@2d8a9c79
02/02/19 04:22:04 |
Chris Johns |
libmisc: Fix rtems_print_buffer
Closes #3684
5
@568490a
02/08/19 11:40:45 |
Jiri Gaisler |
griscv: add additional cpu configurations
* Also switch default …
5
@26333f2a
02/08/19 09:16:07 |
Sebastian Huber |
score: Fix _User_extensions_Thread_switch() (SMP)
We have to read the …
5
@4e686261
02/07/19 10:13:01 |
Sebastian Huber |
bsps/irq: Fix interrupt server init (SMP)
5
@fbd08066
02/07/19 06:46:38 |
Sebastian Huber |
score: Fix plain priority thread queues (SMP)
We must add/remove the …
5
@0fb52ce
02/07/19 06:45:58 |
Sebastian Huber |
bsps/arm: Fix generic timer frequency
Update #3456.
5
@03fcbb1
11/27/18 11:45:53 |
Sebastian Huber |
fs: Add struct dirent::d_type support
5
@9399473c
02/02/19 10:03:13 |
Sebastian Huber |
riscv: Fix misaligned access in context validate
5
@b015c01
01/28/19 11:26:25 |
Sebastian Huber |
build: Do not install test programs
5
@03cdd5ea
01/30/19 08:41:49 |
Sebastian Huber |
record: Add enum value for each event
Update #3665.
5
@dca6184
04/28/18 09:36:11 |
Sebastian Huber |
Add low level event recording support
Add low level event recording …
5
@f0ae613b
01/17/19 06:33:08 |
Sebastian Huber |
m68k: Avoid _Addresses_Add_offset()
This prevents a cyclic dependency …
5
@e74a3fd
01/29/19 12:26:12 |
Sebastian Huber |
samples/pppd: Use less memory hungry configuration
This avoids …
5
@4f3a253
01/28/19 13:16:39 |
Sebastian Huber |
psxtmtests: Fix format warnings
Update #3384.
5
@b1381ae
01/25/19 14:50:14 |
Sebastian Huber |
bsps/powerpc: Fix warnings
5
@81aec18
01/24/19 13:29:03 |
Sebastian Huber |
bsps/powerpc: Fix 64-bit issues in assembler files
We have to be …
5
@afd50b3
01/23/19 12:17:44 |
maksim.e.kozlov |
libmisc: Fix swapped parameters and enable floating point usage.
5
@d3d4e77
01/18/19 11:37:55 |
Jiri Gaisler |
riscv: add griscv bsp
Update #3678.
5
@c1dcd6af
01/21/19 10:27:07 |
Jiri Gaisler |
grlib: make memory coherency cpu-independent
Update #3678.
5
@9b2b389
01/18/19 17:00:47 |
Jiri Gaisler |
grlib: use cpu-independent routines for uncached access
Update #3678.
5
@5981c8ca
01/18/19 10:29:08 |
Jiri Gaisler |
grlib: use rtems_interrupt_handler_install()
Update #3678.
5
@411c297
01/18/19 10:24:18 |
Jiri Gaisler |
grlib: make apbuart driver independent of bsp
Update #3678.
5
@7eb606d3
12/22/18 17:31:04 |
Sebastian Huber |
grlib: Move source files
Update #3678.
5
@31720925
12/22/18 06:13:44 |
Sebastian Huber |
grlib: Move header files
Update #3678.
5
@95c1921
01/21/19 08:17:05 |
Sebastian Huber |
bsps/arm: Remove unused bsp_stack_irq_size
Update #3459.
5
@926ed2b0
01/18/19 12:32:51 |
Sebastian Huber |
score: Remove unused _ISR_lock_Flash()
5
@41310c02
01/18/19 12:16:29 |
Sebastian Huber |
score: Improve debug support for ISR locks
Ensure that interrupts are …
5
@b5bdecf
01/18/19 11:54:05 |
Sebastian Huber |
score: Avoid internal API and use ISR lock
5
@93e3b341
01/14/19 06:50:26 |
Sebastian Huber |
score: Simplify _Addresses_Is_aligned()
The CPU_ALIGNMENT must not be …
5
@12dfe5dc
01/16/19 21:42:18 |
joel |
bsps/i386/shared/cache/cache.c: Make compile
5
@4596127
01/10/19 19:14:03 |
joel |
m68k/include/rtems/score/cpu.h: Add include of address.h
5
@47d5aee
01/14/19 08:38:02 |
Sebastian Huber |
build: Add missing $(LDADD) for dependencies
5
@d1fff86
01/14/19 08:07:16 |
Sebastian Huber |
build: Remove bogus spqreslib_LDADD
5
@dc0285f
01/14/19 08:06:30 |
Sebastian Huber |
5
@8eaf136d
01/10/19 10:35:12 |
Sebastian Huber |
memalign: Add missing attributes to fix warning
Update #3666.
5
@7bde91b
01/10/19 08:05:49 |
Sebastian Huber |
Fix format warnings due to ino_t changes
5
@3a5c71de
01/10/19 07:10:17 |
Sebastian Huber |
psxconfig01: Fix pre-processor conditions
Do not rely on compiler …
5
@e7d623e7
01/10/19 06:57:36 |
Sebastian Huber |
bsps/arm: Conditional ARMv7-AR data cache disable
Update #3667.
Close …
5
@0abe47f
01/10/19 06:29:54 |
thomas.doerfler |
bsps/arm: Fix typo in disable cache for ARMv7-AR
Update #3667.
5
@b9ffc41c
01/08/19 08:50:50 |
Sebastian Huber |
riscv: Enable robust thread dispatch
It must be enabled, since the …
5
@3bd39999
01/08/19 08:53:26 |
Sebastian Huber |
Adjust interrupt mode tests for some CPU ports
In case the robust …
5
@1f285186
01/08/19 07:39:42 |
Sebastian Huber |
rtems: Allow to set ISR level 0 in SMP config
Update #3000.
5
@38cb59e
01/08/19 07:36:31 |
Sebastian Huber |
Separate task mode checks
Update #3000.
5
@feddcde0
01/08/19 08:08:27 |
Sebastian Huber |
tests: Remove bogus RTEMS_INTERRUPT_LEVEL(31)
It is unnecessary to …
5
@fe48400d
01/09/19 09:04:01 |
Sebastian Huber |
libtests/stackchk: Fix for 64-bit targets
5
@e4a19f5
01/08/19 04:14:21 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for errno.h
5
@9aee88a
01/08/19 13:43:02 |
Sebastian Huber |
bsp/riscv: Clear boot command line
5
@07fb7667
01/07/19 12:40:00 |
Sebastian Huber |
build: Call rtems-ld with the $(CC) of the build
This enables support …
5
@7802bb9
01/07/19 12:35:48 |
Sebastian Huber |
build: Call rtems-syms with the $(CC) of the build
This enables …
5
@5b951175
01/07/19 13:22:22 |
Jiri Gaisler |
psxfile01: Fix one second sleep
Checking of atime in psxfile01 (line …
5
@9c12bcfd
01/07/19 08:32:16 |
Sebastian Huber |
Fix format warnings
5
@956d76cc
01/07/19 08:30:43 |
Sebastian Huber |
score: Remove superfluous include from chainimpl.h
5
@a7e8996
12/21/18 20:09:53 |
Sebastian Huber |
drvmgr: Improve LP64 compatibility
5
@6073c71d
12/21/18 20:09:15 |
Sebastian Huber |
drvmgr: Enable build for riscv
5
@8f5abea
12/21/18 19:47:06 |
himanshuwindows8.1 |
psxtmtests: Changed the copyright license to BSD-2-Clause (GCI 2018)
5
@c05d7a9d
12/21/18 20:43:27 |
Sebastian Huber |
bsps/sparc: Fix warnings
5
@75e1009f
12/21/18 20:42:09 |
Sebastian Huber |
bsps/sparc: Fix typo
5
@11f3b9a
11/26/18 14:55:38 |
Sebastian Huber |
bsps/sparc: Add grlib_malloc(), grlib_calloc()
This avoids a …
5
@8b59916
12/21/18 12:31:32 |
Sebastian Huber |
spcxx01: Add test case
5
@c37807e9
12/21/18 10:57:26 |
Sebastian Huber |
bsps/arm: Add cache size support for CP15
5
@41a557bc
12/21/18 07:39:33 |
Sebastian Huber |
bsps/arm: Add ARMv7-AR disable data cache
Close #3667.
5
@b0c2d48
12/21/18 06:49:47 |
Sebastian Huber |
bsps: Add CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA
Update #3667.
5
@5e0ab02
12/21/18 06:46:58 |
Sebastian Huber |
bsps: Update cache manager documentation
Update #3667.
5
@a6f70e1
12/21/18 06:14:42 |
Sebastian Huber |
bsps: Remove superfluous comments in cacheimpl.h
Remove superfluous …
5
@ba85655
12/21/18 09:16:02 |
Sebastian Huber |
ARM_CACHE_L1_CPU_SUPPORT_PROVIDES_RANGE_FUNCTIONS
Remove this …
5
@750e795
12/21/18 06:27:16 |
Sebastian Huber |
bsps/i386: Enable instruction cache support
5
@2158621
12/19/18 08:25:29 |
Sebastian Huber |
Add aligned_alloc() and memalign()
Ensure that the C++17 aligned new …
5
@10135fa
12/20/18 13:26:50 |
thomas.doerfler |
tftpfs: Some bug fixes
Fix for:
- tftpfs did not mount, when device …
5
@8af51b0
12/20/18 20:37:47 |
jacobshin313 |
psxhdrs: Changing copyright license to BSD-2-Clause
5
@9edc558d
12/20/18 13:21:40 |
Sebastian Huber |
bsp/imx: Fix for RAM end at 4GiB
5
@6164fd8
11/23/18 11:00:35 |
Sebastian Huber |
Move COPYING file to LICENSE.GPL-2.0
Use the latest plain text …
5
@cde5e8d
12/11/18 09:15:11 |
Sebastian Huber |
LICENSE.BSD-2-Clause: Clarify copyright format
Update #3053.
5
@7c19e50
12/18/18 07:45:06 |
Sebastian Huber |
score: Fix per-CPU data allocation
Allocate the per-CPU data for …
5
@e7b0a72
12/14/18 07:07:08 |
Sebastian Huber |
config: Remove CONFIGURE_CONFDEFS_DEBUG
This configuration option was …
5
@cfa82b3
12/10/18 18:44:45 |
mcomajoancara |
psxhdrs: Update licenses to 2-Clause BSD (GCI 2018)
Updated licenses …
5
@4bd2f802
12/13/18 19:23:11 |
Some minor fix on psxhdrs
5
@c1912df
12/13/18 18:13:31 |
psxhdrs: Changed the copyright license to BSD-2-Clause (GCI 2018)
5
@6b0a729b
12/13/18 08:39:20 |
Sebastian Huber |
build: Remove ampolish3
Update #3254.
5
@21275b58
11/22/18 18:14:51 |
Sebastian Huber |
score: Static Objects_Information initialization
Statically allocate …
5
@0f5b2c09
12/10/18 11:51:33 |
Sebastian Huber |
rtems: Use object information to get config max
Use functions instead …
5
@8b0e752f
12/10/18 12:44:53 |
Sebastian Huber |
score: Remove Objects_Information::auto_extend
Use …
5
@877048c
12/13/18 15:17:25 |
pritishjain2001 |
psxhdrs: Changed the Copyright license to BSD-2-Clause .
The …
5
@cb8281f
12/13/18 15:42:57 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for sys/msg.h (GCI 2018)
5
@28f23eb
12/13/18 00:46:38 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for sys/select.h …
5
@86b0ac9f
12/12/18 15:33:22 |
abhimanyuraghuvanshi29 |
psxhdrs: Add POSIX Signature Compliance Test for sys/shm.h (GCI 2018)
5
@a0353ea2
12/12/18 14:23:35 |
POSIX Signature Compliance Test for utmpx.h (GCI2018)
5
@0af5ede
12/12/18 14:14:40 |
POSIX Signature Compliance Test for sys/statvfs.h (GCI 2018)
5
@b770665f
12/12/18 21:00:10 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for net/if.h
5
@bf19a9c6
12/11/18 02:21:12 |
zenon.hans.taneka |
psxhdrs/: Changed boilerplate licenses to BSD-2 (GCI 2018)
5
@af677c0
12/11/18 22:08:59 |
psxhdrs: POSIX API Signature Compliance Test for setjmp.h (GCI2018)
5
@6ab788d
12/11/18 16:35:38 |
mcomajoancara |
psxhdrs: Implement POSIX API Signature Compliance Tests for poll.h …
5
@484ef98
12/11/18 08:47:21 |
pritishjain2001 |
psxhdrs: Add POSIX Compliance Tests for wordexp.h (GCI 2018)
5
@a1eb0a5
12/11/18 14:11:10 |
Sebastian Huber |
posix: Fix shm_unlink()
This function is untested.
5
@b7a1f9e
12/11/18 08:30:59 |
Sebastian Huber |
psxhdrs: Fix compile errors
5
@6179767
12/10/18 14:09:41 |
Sebastian Huber |
Remove white space at end of line
Update #3053.
5
@b05aa8e
12/10/18 18:50:47 |
psxhdrs: Add POSIX API Signature Compliance Tests for pwd.h (GCI 2018)
5
@c107f2b7
12/10/18 18:52:09 |
zenon.hans.taneka |
psxhdrs: Add POSIX API Signature Compliance Tests for fcntl.h (GCI 2018)
5
@ed6a8e3
12/10/18 18:39:34 |
joel |
psxtests/Makefile.am: Add fcntl methods missed in previous commit
5
@2bb21dde
12/10/18 18:23:03 |
joel |
psxtests/Makefile.am: Correct spacing
5
@9084b6b5
12/10/18 00:05:54 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for sys/resource.h …
5
