Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @59097e7   04/18/97 18:38:19 Joel Sherrill Changed format of comment blocks to C comments. 4.104.114.84.95
(edit) @7e7143e   04/18/97 18:37:48 Joel Sherrill Duplicated timerisr symbol as _timerisr to avoid tool naming problems. 4.104.114.84.95
(edit) @58ae19a   04/18/97 18:33:53 Joel Sherrill Updated to reflect --enable-gcc28 and --enable-libcdir options. 4.104.114.84.95
(edit) @dda5cf4   04/18/97 17:50:01 Joel Sherrill Corrected incorrect settings for locations of psx and sp test screens. 4.104.114.84.95
(edit) @e412bae   04/18/97 12:45:32 Joel Sherrill Modifications to add --enable-libcdir and --enable-gcc28. These trip … 4.104.114.84.95
(edit) @fb07f404   04/17/97 14:38:27 Joel Sherrill Added gen68360_040. 4.104.114.84.95
(edit) @9fbba98   04/16/97 17:47:48 Joel Sherrill Fixed path which points to shared directory for all BSPs. 4.104.114.84.95
(edit) @334b01f1   04/16/97 17:46:26 Joel Sherrill fixed spacing 4.104.114.84.95
(edit) @f9f375e   04/16/97 17:45:52 Joel Sherrill added fpsp support. 4.104.114.84.95
(edit) @f8f370b6   04/16/97 17:45:35 Joel Sherrill Update from Eric Norum. 4.104.114.84.95
(edit) @34217ccf   04/16/97 17:42:20 Joel Sherrill Updated to reflect Tony Bennett's new email address and the … 4.104.114.84.95
(edit) @5bf6ffb   04/16/97 17:34:40 Joel Sherrill Added FPSP support for MC68040 4.104.114.84.95
(edit) @010e7582   04/16/97 17:34:23 Joel Sherrill Added CVS Id's 4.104.114.84.95
(edit) @f9b93da   04/16/97 17:33:04 Joel Sherrill Added the MC68040 Floating Point Support Package. This was ported to … 4.104.114.84.95
(edit) @83e39b26   04/16/97 17:31:52 Joel Sherrill Added --disable-tcpip option. Add discussion of the pecularities of … 4.104.114.84.95
(edit) @6881e0c   04/15/97 18:02:18 Joel Sherrill Reduced number of POSIX thread priorities from 255 to 254 to avoid … 4.104.114.84.95
(edit) @c24fef3   04/15/97 18:00:03 Joel Sherrill Added directories to place test output screens into as part of fixing … 4.104.114.84.95
(edit) @b1a4ca8   04/15/97 17:40:38 Joel Sherrill Added line to install test screens so difftest does not have to have a … 4.104.114.84.95
(edit) @b584751   04/15/97 17:37:12 Joel Sherrill Switched all bsps which had an implementation of sbrk.c which only … 4.104.114.84.95
(edit) @ecc4594   04/15/97 17:28:26 Joel Sherrill Removed many BSPs' copy of setvec.c and let them share the same … 4.104.114.84.95
(edit) @bc7d465   04/11/97 18:41:38 Joel Sherrill replaced linking of source from mvme147 drivers with use of vpath to … 4.104.114.84.95
(edit) @18e5d86   04/11/97 18:40:04 Joel Sherrill removed commented out line performing a link 4.104.114.84.95
(edit) @6bcceb8   04/09/97 21:00:33 Joel Sherrill enabled floating point and fixed confdef reference to initialization … 4.104.114.84.95
(edit) @61a183a9   04/09/97 20:19:35 Joel Sherrill new test 4.104.114.84.95
(edit) @dfdaf4ac   04/09/97 20:19:22 Joel Sherrill added cpuuse and rtmonuse 4.104.114.84.95
(edit) @c46ce854   04/09/97 20:19:07 Joel Sherrill printing task names now instead of id numbers 4.104.114.84.95
(edit) @fc7bc51   04/09/97 20:18:54 Joel Sherrill new files. 4.104.114.84.95
(edit) @9d5152f   04/09/97 20:07:22 Joel Sherrill added rtmonuse and cpuuse directories 4.104.114.84.95
(edit) @8f695a1   04/09/97 20:07:09 Joel Sherrill added cpuuse and rtmonuse directories 4.104.114.84.95
(edit) @e39e6f7   04/09/97 20:05:59 Joel Sherrill added code to prevent attempts to clean up the library when rtems is down. 4.104.114.84.95
(edit) @0956b52   04/09/97 20:05:37 Joel Sherrill correct incorrect register addresses for port a. 4.104.114.84.95
(edit) @8c0dc2c   04/09/97 20:05:12 Joel Sherrill removed unused is_character_ready routine. 4.104.114.84.95
(edit) @3fc076d   04/09/97 20:04:52 Joel Sherrill added support for tracking thread cpu usage. 4.104.114.84.95
(edit) @192259f   04/09/97 20:04:36 Joel Sherrill enhanced printf statements 4.104.114.84.95
(edit) @48e34595   04/09/97 20:04:22 Joel Sherrill corrected spacing. 4.104.114.84.95
(edit) @bbb846b   04/09/97 20:03:59 Joel Sherrill added SYSTEM_STATE_SHUTDOWN 4.104.114.84.95
(edit) @eafd698   04/09/97 20:03:35 Joel Sherrill enhanced rtems_shutdown_executive to insure that no attempt will be … 4.104.114.84.95
(edit) @113ef9fc   04/09/97 20:02:29 Joel Sherrill added support for statistics on rate monotonic periods. 4.104.114.84.95
(edit) @0c3cd61   04/09/97 19:59:17 Joel Sherrill Rate monotonic period and cpu usage monitor libraries and tests added. 4.104.114.84.95
(edit) @d2afb93   04/09/97 19:58:27 Joel Sherrill blank lines deleted 4.104.114.84.95
(edit) @48d6de3   04/09/97 14:46:16 Joel Sherrill Adding missing files. 4.104.114.84.95
(edit) @e2d79559   04/09/97 14:05:50 Joel Sherrill Added ka9q tcpip stack and network driver for the gen68360. This … 4.104.114.84.95
(edit) @bed475e   04/08/97 11:53:54 Joel Sherrill added cast to eliminate warning. 4.104.114.84.95
(edit) @f8700f77   04/07/97 21:33:28 Joel Sherrill corrected printf specifications and added casts as necessary to … 4.104.114.84.95
(edit) @de4f281   04/07/97 21:31:59 Joel Sherrill added ifdef to avoid warning for unused variable. 4.104.114.84.95
(edit) @1c666fc   04/07/97 21:31:39 Joel Sherrill corrected integer only definitions of "FP CHECK" routines to eliminate … 4.104.114.84.95
(edit) @9ffcaa4a   04/07/97 21:30:58 Joel Sherrill changed signed int to unsigned int to eliminate a warning. 4.104.114.84.95
(edit) @bd71da7   04/07/97 21:30:42 Joel Sherrill removed noreturn attribute to eliminate warnings. 4.104.114.84.95
(edit) @82478528   04/07/97 21:30:16 Joel Sherrill commented out sccs_id's to eliminate warnings. 4.104.114.84.95
(edit) @dd1d1c7   04/07/97 21:29:49 Joel Sherrill added prototype and return statement to eliminate warnings. 4.104.114.84.95
(edit) @f1fc782e   04/07/97 21:29:09 Joel Sherrill commented out sccs_id's to eliminate warnings. main.c: added return … 4.104.114.84.95
(edit) @318976f   04/07/97 21:28:21 Joel Sherrill removed reference to no_bsp. added prototypes. 4.104.114.84.95
(edit) @de1d716   04/07/97 21:27:59 Joel Sherrill commented out sccs_id to eliminate warnings 4.104.114.84.95
(edit) @2938c1a3   04/07/97 21:27:22 Joel Sherrill added or fixed includes of page_table.h to eliminate warnings. 4.104.114.84.95
(edit) @588c9ed   04/07/97 21:26:49 Joel Sherrill added cast to eliminate warning 4.104.114.84.95
(edit) @930b3d5   04/07/97 21:26:34 Joel Sherrill added prototype for delay. 4.104.114.84.95
(edit) @3bc409c   04/07/97 21:26:22 Joel Sherrill added global statement for start entry point 4.104.114.84.95
(edit) @437366f   04/07/97 21:25:42 Joel Sherrill removed noreturn from prototype to avoid warnings. 4.104.114.84.95
(edit) @2bad8aa   04/07/97 21:25:21 Joel Sherrill added cast to eliminate warning. 4.104.114.84.95
(edit) @759a9d9   04/07/97 21:24:28 Joel Sherrill added return statement to avoid warning. 4.104.114.84.95
(edit) @d6ba279   04/07/97 21:24:02 Joel Sherrill added initialization of variable to eliminate warning. 4.104.114.84.95
(edit) @0b50855   04/07/97 21:23:43 Joel Sherrill added include of unistd.h to eliminate warning for no prototype for … 4.104.114.84.95
(edit) @c6e895df   04/07/97 21:22:59 Joel Sherrill added ifdef around variables to eliminate warnings when cross 4.104.114.84.95
(edit) @12d6f14   04/07/97 21:22:15 Joel Sherrill added "ifndef" to avoid redefinition warning. 4.104.114.84.95
(edit) @424ab48   04/07/97 21:21:55 Joel Sherrill added volatile to Switch_necessary structure member to avoid warning. 4.104.114.84.95
(edit) @d911f4c2   04/07/97 21:21:21 Joel Sherrill added test to avoid spurious error 4.104.114.84.95
(edit) @4e8c5a6b   04/07/97 21:20:57 Joel Sherrill added prototype for missing routine. 4.104.114.84.95
(edit) @d749165   04/07/97 21:20:48 Joel Sherrill added "return" to eliminate warning. 4.104.114.84.95
(edit) @2ff1d549   04/07/97 21:20:35 Joel Sherrill added "ifndef" to avoid redefinition warning 4.104.114.84.95
(edit) @82ab443e   04/07/97 21:20:16 Joel Sherrill added prototypes for two assembly language routines to eliminate warnings. 4.104.114.84.95
(edit) @32ef3dc   04/07/97 21:19:59 Joel Sherrill commented out sccs_id to eliminate warning. 4.104.114.84.95
(edit) @11259ab7   04/07/97 21:19:15 Joel Sherrill added plea for someone to implement software stack switching for … 4.104.114.84.95
(edit) @77d20fb   04/07/97 21:18:50 Joel Sherrill Replaced warning message for cpus which do not have hardware support … 4.104.114.84.95
(edit) @2e4bc8b4   04/07/97 21:17:42 Joel Sherrill initialized variable to eliminate warning 4.104.114.84.95
(edit) @94784cf8   04/07/97 21:16:47 Joel Sherrill changed signed int to unsigned to eliminate warning 4.104.114.84.95
(edit) @17c4511   04/07/97 21:16:31 Joel Sherrill added "ifndef" for ASM to avoid redefinition warnings. 4.104.114.84.95
(edit) @872cc62   04/07/97 21:15:24 Joel Sherrill updated to put bsps in alphabetical order 4.104.114.84.95
(edit) @1c24fe7   04/02/97 16:27:05 Joel Sherrill corrected one of the references to an environment variable which is no … 4.104.114.84.95
(edit) @51f5d64c   04/02/97 16:26:39 Joel Sherrill corrected printf format to avoid warning 4.104.114.84.95
(edit) @892a536d   04/02/97 16:26:28 Joel Sherrill initialized variables or removed unused variables to remove warnings 4.104.114.84.95
(edit) @475fb331   04/02/97 15:39:20 Joel Sherrill disabled posix api for the no_cpu-rtems configuration in configure.in … 4.104.114.84.95
(edit) @bbbd11c   04/02/97 15:00:52 Joel Sherrill added Jiri for autoconf'ing 4.104.114.84.95
(edit) @9a11e1f   04/02/97 14:58:19 Joel Sherrill was checking for null cpu_table -- short have been checking … 4.104.114.84.95
(edit) @254b4450   04/01/97 23:07:52 Joel Sherrill This set of changes is the build of what was required to convert to … 4.104.114.84.95
(edit) @467eae4d   03/21/97 19:20:40 Joel Sherrill Fixed symbols. 4.104.114.84.95
(edit) @1a3e4fa   03/21/97 19:20:25 Joel Sherrill added decrementer entry. 4.104.114.84.95
(edit) @84e5b57f   03/21/97 19:19:33 Joel Sherrill Removed Fake input ifdef code. 4.104.114.84.95
(edit) @691259b   03/21/97 19:18:11 Joel Sherrill Fixed timerisr symbol. 4.104.114.84.95
(edit) @e667a0b   03/21/97 19:17:46 Joel Sherrill Rewrote to avoid references to C symbols from assembly. This entirely … 4.104.114.84.95
(edit) @51c9fb4   03/21/97 19:17:05 Joel Sherrill Fixes incorrect reference to start symbol. 4.104.114.84.95
(edit) @d0e126a6   03/11/97 15:53:05 Joel Sherrill updates from John Gwynne 4.104.114.84.95
(edit) @6335022e   03/11/97 15:42:59 Joel Sherrill updates from John Gwynne 4.104.114.84.95
(edit) @c43b34c   03/11/97 15:42:14 Joel Sherrill modified _Chain_Insert_unprotected to have the form required to be … 4.104.114.84.95
(edit) @0302021   03/11/97 15:41:19 Joel Sherrill swapped increment of _ISR_Nest_level and _Thread_Dispatch_disable_level 4.104.114.84.95
(edit) @1dc3500   03/10/97 19:38:30 Joel Sherrill added include of rtems.h so the proper macro definitions would be present. 4.104.114.84.95
(edit) @41c58154   03/10/97 19:38:06 Joel Sherrill made some of this conditional on unix lib 4.104.114.84.95
(edit) @a3cfa9f   03/10/97 19:37:44 Joel Sherrill initialized a stack variable to avoid a warning. 4.104.114.84.95
(edit) @d627c0c4   03/10/97 16:57:08 Joel Sherrill created. Split getpid() from types.c to allow it to be overridden by … 4.104.114.84.95
(edit) @fec60e9   03/10/97 16:56:08 Joel Sherrill Fixed bug where the initial detachstate was not being set properly 4.104.114.84.95
(edit) @1149658   03/08/97 03:57:09 Joel Sherrill updated version to 4.0.0 4.104.114.84.95
