@04436013
03/02/21 17:40:36 |
ryan.long |
gr_rasta_spw_router.c: Fix Unchecked return value from library (CID …
@c7eb89f8
03/01/21 21:06:41 |
ryan.long |
cpuusagetop.c: Fix three Missing break in switch Coverity errors
CID …
@13d6fae
03/01/21 20:33:06 |
ryan.long |
grtc.c: Fix four Missing break in switch Coverity errors
CID 1399761: …
@1eaf4e46
03/01/21 16:06:48 |
ryan.long |
grspw.c: Fix Unchecked return value (CID #1399781)
CID 1399781: …
@6ebf376b
02/22/21 15:39:59 |
jan.sommer |
bsps/shared: Allow setting baud rate for zynq uart
@f662420
02/20/21 03:29:27 |
kinsey.moore |
spec/aarch64: Rename ZynqMP QEMU BSPs
The current ZynqMP BSPs don't …
@a27ba3f
01/08/21 16:13:42 |
kinsey.moore |
bsps/aarch64: Add support for EL2 start
Add the stub necessary to …
@9951cee
02/15/21 15:05:10 |
kinsey.moore |
bsps/aarch64: RTEMS_DEBUG stack alignment faults
Run with stack …
@9d77c0f4
01/08/21 01:39:20 |
kinsey.moore |
spec: Move hypervisor start for use by AArch64
AArch64 on hardware is …
@07297812
01/11/21 17:56:36 |
alex.white |
spec/aarch64: Remove sp37 from intermittent tests
@9aff7e56
01/11/21 16:23:16 |
alex.white |
score/aarch64: Fix interrupt level reads
@bbc9974a
02/15/21 16:51:37 |
kinsey.moore |
cpukit: Explicitly enforce alignment requirements
According to …
@2ee12f02
03/02/21 20:11:49 |
kinsey.moore |
bsps: Allow override of ARM TM27 IRQs
ZynqMP hardware appears to have …
@6bfbfb5
02/19/21 14:34:48 |
kinsey.moore |
bsps/aarch64: Resolve usage of SUBALIGN()
Remove usage of SUBALIGN() …
@61d688bf
03/04/21 07:12:47 |
Sebastian Huber |
aarch64: Fix context switch
The Per_CPU_Control::isr_dispatch_disable …
@5248395
03/03/21 08:23:20 |
Sebastian Huber |
score: Ensure stack alignment requirement
Make sure that a …
@1de00d6
03/03/21 08:36:45 |
Sebastian Huber |
CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
Ensure that …
@8fe59be
03/03/21 09:27:52 |
Sebastian Huber |
validation: Fix for 64-bit targets
Closes #4179.
@30f6fd5b
03/03/21 07:04:55 |
Sebastian Huber |
rtems: Fix RTEMS_TASK_STORAGE_ALIGNMENT
Make sure we meet the stack …
@4a765b47
03/03/21 07:39:33 |
Sebastian Huber |
score: Enforce CPU_STACK_ALIGNMENT requirements
Clarify …
@a510e243
02/25/21 08:47:08 |
jan.sommer |
MAINTAINERS: Add myself to write after approval
@83b1b25d
03/02/21 11:31:45 |
Sebastian Huber |
rtems: Simplify rtems_signal_catch()
In uniprocessor configurations, …
@9a13f37
03/02/21 09:55:10 |
Sebastian Huber |
rtems: Simplify _Signal_Action_handler()
Use the invariant that an …
@320cb42
02/23/21 08:18:40 |
james.fitzsimons |
bsps/beagle: Updating licences to latest BSD 2 clause
@db86c3eb
02/23/21 08:18:39 |
james.fitzsimons |
bsps/beagle: Adding QEP driver support to BeagleBoneBlack? BSP
@c0c4b8b
03/02/21 06:54:17 |
Sebastian Huber |
validation: Format comment blocks
@441824a
03/01/21 07:12:54 |
Sebastian Huber |
score: Simplify _Objects_Name_to_id_u32()
Remove superfluous check …
@2ad03de
03/01/21 09:00:26 |
Sebastian Huber |
validation: Add comments to task tests
@81fcf16
02/24/21 16:59:32 |
Sebastian Huber |
validation: Add comments to message queue tests
Split up post-condition.
@54c9630
03/01/21 09:00:26 |
Sebastian Huber |
validation: Add comments to signal tests
@34f279aa
02/24/21 16:59:32 |
Sebastian Huber |
validation: Add comments to barrier tests
Unify code sections across …
@08cbd4ba
02/26/21 11:34:21 |
Sebastian Huber |
score: Fix _Stack_Extend_size()
Check for an integer overflow. Add a …
@9dad735
02/26/21 11:34:08 |
Sebastian Huber |
validation: Improve task construct error tests
@96918af
02/26/21 23:54:37 |
Chris Johns |
powerpc/motorola_power: Place any common data in the .bss section
@75fb7a0e
02/24/21 06:04:36 |
Chris Johns |
powerpc/motorola_power: Link all text sections into the executable …
@f0f8c111
02/27/21 06:09:01 |
vijay |
getgrent.c, record-client.c: Add missing includes for assert.h
@e2002659
02/19/21 22:34:26 |
ryan.long |
rtems-debugger-threads.c: Fix Unchecked return value error (CID …
@e5e58da
02/19/21 22:30:13 |
ryan.long |
getgrent.c: Fix Unchecked return value error (CID #1459004)
CID …
@be3b87d
02/19/21 22:24:05 |
ryan.long |
record-client.c: Fix Unchecked return value (CID #1456677)
CID …
@1b322a6
02/19/21 22:06:38 |
ryan.long |
printertask.c: Fix Unchecked return value (CID #1399710)
CID 1399710: …
@2428a8ca
02/26/21 08:56:39 |
Sebastian Huber |
build: Install <rtems/score/hash.h>
Update #4267.
@de7df04
02/26/21 08:48:41 |
Sebastian Huber |
bsps: Fix legacy build
@1ac4a85
02/25/21 18:08:52 |
Sebastian Huber |
score: Fix thread initialization
Close the thread object if a thread …
@c96644e8
02/24/21 13:45:47 |
Sebastian Huber |
libtest: Print SHA256 hash in base64url
@74eff26c
02/23/21 18:47:02 |
Sebastian Huber |
libtest: Report target hash
Update #4267.
@7480c34
02/23/21 17:53:42 |
Sebastian Huber |
bsps: Add default rtems_get_target_hash()
Update #4267.
@bc6ffc3
02/24/21 12:25:46 |
Sebastian Huber |
Add system initialization step for target hash
Update #4267.
@fb17af27
02/23/21 11:47:38 |
Sebastian Huber |
rtems: Add rtems_get_target_hash()
Update #4267.
@dea125d0
02/23/21 13:53:40 |
Sebastian Huber |
score: Add Hash Handler
Update #4267.
@5f8bc83
02/23/21 12:25:00 |
Sebastian Huber |
score: Add _IO_Base64url()
Update #4267.
@da8ad67e
02/23/21 09:58:08 |
Sebastian Huber |
libtest: Report build label
Update #4269.
@d8bfa5a
02/23/21 09:58:56 |
Sebastian Huber |
rtems: Add rtems_get_build_label()
Update #4269.
@d138a790
02/24/21 12:12:27 |
Sebastian Huber |
config: Adjust stack allocator initialization
Use the right system …
@32b0d6f8
02/24/21 10:13:30 |
Sebastian Huber |
bsps: Change license to BSD-2-Clause of some files
Change license to …
@e8284a34
02/23/21 18:38:38 |
Sebastian Huber |
build: Sort source lists
Use the Python sorted() function to sort the …
@006c702
02/21/21 16:48:04 |
Sebastian Huber |
validation: Simplify message queue construct tests
@fd838603
02/19/21 20:31:34 |
Sebastian Huber |
validation: Add missing barrier create test case
@5be6e61
02/21/21 16:26:31 |
Sebastian Huber |
libtest: Add support to seize/surrender objects
@d6a649d5
02/19/21 20:41:18 |
Sebastian Huber |
rtems: Move rtems_task_priority definition
This type is not only used …
@88543ade
02/21/21 09:58:15 |
Sebastian Huber |
score: Remove _CORE_barrier_Do_flush()
Call …
@3cbdf19
02/21/21 09:21:26 |
Sebastian Huber |
score: Simplify core barrier
Use the number of threads which must …
@0b263b0e
02/21/21 09:47:36 |
Sebastian Huber |
score: Remove _Objects_Open()
Use the type safe _Objects_Open_u32() …
@3353820b
02/23/21 09:04:51 |
Sebastian Huber |
build: Fix format in wscript
@508f8682
02/20/21 13:28:17 |
Sebastian Huber |
rtems: Simplify rtems_task_mode()
Do the preemption and ASR …
@a7e180b
02/16/21 11:58:36 |
Sebastian Huber |
rtems: Avoid potential recursion in ASR handling
Do the mode changes …
@08adc0d
02/16/21 11:58:02 |
Sebastian Huber |
rtems: Add _Modes_Apply_timeslice_to_thread()
Update #4244.
@8778a0e
02/16/21 09:27:03 |
Sebastian Huber |
rtems: New errors for rtems_signal_catch()
Ensure that no invalid …
@1739bd2
02/19/21 08:48:14 |
Sebastian Huber |
rtems: Remove _Modes_Set_interrupt_level()
This call just obfuscated …
@b207b37
02/17/21 07:00:29 |
Sebastian Huber |
posix: Remove superfluous check
The api pointer is never NULL.
@f6a97f5
02/16/21 07:15:10 |
Sebastian Huber |
rtems: Simplify signal handling
Remove superfluous …
@74ca8b7
02/17/21 08:05:53 |
Sebastian Huber |
rtems: Move _Signal_Action_handler()
Move _Signal_Action_handler() …
@a52e5d9
02/16/21 06:48:39 |
Sebastian Huber |
rtems: Remove unused ASR_Information::nest_level
Update #4244.
@9d5d73b
02/16/21 06:47:53 |
Sebastian Huber |
rtems: Remove unused _Modes_Change()
Update #4244.
@600360d
02/16/21 06:47:20 |
Sebastian Huber |
rtems: Remove unused _Modes_Mask_changed()
Update #4244.
@f9a59164
02/17/21 08:02:31 |
Sebastian Huber |
score: Add _Thread_Append_post_switch_action()
Update #4244.
@fea848b
02/17/21 07:05:37 |
Sebastian Huber |
score: Change thread action locking
Require that the corresponding …
@3e7d658
02/15/21 13:02:49 |
Sebastian Huber |
validation: Add signal manager tests
Update #4244.
@f38c0de4
02/15/21 08:14:41 |
Sebastian Huber |
validation: Add Validation1 test suite
Update #4244.
@fac1ff1
02/16/21 22:39:30 |
ryan.long |
grspw_pkt.c: Fix Dereference before null check (CID #1399846)
CID …
@1fd56a96
02/16/21 22:15:01 |
ryan.long |
grtc.c: Fix Dereference before null check (CID #1399840)
CID 1399840: …
@4edcdf43
02/16/21 21:41:25 |
ryan.long |
b1553rt.c: Fix Deference before null check (CID #1399830)
CID …
@eff3d7c
02/16/21 21:20:04 |
ryan.long |
b1553brm.c: Fix Dereference before null check (CID #1399829)
CID …
@8b1b9872
06/24/20 05:10:25 |
Sebastian Huber |
rtems: Generate <rtems/rtems/signal.h>
Change license to BSD-2-Clause …
@be603721
02/10/21 05:43:39 |
Sebastian Huber |
basedefs: Add RTEMS_ALIGNOF()
@fa25b73
02/18/21 14:35:13 |
thisisryanlong |
shell.c: Fix Dereference before null check (CID #1467420)
CID …
@407e351
06/22/20 05:09:23 |
Sebastian Huber |
rtems: Generate <rtems/rtems/sem.h>
@2768280
06/22/20 07:06:51 |
Sebastian Huber |
rtems: Generate <rtems/rtems/clock.h>
@0c4c035
06/22/20 06:39:29 |
Sebastian Huber |
rtems: Generate <rtems/rtems/barrier.h>
Change license to …
@97825da
02/15/21 12:57:37 |
Sebastian Huber |
rtems: Clarify object services documentation
Unify the wording across …
@7a1828ac
02/15/21 12:57:37 |
Sebastian Huber |
rtems: Clarify IO manager documentation
@bf3b9f45
02/10/21 05:44:12 |
Sebastian Huber |
rtems: Clarify partition manager documentation
Unify the wording …
@f9dc44a
01/27/21 05:10:16 |
Sebastian Huber |
rtems: Clarify timer manager documentation
@2730599c
01/27/21 05:10:15 |
Sebastian Huber |
rtems: Clarify event manager documentation
@026eb3db
02/15/21 22:27:14 |
Chris Johns |
powerpc/motorola_powerpc: Add cache coherent memory to the allocator
@23aad64
02/15/21 22:04:45 |
Chris Johns |
powerpc/motorola_powerpc: Enable bus PCI support in LibBSD
Updates #4245
@6e3c6e04
02/15/21 22:01:57 |
Chris Johns |
powerpc/io: Make [out/in] le and be calls conditional
- These calls …
@85df127
02/15/21 22:01:32 |
Chris Johns |
powerpc/shared: Fix warnings in i8259 PIC code.
@53abbbd0
02/13/21 01:25:07 |
Chris Johns |
@86f031d4
02/13/21 01:23:21 |
Chris Johns |
powerpc/motorola_powerpc: Fix tm27 warnings
@b5aef78
02/13/21 01:22:07 |
Chris Johns |
score: Fix warning in thread queue ops
