@55e0be36
09/16/16 10:58:06 |
Sebastian Huber |
termios: Use IMFS nodes for new Termios devices
This makes the new …
5
@610b9ef1
09/19/16 05:51:07 |
Sebastian Huber |
libtests/devfs: Use printk()
This avoids problems with console …
5
@caf4064
09/16/16 12:54:12 |
Sebastian Huber |
fstests: Use printk() for IMFS configuration tests
This avoids …
5
@29770e12
09/16/16 12:21:30 |
Sebastian Huber |
tests: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
Avoid unnecessary use …
5
@d496e097
09/16/16 11:56:08 |
Sebastian Huber |
imfs: Untangle dependencies
This helps to use …
5
@a3e9ae5d
09/16/16 11:54:18 |
Sebastian Huber |
imfs: Fix IMFS_stat_file()
Use the adjusted and not the requested …
5
@0ab86d09
09/13/16 14:32:51 |
alexander.krutwig |
bsp/atsam: Add SPI bus driver
5
@a42be52
09/12/16 13:00:46 |
alexander.krutwig |
Add SPI bus framework
User API is compatible to Linux userspace API. …
5
@c186de5c
09/14/16 12:46:03 |
alexander.krutwig |
bsp/atsam: Use normal memory for QSPI flash area
This is a …
5
@5eb769ca
09/08/16 21:40:21 |
pisa |
arm/raspberrypi: define bsp_reset to restart board by watchdog.
5
@b20b736
06/28/16 04:54:50 |
Sebastian Huber |
score: Introduce _Thread_Get_priority()
Avoid direct access to thread …
5
@52a661e8
08/02/16 06:55:00 |
Sebastian Huber |
score: Add scheduler node implementation header
Update #2556.
5
@15b5678d
08/01/16 09:03:16 |
Sebastian Huber |
score: Move thread wait node to scheduler node
Update #2556.
5
@e27421f
08/01/16 09:12:52 |
Sebastian Huber |
score: Move scheduler node to own header file
This makes it possible …
5
@1f210ac1
08/10/16 06:37:16 |
Sebastian Huber |
score: Optimize thread queue enqueue
Optimize the enqueue to empty …
5
@e41308ea
08/22/16 08:58:34 |
Sebastian Huber |
score: Introduce Thread_queue_Lock_context
Introduce …
5
@114e408
08/22/16 11:17:05 |
Sebastian Huber |
score: Simplify thread queue acquire/release
5
@db563698
09/08/16 06:08:53 |
Sebastian Huber |
score: Fix warning
5
@63b36cbf
09/08/16 05:48:44 |
Sebastian Huber |
score: Fix warning
5
@8af1663
09/08/16 07:53:34 |
Sebastian Huber |
score: Fix for RTEMS_DEBUG
5
@275032b
09/08/16 07:31:47 |
Sebastian Huber |
powerpc: Fix SMP context switch
We need the unmodified r4 for …
5
@d4160618
09/07/16 03:59:16 |
Chris Johns |
testsuite: Add libdl/dl05 reloc test.
5
@11323b7
09/06/16 06:20:14 |
Chris Johns |
libdl: Add ARM C++ relocation record support.
Closes #2767
5
@84e960e
09/07/16 12:25:30 |
Sebastian Huber |
stackchk: Fix stack checker thread initialization
Commit …
5
@8bb9d41
09/07/16 12:08:06 |
Sebastian Huber |
stackchk: Use a const pattern to check
5
@bba988d
09/07/16 11:46:40 |
Sebastian Huber |
stackchk: Remove superfluous internal header file
5
@531924d
09/08/16 05:24:29 |
Sebastian Huber |
bsp/raspberrypi: Rename file
5
@5d369c85
09/03/16 12:10:52 |
pisa |
arm/raspberrypi: use GPU/system timer as clock source.
It has …
5
@40f49d1
09/03/16 12:04:16 |
pisa |
arm/raspberrypi: correct and extend definitions for GPU timer.
5
@df2ee9d
09/07/16 18:28:33 |
pisa |
arm/raspberrypi: basic BCM2836 SMP implementation.
The BSP support is …
5
@38a5385
09/01/16 19:55:51 |
pisa |
arm/raspberrypi: propagate number of configured CPUs into linker script.
5
@dfbedf3
09/01/16 19:40:09 |
pisa |
arm/raspberrypi: rename linkcmds to linkcmds.in to allow their …
5
@4c53be1
09/03/16 01:37:36 |
pisa |
arm/raspberrypi: more definitions of BCM2836 core local peripherals.
5
@bf62c39
09/03/16 00:26:10 |
krohini1593 |
arm/raspberrypi: include definitions of BCM2836 SMP mailboxes.
5
@6e6a77a6
09/02/16 23:59:21 |
pisa |
bsps/arm: reorganize CP15 code to allow clean and invalidate ARMv7 …
5
@5c494641
09/02/16 23:30:47 |
pisa |
bsps/arm: remove lock in arm_cp15_set_translation_table_entries().
5
@7ec689ad
09/02/16 23:30:20 |
pisa |
bsps/arm: use defines for cache type register format field.
The …
5
@b9cc5aa
08/22/16 08:41:33 |
Christian.Mauderer |
bsp/atsam: Add SDRAM IS42S16320F-7BL.
5
@beb289e
08/19/16 09:59:12 |
bsp/atsam: Move ram init values to structure.
5
@29594b4
09/07/16 07:27:59 |
Sebastian Huber |
score: Remove superfluous SMP debug support
This information turned …
5
@cac586e6
09/06/16 08:55:09 |
Sebastian Huber |
bsp/xilinx-zynq: Avoid duplicate declaration
5
@3709987
08/10/16 06:21:54 |
Sebastian Huber |
score: Add _Chain_Initialize_one()
5
@da15db78
08/24/16 13:25:33 |
Sebastian Huber |
score: Improve red-black tree debug support
Ensure that we extract a …
5
@83b0229
06/28/16 04:59:29 |
Sebastian Huber |
score: Add _RBTree_Initialize_one()
5
@796f12a
08/19/16 11:37:01 |
Sebastian Huber |
score: Add missing const qualifiers
5
@1dd8fff
09/06/16 08:50:50 |
Sebastian Huber |
capture: Use proper accessor functions
5
@7af6b58c
09/06/16 05:44:06 |
Sebastian Huber |
capture: Workaround to avoid misaligned access
Move the 64-bit field …
5
@1c18ebf0
08/31/16 08:56:09 |
Chris Johns |
libmisc/capture: Remove the reserved _t in the types.
5
@6da06c5
08/30/16 06:46:25 |
Chris Johns |
libmisc/capture: Fix the capture engine on SMP.
This patches some …
5
@caf2cbd
08/16/16 05:49:41 |
Chris Johns |
arm/xilinx_zynq: Start the second core when an SMP build.
5
@13c985c
08/31/16 14:49:15 |
pisa |
arm/xilinx_zynq: ensure that cache is cleaned and MMU disabled when …
5
@6deb4190
08/25/16 06:18:21 |
Chris Johns |
libdl: The dl04 is too big for some BSPs. Do not built it.
5
@3c74f4aa
08/27/16 06:15:04 |
muditjain18011995 |
arm/raspberrypi: Mailbox : Extending functionality
Adding …
5
@8099e0a
08/24/16 14:26:07 |
alexander.krutwig |
bsp/atsam: Add missing break statement
5
@8cf102dd
08/24/16 13:30:06 |
alexander.krutwig |
bsp/atsam: Fix data cache flush
5
@89a319a0
08/23/16 01:11:53 |
Chris Johns |
libbsp/arm: Fix ARM BSPs missing the bsp_translation_table_end symbol. …
5
@36fad91
08/19/16 05:38:07 |
Kevin-Kirspel |
arm: Add VFP context validate support for ARMv5
5
@fea392a
08/10/16 08:32:39 |
alexander.krutwig |
bsp/atsam: Add timeout to QSPI send command
5
@5d1fc66
08/12/16 13:54:46 |
Sebastian Huber |
psxtests: Adjust sporadic server tests
According to POSIX priority …
5
@9c42752
08/17/16 05:33:14 |
Sebastian Huber |
score: Fix undefined behaviour
Cast POSIX error codes to unsigned int …
5
@381c42b
08/12/16 09:18:38 |
Chris Johns |
testsuite: Add libdl/dl04 cache test.
5
@97d395b
08/12/16 08:55:53 |
Chris Johns |
testsuite: Add libdl/dl03 cache test.
5
@58c34961
08/12/16 08:02:52 |
Chris Johns |
libdl: Fix cache corruption bugs.
This patch fixes a number of bugs …
5
@75386e11
08/12/16 07:57:51 |
Chris Johns |
libdl: Add trace output when reading section headers.
5
@01aa1ba
08/09/16 07:05:27 |
Chris Johns |
libbsp/arm: Add the TTB table to the default MMU set up as read/write. …
5
@55faa44
08/12/16 09:16:45 |
Sebastian Huber |
score: Improve _RBTree_Insert_inline()
Return if the inserted node is …
5
@424ffe4d
08/11/16 08:26:57 |
Sebastian Huber |
score: Introduce thread queue surrender operation
This is an …
5
@a827447
08/11/16 07:47:21 |
Sebastian Huber |
score: Dismantle _Thread_queue_Do_extract_locked()
Dismantle …
5
@fef3ea9
08/11/16 06:32:49 |
Sebastian Huber |
score: Add _Thread_queue_Surrender()
Add _Thread_queue_Surrender() to …
5
@03c1038
08/10/16 03:28:50 |
Chris Johns |
librtems++: Remove from RTEMS.
This is old and there are better …
5
@9a4eca5
08/10/16 03:07:29 |
Chris Johns |
build-system: Always enable C++ if the compiler is present.
We always …
5
@709594f0
08/01/16 20:54:18 |
Gedare Bloom |
posix: nanosleep: adjust elapsed time calculation
Use clock_gettime …
5
@21d73655
08/10/16 07:54:13 |
Sebastian Huber |
sptests/splinkersets01: Fix for small-data area
5
@b0f08c8
08/01/16 01:02:13 |
Chris Johns |
libmisc/untar: Set the perms to the value in the tar file.
This patch …
5
@5d0f0de4
07/28/16 11:33:50 |
alexander.krutwig |
bsp/atsam: Add power support
5
@5c09e9d
08/08/16 07:47:06 |
Sebastian Huber |
sptests/splinkersets01: Fix warnings
5
@e5fd901
07/28/16 10:01:58 |
alexander.krutwig |
atsam: Add atsam_rtc_get_time()
5
@aaaf9610
08/08/16 06:44:51 |
Sebastian Huber |
score: Add debug support to red-black trees
This helps to detect …
5
@2cb9b86e
08/08/16 06:30:17 |
Sebastian Huber |
posix: Fix for RTEMS_DEBUG
5
@69dd99b
08/05/16 06:19:39 |
Sebastian Huber |
score: Simplify _Thread_Finalize_life_change()
5
@ee0e4135
08/04/16 08:20:29 |
Sebastian Huber |
score: Fix a release/cancel job race condition
Split up the potential …
5
@ca783bbe
08/04/16 08:16:14 |
Sebastian Huber |
score: Fix _Thread_queue_Path_release()
It is possible that the owner …
5
@6117f29
08/04/16 06:31:25 |
Sebastian Huber |
score: Fix _Scheduler_EDF_Cancel_job_filter()
Commit …
5
@1c1e31f7
08/04/16 06:10:29 |
Sebastian Huber |
score: Optimize _Thread_queue_Path_release()
Update #2556.
5
@21bdca4
08/03/16 13:41:31 |
Sebastian Huber |
score: Indroduce cancel job scheduler operation
Do not use a deadline …
5
@ff2e6c64
08/02/16 09:26:56 |
Sebastian Huber |
score: Fix and simplify thread wait locks
There was a subtile race …
5
@3b3552bf
08/03/16 11:40:26 |
Sebastian Huber |
5
@ec735c6a
08/03/16 11:27:13 |
Sebastian Huber |
5
@5fe6d07a
08/01/16 11:16:57 |
linker set: Allow adding any variable into content
The newly created …
5
@501b11ba
08/01/16 12:00:14 |
Sebastian Huber |
5
@db6a637
07/29/16 00:29:23 |
Chris Johns |
score: Fix for RTEMS_DEBUG.
5
@912a1a90
07/31/16 11:10:28 |
pisa |
arm/raspberrypi: framebuffer driver checks for initialization and …
5
@3d3ad4dc
07/31/16 09:33:06 |
pisa |
arm/raspberrypi: VideoCore? access corrections in cache operation and …
5
@842005e4
07/29/16 17:13:41 |
Gedare Bloom |
posix: nanosleep: optimize away a time conversion
updates #2732
5
@f383f4bf
07/27/16 09:39:56 |
Sebastian Huber |
bsp/qoriq: Remove legacy U-Boot support
5
@cecc109
07/28/16 08:48:02 |
Sebastian Huber |
bsp/qoriq: Fix start stack setup
5
@6446773
07/28/16 08:35:24 |
Sebastian Huber |
bsp/qoriq: Fix tlbwe synchronization
5
@b1ef3674
07/27/16 09:30:09 |
Sebastian Huber |
bsp/qoriq: Add QORIQ_HAS_WRITE_BACK_L1_CACHE
Fixes start via U-Boot …
5
@d79df38
07/26/16 08:34:21 |
Sebastian Huber |
score: Add deadlock detection
The mutex objects use the owner field …
5
@1fcac5ad
07/25/16 14:35:37 |
Sebastian Huber |
score: Turn thread lock into thread wait lock
The …
5
