@784d2a1
09/06/13 08:05:35 |
Sebastian Huber |
arm: Fix inconsistent define usage
4.115
@36fdd0b
09/05/13 18:50:46 |
Gedare Bloom |
uuid: make integer arithmetic conversion explicit
Upcast …
4.115
@8ee95e6
09/05/13 18:44:24 |
Gedare Bloom |
imfs: use safe string functions
Replace strcpy and strcat with …
4.115
@a803e04d
09/05/13 18:34:32 |
Gedare Bloom |
termios: check return value from semaphore obtain/release
Raise a …
4.115
@74d35751
09/05/13 18:31:14 |
Gedare Bloom |
flashdisk: swap arguments to checksum helper
The arguments to …
4.115
@59261fba
09/05/13 18:28:14 |
Gedare Bloom |
nvdisk: swap arguments to checksum helper
The arguments to …
4.115
@5f040b8
09/05/13 18:21:32 |
Gedare Bloom |
sparse-disk: check return value from semaphore_obtain/release
In case …
4.115
@97ae1eeb
09/05/13 18:13:32 |
Gedare Bloom |
imfs: check return value from mkdir
4.115
@e075b388
09/05/13 18:10:52 |
Gedare Bloom |
untar: check return value from mkdir
Check the return value from …
4.115
@b6cfbab4
09/05/13 18:03:00 |
Gedare Bloom |
dosfs: Eliminate empty case statements that fall through to default.
4.115
@c963ac7
09/05/13 17:44:04 |
Gedare Bloom |
nfs: Fix ln option processing.
If opts is NULL, then strchr() will …
4.115
@121dd881
09/05/13 17:22:49 |
Gedare Bloom |
bdpart: Argument cannot be negative
If open(fd) fails then avoid the …
4.115
@a8007dc2
09/05/13 17:15:33 |
Gedare Bloom |
dosfs: Unsigned compared against 0
Change the type for storing the …
4.115
@e4c1926
09/05/13 17:09:37 |
Gedare Bloom |
Fix the type of "cmpltd" to be …
4.115
@551468c
09/05/13 16:58:34 |
Gedare Bloom |
dosfs: Unintentional integer overflow
Explicitly promote 32-bit …
4.115
@96654dc
09/05/13 16:15:27 |
Gedare Bloom |
shell: Out-of-bounds access
In case the length of cwd path plus the …
4.115
@a6d35256
09/05/13 15:53:39 |
Gedare Bloom |
IMFS: Resource leak
Free fs_info in case root_node is NULL.
4.115
@d157a4fd
09/04/13 12:03:47 |
Sebastian Huber |
bsps/arm: Fix ARM CP15 opcode for get functions
4.115
@03e097b7
09/03/13 10:59:54 |
Sebastian Huber |
nios2: Include proper header file
4.115
@4a8c334
09/03/13 09:06:46 |
Sebastian Huber |
smptests/smpatomic08: Add initialization test case
4.115
@3bac8a4c
09/03/13 09:04:33 |
Sebastian Huber |
score: Use void * for some atomic pointer ops
4.115
@29f7d317
09/02/13 13:08:05 |
Sebastian Huber |
score: Use unsigned long for atomic integers
Use unsigned long …
4.115
@0c47440
08/29/13 20:20:03 |
Karel Gardas |
bsp/lm4f120: new BSP to support TI LM4F120 XL LaunchPad? board
4.115
@47b6fad
09/01/13 13:14:07 |
Sebastian Huber |
smptests/smpatomic08: Avoid copy and paste
4.115
@7136d7f
09/01/13 13:01:42 |
Sebastian Huber |
smptests/smpatomic08: Simplify or/and test case
Renamed and use …
4.115
@d39ccd69
09/01/13 12:34:31 |
Sebastian Huber |
smptests/smpatomic08: Fix compare and exchange
4.115
@4238aff
09/01/13 10:28:35 |
wei.a.yang |
add atomic sub, and, or, compare_exchange test cases into smpatomic08
4.115
@bf30999
08/23/13 14:15:50 |
Sebastian Huber |
smp: Add and use _Assert_Owner_of_giant()
Add and use …
4.115
@1215fd4
08/26/13 13:14:33 |
Sebastian Huber |
sapi: SMP support for chains
Add ISR lock to chain control for proper …
4.115
@e127c4c
08/29/13 08:03:38 |
Sebastian Huber |
smptests/smpatomic08: Fix race conditions
4.115
@79d03e3
08/28/13 12:52:43 |
Sebastian Huber |
smptests/smpatomic08: New test
4.115
@03aad60
08/28/13 09:27:26 |
Sebastian Huber |
score: Atomic flag changes
Delete _Atomic_Init_flag(). Change …
4.115
@58a70b76
08/27/13 13:14:04 |
wei.a.yang |
score: Simplify <rtems/score/cpuatomic.h>
Add proper license and …
4.115
@4288f9fd
08/27/13 13:10:50 |
Sebastian Huber |
score: Use static inline directly
This file uses already C11 …
4.115
@2bbcb64
08/27/13 12:26:33 |
Sebastian Huber |
smptests: Move ATOMIC conditional to top-level
4.115
@697d31e
08/25/13 13:45:41 |
wei.a.yang |
add atomic init function
4.115
@7bff82f
08/27/13 12:25:25 |
Sebastian Huber |
posix: Avoid NULL pointer access
4.115
@7d9fff6
08/26/13 15:39:00 |
Sebastian Huber |
posix: Add and use _POSIX_signals_Acquire()
Add and use …
4.115
@a4c3e71
08/26/13 15:38:15 |
Sebastian Huber |
score: Add SMP support to _Watchdog_Report_chain()
4.115
@ff0dcf2c
08/26/13 14:51:30 |
Sebastian Huber |
sptests/spthreadq01: Add SMP support
4.115
@c955f99
08/26/13 14:46:53 |
Sebastian Huber |
sptests/spnsext01: Add SMP support
4.115
@ca68215e
08/26/13 14:22:30 |
Sebastian Huber |
posix: _POSIX_signals_Clear_process_signals()
Do not disable …
4.115
@75f6d18
08/26/13 14:03:35 |
Sebastian Huber |
rtems: Add SMP support for signals
Add and use …
4.115
@ef3640f7
08/26/13 13:25:58 |
Sebastian Huber |
ringbuf: Add SMP support
4.115
@4957272
08/26/13 13:14:58 |
Sebastian Huber |
Filesystem: Use unprotected chain operations
This area is protected …
4.115
@58a5889
08/26/13 12:58:07 |
Sebastian Huber |
posix: Protect access to _POSIX_signals_Vectors
Assume the …
4.115
@23de794d
08/26/13 12:27:52 |
Sebastian Huber |
score: Add and use CHAIN_INITIALIZER_ONE_NODE().
Add and use …
4.115
@d56f76a
08/26/13 11:00:53 |
Sebastian Huber |
bsps: Fix header includes
4.115
@07ad4b6
08/26/13 08:44:20 |
Sebastian Huber |
libblock: Use unprotected chain extract
This area is protected by the …
4.115
@a839d62
08/26/13 08:31:46 |
Sebastian Huber |
RFS: Use unprotected chain operations
4.115
@3109857c
08/26/13 19:26:50 |
Joel Sherrill |
bsps: Add and use CLOCK_DRIVER_ISRS_PER_TICK_VALUE
pc386 set …
4.115
@db0e05ff
08/23/13 09:57:11 |
Sebastian Huber |
score: Delete unused function parameter
4.115
@f8f1bdad
08/23/13 10:19:13 |
Sebastian Huber |
score: PR2140: Fix _Thread_queue_Process_timeout()
The …
4.115
@215ccce
08/23/13 09:52:01 |
Sebastian Huber |
score: PR2140: _Thread_queue_Extract()
Return if the executing …
4.115
@842d63ba
08/23/13 08:01:57 |
Sebastian Huber |
libblock: Avoid uninitialized variable
4.115
@2bd440e
08/22/13 12:18:14 |
Ric Claus |
bsp/xilinx-zynq: Add cache support
4.115
@2f0d5e4
08/26/13 01:00:31 |
cynthia |
Initialize the string before replacing characters
4.115
@df533f1
08/25/13 23:49:21 |
cynthia |
Stop a resource leak
Stops a resource leak in the event that the …
4.115
@7cba8ae6
08/23/13 10:53:04 |
Sebastian Huber |
smp: Fix warnings
4.115
@ec987ec0
08/22/13 15:35:33 |
Sebastian Huber |
sptests/spintrcritical20: PR2140: New test
4.115
@396f644
08/23/13 08:26:06 |
Sebastian Huber |
psxtests/psxfatal0[12]: Update due to API changes
4.115
@07332ae
08/22/13 13:20:06 |
Sebastian Huber |
score: _Thread_queue_Enqueue_with_handler()
Add thread parameter to …
4.115
@f4804efa
08/23/13 07:52:07 |
Sebastian Huber |
Filesystem: Remove superfluous free()
4.115
@630365b
08/23/13 07:43:53 |
Sebastian Huber |
Filesystem: Avoid usage of uninitialized variable
This is a cosmetic …
4.115
@dbdfc78f
08/23/13 07:02:40 |
Sebastian Huber |
libblock: PR2040: Avoid NULL pointer access
This partly reverts …
4.115
@38ec8af
08/23/13 07:20:23 |
Sebastian Huber |
libtests/flashdisk01: Update screen file
4.115
@6e4c01e
08/23/13 04:56:36 |
Chris Johns |
posix: Update to the pthread_once changes.
Implement the reeview …
4.115
@c9b66f5
08/22/13 12:00:51 |
Ric Claus |
bsps/arm: Add more CP15 cache functions
4.115
@1a246d7e
08/22/13 11:19:06 |
Sebastian Huber |
arm: Make barrier operations more visible
4.115
@389ffb28
08/21/13 12:58:26 |
Sebastian Huber |
dosfs: Use unprotected chain operations
4.115
@269dd12
08/20/13 13:14:13 |
Sebastian Huber |
smp: Documentation
4.115
@2cfbf23a
08/20/13 13:07:33 |
Sebastian Huber |
smp: Delete RTEMS_BSP_SMP_SIGNAL_TO_SELF
4.115
@518d82b
08/20/13 09:01:55 |
Sebastian Huber |
smp: Disable restart of threads other than self
4.115
@0432dff7
08/19/13 15:36:28 |
wei.a.yang |
add compare_and_swap check in check-atomic.m4
4.115
@99b3505
08/07/13 13:35:47 |
Sebastian Huber |
smp: Add Deterministic Priority SMP Scheduler
4.115
@48c4a55
08/13/13 11:13:25 |
Sebastian Huber |
smp: Generalize Simple SMP scheduler
4.115
@aea4a91
08/08/13 09:49:15 |
Sebastian Huber |
smp: Optimize Simple SMP scheduler
Add Thread_Control::is_in_the_air …
4.115
@fc2ad63
08/12/13 08:59:40 |
Sebastian Huber |
smp: _Scheduler_simple_smp_Allocate_processor()
Rename …
4.115
@6ba15488
08/12/13 10:34:27 |
Sebastian Huber |
smp: Rename _Scheduler_simple_smp_Start_idle()
Rename …
4.115
@9d83f58a
08/12/13 08:32:32 |
Sebastian Huber |
smp: Replace Scheduler_simple_smp_Control
Replace …
4.115
@0405082
08/12/13 08:22:21 |
Sebastian Huber |
score: Add _Priority_bit_map_Is_empty()
4.115
@c1a356e9
08/09/13 12:31:02 |
Sebastian Huber |
score: _Priority_bit_map_Handler_initialization()
Delete …
4.115
@a78e575
08/09/13 12:16:59 |
Sebastian Huber |
score: _Scheduler_priority_Ready_queue_initialize()
Move workspace …
4.115
@e00b0438
08/09/13 11:37:45 |
Sebastian Huber |
score: _Scheduler_priority_Ready_queue_first()
Remove superfluous …
4.115
@f20b3d56
08/09/13 11:34:18 |
Sebastian Huber |
score: Add _Scheduler_priority_Get_ready_queues()
Add and use …
4.115
@0c551f7
08/08/13 06:45:33 |
Sebastian Huber |
score: Add _Scheduler_priority_Get_scheduler_info
Add and use …
4.115
@e5ca54c9
08/07/13 19:19:55 |
Sebastian Huber |
score: PR2136: Fix _Thread_Change_priority()
Add call to …
4.115
@6931037
08/04/13 18:56:00 |
wei.a.yang |
correct memory model in smpatomic test case
4.115
@01b0755
08/14/13 07:56:27 |
Nick Withers |
Expose rtems_verror()
4.115
@2a2f559
08/08/13 23:22:06 |
Pavel Pisa |
bsp/csb336: Memory map update and jump to start at image start …
4.115
@526f895
08/14/13 13:35:58 |
Karel Gardas |
bsp/lm3s69xx: add macros for UART CTS/RTS pin configuration
4.115
@d473dc0
08/14/13 11:26:41 |
Sebastian Huber |
bsps: Fix clock driver defines
4.115
@66c0078
08/14/13 10:14:31 |
Sebastian Huber |
libblock: Add missing initializer
4.115
@ec98c997
08/14/13 09:55:51 |
Sebastian Huber |
posix: Typo
4.115
@6ccdc5c
08/14/13 09:08:15 |
Sebastian Huber |
rtems: Include missing header file
4.115
@540e8603
08/14/13 09:06:16 |
Sebastian Huber |
documentation: Directives allowed from an ISR
Update list.
4.115
@9de9b7d2
08/14/13 09:06:02 |
Sebastian Huber |
libblock: Add SMP support
4.115
@4180a9b
08/13/13 14:32:09 |
Sebastian Huber |
filesystem: Add SMP support
4.115
@b7f2060
08/14/13 01:53:28 |
Chris Johns |
bsp: Fix CLOCK_DRIVER_USE_FAST_IDLE and CLOCK_DRIVER_ISRS_PER_TICK.
4.115
@03acc59
08/14/13 00:21:41 |
Chris Johns |
posix: Change pthread_once to be SMP safe.
Change pthread_once from …
4.115
