dosfs: Ensure initially the sector size is used as bdbuf block size
4.115
@0098c522
10/18/13 16:07:10 |
ralf.kirchner |
fsdosfsformat01: Add test for re-mount of a filesystem
4.115
@865c307
10/17/13 02:15:18 |
Ric Claus |
Remove double count of start offset
4.115
@b8de8281
10/16/13 11:04:33 |
Sebastian Huber |
libcsupport: Updates from latest FreeBSD version
4.115
@9e1d605
10/16/13 13:18:30 |
Sebastian Huber |
libtests/flashdisk01: Include missing header file
4.115
@1f724a0
10/16/13 12:45:00 |
Sebastian Huber |
RFS: Include missing header file
4.115
@e4ced53
10/15/13 17:14:13 |
shubhamsomani92 |
doc: Document format in conf.t
4.115
@816a9cad
10/15/13 07:10:38 |
Sebastian Huber |
4.115
@3c2bb22
10/11/13 14:22:00 |
Sebastian Huber |
Return EINVAL in default ftruncate() handler
According to POSIX this …
4.115
@33e18a4
09/28/13 06:54:38 |
wei.a.yang |
rename smpatomic08 to smpatomic01
4.115
@27a034ef
09/28/13 06:54:37 |
wei.a.yang |
delete smpatomic0-7 test cases
4.115
@fee154be
09/28/13 06:54:36 |
wei.a.yang |
add simple atomic test cases into smpatomic08
4.115
@382f714
10/08/13 08:40:29 |
Pavel Pisa |
SPI SD-Card: setup valid CRC-7 for STOP_TRANSMISSION command.
4.115
@5ceefe1
09/28/13 08:08:25 |
Hesham Almatary |
Shared MMU initialization for ARM BSPs and RaspberryPi? MMU support
4.115
@0a9533fc
09/28/13 08:08:24 |
Hesham Almatary |
Add a new necessary definition needed for raspberrypi MMU support
The …
4.115
@abceda99
09/30/13 17:09:12 |
Joel Sherrill |
Merge branch 'master' into warnings
4.115
@ba2e98e6
09/30/13 17:08:38 |
Joel Sherrill |
libbsp/sparc/.../gnatcommon.c: Formatting
4.115
@d349636b
09/30/13 17:08:13 |
Joel Sherrill |
leon2/.../ckinit.c: Change get nanoseconds handler to static
4.115
@a15650d
09/30/13 17:07:35 |
Joel Sherrill |
mips/shared/.../clockdrv.c: Change get nanoseconds handler to static
4.115
@2dfdecd
09/30/13 17:07:07 |
Joel Sherrill |
uC5282/.../clock.c: Change get nanoseconds handler to static
4.115
@85c855af
09/30/13 06:10:45 |
Chris Johns |
Fix building with RTEMS_DEBUG.
4.115
@38905d70
09/23/13 13:28:48 |
Joel Sherrill |
leon3/bsppredriver.c: Add include file to warning
4.115
@4fab260d
09/23/13 13:24:32 |
Joel Sherrill |
libcpu/sparc/.../access_le.c: Add include file to fix warning
4.115
@db97feb5
09/23/13 13:22:02 |
Joel Sherrill |
internal.h/main_mdump.c: Convert main methods to static
4.115
@876af7a
09/23/13 13:16:55 |
Joel Sherrill |
leon3/.../ckinit.c: Change get nanoseconds handler to static
4.115
@d2c5bff
09/22/13 15:51:36 |
Joel Sherrill |
leon3/.../ckinit.c: Fix missing prototype warnings
4.115
@6867055
09/22/13 15:51:19 |
Joel Sherrill |
libbsp/shared/bspinit.c: Fix missing prototype warnings
4.115
@4650678b
09/22/13 15:38:31 |
Joel Sherrill |
leon3/.../bspstart.c: Fix missing prototype warnings
4.115
@40eea001
09/22/13 15:36:57 |
Joel Sherrill |
nfsclient/src/dirutils.c: Fix missing prototype warnings
4.115
@37a7c27
09/22/13 15:34:20 |
Joel Sherrill |
getdents.c: Fix missing prototype warnings
4.115
@59a2b2b
09/22/13 15:32:20 |
Joel Sherrill |
ctermid.c: Fix missing prototype warnings
4.115
@359b6d0
09/22/13 15:31:08 |
Joel Sherrill |
getpwent.c: Fix missing prototype warnings
4.115
@f3a5d86f
09/22/13 15:29:45 |
Joel Sherrill |
newlibc_init.c: Fix missing prototype warnings
4.115
@01b7b69
09/22/13 15:28:23 |
Joel Sherrill |
times.c: Fix missing prototype warnings
4.115
@59abbec
09/22/13 15:24:39 |
Joel Sherrill |
stat.c: Fix missing prototype warnings
4.115
@d334b60b
09/22/13 15:22:01 |
Joel Sherrill |
gettod.c: Fix missing prototype warnings
4.115
@196749c
09/22/13 15:07:20 |
Joel Sherrill |
gitpid.c: Fix missing prototype warnings
4.115
@e0e2615e
09/22/13 15:06:15 |
Joel Sherrill |
assert.c: Fix missing prototype warnings
4.115
@3ea6b88
09/22/13 15:05:53 |
Joel Sherrill |
issetugid.c: Fix missing prototype warnings
4.115
@a85a552
09/22/13 15:02:18 |
Joel Sherrill |
_execve.c: Fix missing prototype warnings
4.115
@137f947
09/22/13 15:01:58 |
Joel Sherrill |
rtemsbuildname.c: Fix missing prototype warnings
4.115
@90a2a6d
09/22/13 15:01:44 |
Joel Sherrill |
intrbody.c: Fix missing prototype warnings
4.115
@f07b0e65
09/22/13 14:41:49 |
Joel Sherrill |
sparc/.../grcan.c: Switch to using RTEMS_COMPILER_UNUSED_ATTRIBUTE
4.115
@f972703d
09/22/13 14:41:25 |
Joel Sherrill |
semopen.c: Switch to using RTEMS_COMPILER_UNUSED_ATTRIBUTE
4.115
@49fb4dcb
09/22/13 14:41:13 |
Joel Sherrill |
mqueueopen.c: Switch to using RTEMS_COMPILER_UNUSED_ATTRIBUTE
4.115
@ecd82b6d
09/22/13 14:40:44 |
Joel Sherrill |
basedefs.h: Add RTEMS_COMPILER_UNUSED_ATTRIBUTE.
4.115
@c8707a3
09/21/13 21:25:06 |
Joel Sherrill |
leon3/console.c: Fix misisng prototype issues
4.115
@94926599
09/21/13 21:17:48 |
Joel Sherrill |
semopen.c: Address set but unused variable warning
4.115
@acfdf51
09/21/13 21:16:25 |
Joel Sherrill |
sigsuspend.c: Address set but unused variable warning
4.115
@41ea801
09/21/13 21:13:25 |
Joel Sherrill |
mqueueopen.c: Address set but unused variable warning
4.115
@34b57d61
09/21/13 21:10:17 |
Joel Sherrill |
sparc/.../grcan.c: Fix multiple warnings
4.115
@e9da278
09/21/13 21:09:48 |
Joel Sherrill |
sparc/.../ambapp.h: Add ambapp_get_number_apbslv_devices() prototype
4.115
@ac19578
09/21/13 20:56:28 |
Joel Sherrill |
sparc/.../occan.c: Fix missing prototype warning
4.115
@110cc8c
09/21/13 20:55:40 |
Joel Sherrill |
sparc/.../ambapp.h: Add ambapp_get_number_ahbslv_devices() prototype
4.115
@946c391
09/21/13 20:48:45 |
Joel Sherrill |
sparc/../occan.c: Fix set but unused variable warning
4.115
@2cdace7
09/21/13 20:45:51 |
Joel Sherrill |
main_mv.c: Address set but not used warning
It looks like the paths …
4.115
@7071eb3
09/21/13 20:41:50 |
Joel Sherrill |
mouse_parser.c: Fix warning by properly checking return code
4.115
@df74da0
09/21/13 20:38:48 |
Joel Sherrill |
sparc irq-shared.c: Fix unused variable warning
4.115
@1485a58
09/18/13 13:44:42 |
bsp/stm32f4: Add STM32F10XXX support.
4.115
@0282e83
09/13/13 08:20:59 |
Sebastian Huber |
JFFS2: New tests
4.115
@3c96bee
09/12/13 13:32:07 |
Sebastian Huber |
JFFS2: Add RTEMS support
4.115
@78b85286
09/12/13 14:53:41 |
Sebastian Huber |
JFFS2: Update Linux compatibility layer
Modify compatbility layer for …
4.115
@672038b
09/12/13 14:46:51 |
Sebastian Huber |
JFFS2: Import from eCos
Import of Linux compatibility layer and JFFS2 …
4.115
@0c0f128
09/12/13 13:57:47 |
Sebastian Huber |
JFFS2: Import from Linux
Import of Journalling Flash File System, …
4.115
@8ac962e
09/17/13 17:44:08 |
Vipul Nayyar |
bsp_howto/support.t: Add PIC Interrupt Model API Information
4.115
@d9998172
09/17/13 11:48:30 |
Sebastian Huber |
libtests/termios04: Avoid NULL pointer access
4.115
@564860f
09/16/13 19:32:36 |
Joel Sherrill |
leon3/include/bsp.h: Fix spacing
4.115
@3d477da0
09/16/13 19:32:22 |
Joel Sherrill |
m68k/shared/start.S: Fix spacing
4.115
@f7308976
09/16/13 19:31:52 |
Joel Sherrill |
pc386/console/conscfg.c: Fix spacing
4.115
@38d94f56
09/16/13 19:31:28 |
Joel Sherrill |
raspberrypi.cfg: Remove CVS Id
4.115
@390e987e
09/16/13 08:43:30 |
Sebastian Huber |
libblock: PR2145: Limit maximum read-ahead blocks
This helps to …
4.115
@a44917e
09/16/13 07:27:32 |
Ric Claus |
bsps/arm: Fix exception entries
4.115
@bdcf4102
09/13/13 15:37:51 |
Sebastian Huber |
fstests/mdosfs_fstime: Remove test
The FAT file system is not …
4.115
