# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/20/24 20:36:53 Wed, 08 Aug 2007 03:36:15 GMT Ralf Corsepius [92b76712] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Wed, 08 Aug 2007 03:30:27 GMT Ralf Corsepius [ff3a2d87] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:30:15 GMT Ralf Corsepius [5d991cf] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Wed, 08 Aug 2007 03:21:54 GMT Ralf Corsepius [3675f57] * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) Regenerate. Wed, 08 Aug 2007 03:21:29 GMT Ralf Corsepius [8d25d2e] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) GCC_RPMREL = 23. Rebuild against binutils-2.17.90 Tue, 07 Aug 2007 15:41:57 GMT Ralf Corsepius [c48c3590] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (modified) BINUTILS_RPMREL = 2 Tue, 07 Aug 2007 15:38:23 GMT Ralf Corsepius [4907b96] * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (modified) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (modified) Regenerate. Tue, 07 Aug 2007 15:38:10 GMT Ralf Corsepius [90aab6d] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) Enable infos for binutils. Tue, 07 Aug 2007 15:21:40 GMT Ralf Corsepius [69fb982] * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/binutils-sources.add (modified) Upgrade to binutils-2.17.90. Tue, 07 Aug 2007 15:15:42 GMT Ralf Corsepius [039d51b] * contrib/crossrpms/rtems4.8/arm/rtems-4.8-arm-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/avr/rtems-4.8-avr-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/h8300/rtems-4.8-h8300-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/i386/rtems-4.8-i386-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/mips/rtems-4.8-mips-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/powerpc/rtems-4.8-powerpc-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/sh/rtems-4.8-sh-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/sparc/rtems-4.8-sparc-rtems4.8-binutils.spec (added) * contrib/crossrpms/rtems4.8/tic4x/rtems-4.8-tic4x-rtems4.8-binutils.spec (added) Regenerate. Tue, 07 Aug 2007 14:44:58 GMT Joel Sherrill [bf2a6539] * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/preinstall.am (modified) 2007-08-07 Joel Sherrill * ... Tue, 07 Aug 2007 14:39:50 GMT Joel Sherrill [c3b6484f] * VERSION (modified) * aclocal/version.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/aclocal/version.m4 (modified) Upgrade to 4.7.99.2 Tue, 07 Aug 2007 14:33:53 GMT Joel Sherrill [ecda1e42] * ChangeLog (modified) * Makefile.maint (modified) 2007-08-07 Joel Sherrill * ... Tue, 07 Aug 2007 08:20:59 GMT Ralf Corsepius [cae995d] * contrib/crossrpms/patches/binutils-2.17.90-rtems4.8-20070807.diff (added) New. Mon, 06 Aug 2007 13:54:05 GMT Joel Sherrill [8ba985a] * ChangeLog (modified) * README.configure (modified) * aclocal/bsp-alias.m4 (modified) 2007-08-06 Joel Sherrill * ... Mon, 06 Aug 2007 13:53:41 GMT Joel Sherrill [e06e586d] * make/ChangeLog (modified) * make/custom/icecube.cfg (modified) 2007-08-06 Joel Sherrill * ... Mon, 06 Aug 2007 13:53:30 GMT Joel Sherrill [1abae10] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/README.IceCube (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen5200/vectors/vectors.S (modified) 2007-08-06 Joel Sherrill * ... Sun, 05 Aug 2007 04:45:02 GMT Ralf Corsepius [06119b8] * make/ChangeLog (modified) * make/custom/mcf5235.cfg (modified) 2007-08-05 Ralf Corsépius * ... Sun, 05 Aug 2007 04:43:56 GMT Ralf Corsepius [9fa95f8d] * make/ChangeLog (modified) * make/custom/av5282.cfg (modified) 2007-08-05 Ralf Corsépius * ... Sun, 05 Aug 2007 04:42:00 GMT Ralf Corsepius [edcec26] * make/ChangeLog (modified) * make/custom/gen83xx.cfg (modified) 2007-08-05 Ralf Corsépius * ... Sat, 04 Aug 2007 08:21:33 GMT Ralf Corsepius [3ffefc3] * contrib/crossrpms/rtems4.8/m68k/rtems-4.8-m68k-rtems4.8-gcc.spec (modified) Sync. Sat, 04 Aug 2007 08:20:59 GMT Ralf Corsepius [9e84b8e8] * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) GCC_RPMREL = 22. Sat, 04 Aug 2007 08:20:43 GMT Ralf Corsepius [55230f2e] * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) Update to gcc-core-4.2.1-rtems4.8-20070804.diff. Sat, 04 Aug 2007 08:18:14 GMT Ralf Corsepius [5332bc6e] * contrib/crossrpms/patches/gcc-core-4.2.1-rtems4.8-20070804.diff (added) Add m68k -m528x. Sat, 04 Aug 2007 06:24:12 GMT Chris Johns [56f6b907] * contrib/mingw/ChangeLog (modified) * contrib/mingw/build-exes.sh (modified) * contrib/mingw/msys-path.nsi (modified) * contrib/mingw/rtems-autotools.nsi (modified) * contrib/mingw/rtems-tools.nsi (modified) * contrib/mingw/rtems.ini (modified) * contrib/mingw/rtems_logo.bmp (modified) * contrib/mingw/upload.sh (modified) * contrib/mingw/version (modified) 2007-08-03 Chris Johns * ... Sat, 04 Aug 2007 06:13:39 GMT Ralf Corsepius [26ccaab0] * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/rtems-4.8-bfin-rtems4.8-gcc.spec (modified) GCC_RPMREL = 21 Sat, 04 Aug 2007 06:10:36 GMT Ralf Corsepius [44ad1151] * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) 2007-08-04 Ralf Corsépius * ... Sat, 04 Aug 2007 06:07:58 GMT Ralf Corsepius [67a1034] * cpukit/ChangeLog (modified) Remove bogus ChangeLog entry. Sat, 04 Aug 2007 06:07:30 GMT Ralf Corsepius [72b4469] * cpukit/score/cpu/mips/ChangeLog (modified) 2007-08-04 Ralf Corsépius * ... Sat, 04 Aug 2007 06:06:26 GMT Ralf Corsepius [11f2bf59] * cpukit/ChangeLog (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) 2007-08-04 Ralf Corsépius * ... Sat, 04 Aug 2007 06:03:04 GMT Ralf Corsepius [31139c3] * contrib/crossrpms/rtems4.8/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.8/tic4x/gcc-sources.add (modified) Update to newlib-1.15.0-rtems4.8-20070804.diff Sat, 04 Aug 2007 05:45:16 GMT Ralf Corsepius [787ca182] * c/src/make/ChangeLog (modified) * c/src/make/bsp.cfg.in (modified) * c/src/make/target.cfg.in (modified) 2007-08-04 Ralf Corsépius * ... Sat, 04 Aug 2007 04:34:30 GMT Ralf Corsepius [b39173b0] * contrib/crossrpms/patches/newlib-1.15.0-rtems4.8-20070804.diff (added) Add tar.h. Fri, 03 Aug 2007 15:22:44 GMT Joel Sherrill [2154cd3] * c/src/lib/libbsp/bfin/ChangeLog (modified) * c/src/lib/libbsp/bfin/shared/start/start.S (modified) 2007-08-03 Joel Sherrill * ... Thu, 02 Aug 2007 15:01:29 GMT Joel Sherrill [27ccd807] * ChangeLog (modified) * Makefile.maint (modified) * aclocal/enable-rdbg.m4 (deleted) * configure.ac (modified) * release_support (modified) 2007-08-02 Joel Sherrill * ... Thu, 02 Aug 2007 15:00:07 GMT Joel Sherrill [261f99bd] * c/src/ChangeLog (modified) * c/src/aclocal/check-rdbg.m4 (deleted) * c/src/aclocal/enable-rdbg.m4 (deleted) * c/src/configure.ac (modified) * c/src/librdbg/.cvsignore (deleted) * c/src/librdbg/Makefile.am (deleted) * c/src/librdbg/include/rdbg/i386/rdbg_f.h (deleted) * c/src/librdbg/include/rdbg/i386/reg.h (deleted) * c/src/librdbg/include/rdbg/m68k/rdbg_f.h (deleted) * c/src/librdbg/include/rdbg/m68k/reg.h (deleted) * c/src/librdbg/include/rdbg/powerpc/rdbg_f.h (deleted) * c/src/librdbg/include/rdbg/powerpc/reg.h (deleted) * c/src/librdbg/include/rdbg/rdbg.h (deleted) * c/src/librdbg/include/rdbg/servrpc.h (deleted) * c/src/librdbg/preinstall.am (deleted) * c/src/librdbg/src/_servtgt.c (deleted) * c/src/librdbg/src/awk.svc (deleted) * c/src/librdbg/src/excep.c (deleted) * c/src/librdbg/src/i386/any/remdeb.h (deleted) * c/src/librdbg/src/i386/any/remdeb_f.x (deleted) * c/src/librdbg/src/i386/any/remdeb_svc.c (deleted) * c/src/librdbg/src/i386/any/remdeb_xdr.c (deleted) * c/src/librdbg/src/i386/excep_f.c (deleted) * c/src/librdbg/src/i386/rdbg_cpu_asm.S (deleted) * c/src/librdbg/src/i386/rdbg_f.c (deleted) * c/src/librdbg/src/m68k/any/remdeb.h (deleted) * c/src/librdbg/src/m68k/any/remdeb_f.x (deleted) * c/src/librdbg/src/m68k/any/remdeb_svc.c (deleted) * c/src/librdbg/src/m68k/any/remdeb_xdr.c (deleted) * c/src/librdbg/src/m68k/excep_f.c (deleted) * c/src/librdbg/src/m68k/rdbg_cpu_asm.S (deleted) * c/src/librdbg/src/m68k/rdbg_f.c (deleted) * c/src/librdbg/src/powerpc/excep_f.c (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb.h (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_f.x (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_svc.c (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c (deleted) * c/src/librdbg/src/powerpc/rdbg_cpu_asm.S (deleted) * c/src/librdbg/src/powerpc/rdbg_f.c (deleted) * c/src/librdbg/src/ptrace.c (deleted) * c/src/librdbg/src/rdbg.c (deleted) * c/src/librdbg/src/remdeb.x (deleted) * c/src/librdbg/src/servbkpt.c (deleted) * c/src/librdbg/src/servcon.c (deleted) * c/src/librdbg/src/servrpc.c (deleted) * c/src/librdbg/src/servtgt.c (deleted) * c/src/librdbg/src/servtsp.c (deleted) * c/src/librdbg/src/servutil.c (deleted) * c/src/wrapup/Makefile.am (modified) 2007-08-02 Joel Sherrill * ... Thu, 02 Aug 2007 14:59:41 GMT Joel Sherrill [51131354] * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) 2007-08-02 Joel Sherrill * ... Thu, 02 Aug 2007 14:59:16 GMT Joel Sherrill [00de6ac] * doc/ChangeLog (modified) * doc/Makefile.am (modified) * doc/configure.ac (modified) * doc/develenv/direct.t (modified) * doc/rgdb_specs/.cvsignore (deleted) * doc/rgdb_specs/Makefile.am (deleted) * doc/rgdb_specs/comm.t (deleted) * doc/rgdb_specs/conclusion.t (deleted) * doc/rgdb_specs/daemon.t (deleted) * doc/rgdb_specs/gdbinternals.t (deleted) * doc/rgdb_specs/interfacing.t (deleted) * doc/rgdb_specs/intro.t (deleted) * doc/rgdb_specs/layers.eps (deleted) * doc/rgdb_specs/layers.jpg (deleted) * doc/rgdb_specs/layers.txt (deleted) * doc/rgdb_specs/objectives.t (deleted) * doc/rgdb_specs/process.eps (deleted) * doc/rgdb_specs/process.jpg (deleted) * doc/rgdb_specs/process.txt (deleted) * doc/rgdb_specs/revision.t (deleted) * doc/rgdb_specs/rgdb_specs.texi (deleted) * doc/rgdb_specs/seqbreak.eps (deleted) * doc/rgdb_specs/seqbreak.jpg (deleted) * doc/rgdb_specs/seqbreak.txt (deleted) * doc/rgdb_specs/seqdetach.eps (deleted) * doc/rgdb_specs/seqdetach.jpg (deleted) * doc/rgdb_specs/seqdetach.txt (deleted) * doc/rgdb_specs/seqinit.eps (deleted) * doc/rgdb_specs/seqinit.jpg (deleted) * doc/rgdb_specs/seqinit.txt (deleted) * doc/rtems_gdb/.cvsignore (deleted) * doc/rtems_gdb/Makefile.am (deleted) * doc/rtems_gdb/commands.t (deleted) * doc/rtems_gdb/example.t (deleted) * doc/rtems_gdb/intro.t (deleted) * doc/rtems_gdb/rtems_gdb.texi (deleted) * doc/rtems_gdb/started.t (deleted) * doc/rtems_gdb/swarch.t (deleted) * doc/rtems_gdb/trouble.t (deleted) 2007-08-02 Joel Sherrill * ... Thu, 02 Aug 2007 14:56:32 GMT Joel Sherrill [0c640d3d] * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/cmds (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/cmds (modified) 2007-08-02 Joel Sherrill * ... Thu, 02 Aug 2007 13:54:07 GMT Joel Sherrill [dd3e53e] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/showbats.c (added) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) 2007-08-02 Joel Sherrill * ... Thu, 02 Aug 2007 13:53:12 GMT Joel Sherrill [403fe9a] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) 2007-08-02 Joel Sherrill * ... Thu, 02 Aug 2007 13:51:14 GMT Joel Sherrill [65762c81] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/cpuinit.c (modified) * c/src/lib/libbsp/powerpc/gen5200/vectors/vectors_init.c (modified) 2007-08-02 Joel Sherrill * ... Thu, 02 Aug 2007 13:45:18 GMT Joel Sherrill [67ef0f1] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) 2007-08-02 Joel Sherrill * ... Wed, 01 Aug 2007 21:51:23 GMT Joel Sherrill [5797b67] * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c (modified) 2007-08-01 Joel Sherrill * ... Wed, 01 Aug 2007 00:49:03 GMT Joel Sherrill [eec7c441] * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/preinstall.am (modified) 2007-07-31 Joel Sherrill * ... Wed, 01 Aug 2007 00:44:05 GMT Joel Sherrill [51b6226] * cpukit/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2007-07-31 Joel Sherrill ... Tue, 31 Jul 2007 20:23:52 GMT Joel Sherrill [8661209] * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) 2007-07-31 Joel Sherrill ... Tue, 31 Jul 2007 16:48:47 GMT Ralf Corsepius [ee69dc6] * cpukit/score/cpu/m68k/ChangeLog (modified) 2007-07-31 Ralf Corsépius * ... Tue, 31 Jul 2007 16:48:38 GMT Ralf Corsepius [97c73ed] * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) Replace M68K_COLDFIRE_ARCH with __mcoldfire__. Tue, 31 Jul 2007 06:35:10 GMT Ralf Corsepius [4d03577] * cpukit/ChangeLog (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) 2007-07-31 Ralf Corsépius * ... Mon, 30 Jul 2007 17:14:10 GMT Ralf Corsepius [3a8d083] * cpukit/ChangeLog (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.h (modified) 2007-07-30 Ralf Corsépius * ... Mon, 30 Jul 2007 08:16:53 GMT Ralf Corsepius [edc4bbd] * cpukit/ChangeLog (modified) * cpukit/shttpd/log.c (modified) changes Mon, 30 Jul 2007 07:54:14 GMT Ralf Corsepius [f29163ab] * cpukit/ChangeLog (modified) * cpukit/shttpd/log.c (modified) 2007-07-30 Ralf Corsépius * ... Sat, 28 Jul 2007 08:31:57 GMT Chris Johns [f6cd0db] * contrib/mingw/ChangeLog (modified) * contrib/mingw/README (modified) * contrib/mingw/autoconf.def (added) * contrib/mingw/automake.def (added) * contrib/mingw/ba-wrap.sh (added) * contrib/mingw/build-autotools.sh (added) * contrib/mingw/build-exes.sh (modified) * contrib/mingw/build-rpms.sh (modified) * contrib/mingw/msys-path.nsi (added) * contrib/mingw/rtems-autotools.nsi (added) * contrib/mingw/rtems-tools.nsi (modified) * contrib/mingw/rtems.ini (modified) * contrib/mingw/target-section-text (added) * contrib/mingw/upload.sh (added) * contrib/mingw/version (added) 2007-07-28 Chris Johns * README, ... Sat, 28 Jul 2007 04:40:16 GMT Ralf Corsepius [e4a22331] * make/ChangeLog (modified) * make/custom/Linux-posix.cfg (modified) 2007-07-28 Ralf Corsépius * ... Sat, 28 Jul 2007 04:39:30 GMT Ralf Corsepius [e073007] * make/ChangeLog (modified) * make/custom/rbtx4938.cfg (modified) 2007-07-28 Ralf Corsépius * ... Sat, 28 Jul 2007 04:38:40 GMT Ralf Corsepius [14c415f] * make/ChangeLog (modified) * make/custom/rtl22xx.cfg (modified) 2007-07-28 Ralf Corsépius * ... Sat, 28 Jul 2007 04:37:49 GMT Ralf Corsepius [ae590b41] * make/ChangeLog (modified) Fix typo. Sat, 28 Jul 2007 04:37:28 GMT Ralf Corsepius [74cde4d] * make/ChangeLog (modified) * make/custom/virtex.cfg (modified) 2007-07-28 Ralf Corsépius * ... Fri, 27 Jul 2007 16:35:15 GMT Ralf Corsepius [2aaa1643] * c/src/ChangeLog (modified) * c/src/nfsclient/src/dirutils.c (modified) 2007-07-27 Ralf Corsépius * ... Fri, 27 Jul 2007 13:37:36 GMT Joel Sherrill [15b81bb] * c/src/lib/libbsp/powerpc/virtex/ChangeLog (modified) Formatting. Fri, 27 Jul 2007 06:39:21 GMT Thomas Doerfler [ab66cf0d] * c/src/lib/libbsp/powerpc/virtex/ChangeLog (modified) * c/src/lib/libbsp/powerpc/virtex/startup/linkcmds (modified) removed superfluous bss section Fri, 27 Jul 2007 03:58:04 GMT Chris Johns [735892e3] * c/src/ChangeLog (modified) 2007-07-27 Chris Johns * ... Fri, 27 Jul 2007 03:55:49 GMT Chris Johns [0630d52] * cpukit/ChangeLog (modified) 2007-07-27 Chris Johns * ... Fri, 27 Jul 2007 03:51:31 GMT Chris Johns [8d8e6e7d] * cpukit/wrapup/Makefile.am (modified) 2007-07-27i Chris Johns * ... Fri, 27 Jul 2007 03:50:16 GMT Chris Johns [6232750] * c/src/wrapup/Makefile.am (modified) 2007-07-27 Chris Johns * ... Thu, 26 Jul 2007 09:31:41 GMT Ralf Corsepius [462b28d] * contrib/crossrpms/cygwin/i686/libncurses-devel.add (modified) chmod +x etc/postinstall/libncurses-devel.sh Thu, 26 Jul 2007 09:19:22 GMT Ralf Corsepius [5a379b01] * contrib/crossrpms/cygwin/i686/libncurses-devel.add (modified) Don't use sed -i. Thu, 26 Jul 2007 09:19:02 GMT Ralf Corsepius [1b1452b6] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) NCURSES_RPMREL = 0.20070726.1 Thu, 26 Jul 2007 06:12:29 GMT Ralf Corsepius [8eea24b] * cpukit/ChangeLog (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/pci.h (modified) 2007-07-26 Ralf Corsépius * ... Thu, 26 Jul 2007 05:29:47 GMT Ralf Corsepius [ef38e6ca] * c/src/ChangeLog (modified) * c/src/nfsclient/src/rpcio.c (modified) 2007-07-26 Ralf Corsépius * ... Wed, 25 Jul 2007 09:33:59 GMT Ralf Corsepius [433ea5f] * c/src/nfsclient/Makefile.am (modified) Cleanup. Wed, 25 Jul 2007 09:33:23 GMT Ralf Corsepius [9faed348] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2007-07-25 Ralf Corsépius * ... Wed, 25 Jul 2007 09:32:37 GMT Ralf Corsepius [6e6267bb] * c/src/ChangeLog (modified) 2007-07-25 Ralf Corsépius * ... Wed, 25 Jul 2007 09:31:27 GMT Ralf Corsepius [bb9dd72] * c/src/nfsclient/preinstall.am (added) Regenerate. Wed, 25 Jul 2007 05:57:07 GMT Ralf Corsepius [c91dc45] * c/src/nfsclient/.cvsignore (added) * c/src/nfsclient/Makefile.am (added) New. Wed, 25 Jul 2007 05:47:18 GMT Ralf Corsepius [1f3d2bd] * c/src/nfsclient/Makefile (deleted) * c/src/nfsclient/proto/Makefile (deleted) * c/src/nfsclient/src/Makefile (deleted) Remove. Wed, 25 Jul 2007 05:42:02 GMT Ralf Corsepius [adb1a08] * c/src/ChangeLog (modified) 2007-07-25 Ralf Corsépius * ... Wed, 25 Jul 2007 05:41:48 GMT Ralf Corsepius [526cfa8] * c/src/nfsclient/ChangeLog (deleted) Remove (Rename into ChangeLog.slac). Wed, 25 Jul 2007 05:41:25 GMT Ralf Corsepius [228a9b1] * c/src/nfsclient/ChangeLog.slac (added) New (Renamed from ChangeLog). Wed, 25 Jul 2007 05:38:29 GMT Ralf Corsepius [516f2d7] * c/src/ChangeLog (modified) 2007-07-25 Ralf Corsépius * ... Wed, 25 Jul 2007 05:22:23 GMT Ralf Corsepius [ee08e081] * c/src/nfsclient/ChangeLog (added) * c/src/nfsclient/LICENSE (added) * c/src/nfsclient/Makefile (added) * c/src/nfsclient/README (added) * c/src/nfsclient/proto/Makefile (added) * c/src/nfsclient/proto/mount_prot.h (added) * c/src/nfsclient/proto/mount_prot.x (added) * c/src/nfsclient/proto/mount_prot_xdr.c (added) * c/src/nfsclient/proto/nfs_prot.h (added) * c/src/nfsclient/proto/nfs_prot.x (added) * c/src/nfsclient/proto/nfs_prot_xdr.c (added) * c/src/nfsclient/rfc1094.txt (added) * c/src/nfsclient/rtems-filesystem-patch (added) * c/src/nfsclient/src/Makefile (added) * c/src/nfsclient/src/cexphelp.c (added) * c/src/nfsclient/src/dirutils.c (added) * c/src/nfsclient/src/librtemsNfs.h (added) * c/src/nfsclient/src/nfs.c (added) * c/src/nfsclient/src/nfs.modini.c (added) * c/src/nfsclient/src/nfsTest.c (added) * c/src/nfsclient/src/rpcio.c (added) * c/src/nfsclient/src/rpcio.h (added) * c/src/nfsclient/src/rpcio.modini.c (added) * c/src/nfsclient/src/sock_mbuf.c (added) * c/src/nfsclient/src/xdr_mbuf.c (added) This commit was generated by cvs2svn to compensate for changes in ... Wed, 25 Jul 2007 05:22:23 GMT Ralf Corsepius [c589ebc8] * c/src/nfsclient/ChangeLog (added) * c/src/nfsclient/LICENSE (added) * c/src/nfsclient/Makefile (added) * c/src/nfsclient/README (added) * c/src/nfsclient/proto/Makefile (added) * c/src/nfsclient/proto/mount_prot.h (added) * c/src/nfsclient/proto/mount_prot.x (added) * c/src/nfsclient/proto/mount_prot_xdr.c (added) * c/src/nfsclient/proto/nfs_prot.h (added) * c/src/nfsclient/proto/nfs_prot.x (added) * c/src/nfsclient/proto/nfs_prot_xdr.c (added) * c/src/nfsclient/rfc1094.txt (added) * c/src/nfsclient/rtems-filesystem-patch (added) * c/src/nfsclient/src/Makefile (added) * c/src/nfsclient/src/cexphelp.c (added) * c/src/nfsclient/src/dirutils.c (added) * c/src/nfsclient/src/librtemsNfs.h (added) * c/src/nfsclient/src/nfs.c (added) * c/src/nfsclient/src/nfs.modini.c (added) * c/src/nfsclient/src/nfsTest.c (added) * c/src/nfsclient/src/rpcio.c (added) * c/src/nfsclient/src/rpcio.h (added) * c/src/nfsclient/src/rpcio.modini.c (added) * c/src/nfsclient/src/sock_mbuf.c (added) * c/src/nfsclient/src/xdr_mbuf.c (added) Import from rtems-nfs-1.5.tgz. Tue, 24 Jul 2007 21:37:39 GMT Joel Sherrill [3462c34] * cpukit/ChangeLog (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/score/src/timespecdivide.c (modified) 2007-07-24 Joel Sherrill * ... Tue, 24 Jul 2007 21:36:45 GMT Joel Sherrill [6db35220] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/cpuuse/init.c (modified) 2007-07-24 Joel Sherrill * ... Tue, 24 Jul 2007 21:34:28 GMT Joel Sherrill [845c202] * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/preinstall.am (modified) * c/src/lib/libbsp/sh/shsim/startup/linkcmds (modified) * c/src/lib/libbsp/sh/shsim/startup/linkcmds.sim (added) 2007-07-24 Joel Sherrill * ... Tue, 24 Jul 2007 20:52:56 GMT Joel Sherrill [f10d37f] * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/main.c (modified) 2007-07-24 Joel Sherrill * ... Tue, 24 Jul 2007 20:50:35 GMT Joel Sherrill [14ee224c] * make/ChangeLog (modified) * make/custom/Linux-posix.cfg (modified) 2007-07-24 Joel Sherrill * ... Tue, 24 Jul 2007 15:46:01 GMT Joel Sherrill [59aea5d] * make/ChangeLog (modified) * make/custom/Linux-posix.cfg (modified) 2007-07-24 Joel Sherrill * ... Tue, 24 Jul 2007 15:45:42 GMT Joel Sherrill [68e6f0cc] * testsuites/samples/ChangeLog (modified) * testsuites/samples/nsecs/init.c (modified) 2007-07-24 Joel Sherrill * ... Tue, 24 Jul 2007 14:26:46 GMT Ralf Corsepius [e0d85b74] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.2/i586/Makefile.am (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Move %{?dist} into BINUTILS_RPMREL. Tue, 24 Jul 2007 14:24:43 GMT Ralf Corsepius [b8a8bfb0] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd6.2/i586/Makefile.am (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/mingw32/i686/Makefile.am (modified) * contrib/crossrpms/rtems4.8/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.8/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.8/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.8/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.8/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.8/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.8/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.8/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.8/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.8/tic4x/Makefile.am (modified) * contrib/crossrpms/solaris2.7/sparc/Makefile.am (modified) Move %{?dist} into GCC_RPMREL. Tue, 24 Jul 2007 04:27:05 GMT Ralf Corsepius [c5721b9] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Bump the date on *RPMREL Tue, 24 Jul 2007 04:06:51 GMT Ralf Corsepius [000bb343] * cpukit/ChangeLog (modified) 2007-07-24 Ralf Corsépius * ... Tue, 24 Jul 2007 04:06:32 GMT Ralf Corsepius [69079e0a] * cpukit/shttpd/defs.h (modified) Don't build most of my_* wrappers for rtems. Tue, 24 Jul 2007 04:06:09 GMT Ralf Corsepius [bccb841] * cpukit/shttpd/compat_rtems.c (modified) Don't build my_stat for rtems. Tue, 24 Jul 2007 04:05:47 GMT Ralf Corsepius [d4253cf] * cpukit/shttpd/Makefile.am (modified) Prefix all non-public symbols with _shttp_. Tue, 24 Jul 2007 03:47:09 GMT Ralf Corsepius [ee4740b] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) Add cygwin hacks. Tue, 24 Jul 2007 03:45:39 GMT Ralf Corsepius [d292aae] * contrib/crossrpms/cygwin/i686/target-zlib.add (added) * contrib/crossrpms/cygwin/i686/zlib.add (added) New. Tue, 24 Jul 2007 03:45:22 GMT Ralf Corsepius [7feadc65] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) Add zlib.
