# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 09:29:33 Thu, 28 Oct 1999 19:29:49 GMT Joel Sherrill [dcb93155] * doc/posix_users/files.t (modified) Cleaned up spacing on function prototypes. Thu, 28 Oct 1999 19:25:46 GMT Joel Sherrill [d3fc9e9d] * doc/posix_users/files.t (modified) Added lstat(). Thu, 28 Oct 1999 18:30:47 GMT Joel Sherrill [75e3651a] * doc/filesystem/Makefile (modified) * doc/filesystem/filesystem.texi (modified) * doc/filesystem/imfs.t (modified) * doc/filesystem/miniimfs.t (added) * doc/filesystem/tftp.t (added) Added shell of chapters on implementation of miniIMFS and TFTP client ... Thu, 28 Oct 1999 17:44:08 GMT Joel Sherrill [b502b0d1] changed version to 19991028 Thu, 28 Oct 1999 16:01:41 GMT Joel Sherrill [7046cdd] * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * make/custom/gensh1.cfg (modified) Patch rtems-rc-19991011-3.diff from Ralf Corsepius. Thu, 28 Oct 1999 15:30:55 GMT Joel Sherrill [e90c5a1e] * VERSION (modified) changed version to 19991028 Thu, 28 Oct 1999 15:12:10 GMT Joel Sherrill [5c104e08] * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/psxtests/psxcancel/Makefile.in (added) * c/src/tests/psxtests/psxcancel/init.c (added) * c/src/tests/psxtests/psxcancel/psxcancel.scn (added) * c/src/tests/psxtests/psxcancel/system.h (added) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxcancel/init.c (added) * testsuites/psxtests/psxcancel/psxcancel.scn (added) New test added - psxcancel. This is just a shell for now. Thu, 28 Oct 1999 14:59:35 GMT Joel Sherrill [b8d9f41] * c/src/libnetworking/rtems_webserver/socket.c (modified) * cpukit/httpd/socket.c (modified) Added include of in attempt to remove compilation warning. Thu, 28 Oct 1999 14:50:43 GMT Joel Sherrill [be22768] * c/src/libnetworking/rtems_webserver/Makefile.in (modified) * c/src/libnetworking/rtems_webserver/misc.c (modified) * c/src/libnetworking/rtems_webserver/uemf.h (modified) * cpukit/httpd/Makefile.in (modified) * cpukit/httpd/misc.c (modified) * cpukit/httpd/uemf.h (modified) Added use of __rtems__ rather than LINUX for RTEMS configuration. Thu, 28 Oct 1999 14:07:54 GMT Joel Sherrill [bb43e079] * c/ACKNOWLEDGEMENTS (modified) More changes. Thu, 28 Oct 1999 13:36:26 GMT Joel Sherrill [c8b35b1b] * c/src/lib/libbsp/MERGE.PROCEDURE (added) Notes on what to do when merging a BSP. Wed, 27 Oct 1999 20:50:57 GMT Joel Sherrill [45544f0] * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) Patch from Aleksey (Quality Quorum ) to increase ... Wed, 27 Oct 1999 20:21:33 GMT Joel Sherrill [e4487b6] * c/src/libmisc/Makefile.am (modified) * c/src/libmisc/configure.in (modified) * cpukit/libmisc/Makefile.am (modified) Modified to properly descend into the dummy directory. Wed, 27 Oct 1999 20:09:39 GMT Joel Sherrill [0f75a13] * c/src/libmisc/dummy/Makefile.in (modified) Fixed typo. Wed, 27 Oct 1999 19:35:36 GMT Joel Sherrill [b07e06a1] * c/src/libmisc/dummy/Makefile.in (added) * c/src/libmisc/dummy/README (added) * c/src/libmisc/dummy/dummy.c (added) * cpukit/libmisc/dummy/README (added) * cpukit/libmisc/dummy/dummy.c (added) New files from Ralf Corsepius which are a ... Wed, 27 Oct 1999 19:27:05 GMT Joel Sherrill [3abbfdb] * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) Added $(EXEEXT) in attempt to help Cygwin install process. Wed, 27 Oct 1999 19:25:43 GMT Joel Sherrill [10eb06e8] * c/TESTED (modified) Updated. Wed, 27 Oct 1999 19:24:26 GMT Joel Sherrill [226ea52] * make/custom/rxgen960.cfg (modified) Updated to be more like cvme961.cfg. Wed, 27 Oct 1999 19:07:56 GMT Joel Sherrill [4b42e20] * scripts/gccnewlib/gccnewlib.spec.in (modified) Latest version from Ralf Corsepius which ... Wed, 27 Oct 1999 18:54:14 GMT Joel Sherrill [2bdc1e98] * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/startup/linkcmds (modified) Last cleanup to attempt to link. Wed, 27 Oct 1999 17:25:53 GMT Joel Sherrill [ae7325bd] * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/i960RP.h (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/console/console.c (modified) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (modified) * c/src/lib/libbsp/i960/rxgen960/include/rxgen960_config.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/fault.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rxgen_romld.S (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/timer/timerisr.S (modified) * cpukit/score/cpu/i960/cpu.c (modified) rxgen960 now compiles -- may not link. Wed, 27 Oct 1999 16:27:34 GMT Joel Sherrill [2ea8df3] * c/src/lib/libbsp/i960/rxgen960/include/rxgen960_config.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/dram.ld (modified) * c/src/lib/libbsp/i960/rxgen960/startup/fault.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/fault.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/faultret.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/i960.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/kkprintf.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/linkcmds (modified) * c/src/lib/libbsp/i960/rxgen960/startup/main.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/memchnl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/nmi.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/nulsystbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/pmc901_memmap.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom.ld (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_prcb.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rommon.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rxgen_romld.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/time.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/types.h (modified) Added CVS Ids and a basic header. More header cleanup needed. Wed, 27 Oct 1999 16:26:00 GMT Joel Sherrill [f08a5596] * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/startup/save_systbl.c (deleted) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.S (deleted) Removed systbl.S save_systbl.c. They were unnecessary. Wed, 27 Oct 1999 16:21:49 GMT Joel Sherrill [8ac4213] * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.S (deleted) Removed sctns.S. This file was obviously the output of the compiler. Wed, 27 Oct 1999 16:19:24 GMT Joel Sherrill [919822f] * c/src/lib/libbsp/i960/rxgen960/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.in (modified) Replaced Makefile.in's with modified copies of cvme961 to get ... Wed, 27 Oct 1999 15:58:26 GMT Joel Sherrill [d73a8649] * c/src/lib/libbsp/i960/rxgen960/timer/timerisr.S (moved) Moved timerisr.s to timerisr.S per GNU conventions. Wed, 27 Oct 1999 15:57:20 GMT Joel Sherrill [ce644256] * c/src/lib/libbsp/i960/rxgen960/startup/systbl.S (moved) Moved systbl.s to systbl.S per GNU conventions. Wed, 27 Oct 1999 15:57:19 GMT Joel Sherrill [5ee66da] * c/src/lib/libbsp/i960/rxgen960/startup/sctns.S (moved) Moved sctns.s to sctns.S per GNU conventions. Wed, 27 Oct 1999 15:57:17 GMT Joel Sherrill [bf71be9e] * c/src/lib/libbsp/i960/rxgen960/startup/rxgen_romld.S (moved) Moved rxgen_romld.s to rxgen_romld.S per GNU conventions. Wed, 27 Oct 1999 15:57:16 GMT Joel Sherrill [478c4b8] * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.S (moved) Moved ihandler.s to ihandler.S per GNU conventions. Wed, 27 Oct 1999 15:57:15 GMT Joel Sherrill [49b8c26] * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.S (moved) Moved asmstub.s to asmstub.S per GNU conventions. Wed, 27 Oct 1999 15:57:14 GMT Joel Sherrill [eb7f0f22] * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.S (moved) Moved asmfault.s to asmfault.S per GNU conventions. Wed, 27 Oct 1999 15:29:18 GMT Joel Sherrill [702c5f5] * c/ACKNOWLEDGEMENTS (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/i960RP.h (added) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/README (added) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (added) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/clock/ckinit.c (added) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/console/concntl.h (added) * c/src/lib/libbsp/i960/rxgen960/console/console.c (added) * c/src/lib/libbsp/i960/rxgen960/console/serial.c (added) * c/src/lib/libbsp/i960/rxgen960/console/serial.h (added) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (added) * c/src/lib/libbsp/i960/rxgen960/include/coverhd.h (added) * c/src/lib/libbsp/i960/rxgen960/include/rxgen960_config.h (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/addrconv.c (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/getcfg.c (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/lock.c (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/mpisr.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/dram.ld (added) * c/src/lib/libbsp/i960/rxgen960/startup/exit.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/fault.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/fault.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/faultret.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/i960.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/kkprintf.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/linkcmds (added) * c/src/lib/libbsp/i960/rxgen960/startup/main.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/memchnl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/nmi.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/nulsystbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/pmc901_memmap.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom.ld (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_cntrltbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_prcb.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/rommon.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/rxgen_romld.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/save_systbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/setvec.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/time.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/types.h (added) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/timer/timer.c (added) * c/src/lib/libbsp/i960/rxgen960/timer/timerisr.s (added) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.in (added) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/i960/rtems/score/cpu.h (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * make/custom/rxgen960.cfg (added) The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson ... Wed, 27 Oct 1999 15:11:37 GMT Joel Sherrill [090b1c37] * c/ACKNOWLEDGEMENTS (modified) First attempt at icluding Eric Valette and Emmanuel Raguet. Wed, 27 Oct 1999 13:58:58 GMT Joel Sherrill [3f4b575] * c/src/libnetworking/rtems_webserver/socket.c (modified) * c/src/libnetworking/rtems_webserver/webcomp.c (modified) * c/src/libnetworking/rtems_webserver/webmain.c (modified) * cpukit/httpd/socket.c (modified) * cpukit/httpd/webcomp.c (modified) * cpukit/httpd/webmain.c (modified) Warnings removed. Still don't know what to do about the pragma pack ... Wed, 27 Oct 1999 12:50:33 GMT Joel Sherrill [c1cdaa0] * c/src/exec/libnetworking/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/rtems_webserver/Makefile.in (added) * c/src/libnetworking/rtems_webserver/asp.c (added) * c/src/libnetworking/rtems_webserver/balloc.c (added) * c/src/libnetworking/rtems_webserver/default.c (added) * c/src/libnetworking/rtems_webserver/ej.h (added) * c/src/libnetworking/rtems_webserver/ejlex.c (added) * c/src/libnetworking/rtems_webserver/ejparse.c (added) * c/src/libnetworking/rtems_webserver/form.c (added) * c/src/libnetworking/rtems_webserver/h.c (added) * c/src/libnetworking/rtems_webserver/handler.c (added) * c/src/libnetworking/rtems_webserver/mime.c (added) * c/src/libnetworking/rtems_webserver/misc.c (added) * c/src/libnetworking/rtems_webserver/ringq.c (added) * c/src/libnetworking/rtems_webserver/rom.c (added) * c/src/libnetworking/rtems_webserver/rtems_webserver.h (added) * c/src/libnetworking/rtems_webserver/security.c (added) * c/src/libnetworking/rtems_webserver/socket.c (added) * c/src/libnetworking/rtems_webserver/sym.c (added) * c/src/libnetworking/rtems_webserver/uemf.c (added) * c/src/libnetworking/rtems_webserver/uemf.h (added) * c/src/libnetworking/rtems_webserver/url.c (added) * c/src/libnetworking/rtems_webserver/value.c (added) * c/src/libnetworking/rtems_webserver/wbase64.c (added) * c/src/libnetworking/rtems_webserver/webcomp.c (added) * c/src/libnetworking/rtems_webserver/webmain.c (added) * c/src/libnetworking/rtems_webserver/webpage.c (added) * c/src/libnetworking/rtems_webserver/webrom.c (added) * c/src/libnetworking/rtems_webserver/webs.c (added) * c/src/libnetworking/rtems_webserver/webs.h (added) * c/src/libnetworking/rtems_webserver/websuemf.c (added) * c/src/libnetworking/rtems_webserver/wsIntrn.h (added) * c/src/libnetworking/wrapup/Makefile.in (modified) * cpukit/httpd/Makefile.in (added) * cpukit/httpd/asp.c (added) * cpukit/httpd/balloc.c (added) * cpukit/httpd/default.c (added) * cpukit/httpd/ej.h (added) * cpukit/httpd/ejlex.c (added) * cpukit/httpd/ejparse.c (added) * cpukit/httpd/form.c (added) * cpukit/httpd/h.c (added) * cpukit/httpd/handler.c (added) * cpukit/httpd/mime.c (added) * cpukit/httpd/misc.c (added) * cpukit/httpd/ringq.c (added) * cpukit/httpd/rom.c (added) * cpukit/httpd/rtems_webserver.h (added) * cpukit/httpd/security.c (added) * cpukit/httpd/socket.c (added) * cpukit/httpd/sym.c (added) * cpukit/httpd/uemf.c (added) * cpukit/httpd/uemf.h (added) * cpukit/httpd/url.c (added) * cpukit/httpd/value.c (added) * cpukit/httpd/wbase64.c (added) * cpukit/httpd/webcomp.c (added) * cpukit/httpd/webmain.c (added) * cpukit/httpd/webpage.c (added) * cpukit/httpd/webrom.c (added) * cpukit/httpd/webs.c (added) * cpukit/httpd/webs.h (added) * cpukit/httpd/websuemf.c (added) * cpukit/httpd/wsIntrn.h (added) * cpukit/libnetworking/Makefile.am (modified) Patch from Emmanuel Raguet and Eric Valette ... Tue, 26 Oct 1999 21:51:20 GMT Joel Sherrill [7999174] * c/src/exec/libfs/src/imfs/imfs_handlers_device.c (added) * c/src/exec/libfs/src/imfs/imfs_handlers_directory.c (added) * c/src/exec/libfs/src/imfs/imfs_handlers_memfile.c (added) * c/src/lib/libc/imfs_handlers_device.c (added) * c/src/lib/libc/imfs_handlers_directory.c (added) * c/src/lib/libc/imfs_handlers_memfile.c (added) * c/src/libfs/src/imfs/imfs_handlers_device.c (added) * c/src/libfs/src/imfs/imfs_handlers_directory.c (added) * c/src/libfs/src/imfs/imfs_handlers_memfile.c (added) * cpukit/libfs/src/imfs/imfs_handlers_device.c (added) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (added) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (added) New files created by split of old imfs_handlers.c. Tue, 26 Oct 1999 21:51:07 GMT Joel Sherrill [2fe47ff] * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/libc/libio.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) Added include of libio.h so this would compile when posix is disabled. Tue, 26 Oct 1999 20:30:20 GMT Joel Sherrill [7ee88c16] * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c (added) Split console_reserve_resources to separate file to reduce code size. Tue, 26 Oct 1999 20:17:13 GMT Joel Sherrill [657e1bf6] * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/src/base_fs.c (modified) * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/exec/libfs/src/imfs/imfs_eval.c (modified) * c/src/exec/libfs/src/imfs/imfs_free.c (modified) * c/src/exec/libfs/src/imfs/imfs_fsunmount.c (added) * c/src/exec/libfs/src/imfs/imfs_init.c (modified) * c/src/exec/libfs/src/imfs/imfs_initsupp.c (modified) * c/src/exec/libfs/src/imfs/memfile.c (modified) * c/src/exec/libfs/src/imfs/miniimfs_init.c (added) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/base_fs.c (modified) * c/src/lib/libc/imfs.h (modified) * c/src/lib/libc/imfs_eval.c (modified) * c/src/lib/libc/imfs_free.c (modified) * c/src/lib/libc/imfs_fsunmount.c (added) * c/src/lib/libc/imfs_handlers.c (deleted) * c/src/lib/libc/imfs_init.c (modified) * c/src/lib/libc/imfs_initsupp.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/memfile.c (modified) * c/src/lib/libc/miniimfs_init.c (added) * c/src/libfs/src/imfs/imfs.h (modified) * c/src/libfs/src/imfs/imfs_eval.c (modified) * c/src/libfs/src/imfs/imfs_free.c (modified) * c/src/libfs/src/imfs/imfs_fsunmount.c (added) * c/src/libfs/src/imfs/imfs_init.c (modified) * c/src/libfs/src/imfs/imfs_initsupp.c (modified) * c/src/libfs/src/imfs/memfile.c (modified) * c/src/libfs/src/imfs/miniimfs_init.c (added) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_free.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (added) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (added) Added initial cut at miniIMFS which leaves out memfile and directory ... Tue, 26 Oct 1999 16:22:55 GMT Joel Sherrill [e54a7d33] * c/src/exec/score/cpu/i960/cpu_asm.S (modified) * cpukit/score/cpu/i960/cpu_asm.S (modified) Patch from Gerwin Pfab to leave dispatching ... Tue, 26 Oct 1999 15:42:10 GMT Jennifer Averett [10c1bef] * doc/filesystem/fsrequirements.t (modified) * doc/filesystem/patheval.t (modified) Added information on the evaluate and evaluate for make routines. ... Tue, 26 Oct 1999 15:21:01 GMT Joel Sherrill [66a8c6f] * c/src/lib/libbsp/i386/pc386/dec21140/dec21140.c (modified) Patch from Emmanuel Raguet to fix a small bug ... Tue, 26 Oct 1999 14:53:49 GMT Jennifer Averett [704f3a8] * doc/filesystem/fsrequirements.t (modified) Corrected spacing problem. Tue, 26 Oct 1999 14:39:57 GMT Joel Sherrill [9a986282] * c/src/exec/score/cpu/powerpc/mpc750/cpu.h (modified) * c/src/exec/score/cpu/powerpc/other_cpu/cpu.h (modified) Increased minimum stack size to ensure that there are no problems ... Tue, 26 Oct 1999 14:29:53 GMT Joel Sherrill [cb50837d] * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) Patch from Emmanuel Raguet to add missing file ... Tue, 26 Oct 1999 14:22:55 GMT Joel Sherrill [65a60cd] * c/src/make/README (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/compilers/gcc.cfg.in (deleted) * c/src/make/configure.in (modified) * make/README (modified) * make/compilers/Makefile.am (modified) * make/compilers/gcc.cfg.in (deleted) * make/custom/HPUX9-posix.cfg (modified) * make/custom/default.cfg (modified) * make/leaf.cfg (modified) Removed all references to HOST_ARCH including the file gcc.cfg.in. ... Tue, 26 Oct 1999 12:39:24 GMT Joel Sherrill [2782e69] * c/src/configure.in (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/configure.in (modified) * cpukit/libcsupport/Makefile.am (modified) idir=/opt/tmp/opt/rtems rdir=/opt/rtems cd $idir find . -type f | ... Tue, 26 Oct 1999 12:37:14 GMT Joel Sherrill [a94521c] * c/src/lib/libchip/Makefile.am (deleted) * c/src/lib/libchip/configure.in (deleted) * c/src/lib/libchip/network/Makefile.in (deleted) * c/src/lib/libchip/network/README (deleted) * c/src/lib/libchip/network/README.sonic (deleted) * c/src/lib/libchip/network/sonic.c (deleted) * c/src/lib/libchip/network/sonic.h (deleted) * c/src/lib/libchip/rtc/Makefile.in (deleted) * c/src/lib/libchip/rtc/README.ds1643 (deleted) * c/src/lib/libchip/rtc/README.icm7170 (deleted) * c/src/lib/libchip/rtc/README.m48t08 (deleted) * c/src/lib/libchip/rtc/README.m48t18 (deleted) * c/src/lib/libchip/rtc/STATUS (deleted) * c/src/lib/libchip/rtc/icm7170.c (deleted) * c/src/lib/libchip/rtc/icm7170.h (deleted) * c/src/lib/libchip/rtc/icm7170_reg.c (deleted) * c/src/lib/libchip/rtc/icm7170_reg2.c (deleted) * c/src/lib/libchip/rtc/icm7170_reg4.c (deleted) * c/src/lib/libchip/rtc/icm7170_reg8.c (deleted) * c/src/lib/libchip/rtc/m48t08.c (deleted) * c/src/lib/libchip/rtc/m48t08.h (deleted) * c/src/lib/libchip/rtc/m48t08_reg.c (deleted) * c/src/lib/libchip/rtc/m48t08_reg2.c (deleted) * c/src/lib/libchip/rtc/m48t08_reg4.c (deleted) * c/src/lib/libchip/rtc/m48t08_reg8.c (deleted) * c/src/lib/libchip/rtc/rtc.h (deleted) * c/src/lib/libchip/rtc/rtcprobe.c (deleted) * c/src/lib/libchip/serial/Makefile.in (deleted) * c/src/lib/libchip/serial/README (deleted) * c/src/lib/libchip/serial/README.mc68681 (deleted) * c/src/lib/libchip/serial/README.ns16550 (deleted) * c/src/lib/libchip/serial/README.xr88681 (deleted) * c/src/lib/libchip/serial/README.z85c30 (deleted) * c/src/lib/libchip/serial/STATUS (deleted) * c/src/lib/libchip/serial/mc68681.c (deleted) * c/src/lib/libchip/serial/mc68681.h (deleted) * c/src/lib/libchip/serial/mc68681_baud.c (deleted) * c/src/lib/libchip/serial/mc68681_p.h (deleted) * c/src/lib/libchip/serial/mc68681_reg.c (deleted) * c/src/lib/libchip/serial/mc68681_reg2.c (deleted) * c/src/lib/libchip/serial/mc68681_reg4.c (deleted) * c/src/lib/libchip/serial/mc68681_reg8.c (deleted) * c/src/lib/libchip/serial/ns16550.c (deleted) * c/src/lib/libchip/serial/ns16550.h (deleted) * c/src/lib/libchip/serial/ns16550_p.h (deleted) * c/src/lib/libchip/serial/serial.h (deleted) * c/src/lib/libchip/serial/serprobe.c (deleted) * c/src/lib/libchip/serial/sersupp.h (deleted) * c/src/lib/libchip/serial/termios_baud2index.c (deleted) * c/src/lib/libchip/serial/termios_baud2num.c (deleted) * c/src/lib/libchip/serial/z85c30.c (deleted) * c/src/lib/libchip/serial/z85c30.h (deleted) * c/src/lib/libchip/serial/z85c30_p.h (deleted) * c/src/lib/libchip/serial/z85c30_reg.c (deleted) cat /tmp/j | while read f do rpm -qi $f 2>&1 | grep -v "is not ... Tue, 26 Oct 1999 12:31:48 GMT Joel Sherrill [5f78061b] * scripts/Makefile.in (deleted) * scripts/binutils/Makefile.in (deleted) * scripts/gccnewlib/Makefile.in (deleted) * scripts/gdb/Makefile.in (deleted) Removing automatically generated files. Tue, 26 Oct 1999 12:31:00 GMT Joel Sherrill [1da921e1] * scripts/configure (deleted) Removed generated file. Tue, 26 Oct 1999 12:29:36 GMT Joel Sherrill [511a12c6] * scripts/setup.def (modified) New versions for gcc and patch. Tue, 26 Oct 1999 02:58:06 GMT Joel Sherrill [dd04e32] * c/src/configure.in (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/libmisc/Makefile.am (modified) * c/src/libmisc/configure.in (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) Patch from Ralf Corsepius to move ... Tue, 26 Oct 1999 02:49:21 GMT Joel Sherrill [3f06778e] * c/src/lib/libmisc/Makefile.am (deleted) * c/src/lib/libmisc/README (deleted) * c/src/lib/libmisc/configure.in (deleted) * c/src/lib/libmisc/cpuuse/Makefile.in (deleted) * c/src/lib/libmisc/cpuuse/README (deleted) * c/src/lib/libmisc/cpuuse/cpuuse.c (deleted) * c/src/lib/libmisc/cpuuse/cpuuse.h (deleted) * c/src/lib/libmisc/dumpbuf/Makefile.in (deleted) * c/src/lib/libmisc/dumpbuf/dumpbuf.c (deleted) * c/src/lib/libmisc/dumpbuf/dumpbuf.h (deleted) * c/src/lib/libmisc/monitor/Makefile.in (deleted) * c/src/lib/libmisc/monitor/README (deleted) * c/src/lib/libmisc/monitor/mon-command.c (deleted) * c/src/lib/libmisc/monitor/mon-config.c (deleted) * c/src/lib/libmisc/monitor/mon-dname.c (deleted) * c/src/lib/libmisc/monitor/mon-driver.c (deleted) * c/src/lib/libmisc/monitor/mon-extension.c (deleted) * c/src/lib/libmisc/monitor/mon-itask.c (deleted) * c/src/lib/libmisc/monitor/mon-manager.c (deleted) * c/src/lib/libmisc/monitor/mon-monitor.c (deleted) * c/src/lib/libmisc/monitor/mon-mpci.c (deleted) * c/src/lib/libmisc/monitor/mon-object.c (deleted) * c/src/lib/libmisc/monitor/mon-prmisc.c (deleted) * c/src/lib/libmisc/monitor/mon-queue.c (deleted) * c/src/lib/libmisc/monitor/mon-server.c (deleted) * c/src/lib/libmisc/monitor/mon-symbols.c (deleted) * c/src/lib/libmisc/monitor/mon-task.c (deleted) * c/src/lib/libmisc/monitor/monitor.h (deleted) * c/src/lib/libmisc/monitor/symbols.h (deleted) * c/src/lib/libmisc/rtmonuse/Makefile.in (deleted) * c/src/lib/libmisc/rtmonuse/rtmonuse.c (deleted) * c/src/lib/libmisc/rtmonuse/rtmonuse.h (deleted) * c/src/lib/libmisc/stackchk/Makefile.in (deleted) * c/src/lib/libmisc/stackchk/README (deleted) * c/src/lib/libmisc/stackchk/check.c (deleted) * c/src/lib/libmisc/stackchk/internal.h (deleted) * c/src/lib/libmisc/stackchk/stackchk.h (deleted) * c/src/lib/libmisc/untar/Makefile.in (deleted) * c/src/lib/libmisc/untar/README (deleted) * c/src/lib/libmisc/untar/untar.c (deleted) * c/src/lib/libmisc/untar/untar.h (deleted) * c/src/lib/libmisc/wrapup/Makefile.in (deleted) cat /tmp/j | while read f do rpm -qi $f 2>&1 | grep -v "is not ... Tue, 26 Oct 1999 02:45:04 GMT Joel Sherrill [3330ecb] * c/src/Makefile.am (modified) * c/src/configure.in (modified) Patch rtems-rc-19991011-0.diff from Ralf Corsepius [85cb0e5] * scripts/Makefile.in (modified) * scripts/aclocal.m4 (modified) * scripts/binutils/Makefile.in (modified) * scripts/configure (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gdb/Makefile.in (modified) Regenerated Tue, 26 Oct 1999 02:32:47 GMT Joel Sherrill [2ca64b5] * c/src/tests/sptests/sp27/TODO (modified) New ideas on test incorporated. Tue, 26 Oct 1999 01:35:36 GMT Joel Sherrill [99826740] * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/pc386/startup/linkcmds (modified) Modifications from Erik Ivanenko to add ... Tue, 26 Oct 1999 01:34:42 GMT Joel Sherrill [f70598c7] * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) Patch from Erik Ivanenko to fix some ... Mon, 25 Oct 1999 19:48:42 GMT Joel Sherrill [3a0a97a] * doc/networking/driver.t (modified) * doc/user/conf.t (modified) * doc/user/rtmon.t (modified) Fixed line too long problems. Mon, 25 Oct 1999 19:48:07 GMT Joel Sherrill [7ef86b3] * doc/gnu_docs/rtems_tools_index.html (modified) Updated copyright year and corrected image path. Mon, 25 Oct 1999 19:47:48 GMT Joel Sherrill [c8c14c43] * doc/gnu_docs/gnu_footer.html (modified) * doc/gnu_docs/index.html (modified) Updated copyright year. Mon, 25 Oct 1999 19:35:56 GMT Joel Sherrill [213c518] * scripts/Makefile.in (modified) * scripts/aclocal.m4 (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) Patch generated from scripts-19991025-0.tar.gz from Ralf Corsepius ... Mon, 25 Oct 1999 19:33:54 GMT Joel Sherrill [c302d7a3] * scripts/Makefile.in (modified) * scripts/aclocal.m4 (modified) * scripts/binutils/Makefile.in (modified) * scripts/configure (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gdb/Makefile.in (modified) Regnenerated following update from Ralf. Mon, 25 Oct 1999 18:02:33 GMT Joel Sherrill [9ec462aa] * doc/porting/taskcontext.t (modified) * doc/rgdb_specs/daemon.t (modified) * doc/rgdb_specs/gdbinternals.t (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/powerpc/cputable.t (modified) Fixing many lines that are too long to format cleanly. Mon, 25 Oct 1999 17:42:51 GMT Jennifer Averett [86437ec0] * doc/filesystem/mounting.t (modified) Added descriptions of the mount table entry elements. Mon, 25 Oct 1999 17:42:49 GMT Charles Phillips [6a27e08] * doc/FAQ/tools.t (modified) Modified url references to be dynamic links. Mon, 25 Oct 1999 17:41:56 GMT Charles Phillips [c3cc0ee] * doc/FAQ/freesw.t (modified) Added definition of DDD. Modified url references to be dynamic links. Mon, 25 Oct 1999 17:41:33 GMT Jennifer Averett [c3ffd24] * doc/filesystem/imfs.t (modified) + Filled in information on IMFS_freenod and IMFS_freenodinfo + ... Mon, 25 Oct 1999 17:41:03 GMT Jennifer Averett [55f5c1e] * doc/filesystem/fsrequirements.t (modified) + Cleaned up lines that were too long. + Removed subheading File - ... Mon, 25 Oct 1999 17:37:19 GMT Joel Sherrill [ee0702ef] * doc/posix_users/key.t (modified) * doc/posix_users/message.t (modified) * doc/posix_users/semaphores.t (modified) * doc/posix_users/thread.t (modified) * doc/rtems_gdb/example.t (modified) * doc/rtems_gdb/trouble.t (modified) * doc/started/buildc.t (modified) * doc/started/require.t (modified) * doc/started_ada/require.t (modified) Fixing many lines that are too long to format cleanly. Mon, 25 Oct 1999 17:33:01 GMT Jennifer Averett [0d01c94b] * doc/filesystem/syscalls.t (modified) Added information on how the directory is stored for future referance ... Mon, 25 Oct 1999 16:36:50 GMT Joel Sherrill [5a69fe3] * doc/user/Makefile (modified) * doc/user/conf.t (modified) * doc/user/sem.t (modified) Formatting improvements. Mon, 25 Oct 1999 16:32:13 GMT Joel Sherrill [90d02e9] * doc/bsp_howto/Makefile (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/bsp_howto/console.t (modified) * doc/bsp_howto/linkcmds.t (modified) * doc/bsp_howto/makefiles.t (modified) * doc/bsp_howto/shmsupp.t (modified) Enabled Ada95 interrupt support chapter and reformatted a bunch of ... Mon, 25 Oct 1999 16:09:45 GMT Joel Sherrill [8379ada7] * c/src/exec/libnetworking/netinet/ip_input.c (modified) * c/src/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) Patch from Eric Norum to address the following ... Mon, 25 Oct 1999 16:05:34 GMT Joel Sherrill [b6c868e] * c/src/exec/posix/src/pthread.c (modified) * cpukit/posix/src/pthread.c (modified) Patch from Charles-Antoine Gauthier to ... Mon, 25 Oct 1999 15:55:58 GMT Joel Sherrill [4e69f5b7] * c/src/tests/sptests/sp27/TODO (added) Added notes for new test. Mon, 25 Oct 1999 14:57:37 GMT Charles Phillips [c58674c] * doc/FAQ/entry (modified) Made html links browsable. Mon, 25 Oct 1999 14:52:19 GMT Joel Sherrill [3eb75db3] * c/src/lib/libbsp/powerpc/mcp750/dec21140/dec21140.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/dec21140/dec21140.c (modified) * make/custom/mcp750.cfg (modified) tch from Eric Valette and Emmanuel Raguet ... Mon, 25 Oct 1999 14:52:07 GMT Charles Phillips [bf61f225] * doc/FAQ/embeddedinfo.t (modified) Made urls browsable links. Mon, 25 Oct 1999 14:51:32 GMT Charles Phillips [4af77b03] * doc/FAQ/debug.t (modified) Made html urls browsable links. Mon, 25 Oct 1999 14:48:15 GMT Charles Phillips [9cc603ff] * doc/FAQ/basic.t (modified) Made html urls browable links. Updated the reference to the U.S. ... Mon, 25 Oct 1999 14:46:56 GMT Joel Sherrill [1e57186] * c/src/exec/libfs/src/imfs/imfs_gtkn.c (modified) * c/src/lib/libc/imfs_gtkn.c (modified) * c/src/libfs/src/imfs/imfs_gtkn.c (modified) * cpukit/libfs/src/imfs/imfs_gtkn.c (modified) Patch from Eric Valette and Emmanuel Raguet ... Mon, 25 Oct 1999 14:23:03 GMT Jennifer Averett [04df848] * c/src/exec/libcsupport/src/mount.c (modified) * c/src/exec/libcsupport/src/unmount.c (modified) * c/src/lib/libc/mount.c (modified) * c/src/lib/libc/unmount.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/unmount.c (modified) Added code to correctly free any allocated space during the ... Mon, 25 Oct 1999 14:15:09 GMT Joel Sherrill [72d3f610] * scripts/Makefile.in (modified) * scripts/aclocal.m4 (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) Merged scripts-19991022-0 changes from Ralf. Mon, 25 Oct 1999 14:14:36 GMT Joel Sherrill [43d3a8e] * make/custom/erc32.cfg (modified) Changed to use interrupt driven console. Mon, 25 Oct 1999 14:14:07 GMT Joel Sherrill [1232196a] * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/sptests/sp26/Makefile.in (added) * c/src/tests/sptests/sp26/init.c (added) * c/src/tests/sptests/sp26/sp26.doc (added) * c/src/tests/sptests/sp26/sp26.scn (added) * c/src/tests/sptests/sp26/system.h (added) * c/src/tests/sptests/sp26/task1.c (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/sp26/init.c (added) * testsuites/sptests/sp26/sp26.doc (added) * testsuites/sptests/sp26/sp26.scn (added) * testsuites/sptests/sp26/system.h (added) * testsuites/sptests/sp26/task1.c (added) Added sp26 which tests the rtems_task_is_suspended directive. Mon, 25 Oct 1999 14:13:14 GMT Joel Sherrill [9060699] * c/src/tests/psxtests/psxfile01/psxfile01.scn (modified) * c/src/tests/psxtests/psxfile01/test.c (modified) * c/src/tests/psxtests/psxstat/psxstat.scn (modified) * c/src/tests/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxfile01/psxfile01.scn (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxstat/psxstat.scn (modified) * testsuites/psxtests/psxstat/test.c (modified) Modified to ease comparison of screen to target output. Mon, 25 Oct 1999 14:11:12 GMT Joel Sherrill [48296038] * c/src/tests/psxtests/psx05/psx05.scn (modified) * testsuites/psxtests/psx05/psx05.scn (modified) Modified to reflect test change where reinitialize mutex test case ... Mon, 25 Oct 1999 14:10:38 GMT Joel Sherrill [524767cb] * c/src/tests/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) Removed reinitialize mutex test case to reflect earlier code change ... Mon, 25 Oct 1999 14:09:46 GMT Joel Sherrill [c774a07e] * c/src/exec/libfs/src/imfs/imfs_debug.c (modified) * c/src/lib/libc/imfs_debug.c (modified) * c/src/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) Changed leading spaces to periods to ease comparing test output. Mon, 25 Oct 1999 14:09:13 GMT Joel Sherrill [538db54] * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (modified) Modified to produce correct output with new version of sis. Mon, 25 Oct 1999 13:45:10 GMT Joel Sherrill [461caa5c] * doc/networking/networkapp.t (modified) Swapped SO_SNDWAKEUP and SO_RCVWAKEUP in many places since they were ... Mon, 25 Oct 1999 12:29:38 GMT Joel Sherrill [666e377] * scripts/configure (modified) Changed version number. Thu, 21 Oct 1999 19:36:29 GMT Joel Sherrill [61a4d81] * c/src/exec/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) Removed warning. Thu, 21 Oct 1999 19:25:19 GMT Joel Sherrill [ac5a9bf] * scripts/binutils/binutils.spec.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup.def (modified) Now builds RPM without complete source. Each target is only 15K. Thu, 21 Oct 1999 17:22:02 GMT Joel Sherrill [7063e223] * scripts/Makefile.in (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup (modified) Made the RTEMS version get substituted properly even though it is ... Thu, 21 Oct 1999 17:21:05 GMT Joel Sherrill [f4a5803e] * scripts/gccnewlib/gccnewlib.spec.in (modified) Now can specify rpm_build_root via setup. Changed package name so ... Thu, 21 Oct 1999 16:48:06 GMT Joel Sherrill [d013d05] * c/src/tests/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx04/system.h (modified) Increased stack size of initialization thread. Thu, 21 Oct 1999 16:44:24 GMT Joel Sherrill [e7264f07] * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/rtems/src/semflush.c (added) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/src/semflush.c (added) Added rtems_semaphore_flush directive.
