source: rtems
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @1d93843   Sep 14, 2018, 6:02:02 PM Sebastian Huber build: Merge score/Makefile.am
(edit) @640271f   Sep 14, 2018, 5:55:00 PM Sebastian Huber build: Merge rtems/Makefile.am
(edit) @24312f34   Sep 14, 2018, 5:51:38 PM Sebastian Huber build: Merge pppd/Makefile.am
(edit) @b3ef89f9   Sep 14, 2018, 5:46:58 PM Sebastian Huber build: Merge posix/Makefile.am
(edit) @028b0ce   Sep 14, 2018, 2:12:19 PM Sebastian Huber build: Merge mghttpd/Makefile.am
(edit) @a2a71b5   Sep 14, 2018, 2:00:45 PM Sebastian Huber build: Merge libstdthreads/Makefile.am
(edit) @5079524   Sep 14, 2018, 1:56:26 PM Sebastian Huber build: Merge librpc/Makefile.am
(edit) @c38d517   Sep 14, 2018, 4:43:35 AM Sebastian Huber build: Merge libpci/Makefile.am
(edit) @e39642a4   Sep 14, 2018, 4:41:27 AM Sebastian Huber build: Merge libmd/Makefile.am
(edit) @0c56264   Sep 14, 2018, 4:38:50 AM Sebastian Huber build: Merge libi2c/Makefile.am
(edit) @8d677cf   Sep 14, 2018, 4:35:59 AM Sebastian Huber build: Merge libgnat/Makefile.am
(edit) @b45a853   Sep 14, 2018, 4:34:02 AM Sebastian Huber build: Merge libfs/Makefile.am
(edit) @d3d1243   Sep 14, 2018, 4:22:19 AM Sebastian Huber build: Merge libdrvmgr/Makefile.am
(edit) @551f473   Sep 14, 2018, 4:19:15 AM Sebastian Huber build: Merge libdl/Makefile.am
(edit) @bab7a68   Sep 14, 2018, 4:16:36 AM Sebastian Huber build: Merge libdebugger/Makefile.am
(edit) @2532817   Sep 13, 2018, 12:46:30 PM Sebastian Huber build: Merge libcsupport/Makefile.am
(edit) @94acbbf   Sep 13, 2018, 12:22:17 PM Sebastian Huber build: Merge libcrypt/Makefile.am
(edit) @9c058287   Sep 13, 2018, 4:42:32 AM Sebastian Huber build: Merge libblock/Makefile.am
(edit) @8fb3443   Sep 13, 2018, 4:37:56 AM Sebastian Huber build: Merge libfdt/Makefile.am
(edit) @690718ab   Sep 13, 2018, 4:35:03 AM Sebastian Huber build: Merge ftpd/Makefile.am
(edit) @60c4ba1   Sep 13, 2018, 4:30:08 AM Sebastian Huber build: Merge dev/Makefile.am
(edit) @54c0b57   Sep 12, 2018, 2:03:42 PM Sebastian Huber build: Move sapi/Makefile.am
(edit) @68e1ccc   Sep 11, 2018, 4:30:20 AM Sebastian Huber build: Remove specialized CPPFLAGS
(edit) @6cdaa85   Oct 4, 2018, 6:16:45 PM Sebastian Huber shell: Use #include "..." for local header files Update #3375.
(edit) @2806e10   Oct 9, 2018, 6:38:11 AM Sebastian Huber telnetd: Ignore setsockopt() return status Update #3529.
(edit) @84a5921d   Oct 9, 2018, 6:12:46 AM Sebastian Huber ftpd: Restructure chroot() handling. Remove superfluous setting of …
(edit) @dc32b6a   Aug 31, 2018, 6:21:05 AM Daniel Hellstrom leon: do not use -mfix-{device} with Clang Clang do not support …
(edit) @6dc0b5f   Jul 21, 2017, 12:18:50 PM javier.jalle leon, spwtdp: Initial driver commit
(edit) @511ef83c   Oct 9, 2018, 9:59:48 AM Sebastian Huber bsps/arm: Fix ctor/dtor invocation order Remove obsolete .ctor and …
(edit) @acb53d5   Oct 9, 2018, 6:43:08 AM Sebastian Huber posix: Remove static assertion Standard C does not allow pointer …
(edit) @5bd75823   Oct 8, 2018, 8:02:07 AM Sebastian Huber ftpd: Remove superfluous temporary buffer Update #3530.
(edit) @2f784d7   Oct 8, 2018, 6:14:40 AM Sebastian Huber ftpd: Check return status of getsockname() Update #3530.
(edit) @be8de0ff   Oct 5, 2018, 1:16:46 PM Sebastian Huber ftpd: Fix insecure chroot() handling Ensure that the …
(edit) @df97c4d2   Oct 5, 2018, 12:56:10 PM Sebastian Huber ftpd: Avoid resource leak Update #3530.
(edit) @479a28e0   Oct 5, 2018, 12:54:49 PM Sebastian Huber ftpd: Avoid use of uninitialized memory Update #3530.
(edit) @51da629   Oct 5, 2018, 12:47:21 PM Sebastian Huber ftpd: Avoid malloc() and sscanf() Move the user name to the session …
(edit) @dcf42bb2   Oct 5, 2018, 12:39:46 PM Sebastian Huber ftpd: Remove FTPD_SessionInfo_t::pass member There is no need to keep …
(edit) @e761fb4   Oct 5, 2018, 12:05:22 PM Sebastian Huber ftpd: Avoid NULL pointer checks before free() They are superfluous …
(edit) @05b5f9c0   Oct 5, 2018, 11:56:59 AM Sebastian Huber jffs2: Avoid use of constant register variable Avoid the use of a …
(edit) @4a7c6867   Oct 5, 2018, 7:37:44 AM Sebastian Huber Fix rbtree_postorder_for_each_entry_safe() Use the non-standard …
(edit) @1d39e96   Oct 5, 2018, 6:11:09 AM Sebastian Huber score: Fix legacy RTEMS_STATIC_ASSERT() In standard C pointer …
(edit) @51b3cbca   Oct 4, 2018, 1:23:25 PM Sebastian Huber tests: Use rtems_task_exit() Update #3533.
(edit) @8776bb9   Sep 26, 2018, 4:34:54 AM Sebastian Huber score: Remove CPU_PROVIDES_IDLE_THREAD_BODY Remove the …
(edit) @b38887a   Oct 5, 2018, 11:39:49 AM Sebastian Huber dev/sc16is752: Deal with a baud of zero Avoid division by zero and …
(edit) @8352d41   Oct 5, 2018, 5:30:29 AM Sebastian Huber spthreadlife01: A task exit must not return Update #3533.
(edit) @b131cb2   Oct 4, 2018, 12:35:00 PM Sebastian Huber bsp/atsam: Use internal SRAM for stack area
(edit) @8777d4c   Oct 4, 2018, 9:29:03 AM Sebastian Huber Add rtems_interrupt_server_request_set_vector() By default, the …
(edit) @313f897   Sep 13, 2018, 12:50:08 PM Sebastian Huber Optimize calloc() Use return value of memset() to enable tail call …
(edit) @1ad43f8   Sep 13, 2018, 12:49:16 PM Sebastian Huber Avoid need for -fno-builtin for calloc() Use …
(edit) @5418890   Sep 13, 2018, 4:22:21 AM Sebastian Huber Remove superfluous pipe_create()
(edit) @242887bc   Sep 13, 2018, 4:19:05 AM Sebastian Huber Rename files to make them unique within cpukit This allows to build …
(edit) @2d17e88   Sep 11, 2018, 4:25:26 AM Sebastian Huber bsps/mips: Remove unused command line defines Update #3375.
(edit) @f373bdc0   Sep 10, 2018, 3:46:19 PM Sebastian Huber libdl: Avoid command line defines Update #3375.
(edit) @2e77151   Sep 10, 2018, 4:31:53 AM Sebastian Huber mghttpd: Add configuration to source file Update #3375.
(edit) @06060da   Sep 10, 2018, 4:29:11 AM Sebastian Huber pppd: Simplify Makefile.am Update #3375.
(edit) @e069f7fe   Sep 10, 2018, 4:27:10 AM Sebastian Huber rpc: Use configuration header file Update #3375.
(edit) @f004b2b8   Oct 2, 2018, 8:22:15 AM Sebastian Huber Use rtems_task_exit() Update #3530. Update #3533.
(edit) @e50e3f70   Oct 1, 2018, 7:25:06 AM Sebastian Huber rtems: Add rtems_task_exit() Update #3533.
(edit) @57a7ecde   Oct 1, 2018, 6:20:11 AM Sebastian Huber telnetd: Remove CEXP convenience routines Close #3535.
(edit) @a346ebba   Sep 26, 2018, 7:04:43 AM Sebastian Huber telnetd: Remove CONFIGURE_MAXIMUM_PTYS Add a …
(edit) @2da93bcb   Sep 26, 2018, 7:18:12 AM Sebastian Huber telnetd: Regroup includes
(edit) @8e075540   Sep 26, 2018, 7:17:55 AM Sebastian Huber telnetd: Remove dead code
(edit) @0413b14   Sep 26, 2018, 7:06:43 AM Sebastian Huber telnetd: Remove superfluous global variable Update #3528.
(edit) @b980f363   Sep 25, 2018, 1:07:35 PM Sebastian Huber telnetd: Convert pty driver to new Termios API Update #3526.
(edit) @ac9f808   Sep 25, 2018, 1:19:08 PM Sebastian Huber pppd: Remove unused get_pty() function Update #3526.
(edit) @0614743   Oct 1, 2018, 7:24:09 AM Sebastian Huber spthreadlife01: Remove superfluous restart case Update #3243.
(edit) @5cb23f4b   Oct 1, 2018, 6:59:14 AM Sebastian Huber bsp/atsam: Use binary semaphore for I2C Remove superfluous sleep …
(edit) @fca9132   Sep 28, 2018, 12:45:16 PM Sebastian Huber bsp/atsam: Use binary semaphore for SPI Update #3534.
(edit) @69a24c3   Sep 21, 2018, 5:38:23 AM Sebastian Huber bsp/imx: Add imx_ccm_sdhci_hz() Update #3525.
(edit) @c56721c   Sep 27, 2018, 5:21:27 AM Sebastian Huber printer: Fix Doxygen comments
(edit) @7d1acc03   Sep 24, 2018, 7:15:10 AM Sebastian Huber stackchk: Fix interrupt stack preparation We have to prepare the …
(edit) @4221d93   Sep 20, 2018, 6:47:44 AM Sebastian Huber stackchk: Improve support for interrupt stacks Prepare the interrupt …
(edit) @a75a7d3   Sep 21, 2018, 5:30:44 AM Sebastian Huber stackchk: Remove heap hack It is now guranteed that threads do not …
(edit) @56e61e24   Sep 20, 2018, 5:57:08 AM Sebastian Huber Remove INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL The configured …
(edit) @5cbc9c5   Feb 7, 2018, 11:35:33 AM jacob.hansen clang: Keep -qrtems and -B for compilers without -specs support This …
(edit) @9ed109c   Sep 19, 2018, 1:18:38 PM Daniel Hellstrom leon: remove warning missing string.h
(edit) @431661d   Sep 19, 2018, 12:12:59 PM Daniel Hellstrom smp03: make printout match actual task name
(edit) @c2011b47   Feb 21, 2018, 6:23:35 PM maberg leon, grspw_pkt: support CCSDS/ISO16 data CRC When the CCSDS/CCITT …
(edit) @1a2656cd   Aug 31, 2018, 1:34:49 PM Daniel Hellstrom tm26: enable FP context when fprintf used calling …
(edit) @227b145   Aug 31, 2018, 6:56:08 AM Daniel Hellstrom sparc: clang AS does no accept UNIMP without argument
(edit) @0aae151   Aug 13, 2018, 9:36:03 AM Daniel Hellstrom leon,grspw_pkt: protect TX descriptor from bad input (hdrlen)
(edit) @ddc95ab0   Jun 15, 2018, 10:54:32 AM maberg leon, l2cache: workaround for scrubber This is a workaround for a …
(edit) @56a7540   Jan 23, 2018, 9:12:36 AM Daniel Hellstrom leon: substitute printf with printk in driver init
(edit) @68a0012   Nov 21, 2017, 12:19:05 PM Daniel Hellstrom leon3, ckinit: avoid unsued code warnings when drvmgr is enabled
(edit) @d952d73   Nov 21, 2017, 10:09:58 AM Daniel Hellstrom leon3: fix warning when SMP is enabled
(edit) @1c34a9b   Dec 19, 2017, 12:36:33 PM cederman sparc: Remove sequence that could trigger B2BST errata
(edit) @e20da8b   Dec 12, 2017, 10:19:46 AM cederman sparc: Return to previous section type when done with .data._SPARC_Counter
(edit) @b3cf79b   Sep 20, 2018, 5:27:28 AM Sebastian Huber bsp/leon3: Fix typo which breaks the CPU counter Update #3456.
(edit) @776464a   Sep 19, 2018, 9:52:47 AM Sebastian Huber score: Allocate per-CPU data only if necessary The …
(edit) @68f339b6   Sep 17, 2018, 9:53:10 AM Sebastian Huber Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE The RTEMS configuration …
(edit) @5fa0a1f6   Sep 17, 2018, 8:35:45 AM Sebastian Huber config: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE RTEMS had the …
(edit) @bd5cec41   Sep 17, 2018, 8:31:29 AM Sebastian Huber config: Remove CONFIGURE_HAS_OWN_FILESYSTEM_TABLE This configuration …
(edit) @9cda6f29   Sep 17, 2018, 12:12:07 PM Hesham.Almatary riscv: Allow platforms with no PLIC to proceed Spike simulator and …
(edit) @62cb39d7   Sep 17, 2018, 6:28:29 AM Sebastian Huber bsp/tqm8xx: Remove unused files Close #3513.
(edit) @688e101a   Sep 14, 2018, 5:30:46 AM Sebastian Huber bsp/tqm8xx: Fix polled vs. interrupt output Update #3513.
(edit) @d22147e   Sep 12, 2018, 9:47:19 AM Sebastian Huber bsp/tqm8xx: Convert console to new Termios API Update #3513.
(edit) @68920e7f   Sep 12, 2018, 8:43:02 AM Sebastian Huber bsp/tqm8xx: Move DMA support to channel descriptor Update #3513.
(edit) @53fb03fe   Sep 12, 2018, 8:24:56 AM Sebastian Huber bsp/tqm8xx: Move rxBuf to channel descriptor Update #3513.
(edit) @7b93d857   Sep 12, 2018, 8:08:50 AM Sebastian Huber bsp/tqm8xx: Use IRQ extensions API Update #3513.
(edit) @94ea8a8   Sep 13, 2018, 9:34:23 AM Sebastian Huber bsp/tqm8xx: Clear sbss section
