Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @6cb6c7c   11/01/04 11:03:09 Ralf Corsepius 2004-11-01 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @bb6c6701   10/31/04 14:08:34 Joel Sherrill 2004-10-31 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @db1431e9   10/29/04 17:18:12 Joel Sherrill 2004-10-29 Joel Sherrill <joel@…> * setup.def: Update gcc … 4.104.114.84.95
(edit) @9929e2d   10/29/04 10:38:40 Ralf Corsepius 2004-10-29 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @0f9ff459   10/29/04 10:34:38 Ralf Corsepius 2004-10-28 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @ec75ddc   10/29/04 10:15:31 Ralf Corsepius 2004-10-28 Ralf Corsepius <ralf_corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @b24b4eb   10/29/04 10:13:02 Ralf Corsepius 2004-10-28 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @9fcf77a6   10/28/04 18:09:48 Joel Sherrill 2004-10-28 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @62fdded   10/28/04 07:30:13 Ralf Corsepius 2004-10-28 Ralf Corsepius <ralf_corsepius@…> PR … 4.104.114.84.95
(edit) @91f706a   10/28/04 07:14:34 Ralf Corsepius 2004-10-28 Ralf Corsepius <ralf_corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @646bf00   10/27/04 23:15:41 Ralf Corsepius 2004-10-27 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @b345f83   10/27/04 21:17:55 WENorum Add -Wa,-m7450 to CPU_CFLAGS until gcc/gas get their acts together. 4.104.114.84.95
(edit) @2d5bcf6   10/27/04 11:13:04 Ralf Corsepius Remove obsolete files. 4.104.114.84.95
(edit) @c182e2d   10/27/04 08:24:10 Ralf Corsepius 2004-10-27 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @577fe95   10/27/04 06:12:23 Ralf Corsepius 2004-10-27 Ralf Corsepius <ralf_corsepius@…> PR … 4.104.114.84.95
(edit) @f1959d6   10/27/04 06:08:56 Ralf Corsepius Remove (Moved to cpukit/http). 4.104.114.84.95
(edit) @cc87080   10/27/04 06:03:12 Ralf Corsepius 2004-10-27 Ralf Corsepius <ralf_corsepius@…> PR … 4.104.114.84.95
(edit) @6b400fed   10/27/04 05:53:39 Ralf Corsepius 2004-10-27 Ralf Corsepius <ralf_corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @ca1e5baf   10/27/04 05:49:34 Ralf Corsepius 2004-10-27 Ralf Corsepius <ralf_corsepius@…> * Makefile.am, … 4.104.114.84.95
(edit) @be4bd26   10/27/04 05:48:46 Ralf Corsepius Add httpd. 4.104.114.84.95
(edit) @24c32fb   10/27/04 05:48:20 Ralf Corsepius Install libhttpd.a. 4.104.114.84.95
(edit) @eafc34b   10/26/04 17:11:03 Ralf Corsepius 2004-10-26 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @bb7bef4e   10/26/04 14:12:06 WENorum Remove environ common declaration -- it broke newlib. 4.104.114.84.95
(edit) @a097bd1   10/26/04 11:40:17 Ralf Corsepius 2004-10-26 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @75f4119a   10/26/04 11:03:21 Ralf Corsepius 2004-10-26 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @e9d4e8d   10/26/04 11:02:39 Ralf Corsepius New. 4.104.114.84.95
(edit) @795399e   10/26/04 10:45:02 Ralf Corsepius 2004-10-26 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @8c14432   10/26/04 09:48:53 Ralf Corsepius 2004-10-26 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @3822913   10/26/04 07:40:45 Ralf Corsepius 2004-10-26 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @a9dc09a   10/26/04 03:52:21 Ralf Corsepius Reformat. 4.104.114.84.95
(edit) @863b7f1b   10/26/04 03:47:07 Ralf Corsepius Reformat. 4.104.114.84.95
(edit) @04b7821   10/26/04 03:45:12 Ralf Corsepius 2004-10-26 Ralf Corsepius <ralf_corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @f002813d   10/26/04 03:40:54 Ralf Corsepius Reformat. 4.104.114.84.95
(edit) @3758c53c   10/25/04 20:41:29 WENorum Set RTEMS time during TOD initialization 4.104.114.84.95
(edit) @4db99d8a   10/25/04 19:22:07 WENorum No kernel/user distinction. 4.104.114.84.95
(edit) @bb5b4048   10/25/04 13:50:39 WENorum Install working version of ether_sprintf(). 4.104.114.84.95
(edit) @c4b0c2c1   10/22/04 21:32:42 WENorum Changes for new build system. 4.104.114.84.95
(edit) @29e72ae5   10/22/04 14:49:47 Ralf Corsepius New. 4.104.114.84.95
(edit) @ba5288d   10/22/04 14:47:07 Ralf Corsepius 2004-10-22 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @f98cd898   10/22/04 14:44:21 Ralf Corsepius 2004-10-22 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @e9415b3f   10/22/04 14:15:38 Ralf Corsepius 2004-10-22 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @1c214b1   10/22/04 14:09:43 Ralf Corsepius New. 4.104.114.84.95
(edit) @d04ca5a6   10/22/04 14:09:12 Ralf Corsepius 2004-10-22 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @134191b   10/22/04 14:06:33 Ralf Corsepius 2004-10-22 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @7a845a9e   10/22/04 11:54:09 Ralf Corsepius 2004-10-22 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @c3814c5   10/22/04 10:12:02 Ralf Corsepius 2004-10-22 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @0262dee   10/22/04 10:03:53 Ralf Corsepius 2004-10-22 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @a328cd15   10/22/04 05:46:58 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @e0d83348   10/22/04 05:30:46 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @c39ecd73   10/22/04 03:38:05 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @6a60333   10/22/04 03:33:19 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @cb97349   10/22/04 02:28:16 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @20a7adf   10/21/04 21:18:43 WENorum Add prototype for device-specific probe routine. 4.104.114.84.95
(edit) @05682dc   10/21/04 17:36:18 Joel Sherrill 2004-10-21 Joel Sherrill <joel@…> * startup/bspstart.c: … 4.104.114.84.95
(edit) @031d15d3   10/21/04 16:31:36 Joel Sherrill 2004-10-21 Joel Sherrill <joel@…> * Makefile.am: Add … 4.104.114.84.95
(edit) @a831baa   10/21/04 14:24:23 Ralf Corsepius Fix stupid typo. 4.104.114.84.95
(edit) @1e006d52   10/21/04 13:48:49 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @4bd22812   10/21/04 13:46:02 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @5146462f   10/21/04 13:42:53 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @d4d624e2   10/21/04 13:26:58 Ralf Corsepius 2004-10-20 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @ad17f7f   10/21/04 13:24:40 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @ee5769ad   10/21/04 13:21:26 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @15ebe58b   10/21/04 13:19:15 Ralf Corsepius 2004-10-20 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @1dff10fd   10/21/04 13:15:54 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @86ad4860   10/21/04 13:13:39 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @5523d789   10/21/04 13:10:10 Ralf Corsepius Add coverhd.h 4.104.114.84.95
(edit) @08f086ea   10/21/04 12:36:47 Ralf Corsepius Add libcpu and exception handling rels. 4.104.114.84.95
(edit) @b3a78e34   10/21/04 12:23:15 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @69d90133   10/21/04 11:57:39 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @f0d1c94   10/21/04 09:16:44 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @6741c2e1   10/21/04 09:01:00 Ralf Corsepius 2004-10-20 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @f59eab9c   10/21/04 08:41:43 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @b35f962   10/21/04 08:30:47 Ralf Corsepius New. 4.104.114.84.95
(edit) @1755e5d   10/21/04 08:29:47 Ralf Corsepius Adaptations to rtems-4.7. 4.104.114.84.95
(edit) @2fed9af   10/21/04 08:29:17 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @f61731c   10/21/04 08:28:07 Ralf Corsepius Remove (obsolete). 4.104.114.84.95
(edit) @de2582f8   10/21/04 08:26:38 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @1768b06   10/21/04 08:25:39 Ralf Corsepius Misc. adaptations to rtems-4.7. 4.104.114.84.95
(edit) @f4a59e33   10/21/04 08:17:43 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @24c094c   10/21/04 07:58:33 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * configure: … 4.104.114.84.95
(edit) @c5496d0   10/21/04 07:58:04 Ralf Corsepius New. 4.104.114.84.95
(edit) @430ae148   10/21/04 07:57:09 Ralf Corsepius Remove (Bogus). 4.104.114.84.95
(edit) @25a8b2fa   10/21/04 07:56:28 Ralf Corsepius New (Stub). 4.104.114.84.95
(edit) @48a57c5   10/21/04 04:00:00 Ralf Corsepius This commit was generated by cvs2svn to compensate for changes in … 4.104.114.84.95
(edit) @df68bcf1   10/21/04 04:00:00 Ralf Corsepius Import from zlib-1.2.5 4.104.114.84.95
(edit) @f8e0327   10/20/04 18:28:00 Joel Sherrill 2004-10-20 Joel Sherrill <joel@…> * README, configure.ac, … 4.104.114.84.95
(edit) @2fd2786   10/20/04 18:24:50 Joel Sherrill 2004-10-20 Kate Feng <feng1@…> * New BSP. 4.104.114.84.95
(edit) @83d7232   10/20/04 15:42:24 WENorum Add Kate Feng's MVME5500 BSP. 4.104.114.84.95
(edit) @f801bf2   10/20/04 15:26:06 WENorum Add MVME5500 BSP. 4.104.114.84.95
(edit) @e9aa9bb0   10/20/04 15:23:55 WENorum Add MPC7455 support. 4.104.114.84.95
(edit) @7be6ad9   10/20/04 15:21:05 WENorum Add MVME550 BSP 4.104.114.84.95
(edit) @811db88   10/20/04 14:53:26 Ralf Corsepius 2004-10-20 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @d2df5ee   10/20/04 08:25:35 Ralf Corsepius 2004-10-20 Ralf Corsepius <ralf_corsepius@…> PR 696/bsps * … 4.104.114.84.95
(edit) @76f9c44   10/20/04 08:23:27 Ralf Corsepius 2004-10-20 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @f876488   10/20/04 04:31:21 Ralf Corsepius 2004-10-20 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @39d1c25   10/20/04 04:30:31 Ralf Corsepius Preinstall tm27.h 4.104.114.84.95
(edit) @d48a010c   10/20/04 04:29:23 Ralf Corsepius 2004-10-20 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @41d0d94e   10/19/04 13:46:47 Ralf Corsepius 2004-10-19 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @9a4b31f   10/19/04 09:57:02 Ralf Corsepius 2004-10-19 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @41ed282   10/19/04 08:08:22 Ralf Corsepius 2004-10-19 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
