@14d55deb
04/13/15 09:12:04 |
Daniel Hellstrom |
DRVMGR: renamed info_dev to get_info_dev
4.115
@246fe22
04/13/15 09:07:54 |
Daniel Hellstrom |
DRVMGR: change name of freq_get to get_freq
4.115
@bb2f220
04/13/15 08:49:47 |
Daniel Hellstrom |
DRVMGR: renamed private drv_mgr and its struct name
4.115
@bf2c3f8b
04/13/15 08:47:22 |
Daniel Hellstrom |
DRVMGR: updated README
4.115
@4f09060
04/13/15 08:32:50 |
Daniel Hellstrom |
DRVMGR: only build on SPARC platform
4.115
@4a7d1026
04/13/15 08:25:52 |
Daniel Hellstrom |
sparc bsps: updated license to rtems.org
4.115
@e53daed
04/09/15 14:09:42 |
Daniel Hellstrom |
LIBPCI: updated license to rtems.org
4.115
@0decc806
04/09/15 14:09:13 |
Daniel Hellstrom |
DRVMGR: updated license to rtems.org
4.115
@cc3f87c0
04/09/15 06:36:39 |
Daniel Hellstrom |
DRVMGR: removed a goto and added comments
4.115
@1b645c3
04/08/15 15:00:43 |
Daniel Hellstrom |
LIBPCI: corrected documentation
4.115
@f4bf22c
04/08/15 08:51:45 |
Daniel Hellstrom |
LIBPCI: new implementation private header file
- new implementation …
4.115
@1f4f1e2e
04/08/15 08:39:41 |
Daniel Hellstrom |
LIBPCI: various comment/unsed clean-ups
4.115
@346a9a5
04/08/15 08:16:51 |
Daniel Hellstrom |
LIBPCI: use enum with pci_system_type
4.115
@15620f5b
04/08/15 08:03:45 |
Daniel Hellstrom |
LIBPCI: use RTEMS_INLINE_ROUTINE
4.115
@dc623099
04/08/15 08:01:48 |
Daniel Hellstrom |
LIBPCI: moved comment out of license header
4.115
@e189f241
04/08/15 08:00:48 |
Daniel Hellstrom |
PCI BUS: moved comment out of license header
4.115
@2fb0912
04/08/15 07:50:28 |
Daniel Hellstrom |
DRVMGR: clean-up Makefile.am
4.115
@eff69891
04/08/15 07:49:11 |
Daniel Hellstrom |
DRVMGR: use RTEMS_INLINE_ROUTINE
4.115
@39937b6c
04/07/15 14:35:53 |
Daniel Hellstrom |
LIBPCI: added license and auto-gen comment to pci/ids.h
To be Merged.
4.115
@07e5a0e
04/07/15 14:19:39 |
Daniel Hellstrom |
LIBPCI: clean-up pci_for_each_child() search arg
4.115
@4ab9296
04/07/15 14:08:05 |
Daniel Hellstrom |
LIBPCI: remove $Id in makefile.am
4.115
@159ee990
04/07/15 14:05:04 |
Daniel Hellstrom |
leon3,ngmp: cpucounter initialization use proper names
To be merged …
4.115
@5564b5a
04/07/15 14:04:13 |
Daniel Hellstrom |
leon3: timer config updated to use proper naming
To be merged with …
4.115
@9b292ea
04/07/15 12:31:22 |
Daniel Hellstrom |
LEON: converted LEON4-N2X to BSD header
4.115
@8b29637c
04/07/15 12:31:07 |
Daniel Hellstrom |
LEON: converted PCI peripherals to BSD header
4.115
@d5ca821
04/07/15 12:28:29 |
Daniel Hellstrom |
LEON: converted AT697,GRPCi,GRPCI2,PCIF to BSD header
4.115
@c1c37a1
04/07/15 12:25:49 |
Daniel Hellstrom |
LIBPCI: converted to BSD header
4.115
@56ea46ba
04/07/15 12:25:23 |
Daniel Hellstrom |
DRVMGR: PCI BUS converted to BSD header
4.115
@1f66914
04/13/15 08:12:08 |
Daniel Hellstrom |
LIBPCI: moved pci_bus copyright into a single line
4.115
@71e8a5c
02/27/15 15:45:59 |
Daniel Hellstrom |
LIBPCI: moved copyright into a single line
4.115
@358b8543
02/27/15 15:45:20 |
Daniel Hellstrom |
LIBPCI: removed unused changes file
4.115
@a2e0e6e
02/27/15 15:44:48 |
Daniel Hellstrom |
LIBPCI: fixed RES2DEV in pci/cfg.h
4.115
@65d1f35
02/27/15 15:42:36 |
Daniel Hellstrom |
DRVMGR: updated copyright into one line only
4.115
@5823bae8
02/27/15 13:03:15 |
Daniel Hellstrom |
LEON: move driver headers to bsp/ directory
4.115
@445e253
02/06/15 09:07:19 |
Daniel Hellstrom |
MCTRL: fix build warnings in MCTRL driver
4.115
@dbfa7c98
02/11/15 11:56:03 |
Daniel Hellstrom |
AMBAPP GRLIB: fix build warnings
4.115
@62fb1778
02/11/15 11:55:32 |
Daniel Hellstrom |
LEON2: fix build warnings
4.115
@43613a90
02/11/15 11:54:57 |
Daniel Hellstrom |
AMBAPP_BUS: fix build warnings
4.115
@56662f5c
02/11/15 11:52:14 |
Daniel Hellstrom |
LEON CONS: fix build warnings
4.115
@103bbde
02/11/15 11:50:35 |
Daniel Hellstrom |
GR-TMTC-1553: fix build warnings
4.115
@dd8abfc
02/11/15 11:40:17 |
Daniel Hellstrom |
GR-RASTA-TMTC: fix build warnings
4.115
@90fd587
02/11/15 11:39:40 |
Daniel Hellstrom |
GR-RASTA-SPW-ROUTER: fix build warnings
4.115
@960aebf
02/11/15 11:39:04 |
Daniel Hellstrom |
GR-RASTA-IO: fix build warnings
4.115
@03037b4
02/11/15 11:38:22 |
Daniel Hellstrom |
GR-RASTA-ADCDAC: fix build warnings
4.115
@ef7a009
02/11/15 11:37:28 |
Daniel Hellstrom |
GR-LEON4-N2X: fix build warnings
4.115
@05a45c79
02/11/15 11:36:50 |
Daniel Hellstrom |
GR_701: fix build warnings
4.115
@cb64b862
02/11/15 11:35:53 |
Daniel Hellstrom |
GRGPIO: fix buld warnings
4.115
@c39de3c4
02/11/15 11:35:36 |
Daniel Hellstrom |
GPIOLIB: fix build warnings
4.115
@7bc74ed
02/11/15 11:34:48 |
Daniel Hellstrom |
GRADCDAC: fix build warnings
4.115
@0355ad4
02/11/15 11:34:02 |
Daniel Hellstrom |
GENIRQ: fix build warnings
4.115
@9d05c6df
02/11/15 11:32:22 |
Daniel Hellstrom |
GRPWM: fix build warnings
4.115
@126b25d
02/11/15 11:31:26 |
Daniel Hellstrom |
SPWCUC: fix build warnings
4.115
@8c6c53d
02/11/15 11:27:05 |
Daniel Hellstrom |
SPICTRL: fix build warnings
4.115
@9b90342
02/11/15 11:23:45 |
Daniel Hellstrom |
GRSPW router: fix build warnings
4.115
@b6292a0b
02/11/15 11:23:04 |
Daniel Hellstrom |
GRSPW_PKT: fix build warnings
4.115
@fd7eaa2
02/11/15 08:40:15 |
Daniel Hellstrom |
TLIB: fix build warnings
4.115
@6048035
02/11/15 08:39:48 |
Daniel Hellstrom |
TLIB Clock: fix build warnings
4.115
@a93b3aa4
02/11/15 08:37:50 |
Daniel Hellstrom |
GRASCS: fix build warnings
4.115
@3823f5c
02/11/15 08:20:40 |
Daniel Hellstrom |
GRCTM: fix build warnings
4.115
@60d392b7
02/11/15 08:19:53 |
Daniel Hellstrom |
GRTM: fix build warnings
4.115
@e21a5b0
02/11/15 08:18:53 |
Daniel Hellstrom |
GRTC: fix build warnings
4.115
@6657a3d
02/10/15 15:33:16 |
Daniel Hellstrom |
LEON: GRPCI2 driver warning fixes
4.115
@48191662
02/10/15 15:29:39 |
Daniel Hellstrom |
LEON: I2CMST driver warnings fixes
4.115
@c9f75435
02/10/15 15:28:55 |
Daniel Hellstrom |
LEON: OCCAN driver warnings fixes
4.115
@be815e78
02/10/15 15:28:19 |
Daniel Hellstrom |
LEON: B1553BRM driver warnings fixes
4.115
@44e514f
02/10/15 15:28:03 |
Daniel Hellstrom |
LEON: B1553RT driver warnings fixes
4.115
@3f38335b
02/10/15 15:05:38 |
Daniel Hellstrom |
LEON: added get_resarray_count() helper routine
4.115
@b787bead
02/10/15 08:23:48 |
Daniel Hellstrom |
GR1553B: fixed build warnings
4.115
@05ce8bd5
02/10/15 07:32:42 |
Daniel Hellstrom |
AT697PCI: fix build warnings
4.115
@e3c9937
02/18/15 14:34:39 |
Daniel Hellstrom |
GPTIMER: move ISR install from init1
To avoid install ISRs during …
4.115
@f37a3c2
02/06/15 10:10:17 |
Daniel Hellstrom |
GPTIMER: fix build warnings
4.115
@7a03ac29
02/06/15 08:59:13 |
Daniel Hellstrom |
APBUART_CONS: fix build warning
4.115
@d77b16d
02/06/15 08:27:08 |
Daniel Hellstrom |
4.115
@28950f0b
02/05/15 13:35:33 |
Daniel Hellstrom |
PCIF: fixed build warnings
4.115
@f407c51
02/05/15 13:31:42 |
Daniel Hellstrom |
GRPCI: fixed build warnings
4.115
@0d9bc25
02/05/15 08:52:00 |
Daniel Hellstrom |
GRSPW: fix build warnings
4.115
@b55aa49
02/05/15 07:07:15 |
Daniel Hellstrom |
LEON3: watchdog use common timer defines
4.115
@5ba49066
02/05/15 07:06:26 |
Daniel Hellstrom |
LEON3: export debug uart to console uart driver
4.115
@aedc9849
02/05/15 07:05:56 |
Daniel Hellstrom |
GRETH: fix build warnings with GCC-4.9
4.115
@bf6fe958
02/04/15 15:22:59 |
Daniel Hellstrom |
GPTIMER: avoid build warnings
4.115
@0fcd4b33
02/04/15 15:22:41 |
Daniel Hellstrom |
AHBSTAT: fix build warnings
4.115
@bb689e6
11/04/14 07:57:55 |
Daniel Hellstrom |
GRTM: fixed descriptor TS bit declaration
4.115
@5f4028b
11/04/14 07:52:39 |
Daniel Hellstrom |
GRSPW_PKT: grspw_status renamed in header
4.115
@e8f6005f
08/08/14 08:01:41 |
Daniel Hellstrom |
GR-RASTA-TMTC,rev1: add GRGPIO[0] register init
4.115
@fed905c8
08/08/14 07:59:36 |
Daniel Hellstrom |
B1553BRM: change the init of the RT legalization registers
4.115
@d2a94ab
05/02/14 12:28:44 |
Daniel Hellstrom |
GRSPW: added clock cycles after GRSPW reset
added clock cycles after …
4.115
@56fc7809
07/03/13 08:16:30 |
andreas |
GRSPW_PKT: Add support for Interrupt-codes
Update: Daniel Hellstrom …
4.115
@c119c0e
07/03/13 08:06:37 |
andreas |
GRSPW: Fix incorrect register defines - presently functionally …
4.115
@f1b1668
12/20/13 09:17:22 |
Daniel Hellstrom |
AMBAPP: updated PnP IDs database with SPWTDP
4.115
@fa12bb43
11/29/13 13:58:58 |
Daniel Hellstrom |
GRTIMER: added to GPTIMER driver
GRTIMER is compatible with GPTIMER, …
4.115
@9b8e04e2
10/22/13 10:03:41 |
Daniel Hellstrom |
GRETH: avoid hw generated UDP/TCP cksum generation
Hardware generated …
4.115
@80b9c8ac
12/20/13 13:03:10 |
Daniel Hellstrom |
GR-RASTA-IO: updated for new version
From this driver's point of view …
4.115
@fc76056e
12/20/13 13:01:12 |
Daniel Hellstrom |
GR-RASTA-TMTC: updated for new version
From this driver's point of …
4.115
@9d88008
12/18/13 15:42:16 |
Daniel Hellstrom |
AT697PCI: fix PCI cfg writes
4.115
@ddc4002
11/22/13 09:22:56 |
Daniel Hellstrom |
AT697 PCI: abort whhen a peripheral PCI system detected
4.115
@3c236cc
02/05/14 16:17:53 |
Daniel Hellstrom |
LEON PCI: fix for PCI host bridge driver CFG space access
4.115
@acf7047e
09/10/13 11:46:29 |
Daniel Hellstrom |
GPTIMER: timer probing must not be on timer0
Timers are identical …
4.115
@51347053
07/01/13 13:00:21 |
Daniel Hellstrom |
LEON PCI: host bridge driver support for probing dev0=AD16
Before the …
4.115
@d936c1a
06/03/13 12:12:08 |
Daniel Hellstrom |
APBUART: debug bit was cleared incorrectly
4.115
@ab907e8e
05/21/13 08:10:21 |
Daniel Hellstrom |
NGMP PCI: added support for NGMP prototype boards
4.115
