# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 18:47:05 Fri, 03 Apr 2009 12:53:02 GMT Ralf Corsepius [eae45e23] * testsuites/tmitrontests/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:51:19 GMT Ralf Corsepius [230c879] * testsuites/tmtests/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:48:04 GMT Ralf Corsepius [8e1f626] * testsuites/sptests/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:46:29 GMT Ralf Corsepius [1f52d0e] * testsuites/libtests/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:45:33 GMT Ralf Corsepius [d024b773] * testsuites/itrontests/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:44:48 GMT Ralf Corsepius [b9665ca] * testsuites/psxtests/ChangeLog (modified) 2009-04-03 Ralf Corsépius ... Fri, 03 Apr 2009 12:43:50 GMT Ralf Corsepius [3414f307] * testsuites/samples/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:43:40 GMT Ralf Corsepius [dea3a9ca] * testsuites/ChangeLog (modified) * testsuites/aclocal/prog-cc.m4 (modified) 2009-04-03 Ralf Corsépius * ... Thu, 02 Apr 2009 11:49:51 GMT Ralf Corsepius [52f8e7aa] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-rtems-debug.m4 (modified) 2009-04-02 Ralf Corsépius * ... Mon, 30 Mar 2009 17:05:23 GMT Joel Sherrill [9eab99a] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/symlink.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) 2009-03-30 Sebastian Huber ... Mon, 30 Mar 2009 17:05:04 GMT Joel Sherrill [9fb97de] * doc/ChangeLog (modified) * doc/shell/confinit.t (modified) 2009-03-30 Sebastian Huber ... Mon, 30 Mar 2009 14:10:54 GMT Joel Sherrill [7c48db8d] * c/src/lib/libbsp/lm32/lm32_evr/ChangeLog (modified) * c/src/lib/libbsp/lm32/lm32_evr/startup/linkcmds (modified) 2009-03-30 Joel Sherrill * ... Mon, 30 Mar 2009 05:55:09 GMT Ralf Corsepius [241a259d] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Mon, 30 Mar 2009 05:54:34 GMT Ralf Corsepius [68946ac7] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Mon, 30 Mar 2009 05:52:23 GMT Ralf Corsepius [e8b6f1e5] * contrib/crossrpms/gcc/install.add (modified) Also remove @tool_target@/include/bits for c-only targets. Sun, 29 Mar 2009 23:14:58 GMT Joel Sherrill [6dcb3b0] * testsuites/samples/fileio/init.c (modified) Fix Id string typo. Sun, 29 Mar 2009 23:04:19 GMT Joel Sherrill [06ac2e6f] * testsuites/samples/ChangeLog (modified) * testsuites/samples/fileio/init.c (modified) 2009-03-29 Joel Sherrill * ... Sun, 29 Mar 2009 04:49:10 GMT Ralf Corsepius [006eafe] * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) Update to gdb-6.8.50.20090329 Sun, 29 Mar 2009 03:28:22 GMT Ralf Corsepius [49a5e79] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Sun, 29 Mar 2009 03:27:15 GMT Ralf Corsepius [88ad0c9] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Sun, 29 Mar 2009 03:26:22 GMT Ralf Corsepius [0539334d] * contrib/crossrpms/gcc/install.add (modified) rmdir ${RPM_BUILD_ROOT}%{_prefix}/@tool_target@/include/bits Fri, 27 Mar 2009 15:31:52 GMT Joel Sherrill [2649eef] * cpukit/libmisc/shell/login.h (added) * cpukit/libmisc/shell/login_check.c (added) * cpukit/libmisc/shell/login_prompt.c (added) 2009-03-27 Sebastian Huber ... Fri, 27 Mar 2009 13:45:31 GMT Joel Sherrill [8a775c27] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/libcsupport/src/libio_sockets.c (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libnetworking/rtems/ftpfs.h (modified) * cpukit/preinstall.am (modified) * cpukit/telnetd/check_passwd.c (modified) * cpukit/telnetd/telnetd.c (modified) * cpukit/telnetd/telnetd.h (modified) 2009-03-27 Sebastian Huber ... Thu, 26 Mar 2009 14:11:53 GMT Thomas Doerfler [8916bdc7] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/main_mount_ftp.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/rtems/ftpfs.h (modified) * libmisc/shell/shell.h: Pointer to oparations table for ... Thu, 26 Mar 2009 11:18:03 GMT Joel Sherrill [d785ce4a] * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/console/console.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/linkcmds (modified) 2009-03-26 Joel Sherrill * ... Wed, 25 Mar 2009 17:56:04 GMT Joel Sherrill [8b074ee6] * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds (modified) 2009-03-25 Joel Sherrill * ... Thu, 19 Mar 2009 10:49:55 GMT Thomas Doerfler [ce7d6e62] * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/hwreg_vals.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/cpuinit.c (modified) * start/start.S, include/hwreg_vals.h, startup/cpuinit.c: ... Thu, 12 Mar 2009 21:13:15 GMT Joel Sherrill [434bc85b] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) 2009-03-12 Santosh G Vattam ... Thu, 12 Mar 2009 15:42:51 GMT Joel Sherrill [a33af586] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-memdrv.c (modified) 2009-03-12 Daniel Hellstrom PR ... Thu, 12 Mar 2009 15:34:29 GMT Joel Sherrill [47261f4] * cpukit/ChangeLog (modified) * cpukit/ftpd/ftpd.h (modified) 2009-03-12 Joel Sherrill * ... Thu, 12 Mar 2009 15:32:58 GMT Joel Sherrill [a1bc6751] * cpukit/ChangeLog (modified) * cpukit/posix/src/mutextranslatereturncode.c (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:33:14 GMT Joel Sherrill [f0a90bb] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_asm.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:33:05 GMT Joel Sherrill [b321b10e] * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:18:32 GMT Joel Sherrill [01d1ae3] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:18:28 GMT Joel Sherrill [1ba9d1bb] * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq_asm.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:18:21 GMT Joel Sherrill [d2c730f8] * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/startup/exception.S (modified) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/exception.S (modified) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/startup/exception.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:16:50 GMT Joel Sherrill [0067feb] * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/cpu_asm.S (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/cpu_asm.S (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 09:01:09 GMT Ralf Corsepius [fb0a7e9] * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) Regenerate. Thu, 12 Mar 2009 09:00:39 GMT Ralf Corsepius [c6c6b00] * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) gdb-6.8-rtems4.10-20090312.diff Thu, 12 Mar 2009 09:00:21 GMT Ralf Corsepius [d0e1a7f6] * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) Bump GDB_RPMREL. Thu, 12 Mar 2009 08:59:26 GMT Ralf Corsepius [4022445] * contrib/crossrpms/patches/gdb-6.8-rtems4.10-20090312.diff (added) Add psim/configure. Wed, 11 Mar 2009 17:27:01 GMT Ralf Corsepius [d0b8001] * cpukit/libcsupport/src/__assert.c (modified) Conditionally build __assert(). Wed, 11 Mar 2009 17:26:47 GMT Ralf Corsepius [d020f6f] * cpukit/configure.ac (modified) Check for __assert(). Wed, 11 Mar 2009 17:26:27 GMT Ralf Corsepius [947e877] * cpukit/ChangeLog (modified) Fix typo. Wed, 11 Mar 2009 17:25:54 GMT Ralf Corsepius [986f39b3] * cpukit/ChangeLog (modified) 2009-03-11 Ralf Corsépius * ... Wed, 11 Mar 2009 08:48:22 GMT Ralf Corsepius [c033221] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Wed, 11 Mar 2009 08:45:05 GMT Ralf Corsepius [cf3e180] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.17.0-rtems4.10-20090311.diff. Wed, 11 Mar 2009 08:44:37 GMT Ralf Corsepius [2eb41aee] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Wed, 11 Mar 2009 08:41:22 GMT Ralf Corsepius [9e3d90d] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090311.diff (added) Address __assert etc. Tue, 10 Mar 2009 17:40:06 GMT Joel Sherrill [96f2d87] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) 2009-03-10 Eric Norum * ... Tue, 10 Mar 2009 10:56:03 GMT Ralf Corsepius [aab8725] * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) Disable sim on mingw32. Tue, 10 Mar 2009 10:55:03 GMT Ralf Corsepius [8e5d175] * contrib/crossrpms/gdb/gdb.add (modified) Disable m32c simulator. Tue, 10 Mar 2009 09:38:36 GMT Ralf Corsepius [f29c64b] * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) Upgrade to gdb-6.8.50 Tue, 10 Mar 2009 07:13:19 GMT Ralf Corsepius [d2730232] * cpukit/ChangeLog (modified) 2009-03-10 Ralf Corsépius * ... Tue, 10 Mar 2009 07:13:08 GMT Ralf Corsepius [a746013] * cpukit/configure.ac (modified) Check for creat(). Tue, 10 Mar 2009 07:12:50 GMT Ralf Corsepius [0ba07a0] * cpukit/libcsupport/src/creat.c (modified) Build conditionally. Mon, 09 Mar 2009 17:00:20 GMT Joel Sherrill [cdb6eae] * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/bsp.h (modified) 2009-03-09 Sebastian Huber ... Mon, 09 Mar 2009 16:53:27 GMT Joel Sherrill [94da794] * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) 2009-03-09 Antoine Lacroix ... Mon, 09 Mar 2009 14:11:23 GMT Joel Sherrill [f855b9e3] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) 2009-03-09 Joel Sherrill ... Mon, 09 Mar 2009 13:57:53 GMT Ralf Corsepius [57224657] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090309.diff (modified) Update. Mon, 09 Mar 2009 12:40:23 GMT Ralf Corsepius [59369291] * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) Bump release. Mon, 09 Mar 2009 12:37:55 GMT Ralf Corsepius [0c614d16] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090309.diff (added) newlib/libc/machine/powerpc/times.c: Remove. Fri, 06 Mar 2009 20:08:20 GMT Joel Sherrill [17175bbd] * cpukit/ChangeLog (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) 2009-03-06 Joel Sherrill * ... Thu, 05 Mar 2009 22:27:19 GMT Eric Norum [ac4dd0b] * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) With Till, Joel and Eric all trying to fix this file things seem to ... Thu, 05 Mar 2009 21:17:55 GMT Till Straumann [05b0c8a] * c/src/lib/libbsp/powerpc/mvme3100/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/start/start.S (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) 2009-03-05 Till Straumann ... Thu, 05 Mar 2009 21:15:17 GMT Till Straumann [0f2852d] * c/src/lib/libbsp/powerpc/mvme3100/ChangeLog (modified) 2009-03-05 Till Straumann ... Thu, 05 Mar 2009 21:10:07 GMT Till Straumann [b0d9310] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) 2009-03-05 Till Straumann ... Thu, 05 Mar 2009 21:07:01 GMT Till Straumann [6987eecc] * c/src/lib/libbsp/powerpc/mvme3100/flash/flashcfg.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c (modified) 2009-03-05 Till Straumann ... Thu, 05 Mar 2009 21:05:13 GMT Till Straumann [7e7f6d7] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.h (modified) 2009-03-05 Till Straumann ... Thu, 05 Mar 2009 20:09:59 GMT Till Straumann [ad82bec] * c/src/lib/libbsp/powerpc/shared/startup/sbrk.c (modified) - must return original memory size in *heap_size_p if policy == -1 Thu, 05 Mar 2009 13:45:06 GMT Thomas Doerfler [21ae805] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) * shared/clock/clock.c: Standard decrementer exception is now more ... Thu, 05 Mar 2009 12:16:22 GMT Joel Sherrill [eb7ee96] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) 2009-03-05 Sebastian Huber ... Tue, 03 Mar 2009 12:20:30 GMT Joel Sherrill [b96bd98] * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/console/console.c (modified) 2009-03-02 Joel Sherrill * ... Tue, 03 Mar 2009 00:10:56 GMT Joel Sherrill [f0f8e4de] * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/include/bsp.h (modified) * c/src/lib/libbsp/nios2/nios2_iss/preinstall.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/setvec.c (modified) 2009-03-02 Joel Sherrill * ... Mon, 02 Mar 2009 18:57:11 GMT Joel Sherrill [188a3fc] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) 2009-03-02 Till Straumann ... Mon, 02 Mar 2009 18:34:12 GMT Joel Sherrill [b7f49f7] * cpukit/score/cpu/nios2/ChangeLog (modified) * cpukit/score/cpu/nios2/cpu_asm.S (modified) 2009-03-02 Joel Sherrill * ... Mon, 02 Mar 2009 18:10:34 GMT Joel Sherrill [7246c8e9] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/protectedheap.h (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/src/pheapgetsize.c (added) 2009-03-02 Joel Sherrill * ... Mon, 02 Mar 2009 17:28:28 GMT Joel Sherrill [6387939] * testsuites/samples/ChangeLog (modified) * testsuites/samples/cdtest/main.cc (modified) 2009-03-02 Joel Sherrill * ... Mon, 02 Mar 2009 17:27:54 GMT Joel Sherrill [27d29e18] * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds (modified) 2009-03-02 Daniel Hellstrom PR ... Mon, 02 Mar 2009 17:10:31 GMT Joel Sherrill [bdc8d46] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/shared/irq/irq_asm.S (modified) 2009-03-02 Ray Xu * ... Mon, 02 Mar 2009 17:03:10 GMT Joel Sherrill [b9005867] * c/src/lib/libbsp/arm/rtl22xx/ChangeLog (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) 2009-03-02 Ray Xu PR 1380/bsps ... Mon, 02 Mar 2009 16:12:49 GMT Joel Sherrill [8c324aa] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/sp09.scn (modified) 2009-03-02 Joel Sherrill ... Mon, 02 Mar 2009 16:12:41 GMT Joel Sherrill [e93d791] * cpukit/ChangeLog (modified) * cpukit/rtems/src/semcreate.c (modified) 2009-03-02 Joel Sherrill ... Mon, 02 Mar 2009 15:04:02 GMT Joel Sherrill [657d23e] * doc/ChangeLog (modified) * doc/user/.cvsignore (modified) 2009-03-02 Joel Sherrill * ... Mon, 02 Mar 2009 12:12:17 GMT Joel Sherrill [f547bc8] * cpukit/score/cpu/nios2/ChangeLog (modified) * cpukit/score/cpu/nios2/cpu.c (modified) 2009-03-02 Joel Sherrill * ... Fri, 27 Feb 2009 19:19:46 GMT Joel Sherrill [eb148a26] * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.S (deleted) 2009-02-27 Joel Sherrill * ... Fri, 27 Feb 2009 18:19:33 GMT Joel Sherrill [fd234b8] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) 2009-02-27 Joel Sherrill * ... Fri, 27 Feb 2009 18:04:44 GMT Joel Sherrill [1fb9fa1c] * doc/ChangeLog (modified) * doc/common/opengroup_manpage_acknowledgement.texi (added) * doc/common/opengroup_preface_acknowledgement.texi (added) * doc/posix_users/preface.texi (modified) * doc/shell/preface.texi (modified) 2009-02-27 Joel Sherrill * ... Fri, 27 Feb 2009 16:44:55 GMT Joel Sherrill [78de0879] * testsuites/samples/ChangeLog (modified) Format. Fri, 27 Feb 2009 16:02:28 GMT Joel Sherrill [f2d3786] * doc/ChangeLog (modified) * doc/user/intr.t (modified) 2009-02-27 Joel Sherrill ... Fri, 27 Feb 2009 15:33:08 GMT Joel Sherrill [08ed3c3] * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/shared/start.S (modified) 2009-02-27 Daniel Hellstrom PR ... Fri, 27 Feb 2009 15:09:37 GMT Joel Sherrill [5d01560b] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bspgetworkarea.c (modified) 2009-02-27 Joel Sherrill * ... Fri, 27 Feb 2009 15:09:14 GMT Joel Sherrill [67cad729] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspgetworkarea.c (modified) 2009-02-27 Joel Sherrill * ... Fri, 27 Feb 2009 12:12:08 GMT Thomas Doerfler [949166d] * c/src/lib/libbsp/arm/lpc24xx/network/network.c (added) * c/src/lib/libbsp/arm/lpc24xx/startup/bspreset.c (added) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc2478 (added) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc2478_ncs (added) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc2478_ncs_ram (added) * c/src/lib/libbsp/arm/shared/startup/linkcmds.rom (added) * make/custom/lpc2478_ncs.cfg (added) * make/custom/lpc2478_ncs_ram.cfg (added) * make/custom/lpc24xx.cfg (added) added missing files Fri, 27 Feb 2009 11:26:44 GMT Thomas Doerfler [9647f7fe] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/README (modified) * c/src/lib/libbsp/arm/lpc24xx/clock/clock-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc24xx.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/system-clocks.h (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/system-clocks.c (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/ssp/ssp.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/include/start.h (modified) * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/include/utility.h (modified) * make/custom/lpc2478.cfg (modified) * README: Added NCS. * Makefile.am, configure.ac, ... Fri, 27 Feb 2009 11:25:30 GMT Thomas Doerfler [92cbf96] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/bsp_specs (modified) * bsp_specs: Added crtbegin.o and crtend.o to support global C++ ... Fri, 27 Feb 2009 11:13:52 GMT Thomas Doerfler [7a18a320] * testsuites/samples/ChangeLog (modified) * testsuites/samples/fileio/init.c (modified) Adapt to modified shell configuration Fri, 27 Feb 2009 11:10:46 GMT Thomas Doerfler [ca5bcd8] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) PR 1356 * libchip/i2c/spi-sd-card.c: Added support for high ... Fri, 27 Feb 2009 11:06:21 GMT Thomas Doerfler [cd4ed38] * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) * rtems/powerpc/registers.h: Added Freescale Book E Implementation ... Fri, 27 Feb 2009 11:03:57 GMT Thomas Doerfler [06f8e558] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libmisc/shell/shellconfig.h (modified) * libmisc/shell/shell.c, libmisc/shell/shell.h: Changed type for ...
