# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/05/24 02:03:31 Fri, 21 Dec 2007 11:30:36 GMT Ralf Corsepius [f5cc928] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20071221.diff (added) Reflect API changes from newlib-1.16.0 Mon, 17 Dec 2007 07:52:25 GMT Ralf Corsepius [d475f9d] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) Regenerate. Mon, 17 Dec 2007 07:51:52 GMT Ralf Corsepius [e945d6b9] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) Backport from HEAD. Mon, 17 Dec 2007 03:57:46 GMT Ralf Corsepius [50f25ac] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gdb.spec (modified) Sync. Sun, 16 Dec 2007 18:14:09 GMT Ralf Corsepius [7875d408] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) 2007-12-16 Ralf Corsépius * ... Sun, 16 Dec 2007 12:45:35 GMT Ralf Corsepius [ed36c35] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Bump GDB_RPMREL. Sun, 16 Dec 2007 12:45:16 GMT Ralf Corsepius [5dd2ecbb] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gdb-sources.add (modified) gdb-6.6-rtems4.8-20071216.diff. Sun, 16 Dec 2007 12:38:14 GMT Ralf Corsepius [ce195afa] * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20071216.diff (added) New. Sun, 16 Dec 2007 12:37:49 GMT Ralf Corsepius [bd025cde] * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20071110.diff (deleted) * contrib/crossrpms/patches/gdb-6.7.1-rtems4.8-20071031.diff (deleted) Remove. Sun, 16 Dec 2007 12:35:49 GMT Ralf Corsepius [1ecaae4] * contrib/crossrpms/patches/gdb-6.7.1-rtems4.8-20071216.diff (added) Back port from HEAD. Sun, 16 Dec 2007 12:29:29 GMT Ralf Corsepius [16b5fa31] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/cpukit-prep.add (deleted) * contrib/crossrpms/rtems4.8/cpukit.am (deleted) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/cpukit-sources.add (deleted) Remove cpukit. Sun, 16 Dec 2007 12:18:51 GMT Ralf Corsepius [ae8600f] * contrib/crossrpms/gdb/build.add (modified) Add %{?_smp_mflags}. Tue, 11 Dec 2007 23:44:29 GMT Joel Sherrill [49bf16a] * cpukit/ChangeLog (modified) * cpukit/score/src/pheapallocatealigned.c (modified) * cpukit/score/src/pheapgetblocksize.c (modified) 2007-12-11 Joel Sherrill * ... Mon, 10 Dec 2007 04:03:24 GMT Ralf Corsepius [87f08a6] * c/src/lib/libcpu/nios2/.cvsignore (deleted) * c/src/lib/libcpu/nios2/ChangeLog (deleted) * c/src/lib/libcpu/nios2/Makefile.am (deleted) * c/src/lib/libcpu/nios2/configure.ac (deleted) * c/src/lib/libcpu/nios2/preinstall.am (deleted) * c/src/lib/libcpu/nios2/shared/cache/cache.c (deleted) * c/src/lib/libcpu/nios2/shared/cache/cache_.h (deleted) * c/src/lib/libcpu/nios2/shared/misc/memcpy.c (deleted) Remove from rtems-4-8-branch. Mon, 10 Dec 2007 04:00:24 GMT Ralf Corsepius [c3bb8582] * doc/ChangeLog (modified) 2007-12-10 Ralf Corsépius * ... Mon, 10 Dec 2007 03:59:49 GMT Ralf Corsepius [06b8ba0] * doc/cpu_supplement/tic4x.t (deleted) Remove. Mon, 10 Dec 2007 03:59:18 GMT Ralf Corsepius [3402633] * doc/cpu_supplement/Makefile.am (modified) * doc/cpu_supplement/cpu_supplement.texi (modified) 2007-12-10 Ralf Corsépius * ... Mon, 10 Dec 2007 03:44:06 GMT Ralf Corsepius [372cdd51] * doc/tools/bmenu/ChangeLog (modified) * doc/tools/bmenu/Makefile.am (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/isr.h (deleted) * doc/tools/bmenu/system.h (modified) 2007-12-10 Ralf Corsepius * ... Thu, 06 Dec 2007 15:18:42 GMT Joel Sherrill [aa56c201] * cpukit/ChangeLog (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/httpd/preinstall.am (modified) 2007-12-06 Joel Sherrill * ... Thu, 06 Dec 2007 14:21:05 GMT Joel Sherrill [2e3199e] * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/shared/include/grcan_spwrtc.h (deleted) 2007-12-06 Joel Sherrill * ... Wed, 05 Dec 2007 15:49:40 GMT Joel Sherrill [1b0c3e6c] * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c (added) * c/src/lib/libbsp/sparc/shared/include/i2cmst.h (added) 2007-12-05 Daniel Hellstrom * ... Wed, 05 Dec 2007 15:49:38 GMT Joel Sherrill [7e15770] * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) 2007-12-05 Daniel Hellstrom * ... Wed, 05 Dec 2007 15:41:28 GMT Joel Sherrill [e5ce943] * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp.h (modified) 2007-12-05 Daniel Hellstrom * ... Wed, 05 Dec 2007 09:37:57 GMT Ralf Corsepius [8ffd6be0] * cpukit/ChangeLog (modified) 2007-12-05 Ralf Corsépius * ... Wed, 05 Dec 2007 09:37:49 GMT Ralf Corsepius [dea5bb9] * cpukit/configure.ac (modified) Remove score/cpu/avr/Makefile, score/cpu/nios2/Makefile, ... Wed, 05 Dec 2007 09:37:28 GMT Ralf Corsepius [76fb8a6] * cpukit/score/cpu/Makefile.am (modified) Remove avr, nios2, c4x. Wed, 05 Dec 2007 05:14:05 GMT Ralf Corsepius [abc81aa7] * tools/cpu/ChangeLog (modified) 2007-12-05 Ralf Corsépius * ... Wed, 05 Dec 2007 05:13:18 GMT Ralf Corsepius [54e05e1] * tools/cpu/configure.ac (modified) Remove nios2. Wed, 05 Dec 2007 05:12:33 GMT Ralf Corsepius [bec1af0] * tools/cpu/nios2/.cvsignore (deleted) * tools/cpu/nios2/ChangeLog (deleted) * tools/cpu/nios2/Makefile.am (deleted) * tools/cpu/nios2/README (deleted) * tools/cpu/nios2/bridges.c (deleted) * tools/cpu/nios2/bridges.h (deleted) * tools/cpu/nios2/clocks.c (deleted) * tools/cpu/nios2/clocks.h (deleted) * tools/cpu/nios2/configure.ac (deleted) * tools/cpu/nios2/devices.c (deleted) * tools/cpu/nios2/devices.h (deleted) * tools/cpu/nios2/linkcmds.c (deleted) * tools/cpu/nios2/linkcmds.h (deleted) * tools/cpu/nios2/memory.c (deleted) * tools/cpu/nios2/memory.h (deleted) * tools/cpu/nios2/nios2gen.c (deleted) * tools/cpu/nios2/output.c (deleted) * tools/cpu/nios2/output.h (deleted) * tools/cpu/nios2/ptf.c (deleted) * tools/cpu/nios2/ptf.h (deleted) * tools/cpu/nios2/sample.ptf (deleted) Remove from rtems-4-8-branch. Tue, 04 Dec 2007 16:27:14 GMT Ralf Corsepius [ad8f26a] * make/Makefile.am (modified) * make/custom/c3xsim.cfg (deleted) * make/custom/c4xsim.cfg (deleted) * make/custom/nios2_iss.cfg (deleted) Remove nios, tic4x family BSPs. Tue, 04 Dec 2007 16:24:06 GMT Ralf Corsepius [ccdfdb20] * contrib/crossrpms/configure.ac (modified) Remove tic4x, avr. Tue, 04 Dec 2007 16:23:21 GMT Ralf Corsepius [3753b007] * contrib/crossrpms/rtems4.8/Makefile.am (modified) Remove tic4x, avr from rtems-4-8-branch. Tue, 04 Dec 2007 16:22:31 GMT Ralf Corsepius [29cce4be] * c/src/lib/libbsp/c4x/.cvsignore (deleted) * c/src/lib/libbsp/c4x/ChangeLog (deleted) * c/src/lib/libbsp/c4x/Makefile.am (deleted) * c/src/lib/libbsp/c4x/acinclude.m4 (deleted) * c/src/lib/libbsp/c4x/c4xsim/.cvsignore (deleted) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (deleted) * c/src/lib/libbsp/c4x/c4xsim/Makefile.am (deleted) * c/src/lib/libbsp/c4x/c4xsim/README (deleted) * c/src/lib/libbsp/c4x/c4xsim/bsp_specs (deleted) * c/src/lib/libbsp/c4x/c4xsim/clock/clock.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/console.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/consolereserveresources.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/debugio.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/console/simio.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/.cvsignore (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/bsp.h (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/simio.h (deleted) * c/src/lib/libbsp/c4x/c4xsim/include/tm27.h (deleted) * c/src/lib/libbsp/c4x/c4xsim/preinstall.am (deleted) * c/src/lib/libbsp/c4x/c4xsim/start/start.S (deleted) * c/src/lib/libbsp/c4x/c4xsim/startup/bspstart.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/startup/linkcmds (deleted) * c/src/lib/libbsp/c4x/c4xsim/startup/spurious.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/timer/timer.c (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/.cvsignore (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/Makefile.am (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (deleted) * c/src/lib/libbsp/c4x/c4xsim/tools/runtest.in (deleted) * c/src/lib/libbsp/c4x/configure.ac (deleted) * c/src/lib/libbsp/c4x/shared/bspspuriousinit.c (deleted) * c/src/lib/libbsp/c4x/shared/c3xspurious.c (deleted) * c/src/lib/libbsp/c4x/shared/c4xspurious.c (deleted) * c/src/lib/libbsp/nios2/.cvsignore (deleted) * c/src/lib/libbsp/nios2/ChangeLog (deleted) * c/src/lib/libbsp/nios2/Makefile.am (deleted) * c/src/lib/libbsp/nios2/README (deleted) * c/src/lib/libbsp/nios2/acinclude.m4 (deleted) * c/src/lib/libbsp/nios2/configure.ac (deleted) * c/src/lib/libbsp/nios2/nios2_iss/.cvsignore (deleted) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (deleted) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (deleted) * c/src/lib/libbsp/nios2/nios2_iss/bsp_specs (deleted) * c/src/lib/libbsp/nios2/nios2_iss/clock/clock.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (deleted) * c/src/lib/libbsp/nios2/nios2_iss/console/console.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/include/.cvsignore (deleted) * c/src/lib/libbsp/nios2/nios2_iss/include/bsp.h (deleted) * c/src/lib/libbsp/nios2/nios2_iss/include/coverhd.h (deleted) * c/src/lib/libbsp/nios2/nios2_iss/include/tm27.h (deleted) * c/src/lib/libbsp/nios2/nios2_iss/nios2_iss.ptf (deleted) * c/src/lib/libbsp/nios2/nios2_iss/nios2_iss.sh (deleted) * c/src/lib/libbsp/nios2/nios2_iss/preinstall.am (deleted) * c/src/lib/libbsp/nios2/nios2_iss/shmsupp/addrconv.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/shmsupp/getcfg.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/shmsupp/lock.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/shmsupp/mpisr.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/start/crtnn.s (deleted) * c/src/lib/libbsp/nios2/nios2_iss/start/start.S (deleted) * c/src/lib/libbsp/nios2/nios2_iss/startup/bspclean.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/startup/bspstart.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/startup/linkcmds (deleted) * c/src/lib/libbsp/nios2/nios2_iss/startup/main.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/startup/setvec.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c (deleted) * c/src/lib/libbsp/nios2/nios2_iss/times (deleted) * contrib/crossrpms/rtems4.8/avr/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/avr/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (deleted) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (deleted) * contrib/crossrpms/rtems4.8/tic4x/.cvsignore (deleted) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (deleted) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/cpukit-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (deleted) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (deleted) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (deleted) Remove from rtems-4-8-branch. Tue, 04 Dec 2007 16:15:55 GMT Ralf Corsepius [8abda651] * ChangeLog (modified) Revert previous change. Tue, 04 Dec 2007 16:15:22 GMT Ralf Corsepius [01a9d2c3] * cpukit/ChangeLog (modified) 2007-10-15 Ralf Corsépius * ... Tue, 04 Dec 2007 16:14:51 GMT Ralf Corsepius [be39e03] * ChangeLog (modified) 2007-12-04 Ralf Corsépius * ... Tue, 04 Dec 2007 16:13:25 GMT Ralf Corsepius [1992eff9] * cpukit/score/cpu/avr/.cvsignore (deleted) * cpukit/score/cpu/avr/ChangeLog (deleted) * cpukit/score/cpu/avr/Makefile.am (deleted) * cpukit/score/cpu/avr/README (deleted) * cpukit/score/cpu/avr/cpu.c (deleted) * cpukit/score/cpu/avr/cpu_asm.c (deleted) * cpukit/score/cpu/avr/preinstall.am (deleted) * cpukit/score/cpu/avr/rtems/asm.h (deleted) * cpukit/score/cpu/avr/rtems/score/avr.h (deleted) * cpukit/score/cpu/avr/rtems/score/cpu.h (deleted) * cpukit/score/cpu/avr/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/avr/rtems/score/types.h (deleted) * cpukit/score/cpu/c4x/.cvsignore (deleted) * cpukit/score/cpu/c4x/ChangeLog (deleted) * cpukit/score/cpu/c4x/Makefile.am (deleted) * cpukit/score/cpu/c4x/cpu.c (deleted) * cpukit/score/cpu/c4x/cpu_asm.S (deleted) * cpukit/score/cpu/c4x/irq.c (deleted) * cpukit/score/cpu/c4x/preinstall.am (deleted) * cpukit/score/cpu/c4x/rtems/asm.h (deleted) * cpukit/score/cpu/c4x/rtems/score/c4x.h (deleted) * cpukit/score/cpu/c4x/rtems/score/cpu.h (deleted) * cpukit/score/cpu/c4x/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/c4x/rtems/score/types.h (deleted) * cpukit/score/cpu/c4x/rtems/tic4x/c4xio.h (deleted) * cpukit/score/cpu/nios2/.cvsignore (deleted) * cpukit/score/cpu/nios2/ChangeLog (deleted) * cpukit/score/cpu/nios2/Makefile.am (deleted) * cpukit/score/cpu/nios2/cpu.c (deleted) * cpukit/score/cpu/nios2/cpu_asm.S (deleted) * cpukit/score/cpu/nios2/irq.c (deleted) * cpukit/score/cpu/nios2/preinstall.am (deleted) * cpukit/score/cpu/nios2/rtems/asm.h (deleted) * cpukit/score/cpu/nios2/rtems/score/cpu.h (deleted) * cpukit/score/cpu/nios2/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/nios2/rtems/score/nios2.h (deleted) * cpukit/score/cpu/nios2/rtems/score/types.h (deleted) Remove from rtems-4-8-branch. Fri, 30 Nov 2007 23:00:05 GMT Joel Sherrill [e1cc416] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/GT64260Int.c (deleted) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/Makefile.am (deleted) * c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/Makefile.am (deleted) 2007-11-30 Joel Sherrill * ... Fri, 30 Nov 2007 18:17:44 GMT Joel Sherrill [38f3ce5] * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) 2007-11-30 Joel Sherrill * ... Fri, 30 Nov 2007 16:53:44 GMT Joel Sherrill [b25b7da8] * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/shared/include/grspw.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) 2007-11-30 Daniel Hellstrom * ... Fri, 30 Nov 2007 16:52:23 GMT Joel Sherrill [125d4c61] * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/shared/can/occan.c (modified) 2007-11-30 Daniel Hellstrom * ... Fri, 30 Nov 2007 16:51:10 GMT Joel Sherrill [0cec037] * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/rasta/rasta.c (modified) 2007-11-30 Daniel Hellstrom * ... Fri, 30 Nov 2007 16:48:06 GMT Joel Sherrill [d805da0e] * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp.h (modified) 2007-11-30 Daniel Hellstrom * ... Fri, 30 Nov 2007 06:02:22 GMT Ralf Corsepius [cf148c7] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) Regnerate. Fri, 30 Nov 2007 06:00:40 GMT Ralf Corsepius [b32338ab] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) GCC_RPMREL = 27. Thu, 29 Nov 2007 17:24:15 GMT Ralf Corsepius [afb21a9] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Upgrade to gcc-4.2.2 Thu, 29 Nov 2007 17:20:26 GMT Ralf Corsepius [eb5b37d] * contrib/crossrpms/patches/gcc-core-4.2.2-rtems4.8-20071127.diff (added) Copy from CVS-HEAD/rtems-4.9 Thu, 29 Nov 2007 16:13:32 GMT Glenn Humphrey [fc121ce] * doc/ChangeLog (modified) * doc/develenv/direct.t (modified) * doc/develenv/sample.t (modified) 2007-11-29 Glenn Humphrey ... Thu, 29 Nov 2007 13:38:44 GMT Ralf Corsepius [b5273f0] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) gcc-core-4.2.1-rtems4.8-20071129. Thu, 29 Nov 2007 13:37:27 GMT Ralf Corsepius [385451b] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20071129.diff (added) Backport from CVS-HEAD/rtems-4.9 Wed, 28 Nov 2007 21:15:35 GMT Joel Sherrill [f52af24] * make/ChangeLog (modified) * make/custom/mvme5500.cfg (modified) 2007-11-28 Joel Sherrill * ... Wed, 28 Nov 2007 16:24:39 GMT Glenn Humphrey [ef47c44f] * doc/ChangeLog (modified) * doc/user/barrier.t (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/datatypes.t (modified) * doc/user/dpmem.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) 2007-11-28 Glenn Humphrey ... Tue, 27 Nov 2007 21:23:13 GMT Glenn Humphrey [bd58b13] * c/src/ada/ChangeLog (modified) * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) 2007-11-27 Glenn Humphrey ... Tue, 27 Nov 2007 20:47:15 GMT Joel Sherrill [32daf5d] * make/ChangeLog (modified) * make/custom/mvme5500.cfg (modified) 2007-11-27 Kate Feng * ... Tue, 27 Nov 2007 20:42:42 GMT Glenn Humphrey [a74aefe] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp33/init.c (modified) * testsuites/sptests/sp33/sp33.scn (modified) 2007-11-27 Glenn Humphrey ... Tue, 27 Nov 2007 20:13:09 GMT Glenn Humphrey [7301b37] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psxbarrier01/psxbarrier01.scn (modified) * testsuites/psxtests/psxbarrier01/test.c (modified) * testsuites/psxtests/psxrwlock01/psxrwlock01.scn (modified) * testsuites/psxtests/psxrwlock01/test.c (modified) 2007-11-27 Glenn Humphrey ... Tue, 27 Nov 2007 19:30:59 GMT Joel Sherrill [d9779bd] * doc/ChangeLog (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.t (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.t (modified) * doc/develenv/utils.t (modified) 2007-11-27 Joel Sherrill * ... Tue, 27 Nov 2007 18:45:03 GMT Glenn Humphrey [5d55a0b] * cpukit/ChangeLog (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/rtems/include/rtems/rtems/barrier.h (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) 2007-11-27 Glenn Humphrey ... Tue, 27 Nov 2007 15:36:18 GMT Joel Sherrill [6bca11e] * doc/ChangeLog (modified) * doc/user/conf.t (modified) 2007-11-27 Joel Sherrill * ... Tue, 27 Nov 2007 15:36:12 GMT Joel Sherrill [4b650b58] * cpukit/ChangeLog (modified) * cpukit/sapi/include/confdefs.h (modified) 2007-11-27 Joel Sherrill * ... Mon, 26 Nov 2007 22:09:45 GMT Joel Sherrill [325a4df0] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) 2007-11-26 Joel Sherrill * ... Mon, 26 Nov 2007 21:53:16 GMT Joel Sherrill [7fd0bc4] * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c (modified) 2007-11-26 Joel Sherrill * ... Mon, 26 Nov 2007 21:53:14 GMT Joel Sherrill [0519e2c1] * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) 2007-11-26 Joel Sherrill * ... Mon, 26 Nov 2007 21:13:35 GMT Joel Sherrill [c4254e9] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/printk.c (modified) * cpukit/score/src/objectget.c (modified) 2007-11-26 Joel Sherrill * ... Mon, 26 Nov 2007 21:13:02 GMT Joel Sherrill [8802a9b] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/malloc.c (modified) 2007-11-26 Joel Sherrill * ... Mon, 26 Nov 2007 19:46:24 GMT Joel Sherrill [3a9e70c] * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (modified) 2007-11-26 Joel Sherrill * ... Mon, 26 Nov 2007 19:35:48 GMT Joel Sherrill [e2f429f] * cpukit/ChangeLog (modified) * cpukit/score/include/rtems/score/thread.h (modified) 2007-11-26 Joel Sherrill * ... Mon, 26 Nov 2007 19:34:21 GMT Joel Sherrill [8545a7ea] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.c (modified) 2007-11-26 Joel Sherrill * ... Mon, 26 Nov 2007 17:48:39 GMT Joel Sherrill [5cc0c0d3] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/network/network.c (modified) 2007-11-26 Eric Norum * ... Thu, 15 Nov 2007 04:38:18 GMT Ralf Corsepius [08988b7] * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070216.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070405.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.2-rtems4.8-20070613.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2-20070221-rtems4.8-20070228.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.0-rtems4.8-20070515.diff (deleted) * contrib/crossrpms/patches/gdb-6.5-rtems-20060713.diff (deleted) * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20070306.diff (deleted) * contrib/crossrpms/patches/gdb-6.7-rtems4.8-20071011.diff (deleted) Remove. Wed, 14 Nov 2007 14:37:33 GMT Ralf Corsepius [27de0e70] * contrib/crossrpms/rtems4.8/bfin/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (modified) Update. Wed, 14 Nov 2007 14:35:06 GMT Ralf Corsepius [72c04e8] * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060720.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060908.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems-20060909.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070102.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070131.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.1.1-rtems4.8-20070201.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.0-20070501-rtems4.8-20070501.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.2.0-rtems4.8-20070613.diff (deleted) * contrib/crossrpms/patches/gdb-6.5-bfinrtems-20060810a.diff (deleted) Remove. Tue, 13 Nov 2007 15:09:07 GMT Ralf Corsepius [6dba71e] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-gcc.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-gcc.spec (modified) backup. Tue, 13 Nov 2007 09:29:15 GMT Ralf Corsepius [02058598] * contrib/crossrpms/gcc/target-gcc.add (modified) Backport from HEAD. Tue, 13 Nov 2007 09:26:55 GMT Ralf Corsepius [be4e5f69] * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) GCC_RPMREL = 14. Tue, 13 Nov 2007 09:26:17 GMT Ralf Corsepius [fc98297] * contrib/crossrpms/patches/gcc-core-3.4.6-rtems4.8-20071111.diff (added) New. Sun, 11 Nov 2007 16:58:15 GMT Ralf Corsepius [425cb26] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20071111.diff (modified) More makeinfo hacks. Sun, 11 Nov 2007 13:19:55 GMT Ralf Corsepius [484d126] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20071111.diff (added) New. Sun, 11 Nov 2007 13:19:12 GMT Ralf Corsepius [e55f7f7] * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) Remove gcc-3.4.6. Sun, 11 Nov 2007 13:17:20 GMT Ralf Corsepius [3254133] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Remove gcc-4.2.0. Sun, 11 Nov 2007 13:16:07 GMT Ralf Corsepius [02e1bdb] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Remove gcc-4.0.3. Sun, 11 Nov 2007 13:14:31 GMT Ralf Corsepius [a3459e8] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Remove gcc-4.1.2. Sun, 11 Nov 2007 13:13:51 GMT Ralf Corsepius [501a675a] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Remove gcc-4.1.1. Sun, 11 Nov 2007 13:11:41 GMT Ralf Corsepius [78945895] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) gcc-core-4.2.1-rtems4.8-20071111.diff. Sun, 11 Nov 2007 13:11:05 GMT Ralf Corsepius [4ee3225] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) GCC_RPMREL = 25. Sat, 10 Nov 2007 07:05:17 GMT Ralf Corsepius [cfa08cf] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/mipstx39/rtems-4.8-mipstx39-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-gdb.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-gdb.spec (modified) Regenerate. Sat, 10 Nov 2007 07:04:57 GMT Ralf Corsepius [2b6a100] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) gdb-6.6-rtems4.8-20071110.diff Sat, 10 Nov 2007 07:03:42 GMT Ralf Corsepius [70a276a] * contrib/crossrpms/patches/gdb-6.6-rtems4.8-20071110.diff (added) New. Sat, 10 Nov 2007 07:02:16 GMT Ralf Corsepius [4256152] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) GDB_RPMREL = 10 Sat, 10 Nov 2007 05:47:54 GMT Ralf Corsepius [116826e7] * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (deleted) Remove (Unused). Sat, 10 Nov 2007 05:46:40 GMT Ralf Corsepius [66a55224] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) Remove gdb-6.5 Sat, 10 Nov 2007 05:43:14 GMT Ralf Corsepius [001c1508] * contrib/crossrpms/rtems4.8/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/mipstx39/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gdb-sources.add (modified) Update gdb-6.6 patch. Tue, 06 Nov 2007 21:38:58 GMT Joel Sherrill [57a483cf] * cpukit/ChangeLog (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keyrundestructors.c (modified) 2007-11-06 Joel Sherrill ... Tue, 06 Nov 2007 20:23:01 GMT Joel Sherrill [2a656265] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp13/system.h (modified) 2007-11-06 Joel Sherrill * ... Tue, 06 Nov 2007 19:54:22 GMT Glenn Humphrey [22112254] * cpukit/ChangeLog (modified) * cpukit/posix/src/pbarrierinit.c (modified) * cpukit/posix/src/prwlockdestroy.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/pspinlocktranslatereturncode.c (modified) * cpukit/score/include/rtems/score/corespinlock.h (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corespinlockrelease.c (modified) 2007-11-06 Glenn Humphrey ... Sun, 04 Nov 2007 09:36:15 GMT Ralf Corsepius [0e95f1e] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (modified) Regenerate. Sun, 04 Nov 2007 09:34:49 GMT Ralf Corsepius [7d1ca2a] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) BINUTILS_RPMREL = 2. Sun, 04 Nov 2007 09:34:31 GMT Ralf Corsepius [6dc54314] * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (modified) binutils-2.18-rtems4.8-20071104.diff. Sun, 04 Nov 2007 09:31:43 GMT Ralf Corsepius [7eb30458] * contrib/crossrpms/patches/binutils-2.18-rtems4.8-20071104.diff (added) New. Fri, 02 Nov 2007 13:35:12 GMT Joel Sherrill [334573e3] * cpukit/ChangeLog (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/src/threadhandler.c (modified) 2007-11-02 Joel Sherrill * ...
