source: rtems
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @bac53634   Dec 17, 2018, 6:40:46 AM Chris Johns libtests/dl02: Update the rtl-shell path. More verbose test. Updates #3686
(edit) @85b59974   Dec 17, 2018, 6:40:25 AM Chris Johns libtests/dl02: Update the rtl-shell path. Updates #3686
(edit) @89c59be   Dec 17, 2018, 5:36:48 AM Chris Johns libdl: Add symbol searching and loading from archives. - Load archive …
(edit) @b08278e   Feb 2, 2019, 4:32:38 AM Chris Johns powerpc/psim: Increase the psim memory to 256M This allows test dl09 …
(edit) @e2f13430   Feb 2, 2019, 4:19:59 AM Chris Johns libdl: Fix dlerror non-conformance Closes #3298
(edit) @2d8a9c79   Feb 2, 2019, 4:22:04 AM Chris Johns libmisc: Fix rtems_print_buffer Closes #3684
(edit) @568490a   Feb 8, 2019, 11:40:45 AM Jiri Gaisler griscv: add additional cpu configurations * Also switch default …
(edit) @26333f2a   Feb 8, 2019, 9:16:07 AM Sebastian Huber score: Fix _User_extensions_Thread_switch() (SMP) We have to read the …
(edit) @4e686261   Feb 7, 2019, 10:13:01 AM Sebastian Huber bsps/irq: Fix interrupt server init (SMP)
(edit) @fbd08066   Feb 7, 2019, 6:46:38 AM Sebastian Huber score: Fix plain priority thread queues (SMP) We must add/remove the …
(edit) @0fb52ce   Feb 7, 2019, 6:45:58 AM Sebastian Huber bsps/arm: Fix generic timer frequency Update #3456.
(edit) @03fcbb1   Nov 27, 2018, 11:45:53 AM Sebastian Huber fs: Add struct dirent::d_type support
(edit) @9399473c   Feb 2, 2019, 10:03:13 AM Sebastian Huber riscv: Fix misaligned access in context validate
(edit) @b015c01   Jan 28, 2019, 11:26:25 AM Sebastian Huber build: Do not install test programs
(edit) @03cdd5ea   Jan 30, 2019, 8:41:49 AM Sebastian Huber record: Add enum value for each event Update #3665.
(edit) @dca6184   Apr 28, 2018, 9:36:11 AM Sebastian Huber Add low level event recording support Add low level event recording …
(edit) @f0ae613b   Jan 17, 2019, 6:33:08 AM Sebastian Huber m68k: Avoid _Addresses_Add_offset() This prevents a cyclic dependency …
(edit) @e74a3fd   Jan 29, 2019, 12:26:12 PM Sebastian Huber samples/pppd: Use less memory hungry configuration This avoids …
(edit) @4f3a253   Jan 28, 2019, 1:16:39 PM Sebastian Huber psxtmtests: Fix format warnings Update #3384.
(edit) @b1381ae   Jan 25, 2019, 2:50:14 PM Sebastian Huber bsps/powerpc: Fix warnings
(edit) @81aec18   Jan 24, 2019, 1:29:03 PM Sebastian Huber bsps/powerpc: Fix 64-bit issues in assembler files We have to be …
(edit) @afd50b3   Jan 23, 2019, 12:17:44 PM maksim.e.kozlov libmisc: Fix swapped parameters and enable floating point usage.
(edit) @d3d4e77   Jan 18, 2019, 11:37:55 AM Jiri Gaisler riscv: add griscv bsp Update #3678.
(edit) @c1dcd6af   Jan 21, 2019, 10:27:07 AM Jiri Gaisler grlib: make memory coherency cpu-independent Update #3678.
(edit) @9b2b389   Jan 18, 2019, 5:00:47 PM Jiri Gaisler grlib: use cpu-independent routines for uncached access Update #3678.
(edit) @5981c8ca   Jan 18, 2019, 10:29:08 AM Jiri Gaisler grlib: use rtems_interrupt_handler_install() Update #3678.
(edit) @411c297   Jan 18, 2019, 10:24:18 AM Jiri Gaisler grlib: make apbuart driver independent of bsp Update #3678.
(edit) @7eb606d3   Dec 22, 2018, 5:31:04 PM Sebastian Huber grlib: Move source files Update #3678.
(edit) @31720925   Dec 22, 2018, 6:13:44 AM Sebastian Huber grlib: Move header files Update #3678.
(edit) @95c1921   Jan 21, 2019, 8:17:05 AM Sebastian Huber bsps/arm: Remove unused bsp_stack_irq_size Update #3459.
(edit) @926ed2b0   Jan 18, 2019, 12:32:51 PM Sebastian Huber score: Remove unused _ISR_lock_Flash()
(edit) @41310c02   Jan 18, 2019, 12:16:29 PM Sebastian Huber score: Improve debug support for ISR locks Ensure that interrupts are …
(edit) @b5bdecf   Jan 18, 2019, 11:54:05 AM Sebastian Huber score: Avoid internal API and use ISR lock
(edit) @93e3b341   Jan 14, 2019, 6:50:26 AM Sebastian Huber score: Simplify _Addresses_Is_aligned() The CPU_ALIGNMENT must not be …
(edit) @12dfe5dc   Jan 16, 2019, 9:42:18 PM joel bsps/i386/shared/cache/cache.c: Make compile
(edit) @4596127   Jan 10, 2019, 7:14:03 PM joel m68k/include/rtems/score/cpu.h: Add include of address.h
(edit) @47d5aee   Jan 14, 2019, 8:38:02 AM Sebastian Huber build: Add missing $(LDADD) for dependencies
(edit) @d1fff86   Jan 14, 2019, 8:07:16 AM Sebastian Huber build: Remove bogus spqreslib_LDADD
(edit) @dc0285f   Jan 14, 2019, 8:06:30 AM Sebastian Huber build: Add missing $(LDADD) for dependencies
(edit) @8eaf136d   Jan 10, 2019, 10:35:12 AM Sebastian Huber memalign: Add missing attributes to fix warning Update #3666.
(edit) @7bde91b   Jan 10, 2019, 8:05:49 AM Sebastian Huber Fix format warnings due to ino_t changes
(edit) @3a5c71d   Jan 10, 2019, 7:10:17 AM Sebastian Huber psxconfig01: Fix pre-processor conditions Do not rely on compiler …
(edit) @e7d623e7   Jan 10, 2019, 6:57:36 AM Sebastian Huber bsps/arm: Conditional ARMv7-AR data cache disable Update #3667. Close …
(edit) @0abe47f   Jan 10, 2019, 6:29:54 AM thomas.doerfler bsps/arm: Fix typo in disable cache for ARMv7-AR Update #3667.
(edit) @b9ffc41c   Jan 8, 2019, 8:50:50 AM Sebastian Huber riscv: Enable robust thread dispatch It must be enabled, since the …
(edit) @3bd39999   Jan 8, 2019, 8:53:26 AM Sebastian Huber Adjust interrupt mode tests for some CPU ports In case the robust …
(edit) @1f285186   Jan 8, 2019, 7:39:42 AM Sebastian Huber rtems: Allow to set ISR level 0 in SMP config Update #3000.
(edit) @38cb59e   Jan 8, 2019, 7:36:31 AM Sebastian Huber Separate task mode checks Update #3000.
(edit) @feddcde   Jan 8, 2019, 8:08:27 AM Sebastian Huber tests: Remove bogus RTEMS_INTERRUPT_LEVEL(31) It is unnecessary to …
(edit) @fe48400d   Jan 9, 2019, 9:04:01 AM Sebastian Huber libtests/stackchk: Fix for 64-bit targets
(edit) @e4a19f5   Jan 8, 2019, 4:14:21 AM jacobshin313 psxhdrs: Add POSIX API Signature Compliance Tests for errno.h
(edit) @9aee88a   Jan 8, 2019, 1:43:02 PM Sebastian Huber bsp/riscv: Clear boot command line
(edit) @07fb7667   Jan 7, 2019, 12:40:00 PM Sebastian Huber build: Call rtems-ld with the $(CC) of the build This enables support …
(edit) @7802bb9   Jan 7, 2019, 12:35:48 PM Sebastian Huber build: Call rtems-syms with the $(CC) of the build This enables …
(edit) @5b951175   Jan 7, 2019, 1:22:22 PM Jiri Gaisler psxfile01: Fix one second sleep Checking of atime in psxfile01 (line …
(edit) @9c12bcfd   Jan 7, 2019, 8:32:16 AM Sebastian Huber Fix format warnings
(edit) @956d76cc   Jan 7, 2019, 8:30:43 AM Sebastian Huber score: Remove superfluous include from chainimpl.h
(edit) @a7e8996   Dec 21, 2018, 8:09:53 PM Sebastian Huber drvmgr: Improve LP64 compatibility
(edit) @6073c71d   Dec 21, 2018, 8:09:15 PM Sebastian Huber drvmgr: Enable build for riscv
(edit) @8f5abea   Dec 21, 2018, 7:47:06 PM himanshuwindows8.1 psxtmtests: Changed the copyright license to BSD-2-Clause (GCI 2018)
(edit) @c05d7a9d   Dec 21, 2018, 8:43:27 PM Sebastian Huber bsps/sparc: Fix warnings
(edit) @75e1009f   Dec 21, 2018, 8:42:09 PM Sebastian Huber bsps/sparc: Fix typo
(edit) @11f3b9a   Nov 26, 2018, 2:55:38 PM Sebastian Huber bsps/sparc: Add grlib_malloc(), grlib_calloc() This avoids a …
(edit) @8b59916   Dec 21, 2018, 12:31:32 PM Sebastian Huber spcxx01: Add test case
(edit) @c37807e9   Dec 21, 2018, 10:57:26 AM Sebastian Huber bsps/arm: Add cache size support for CP15
(edit) @41a557bc   Dec 21, 2018, 7:39:33 AM Sebastian Huber bsps/arm: Add ARMv7-AR disable data cache Close #3667.
(edit) @b0c2d48   Dec 21, 2018, 6:49:47 AM Sebastian Huber bsps: Add CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA Update #3667.
(edit) @5e0ab02   Dec 21, 2018, 6:46:58 AM Sebastian Huber bsps: Update cache manager documentation Update #3667.
(edit) @a6f70e1   Dec 21, 2018, 6:14:42 AM Sebastian Huber bsps: Remove superfluous comments in cacheimpl.h Remove superfluous …
(edit) @ba85655   Dec 21, 2018, 9:16:02 AM Sebastian Huber ARM_CACHE_L1_CPU_SUPPORT_PROVIDES_RANGE_FUNCTIONS Remove this …
(edit) @750e795   Dec 21, 2018, 6:27:16 AM Sebastian Huber bsps/i386: Enable instruction cache support
(edit) @2158621   Dec 19, 2018, 8:25:29 AM Sebastian Huber Add aligned_alloc() and memalign() Ensure that the C++17 aligned new …
(edit) @10135fa   Dec 20, 2018, 1:26:50 PM thomas.doerfler tftpfs: Some bug fixes Fix for: - tftpfs did not mount, when device …
(edit) @8af51b0   Dec 20, 2018, 8:37:47 PM jacobshin313 psxhdrs: Changing copyright license to BSD-2-Clause
(edit) @9edc558d   Dec 20, 2018, 1:21:40 PM Sebastian Huber bsp/imx: Fix for RAM end at 4GiB
(edit) @6164fd8   Nov 23, 2018, 11:00:35 AM Sebastian Huber Move COPYING file to LICENSE.GPL-2.0 Use the latest plain text …
(edit) @cde5e8d   Dec 11, 2018, 9:15:11 AM Sebastian Huber LICENSE.BSD-2-Clause: Clarify copyright format Update #3053.
(edit) @7c19e50   Dec 18, 2018, 7:45:06 AM Sebastian Huber score: Fix per-CPU data allocation Allocate the per-CPU data for …
(edit) @e7b0a72   Dec 14, 2018, 7:07:08 AM Sebastian Huber config: Remove CONFIGURE_CONFDEFS_DEBUG This configuration option was …
(edit) @cfa82b3   Dec 10, 2018, 6:44:45 PM mcomajoancara psxhdrs: Update licenses to 2-Clause BSD (GCI 2018) Updated licenses …
(edit) @4bd2f802   Dec 13, 2018, 7:23:11 PM himanshuwindows8.1 Some minor fix on psxhdrs
(edit) @c1912df   Dec 13, 2018, 6:13:31 PM himanshuwindows8.1 psxhdrs: Changed the copyright license to BSD-2-Clause (GCI 2018)
(edit) @6b0a729b   Dec 13, 2018, 8:39:20 AM Sebastian Huber build: Remove ampolish3 Update #3254.
(edit) @21275b58   Nov 22, 2018, 6:14:51 PM Sebastian Huber score: Static Objects_Information initialization Statically allocate …
(edit) @0f5b2c09   Dec 10, 2018, 11:51:33 AM Sebastian Huber rtems: Use object information to get config max Use functions instead …
(edit) @8b0e752   Dec 10, 2018, 12:44:53 PM Sebastian Huber score: Remove Objects_Information::auto_extend Use …
(edit) @877048c   Dec 13, 2018, 3:17:25 PM pritishjain2001 psxhdrs: Changed the Copyright license to BSD-2-Clause . The …
(edit) @cb8281f   Dec 13, 2018, 3:42:57 PM jacobshin313 psxhdrs: Add POSIX API Signature Compliance Tests for sys/msg.h (GCI 2018)
(edit) @28f23eb   Dec 13, 2018, 12:46:38 AM jacobshin313 psxhdrs: Add POSIX API Signature Compliance Tests for sys/select.h …
(edit) @86b0ac9   Dec 12, 2018, 3:33:22 PM abhimanyuraghuvanshi29 psxhdrs: Add POSIX Signature Compliance Test for sys/shm.h (GCI 2018)
(edit) @a0353ea2   Dec 12, 2018, 2:23:35 PM abhimanyuraghuvanshi29 POSIX Signature Compliance Test for utmpx.h (GCI2018)
(edit) @0af5ede   Dec 12, 2018, 2:14:40 PM abhimanyuraghuvanshi29 POSIX Signature Compliance Test for sys/statvfs.h (GCI 2018)
(edit) @b770665   Dec 12, 2018, 9:00:10 PM jacobshin313 psxhdrs: Add POSIX API Signature Compliance Tests for net/if.h
(edit) @bf19a9c6   Dec 11, 2018, 2:21:12 AM zenon.hans.taneka psxhdrs/: Changed boilerplate licenses to BSD-2 (GCI 2018)
(edit) @af677c0   Dec 11, 2018, 10:08:59 PM abhimanyuraghuvanshi29 psxhdrs: POSIX API Signature Compliance Test for setjmp.h (GCI2018)
(edit) @6ab788d   Dec 11, 2018, 4:35:38 PM mcomajoancara psxhdrs: Implement POSIX API Signature Compliance Tests for poll.h …
(edit) @484ef98   Dec 11, 2018, 8:47:21 AM pritishjain2001 psxhdrs: Add POSIX Compliance Tests for wordexp.h (GCI 2018)
(edit) @a1eb0a5   Dec 11, 2018, 2:11:10 PM Sebastian Huber posix: Fix shm_unlink() This function is untested.
(edit) @b7a1f9e   Dec 11, 2018, 8:30:59 AM Sebastian Huber psxhdrs: Fix compile errors
(edit) @6179767   Dec 10, 2018, 2:09:41 PM Sebastian Huber Remove white space at end of line Update #3053.
