# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 22:11:34 Thu, 25 Mar 2004 11:09:19 GMT Ralf Corsepius [8ae203e3] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2004-03-25 Ralf Corsepius * ... Thu, 25 Mar 2004 11:04:56 GMT Ralf Corsepius [a7c4e122] * testsuites/ChangeLog (modified) * testsuites/aclocal/check-custom-bsp.m4 (modified) 2004-03-25 Ralf Corsepius * ... Thu, 25 Mar 2004 10:38:16 GMT Ralf Corsepius [5a800eee] * testsuites/support/ChangeLog (modified) * testsuites/support/include/tmacros.h (modified) 2004-03-25 Ralf Corsepius * ... Thu, 25 Mar 2004 10:36:41 GMT Ralf Corsepius [d04abc83] * testsuites/ChangeLog (modified) * testsuites/aclocal/check-custom-bsp.m4 (modified) * testsuites/aclocal/rtems-top.m4 (modified) 2004-03-25 Ralf Corsepius * ... Thu, 25 Mar 2004 08:22:14 GMT Ralf Corsepius [93a0f2b] * testsuites/ChangeLog (modified) * testsuites/aclocal/rtems-top.m4 (modified) 2004-03-25 Ralf Corsepius * ... Thu, 25 Mar 2004 07:33:57 GMT Ralf Corsepius [e84c2a46] * testsuites/ChangeLog (modified) * testsuites/aclocal/enable-bare.m4 (modified) * testsuites/aclocal/enable-cxx.m4 (modified) * testsuites/aclocal/enable-itron.m4 (modified) * testsuites/aclocal/enable-multiprocessing.m4 (modified) * testsuites/aclocal/enable-networking.m4 (modified) * testsuites/aclocal/enable-posix.m4 (modified) * testsuites/aclocal/enable-tests.m4 (modified) * testsuites/aclocal/multilib.m4 (modified) * testsuites/aclocal/rtems-test-no-pause.m4 (modified) 2004-03-25 Ralf Corsepius * ... Thu, 25 Mar 2004 06:05:21 GMT Ralf Corsepius [7c48a2e8] * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/support/ChangeLog (modified) * testsuites/support/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) 2004-03-25 Ralf Corsepius * ... Thu, 25 Mar 2004 05:19:36 GMT Ralf Corsepius [a1cf46b] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/Makefile.am (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/samples/Makefile.am (modified) 2004-03-25 Ralf Corsepius * ... Thu, 25 Mar 2004 04:21:03 GMT Ralf Corsepius [e1908de] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2004-03-25 Ralf Corsepius * ... Tue, 23 Mar 2004 13:13:17 GMT Ralf Corsepius [20f78a3] * cpukit/ChangeLog (modified) * cpukit/itron/include/itronsys/mbox.h (modified) * cpukit/itron/include/itronsys/types.h (modified) * cpukit/itron/include/rtems/itron/eventflags.h (modified) * cpukit/itron/include/rtems/itron/fmempool.h (modified) * cpukit/itron/include/rtems/itron/mbox.h (modified) * cpukit/itron/include/rtems/itron/msgbuffer.h (modified) * cpukit/itron/include/rtems/itron/port.h (modified) * cpukit/itron/include/rtems/itron/semaphore.h (modified) * cpukit/itron/include/rtems/itron/task.h (modified) * cpukit/itron/include/rtems/itron/vmempool.h (modified) * cpukit/itron/inline/rtems/itron/semaphore.inl (modified) * cpukit/itron/macros/rtems/itron/semaphore.inl (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/snd_mbx.c (modified) * cpukit/itron/src/task.c (modified) * cpukit/itron/src/trcv_mbx.c (modified) * cpukit/itron/src/vmempool.c (modified) 2004-03-23 Ralf Corsepius * ... Tue, 23 Mar 2004 13:07:29 GMT Ralf Corsepius [39cefdd] * cpukit/ChangeLog (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/intr.h (modified) * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/include/rtems/posix/timer.h (modified) * cpukit/posix/src/cond.c (modified) * cpukit/posix/src/intr.c (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keydelete.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keyrundestructors.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuetranslatereturncode.c (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/posix/src/posixintervaltotimespec.c (modified) * cpukit/posix/src/posixtimespecsubtract.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/ptimer1.c (modified) * cpukit/posix/src/semaphore.c (modified) * cpukit/posix/src/sysconf.c (modified) 2004-03-23 Ralf Corsepius * ... Tue, 23 Mar 2004 12:59:04 GMT Ralf Corsepius [a4365e4] * cpukit/ChangeLog (modified) * cpukit/score/include/rtems/system.h (modified) 2004-03-23 Ralf Corsepius * ... Tue, 23 Mar 2004 12:24:54 GMT Ralf Corsepius [cdcef7e6] * c/src/ChangeLog (modified) * c/src/libchip/network/pci.h (deleted) 2004-03-23 Ralf Corsepius ... Tue, 23 Mar 2004 12:21:47 GMT Ralf Corsepius [1db1bc5] * cpukit/ChangeLog (modified) * cpukit/include/rtems/pci.h (added) 2004-03-23 Ralf Corsepius ... Tue, 23 Mar 2004 12:16:30 GMT Ralf Corsepius [e7ceef91] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/malloc.c (modified) 2004-03-23 Ralf Corsepius * ... Tue, 23 Mar 2004 09:59:52 GMT Ralf Corsepius [ee4f57d] * c/src/ChangeLog (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ata_internal.h (modified) * c/src/libchip/ide/ide_controller.c (modified) * c/src/libchip/ide/ide_ctrl_cfg.h (modified) * c/src/libchip/ide/ide_ctrl_io.h (modified) * c/src/libchip/network/cs8900.c (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) * c/src/libchip/network/if_fxp.c (modified) * c/src/libchip/network/open_eth.c (modified) * c/src/libchip/network/open_eth.h (modified) * c/src/libchip/network/sonic.c (modified) * c/src/libchip/network/sonic.h (modified) * c/src/libchip/rtc/icm7170.c (modified) * c/src/libchip/rtc/icm7170.h (modified) * c/src/libchip/rtc/icm7170_reg.c (modified) * c/src/libchip/rtc/icm7170_reg2.c (modified) * c/src/libchip/rtc/icm7170_reg4.c (modified) * c/src/libchip/rtc/icm7170_reg8.c (modified) * c/src/libchip/rtc/m48t08.c (modified) * c/src/libchip/rtc/m48t08.h (modified) * c/src/libchip/rtc/m48t08_reg.c (modified) * c/src/libchip/rtc/m48t08_reg2.c (modified) * c/src/libchip/rtc/m48t08_reg4.c (modified) * c/src/libchip/rtc/m48t08_reg8.c (modified) * c/src/libchip/rtc/rtc.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_reg.c (modified) * c/src/libchip/serial/mc68681_reg2.c (modified) * c/src/libchip/serial/mc68681_reg4.c (modified) * c/src/libchip/serial/mc68681_reg8.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/serial.h (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.h (modified) * c/src/libchip/serial/z85c30_p.h (modified) * c/src/libchip/serial/z85c30_reg.c (modified) * c/src/libchip/shmdr/addlq.c (modified) * c/src/libchip/shmdr/cnvpkt.c (modified) * c/src/libchip/shmdr/dump.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * c/src/libchip/shmdr/getlq.c (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/initlq.c (modified) * c/src/libchip/shmdr/intr.c (modified) * c/src/libchip/shmdr/poll.c (modified) * c/src/libchip/shmdr/send.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) 2004-03-23 Ralf Corsepius * ... Tue, 23 Mar 2004 06:07:53 GMT Ralf Corsepius [83c5fc1] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/chain.h (modified) * cpukit/libcsupport/include/clockdrv.h (modified) * cpukit/libcsupport/include/motorola/mc68230.h (modified) * cpukit/libcsupport/include/ringbuf.h (modified) * cpukit/libcsupport/include/rtems/assoc.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/include/spurious.h (modified) * cpukit/libcsupport/include/timerdrv.h (modified) * cpukit/libcsupport/include/vmeintr.h (modified) * cpukit/libcsupport/include/zilog/z8036.h (modified) * cpukit/libcsupport/include/zilog/z8530.h (modified) * cpukit/libcsupport/include/zilog/z8536.h (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/assoc.c (modified) * cpukit/libcsupport/src/assocnamebad.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/libio_sockets.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/no_libc.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termiosreserveresources.c (modified) 2004-03-23 Ralf Corsepius * ... Mon, 22 Mar 2004 17:10:43 GMT Ralf Corsepius [f91bbe64] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) * cpukit/libfs/src/dosfs/fat_fat_operations.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/fat_file.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/linearfile.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) 2004-03-22 Ralf Corsepius * ... Thu, 18 Mar 2004 17:19:11 GMT Ralf Corsepius [82c123d] * scripts/ChangeLog (modified) * scripts/gcc3newlib/base-gcc.add (modified) * scripts/gcc3newlib/base-gcj.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gcc3newlib/target-gcj.add (modified) * scripts/gcc3newlib/target-gnat.add (modified) 2004-03-18 Ralf Corsepius * ... Thu, 18 Mar 2004 11:35:27 GMT Ralf Corsepius [4ef10977] * scripts/ChangeLog (modified) * scripts/gcc3newlib/base-gcc.add (modified) * scripts/gcc3newlib/target-g77.add (modified) * scripts/gcc3newlib/target-objc.add (modified) 2004-03-18 Ralf Corsepius * ... Wed, 17 Mar 2004 17:54:27 GMT Ralf Corsepius [08b1e43] * scripts/ChangeLog (modified) * scripts/gcc3newlib/target-c++.add (modified) * scripts/gcc3newlib/target-gcc.add (modified) 2004-03-17 Ralf Corsepius * ... Wed, 17 Mar 2004 17:14:07 GMT Ralf Corsepius [40605a2] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2004-03-17 Ralf Corsepius * ... Mon, 15 Mar 2004 07:31:31 GMT Ralf Corsepius [c2cbaba] * scripts/ChangeLog (modified) * scripts/binutils/base-binutils.add (modified) 2004-03-15 Ralf Corsepius * ... Sun, 14 Mar 2004 01:38:54 GMT Chris Johns [60f9088] * c/src/ChangeLog (modified) CS8900 driver updates. Sun, 14 Mar 2004 01:28:34 GMT Chris Johns [528da1c] * c/src/libchip/network/cs8900.c.bsp (modified) * c/src/libchip/network/cs8900.h.bsp (added) Updated the BSP example code. Sun, 14 Mar 2004 01:28:08 GMT Chris Johns [00bf7745] * c/src/libchip/network/cs8900.c (modified) * c/src/libchip/network/cs8900.h (modified) Changes made to support the DIMMPC. This is a pc396 target with IO ... Sun, 14 Mar 2004 01:26:07 GMT Chris Johns [27192b8] * c/src/libchip/network/README.cs8900 (modified) The CS8900 driver is documented in the cs8900.h header file. Tue, 09 Mar 2004 12:49:37 GMT Ralf Corsepius [6a54d6f] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/README (modified) 2004-03-09 Ralf Corsepius * ... Tue, 09 Mar 2004 10:41:30 GMT Ralf Corsepius [2494cba] * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) 2004-03-09 Ralf Corsepius * ... Tue, 09 Mar 2004 10:08:33 GMT Ralf Corsepius [51b9899] * c/src/ChangeLog (modified) * c/src/libchip/network/dec21140.c (modified) 2004-03-09 Ralf Corsepius * ... Tue, 09 Mar 2004 09:53:08 GMT Ralf Corsepius [5569cec] * c/src/ChangeLog (modified) * c/src/aclocal/canonicalize-tools.m4 (modified) 2004-03-09 Ralf Corsepius * ... Tue, 09 Mar 2004 09:15:48 GMT Ralf Corsepius [b6e03375] * c/src/lib/libbsp/c4x/c4xsim/include/.cvsignore (modified) * c/src/lib/libbsp/h8300/h8sim/include/.cvsignore (modified) * c/src/lib/libbsp/i386/i386ex/include/.cvsignore (modified) * c/src/lib/libbsp/i386/pc386/include/.cvsignore (modified) * c/src/lib/libbsp/i386/ts_386ex/include/.cvsignore (modified) * c/src/lib/libbsp/i960/cvme961/include/.cvsignore (modified) * c/src/lib/libbsp/i960/i960sim/include/.cvsignore (modified) * c/src/lib/libbsp/i960/rxgen960/include/.cvsignore (modified) * c/src/lib/libbsp/mips/genmongoosev/include/.cvsignore (modified) * c/src/lib/libbsp/mips/jmr3904/include/.cvsignore (modified) * c/src/lib/libbsp/mips/p4000/include/.cvsignore (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/.cvsignore (modified) * c/src/lib/libbsp/or32/orp/include/.cvsignore (modified) * c/src/lib/libbsp/powerpc/dmv177/include/.cvsignore (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/.cvsignore (modified) * c/src/lib/libbsp/powerpc/gen405/include/.cvsignore (modified) * c/src/lib/libbsp/powerpc/helas403/include/.cvsignore (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/.cvsignore (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/.cvsignore (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/.cvsignore (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/.cvsignore (modified) * c/src/lib/libbsp/powerpc/psim/include/.cvsignore (modified) * c/src/lib/libbsp/powerpc/score603e/include/.cvsignore (modified) * c/src/lib/libbsp/sh/gensh1/include/.cvsignore (modified) * c/src/lib/libbsp/sh/gensh2/include/.cvsignore (modified) * c/src/lib/libbsp/sh/gensh4/include/.cvsignore (modified) * c/src/lib/libbsp/sh/shsim/include/.cvsignore (modified) * c/src/lib/libbsp/sh/simsh4/include/.cvsignore (modified) * c/src/lib/libbsp/sparc/erc32/include/.cvsignore (modified) * c/src/lib/libbsp/sparc/leon/include/.cvsignore (modified) * c/src/lib/libbsp/unix/posix/include/.cvsignore (modified) * c/src/lib/libcpu/mips/mongoosev/duart/.cvsignore (modified) * c/src/lib/libcpu/mips/mongoosev/include/.cvsignore (modified) * c/src/lib/libcpu/mips/mongoosev/vectorisrs/.cvsignore (modified) * c/src/lib/libcpu/mips/r46xx/vectorisrs/.cvsignore (modified) * c/src/lib/libcpu/mips/tx39/include/.cvsignore (modified) * c/src/lib/libcpu/mips/tx39/vectorisrs/.cvsignore (modified) * c/src/lib/libcpu/powerpc/shared/src/.cvsignore (modified) * c/src/lib/libcpu/sparc/cache/.cvsignore (modified) * c/src/make/custom/.cvsignore (modified) * cpukit/itron/src/.cvsignore (modified) * cpukit/libcsupport/src/.cvsignore (modified) * cpukit/libfs/src/dosfs/.cvsignore (modified) * cpukit/libfs/src/imfs/.cvsignore (modified) * cpukit/posix/src/.cvsignore (modified) * cpukit/score/cpu/unix/rtems/score/.cvsignore (modified) * cpukit/score/include/rtems/score/.cvsignore (modified) * doc/common/.cvsignore (modified) * make/custom/.cvsignore (modified) Remove refs to Makefile*. Tue, 09 Mar 2004 09:13:25 GMT Ralf Corsepius [0b1fce8] * doc/images/.cvsignore (deleted) * doc/started/pictures/.cvsignore (deleted) * make/Templates/.cvsignore (deleted) * make/compilers/.cvsignore (deleted) * testsuites/support/include/.cvsignore (deleted) * tools/.cvsignore (deleted) Unused. Mon, 08 Mar 2004 16:26:41 GMT Ralf Corsepius [2609e83] * c/src/lib/libbsp/mips/genmongoosev/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/console/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/scitab/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/startup/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh1/wrapup/.cvsignore (deleted) * c/src/lib/libbsp/sh/gensh2/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/shsim/start/.cvsignore (deleted) * c/src/lib/libbsp/sh/simsh4/start/.cvsignore (deleted) * c/src/lib/libbsp/shared/.cvsignore (deleted) * c/src/lib/libcpu/i960/include/.cvsignore (deleted) * c/src/lib/libcpu/m68k/m68040/fpsp/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/clock/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/console/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/include/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/mbus/.cvsignore (deleted) * c/src/lib/libcpu/m68k/mcf5206/timer/.cvsignore (deleted) * c/src/lib/libcpu/m68k/shared/cache/.cvsignore (deleted) * c/src/lib/libcpu/m68k/shared/misc/.cvsignore (deleted) * c/src/lib/libcpu/mips/clock/.cvsignore (deleted) * c/src/lib/libcpu/mips/shared/cache/.cvsignore (deleted) * c/src/lib/libcpu/mips/shared/interrupts/.cvsignore (deleted) * c/src/lib/libcpu/mips/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc505/ictrl/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc505/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc505/vectors/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/cpm/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/exceptions/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/include/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/mmu/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/exceptions/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/include/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/mmu/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/clock/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/console/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/ictrl/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/timer/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/tty_drv/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/ppc403/vectors/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/shared/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/clock/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/delay/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/sci/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/score/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7032/timer/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/clock/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/sci/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/score/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7045/timer/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/clock/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/include/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/sci/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/score/.cvsignore (deleted) * c/src/lib/libcpu/sh/sh7750/timer/.cvsignore (deleted) * c/src/lib/libcpu/sparc/reg_win/.cvsignore (deleted) * c/src/lib/libcpu/sparc/syscall/.cvsignore (deleted) * c/src/librdbg/include/.cvsignore (deleted) * c/src/librdbg/src/.cvsignore (deleted) * c/src/librdbg/src/i386/.cvsignore (deleted) * c/src/librdbg/src/i386/any/.cvsignore (deleted) * c/src/librdbg/src/m68k/.cvsignore (deleted) * c/src/librdbg/src/m68k/any/.cvsignore (deleted) * c/src/librdbg/src/powerpc/.cvsignore (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/.cvsignore (deleted) * c/src/librtems++/include/.cvsignore (deleted) * c/src/librtems++/include/rtems++/.cvsignore (deleted) * c/src/librtems++/src/.cvsignore (deleted) * c/src/optman/rtems/.cvsignore (deleted) * c/src/optman/sapi/.cvsignore (deleted) * cpukit/include/.cvsignore (deleted) * cpukit/itron/include/.cvsignore (deleted) * cpukit/itron/include/itronsys/.cvsignore (deleted) * cpukit/itron/include/rtems/.cvsignore (deleted) * cpukit/itron/include/rtems/itron/.cvsignore (deleted) * cpukit/itron/inline/.cvsignore (deleted) * cpukit/itron/inline/rtems/.cvsignore (deleted) * cpukit/itron/inline/rtems/itron/.cvsignore (deleted) * cpukit/itron/macros/.cvsignore (deleted) * cpukit/itron/macros/rtems/.cvsignore (deleted) * cpukit/itron/macros/rtems/itron/.cvsignore (deleted) * cpukit/libblock/include/.cvsignore (deleted) * cpukit/libblock/include/rtems/.cvsignore (deleted) * cpukit/libblock/src/.cvsignore (deleted) * cpukit/libcsupport/include/.cvsignore (deleted) * cpukit/libcsupport/include/motorola/.cvsignore (deleted) * cpukit/libcsupport/include/rtems/.cvsignore (deleted) * cpukit/libcsupport/include/sys/.cvsignore (deleted) * cpukit/libcsupport/include/zilog/.cvsignore (deleted) * cpukit/libfs/src/.cvsignore (deleted) * cpukit/libmisc/capture/.cvsignore (deleted) * cpukit/libmisc/cpuuse/.cvsignore (deleted) * cpukit/libmisc/devnull/.cvsignore (deleted) * cpukit/libmisc/dummy/.cvsignore (deleted) * cpukit/libmisc/dumpbuf/.cvsignore (deleted) * cpukit/libmisc/fsmount/.cvsignore (deleted) * cpukit/libmisc/monitor/.cvsignore (deleted) * cpukit/libmisc/mw-fb/.cvsignore (deleted) * cpukit/libmisc/rtmonuse/.cvsignore (deleted) * cpukit/libmisc/serdbg/.cvsignore (deleted) * cpukit/libmisc/shell/.cvsignore (deleted) * cpukit/libmisc/stackchk/.cvsignore (deleted) * cpukit/libmisc/untar/.cvsignore (deleted) * cpukit/libnetworking/arpa/.cvsignore (deleted) * cpukit/libnetworking/kern/.cvsignore (deleted) * cpukit/libnetworking/lib/.cvsignore (deleted) * cpukit/libnetworking/libc/.cvsignore (deleted) * cpukit/libnetworking/machine/.cvsignore (deleted) * cpukit/libnetworking/net/.cvsignore (deleted) * cpukit/libnetworking/netinet/.cvsignore (deleted) * cpukit/libnetworking/nfs/.cvsignore (deleted) * cpukit/libnetworking/rtems/.cvsignore (deleted) * cpukit/libnetworking/sys/.cvsignore (deleted) * cpukit/libnetworking/vm/.cvsignore (deleted) * cpukit/librpc/include/.cvsignore (deleted) * cpukit/librpc/include/rpc/.cvsignore (deleted) * cpukit/librpc/include/rpcsvc/.cvsignore (deleted) * cpukit/librpc/src/.cvsignore (deleted) * cpukit/librpc/src/rpc/.cvsignore (deleted) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (deleted) * cpukit/librpc/src/xdr/.cvsignore (deleted) * cpukit/posix/include/.cvsignore (deleted) * cpukit/posix/include/rtems/.cvsignore (deleted) * cpukit/posix/include/rtems/posix/.cvsignore (deleted) * cpukit/posix/inline/.cvsignore (deleted) * cpukit/posix/inline/rtems/.cvsignore (deleted) * cpukit/posix/inline/rtems/posix/.cvsignore (deleted) * cpukit/posix/macros/.cvsignore (deleted) * cpukit/posix/macros/rtems/.cvsignore (deleted) * cpukit/posix/macros/rtems/posix/.cvsignore (deleted) * cpukit/rtems/include/.cvsignore (deleted) * cpukit/rtems/include/rtems/.cvsignore (deleted) * cpukit/rtems/include/rtems/rtems/.cvsignore (deleted) * cpukit/rtems/inline/.cvsignore (deleted) * cpukit/rtems/inline/rtems/.cvsignore (deleted) * cpukit/rtems/inline/rtems/rtems/.cvsignore (deleted) * cpukit/rtems/macros/.cvsignore (deleted) * cpukit/rtems/macros/rtems/.cvsignore (deleted) * cpukit/rtems/macros/rtems/rtems/.cvsignore (deleted) * cpukit/rtems/src/.cvsignore (deleted) * cpukit/score/cpu/arm/rtems/.cvsignore (deleted) * cpukit/score/cpu/arm/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/c4x/rtems/.cvsignore (deleted) * cpukit/score/cpu/c4x/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/h8300/rtems/.cvsignore (deleted) * cpukit/score/cpu/h8300/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/i386/rtems/.cvsignore (deleted) * cpukit/score/cpu/i386/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/i960/rtems/.cvsignore (deleted) * cpukit/score/cpu/i960/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/m68k/rtems/.cvsignore (deleted) * cpukit/score/cpu/m68k/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/mips/rtems/.cvsignore (deleted) * cpukit/score/cpu/mips/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/no_cpu/rtems/.cvsignore (deleted) * cpukit/score/cpu/no_cpu/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/or32/rtems/.cvsignore (deleted) * cpukit/score/cpu/or32/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/powerpc/rtems/.cvsignore (deleted) * cpukit/score/cpu/powerpc/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/sh/rtems/.cvsignore (deleted) * cpukit/score/cpu/sh/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/sparc/rtems/.cvsignore (deleted) * cpukit/score/cpu/sparc/rtems/score/.cvsignore (deleted) * cpukit/score/cpu/unix/rtems/.cvsignore (deleted) * cpukit/score/include/.cvsignore (deleted) * cpukit/score/include/rtems/.cvsignore (deleted) * cpukit/score/inline/.cvsignore (deleted) * cpukit/score/inline/rtems/.cvsignore (deleted) * cpukit/score/inline/rtems/score/.cvsignore (deleted) * cpukit/score/macros/.cvsignore (deleted) * cpukit/score/macros/rtems/.cvsignore (deleted) * cpukit/score/macros/rtems/score/.cvsignore (deleted) * cpukit/score/src/.cvsignore (deleted) Unused. Mon, 08 Mar 2004 15:40:40 GMT Ralf Corsepius [9c4a30e2] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) 2004-03-08 Ralf Corsepius PR ... Mon, 08 Mar 2004 15:37:31 GMT Ralf Corsepius [25f59b14] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) 2004-03-08 Ralf Corsepius * ... Mon, 08 Mar 2004 15:36:03 GMT Ralf Corsepius [0aee2be5] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc5xx/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc5xx/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc5xx/exceptions/asm_utils.S (added) * c/src/lib/libcpu/powerpc/mpc5xx/exceptions/raw_exception.c (added) * c/src/lib/libcpu/powerpc/mpc5xx/exceptions/raw_exception.h (added) * c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.c (added) * c/src/lib/libcpu/powerpc/mpc5xx/ictrl/ictrl.h (added) * c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c (added) 2004-03-08 Ralf Corsepius * ... Mon, 08 Mar 2004 03:41:10 GMT Ralf Corsepius [bacd4df] * c/src/lib/libbsp/i386/shared/comm/.cvsignore (deleted) * c/src/lib/libbsp/i386/shared/irq/.cvsignore (deleted) * c/src/lib/libbsp/i386/shared/pci/.cvsignore (deleted) Unused Mon, 08 Mar 2004 03:17:16 GMT Ralf Corsepius [afd00b05] * c/src/libchip/ide/.cvsignore (deleted) * c/src/libchip/network/.cvsignore (deleted) * c/src/libchip/rtc/.cvsignore (deleted) * c/src/libchip/serial/.cvsignore (deleted) * c/src/libchip/shmdr/.cvsignore (deleted) Unused Fri, 05 Mar 2004 18:37:16 GMT Joel Sherrill [355f03eb] * cpukit/ChangeLog (modified) * cpukit/libnetworking/net/radix.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:34:13 GMT Joel Sherrill [2f5c2f0] * make/ChangeLog (modified) * make/custom/p4650.cfg (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:32:06 GMT Joel Sherrill [08df9497] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/cmds.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:28:38 GMT Joel Sherrill [e73c249] * c/src/ChangeLog (modified) * c/src/aclocal/canonicalize-tools.m4 (modified) 2004-03-04 Joel Sherrill * ... Fri, 05 Mar 2004 18:26:16 GMT Joel Sherrill [6debefee] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp07/buffered_io.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:25:33 GMT Joel Sherrill [1cf0ea1] * cpukit/ChangeLog (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:24:24 GMT Joel Sherrill [07e9194e] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libcsupport/src/sync.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:22:08 GMT Joel Sherrill [120b59e] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:14:27 GMT Joel Sherrill [bfb4c547] * c/src/ChangeLog (modified) * c/src/libnetworking/rtems_webserver/ejparse.c (modified) * c/src/libnetworking/rtems_webserver/emfdb.c (modified) * c/src/libnetworking/rtems_webserver/sock.c (modified) * c/src/libnetworking/rtems_webserver/socket.c (modified) * c/src/libnetworking/rtems_webserver/sym.c (modified) * c/src/libnetworking/rtems_webserver/webs.c (modified) * c/src/libnetworking/rtems_webserver/websuemf.c (modified) * cpukit/httpd/ejparse.c (modified) * cpukit/httpd/emfdb.c (modified) * cpukit/httpd/sock.c (modified) * cpukit/httpd/socket.c (modified) * cpukit/httpd/sym.c (modified) * cpukit/httpd/webs.c (modified) * cpukit/httpd/websuemf.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:12:33 GMT Joel Sherrill [845e4f3] * c/src/ChangeLog (modified) * c/src/libchip/network/open_eth.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:10:51 GMT Joel Sherrill [d52342e] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:09:14 GMT Joel Sherrill [da3b8d3] * c/src/lib/libbsp/powerpc/shared/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/pci.h (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:06:46 GMT Joel Sherrill [d2ae273] * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:04:00 GMT Joel Sherrill [24a7692] * cpukit/ChangeLog (modified) * cpukit/score/macros/rtems/score/chain.inl (modified) * cpukit/score/src/objectidtoname.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 18:02:41 GMT Joel Sherrill [cb2f320] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/net/radix.c (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/score/macros/rtems/score/chain.inl (modified) * cpukit/score/src/objectidtoname.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 17:58:51 GMT Joel Sherrill [b2b143f4] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/ramdisk.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/net/radix.c (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/macros/rtems/score/chain.inl (modified) * cpukit/score/src/objectidtoname.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 15:51:13 GMT Joel Sherrill [3c0c898] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtimer/psxtimer.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 15:41:43 GMT Joel Sherrill [070425c] * doc/ChangeLog (modified) * doc/FAQ/FAQ.texi (modified) * doc/FAQ/Makefile.am (modified) * doc/FAQ/embeddedinfo.t (deleted) 2004-03-05 Joel Sherrill PR 576/doc ... Fri, 05 Mar 2004 15:31:01 GMT Joel Sherrill [bb7cd38] * c/src/lib/libbsp/m68k/shared/ChangeLog (modified) * c/src/lib/libbsp/m68k/shared/setvec.c (modified) 2004-03-05 Joel Sherrill PR ... Wed, 03 Mar 2004 14:23:05 GMT Joel Sherrill [b16bdbf7] * testsuites/support/ChangeLog (modified) * testsuites/support/include/buffer_test_io.h (modified) 2004-03-03 Joel Sherrill * ... Wed, 03 Mar 2004 14:22:27 GMT Joel Sherrill [f47ee58] * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/startup/linkcmds (modified) 2004-03-03 Joel Sherrill * ... Wed, 03 Mar 2004 14:21:38 GMT Joel Sherrill [230134e9] * c/src/lib/libbsp/powerpc/shared/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/vectors/vectors.h (modified) * c/src/lib/libbsp/powerpc/shared/vectors/vectors_init.c (modified) 2004-03-03 Joel Sherrill * ... Wed, 03 Mar 2004 14:21:12 GMT Joel Sherrill [68aef00] * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.h (modified) 2004-03-03 Joel Sherrill * ... Wed, 03 Mar 2004 14:20:59 GMT Joel Sherrill [c403d4b] * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/Makefile.am (modified) 2004-03-03 Joel Sherrill * ... Wed, 03 Mar 2004 14:20:36 GMT Joel Sherrill [cc3de44e] * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/startup/linkcmds (modified) 2004-03-03 Joel Sherrill * ... Thu, 26 Feb 2004 17:26:35 GMT Joel Sherrill [22eda53c] * make/ChangeLog (modified) * make/custom/mvme2307.cfg (modified) 2004-02-26 Joel Sherrill PR ... Thu, 26 Feb 2004 17:23:54 GMT Joel Sherrill [f4fe0e9a] * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) 2004-02-26 Andreas Karlsson ... Thu, 26 Feb 2004 17:04:44 GMT Joel Sherrill [f4548e9] * cpukit/ChangeLog (modified) * cpukit/rtems/src/eventtimeout.c (modified) 2004-02-26 Thomas Rauscher [54a43fe4] * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/task1.c (modified) 2004-02-26 Joel Sherrill PR ... Thu, 26 Feb 2004 14:28:56 GMT Joel Sherrill [652524d9] * cpukit/ChangeLog (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) 2004-02-26 Joel Sherrill PR ... Thu, 26 Feb 2004 14:26:23 GMT Joel Sherrill [68cc3ad] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxmsgq01/psxmsgq01.scn (modified) 2004-02-26 Sébastien Barré PR ... Tue, 24 Feb 2004 12:06:30 GMT Joel Sherrill [79f90ba] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2004-02-24 Joel Sherrill PR ... Mon, 23 Feb 2004 06:04:23 GMT Ralf Corsepius [8b2642c2] * scripts/ChangeLog (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) 2004-02-23 Ralf Corsepius * ... Sat, 21 Feb 2004 13:09:54 GMT Joel Sherrill [36fc0ee1] * contrib/apt-conf/ChangeLog (modified) * contrib/apt-conf/README (added) 2004-02-21 Joel Sherrill * README: ... Fri, 20 Feb 2004 20:48:58 GMT Ralf Corsepius [f79a10c] * contrib/apt-conf/ChangeLog (modified) * contrib/apt-conf/rtems-apt-conf.spec.in (modified) 2004-02-20 Ralf Corsepius * ... Fri, 20 Feb 2004 14:21:03 GMT Ralf Corsepius [108a9cc5] * contrib/apt-conf/.cvsignore (modified) Update. Fri, 20 Feb 2004 14:18:21 GMT Ralf Corsepius [92f1119] * contrib/apt-conf/ChangeLog (added) Add ChangeLog Fri, 20 Feb 2004 14:17:43 GMT Ralf Corsepius [c9626644] * contrib/apt-conf/.cvsignore (added) * contrib/apt-conf/COPYING (added) * contrib/apt-conf/INSTALL (added) * contrib/apt-conf/Makefile.am (added) * contrib/apt-conf/configure.ac (added) * contrib/apt-conf/gpg/gpg-pubkey-eac29b6f-3fe1f458 (added) * contrib/apt-conf/rtems-apt-conf.spec.in (added) * contrib/apt-conf/sources.list.d/rtems-4.6.list (added) * contrib/apt-conf/sources.list.d/rtems-4.7.list (added) * contrib/apt-conf/vendors.list.d/rtems.list (added) 2004-02-20 Ralf Corsepius * ... Fri, 20 Feb 2004 01:45:34 GMT Ralf Corsepius [93302bf9] * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/Makefile.am (modified) * make/ChangeLog (modified) * make/Makefile.am (modified) 2004-02-20 Ralf Corsepius * ... Fri, 20 Feb 2004 01:44:19 GMT Ralf Corsepius [6e2ef53f] * Makefile.am (modified) * aclocal/rtems-top.m4 (modified) 2004-02-20 Ralf Corsepius * ... Fri, 20 Feb 2004 01:40:59 GMT Ralf Corsepius [4d327517] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) 2004-02-20 Ralf Corsepius * ... Fri, 20 Feb 2004 01:37:30 GMT Ralf Corsepius [a922482b] * tools/build/ChangeLog (modified) * tools/build/Makefile.am (modified) 2004-02-20 Ralf Corsepius * ... Fri, 20 Feb 2004 01:22:04 GMT Ralf Corsepius [789694a1] * c/src/ChangeLog (modified) * c/src/acinclude.m4 (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/configure.ac (modified) 2004-02-20 Ralf Corsepius * ... Fri, 20 Feb 2004 01:11:53 GMT Ralf Corsepius [fcf0034] * c/src/ChangeLog (modified) * c/src/libchip/Makefile.am (modified) * c/src/librdbg/Makefile.am (modified) * c/src/optman/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) 2004-02-20 Ralf Corsepius * ... Fri, 20 Feb 2004 01:02:24 GMT Ralf Corsepius [f8914a3] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) 2004-02-20 Ralf Corsepius * ... Thu, 19 Feb 2004 14:19:15 GMT Joel Sherrill [2c7f0e3d] * scripts/ChangeLog (modified) * scripts/gdb/gdb.add (modified) * scripts/setup.def (modified) 2004-02-19 Joel Sherrill * ... Thu, 19 Feb 2004 12:13:42 GMT Joel Sherrill [074133a] * scripts/ChangeLog (modified) 2004-02-19 Joel Sherrill * ... Thu, 19 Feb 2004 06:23:44 GMT Ralf Corsepius [984ea8b3] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) 2004-02-19 Ralf Corsepius * ... Thu, 19 Feb 2004 06:22:18 GMT Ralf Corsepius [2a7f9a28] * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/Makefile.am (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/Makefile.am (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/Makefile.am (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.am (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/Makefile.am (modified) 2004-02-19 Ralf Corsepius * ... Thu, 19 Feb 2004 06:11:55 GMT Ralf Corsepius [d7fb9f8] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) 2004-02-19 Ralf Corsepius * ... Thu, 19 Feb 2004 06:08:15 GMT Ralf Corsepius [5e5cf07] * c/src/ChangeLog (modified) * c/src/aclocal/check-multiprocessing.m4 (modified) * c/src/aclocal/env-rtemsbsp.m4 (modified) * c/src/aclocal/project-root.m4 (modified) * c/src/libchip/Makefile.am (modified) * c/src/librdbg/Makefile.am (modified) * c/src/optman/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) 2004-02-19 Ralf Corsepius * ... Thu, 19 Feb 2004 06:02:04 GMT Ralf Corsepius [c98c9c9] * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/Makefile.am (modified) 2004-02-18 Ralf Corsepius * ... Thu, 19 Feb 2004 05:51:30 GMT Ralf Corsepius [8f1eeb91] * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/bsp.am (modified) 2004-02-17 Ralf Corsepius * ... Thu, 19 Feb 2004 05:40:02 GMT Ralf Corsepius [17ad82c] * testsuites/ChangeLog (modified) * testsuites/aclocal/check-custom-bsp.m4 (modified) * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/aclocal/project-root.m4 (modified) * testsuites/aclocal/rtems-top.m4 (modified) * testsuites/configure.ac (modified) 2004-02-18 Ralf Corsepius * ... Tue, 17 Feb 2004 19:09:57 GMT Joel Sherrill [90357e29] * scripts/ChangeLog (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/setup.def (modified) 2004-02-17 RTEMS * setup.def, gdb/base-gdb.add, ... Tue, 17 Feb 2004 16:15:18 GMT Ralf Corsepius [6ed6288] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.am (modified) 2004-02-17 Ralf Corsepius * ... Tue, 17 Feb 2004 13:50:24 GMT Ralf Corsepius [9078e097] * ChangeLog (modified) * Makefile.am (modified) * aclocal/enable-rtemsbsp.m4 (modified) * configure.ac (modified) 2004-02-17 Ralf Corsepius * ... Tue, 17 Feb 2004 13:44:16 GMT Ralf Corsepius [1204f22] * c/ChangeLog (modified) * c/Makefile.am (modified) * c/configure.ac (modified) 2004-02-17 Ralf Corsepius * ... Tue, 17 Feb 2004 13:41:35 GMT Ralf Corsepius [e7495ae] * c/src/ChangeLog (modified) * c/src/Makefile.am (modified) * c/src/configure.ac (modified) * c/src/librdbg/Makefile.am (modified) * c/src/librdbg/include/Makefile.am (deleted) * c/src/librdbg/src/Makefile.am (deleted) * c/src/wrapup/Makefile.am (modified) 2004-02-17 Ralf Corsepius * ... Tue, 17 Feb 2004 09:39:54 GMT Ralf Corsepius [b52b7f9] * doc/ChangeLog (modified) * doc/develenv/Makefile.am (modified) 2004-02-17 Ralf Corsepius * ... Sun, 15 Feb 2004 15:14:45 GMT Ralf Corsepius [3afcb03] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) 2004-02-15 Ralf Corsepius * ...
