@359a3a3
11/22/18 05:38:42 |
Sebastian Huber |
score: Rename Objects_Information::allocation_size
Rename …
5
@0da9d80
11/22/18 05:16:52 |
Sebastian Huber |
score: Rename Objects_Information::size
Rename …
5
@9c9c6a9
11/21/18 16:30:52 |
Sebastian Huber |
score: Remove Objects_Information::is_string
Use …
5
@d6e3473
11/23/18 19:37:57 |
Sebastian Huber |
score: Remove dead code
Update #3621.
5
@7ee6437
12/06/18 08:57:01 |
Sebastian Huber |
rtems: Add rtems_scheduler_get_maximum_priority()
Update #3636.
5
@0a1f5df9
05/03/18 11:03:27 |
Sebastian Huber |
Simplify _CPU_Counter_difference()
In order to simplify the use of …
5
@ef23838
12/03/18 12:10:21 |
Sebastian Huber |
score: Avoid sbintime_t in API headers
The sbintime_t is a non-POSIX …
5
@9921ab6
12/05/18 09:03:13 |
Sebastian Huber |
psxtimes01: Fix sporadic failures
It is not enough to just wait for …
5
@03e86553
12/05/18 07:05:54 |
Sebastian Huber |
tests: Fix rtems_test_spin_until_next_tick()
This bug surfaced due to …
5
@fcd577a
12/07/18 04:29:42 |
joel |
psxtests/Makefile.am: Fix ticket number for ucontext.h
5
@17c32e5d
12/07/18 02:48:46 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for ucontext.h (GCI 2018)
5
@bf763d3e
12/06/18 21:23:16 |
mcomajoancara |
Implement POSIX API Signature Compliance Tests for inttypes.h
This …
5
@9feff78
12/06/18 19:10:59 |
shashvatjain2002 |
psxhdrs:Add POSIX Conformance Test for fmtmsg.h (GCI 2018)
5
@1e455d4
12/06/18 18:24:13 |
shashvatjain2002 |
Includes …
5
@b24c098
12/06/18 19:06:29 |
himanshuwindows8.1 |
psxhdrs: Add POSIX API Signature Compliance Tests for string.h (GCI 2018)
5
@a803bd9e
12/06/18 16:49:32 |
zenon.hans.taneka |
Added POSIX Compliance Test for <ctype.h> (GCI 2018)
5
@5886a701
12/06/18 17:30:23 |
joel |
psxtmtests_plan.csv: Add preemption cases for pthread_setschedprio
5
@be9a83d
12/06/18 16:34:16 |
mcomajoancara |
psxtmtests/psxtmtests_plan.csv: Fix typos (GCI 2018)
Two quotation …
5
@c078065
12/06/18 16:28:23 |
mcomajoancara |
psxtmtests: Identified a Timing Test missing (GCI 2018)
5
@9598f83e
12/06/18 13:08:12 |
shashvatjain2002 |
psxhdrs: Add POSIX Conformance Tests for math.h (GCI 2018)
Includes …
5
@da262164
12/06/18 11:16:25 |
abhimanyuraghuvanshi29 |
POSIX Signature Test for fenv.h (GCI 2018)
Updates #2971.
5
@187ef31
12/06/18 06:44:41 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for wctype.h (GCI 2018)
5
@e50b4bd3
12/06/18 12:40:08 |
Sebastian Huber |
score: Use typeof for strict ISO C compat
Enable the use of …
5
@4e46ba8
12/06/18 09:49:43 |
Sebastian Huber |
rtems: Fix rtems_task_restart() argument type
Close #3637.
5
@bf135a9
12/06/18 04:08:31 |
POSIX Compliance Signature Test for glob.h (GCI 2018)
5
@65b3fba
12/05/18 23:02:39 |
zenon.hans.taneka |
Added POSIX Compliance Test for complex.h, and adding lines to define …
5
@95095be
12/06/18 00:33:33 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for ftw.h (GCI 2018)
5
@cbb08b61
12/05/18 22:07:33 |
joel |
psxhdrs: Fix spacing
5
@36e1b82
12/05/18 21:23:58 |
joel |
psxtmcleanup01/init.c: Fix warnings
5
@70966985
12/05/18 21:23:40 |
joel |
psxhdrs/strings/strncasecmp_l.c: Fix warning
5
@a115818
12/05/18 20:03:13 |
psxhdrs: added POSIX API Signature Compliance Tests for stdio.h File …
5
@cf2e6dde
12/05/18 19:14:42 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for sys/utsname.h (GCI 2018)
5
@7b5379d
12/05/18 17:38:50 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for assert.h (GCI 2018)
5
@9abe98b3
12/05/18 17:59:31 |
joel |
testsuites/psxtests/Makefile.am: Disable psxhdrs for dirfd.c and …
5
@e517fe68
12/05/18 17:58:59 |
joel |
psxhdrs: Fix warnings
5
@e15ae5a3
12/05/18 15:28:39 |
psxhdrs: Align the code properly to left hand margin
5
@7fe5922a
12/05/18 17:14:17 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for langinfo.h (GCI 2018)
5
@2e8b5de
12/05/18 12:02:59 |
Sebastian Huber |
bsp/leon2: Move printk() support
Avoid assert() in …
5
@5bb1f3b2
12/04/18 23:00:09 |
jacobshin313 |
psxhdrs: Implement POSIX API Signature Compliance Tests for monetary.h …
5
@55719ba
12/04/18 22:55:53 |
joel |
5
@b0b095c
12/04/18 22:29:37 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for ulimit.h (GCI 2018)
5
@99de42c
12/04/18 22:05:10 |
mcomajoancara |
Capitalize Rtems to RTEMS
5
@0446f680
12/03/18 20:37:32 |
mcomajoancara |
Spelling and grammar fixes in source code comments (GCI 2018)
5
@e25acd8
12/04/18 16:43:59 |
zenon.hans.taneka |
psxhdrs: Added POSIX Compliance Test fot sys/time.h (GCI 2018)
5
@adc11af9
12/04/18 04:42:01 |
jacobshin313 |
psxhdrs: Implement POSIX API Signature Compliance Tests for iconv.h …
5
@fdcba406
12/04/18 14:26:55 |
Sebastian Huber |
bsp/leon3: Fix CPU counter frequency
5
@8f79854
12/04/18 02:57:47 |
jacobshin313 |
psxhdrs: Implement POSIX API Signature Compliance Tests for fnmatch.h …
5
@b055da27
12/03/18 17:04:04 |
psxhdrs: add POSIX API Signature Compliance Tests for regex.h (GCI 2018)
5
@577d9a5
12/03/18 12:34:28 |
Sebastian Huber |
testsupport: Include missing <rtems/bspIo.h>
5
@b9ffb624
11/30/18 12:57:04 |
Sebastian Huber |
Convert CPU counter ticks to/from sbintime_t
The sbintime_t is an …
5
@d0a7f03
12/03/18 03:13:23 |
jacobshin313 |
5 spelling errors for a Google Code-In task.
Username: deuteriumoxide …
5
@7383632c
12/03/18 01:36:54 |
shashvatjain2002 |
psxhdrs:Add POSIX conformance test for utime.h (GCI 2018)
5
@b8e8d0d
12/02/18 14:36:39 |
kho237115 |
Fix wrong command hint in case of error
5
@0888bfd5
12/02/18 11:01:18 |
psxhdrs: add POSIX API Signature Compliance Tests for locale.h (GCI 2018)
5
@903c57a
12/01/18 18:41:19 |
psxhdrs: add POSIX API Signature Compliance Tests for dlfcn.h File …
5
@e3086c9c
12/01/18 17:53:06 |
psxhdrs: add POSIX API signature tests for strings.h file (GCI 2018)
5
@f40f86d
11/30/18 19:01:50 |
shashvatjain2002 |
powerpc/haleakala:Add per-section compilation and linking support (GCI …
5
@c056f21
11/30/18 18:07:17 |
shashvatjain2002 |
powerpc/mpc8260ads:Add per-section compilation and linking support …
5
@8b3ca0c
11/30/18 16:39:29 |
shashvatjain2002 |
powerpc/qemuppc:Add per-section compilation and linking support (GCI …
5
@8b6273a8
11/30/18 15:03:25 |
shashvatjain2002 |
powerpc/ss555:Add per-section compilation and linking support(GCI …
5
@e54a266e
11/30/18 14:33:45 |
joel |
psxmsgq01/init.c: Disable signal usage when POSIX disabled
closes #3626.
5
@10e7d87
11/30/18 14:33:31 |
joel |
mcf52235-testsuite.tcfg: Add dl07
5
@e447d4c0
11/29/18 22:46:06 |
joel |
generic_or1k-testsuite.tcfg: Enable sptls01 now that GCC is from FSF …
5
@8b28fdd
11/29/18 20:39:47 |
shashvatjain2002 |
m68k/mrm332:Add per-section compilation and linking support (GCI 2018) …
5
@f57d4d5
11/29/18 18:32:46 |
shashvatjain2002 |
m68k/mcf5206elite:Add per-section compilation and linking support (GCI …
5
@7ea4c02
11/29/18 17:03:19 |
psxtests : Add POSIX API Signature Compliance Tests for semaphore.h …
5
@d6d4002
11/29/18 16:54:12 |
joel |
bfin/shared/dev/clock.c: Include rtems/score/thread.h
5
@b56edf1
11/29/18 16:53:48 |
joel |
lpc23xx_tli800-testsuite.tcfg: Add dl07
5
@9002859
11/29/18 16:53:32 |
joel |
lpc2362-testsuite.tcfg: Add dl07
5
@7ed1e618
11/29/18 15:19:44 |
joel |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add dl07
5
@1491db5b
11/29/18 15:19:06 |
joel |
lpc1768_mbed_ahb_ram-testsuite.tcfg: Add dl07
5
@1d78d66
11/29/18 15:18:48 |
joel |
lpc1768_mbed-testsuite.tcfg: Add dl07
5
@1fe6d11
11/28/18 17:53:36 |
shashvatjain2002 |
m68k/mcf52235:Add per-section compilation and linking support(GCI …
5
@9c4dc7b0
11/28/18 20:07:41 |
shashvatjain2002 |
m68k/mcf5225x:Add per-section compilation and linking support(GCI …
5
@cc119eb
11/28/18 15:36:31 |
shashvatjain2002 |
m68k/mcf5329:Add per-section compilation and linking support (GCI …
5
@e80d34e
11/28/18 13:15:38 |
shashvatjain2002 |
m68k/mcf5235:Add per-section compilation and linking support (GCI …
5
@93ccf479
11/28/18 08:04:34 |
psxtests: add POSIX API signature compliance tests for mqueue.h file …
5
@a919807
11/28/18 16:43:23 |
joel |
lm3s3749-testsuite.tcfg: Add dl07
5
@5bf0c1a
11/28/18 13:52:22 |
Sebastian Huber |
bsps/sparc: Fix SMP build
Update #3622.
5
@aa5c462
11/28/18 09:32:46 |
Chris Johns |
testsuite: Parse TCFG path based on OS path separator.
5
@27a8fc5
11/27/18 17:10:30 |
psxtests: add POSIX API signature compliance tests for dirent.h file …
5
@89bff5a
11/27/18 02:29:49 |
shashvatjain2002 |
m68k/av5282: Add per-section compilation and linking support (GCI …
5
@06331e4
11/27/18 10:56:01 |
Sebastian Huber |
dosfs: Fix device identifier
Update #3358.
5
@a7267241
11/26/18 14:44:25 |
Sebastian Huber |
bsps/sparc: Add and use <grlib_impl.h>
Reduce copy and paste.
5
@c1864a0a
10/15/18 05:46:27 |
Sebastian Huber |
Add LICENSE.BSD-2-Clause
Copied from:
5
@0a75a4aa
11/26/18 13:04:59 |
Sebastian Huber |
Remove rtems_cache_*_processor_set() functions
The following …
5
@6378978
11/26/18 09:14:00 |
Sebastian Huber |
rtems: Fix semaphore MPCI support
5
@5fc727f
11/26/18 07:25:36 |
Sebastian Huber |
score: <rtems/score/smplockstats.h>
Remove <rtems/score/chainimpl.h> …
5
@eaa5ea84
11/20/18 15:22:56 |
Sebastian Huber |
score: Introduce <rtems/score/heapinfo.h>
Move Heap_Information_block …
5
@1947449
11/25/18 20:17:54 |
shashvatjain2002 |
m68k/uC5282: Add per-section compilation and linking (GCI 2018)
The …
5
@183b0ae
11/25/18 15:49:30 |
psxtmtests: add psxtmmqrcvblock02 (GCI 2018)
5
@16d5e394
11/24/18 20:11:50 |
psxtests/psxhdrs patch (GCI 2018)
5
@ffe9e7a
11/25/18 07:37:01 |
shashvatjain2002 |
m68k/gen68360:Add per-section compilation and linking support
The …
5
@1b2124d
11/24/18 20:55:07 |
pritishjain2001 |
m68k/gen68340:Add per-section compilation and linking support
The …
5
@2ce44de
11/22/18 01:25:43 |
zenon.hans.taneka |
Changed slightly awkward sentence structure
5
@9dfb9a98
11/22/18 00:46:35 |
joel |
pipe/fifo.c: Remove dead code (CID 1437649)
Closes #3581.
5
@03139d5b
11/20/18 03:56:11 |
Chris Johns |
libdl: Add object file dependencies to track references
Tracking …
5
@8e7c72a7
11/20/18 03:00:48 |
Chris Johns |
libdl: Reindex unresolved names after removing used records.
Updates #3194
5
@803eac9
11/13/18 06:26:17 |
Chris Johns |
libdl: Manage the allocation of common uninitialised variables.
The …
5
@69812aa
11/21/18 16:00:35 |
psxtmbarrierattr01: Added new POSIX timing suite (GCI 2018)
5
