# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/24/24 02:25:53 Thu, 27 Aug 2009 08:20:36 GMT Ralf Corsepius [d7bc7aa] * contrib/crossrpms/freebsd7.2/i586/Makefile.am (modified) Split out libs.am Thu, 27 Aug 2009 08:14:23 GMT Ralf Corsepius [79e55c5] * contrib/crossrpms/freebsd7.2/binutils.am (modified) * contrib/crossrpms/freebsd7.2/gcc.am (modified) * contrib/crossrpms/freebsd7.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-binutils.spec (modified) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-gcc.spec (modified) * contrib/crossrpms/freebsd7.2/i586/i586-pc-freebsd7.2-libs.spec (modified) * contrib/crossrpms/freebsd7.2/i586/libs.add (modified) Modernize. Thu, 27 Aug 2009 06:39:53 GMT Ralf Corsepius [1ab6977] * contrib/crossrpms/cygwin/i686/expat.add (modified) * contrib/crossrpms/cygwin/i686/ncurses.add (modified) * contrib/crossrpms/cygwin/i686/zlib.add (modified) Update. Thu, 27 Aug 2009 06:33:11 GMT Ralf Corsepius [4668c7fe] * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-binutils.spec (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-expat.spec (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-gcc.spec (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-gmp.spec (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-libs.spec (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-mpfr.spec (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-ncurses.spec (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-readline.spec (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-termcap.spec (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-terminfo.spec (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-w32api.spec (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-zlib.spec (modified) Regenerate. Thu, 27 Aug 2009 06:32:49 GMT Ralf Corsepius [1c360794] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Various updates. Hard-code release instead of using @VERSION@. Thu, 27 Aug 2009 06:31:31 GMT Ralf Corsepius [8514d37] * contrib/crossrpms/gcc/rpm-install.add (modified) HACK: filter gcclibdir/* iff _gcclibdir is defined Thu, 27 Aug 2009 05:21:30 GMT Ralf Corsepius [dfe5b24b] * contrib/crossrpms/gcc/install.add (modified) More libiberty tweaks Thu, 27 Aug 2009 05:20:57 GMT Ralf Corsepius [27e77c93] * contrib/crossrpms/gcc/target-gfortran.add (modified) exclude finclude for gcc < 4.2.0 Thu, 27 Aug 2009 03:40:26 GMT Ralf Corsepius [5ec1009] * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) Install to --libdir=%{_prefix}/lib instead of %{_libdir} Thu, 27 Aug 2009 03:39:14 GMT Ralf Corsepius [3f8272d] * contrib/crossrpms/gcc/install.add (modified) Remove work-around to obsolete gfortran bug. Thu, 27 Aug 2009 02:59:15 GMT Ralf Corsepius [cd0393ff] * contrib/crossrpms/gcc/target-gcc.add (modified) Remove obsolete conditional. Thu, 27 Aug 2009 02:52:11 GMT Ralf Corsepius [fdff67bb] * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) Remove obsolete conditional. Thu, 27 Aug 2009 02:50:11 GMT Ralf Corsepius [1bd552a] * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) Remove obsolete conditional. Thu, 27 Aug 2009 02:22:20 GMT Ralf Corsepius [9af225c] * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gcc/rpm-install.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) s,%{gcclib},%{_gcclibdir}/gcc/, Thu, 27 Aug 2009 02:18:11 GMT Ralf Corsepius [150fd4ca] * contrib/crossrpms/gcc/base-gcj.add (modified) Remove outdated conditionals. Thu, 27 Aug 2009 00:01:06 GMT Joel Sherrill [a4a626b] * c/src/lib/libbsp/arm/gumstix/ChangeLog (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) 2009-08-26 Joel Sherrill * ... Wed, 26 Aug 2009 23:25:18 GMT Joel Sherrill [4314d61b] * cpukit/ChangeLog (modified) * cpukit/score/inline/rtems/score/address.inl (modified) 2009-08-26 Sebastian Huber ... Wed, 26 Aug 2009 17:16:23 GMT Ralf Corsepius [42663eec] * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) Eliminate %{gccexec}. Wed, 26 Aug 2009 17:14:38 GMT Ralf Corsepius [88687a62] * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) Abandon gcc < 3.4 Wed, 26 Aug 2009 17:03:54 GMT Ralf Corsepius [bbdde8b] * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) Move finclude into *-gfortran. Wed, 26 Aug 2009 16:58:08 GMT Ralf Corsepius [3b3b3b9] * contrib/crossrpms/specstrip (modified) Use fortran instead of f95. Wed, 26 Aug 2009 16:57:32 GMT Ralf Corsepius [4de09b5] * contrib/crossrpms/specstrip (modified) Abandon build_g77. Wed, 26 Aug 2009 16:56:59 GMT Ralf Corsepius [b8cb165] * contrib/crossrpms/cygwin/i686/gcc-sources.add (modified) * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.4/i586/gcc-sources.add (modified) * contrib/crossrpms/freebsd7.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.0/i586/gcc-sources.add (modified) * contrib/crossrpms/freebsd7.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.1/i586/gcc-sources.add (modified) * contrib/crossrpms/freebsd7.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.2/i586/gcc-sources.add (modified) * contrib/crossrpms/netbsd4.0.1/i386/Makefile.am (modified) * contrib/crossrpms/netbsd4.0.1/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/gcc-sources.add (modified) Use build_fortran instead of build_f95. Wed, 26 Aug 2009 16:49:08 GMT Ralf Corsepius [9dcd8f7] * contrib/crossrpms/gcc/install.add (modified) Abandon g77. Wed, 26 Aug 2009 16:47:48 GMT Ralf Corsepius [0b801216] * contrib/crossrpms/gcc/build.add (modified) Use --language=fortran for fortran. Abandon g77. Wed, 26 Aug 2009 16:44:54 GMT Ralf Corsepius [246717f] * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gcc/prep.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) Replace build_f95 with build_fortran. Wed, 26 Aug 2009 16:43:05 GMT Ralf Corsepius [439f9f4] * contrib/crossrpms/gcc/base-g77.add (deleted) * contrib/crossrpms/gcc/target-g77.add (deleted) Remove. Wed, 26 Aug 2009 13:39:01 GMT Joel Sherrill [e90329f] * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/idle.h (deleted) * c/src/lib/libbsp/arm/lpc24xx/misc/bspidle.c (moved) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) 2009-08-26 Joel Sherrill * ... Wed, 26 Aug 2009 13:32:22 GMT Joel Sherrill [758daa4] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) 2009-08-26 Joel Sherrill * ... Wed, 26 Aug 2009 13:31:40 GMT Joel Sherrill [fc472c9] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspidle.c (added) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspidle.c (added) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspidle.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspidle.c (added) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspidle.c (added) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) 2009-08-26 Joel Sherrill * ... Wed, 26 Aug 2009 13:22:58 GMT Joel Sherrill [7173c437] * testsuites/samples/ChangeLog (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (deleted) 2009-08-26 Joel Sherrill * ... Wed, 26 Aug 2009 13:22:27 GMT Joel Sherrill [d58ea3b] * cpukit/ChangeLog (modified) * cpukit/libfs/src/devfs/devfs.h (modified) 2009-08-26 Joel Sherrill * ... Wed, 26 Aug 2009 12:18:42 GMT Joel Sherrill [7bbedbe] * cpukit/ChangeLog (modified) * cpukit/sapi/include/rtems/config.h (modified) 2009-08-26 Sebastian Huber ... Wed, 26 Aug 2009 12:16:36 GMT Joel Sherrill [c1ac715] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/spstkalloc/init.c (modified) 2009-08-26 Sebastian Huber ... Wed, 26 Aug 2009 12:14:57 GMT Joel Sherrill [7c9c8c8c] * doc/ChangeLog (modified) * doc/user/conf.t (modified) 2009-08-26 Sebastian Huber ... Wed, 26 Aug 2009 12:01:21 GMT Joel Sherrill [8de136b] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/heapwalk/init.c (modified) * testsuites/libtests/stackchk/blow.c (modified) 2009-08-19 Sebastian Huber ... Wed, 26 Aug 2009 12:00:24 GMT Joel Sherrill [371cea31] * cpukit/ChangeLog (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapalignupuptr.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapallocatealigned.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/heapgetfreeinfo.c (modified) * cpukit/score/src/heapgetinfo.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/pheapgetblocksize.c (modified) 2009-08-24 Sebastian Huber ... Wed, 26 Aug 2009 11:02:45 GMT Ralf Corsepius [2bbfbf1] * contrib/crossrpms/gcc/gccnewlib.add (modified) Add mpfr_provided for openSUSE 11.0 + 11.1 Wed, 26 Aug 2009 10:57:06 GMT Ralf Corsepius [5426f17e] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-readline.spec (modified) Update readline. Wed, 26 Aug 2009 02:16:03 GMT Joel Sherrill [39385ed5] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp29/init.c (modified) 2009-08-25 Sebastian Huber ... Wed, 26 Aug 2009 02:13:38 GMT Joel Sherrill [bd03933] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp59/init.c (modified) * testsuites/sptests/sp59/sp59.scn (modified) * testsuites/sptests/sp63/init.c (modified) 2009-08-25 Sebastian Huber ... Tue, 25 Aug 2009 19:09:31 GMT Joel Sherrill [6749520] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/score603e/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/ss555/startup/linkcmds (modified) 2009-08-25 Joel Sherrill * ... Tue, 25 Aug 2009 13:45:30 GMT Joel Sherrill [0d32490] * cpukit/ChangeLog (modified) * cpukit/libfs/src/devfs/devfs_eval.c (modified) 2009-08-25 Joel Sherrill * ... Mon, 24 Aug 2009 21:06:01 GMT Joel Sherrill [eef91af] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) 2009-08-24 Joel Sherrill * ... Mon, 24 Aug 2009 12:15:24 GMT Joel Sherrill [dedccb64] * c/src/ada/ChangeLog (modified) * c/src/ada/rtems.adb (modified) 2009-08-24 Christian Mauderer [da42259] * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) Define M68K_FP_STATE_SIZE also if used in assembler files. Sun, 23 Aug 2009 15:00:29 GMT Joel Sherrill [2b86087] * doc/ChangeLog (modified) * doc/bsp_howto/framebuffer.t (modified) 2009-08-22 Roxana Leontie * ... Sun, 23 Aug 2009 14:59:55 GMT Joel Sherrill [b8dfc88] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vga.c (modified) 2009-08-22 Roxana Leontie * ... Sat, 22 Aug 2009 13:59:56 GMT Joel Sherrill [d46a0055] * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/pxa255/include/pxa255.h (modified) * c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_init.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.h (modified) 2009-08-22 Xi Yang * ... Sat, 22 Aug 2009 13:55:51 GMT Joel Sherrill [1179b5f3] * c/src/lib/libbsp/arm/gumstix/ChangeLog (modified) * c/src/lib/libbsp/arm/gumstix/fb/fb.c (modified) * c/src/lib/libbsp/arm/gumstix/startup/bspstart.c (modified) 2009-08-22 Xi Yang * fb/fb.c: ... Fri, 21 Aug 2009 18:41:50 GMT Joel Sherrill [2eb33fdc] * doc/ChangeLog (modified) * doc/bsp_howto/framebuffer.t (modified) 2009-08-21 Roxana Leontie * ... Fri, 21 Aug 2009 18:39:59 GMT Joel Sherrill [cb09a5da] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/fb/fb.h (moved) * cpukit/libmisc/fb/mw_uid.c (moved) * cpukit/libmisc/fb/mw_uid.h (moved) * cpukit/preinstall.am (modified) 2009-08-21 Roxana Leontie * ... Fri, 21 Aug 2009 18:36:02 GMT Joel Sherrill [4d06315] * c/src/lib/libbsp/arm/nds/ChangeLog (modified) * c/src/lib/libbsp/arm/nds/fb/fb.c (modified) 2009-08-21 Roxana Leontie * ... Fri, 21 Aug 2009 18:35:28 GMT Joel Sherrill [573e3b2] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vga.c (modified) 2009-08-21 Roxana Leontie * ... Fri, 21 Aug 2009 17:59:31 GMT Joel Sherrill [a3a6fae] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/include/bsp.h (modified) * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/arm/gumstix/ChangeLog (modified) * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) * c/src/lib/libbsp/arm/rtl22xx/ChangeLog (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) * c/src/lib/libbsp/bfin/bf537Stamp/ChangeLog (modified) * c/src/lib/libbsp/bfin/bf537Stamp/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/haleakala/ChangeLog (modified) * c/src/lib/libbsp/powerpc/haleakala/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) 2009-08-21 Joel Sherrill * ... Fri, 21 Aug 2009 17:49:31 GMT Joel Sherrill [a17bc42] * c/src/lib/libbsp/arm/gumstix/ChangeLog (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/fb/fb.c (added) * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) * c/src/lib/libbsp/arm/gumstix/preinstall.am (modified) * c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c (added) * c/src/lib/libbsp/arm/gumstix/rtl8019/wd80x3.h (added) * c/src/lib/libbsp/arm/gumstix/startup/memmap.c (modified) 2009-08-21 Xi Yang * Makefile.am: ... Fri, 21 Aug 2009 17:35:49 GMT Joel Sherrill [c39d81bc] * testsuites/samples/ChangeLog (modified) * testsuites/samples/unlimited/test2.c (modified) 2009-08-21 Xi Yang * ... Thu, 20 Aug 2009 23:56:17 GMT Joel Sherrill [b580e71] * c/src/ChangeLog (modified) * c/src/aclocal/check-networking.m4 (modified) 2009-08-20 Joel Sherrill * ... Thu, 20 Aug 2009 13:40:26 GMT Ralf Corsepius [2c3e6c5] * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) Regenerate. Thu, 20 Aug 2009 13:40:00 GMT Ralf Corsepius [0ebf6f22] * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) Remove gcc-4.4.0. gcc-core-4.4.1--rtems4.10-20090820.diff. Thu, 20 Aug 2009 13:39:24 GMT Ralf Corsepius [b610c1b] * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) Bump GCC_RPMREL. Thu, 20 Aug 2009 13:38:50 GMT Ralf Corsepius [5e770e65] * contrib/crossrpms/patches/gcc-core-4.4.1-rtems4.10-20090820.diff (added) Remove _exit from avr's libgcc. Wed, 19 Aug 2009 21:42:36 GMT Joel Sherrill [897aa558] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/spwatchdog/spwatchdog.scn (modified) * testsuites/sptests/spwatchdog/task1.c (modified) 2009-08-19 Joel Sherrill * ... Wed, 19 Aug 2009 17:28:19 GMT Joel Sherrill [c45ca10] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psx09/init.c (modified) * testsuites/psxtests/psx09/psx09.scn (modified) 2009-08-19 Joel Sherrill * ... Wed, 19 Aug 2009 17:26:38 GMT Joel Sherrill [9f49b43] * testsuites/psxtests/ChangeLog (modified) Give credit to Santosh. Wed, 19 Aug 2009 16:40:03 GMT Joel Sherrill [93f7ea15] * cpukit/ChangeLog (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadidlebody.c (deleted) 2009-08-19 Joel Sherrill * ... Wed, 19 Aug 2009 16:39:05 GMT Joel Sherrill [db0df7b] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) 2009-08-19 Joel Sherrill * ... Wed, 19 Aug 2009 16:37:10 GMT Joel Sherrill [3c1adeec] * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) 2009-08-19 Joel Sherrill * ... Wed, 19 Aug 2009 16:30:24 GMT Joel Sherrill [d0971334] * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/startup/ithread.S (deleted) 2009-08-19 Joel Sherrill * ... Wed, 19 Aug 2009 16:28:55 GMT Joel Sherrill [56035ca3] * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/debugputs.c (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspidle.S (added) * c/src/lib/libbsp/sparc/leon3/startup/setvec.c (modified) 2009-08-19 Joel Sherrill * ... Wed, 19 Aug 2009 16:13:01 GMT Joel Sherrill [b181c30] * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/startup/bspidle.c (added) * c/src/lib/libbsp/sparc/leon2/startup/setvec.c (modified) 2009-08-19 Joel Sherrill * ... Wed, 19 Aug 2009 16:05:38 GMT Joel Sherrill [0fed29a] * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspidle.c (added) * c/src/lib/libbsp/sparc/erc32/startup/setvec.c (modified) 2009-08-19 Joel Sherrill * ... Wed, 19 Aug 2009 15:18:19 GMT Joel Sherrill [a1f0ca28] * cpukit/ChangeLog (modified) * cpukit/posix/src/pthread.c (modified) 2009-08-19 Joel Sherrill * ... Wed, 19 Aug 2009 15:13:34 GMT Joel Sherrill [4e7ca87] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtime/psxtime.scn (modified) * testsuites/psxtests/psxtime/test.c (modified) 2009-08-19 Joel Sherrill * ... Wed, 19 Aug 2009 14:55:24 GMT Joel Sherrill [712726d] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/psx07.scn (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/task.c (modified) 2009-08-19 Joel Sherrill * ... Tue, 18 Aug 2009 18:46:21 GMT Joel Sherrill [3a121776] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp63/init.c (modified) * testsuites/sptests/sp63/sp63.scn (modified) 2009-08-18 Joel Sherrill * ... Tue, 18 Aug 2009 18:40:14 GMT Joel Sherrill [3a95c679] * cpukit/ChangeLog (modified) * cpukit/score/src/heapallocatealigned.c (modified) 2009-08-18 Joel Sherrill * ... Tue, 18 Aug 2009 16:15:16 GMT Joel Sherrill [0979426] * cpukit/ChangeLog (modified) * cpukit/score/src/heapallocatealigned.c (modified) 2009-08-18 Sebastian Huber ... Tue, 18 Aug 2009 15:37:52 GMT Joel Sherrill [7ca51e3] * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/s3c2400/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c (modified) 2009-08-18 Joel Sherrill * ... Tue, 18 Aug 2009 15:35:51 GMT Joel Sherrill [63b3dff5] * cpukit/ChangeLog (modified) * cpukit/rtems/src/timerreset.c (modified) 2009-08-18 Joel Sherrill * ... Tue, 18 Aug 2009 15:32:49 GMT Joel Sherrill [7d414c3] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/spobjgetnext/init.c (modified) * testsuites/sptests/spobjgetnext/spobjgetnext.scn (modified) 2009-08-18 Joel Sherrill * ... Tue, 18 Aug 2009 14:39:33 GMT Joel Sherrill [84f27fa] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/psx01.scn (modified) 2009-08-18 Joel Sherrill * ... Tue, 18 Aug 2009 14:15:50 GMT Joel Sherrill [804e5715] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp16/sp16.scn (modified) * testsuites/sptests/sp16/task1.c (modified) 2009-08-18 Joel Sherrill * ... Mon, 17 Aug 2009 21:18:53 GMT Joel Sherrill [6a41df1] * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) 2009-08-17 Joel Sherrill * ... Mon, 17 Aug 2009 21:18:34 GMT Joel Sherrill [118472cf] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-networking.m4 (modified) 2009-08-17 Joel Sherrill * ... Mon, 17 Aug 2009 17:44:36 GMT Joel Sherrill [4f79a900] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/configure.ac (modified) Revert configure.ac change. Mon, 17 Aug 2009 17:43:35 GMT Joel Sherrill [49325ef] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/psx05.scn (modified) 2009-08-17 Santosh G Vattam ... Mon, 17 Aug 2009 17:42:21 GMT Joel Sherrill [58dbfd7] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp65/init.c (modified) * testsuites/sptests/sp65/sp65.doc (modified) 2009-08-17 Santosh G Vattam ... Mon, 17 Aug 2009 14:25:28 GMT Till Straumann [07ed2f87] * c/src/lib/libbsp/powerpc/mvme3100/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme3100/network/if_tsec_pub.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/network/tsec.c (modified) 2009-08-17 Till Straumann ... Mon, 17 Aug 2009 13:31:20 GMT Joel Sherrill [e0d71f7] * cpukit/ChangeLog (modified) * cpukit/rtems/src/clockget.c (modified) 2009-08-17 Joel Sherrill * ... Sun, 16 Aug 2009 15:15:01 GMT Joel Sherrill [400a04a] * cpukit/ChangeLog (modified) * cpukit/libi2c/libi2c.c (modified) 2009-08-16 Joel Sherrill * ... Sat, 15 Aug 2009 22:29:38 GMT Joel Sherrill [e958d79b] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios01.scn (modified) 2009-08-15 Joel Sherrill * ... Sat, 15 Aug 2009 20:59:23 GMT Joel Sherrill [8e58208] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/termios_baud2num.c (modified) 2009-08-15 Joel Sherrill * ... Sat, 15 Aug 2009 17:54:48 GMT Joel Sherrill [4d5b156] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/termios01/.cvsignore (added) * testsuites/libtests/termios01/Makefile.am (added) * testsuites/libtests/termios01/init.c (added) * testsuites/libtests/termios01/termios01.doc (added) * testsuites/libtests/termios01/termios01.scn (added) * testsuites/libtests/termios01/termios_testdriver.c (added) * testsuites/libtests/termios01/termios_testdriver.h (added) 2009-08-15 Joel Sherrill * ... Fri, 14 Aug 2009 01:10:23 GMT Joel Sherrill [146301d] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp65/init.c (modified) * testsuites/sptests/sp65/sp65.doc (modified) * testsuites/sptests/sp65/sp65.scn (modified) 2009-08-13 Santosh G Vattam ... Thu, 13 Aug 2009 19:14:14 GMT Joel Sherrill [b1c9811] * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timer.c (modified) 2009-08-13 Joel Sherrill * ... Wed, 12 Aug 2009 20:53:33 GMT Joel Sherrill [717391f5] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/malloc_boundary.c (modified) * cpukit/sapi/include/confdefs.h (modified) 2009-08-12 Joel Sherrill * ... Wed, 12 Aug 2009 20:50:51 GMT Joel Sherrill [4e76c71] * testsuites/ChangeLog (modified) * testsuites/support/include/tmacros.h (modified) 2009-08-12 Joel Sherrill * ... Wed, 12 Aug 2009 20:50:43 GMT Joel Sherrill [1f7ee02] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp02/task1.c (modified) * testsuites/sptests/sp02/task2.c (modified) * testsuites/sptests/sp02/task3.c (modified) * testsuites/sptests/sp03/task2.c (modified) * testsuites/sptests/sp05/task1.c (modified) * testsuites/sptests/sp05/task2.c (modified) * testsuites/sptests/sp05/task3.c (modified) * testsuites/sptests/sp06/task1.c (modified) * testsuites/sptests/sp06/task2.c (modified) * testsuites/sptests/sp09/screen02.c (modified) * testsuites/sptests/sp09/screen04.c (modified) * testsuites/sptests/sp09/screen06.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen10.c (modified) * testsuites/sptests/sp09/screen12.c (modified) * testsuites/sptests/sp09/screen13.c (modified) * testsuites/sptests/sp09/screen14.c (modified) * testsuites/sptests/sp11/task1.c (modified) * testsuites/sptests/sp11/task2.c (modified) * testsuites/sptests/sp12/pridrv.c (modified) * testsuites/sptests/sp12/pritask.c (modified) * testsuites/sptests/sp12/task1.c (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp14/task1.c (modified) * testsuites/sptests/sp16/task1.c (modified) * testsuites/sptests/sp16/task4.c (modified) * testsuites/sptests/sp19/fptask.c (modified) * testsuites/sptests/sp19/task1.c (modified) * testsuites/sptests/sp22/task1.c (modified) * testsuites/sptests/sp24/task1.c (modified) * testsuites/sptests/sp26/task1.c (modified) * testsuites/sptests/sp29/init.c (modified) * testsuites/sptests/sp30/task1.c (modified) * testsuites/sptests/sp31/task1.c (modified) * testsuites/sptests/sp33/init.c (modified) * testsuites/sptests/sp45/init.c (modified) * testsuites/sptests/sp46/init.c (modified) * testsuites/sptests/sp50/init.c (modified) * testsuites/sptests/spintrcritical06/init.c (modified) * testsuites/sptests/spwatchdog/task1.c (modified) 2009-08-12 Joel Sherrill * ... Wed, 12 Aug 2009 20:50:38 GMT Joel Sherrill [99f09711] * testsuites/samples/ChangeLog (modified) * testsuites/samples/cdtest/main.cc (modified) * testsuites/samples/fileio/init.c (modified) * testsuites/samples/fileio/system.h (modified) * testsuites/samples/pppd/pppdapp.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) 2009-08-12 Joel Sherrill * ...
