@167818a
08/01/06 18:30:35 |
WENorum |
Add bsp_setbenv system call.
4.104.114.84.95
@6d05356
07/25/06 16:16:07 |
Ralf Corsepius |
Add objc
4.104.114.84.95
@8eb71ea4
07/25/06 16:11:49 |
Ralf Corsepius |
Remove sed -e /[@]tool_target[@]-newlib/d"
4.104.114.84.95
@eca59879
07/25/06 16:11:21 |
Ralf Corsepius |
Remove blank lines.
4.104.114.84.95
@e8b0467
07/25/06 16:10:46 |
Ralf Corsepius |
More %if %build_newlib blocks.
4.104.114.84.95
@6cbe966
07/25/06 14:18:12 |
Ralf Corsepius |
New.
4.104.114.84.95
@f391f6a
07/25/06 13:15:18 |
Ralf Corsepius |
Fix rpmgroup.
Cosmetics.
4.104.114.84.95
@41e4caf
07/25/06 11:47:04 |
Ralf Corsepius |
Upgrade to gcc-3.4.4-2, cygwin-1.5.21-1
4.104.114.84.95
@c45ec73
07/24/06 09:01:22 |
Ralf Corsepius |
Bump version.
Add AC_CONFIG_FILES([autotools/Makefile])
4.104.114.84.95
@9b966c30
07/24/06 08:57:02 |
Ralf Corsepius |
Add autotools.
4.104.114.84.95
@35ed8723
07/24/06 08:56:11 |
Ralf Corsepius |
Add provisory/preliminary autotools support.
4.104.114.84.95
@43fe4445
07/24/06 08:54:04 |
Ralf Corsepius |
Cleanup.
Add note on autotools.
4.104.114.84.95
@a26364de
07/24/06 08:51:15 |
Ralf Corsepius |
New.
4.104.114.84.95
@262bea9
07/24/06 08:50:28 |
Ralf Corsepius |
Add Chris and Joel.
4.104.114.84.95
@c791b9d
07/24/06 08:48:26 |
Ralf Corsepius |
2006-07-23 Rename "*-base-*" packages into <tool>-common.
Rename …
4.104.114.84.95
@a61e8325
07/23/06 14:24:25 |
Ralf Corsepius |
Bump version
4.104.114.84.95
@5e58aa92
07/23/06 14:23:21 |
Ralf Corsepius |
Minor fixes.
4.104.114.84.95
@1528803c
07/23/06 14:22:37 |
Ralf Corsepius |
Let rpm Obsolete < %{binutils_version}-%{release}
4.104.114.84.95
@6255333
07/23/06 14:21:26 |
Ralf Corsepius |
Rename *base packages into gcc*-common gcc/base*.add
4.104.114.84.95
@f789c8a2
07/23/06 14:20:22 |
Ralf Corsepius |
Rename *gfortran …
4.104.114.84.95
@6f60abde
07/23/06 14:19:57 |
Ralf Corsepius |
Rename *g77 into …
4.104.114.84.95
@6d206e16
07/23/06 14:19:14 |
Ralf Corsepius |
Rename *objc into …
4.104.114.84.95
@bf7b460
07/23/06 14:18:56 |
Ralf Corsepius |
Rename *gcj into …
4.104.114.84.95
@45c41764
07/23/06 14:18:39 |
Ralf Corsepius |
Rename *gnat into …
4.104.114.84.95
@48b256c3
07/23/06 14:18:24 |
Ralf Corsepius |
Rename *c++ into …
4.104.114.84.95
@793bad2
07/23/06 14:17:48 |
Ralf Corsepius |
4.104.114.84.95
@e41b8b7
07/23/06 14:16:21 |
Ralf Corsepius |
Let rpm Obsolete < %{gdb_version}-%{release}
4.104.114.84.95
@9a626a3
07/23/06 14:14:55 |
Ralf Corsepius |
Add --enable-threads.
4.104.114.84.95
@aec66f3
07/23/06 05:36:19 |
Ralf Corsepius |
Elminate blank lines.
4.104.114.84.95
@332fd2a
07/22/06 07:23:51 |
Chris Johns |
Changes to the installer and an extra script to build all.
4.104.114.84.95
@e302e959
07/22/06 05:05:22 |
Ralf Corsepius |
Eliminate white spaces.
4.104.114.84.95
@385f81c
07/22/06 02:40:16 |
Ralf Corsepius |
Rename rtems4.7-base-gdb into gdb-common
4.104.114.84.95
@65f75598
07/21/06 15:55:08 |
Ralf Corsepius |
Rename rtems4.7-base-binutils into binutils-common
4.104.114.84.95
@7bcdece
07/21/06 05:02:12 |
Ralf Corsepius |
Remove --sources (Unused)
4.104.114.84.95
@a52dc937
07/21/06 04:51:54 |
Ralf Corsepius |
Add %{gcclib}/@tool_target@/%{gcc_version}/include/ssp
4.104.114.84.95
@0c8a556
07/21/06 04:38:56 |
Ralf Corsepius |
Make install-patches more verbose.
4.104.114.84.95
@e8ba788
07/21/06 04:36:14 |
Ralf Corsepius |
Add install-patches.
4.104.114.84.95
@654cb682
07/21/06 04:29:02 |
Ralf Corsepius |
Add objc.
4.104.114.84.95
@83fc6ac
07/21/06 00:13:42 |
Chris Johns |
2006-07-21 Chris Johns <chrisj@…>
* build-rpms.sh: Add the …
4.104.114.84.95
@ed70a496
07/21/06 00:11:54 |
Chris Johns |
Add the build-rpms.sh here until moved to crossrpms.
4.104.114.84.95
@7cadb8e
07/21/06 00:07:45 |
Chris Johns |
Add the support files.
4.104.114.84.95
@be77d1f
07/21/06 00:04:20 |
Chris Johns |
Add NSIS installer support for MinGW.
4.104.114.84.95
@44a6dcc
07/20/06 23:32:32 |
Chris Johns |
Use gcc-core-4.1.1-rtems-20060720.diff.
4.104.114.84.95
@c29d0a21
07/20/06 05:17:36 |
Ralf Corsepius |
Remove $build_infos.
Add SPECSTRIP_OPTS.
4.104.114.84.95
@8747e99a
07/20/06 05:16:29 |
Ralf Corsepius |
Add --enable/disable-infos.
4.104.114.84.95
@40459fbf
07/20/06 05:15:47 |
Ralf Corsepius |
Add SPECSTRIP_OPTS.
4.104.114.84.95
@a1abfb95
07/20/06 00:40:11 |
Chris Johns |
2006-07-19 Chris Johns <chrisj@…>
4.104.114.84.95
@45def1d
07/19/06 21:51:39 |
Chris Johns |
Added patch to fix GCC bug PR28400.
4.104.114.84.95
@d4609b2
07/18/06 07:26:10 |
Ralf Corsepius |
Use newlib-1.14.0-rtems-20060707.diff
4.104.114.84.95
@22f187d0
07/18/06 07:25:19 |
Ralf Corsepius |
Fix setting up targets for solaris*
4.104.114.84.95
@4557d3c
07/18/06 02:32:19 |
Ralf Corsepius |
Remove infos and man7 if !%build_infos.
4.104.114.84.95
@c10a31b
07/17/06 15:23:04 |
Ralf Corsepius |
Require: base packages iff %build_infos
4.104.114.84.95
@176aca7
07/17/06 15:22:05 |
Ralf Corsepius |
Require: base-g77 iff %build_infos
4.104.114.84.95
@f69ae2e
07/17/06 15:21:33 |
Ralf Corsepius |
Require: base-gfortran iff %build_infos
4.104.114.84.95
@d2b94e76
07/17/06 14:30:28 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@517782a
07/16/06 14:37:02 |
Joel Sherrill |
2006-07-16 Joel Sherrill <joel@…>
* preinstall.am: Install …
4.104.114.84.95
@f3ef35af
07/16/06 06:17:32 |
Ralf Corsepius |
Require base-gnat if build_infos is true.
4.104.114.84.95
@45fbca9
07/16/06 06:15:33 |
Ralf Corsepius |
Require base-gcc if build_infos is true.
4.104.114.84.95
@c20efa7
07/16/06 06:05:37 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@4edae5cf
07/16/06 06:05:02 |
Ralf Corsepius |
Let *-gcc subpackage require base-package.
4.104.114.84.95
@473fe62
07/16/06 06:03:36 |
Ralf Corsepius |
Remove rpmlint warning on subject.
4.104.114.84.95
@aaf5563
07/16/06 05:05:11 |
Ralf Corsepius |
Remove @build_infos@.
4.104.114.84.95
@116f0fc
07/16/06 04:52:38 |
Ralf Corsepius |
Eliminate @osversion@
4.104.114.84.95
@1ac7a00
07/16/06 04:51:16 |
Ralf Corsepius |
Eliminate @osversion. Hard-code 4.7.
4.104.114.84.95
@0b83afe9
07/14/06 20:11:29 |
Joel Sherrill |
2006-07-13 Jerry Needell <jerry.needell@…>
* clock/ckinit.c, …
4.104.114.84.95
@8eb78a20
07/14/06 09:52:00 |
Thomas.Doerfler |
added ChangeLog? entries for PR1117/1118/1119/1120
4.104.114.84.95
@26bdc875
07/14/06 06:54:23 |
Ralf Corsepius |
Use <os>/<arch>/Makefile.am in check for all/rtems.
4.104.114.84.95
@cb9c5a8
07/14/06 06:05:04 |
Ralf Corsepius |
include ../gcc.am
4.104.114.84.95
@969f4d5
07/14/06 06:04:51 |
Ralf Corsepius |
New. Split out from i686/Makefile.am
4.104.114.84.95
@7681446
07/14/06 05:19:05 |
Ralf Corsepius |
include ../gcc.am
4.104.114.84.95
@4e7fb7b
07/14/06 05:18:42 |
Ralf Corsepius |
4.104.114.84.95
@6e97f0bf
07/13/06 20:51:21 |
Joel Sherrill |
Fix whitespace.
4.104.114.84.95
@984ccfed
07/13/06 20:50:54 |
Joel Sherrill |
Change RTEMS to Joel.
4.104.114.84.95
@460d7e7
07/13/06 16:48:53 |
Joel Sherrill |
2006-07-13 Joel Sherrill <joel@…>
* configure.ac, …
4.104.114.84.95
@6933a4c
07/13/06 12:50:17 |
Ralf Corsepius |
BR: libtermcap-devel for sparc-rtems.
4.104.114.84.95
@b18c5f7c
07/13/06 06:37:43 |
Ralf Corsepius |
2006-07-13 Ralf Corsepius <ralf.corsepius@…>
* doxy-filter: …
4.104.114.84.95
@47854a0d
07/13/06 01:27:30 |
strauman |
PR 1110/networking
* libnetworking/machine/in_cksum.h: Replaced PPC …
4.104.114.84.95
@b365d4d
07/13/06 00:41:03 |
strauman |
* shared/pci/pcibios.c: let pci_find_device() return
-1 on failure, …
4.104.114.84.95
@a031fc22
07/13/06 00:36:15 |
strauman |
* rtems/old-exceptions/cpu.h, rtems/powerpc/registers.h:
Checked …
4.104.114.84.95
@60426fed
07/13/06 00:32:41 |
strauman |
* pppd/sys-rtems.c: fixed error message so that the correct
ioctl is …
4.104.114.84.95
@05e2e4c
07/13/06 00:29:06 |
strauman |
* mpc6xx/mmu/bat.c, mpc6xx/mmu/pte121.c, shared/src/cache.c:
Checked …
4.104.114.84.95
@c8f74b47
07/12/06 23:43:56 |
strauman |
* vmeUniverse/vmeTsi148.c: Silenced compiler warnings
(gcc-4.1.1 …
4.104.114.84.95
@689429f8
07/12/06 23:39:48 |
strauman |
* shared/startup/probeMemEnd.c: added paranoia to inline
assembly …
4.104.114.84.95
@c632f647
07/12/06 23:37:13 |
strauman |
* shared/startup/panic.c: Fixed compiler warnings.
4.104.114.84.95
@ad6a58d
07/12/06 20:57:29 |
Joel Sherrill |
2006-07-12 Jerry Needell <jerry.needell@…>
* amba/amba.c, …
4.104.114.84.95
@d959898
07/12/06 20:48:51 |
Joel Sherrill |
2006-07-12 RTEMS
* rtems4.7/arm/gdb-sources.add, …
4.104.114.84.95
@8faa4a5
07/12/06 19:09:24 |
Joel Sherrill |
2006-07-12 Joel Sherrill <joel@…>
4.104.114.84.95
@9956f81d
07/12/06 19:08:32 |
Joel Sherrill |
* Makefile.am, …
4.104.114.84.95
@97871c97
07/12/06 18:24:44 |
Joel Sherrill |
* Makefile.am: Merge SHM …
4.104.114.84.95
@1a3ddc10
07/11/06 22:27:28 |
Joel Sherrill |
2006-07-11 Joel Sherrill <joel@…>
* clock/ckinit.c: …
4.104.114.84.95
@83df49f
07/11/06 21:05:12 |
Joel Sherrill |
PR 1124/rtems
4.104.114.84.95
@e8f5da0
07/11/06 19:57:33 |
Thomas.Doerfler |
fixed system.h: only include ATA/IDE driver, when BSP supports an ide …
4.104.114.84.95
@4795141
07/11/06 15:56:58 |
Joel Sherrill |
* leon_greth/.cvsignore, …
4.104.114.84.95
@72baf565
07/11/06 14:53:07 |
Joel Sherrill |
* clock/ckinit.c, …
4.104.114.84.95
@daf46560
07/11/06 14:46:22 |
Ralf Corsepius |
Sync.
4.104.114.84.95
@0b130fae
07/11/06 14:45:24 |
Ralf Corsepius |
Rebuild with arm-patch applied.
4.104.114.84.95
@81d914d8
07/11/06 14:15:22 |
Joel Sherrill |
2006-07-11 Jerry Needell <jerry.needell@…>
4.104.114.84.95
@6dd1665c
07/11/06 14:14:15 |
Joel Sherrill |
* ChangeLog?, …
4.104.114.84.95
@dfc207ea
07/11/06 11:33:19 |
Ralf Corsepius |
4.104.114.84.95
@2dd8aa1e
07/11/06 11:32:10 |
Ralf Corsepius |
New. Remove arm/endian.h
4.104.114.84.95
