# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 23:04:45 Mon, 15 Jun 2020 16:00:33 GMT Simon Glass [eaadf704] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: Correct condition for reordering blocks This condition uses ... Thu, 05 Mar 2020 14:04:45 GMT Jan Beulich [caa59e66] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: fix undefined behaviour in fdt_splice_() libfdt: fix ... Mon, 02 Mar 2020 19:02:55 GMT Simon Glass [16420fbb] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: Use VALID_INPUT for FDT_ERR_BADSTATE checks This error ... Mon, 02 Mar 2020 19:02:54 GMT Simon Glass [fe0b99d] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Add support for disabling internal checks If libfdt returns ... Mon, 02 Mar 2020 19:02:53 GMT Simon Glass [1f2b9ad] * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Improve comments in some of the assumptions Add a little ... Mon, 02 Mar 2020 19:02:52 GMT Simon Glass [f7a174ef] * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Fix a few typos Fix 'saftey' and 'additional' typos noticed ... Thu, 01 Jul 2021 06:27:11 GMT Sebastian Huber [f44e2c99] * bsps/sparc/leon3/start/bspsmp.c (modified) bsp/leon3: Do not invalidate cache in SMP start Since the trap ... Fri, 10 Dec 2021 13:25:30 GMT Sebastian Huber [044701e] * bsps/sparc/leon3/include/tm27.h (modified) bsp/leon3: Use interrupt entry for tm27 support Using ... Fri, 10 Dec 2021 13:24:49 GMT Sebastian Huber [1179430f] * bsps/sparc/leon3/start/bspsmp.c (modified) bsp/leon3: Use interrupt entry for the SMP support Using ... Thu, 01 Jul 2021 06:26:47 GMT Sebastian Huber [6318154] * bsps/sparc/leon3/clock/ckinit.c (modified) bsp/leon3: Use interrupt entry for Clock Driver Using ... Sat, 11 Dec 2021 10:44:44 GMT Sebastian Huber [2d75d5d] * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) bsps/arm: Add missing Cache Manager source file Sat, 11 Dec 2021 10:44:17 GMT Sebastian Huber [96221e40] * bsps/aarch64/shared/start/linkcmds.base (modified) bsps/aarch64: Support .noinit linker section Fri, 10 Dec 2021 07:48:27 GMT Sebastian Huber [868e6d8] * cpukit/include/rtems/rtems/intr.h (modified) rtems: Improve ordering in Move the data ... Fri, 10 Dec 2021 15:45:54 GMT Kinsey Moore [68b0db35] * bsps/aarch64/shared/cache/cache.c (modified) bsps/aarch64: Remove erroneous cache feature The AArch64 cache ... Wed, 14 Oct 2020 08:47:44 GMT Sebastian Huber [fb17dfb1] * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/ratemondata.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) Avoid ISR_LOCK_MEMBER() since it confuses Doxygen If RTEMS_SMP is ... Thu, 09 Dec 2021 01:06:29 GMT Kinsey Moore [0f5fa026] * spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) spec: Update location of cadence I2C When the cadence I2C code was ... Thu, 09 Dec 2021 12:31:10 GMT Sebastian Huber [4c20360d] * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/librtemstest.yml (modified) build: Move test header to right library item Wed, 01 Dec 2021 15:39:46 GMT Christian Mauderer [ffc57e3] * cpukit/libmisc/untar/untar.c (modified) * testsuites/libtests/tar01/init.c (modified) * testsuites/libtests/tar01/tar01.doc (modified) * testsuites/libtests/tar01/tar01.scn (modified) * testsuites/libtests/tar01/tar01.tar (modified) untar: Make behavior similar to GNU or BSD tar RTEMS untar ... Tue, 07 Dec 2021 15:31:45 GMT Sebastian Huber [39e6f532] * cpukit/include/rtems/score/wkspaceinitone.h (modified) score: Fix _Workspace_Initialize_for_one_area() In ... Fri, 26 Nov 2021 06:29:52 GMT Sebastian Huber [e543a16] * cpukit/libtest/t-test-rtems-measure.c (modified) libtest: Fix sample reporting The sample reporting wronly added ... Fri, 26 Nov 2021 06:28:38 GMT Sebastian Huber [5e3607bc] * cpukit/libtest/t-test-rtems-measure.c (modified) libtest: Fix overlap in measurement context Sun, 05 Dec 2021 15:37:33 GMT Sebastian Huber [69d643f7] * cpukit/include/rtems/score/cpustdatomic.h (modified) score: Fix atomic stores for C++ Close #4566. Thu, 02 Dec 2021 14:06:48 GMT Sebastian Huber [9089bcc] * cpukit/include/rtems/irq-extension.h (modified) * cpukit/include/rtems/rtems/intr.h (modified) rtems: Move all Interrupt Manager stuff to intr.h Since the ... Thu, 02 Dec 2021 13:00:53 GMT Sebastian Huber [0d83bed2] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/scheduler.h (added) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/rtems/src/scheduleraddprocessor.c (modified) * cpukit/rtems/src/schedulergetmaxprio.c (modified) * cpukit/rtems/src/schedulergetprocessor.c (modified) * cpukit/rtems/src/schedulergetprocessormax.c (modified) * cpukit/rtems/src/schedulergetprocessorset.c (modified) * cpukit/rtems/src/schedulerident.c (modified) * cpukit/rtems/src/scheduleridentbyprocessor.c (modified) * cpukit/rtems/src/scheduleridentbyprocessorset.c (modified) * cpukit/rtems/src/schedulermapfromposix.c (modified) * cpukit/rtems/src/schedulermaptoposix.c (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Move scheduler directives to own header Move all ... Wed, 08 Apr 2020 15:14:41 GMT Sebastian Huber [d7205f0] * bsps/shared/start/mallocinitmulti.c (added) * bsps/shared/start/mallocinitone.c (added) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/mallocinitmulti.h (added) * cpukit/include/rtems/mallocinitone.h (added) * cpukit/libcsupport/src/malloc_initialize.c (deleted) * cpukit/libcsupport/src/mallocheap.c (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/objmem.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/objmem.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (modified) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/libtests/malloc04/init.c (modified) libc: Optimize malloc() initialization The BSPs provide memory for ... Wed, 08 Apr 2020 14:54:34 GMT Sebastian Huber [3d0620b] * bsps/shared/start/wkspaceinitmulti.c (added) * bsps/shared/start/wkspaceinitone.c (added) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/include/rtems/score/wkspaceinitmulti.h (added) * cpukit/include/rtems/score/wkspaceinitone.h (added) * cpukit/score/src/wkspace.c (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/objmem.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/objmem.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (modified) score: Optimize Workspace Handler initialization The BSPs provide ... Mon, 29 Nov 2021 07:35:43 GMT Sebastian Huber [2de3a6e] * spec/build/bsps/aarch64/a53/grp.yml (modified) * spec/build/bsps/aarch64/a53/obj.yml (modified) * spec/build/bsps/aarch64/a72/grp.yml (modified) * spec/build/bsps/aarch64/a72/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml (modified) * spec/build/bsps/arm/atsam/bspatsam.yml (modified) * spec/build/bsps/arm/beagle/grp.yml (modified) * spec/build/bsps/arm/beagle/obj.yml (modified) * spec/build/bsps/arm/csb336/bspcsb336.yml (modified) * spec/build/bsps/arm/csb337/grp.yml (modified) * spec/build/bsps/arm/csb337/obj.yml (modified) * spec/build/bsps/arm/edb7312/bspedb7312.yml (modified) * spec/build/bsps/arm/fvp/grp.yml (modified) * spec/build/bsps/arm/fvp/obj.yml (modified) * spec/build/bsps/arm/gumstix/bspgumstix.yml (modified) * spec/build/bsps/arm/imxrt/bspimxrt.yml (modified) * spec/build/bsps/arm/lm3s69xx/grp.yml (modified) * spec/build/bsps/arm/lm3s69xx/obj.yml (modified) * spec/build/bsps/arm/lpc176x/grp.yml (modified) * spec/build/bsps/arm/lpc176x/obj.yml (modified) * spec/build/bsps/arm/lpc24xx/grp.yml (modified) * spec/build/bsps/arm/lpc24xx/obj.yml (modified) * spec/build/bsps/arm/lpc32xx/grp.yml (modified) * spec/build/bsps/arm/lpc32xx/obj.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml (modified) * spec/build/bsps/arm/rtl22xx/grp.yml (modified) * spec/build/bsps/arm/rtl22xx/obj.yml (modified) * spec/build/bsps/arm/smdk2410/bspsmdk2410.yml (modified) * spec/build/bsps/arm/stm32f4/grp.yml (modified) * spec/build/bsps/arm/stm32f4/obj.yml (modified) * spec/build/bsps/arm/stm32h7/grp.yml (modified) * spec/build/bsps/arm/stm32h7/obj.yml (modified) * spec/build/bsps/arm/tms570/grp.yml (modified) * spec/build/bsps/arm/tms570/obj.yml (modified) * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/grp.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) * spec/build/bsps/bfin/TLL6527M/bsptll6527m.yml (modified) * spec/build/bsps/bfin/bf537Stamp/bspbf537stamp.yml (modified) * spec/build/bsps/bfin/eZKit533/bspezkit533.yml (modified) * spec/build/bsps/lm32/lm32_evr/grp.yml (modified) * spec/build/bsps/lm32/lm32_evr/obj.yml (modified) * spec/build/bsps/lm32/milkymist/bspmilkymist.yml (modified) * spec/build/bsps/m68k/av5282/bspav5282.yml (modified) * spec/build/bsps/m68k/csb360/bspcsb360.yml (modified) * spec/build/bsps/m68k/gen68340/bspgen68340.yml (modified) * spec/build/bsps/m68k/gen68360/grp.yml (modified) * spec/build/bsps/m68k/gen68360/obj.yml (modified) * spec/build/bsps/m68k/genmcf548x/grp.yml (modified) * spec/build/bsps/m68k/genmcf548x/obj.yml (modified) * spec/build/bsps/m68k/mcf5206elite/bspmcf5206elite.yml (modified) * spec/build/bsps/m68k/mcf52235/bspmcf52235.yml (modified) * spec/build/bsps/m68k/mcf5225x/bspmcf5225x.yml (modified) * spec/build/bsps/m68k/mcf5235/bspmcf5235.yml (modified) * spec/build/bsps/m68k/mcf5329/bspmcf5329.yml (modified) * spec/build/bsps/m68k/mrm332/bspmrm332.yml (modified) * spec/build/bsps/m68k/mvme147/bspmvme147.yml (modified) * spec/build/bsps/m68k/mvme147s/bspmvme147s.yml (modified) * spec/build/bsps/m68k/mvme162/grp.yml (modified) * spec/build/bsps/m68k/mvme162/obj.yml (modified) * spec/build/bsps/m68k/mvme167/bspmvme167.yml (modified) * spec/build/bsps/m68k/uC5282/bspuc5282.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/grp.yml (modified) * spec/build/bsps/microblaze/microblaze_fpga/obj.yml (modified) * spec/build/bsps/mips/csb350/bspcsb350.yml (modified) * spec/build/bsps/mips/hurricane/bsphurricane.yml (modified) * spec/build/bsps/mips/jmr3904/bspjmr3904.yml (modified) * spec/build/bsps/mips/malta/bspmalta.yml (modified) * spec/build/bsps/mips/rbtx4925/bsprbtx4925.yml (modified) * spec/build/bsps/mips/rbtx4938/bsprbtx4938.yml (modified) * spec/build/bsps/moxie/moxiesim/bspmoxiesim.yml (modified) * spec/build/bsps/nios2/nios2_iss/bspnios2iss.yml (modified) * spec/build/bsps/objmem.yml (added) * spec/build/bsps/or1k/generic_or1k/bspgenericor1k.yml (modified) * spec/build/bsps/powerpc/beatnik/bspbeatnik.yml (modified) * spec/build/bsps/powerpc/gen5200/grp.yml (modified) * spec/build/bsps/powerpc/gen5200/obj.yml (modified) * spec/build/bsps/powerpc/gen83xx/grp.yml (modified) * spec/build/bsps/powerpc/gen83xx/obj.yml (modified) * spec/build/bsps/powerpc/haleakala/bsphaleakala.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/grp.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/obj.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/bspmpc8260ads.yml (modified) * spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml (modified) * spec/build/bsps/powerpc/mvme5500/bspmvme5500.yml (modified) * spec/build/bsps/powerpc/objmem.yml (added) * spec/build/bsps/powerpc/psim/bsppsim.yml (modified) * spec/build/bsps/powerpc/qemuppc/bspqemuppc.yml (modified) * spec/build/bsps/powerpc/ss555/bspss555.yml (modified) * spec/build/bsps/powerpc/t32mppc/bspt32mppc.yml (modified) * spec/build/bsps/powerpc/virtex/bspvirtex.yml (modified) * spec/build/bsps/powerpc/virtex4/bspvirtex4.yml (modified) * spec/build/bsps/powerpc/virtex5/bspvirtex5.yml (modified) * spec/build/bsps/riscv/griscv/grp.yml (modified) * spec/build/bsps/riscv/griscv/obj.yml (modified) * spec/build/bsps/riscv/riscv/grp.yml (modified) * spec/build/bsps/riscv/riscv/obj.yml (modified) * spec/build/bsps/sh/gensh1/bspgensh1.yml (modified) * spec/build/bsps/sh/gensh2/bspgensh2.yml (modified) * spec/build/bsps/sh/gensh4/bspgensh4.yml (modified) * spec/build/bsps/sh/shsim/grp.yml (modified) * spec/build/bsps/sh/shsim/obj.yml (modified) * spec/build/bsps/sparc/erc32/bsperc32.yml (modified) * spec/build/bsps/sparc/leon2/grp.yml (modified) * spec/build/bsps/sparc/leon2/obj.yml (modified) * spec/build/bsps/sparc/leon3/grp.yml (modified) * spec/build/bsps/sparc/leon3/obj.yml (modified) * spec/build/bsps/sparc/objmem.yml (added) * spec/build/bsps/sparc64/niagara/bspniagara.yml (modified) * spec/build/bsps/sparc64/usiii/bspusiii.yml (modified) * spec/build/bsps/v850/gdbv850sim/grp.yml (modified) * spec/build/bsps/v850/gdbv850sim/obj.yml (modified) * spec/build/bsps/x86_64/amd64/bspamd64.yml (modified) build: Use common objects item for get memory Thu, 09 Apr 2020 07:31:28 GMT Sebastian Huber [0bd28da] * cpukit/score/src/wkspace.c (modified) * cpukit/score/src/wkspaceallocate.c (added) * cpukit/score/src/wkspacefree.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Split wkspace.c Splitting the file avoids unnecessary ... Thu, 09 Apr 2020 07:24:05 GMT Sebastian Huber [b070e012] * cpukit/score/src/wkspace.c (modified) wkspace.c: Change license to BSD-2-Clause Change licence according ... Mon, 29 Nov 2021 15:19:01 GMT Sebastian Huber [73305a1] * cpukit/score/cpu/arm/include/rtems/score/aarch32-pmsa.h (modified) arm: Add AARCH32_PMSA_DATA_READ_WRITE_DEFAULT Add default memory ... Mon, 29 Nov 2021 13:54:21 GMT Sebastian Huber [7fec89e2] * cpukit/score/cpu/arm/include/rtems/score/aarch32-pmsa.h (modified) arm: Fix AARCH32_PMSA_DATA_READ_WRITE_CACHED Fix definition of ... Wed, 24 Nov 2021 18:03:57 GMT Joel Sherrill [e945e3fc] * cpukit/aclocal/canonical-target-name.m4 (deleted) * cpukit/aclocal/canonicalize-tools.m4 (deleted) * cpukit/aclocal/check-func.m4 (deleted) * cpukit/aclocal/check-multiprocessing.m4 (deleted) * cpukit/aclocal/check-networking.m4 (deleted) * cpukit/aclocal/check-newlib.m4 (deleted) * cpukit/aclocal/check-posix.m4 (deleted) * cpukit/aclocal/check-rtems-debug.m4 (deleted) * cpukit/aclocal/check-smp.m4 (deleted) * cpukit/aclocal/check-tool.m4 (deleted) * cpukit/aclocal/enable-drvmgr.m4 (deleted) * cpukit/aclocal/enable-multiprocessing.m4 (deleted) * cpukit/aclocal/enable-networking.m4 (deleted) * cpukit/aclocal/enable-paravirt.m4 (deleted) * cpukit/aclocal/enable-posix.m4 (deleted) * cpukit/aclocal/enable-profiling.m4 (deleted) * cpukit/aclocal/enable-rtems-debug.m4 (deleted) * cpukit/aclocal/enable-smp.m4 (deleted) * cpukit/aclocal/env-rtemscpu.m4 (deleted) * cpukit/aclocal/gcc-pipe.m4 (deleted) * cpukit/aclocal/gcc-sanity.m4 (deleted) * cpukit/aclocal/gcc-weak.m4 (deleted) * cpukit/aclocal/multi.m4 (deleted) * cpukit/aclocal/multilib.m4 (deleted) * cpukit/aclocal/prog-cc.m4 (deleted) * cpukit/aclocal/prog-ccas.m4 (deleted) * cpukit/aclocal/rtems-bsp-includes.m4 (deleted) * cpukit/aclocal/rtems-build-top.m4 (deleted) * cpukit/aclocal/rtems-includes.m4 (deleted) * cpukit/aclocal/rtems-source-top.m4 (deleted) * cpukit/aclocal/rtems-top.m4 (deleted) * cpukit/aclocal/version.m4 (deleted) * testsuites/aclocal/canonical-target-name.m4 (deleted) * testsuites/aclocal/canonicalize-tools.m4 (deleted) * testsuites/aclocal/check-cpuopts.m4 (deleted) * testsuites/aclocal/check-custom-bsp.m4 (deleted) * testsuites/aclocal/check-cxx.m4 (deleted) * testsuites/aclocal/check-tool.m4 (deleted) * testsuites/aclocal/enable-cxx.m4 (deleted) * testsuites/aclocal/enable-tests.m4 (deleted) * testsuites/aclocal/env-rtemsbsp.m4 (deleted) * testsuites/aclocal/gcc-specs.m4 (deleted) * testsuites/aclocal/prog-cc.m4 (deleted) * testsuites/aclocal/prog-cxx.m4 (deleted) * testsuites/aclocal/project-root.m4 (deleted) * testsuites/aclocal/rtems-bsp-includes.m4 (deleted) * testsuites/aclocal/rtems-bsp-linkcmds.m4 (deleted) * testsuites/aclocal/rtems-build-top.m4 (deleted) * testsuites/aclocal/rtems-includes.m4 (deleted) * testsuites/aclocal/rtems-source-top.m4 (deleted) * testsuites/aclocal/rtems-test-check.m4 (deleted) * testsuites/aclocal/rtems-top.m4 (deleted) * testsuites/aclocal/version.m4 (deleted) * testsuites/ada/aclocal/prog-gnat.m4 (deleted) */aclocal/*: Remove remnants of autoconf/automae build system ... Thu, 25 Nov 2021 01:43:10 GMT Joel Sherrill [dd70c81] * bsps/arm/altera-cyclone-v/start/bsp_specs (deleted) * bsps/arm/atsam/start/bsp_specs (deleted) * bsps/arm/beagle/start/bsp_specs (deleted) * bsps/arm/csb336/start/bsp_specs (deleted) * bsps/arm/csb337/start/bsp_specs (deleted) * bsps/arm/edb7312/start/bsp_specs (deleted) * bsps/arm/gumstix/start/bsp_specs (deleted) * bsps/arm/imx/start/bsp_specs (deleted) * bsps/arm/lm3s69xx/start/bsp_specs (deleted) * bsps/arm/lpc176x/start/bsp_specs (deleted) * bsps/arm/lpc24xx/start/bsp_specs (deleted) * bsps/arm/lpc32xx/start/bsp_specs (deleted) * bsps/arm/raspberrypi/start/bsp_specs (deleted) * bsps/arm/realview-pbx-a9/start/bsp_specs (deleted) * bsps/arm/rtl22xx/start/bsp_specs (deleted) * bsps/arm/smdk2410/start/bsp_specs (deleted) * bsps/arm/stm32f4/start/bsp_specs (deleted) * bsps/arm/stm32h7/start/bsp_specs (deleted) * bsps/arm/tms570/start/bsp_specs (deleted) * bsps/arm/xen/start/bsp_specs (deleted) * bsps/arm/xilinx-zynq/start/bsp_specs (deleted) * bsps/arm/xilinx-zynqmp/start/bsp_specs (deleted) * bsps/bfin/TLL6527M/start/bsp_specs (deleted) * bsps/bfin/bf537Stamp/start/bsp_specs (deleted) * bsps/bfin/eZKit533/start/bsp_specs (deleted) * bsps/i386/pc386/start/bsp_specs (deleted) * bsps/lm32/lm32_evr/start/bsp_specs (deleted) * bsps/lm32/milkymist/start/bsp_specs (deleted) * bsps/m68k/av5282/start/bsp_specs (deleted) * bsps/m68k/csb360/start/bsp_specs (deleted) * bsps/m68k/gen68340/start/bsp_specs (deleted) * bsps/m68k/gen68360/start/bsp_specs (deleted) * bsps/m68k/genmcf548x/start/bsp_specs (deleted) * bsps/m68k/mcf5206elite/start/bsp_specs (deleted) * bsps/m68k/mcf52235/start/bsp_specs (deleted) * bsps/m68k/mcf5225x/start/bsp_specs (deleted) * bsps/m68k/mcf5235/start/bsp_specs (deleted) * bsps/m68k/mcf5329/start/bsp_specs (deleted) * bsps/m68k/mrm332/start/bsp_specs (deleted) * bsps/m68k/mvme147/start/bsp_specs (deleted) * bsps/m68k/mvme147s/start/bsp_specs (deleted) * bsps/m68k/mvme162/start/bsp_specs (deleted) * bsps/m68k/mvme167/start/bsp_specs (deleted) * bsps/m68k/uC5282/start/bsp_specs (deleted) * bsps/mips/csb350/start/bsp_specs (deleted) * bsps/mips/hurricane/start/bsp_specs (deleted) * bsps/mips/jmr3904/start/bsp_specs (deleted) * bsps/mips/malta/start/bsp_specs (deleted) * bsps/mips/rbtx4925/start/bsp_specs (deleted) * bsps/mips/rbtx4938/start/bsp_specs (deleted) * bsps/moxie/moxiesim/start/bsp_specs (deleted) * bsps/nios2/nios2_iss/start/bsp_specs (deleted) * bsps/no_cpu/no_bsp/start/bsp_specs (deleted) * bsps/or1k/generic_or1k/start/bsp_specs (deleted) * bsps/powerpc/beatnik/start/bsp_specs (deleted) * bsps/powerpc/gen5200/start/bsp_specs (deleted) * bsps/powerpc/gen83xx/start/bsp_specs (deleted) * bsps/powerpc/haleakala/start/bsp_specs (deleted) * bsps/powerpc/motorola_powerpc/start/bsp_specs (deleted) * bsps/powerpc/mpc55xxevb/start/bsp_specs (deleted) * bsps/powerpc/mpc8260ads/start/bsp_specs (deleted) * bsps/powerpc/mvme3100/start/bsp_specs (deleted) * bsps/powerpc/mvme5500/start/bsp_specs (deleted) * bsps/powerpc/psim/start/bsp_specs (deleted) * bsps/powerpc/qemuppc/start/bsp_specs (deleted) * bsps/powerpc/qoriq/start/bsp_specs (deleted) * bsps/powerpc/ss555/start/bsp_specs (deleted) * bsps/powerpc/t32mppc/start/bsp_specs (deleted) * bsps/powerpc/tqm8xx/start/bsp_specs (deleted) * bsps/powerpc/virtex/start/bsp_specs (deleted) * bsps/powerpc/virtex4/start/bsp_specs (deleted) * bsps/powerpc/virtex5/start/bsp_specs (deleted) * bsps/riscv/griscv/start/bsp_specs (deleted) * bsps/riscv/riscv/start/bsp_specs (deleted) * bsps/sh/gensh1/start/bsp_specs (deleted) * bsps/sh/gensh2/start/bsp_specs (deleted) * bsps/sh/gensh4/start/bsp_specs (deleted) * bsps/sh/shsim/start/bsp_specs (deleted) * bsps/sparc/erc32/start/bsp_specs (deleted) * bsps/sparc/leon2/start/bsp_specs (deleted) * bsps/sparc/leon3/start/bsp_specs (deleted) * bsps/sparc64/niagara/start/bsp_specs (deleted) * bsps/sparc64/usiii/start/bsp_specs (deleted) * bsps/v850/gdbv850sim/start/bsp_specs (deleted) * bsps/x86_64/amd64/start/bsp_specs (deleted) * spec/build/bsps/arm/stm32h7/obj.yml (modified) bsp_specs: Delete last remnants of these. Updates #3937. Mon, 29 Nov 2021 07:49:27 GMT Sebastian Huber [61d0df45] * spec/build/bsps/aarch64/xilinx-versal/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/obj.yml (modified) build: Remove trailing white space Tue, 23 Nov 2021 15:32:23 GMT Sebastian Huber [bdcc814] * cpukit/score/cpu/sparc/cpu_asm.S (modified) sparc: Add workaround for GRLIB-TN-0011 Affected components are the ... Tue, 23 Nov 2021 14:15:27 GMT Sebastian Huber [675e879] * cpukit/include/rtems/rtems/clock.h (modified) rtems: Replace "precision" with "resolution" Resolution is the ... Thu, 11 Nov 2021 07:44:29 GMT Sebastian Huber [5468464] * cpukit/include/rtems/score/status.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Properly continue the thread during restart The ... Fri, 12 Nov 2021 07:17:32 GMT Sebastian Huber [3b6e263a] * cpukit/score/src/threadqenqueue.c (modified) score: _Thread_queue_Surrender_no_priority() Simplify ... Thu, 11 Nov 2021 08:00:03 GMT Sebastian Huber [2e56aab] * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextract.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Move _Thread_queue_Extract() Move _Thread_queue_Extract() ... Thu, 11 Nov 2021 09:34:31 GMT Sebastian Huber [e429e97] * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadtimeout.c (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) score: Simplify thread wait state handling Remove the ... Thu, 11 Nov 2021 07:35:22 GMT Sebastian Huber [50aef135] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadrestart.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/objmpci.yml (modified) score: Add _Thread_MP_Extract_proxy() Remove ... Thu, 11 Nov 2021 07:33:36 GMT Sebastian Huber [cd791039] * cpukit/score/src/threadrestart.c (modified) score: Remove thread timer earlier The earlier we remove the thread ... Mon, 15 Nov 2021 09:20:30 GMT Sebastian Huber [834a86fe] * cpukit/score/src/scheduleredfsmp.c (modified) score: Restrict affinity for EDF SMP scheduler The SMP EDF ... Mon, 08 Nov 2021 10:08:24 GMT Sebastian Huber [c69a70a] * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/rtems/src/schedulerremoveprocessor.c (modified) rtems: Fix rtems_scheduler_remove_processor() Return an error ... Wed, 10 Nov 2021 07:54:03 GMT Sebastian Huber [6443c9d] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Fix assertion in SMP scheduler framework Properly assert ... Fri, 29 Oct 2021 07:30:13 GMT Sebastian Huber [fc64e837] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/schedulersmp.c (modified) * cpukit/score/src/threaddispatch.c (modified) score: Rework ask for help requests Process ask for help requests ... Fri, 29 Oct 2021 12:17:54 GMT Sebastian Huber [4d90289e] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: _Scheduler_SMP_Schedule_highest_ready() Simplify callers of ... Fri, 29 Oct 2021 12:45:28 GMT Sebastian Huber [d0434b88] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: Remove victim thread from CPU allocation Update #4531. Fri, 29 Oct 2021 11:44:04 GMT Sebastian Huber [c6362f6] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Move _Scheduler_Unblock_node() Move ... Fri, 29 Oct 2021 11:38:43 GMT Sebastian Huber [dcd8b93] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Move _Scheduler_Block_node() Move _Scheduler_Block_node() ... Fri, 29 Oct 2021 06:29:51 GMT Sebastian Huber [f767ef80] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Simplify _Scheduler_SMP_Yield() There is not need to ... Wed, 27 Oct 2021 06:48:47 GMT Sebastian Huber [b9990b8d] * cpukit/score/src/scheduleredfsmp.c (modified) score: Fix SMP EDF priority group ordering The SMP EDF scheduler ... Wed, 27 Oct 2021 06:35:22 GMT Sebastian Huber [6d20f0c5] * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/include/rtems/score/schedulersimpleimpl.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * testsuites/sptests/spchain/init.c (modified) score: Add node to insert to Chain_Node_order This allows to use ... Wed, 20 Oct 2021 12:21:20 GMT Sebastian Huber [ff20bc9] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/include/rtems/score/schedulersmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: Rework idle handling in SMP schedulers This patch fixes an ... Fri, 15 Oct 2021 09:21:31 GMT Sebastian Huber [3d6ebde1] * cpukit/include/rtems/score/mrspimpl.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/schedulerdefaultmakecleansticky.c (added) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * spec/build/cpukit/objsmp.yml (modified) score: Add SMP scheduler make/clean sticky This patch fixes the ... Wed, 20 Oct 2021 06:24:24 GMT Sebastian Huber [3781709] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Add SMP scheduler idle exchange callback Update #4531. Wed, 27 Oct 2021 07:46:06 GMT Sebastian Huber [75527ef3] * cpukit/score/src/scheduleredfsmp.c (modified) score: Optimize SMP EDF move to ready operation If a node is moved ... Tue, 19 Oct 2021 12:28:48 GMT Sebastian Huber [9d3e8212] * cpukit/include/rtems/score/scheduleredfsmp.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) score: Rework affine ready queue handling Rework the handling of ... Tue, 19 Oct 2021 11:06:09 GMT Sebastian Huber [a53229bb] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: Use extract from scheduled callbacks Use the extract from ... Thu, 21 Oct 2021 09:07:21 GMT Sebastian Huber [757a1096] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/scheduleredfsmp.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) score: Remove return value from enqueue scheduled The return value ... Tue, 19 Oct 2021 10:43:47 GMT Sebastian Huber [6286a40] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Scheduler insert after move Insert nodes after moving the ... Wed, 20 Oct 2021 06:23:07 GMT Sebastian Huber [81659420] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Add missing idle thread exchanges Update #4531. Wed, 20 Oct 2021 06:20:58 GMT Sebastian Huber [e787091] * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Add missing idle thread releases Update #4531. Tue, 19 Oct 2021 09:25:25 GMT Sebastian Huber [bd55f69] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Simplify _Scheduler_Exchange_idle_thread() Remove ... Tue, 19 Oct 2021 09:21:49 GMT Sebastian Huber [f0f60a1e] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulersmpimpl.h (modified) score: Change _Scheduler_Try_to_schedule_node() Add the victim node ... Mon, 18 Oct 2021 07:07:07 GMT Sebastian Huber [7ae4f569] * cpukit/include/rtems/score/schedulerimpl.h (modified) score: Not set CPU in _Scheduler_Use_idle_thread() Do not set the ... Mon, 18 Oct 2021 07:05:30 GMT Sebastian Huber [45e942d] * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulernodeimpl.h (modified) score: Rename _Scheduler_Set_idle_thread() Rename ... Fri, 22 Oct 2021 05:31:46 GMT Sebastian Huber [577262a7] * cpukit/include/rtems/score/rbtreeimpl.h (modified) * cpukit/score/src/rbtreeappend.c (added) * cpukit/score/src/rbtreeprepend.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Add red-black tree append/prepend These functions are a ... Fri, 29 Oct 2021 11:57:27 GMT Sebastian Huber [3c076041] * cpukit/include/rtems/score/schedulerimpl.h (modified) score: Simplify _Scheduler_Generic_block() If we block the ... Wed, 17 Nov 2021 16:30:24 GMT Kinsey Moore [1eb266b] * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/src/stackallocatorforidle.c (modified) cpukit: Consistize OAR copyright headers These two OAR copyright ... Tue, 16 Nov 2021 16:26:00 GMT Kinsey Moore [50cf1932] * cpukit/include/rtems/score/percpu.h (modified) cpukit: Enable debug for SMP AArch64 Ensure when both RTEMS_DEBUG ... Thu, 18 Nov 2021 06:59:04 GMT Sebastian Huber [18484f02] * cpukit/rtems/src/schedulergetprocessor.c (added) * cpukit/rtems/src/schedulergetprocessormax.c (added) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Add external functions These external functions ... Thu, 18 Nov 2021 11:13:53 GMT Sebastian Huber [9b6362da] * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/taskident.c (modified) * testsuites/libtests/malloctest/task1.c (modified) * testsuites/libtests/stackchk/task1.c (modified) * testsuites/mptests/mp01/task1.c (modified) * testsuites/mptests/mp03/task1.c (modified) * testsuites/mptests/mp04/task1.c (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/smptests/smp08/tasks.c (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/sptests/sp19/first.c (modified) * testsuites/sptests/sp19/fptask.c (modified) * testsuites/sptests/sp19/task1.c (modified) * testsuites/sptests/sp24/task1.c (modified) * testsuites/sptests/sp30/task1.c (modified) * testsuites/sptests/sp42/init.c (modified) * testsuites/sptests/sp76/init.c (modified) * testsuites/sptests/spcbssched01/task1.c (modified) * testsuites/sptests/spedfsched01/task1.c (modified) * testsuites/sptests/spsimplesched01/init.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) * testsuites/sptests/sptask_err04/task1.c (modified) rtems: Use RTEMS_WHO_AM_I for rtems_task_ident() Wed, 17 Nov 2021 19:05:52 GMT Sebastian Huber [99fdfcd] * cpukit/include/rtems/rtems/asr.h (modified) * cpukit/include/rtems/rtems/signal.h (modified) rtems: Add signal header to implementation group Tue, 16 Nov 2021 16:00:29 GMT Sebastian Huber [c47daf6f] * cpukit/include/rtems/confdefs/iodrivers.h (modified) config: Fix IO driver table initialization Check all IO driver ... Mon, 15 Nov 2021 18:15:27 GMT Sebastian Huber [32cee883] * cpukit/include/rtems/confdefs/bsp.h (modified) * cpukit/include/rtems/confdefs/extensions.h (modified) * cpukit/include/rtems/confdefs/iodrivers.h (modified) * cpukit/include/rtems/confdefs/malloc.h (modified) * cpukit/include/rtems/confdefs/percpu.h (modified) config: CONFIGURE_DISABLE_BSP_SETTINGS Evaluate ... Tue, 16 Nov 2021 06:44:04 GMT Sebastian Huber [c1395ca0] * wscript (modified) build: Add --rtems-version command line option Update #4548. Mon, 15 Nov 2021 07:46:21 GMT Sebastian Huber [f06dd3e] * spec/build/cpukit/optvermaj.yml (modified) build: Optional __RTEMS_MAJOR__ via command line Update #4548. Mon, 15 Nov 2021 07:33:54 GMT Sebastian Huber [a0650f5f] * wscript (modified) build: Support command line specified options Update #4548. Mon, 15 Nov 2021 07:36:58 GMT Sebastian Huber [9551f340] * spec/build/cpukit/optvermaj.yml (modified) Revert "optvermaj.yml: Allow __RTEMS_MAJOR__ to be overridden so ... Mon, 11 Oct 2021 15:07:50 GMT Sebastian Huber [ccbcfb6] * cpukit/include/rtems/rtems/clock.h (modified) * cpukit/score/src/kern_tc.c (modified) rtems: Add new clock manager directives Update #4527. Tue, 23 Mar 2021 15:36:09 GMT Sebastian Huber [1b5db79] * cpukit/rtems/src/semsetpriority.c (modified) * testsuites/smptests/smpscheduler02/init.c (modified) rtems: Simplify rtems_semaphore_set_priority() Do not write to the ... Tue, 23 Mar 2021 14:34:26 GMT Sebastian Huber [ee57a7f1] * cpukit/include/rtems/score/coremuteximpl.h (modified) * cpukit/rtems/src/semsetpriority.c (modified) score: Fix _CORE_ceiling_mutex_Set_priority() We have to use a ... Fri, 16 Apr 2021 07:21:57 GMT Sebastian Huber [16b50ac6] * cpukit/include/rtems/score/coremuteximpl.h (modified) score: Always check if a prio ceiling is defined Priority ceiling ... Wed, 12 May 2021 08:53:48 GMT Sebastian Huber [7a591d0c] * cpukit/include/rtems/score/threadimpl.h (modified) score: Fix thread pinning assertions Thu, 28 Oct 2021 09:14:57 GMT Sebastian Huber [ffb8833d] * cpukit/include/rtems/score/timecounter.h (modified) * cpukit/score/src/kern_tc.c (modified) score: Add _Timecounter_Set_NTP_update_second() Allow the ... Mon, 11 Oct 2021 15:10:29 GMT Sebastian Huber [b936ce5] * cpukit/score/src/kern_tc.c (modified) score: Optimize timehand updates for non-SMP In uniprocessor ... Mon, 11 Oct 2021 08:45:27 GMT Sebastian Huber [52c53a59] * cpukit/score/src/kern_tc.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) score: Port large time delta support to RTEMS Mon, 11 Oct 2021 08:09:57 GMT Sebastian Huber [b88d9cb3] * cpukit/score/src/kern_tc.c (modified) score: Initialize timehand generation to UINT_MAX This leads to a ... Fri, 29 Oct 2021 18:29:22 GMT Mark Johnston [c3a68059] * cpukit/score/src/kern_tc.c (modified) timecounter: Load the currently selected tc once in tc_windup() ... Thu, 28 Oct 2021 08:22:58 GMT Sebastian Huber [34675587] * cpukit/score/src/kern_tc.c (modified) kern_tc.c: Scaling/large delta recalculation This change is a ... Sat, 16 Oct 2021 13:46:55 GMT Mark Johnston [ea389aaa] * cpukit/score/src/kern_tc.c (modified) timecounter: Lock the timecounter list Timecounter registration is ... Sat, 09 Oct 2021 16:34:06 GMT Mark Johnston [66d4077] * cpukit/score/src/kern_tc.c (modified) timecounter: Let kern.timecounter.stepwarnings be set as a tunable ... Sun, 08 Aug 2021 14:38:01 GMT Ed Maste [d84e3b6e] * cpukit/score/src/kern_tc.c (modified) Remove "All Rights Reserved" from FreeBSD Foundation sys/ ... Wed, 05 May 2021 18:32:13 GMT Warner Losh [87d7a6e] * cpukit/score/src/kern_tc.c (modified) kern: clarify boot time In FreeBSD, the current time is computed ... Sun, 07 Mar 2021 23:50:12 GMT Konstantin Belousov [8d5fc57] * cpukit/score/src/kern_tc.c (modified) Make kern.timecounter.hardware tunable Noted and reviewed by: ... Mon, 18 Jan 2021 07:25:36 GMT Konstantin Belousov [570e58e] * cpukit/score/src/kern_tc.c (modified) Add ddb 'show timecounter' command. MFC after: 1 week ... Sat, 09 Jan 2021 08:38:11 GMT Robert Watson [4b384f3] * cpukit/score/src/kern_tc.c (modified) Changes that improve DTrace FBT reliability on freebsd/arm64: - ... Wed, 10 Jun 2020 22:30:32 GMT Konstantin Belousov [18e6686d] * cpukit/score/src/kern_tc.c (modified) Remove double-calls to tc_get_timecount() to warm timecounters. ... Wed, 26 Feb 2020 14:26:36 GMT Pawel Biernacki [df775722] * cpukit/score/src/kern_tc.c (modified) Mark more nodes as CTLFLAG_MPSAFE or CTLFLAG_NEEDGIANT (17 of many) ...
