# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/17/24 16:55:04 Mon, 09 Mar 2009 17:00:20 GMT Joel Sherrill [cdb6eae] * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/bsp.h (modified) 2009-03-09 Sebastian Huber ... Mon, 09 Mar 2009 16:53:27 GMT Joel Sherrill [94da794] * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) 2009-03-09 Antoine Lacroix ... Mon, 09 Mar 2009 14:11:23 GMT Joel Sherrill [f855b9e3] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) 2009-03-09 Joel Sherrill ... Mon, 09 Mar 2009 13:57:53 GMT Ralf Corsepius [57224657] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090309.diff (modified) Update. Mon, 09 Mar 2009 12:40:23 GMT Ralf Corsepius [59369291] * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) Bump release. Mon, 09 Mar 2009 12:37:55 GMT Ralf Corsepius [0c614d16] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090309.diff (added) newlib/libc/machine/powerpc/times.c: Remove. Fri, 06 Mar 2009 20:08:20 GMT Joel Sherrill [17175bbd] * cpukit/ChangeLog (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) 2009-03-06 Joel Sherrill * ... Thu, 05 Mar 2009 22:27:19 GMT Eric Norum [ac4dd0b] * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) With Till, Joel and Eric all trying to fix this file things seem to ... Thu, 05 Mar 2009 21:17:55 GMT Till Straumann [05b0c8a] * c/src/lib/libbsp/powerpc/mvme3100/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/start/start.S (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) 2009-03-05 Till Straumann ... Thu, 05 Mar 2009 21:15:17 GMT Till Straumann [0f2852d] * c/src/lib/libbsp/powerpc/mvme3100/ChangeLog (modified) 2009-03-05 Till Straumann ... Thu, 05 Mar 2009 21:10:07 GMT Till Straumann [b0d9310] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) 2009-03-05 Till Straumann ... Thu, 05 Mar 2009 21:07:01 GMT Till Straumann [6987eecc] * c/src/lib/libbsp/powerpc/mvme3100/flash/flashcfg.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c (modified) 2009-03-05 Till Straumann ... Thu, 05 Mar 2009 21:05:13 GMT Till Straumann [7e7f6d7] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.h (modified) 2009-03-05 Till Straumann ... Thu, 05 Mar 2009 20:09:59 GMT Till Straumann [ad82bec] * c/src/lib/libbsp/powerpc/shared/startup/sbrk.c (modified) - must return original memory size in *heap_size_p if policy == -1 Thu, 05 Mar 2009 13:45:06 GMT Thomas Doerfler [21ae805] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) * shared/clock/clock.c: Standard decrementer exception is now more ... Thu, 05 Mar 2009 12:16:22 GMT Joel Sherrill [eb7ee96] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) 2009-03-05 Sebastian Huber ... Tue, 03 Mar 2009 12:20:30 GMT Joel Sherrill [b96bd98] * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/console/console.c (modified) 2009-03-02 Joel Sherrill * ... Tue, 03 Mar 2009 00:10:56 GMT Joel Sherrill [f0f8e4de] * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/include/bsp.h (modified) * c/src/lib/libbsp/nios2/nios2_iss/preinstall.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/setvec.c (modified) 2009-03-02 Joel Sherrill * ... Mon, 02 Mar 2009 18:57:11 GMT Joel Sherrill [188a3fc] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) 2009-03-02 Till Straumann ... Mon, 02 Mar 2009 18:34:12 GMT Joel Sherrill [b7f49f7] * cpukit/score/cpu/nios2/ChangeLog (modified) * cpukit/score/cpu/nios2/cpu_asm.S (modified) 2009-03-02 Joel Sherrill * ... Mon, 02 Mar 2009 18:10:34 GMT Joel Sherrill [7246c8e9] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/protectedheap.h (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/src/pheapgetsize.c (added) 2009-03-02 Joel Sherrill * ... Mon, 02 Mar 2009 17:28:28 GMT Joel Sherrill [6387939] * testsuites/samples/ChangeLog (modified) * testsuites/samples/cdtest/main.cc (modified) 2009-03-02 Joel Sherrill * ... Mon, 02 Mar 2009 17:27:54 GMT Joel Sherrill [27d29e18] * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds (modified) 2009-03-02 Daniel Hellstrom PR ... Mon, 02 Mar 2009 17:10:31 GMT Joel Sherrill [bdc8d46] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/shared/irq/irq_asm.S (modified) 2009-03-02 Ray Xu * ... Mon, 02 Mar 2009 17:03:10 GMT Joel Sherrill [b9005867] * c/src/lib/libbsp/arm/rtl22xx/ChangeLog (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) 2009-03-02 Ray Xu PR 1380/bsps ... Mon, 02 Mar 2009 16:12:49 GMT Joel Sherrill [8c324aa] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/sp09.scn (modified) 2009-03-02 Joel Sherrill ... Mon, 02 Mar 2009 16:12:41 GMT Joel Sherrill [e93d791] * cpukit/ChangeLog (modified) * cpukit/rtems/src/semcreate.c (modified) 2009-03-02 Joel Sherrill ... Mon, 02 Mar 2009 15:04:02 GMT Joel Sherrill [657d23e] * doc/ChangeLog (modified) * doc/user/.cvsignore (modified) 2009-03-02 Joel Sherrill * ... Mon, 02 Mar 2009 12:12:17 GMT Joel Sherrill [f547bc8] * cpukit/score/cpu/nios2/ChangeLog (modified) * cpukit/score/cpu/nios2/cpu.c (modified) 2009-03-02 Joel Sherrill * ... Fri, 27 Feb 2009 19:19:46 GMT Joel Sherrill [eb148a26] * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.S (deleted) 2009-02-27 Joel Sherrill * ... Fri, 27 Feb 2009 18:19:33 GMT Joel Sherrill [fd234b8] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) 2009-02-27 Joel Sherrill * ... Fri, 27 Feb 2009 18:04:44 GMT Joel Sherrill [1fb9fa1c] * doc/ChangeLog (modified) * doc/common/opengroup_manpage_acknowledgement.texi (added) * doc/common/opengroup_preface_acknowledgement.texi (added) * doc/posix_users/preface.texi (modified) * doc/shell/preface.texi (modified) 2009-02-27 Joel Sherrill * ... Fri, 27 Feb 2009 16:44:55 GMT Joel Sherrill [78de0879] * testsuites/samples/ChangeLog (modified) Format. Fri, 27 Feb 2009 16:02:28 GMT Joel Sherrill [f2d3786] * doc/ChangeLog (modified) * doc/user/intr.t (modified) 2009-02-27 Joel Sherrill ... Fri, 27 Feb 2009 15:33:08 GMT Joel Sherrill [08ed3c3] * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/shared/start.S (modified) 2009-02-27 Daniel Hellstrom PR ... Fri, 27 Feb 2009 15:09:37 GMT Joel Sherrill [5d01560b] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bspgetworkarea.c (modified) 2009-02-27 Joel Sherrill * ... Fri, 27 Feb 2009 15:09:14 GMT Joel Sherrill [67cad729] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspgetworkarea.c (modified) 2009-02-27 Joel Sherrill * ... Fri, 27 Feb 2009 12:12:08 GMT Thomas Doerfler [949166d] * c/src/lib/libbsp/arm/lpc24xx/network/network.c (added) * c/src/lib/libbsp/arm/lpc24xx/startup/bspreset.c (added) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc2478 (added) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc2478_ncs (added) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc2478_ncs_ram (added) * c/src/lib/libbsp/arm/shared/startup/linkcmds.rom (added) * make/custom/lpc2478_ncs.cfg (added) * make/custom/lpc2478_ncs_ram.cfg (added) * make/custom/lpc24xx.cfg (added) added missing files Fri, 27 Feb 2009 11:26:44 GMT Thomas Doerfler [9647f7fe] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/README (modified) * c/src/lib/libbsp/arm/lpc24xx/clock/clock-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc24xx.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/system-clocks.h (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/system-clocks.c (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/ssp/ssp.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/include/start.h (modified) * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/include/utility.h (modified) * make/custom/lpc2478.cfg (modified) * README: Added NCS. * Makefile.am, configure.ac, ... Fri, 27 Feb 2009 11:25:30 GMT Thomas Doerfler [92cbf96] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/bsp_specs (modified) * bsp_specs: Added crtbegin.o and crtend.o to support global C++ ... Fri, 27 Feb 2009 11:13:52 GMT Thomas Doerfler [7a18a320] * testsuites/samples/ChangeLog (modified) * testsuites/samples/fileio/init.c (modified) Adapt to modified shell configuration Fri, 27 Feb 2009 11:10:46 GMT Thomas Doerfler [ca5bcd8] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) PR 1356 * libchip/i2c/spi-sd-card.c: Added support for high ... Fri, 27 Feb 2009 11:06:21 GMT Thomas Doerfler [cd4ed38] * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) * rtems/powerpc/registers.h: Added Freescale Book E Implementation ... Fri, 27 Feb 2009 11:03:57 GMT Thomas Doerfler [06f8e558] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libmisc/shell/shellconfig.h (modified) * libmisc/shell/shell.c, libmisc/shell/shell.h: Changed type for ... Thu, 26 Feb 2009 21:16:03 GMT Joel Sherrill [9cc70d8] * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/startup/cpu.c (modified) 2009-02-26 Joel Sherrill * ... Thu, 26 Feb 2009 20:45:48 GMT Joel Sherrill [5d64375f] * c/src/lib/libbsp/lm32/ChangeLog (modified) * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/start/start.S (modified) * c/src/lib/libbsp/lm32/shared/timer/timer.c (modified) 2009-02-26 Joel Sherrill * ... Thu, 26 Feb 2009 20:45:44 GMT Joel Sherrill [be9f085] * c/src/lib/libbsp/lm32/lm32_evr/ChangeLog (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h (modified) 2009-02-26 Joel Sherrill * ... Thu, 26 Feb 2009 17:38:05 GMT Joel Sherrill [9f127d2] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspgetworkarea.c (modified) 2009-02-26 Joel Sherrill * ... Thu, 26 Feb 2009 17:37:43 GMT Joel Sherrill [7b1d93db] * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/irq/irq.c (modified) 2009-02-26 Joel Sherrill * ... Wed, 25 Feb 2009 22:22:47 GMT Joel Sherrill [b7beebfd] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) 2009-02-25 Joel Sherrill * ... Wed, 25 Feb 2009 21:32:53 GMT Joel Sherrill [0b05a31] * c/src/lib/libbsp/lm32/ChangeLog (modified) * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) 2009-02-25 Joel Sherrill * ... Wed, 25 Feb 2009 21:32:22 GMT Joel Sherrill [4ce4084] * c/src/lib/libbsp/lm32/lm32_evr/ChangeLog (modified) * c/src/lib/libbsp/lm32/lm32_evr/README (modified) 2009-02-25 Joel Sherrill * ... Wed, 25 Feb 2009 21:31:23 GMT Joel Sherrill [74133389] * c/src/lib/libbsp/lm32/lm32_evr/ChangeLog (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/README (added) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) 2009-02-25 Joel Sherrill * ... Wed, 25 Feb 2009 16:08:07 GMT Ralf Corsepius [36944ec] * c/src/lib/libbsp/avr/ChangeLog (modified) 2009-02-25 Ralf Corsépius * ... Wed, 25 Feb 2009 07:42:28 GMT Ralf Corsepius [d35ffd68] * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) Regenerate. Wed, 25 Feb 2009 07:42:16 GMT Ralf Corsepius [8ac2414] * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) Bump GDB_RPMREL. Wed, 25 Feb 2009 07:41:06 GMT Ralf Corsepius [d3340106] * contrib/crossrpms/gdb/gdb.add (modified) Disable lm32 simulator on mingw32. Wed, 25 Feb 2009 06:13:06 GMT Ralf Corsepius [beb5d47] * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) Regenerate. Wed, 25 Feb 2009 06:12:47 GMT Ralf Corsepius [5a994432] * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) Add gdb-6.8.50.20090224-rtems4.10-20090225.diff Wed, 25 Feb 2009 06:08:38 GMT Ralf Corsepius [5915358] * contrib/crossrpms/patches/gdb-6.8.50.20090224-rtems4.10-20090225.diff (added) New. Rebase gdb-6.8-rtems4.10-20090122.diff patch against gcc-cvs ... Tue, 24 Feb 2009 09:10:23 GMT Ralf Corsepius [88ab8f3] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate, fix spec file. Tue, 24 Feb 2009 09:09:54 GMT Ralf Corsepius [4ec1692] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GDB_RPMREL. Tue, 24 Feb 2009 09:04:51 GMT Ralf Corsepius [19409e42] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Tue, 24 Feb 2009 09:03:38 GMT Ralf Corsepius [47616e9e] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) GCC_RPMREL = 8 Tue, 24 Feb 2009 09:03:21 GMT Ralf Corsepius [9702d56] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.17.0-rtems4.10-20090224.diff Tue, 24 Feb 2009 07:44:15 GMT Ralf Corsepius [f1a96d9] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090224.diff (added) * libc/unix/ttyname.c: Sync with newlib-cvs. * ... Tue, 24 Feb 2009 05:47:47 GMT Ralf Corsepius [ddde079] * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) Regenerate. Tue, 24 Feb 2009 05:47:03 GMT Ralf Corsepius [a0785556] * contrib/crossrpms/gdb/gdb.add (modified) Use "%{?suse}" >= "10.3" to detect suse Tue, 24 Feb 2009 05:36:05 GMT Ralf Corsepius [8a6a2fd] * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (added) New. Tue, 24 Feb 2009 05:35:34 GMT Ralf Corsepius [5e40650] * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) Activate GDB. Tue, 24 Feb 2009 05:34:13 GMT Ralf Corsepius [946dcf8] * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) Use a gdb-snapshot. Tue, 24 Feb 2009 05:31:05 GMT Ralf Corsepius [cd9e9b55] * contrib/crossrpms/gdb/build.add (modified) Disable python. Mon, 23 Feb 2009 16:47:05 GMT Ralf Corsepius [a057a6c] * c/src/lib/libbsp/lm32/lm32_evr/ChangeLog (modified) 2009-02-23 Ralf Corsépius * ... Mon, 23 Feb 2009 16:46:05 GMT Ralf Corsepius [12aa044] * c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h (modified) Conditionally include rtems/rtems_bsdnet.h. Mon, 23 Feb 2009 16:46:04 GMT Ralf Corsepius [f8d9da4] * c/src/lib/libbsp/lm32/lm32_evr/ChangeLog (modified) 2009-02-23 Ralf Corsépius * ... Mon, 23 Feb 2009 16:45:59 GMT Ralf Corsepius [a825e53] * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) Rework. Mon, 23 Feb 2009 16:45:48 GMT Ralf Corsepius [f4249583] * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) Add RTEMS_CHECK_NETWORKING. Mon, 23 Feb 2009 10:22:24 GMT Ralf Corsepius [e01c09d4] * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (added) Regenerate. Mon, 23 Feb 2009 10:21:43 GMT Ralf Corsepius [d636a27] * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) Update. Mon, 23 Feb 2009 10:21:25 GMT Ralf Corsepius [851c7cac] * contrib/crossrpms/rtems4.10/lm32/binutils-sources.add (modified) binutils-2.19.51-20090222. Mon, 23 Feb 2009 10:20:54 GMT Ralf Corsepius [178c339] * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) Activate GCC-4.3.3 Mon, 23 Feb 2009 10:19:26 GMT Ralf Corsepius [ba6f8124] * contrib/crossrpms/patches/gcc-core-4.3.3-rtems4.10-20090223.diff (added) * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090222.diff (added) Add lm32 Sun, 22 Feb 2009 04:54:16 GMT Ralf Corsepius [e1ae901] * contrib/crossrpms/configure.ac (modified) Add lm32. Sun, 22 Feb 2009 04:51:10 GMT Ralf Corsepius [da589d0] * contrib/crossrpms/rtems4.10/lm32/.cvsignore (added) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (added) * contrib/crossrpms/rtems4.10/lm32/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/lm32/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (added) New. Sun, 22 Feb 2009 04:50:05 GMT Ralf Corsepius [12af6f7] * contrib/crossrpms/rtems4.10/Makefile.am (modified) Add lm32 Sun, 22 Feb 2009 04:22:55 GMT Ralf Corsepius [a2b76fdf] * contrib/crossrpms/autotools/automake-sources.add (added) * contrib/crossrpms/patches/automake-1.10.2-rtems4.10-20090222.diff (added) New. Sun, 22 Feb 2009 04:22:17 GMT Ralf Corsepius [2276acc0] * contrib/crossrpms/autotools/rtems-4.10-automake.spec (modified) Regenerate. Sun, 22 Feb 2009 04:21:18 GMT Ralf Corsepius [d129b56] * contrib/crossrpms/autotools/Makefile.am (modified) Bump version. Sun, 22 Feb 2009 04:20:44 GMT Ralf Corsepius [bef54816] * contrib/crossrpms/autotools/automake.add (modified) Add @SOURCES@, PATCH0. Sun, 22 Feb 2009 04:19:52 GMT Ralf Corsepius [024eb28] * contrib/crossrpms/autotools/automake.am (modified) Add automake-sources.add. Sat, 21 Feb 2009 14:02:11 GMT Joel Sherrill [09b73cf] * c/src/lib/libbsp/lm32/lm32_evr/ChangeLog (modified) * c/src/lib/libbsp/lm32/lm32_evr/startup/linkcmds (modified) 2009-02-21 Michael Walle * ... Fri, 20 Feb 2009 16:47:37 GMT Ralf Corsepius [4ee7d75] * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) 2009-02-17 Ralf Corsépius * ... Fri, 20 Feb 2009 16:12:53 GMT Ralf Corsepius [0bff7f8] * cpukit/include/sys/priority.h (added) New. Fri, 20 Feb 2009 14:29:23 GMT Ralf Corsepius [730f141] * cpukit/preinstall.am (modified) Regenerate. Fri, 20 Feb 2009 14:28:45 GMT Ralf Corsepius [d7f6e5c] * cpukit/ChangeLog (modified) 2009-02-20 Ralf Corsepius * ... Fri, 20 Feb 2009 14:27:38 GMT Ralf Corsepius [b4a2209] * cpukit/Makefile.am (modified) Add include/sys/priority.h. Fri, 20 Feb 2009 10:10:16 GMT Ralf Corsepius [6c3fa5b] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Fri, 20 Feb 2009 10:03:21 GMT Ralf Corsepius [273b931] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090220.diff (added) Split ttyname.c/ttyname_r.c Thu, 19 Feb 2009 21:34:09 GMT Joel Sherrill [f239aa9a] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) 2009-02-19 Joel Sherrill * ... Thu, 19 Feb 2009 21:23:59 GMT Joel Sherrill [a064ef5] * make/ChangeLog (modified) * make/custom/simsh2e.cfg (added) 2009-02-19 Joel Sherrill * ...
