@28f23eb
12/13/18 00:46:38 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for sys/select.h …
5
@86b0ac9f
12/12/18 15:33:22 |
abhimanyuraghuvanshi29 |
psxhdrs: Add POSIX Signature Compliance Test for sys/shm.h (GCI 2018)
5
@a0353ea2
12/12/18 14:23:35 |
POSIX Signature Compliance Test for utmpx.h (GCI2018)
5
@0af5ede
12/12/18 14:14:40 |
POSIX Signature Compliance Test for sys/statvfs.h (GCI 2018)
5
@b770665f
12/12/18 21:00:10 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for net/if.h
5
@bf19a9c6
12/11/18 02:21:12 |
zenon.hans.taneka |
psxhdrs/: Changed boilerplate licenses to BSD-2 (GCI 2018)
5
@af677c0
12/11/18 22:08:59 |
psxhdrs: POSIX API Signature Compliance Test for setjmp.h (GCI2018)
5
@6ab788d
12/11/18 16:35:38 |
mcomajoancara |
psxhdrs: Implement POSIX API Signature Compliance Tests for poll.h …
5
@484ef98
12/11/18 08:47:21 |
pritishjain2001 |
psxhdrs: Add POSIX Compliance Tests for wordexp.h (GCI 2018)
5
@a1eb0a5
12/11/18 14:11:10 |
Sebastian Huber |
posix: Fix shm_unlink()
This function is untested.
5
@b7a1f9e
12/11/18 08:30:59 |
Sebastian Huber |
psxhdrs: Fix compile errors
5
@6179767
12/10/18 14:09:41 |
Sebastian Huber |
Remove white space at end of line
Update #3053.
5
@b05aa8e
12/10/18 18:50:47 |
himanshuwindows8.1 |
psxhdrs: Add POSIX API Signature Compliance Tests for pwd.h (GCI 2018)
5
@c107f2b7
12/10/18 18:52:09 |
zenon.hans.taneka |
psxhdrs: Add POSIX API Signature Compliance Tests for fcntl.h (GCI 2018)
5
@ed6a8e3
12/10/18 18:39:34 |
joel |
psxtests/Makefile.am: Add fcntl methods missed in previous commit
5
@2bb21dde
12/10/18 18:23:03 |
joel |
psxtests/Makefile.am: Correct spacing
5
@9084b6b5
12/10/18 00:05:54 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for sys/resource.h …
5
@5269bf47
12/09/18 23:08:38 |
mcomajoancara |
psxhdrs: Implement POSIX API Signature Compliance Tests for …
5
@dc95ef67
12/09/18 17:13:48 |
shashvatjain2002 |
psxhdrs: Add POSIX Conformance Test for sys/ipc.h (GCI 2018)
Test for …
5
@9e7e8b3f
12/09/18 16:31:41 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for sys/stat.h (GCI 2018)
5
@b009cfb6
12/09/18 12:20:13 |
psxhdrs: Added POSIX API Signature Compliance Tests for threads.h (GCI …
5
@a5c0886a
12/08/18 18:49:20 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for stdlib.h (GCI 2018)
5
@15d806b0
12/08/18 17:42:24 |
psxhdrs: POSIX Signature Test for syslog.h (GCI2018)
5
@30f5272
12/08/18 17:35:49 |
psxhdrs: added POSIX API Signature Compliance Tests for libgen.h (GCI 2018)
5
@8e06aff
12/08/18 17:26:43 |
zenon.hans.taneka |
psxhdrs: Added POSIX Compliance Test for wchar.h (GCI 2018)
5
@6acc556
12/07/18 16:48:11 |
mcomajoancara |
Implement POSIX API Signature Compliance Tests for stddef.h (GCI 2018)
5
@100d87f
12/08/18 03:50:49 |
POSIX Signature Test for arpa/inet.h (GCI2018)
5
@aad6551b
12/07/18 18:14:43 |
psxhdrs: POSIX API Signature Compliance Tests for netdb.h (GCI 2018)
5
@add0b6a3
12/07/18 17:59:38 |
mcomajoancara |
Implement POSIX API Signature Compliance Tests for uchar.h
This …
5
@f70079c
11/25/18 19:26:02 |
Sebastian Huber |
score: Remove Objects_Information::the_api
Remove …
5
@1c2d178
11/25/18 19:15:26 |
Sebastian Huber |
score: Remove Objects_Information::maximum
This information is …
5
@3899bc1a
11/24/18 10:51:28 |
Sebastian Huber |
score: Optimize object lookup
Use the maximum ID for the ID to object …
5
@359a3a3
11/22/18 05:38:42 |
Sebastian Huber |
score: Rename Objects_Information::allocation_size
Rename …
5
@0da9d80
11/22/18 05:16:52 |
Sebastian Huber |
score: Rename Objects_Information::size
Rename …
5
@9c9c6a9
11/21/18 16:30:52 |
Sebastian Huber |
score: Remove Objects_Information::is_string
Use …
5
@d6e3473
11/23/18 19:37:57 |
Sebastian Huber |
score: Remove dead code
Update #3621.
5
@7ee6437
12/06/18 08:57:01 |
Sebastian Huber |
rtems: Add rtems_scheduler_get_maximum_priority()
Update #3636.
5
@0a1f5df9
05/03/18 11:03:27 |
Sebastian Huber |
Simplify _CPU_Counter_difference()
In order to simplify the use of …
5
@ef23838
12/03/18 12:10:21 |
Sebastian Huber |
score: Avoid sbintime_t in API headers
The sbintime_t is a non-POSIX …
5
@9921ab6
12/05/18 09:03:13 |
Sebastian Huber |
psxtimes01: Fix sporadic failures
It is not enough to just wait for …
5
@03e86553
12/05/18 07:05:54 |
Sebastian Huber |
tests: Fix rtems_test_spin_until_next_tick()
This bug surfaced due to …
5
@fcd577a
12/07/18 04:29:42 |
joel |
psxtests/Makefile.am: Fix ticket number for ucontext.h
5
@17c32e5d
12/07/18 02:48:46 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for ucontext.h (GCI 2018)
5
@bf763d3e
12/06/18 21:23:16 |
mcomajoancara |
Implement POSIX API Signature Compliance Tests for inttypes.h
This …
5
@9feff78
12/06/18 19:10:59 |
shashvatjain2002 |
psxhdrs:Add POSIX Conformance Test for fmtmsg.h (GCI 2018)
5
@1e455d4
12/06/18 18:24:13 |
shashvatjain2002 |
Includes …
5
@b24c098
12/06/18 19:06:29 |
psxhdrs: Add POSIX API Signature Compliance Tests for string.h (GCI 2018)
5
@a803bd9e
12/06/18 16:49:32 |
zenon.hans.taneka |
Added POSIX Compliance Test for <ctype.h> (GCI 2018)
5
@5886a701
12/06/18 17:30:23 |
joel |
psxtmtests_plan.csv: Add preemption cases for pthread_setschedprio
5
@be9a83d
12/06/18 16:34:16 |
mcomajoancara |
psxtmtests/psxtmtests_plan.csv: Fix typos (GCI 2018)
Two quotation …
5
@c078065
12/06/18 16:28:23 |
mcomajoancara |
psxtmtests: Identified a Timing Test missing (GCI 2018)
5
@9598f83e
12/06/18 13:08:12 |
shashvatjain2002 |
psxhdrs: Add POSIX Conformance Tests for math.h (GCI 2018)
Includes …
5
@da262164
12/06/18 11:16:25 |
POSIX Signature Test for fenv.h (GCI 2018)
Updates #2971.
5
@187ef31
12/06/18 06:44:41 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for wctype.h (GCI 2018)
5
@e50b4bd3
12/06/18 12:40:08 |
Sebastian Huber |
score: Use typeof for strict ISO C compat
Enable the use of …
5
@4e46ba8
12/06/18 09:49:43 |
Sebastian Huber |
rtems: Fix rtems_task_restart() argument type
Close #3637.
5
@bf135a9
12/06/18 04:08:31 |
POSIX Compliance Signature Test for glob.h (GCI 2018)
5
@65b3fba
12/05/18 23:02:39 |
zenon.hans.taneka |
Added POSIX Compliance Test for complex.h, and adding lines to define …
5
@95095be
12/06/18 00:33:33 |
jacobshin313 |
psxhdrs: Add POSIX API Signature Compliance Tests for ftw.h (GCI 2018)
5
@cbb08b61
12/05/18 22:07:33 |
joel |
psxhdrs: Fix spacing
5
@36e1b82
12/05/18 21:23:58 |
joel |
psxtmcleanup01/init.c: Fix warnings
5
@70966985
12/05/18 21:23:40 |
joel |
psxhdrs/strings/strncasecmp_l.c: Fix warning
5
@a115818
12/05/18 20:03:13 |
psxhdrs: added POSIX API Signature Compliance Tests for stdio.h File …
5
@cf2e6dde
12/05/18 19:14:42 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for sys/utsname.h (GCI 2018)
5
@7b5379d
12/05/18 17:38:50 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for assert.h (GCI 2018)
5
@9abe98b3
12/05/18 17:59:31 |
joel |
testsuites/psxtests/Makefile.am: Disable psxhdrs for dirfd.c and …
5
@e517fe68
12/05/18 17:58:59 |
joel |
psxhdrs: Fix warnings
5
@e15ae5a3
12/05/18 15:28:39 |
psxhdrs: Align the code properly to left hand margin
5
@7fe5922a
12/05/18 17:14:17 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for langinfo.h (GCI 2018)
5
@2e8b5de
12/05/18 12:02:59 |
Sebastian Huber |
bsp/leon2: Move printk() support
Avoid assert() in …
5
@5bb1f3b2
12/04/18 23:00:09 |
jacobshin313 |
psxhdrs: Implement POSIX API Signature Compliance Tests for monetary.h …
5
@55719ba
12/04/18 22:55:53 |
joel |
5
@b0b095c
12/04/18 22:29:37 |
jacobshin313 |
psxhdrs: POSIX API Signature Compliance Tests for ulimit.h (GCI 2018)
5
@99de42c
12/04/18 22:05:10 |
mcomajoancara |
Capitalize Rtems to RTEMS
5
@0446f680
12/03/18 20:37:32 |
mcomajoancara |
Spelling and grammar fixes in source code comments (GCI 2018)
5
@e25acd8
12/04/18 16:43:59 |
zenon.hans.taneka |
psxhdrs: Added POSIX Compliance Test fot sys/time.h (GCI 2018)
5
@adc11af9
12/04/18 04:42:01 |
jacobshin313 |
psxhdrs: Implement POSIX API Signature Compliance Tests for iconv.h …
5
@fdcba406
12/04/18 14:26:55 |
Sebastian Huber |
bsp/leon3: Fix CPU counter frequency
5
@8f79854
12/04/18 02:57:47 |
jacobshin313 |
psxhdrs: Implement POSIX API Signature Compliance Tests for fnmatch.h …
5
@b055da27
12/03/18 17:04:04 |
psxhdrs: add POSIX API Signature Compliance Tests for regex.h (GCI 2018)
5
@577d9a5
12/03/18 12:34:28 |
Sebastian Huber |
testsupport: Include missing <rtems/bspIo.h>
5
@b9ffb624
11/30/18 12:57:04 |
Sebastian Huber |
Convert CPU counter ticks to/from sbintime_t
The sbintime_t is an …
5
@d0a7f03
12/03/18 03:13:23 |
jacobshin313 |
5 spelling errors for a Google Code-In task.
Username: deuteriumoxide …
5
@7383632c
12/03/18 01:36:54 |
shashvatjain2002 |
psxhdrs:Add POSIX conformance test for utime.h (GCI 2018)
5
@b8e8d0d
12/02/18 14:36:39 |
kho237115 |
Fix wrong command hint in case of error
5
@0888bfd5
12/02/18 11:01:18 |
psxhdrs: add POSIX API Signature Compliance Tests for locale.h (GCI 2018)
5
@903c57a
12/01/18 18:41:19 |
psxhdrs: add POSIX API Signature Compliance Tests for dlfcn.h File …
5
@e3086c9c
12/01/18 17:53:06 |
psxhdrs: add POSIX API signature tests for strings.h file (GCI 2018)
5
@f40f86d
11/30/18 19:01:50 |
shashvatjain2002 |
powerpc/haleakala:Add per-section compilation and linking support (GCI …
5
@c056f21
11/30/18 18:07:17 |
shashvatjain2002 |
powerpc/mpc8260ads:Add per-section compilation and linking support …
5
@8b3ca0c
11/30/18 16:39:29 |
shashvatjain2002 |
powerpc/qemuppc:Add per-section compilation and linking support (GCI …
5
@8b6273a8
11/30/18 15:03:25 |
shashvatjain2002 |
powerpc/ss555:Add per-section compilation and linking support(GCI …
5
@e54a266e
11/30/18 14:33:45 |
joel |
psxmsgq01/init.c: Disable signal usage when POSIX disabled
closes #3626.
5
@10e7d87
11/30/18 14:33:31 |
joel |
mcf52235-testsuite.tcfg: Add dl07
5
@e447d4c0
11/29/18 22:46:06 |
joel |
generic_or1k-testsuite.tcfg: Enable sptls01 now that GCC is from FSF …
5
@8b28fdd
11/29/18 20:39:47 |
shashvatjain2002 |
m68k/mrm332:Add per-section compilation and linking support (GCI 2018) …
5
@f57d4d5
11/29/18 18:32:46 |
shashvatjain2002 |
m68k/mcf5206elite:Add per-section compilation and linking support (GCI …
5
@7ea4c02
11/29/18 17:03:19 |
psxtests : Add POSIX API Signature Compliance Tests for semaphore.h …
5
@d6d4002
11/29/18 16:54:12 |
joel |
bfin/shared/dev/clock.c: Include rtems/score/thread.h
5
@b56edf1
11/29/18 16:53:48 |
joel |
lpc23xx_tli800-testsuite.tcfg: Add dl07
5
