@73a193f
10/21/16 12:15:30 |
Sebastian Huber |
score: Delete unused functions
Delete …
5
@3a27248
10/21/16 07:23:58 |
Sebastian Huber |
score: First part of new MrsP implementation
Update #2556.
5
@913864c
10/13/16 06:57:29 |
Sebastian Huber |
score: Use scheduler instance specific locks
Update #2556.
5
@6a82f1ae
10/10/16 09:46:07 |
Sebastian Huber |
score: Yield support for new SMP helping protocol
Update #2556.
5
@351c14d
09/27/16 09:33:36 |
Sebastian Huber |
score: Add new SMP scheduler helping protocol
Update #2556.
5
@2403473
09/23/16 12:54:04 |
Sebastian Huber |
score: Add _Thread_Scheduler_process_requests()
Update #2556.
5
@ebdd2a3
09/23/16 11:24:06 |
Sebastian Huber |
score: Add scheduler node requests
Add the ability to add/remove …
5
@edb020c
10/14/16 11:03:46 |
Sebastian Huber |
score: Protect thread CPU by thread scheduler lock
Update #2556.
5
@a7a8ec03
10/12/16 07:55:34 |
Sebastian Huber |
score: Protect thread scheduler state changes
Update #2556.
5
@07a32d19
09/23/16 09:57:59 |
Sebastian Huber |
score: Add thread scheduler lock
Update #2556.
5
@70c22d93
09/23/16 08:47:22 |
Sebastian Huber |
score: Add _Thread_Scheduler_remove_wait_node()
Update #2556.
5
@36d7aba
09/23/16 08:46:49 |
Sebastian Huber |
score: Add _Thread_Scheduler_add_wait_node()
Update #2556.
5
@1c9688a9
09/27/16 09:37:22 |
Sebastian Huber |
score: Add _Scheduler_Node_get_scheduler()
Update #2556.
5
@3a72411
10/10/16 13:03:39 |
Sebastian Huber |
score: Simplify _Scheduler_SMP_Node_change_state()
Update #2556.
5
@72e0bdb
10/10/16 12:50:19 |
Sebastian Huber |
score: Pass scheduler node to unblock operation
Changed for …
5
@e382a1b
10/10/16 12:33:17 |
Sebastian Huber |
score: Pass scheduler node to block operation
Changed for consistency …
5
@2df4abc
10/10/16 12:01:55 |
Sebastian Huber |
score: Pass scheduler node to yield operation
5
@501043a
09/30/16 12:38:04 |
Sebastian Huber |
score: Pass scheduler node to update priority op
This enables to call …
5
@d097b546
09/21/16 13:17:37 |
Sebastian Huber |
score: Rename scheduler ask for help stuff
Rename the scheduler ask …
5
@d057d653
09/30/16 08:10:22 |
Sebastian Huber |
score: Fix _Scheduler_Try_to_schedule_node() usage
Fix wrong use of …
5
@fac8a3a
11/02/16 09:01:36 |
Sebastian Huber |
bsps/sparc: Fix copy of initialized data
The text and data sections …
5
@b7694c8c
10/31/16 15:04:11 |
Sebastian Huber |
sptests/sp35: Remove dead code
5
@4cf58905
10/31/16 13:45:30 |
Sebastian Huber |
cpuuse: Use rtems_task_iterate()
Update #2423.
5
@d271c3bb
10/31/16 12:37:59 |
Sebastian Huber |
rtems: Add rtems_task_iterate()
Update #2423.
5
@bb9f09f
10/31/16 12:07:34 |
Sebastian Huber |
posix: Fix timer interval
Do not overwrite timer interval with …
5
@3e9f4c92
10/31/16 12:05:55 |
Sebastian Huber |
posix: Fix timeout handling in sigtimedwait()
Update #2798.
5
@7eec247
10/31/16 09:50:54 |
Sebastian Huber |
smptests/smplock01: Use test support
Convert output to XML.
5
@1aae680
10/21/16 13:34:21 |
Sebastian Huber |
sys/sockio.h: Update to FreeBSD head 2016-05-03
5
@505eb55
10/26/16 11:55:51 |
Sebastian Huber |
sys/uio.h: Update to FreeBSD head 2015-12-03
5
@8b8d05f
10/26/16 11:50:56 |
Sebastian Huber |
sys/event.h: Update to FreeBSD head 2016-06-27
5
@fc718cb8
10/22/16 15:46:56 |
jcmarsh |
Updated xilinx_zynq_a9_qemu bsp README instructions.
5
@f94155b
10/18/16 22:22:57 |
Sebastian Huber |
bsps/sparc: Add interrupt controller registers
5
@9361412
10/18/16 22:21:21 |
Sebastian Huber |
bsp/leon3: Avoid implicit integer conversions
5
@24fe213
10/17/16 12:36:49 |
alexander.krutwig |
atsam: multiple messages on one cs low level
5
@dfcec559
10/12/16 08:15:29 |
pisa |
libchip/network/if_fxp.c: do not use rtems_interrupt_disable.
The …
5
@20625a5
10/12/16 07:47:00 |
pisa |
bsps/i386: use Pentimum instructions for pc586 and pc686 builds.
When …
5
@6b54dcb
10/12/16 07:40:41 |
pisa |
bsps/i386: replace global interrupt disable by SMP build supporting …
5
@f45ddeea
10/13/16 05:51:55 |
Sebastian Huber |
bsp/atsamv: Fix typo
5
@f5eff00
10/13/16 05:09:49 |
Sebastian Huber |
score: Rename RTEMS_OBFUSCATE_POINTER()
The inline asm construct …
5
@826f3afa
10/11/16 22:15:23 |
Chris Johns |
libmisc/xz: Add xz decompression.
Add support to untar XZ compressed …
5
@be57318
09/23/16 04:45:07 |
Sebastian Huber |
score: More robust linker sets
Update #2408.
Update #2790.
5
@97eaefd4
10/12/16 08:44:51 |
Sebastian Huber |
score: Add RTEMS_OBFUSCATE_POINTER()
Update #2790.
5
@2ba0c035
10/12/16 07:54:58 |
Sebastian Huber |
score: Simplify check for migrations
5
@ed19002
10/12/16 08:37:07 |
Sebastian Huber |
smpschedaffinity05: Fix configuration
5
@facebbb
10/02/16 10:19:12 |
pisa |
bsps/i386: Separate variable for i8259 IRQs disable due to in progress …
5
@4745650
09/25/16 00:34:55 |
pisa |
pci.h add PCI_COMMAND_INTX_DISABLE definition.
5
@271690e
10/11/16 12:42:55 |
Sebastian Huber |
score: Enhance _SMP_barrier_Wait()
Indicate which processor released …
5
@282de10
10/11/16 08:42:15 |
Sebastian Huber |
bsp/qoriq: Add GPIO register map
5
@00bac95
10/11/16 06:25:39 |
Sebastian Huber |
bsps/sparc: Support GR740 GPIO
5
@475faef5
10/10/16 06:47:26 |
Sebastian Huber |
tmfine01: Add self-contained mutex test case
This demonstrates the …
5
@a899549e
10/05/16 12:04:23 |
Sebastian Huber |
bsp/atsam: Provide default buffer counts
5
@10eedb9f
10/05/16 12:04:07 |
Sebastian Huber |
bsp/atsam: Fix PHY detection
5
@8714684
10/04/16 21:30:22 |
pisa |
score/arm: Correct logic to select 64 byte cache line maximum size for …
5
@89b4a5cc
10/03/16 09:01:39 |
pisa |
libdl/rtl-obj.c: synchronize cache should not depend on …
5
@9b04456
09/30/16 05:54:29 |
Sebastian Huber |
monitor: Support priority inheritance queues
5
@8797c76
09/27/16 13:23:00 |
Sebastian Huber |
score: Unify CORE mutex seize/surrender
Use the …
5
@4e02681
09/23/16 09:56:45 |
Sebastian Huber |
score: Simplify ISR lock name
5
@94d5b390
09/23/16 09:29:48 |
Sebastian Huber |
score: Simplify CORE mutex seize
Rename …
5
@f0115ab
09/23/16 08:47:36 |
Sebastian Huber |
score: Fix warning
5
@938ee19c
09/23/16 08:09:57 |
Sebastian Huber |
sptests/spsem03: Fix compile error
5
@8ace7ee4
09/23/16 06:17:00 |
Sebastian Huber |
bsp/mvme147*: Fix linker issue
The GNU linker does not allow a …
5
@bbe8833
09/23/16 06:03:41 |
Sebastian Huber |
bsps/m68k: Add libatomic support to some bsp_specs
Update #2695.
5
@d6e58a0
09/23/16 04:44:08 |
Sebastian Huber |
bsps/m68k: Fix linker command file
Prevent garbage collection of …
5
@9149c87e
09/23/16 04:52:33 |
Sebastian Huber |
score: Fix C/C++ compatibility issue
Only use CPU_Per_CPU_control if …
5
@425f6cfa
09/22/16 07:56:06 |
pisa |
arm/tms570: document BSP setup with included hardware initialization.
5
@aae17bf3
09/22/16 07:48:26 |
pisa |
arm/tms570: update bootstrap generated preinstall.am
5
@98b6874
09/22/16 07:23:17 |
pisa |
arm/tms570: include TMS570_USE_HWINIT_STARTUP option to select bare …
5
@29430a3
09/22/16 07:50:59 |
pisa |
arm/tms570: include hardware initialization and selftest based on Ti …
5
@5746f10
09/12/16 08:46:58 |
pisa |
arm/tms570: define base addresses of all TMS570LS3137 SPI interfaces.
5
@a396ed4
09/17/16 15:09:11 |
pisa |
bsps/arm: Export bsp_start_hook_0_done symbol from ARM start.S.
The …
5
@4d3c866
09/20/16 22:14:45 |
pisa |
classic networking: adapt FXP driver to work with actual PCI and IRQ …
5
@f6142c19
09/09/16 09:00:06 |
Sebastian Huber |
score: Scheduler node awareness for thread queues
Maintain the …
5
@8123cae8
09/08/16 13:32:22 |
Sebastian Huber |
rtems: Add rtems_task_get_priority()
Update #2556.
Update #2784.
5
@6ae309ec
09/09/16 08:01:06 |
Sebastian Huber |
smptests/smpmutex01: Use test case functions
5
@266d383
09/08/16 12:07:12 |
Sebastian Huber |
score: Manage scheduler nodes via thread queues
Update #2556.
5
@5d6b211
09/07/16 07:04:45 |
Sebastian Huber |
score: Add scheduler node table for each thread
Update #2556.
5
@300f6a48
06/22/16 15:09:23 |
Sebastian Huber |
score: Rework thread priority management
Add priority nodes which …
5
@8c83cbc
08/04/16 21:32:06 |
pisa |
classic networking: do not reference BSP_irq_enabled_at_i8259s which …
5
@e814a23
09/16/16 12:20:07 |
Sebastian Huber |
termios: Add IO control handler
Update #2785.
5
@55e0be36
09/16/16 10:58:06 |
Sebastian Huber |
termios: Use IMFS nodes for new Termios devices
This makes the new …
5
@610b9ef1
09/19/16 05:51:07 |
Sebastian Huber |
libtests/devfs: Use printk()
This avoids problems with console …
5
@caf4064
09/16/16 12:54:12 |
Sebastian Huber |
fstests: Use printk() for IMFS configuration tests
This avoids …
5
@29770e12
09/16/16 12:21:30 |
Sebastian Huber |
tests: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
Avoid unnecessary use …
5
@d496e097
09/16/16 11:56:08 |
Sebastian Huber |
imfs: Untangle dependencies
This helps to use …
5
@a3e9ae5d
09/16/16 11:54:18 |
Sebastian Huber |
imfs: Fix IMFS_stat_file()
Use the adjusted and not the requested …
5
@0ab86d09
09/13/16 14:32:51 |
alexander.krutwig |
bsp/atsam: Add SPI bus driver
5
@a42be52
09/12/16 13:00:46 |
alexander.krutwig |
Add SPI bus framework
User API is compatible to Linux userspace API. …
5
@c186de5c
09/14/16 12:46:03 |
alexander.krutwig |
bsp/atsam: Use normal memory for QSPI flash area
This is a …
5
@5eb769ca
09/08/16 21:40:21 |
pisa |
arm/raspberrypi: define bsp_reset to restart board by watchdog.
5
@b20b736
06/28/16 04:54:50 |
Sebastian Huber |
score: Introduce _Thread_Get_priority()
Avoid direct access to thread …
5
@52a661e8
08/02/16 06:55:00 |
Sebastian Huber |
score: Add scheduler node implementation header
Update #2556.
5
@15b5678d
08/01/16 09:03:16 |
Sebastian Huber |
score: Move thread wait node to scheduler node
Update #2556.
5
@e27421f
08/01/16 09:12:52 |
Sebastian Huber |
score: Move scheduler node to own header file
This makes it possible …
5
@1f210ac1
08/10/16 06:37:16 |
Sebastian Huber |
score: Optimize thread queue enqueue
Optimize the enqueue to empty …
5
@e41308ea
08/22/16 08:58:34 |
Sebastian Huber |
score: Introduce Thread_queue_Lock_context
Introduce …
5
@114e408
08/22/16 11:17:05 |
Sebastian Huber |
score: Simplify thread queue acquire/release
5
@db563698
09/08/16 06:08:53 |
Sebastian Huber |
score: Fix warning
5
@63b36cbf
09/08/16 05:48:44 |
Sebastian Huber |
score: Fix warning
5
@8af1663
09/08/16 07:53:34 |
Sebastian Huber |
score: Fix for RTEMS_DEBUG
5
@275032b
09/08/16 07:31:47 |
Sebastian Huber |
powerpc: Fix SMP context switch
We need the unmodified r4 for …
5
