# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/12/24 15:59:18 Tue, 16 Nov 1999 16:01:32 GMT Joel Sherrill [7fec3b7a] * c/src/exec/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) Added call to _Watchdog_Remove to remove the sporadic timer. It was ... Tue, 16 Nov 1999 16:00:11 GMT Joel Sherrill [2c0e896e] * c/src/exec/posix/src/Makefile.in (modified) Moved utsname from "build for now" (unimplemented files) to the main ... Tue, 16 Nov 1999 15:58:21 GMT Joel Sherrill [d280ce18] * c/src/exec/itron/include/rtems/itron/msgbuffer.h (modified) * cpukit/itron/include/rtems/itron/msgbuffer.h (modified) Comment fixed when adding prototype for ... Tue, 16 Nov 1999 15:52:49 GMT Joel Sherrill [bd462d1] * c/src/exec/score/src/threadreset.c (added) * cpukit/score/src/threadreset.c (added) New file. Tue, 16 Nov 1999 15:48:11 GMT Joel Sherrill [d6c83529] * Makefile.am (modified) * bootstrap (moved) * c/Makefile.am (modified) * c/configure.in (modified) * c/make/Makefile.am (added) * c/make/configure.in (added) * c/make/target.cfg.in (moved) * c/src/make/Makefile.am (modified) * c/src/make/bsp.cfg.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * make/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/default.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/ods68302.cfg (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) Patch rtems-rc-19991105-1.diff.gz from Ralf Corsepius ... Tue, 16 Nov 1999 15:41:58 GMT Jennifer Averett [fa3346f] * c/src/tests/psxtests/psxreaddir/psxreaddir.scn (modified) * testsuites/psxtests/psxreaddir/psxreaddir.scn (modified) Modified file to match seen output. Tue, 16 Nov 1999 15:41:29 GMT Jennifer Averett [f9879915] * c/src/tests/psxtests/psxstat/psxstat.scn (modified) * testsuites/psxtests/psxstat/psxstat.scn (modified) Modified output file to match seen output. Added comment to all ino ... Tue, 16 Nov 1999 15:40:40 GMT Jennifer Averett [e9b00d7] * c/src/tests/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxstat/test.c (modified) Removed compiler warning. Tue, 16 Nov 1999 15:39:08 GMT Jennifer Averett [d37aa444] * c/src/tests/itrontests/itrontask03/init.c (modified) * c/src/tests/itrontests/itrontask03/preempt.c (modified) * testsuites/itrontests/itrontask03/init.c (modified) * testsuites/itrontests/itrontask03/preempt.c (modified) Changed asserts to tmmacros. Tue, 16 Nov 1999 15:38:44 GMT Jennifer Averett [2d82857] * c/src/tests/itrontests/itrontask02/itrontask02.scn (modified) * testsuites/itrontests/itrontask02/itrontask02.scn (modified) Updated scn file to match new output. Left out unemplemented parts ... Tue, 16 Nov 1999 15:33:10 GMT Jennifer Averett [47619951] * c/src/tests/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/init.c (modified) + Changed ID to 1. ( Compilation error introduced by modifications. ) Tue, 16 Nov 1999 15:30:04 GMT Jennifer Averett [1da9f4bd] * c/src/tests/itrontests/itronhello/itronhello.scn (modified) * testsuites/itrontests/itronhello/itronhello.scn (modified) Modified scan file to match. Tue, 16 Nov 1999 15:28:03 GMT Joel Sherrill [817031f] * c/src/exec/libcsupport/src/ttyname_r.c (added) * c/src/lib/libc/ttyname_r.c (added) * cpukit/libcsupport/src/ttyname_r.c (added) New file. Tue, 16 Nov 1999 15:27:52 GMT Joel Sherrill [c7016198] * c/src/exec/libcsupport/src/ctermid.c (added) * c/src/exec/libcsupport/src/tcgetprgrp.c (added) * c/src/exec/libcsupport/src/tcsendbreak.c (added) * c/src/exec/libcsupport/src/tcsetpgrp.c (added) * c/src/exec/libcsupport/src/ttyname.c (added) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/ctermid.c (added) * c/src/lib/libc/tcgetprgrp.c (added) * c/src/lib/libc/tcsendbreak.c (added) * c/src/lib/libc/tcsetpgrp.c (added) * c/src/lib/libc/ttyname.c (added) * cpukit/libcsupport/src/ctermid.c (added) * cpukit/libcsupport/src/tcgetprgrp.c (added) * cpukit/libcsupport/src/tcsendbreak.c (added) * cpukit/libcsupport/src/tcsetpgrp.c (added) * cpukit/libcsupport/src/ttyname.c (added) Added. Tue, 16 Nov 1999 15:26:29 GMT Joel Sherrill [b88691c] * c/src/exec/libcsupport/src/scandir.c (modified) * c/src/lib/libc/scandir.c (modified) * cpukit/libcsupport/src/scandir.c (modified) Source and destination arguments to strncpy were swapped. This ... Tue, 16 Nov 1999 15:24:30 GMT Joel Sherrill [c276c87] * c/src/tests/tools/generic/difftest.in (modified) * testsuites/tools/generic/difftest.in (modified) Added itron tests. Tue, 16 Nov 1999 14:39:56 GMT Jennifer Averett [3fb7b70b] * c/src/tests/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/init.c (modified) Changed to call tmmacros instead of assert. Tue, 16 Nov 1999 14:24:50 GMT Joel Sherrill [56e61bb8] * scripts/gdb/gdb.spec.in (modified) Patch rtems-rc-19991105-0.diff from Ralf Corsepius [ac656f2d] * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.in (added) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/start/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.in (added) Moved start code from lib/start to libbsp. Tue, 16 Nov 1999 13:55:35 GMT Joel Sherrill [25f705e] * c/src/lib/start/Makefile.am (deleted) * c/src/lib/start/README (deleted) * c/src/lib/start/m68k/Makefile.in (deleted) * c/src/lib/start/m68k/configure.in (deleted) * c/src/lib/start/m68k/start.S (deleted) Moved start code from lib/start to libbsp. Tue, 16 Nov 1999 13:45:51 GMT Joel Sherrill [1d04e16] * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (deleted) * c/src/lib/start/i960/configure.in (deleted) * c/src/lib/start/i960/start.S (deleted) * c/src/lib/start/mips64orion/Makefile.in (deleted) * c/src/lib/start/mips64orion/configure.in (deleted) * c/src/lib/start/mips64orion/idt_csu.S (deleted) * c/src/lib/start/sh/Makefile.in (deleted) * c/src/lib/start/sh/configure.in (deleted) * c/src/lib/start/sh/start.S (deleted) Moved start code from lib/start to libbsp. Tue, 16 Nov 1999 13:37:49 GMT Joel Sherrill [7f93f772] * c/src/lib/start/a29k/Makefile.in (deleted) * c/src/lib/start/a29k/amd.ah (deleted) * c/src/lib/start/a29k/configure.in (deleted) * c/src/lib/start/a29k/crt0.S (deleted) * c/src/lib/start/a29k/pswmacro.ah (deleted) * c/src/lib/start/a29k/register.S (deleted) * c/src/lib/start/a29k/register.ah (deleted) Committed modifications from ITRON Task and Task Dependendent ... Tue, 16 Nov 1999 13:37:25 GMT Joel Sherrill [a7d988a] * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) Minor changes since new Makefile. Tue, 16 Nov 1999 13:34:41 GMT Joel Sherrill [14dbf50] * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) Added start subdirectory. Tue, 16 Nov 1999 13:31:13 GMT Joel Sherrill [1bcdb3f6] * c/src/lib/include/rdbg/Makefile.am (deleted) * c/src/lib/include/rdbg/i386/Makefile.am (deleted) * c/src/lib/include/rdbg/i386/rdbg_f.h (deleted) * c/src/lib/include/rdbg/i386/reg.h (deleted) * c/src/lib/include/rdbg/powerpc/Makefile.am (deleted) * c/src/lib/include/rdbg/powerpc/rdbg_f.h (deleted) * c/src/lib/include/rdbg/powerpc/reg.h (deleted) * c/src/lib/include/rdbg/rdbg.h (deleted) * c/src/lib/include/rdbg/servrpc.h (deleted) * c/src/lib/include/rpc/Makefile.am (deleted) * c/src/lib/include/rpc/auth.h (deleted) * c/src/lib/include/rpc/clnt.h (deleted) * c/src/lib/include/rpc/rpc.h (deleted) * c/src/lib/include/rpc/rpc_msg.h (deleted) * c/src/lib/include/rpc/svc.h (deleted) * c/src/lib/include/rpc/svc_auth.h (deleted) * c/src/lib/include/rpc/types.h (deleted) * c/src/lib/include/rpc/xdr.h (deleted) Committed modifications from ITRON Task and Task Dependendent ... Mon, 15 Nov 1999 22:19:51 GMT Joel Sherrill [80fd699] * c/src/exec/posix/src/sysconf.c (modified) * cpukit/posix/src/sysconf.c (modified) Removed nanosleep() since it is now in its own file. Mon, 15 Nov 1999 21:37:56 GMT Jennifer Averett [40aac29] * c/src/exec/itron/include/rtems/itron/object.h (modified) * cpukit/itron/include/rtems/itron/object.h (modified) Returned third parameter for a NULL name to the objects open call. Mon, 15 Nov 1999 21:35:14 GMT Jennifer Averett [25789705] * c/src/exec/itron/src/can_wup.c (modified) * c/src/exec/itron/src/chg_pri.c (modified) * c/src/exec/itron/src/del_tsk.c (modified) * c/src/exec/itron/src/frsm_tsk.c (modified) * c/src/exec/itron/src/ref_tsk.c (modified) * c/src/exec/itron/src/rel_wai.c (modified) * c/src/exec/itron/src/rot_rdq.c (modified) * c/src/exec/itron/src/rsm_tsk.c (modified) * c/src/exec/itron/src/sta_tsk.c (modified) * c/src/exec/itron/src/sus_tsk.c (modified) * c/src/exec/itron/src/ter_tsk.c (modified) * cpukit/itron/src/can_wup.c (modified) * cpukit/itron/src/chg_pri.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/ref_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rot_rdq.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/ter_tsk.c (modified) + Fixed files to consistantly use a case of the location after calls ... Mon, 15 Nov 1999 21:31:28 GMT Jennifer Averett [1ae60eb4] * c/src/exec/itron/src/ext_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) + Modified to use new Thread_Reset routine instead of the restart method. Mon, 15 Nov 1999 21:28:21 GMT Jennifer Averett [e672263] * c/src/tests/itrontests/itrontask04/init.c (modified) * testsuites/itrontests/itrontask04/init.c (modified) Fixed verificaiton checks to call correct macro if dispatch is disabled. Mon, 15 Nov 1999 21:25:53 GMT Jennifer Averett [06380cfe] * c/src/tests/itrontests/itrontask03/init.c (modified) * c/src/tests/itrontests/itrontask03/itrontask03.scn (modified) * c/src/tests/itrontests/itrontask03/preempt.c (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask03/init.c (modified) * testsuites/itrontests/itrontask03/itrontask03.scn (modified) * testsuites/itrontests/itrontask03/preempt.c (modified) * testsuites/itrontests/itrontask03/system.h (modified) + Added check that a task could be sent to a dormant state then ... Mon, 15 Nov 1999 21:19:58 GMT Jennifer Averett [0f88857] * c/src/tests/itrontests/itrontask02/Makefile.in (modified) * c/src/tests/itrontests/itrontask02/dormant.c (moved) * c/src/tests/itrontests/itrontask02/init.c (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask02/dormant.c (added) * testsuites/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/system.h (modified) + Changed preempt routine into two dummy tasks one that is in dormant ... Mon, 15 Nov 1999 21:04:01 GMT Joel Sherrill [cb193710] * doc/posix1003.1/preface.texi (modified) Added paragraph describing SUSP. Mon, 15 Nov 1999 17:15:58 GMT Joel Sherrill [9da0994] * c/src/exec/itron/src/Makefile.in (modified) * c/src/exec/itron/src/cre_mbf.c (added) * c/src/exec/itron/src/del_mbf.c (added) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/msgbuffertranslatereturncode.c (added) * c/src/exec/itron/src/prcv_mbf.c (added) * c/src/exec/itron/src/psnd_mbf.c (added) * c/src/exec/itron/src/rcv_mbf.c (added) * c/src/exec/itron/src/ref_mbf.c (added) * c/src/exec/itron/src/snd_mbf.c (added) * c/src/exec/itron/src/trcv_mbf.c (added) * c/src/exec/itron/src/tsnd_mbf.c (added) * cpukit/itron/src/cre_mbf.c (added) * cpukit/itron/src/del_mbf.c (added) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/msgbuffertranslatereturncode.c (added) * cpukit/itron/src/prcv_mbf.c (added) * cpukit/itron/src/psnd_mbf.c (added) * cpukit/itron/src/rcv_mbf.c (added) * cpukit/itron/src/ref_mbf.c (added) * cpukit/itron/src/snd_mbf.c (added) * cpukit/itron/src/trcv_mbf.c (added) * cpukit/itron/src/tsnd_mbf.c (added) Split ITRON Message Buffer Manager into multiple files. Mon, 15 Nov 1999 16:39:01 GMT Joel Sherrill [fb27af76] * c/src/exec/itron/src/Makefile.in (modified) * c/src/exec/itron/src/cre_sem.c (added) * c/src/exec/itron/src/del_sem.c (added) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/preq_sem.c (added) * c/src/exec/itron/src/ref_sem.c (added) * c/src/exec/itron/src/sig_sem.c (added) * c/src/exec/itron/src/twai_sem.c (added) * c/src/exec/itron/src/wai_sem.c (added) * cpukit/itron/src/cre_sem.c (added) * cpukit/itron/src/del_sem.c (added) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/preq_sem.c (added) * cpukit/itron/src/ref_sem.c (added) * cpukit/itron/src/sig_sem.c (added) * cpukit/itron/src/twai_sem.c (added) * cpukit/itron/src/wai_sem.c (added) Split ITRON semaphore manager into multiple files. Fri, 12 Nov 1999 22:00:10 GMT Joel Sherrill [afb11f8] * c/src/tests/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/init.c (modified) + Modified calls to use TSK_SLF for calls to self. + Modified calls ... Fri, 12 Nov 1999 21:27:42 GMT Joel Sherrill [624d7ca4] * c/src/tests/itrontests/itronhello/itronhello.doc (modified) * c/src/tests/itrontests/itrontask03/itrontask03.doc (modified) * testsuites/itrontests/itronhello/itronhello.doc (modified) * testsuites/itrontests/itrontask03/itrontask03.doc (modified) + Added comments on paths tested. Fri, 12 Nov 1999 21:26:54 GMT Joel Sherrill [e8c902c] * c/src/tests/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/init.c (modified) + Added check for priority over 256. + Modified output to correctly ... Fri, 12 Nov 1999 21:24:56 GMT Joel Sherrill [8ed3125d] * c/src/tests/itrontests/itrontask04/itrontask04.doc (modified) * testsuites/itrontests/itrontask04/itrontask04.doc (modified) Added comments for path's tested. Fri, 12 Nov 1999 21:23:34 GMT Joel Sherrill [d8f3f65b] * c/src/exec/itron/src/del_tsk.c (modified) * c/src/exec/itron/src/frsm_tsk.c (modified) * c/src/exec/itron/src/sus_tsk.c (modified) * c/src/exec/itron/src/ter_tsk.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/ter_tsk.c (modified) + Changed validation of the_thread to validation of location. + ... Fri, 12 Nov 1999 21:21:09 GMT Joel Sherrill [2979c28] * c/src/exec/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sta_tsk.c (modified) + Changed validation of the_thread to validation of location. + ... Fri, 12 Nov 1999 21:20:04 GMT Joel Sherrill [3971537] * c/src/exec/itron/src/rel_wai.c (modified) * c/src/exec/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) + Changed validation of the_thread to validation of location. Fri, 12 Nov 1999 21:18:36 GMT Joel Sherrill [037a7b1] * c/src/exec/itron/src/ref_tsk.c (modified) * cpukit/itron/src/ref_tsk.c (modified) + Moved error checks to before the disable dispatch where possible. Fri, 12 Nov 1999 21:16:45 GMT Joel Sherrill [0c5ab522] * c/src/exec/itron/src/ext_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) Added comment about the E_CTX error condition (Implementation dependent). Fri, 12 Nov 1999 21:15:12 GMT Joel Sherrill [c257429f] * c/src/exec/itron/src/cre_tsk.c (modified) * cpukit/itron/src/cre_tsk.c (modified) + Moved error checks to before the dispatch disable where possible. ... Fri, 12 Nov 1999 21:13:52 GMT Joel Sherrill [2183b65] * c/src/exec/itron/src/chg_pri.c (modified) * cpukit/itron/src/chg_pri.c (modified) + Modified correct return path to call _ITRON_return_errorno( E_OK ) ... Fri, 12 Nov 1999 21:12:27 GMT Joel Sherrill [ea6bfcb] * c/src/exec/itron/src/can_wup.c (modified) * cpukit/itron/src/can_wup.c (modified) + Modified correct return path to call _ITRON_return_errorno( E_OK ) ... Fri, 12 Nov 1999 15:54:48 GMT Joel Sherrill [6af81435] * c/src/exec/score/src/objectallocatebyindex.c (modified) * cpukit/score/src/objectallocatebyindex.c (modified) Corrected so now actually indexes into the allocation block. Fri, 12 Nov 1999 15:54:07 GMT Joel Sherrill [1925ec9b] * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/taskvariableadd.c (modified) Corrected remaining references to struct rtems_task_variable_t since ... Fri, 12 Nov 1999 15:53:29 GMT Joel Sherrill [a8d72dea] * c/src/exec/itron/include/rtems/itron/object.h (modified) * cpukit/itron/include/rtems/itron/object.h (modified) Removed unnecessary 3rd parameter. Fri, 12 Nov 1999 15:37:09 GMT Joel Sherrill [6bd132e5] * c/src/exec/itron/src/TODO (added) * cpukit/itron/src/TODO (added) New file. Fri, 12 Nov 1999 14:54:13 GMT Joel Sherrill [95bb279] * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) Used typedef so all "struct rtems_task_variable_t" uses are now just ... Fri, 12 Nov 1999 14:52:36 GMT Joel Sherrill [884b460] * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) Added per-task variable data stucture (rtems_task_variable_t), ... Fri, 12 Nov 1999 14:51:03 GMT Joel Sherrill [f4771656] * c/src/tests/itrontests/itrontask03/init.c (modified) * c/src/tests/itrontests/itrontask03/itrontask03.scn (modified) * c/src/tests/itrontests/itrontask03/task1.c (modified) * c/src/tests/itrontests/itrontask04/init.c (modified) * c/src/tests/itrontests/itrontask04/itrontask04.scn (modified) * c/src/tests/itrontests/itrontask04/task3.c (modified) * testsuites/itrontests/itrontask03/init.c (modified) * testsuites/itrontests/itrontask03/itrontask03.scn (modified) * testsuites/itrontests/itrontask03/task1.c (modified) * testsuites/itrontests/itrontask04/init.c (modified) * testsuites/itrontests/itrontask04/itrontask04.scn (modified) * testsuites/itrontests/itrontask04/task3.c (modified) Test name changed to reflect placement after merger. Fri, 12 Nov 1999 14:50:42 GMT Joel Sherrill [ec0b5ce] * c/src/tests/itrontests/itrontask02/init.c (modified) * c/src/tests/itrontests/itrontask02/itrontask02.scn (modified) * testsuites/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/itrontask02.scn (modified) Test name changed to reflect placement after merger. Changed output ... Fri, 12 Nov 1999 14:49:47 GMT Joel Sherrill [3136f5c9] * c/src/tests/itrontests/itrontask01/init.c (modified) * c/src/tests/itrontests/itrontask01/itrontask01.doc (modified) * c/src/tests/itrontests/itrontask01/itrontask01.scn (modified) * c/src/tests/itrontests/itrontask01/task1.c (modified) * testsuites/itrontests/itrontask01/init.c (modified) * testsuites/itrontests/itrontask01/itrontask01.doc (modified) * testsuites/itrontests/itrontask01/itrontask01.scn (modified) * testsuites/itrontests/itrontask01/task1.c (modified) Test name changed to reflect placement after merger. Increased ... Fri, 12 Nov 1999 14:38:19 GMT Joel Sherrill [5aa5560] * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (added) * c/src/exec/rtems/src/taskvariabledelete.c (added) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariableadd.c (added) * cpukit/rtems/src/taskvariabledelete.c (added) Added per task variables based on patch from Eric Norum ... Fri, 12 Nov 1999 14:15:50 GMT Joel Sherrill [3c49a508] * c/src/exec/itron/src/msgbuffer.c (modified) * cpukit/itron/src/msgbuffer.c (modified) Cleaned up style. Fri, 12 Nov 1999 13:46:04 GMT Joel Sherrill [3ad17f5] * c/src/exec/itron/src/cre_tsk.c (modified) * cpukit/itron/src/cre_tsk.c (modified) Removed redundant line. Fri, 12 Nov 1999 13:46:03 GMT Joel Sherrill [e972ff0] Merged message buffer code from CS595 projects. Fri, 12 Nov 1999 13:45:39 GMT Joel Sherrill [6977b38] * c/src/tests/itrontests/itronmbf01/init.c (modified) * testsuites/itrontests/itronmbf01/init.c (modified) Enabled after merging message buffer code. Fri, 12 Nov 1999 13:22:31 GMT Joel Sherrill [f9078d1] * c/src/tests/sptests/sp28/init.c (modified) * testsuites/sptests/sp28/init.c (modified) Added comment block and removed include of deleted file. Thu, 11 Nov 1999 02:51:31 GMT Joel Sherrill [33bbd74] * doc/networking/Makefile (modified) * doc/networking/networkapp.t (modified) Added information about the NTP servier field and included a copy of ... Thu, 11 Nov 1999 02:39:12 GMT Joel Sherrill [d102810e] * c/src/lib/libcpu/powerpc/README (modified) Updated. Thu, 11 Nov 1999 02:23:26 GMT Joel Sherrill [dc83752] * c/src/tests/sptests/sp27/sp27.scn (modified) * testsuites/sptests/sp27/sp27.scn (modified) Screen updated. Thu, 11 Nov 1999 02:23:04 GMT Joel Sherrill [458d4e66] * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/sptests/sp28/Makefile.in (added) * c/src/tests/sptests/sp28/init.c (added) * c/src/tests/sptests/sp28/sp28.doc (added) * c/src/tests/sptests/sp28/sp28.scn (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/sp28/init.c (added) * testsuites/sptests/sp28/sp28.doc (added) * testsuites/sptests/sp28/sp28.scn (added) Added new test sp28 to test the task variable directives. Wed, 10 Nov 1999 22:15:42 GMT Joel Sherrill [713b2ea] * c/src/tests/itrontests/Makefile.am (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/init.c (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itrontask01/itrontask01.doc (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask02/itrontask02.doc (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/itrontask03.doc (modified) * c/src/tests/itrontests/itrontask03/itrontask03.scn (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask03/task1.c (modified) * c/src/tests/itrontests/itrontask04/itrontask04.doc (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * testsuites/itrontests/Makefile.am (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/init.c (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itrontask01/itrontask01.doc (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask02/itrontask02.doc (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/itrontask03.doc (modified) * testsuites/itrontests/itrontask03/itrontask03.scn (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask03/task1.c (modified) * testsuites/itrontests/itrontask04/itrontask04.doc (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontime01/system.h (modified) General cleanup. Test documentation improved. The message buffer ... Wed, 10 Nov 1999 22:14:26 GMT Joel Sherrill [59d1127] * c/src/exec/score/src/objectallocatebyindex.c (modified) * cpukit/score/src/objectallocatebyindex.c (modified) Corrected to account for the way memory is divided up in ... Wed, 10 Nov 1999 22:13:42 GMT Joel Sherrill [7d29dc7f] * c/src/exec/score/include/rtems/score/Makefile.in (modified) Added line to make sure HAS_ITRON_API is defined in Makefile. Wed, 10 Nov 1999 20:37:01 GMT Joel Sherrill [72719d2] * c/src/exec/rtems/src/semflush.c (modified) * cpukit/rtems/src/semflush.c (modified) Added call to _Thread_Enable_dispatch() and did some cleanup. Wed, 10 Nov 1999 20:36:25 GMT Joel Sherrill [74db82a] * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/sptests/sp27/Makefile.in (added) * c/src/tests/sptests/sp27/TODO (deleted) * c/src/tests/sptests/sp27/init.c (added) * c/src/tests/sptests/sp27/sp27.doc (added) * c/src/tests/sptests/sp27/sp27.scn (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/sp27/init.c (added) * testsuites/sptests/sp27/sp27.doc (added) * testsuites/sptests/sp27/sp27.scn (added) rtems_semaphore_flush test from Eric Norum . Wed, 10 Nov 1999 14:31:11 GMT Joel Sherrill [cbccd37] * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (added) * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (added) * c/src/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (added) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) Patch from Eric Norum which includes: ... Wed, 10 Nov 1999 14:19:55 GMT Joel Sherrill [442d0478] * c/src/tests/itrontests/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.in (added) * c/src/tests/itrontests/itronmbf01/Makefile.in (added) * c/src/tests/itrontests/itronsem01/Makefile.in (added) * c/src/tests/itrontests/itrontask01/Makefile.in (modified) * c/src/tests/itrontests/itrontask02/Makefile.in (modified) * c/src/tests/itrontests/itrontask03/Makefile.in (modified) * c/src/tests/itrontests/itrontask04/Makefile.in (modified) * c/src/tests/itrontests/itrontime01/Makefile.in (added) * c/src/tests/itrontests/itrontime01/init.c (added) * c/src/tests/itrontests/itrontime01/itrontime01.doc (added) * c/src/tests/itrontests/itrontime01/itrontime01.scn (added) * c/src/tests/itrontests/itrontime01/system.h (added) * testsuites/itrontests/Makefile.am (modified) * testsuites/itrontests/itrontime01/init.c (added) * testsuites/itrontests/itrontime01/itrontime01.doc (added) * testsuites/itrontests/itrontime01/itrontime01.scn (added) * testsuites/itrontests/itrontime01/system.h (added) Combination of committing some new files which had been overlooked ... Wed, 10 Nov 1999 13:48:27 GMT Joel Sherrill [eb02f47] * c/src/exec/itron/include/itronsys/types.h (modified) * c/src/exec/itron/include/rtems/itron/object.h (modified) * c/src/exec/itron/include/rtems/itron/task.h (modified) * c/src/exec/itron/inline/rtems/itron/task.inl (modified) * c/src/exec/itron/src/can_wup.c (modified) * c/src/exec/itron/src/chg_pri.c (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/del_tsk.c (modified) * c/src/exec/itron/src/exd_tsk.c (modified) * c/src/exec/itron/src/ext_tsk.c (modified) * c/src/exec/itron/src/frsm_tsk.c (modified) * c/src/exec/itron/src/get_tid.c (modified) * c/src/exec/itron/src/ref_tsk.c (modified) * c/src/exec/itron/src/rel_wai.c (modified) * c/src/exec/itron/src/rot_rdq.c (modified) * c/src/exec/itron/src/rsm_tsk.c (modified) * c/src/exec/itron/src/slp_tsk.c (modified) * c/src/exec/itron/src/sta_tsk.c (modified) * c/src/exec/itron/src/sus_tsk.c (modified) * c/src/exec/itron/src/task.c (modified) * c/src/exec/itron/src/ter_tsk.c (modified) * c/src/exec/rtems/src/taskresume.c (modified) * c/src/exec/rtems/src/tasksuspend.c (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/inline/rtems/score/thread.inl (modified) * c/src/exec/score/macros/rtems/score/thread.inl (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/src/threadinitialize.c (modified) * c/src/exec/score/src/threadrestart.c (modified) * c/src/exec/score/src/threadresume.c (added) * c/src/exec/score/src/threadrotatequeue.c (added) * c/src/exec/score/src/threadsuspend.c (added) * c/src/tests/itrontests/itrontask03/Makefile.in (modified) * c/src/tests/itrontests/itrontask03/spinit.c (deleted) * configure.in (modified) * cpukit/itron/include/itronsys/types.h (modified) * cpukit/itron/include/rtems/itron/object.h (modified) * cpukit/itron/include/rtems/itron/task.h (modified) * cpukit/itron/inline/rtems/itron/task.inl (modified) * cpukit/itron/src/can_wup.c (modified) * cpukit/itron/src/chg_pri.c (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/exd_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/get_tid.c (modified) * cpukit/itron/src/ref_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rot_rdq.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/slp_tsk.c (modified) * cpukit/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/task.c (modified) * cpukit/itron/src/ter_tsk.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/macros/rtems/score/thread.inl (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadresume.c (added) * cpukit/score/src/threadrotatequeue.c (added) * cpukit/score/src/threadsuspend.c (added) Committed modifications from ITRON Task and Task Dependendent ... Wed, 10 Nov 1999 13:45:54 GMT Joel Sherrill [dcc1f6b6] * c/src/tests/tools/generic/difftest.in (modified) * testsuites/tools/generic/difftest.in (modified) Added support for ITRON tests. Wed, 10 Nov 1999 13:38:34 GMT Joel Sherrill [a5f5acad] * doc/itron3.0/eventflags.t (modified) * doc/itron3.0/fixedblock.t (modified) * doc/itron3.0/mailbox.t (modified) * doc/itron3.0/memorypool.t (modified) * doc/itron3.0/status.t (modified) Updated to include more documentation from CS595. Wed, 10 Nov 1999 13:21:33 GMT Joel Sherrill [aff08f5] * doc/itron3.0/mailbox.t (modified) Better formatting. Tue, 09 Nov 1999 23:28:04 GMT Joel Sherrill [bab5ba44] * c/src/tests/itrontests/Makefile.am (modified) * c/src/tests/itrontests/configure.in (modified) * testsuites/itrontests/Makefile.am (modified) Added more tasking tests. Tue, 09 Nov 1999 23:27:05 GMT Joel Sherrill [e099180] * c/src/tests/itrontests/itronhello/itronhello.doc (added) * c/src/tests/itrontests/itronhello/itronhello.scn (added) * c/src/tests/itrontests/itronmbf01/itronmbf01.doc (added) * c/src/tests/itrontests/itronmbf01/itronmbf01.scn (added) * c/src/tests/itrontests/itronsem01/itronsem01.doc (added) * c/src/tests/itrontests/itronsem01/itronsem01.scn (added) * c/src/tests/itrontests/itrontask01/Makefile.in (added) * c/src/tests/itrontests/itrontask01/init.c (modified) * c/src/tests/itrontests/itrontask01/itrontask01.doc (added) * c/src/tests/itrontests/itrontask01/itrontask01.scn (added) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask01/task1.c (added) * c/src/tests/itrontests/itrontask02/Makefile.in (added) * c/src/tests/itrontests/itrontask02/init.c (added) * c/src/tests/itrontests/itrontask02/itrontask02.doc (added) * c/src/tests/itrontests/itrontask02/itrontask02.scn (added) * c/src/tests/itrontests/itrontask02/preempt.c (added) * c/src/tests/itrontests/itrontask02/system.h (added) * c/src/tests/itrontests/itrontask03/Makefile.in (added) * c/src/tests/itrontests/itrontask03/init.c (added) * c/src/tests/itrontests/itrontask03/itrontask03.doc (added) * c/src/tests/itrontests/itrontask03/itrontask03.scn (added) * c/src/tests/itrontests/itrontask03/preempt.c (added) * c/src/tests/itrontests/itrontask03/spinit.c (added) * c/src/tests/itrontests/itrontask03/system.h (added) * c/src/tests/itrontests/itrontask03/task1.c (added) * c/src/tests/itrontests/itrontask03/task2.c (added) * c/src/tests/itrontests/itrontask03/task3.c (added) * c/src/tests/itrontests/itrontask04/Makefile.in (added) * c/src/tests/itrontests/itrontask04/init.c (added) * c/src/tests/itrontests/itrontask04/itrontask04.doc (added) * c/src/tests/itrontests/itrontask04/itrontask04.scn (added) * c/src/tests/itrontests/itrontask04/system.h (added) * c/src/tests/itrontests/itrontask04/task1.c (added) * c/src/tests/itrontests/itrontask04/task2.c (added) * c/src/tests/itrontests/itrontask04/task3.c (added) * testsuites/itrontests/itronhello/itronhello.doc (added) * testsuites/itrontests/itronhello/itronhello.scn (added) * testsuites/itrontests/itronmbf01/itronmbf01.doc (added) * testsuites/itrontests/itronmbf01/itronmbf01.scn (added) * testsuites/itrontests/itronsem01/itronsem01.doc (added) * testsuites/itrontests/itronsem01/itronsem01.scn (added) * testsuites/itrontests/itrontask01/init.c (modified) * testsuites/itrontests/itrontask01/itrontask01.doc (added) * testsuites/itrontests/itrontask01/itrontask01.scn (added) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask01/task1.c (added) * testsuites/itrontests/itrontask02/init.c (added) * testsuites/itrontests/itrontask02/itrontask02.doc (added) * testsuites/itrontests/itrontask02/itrontask02.scn (added) * testsuites/itrontests/itrontask02/system.h (added) * testsuites/itrontests/itrontask03/init.c (added) * testsuites/itrontests/itrontask03/itrontask03.doc (added) * testsuites/itrontests/itrontask03/itrontask03.scn (added) * testsuites/itrontests/itrontask03/preempt.c (added) * testsuites/itrontests/itrontask03/system.h (added) * testsuites/itrontests/itrontask03/task1.c (added) * testsuites/itrontests/itrontask03/task2.c (added) * testsuites/itrontests/itrontask03/task3.c (added) * testsuites/itrontests/itrontask04/init.c (added) * testsuites/itrontests/itrontask04/itrontask04.doc (added) * testsuites/itrontests/itrontask04/itrontask04.scn (added) * testsuites/itrontests/itrontask04/system.h (added) * testsuites/itrontests/itrontask04/task1.c (added) * testsuites/itrontests/itrontask04/task2.c (added) * testsuites/itrontests/itrontask04/task3.c (added) Merged tests from Task group. Tue, 09 Nov 1999 23:10:48 GMT Joel Sherrill [3d67661] * c/src/tests/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm26/task1.c (modified) Added nesting count for suspend/resume. Tue, 09 Nov 1999 22:45:35 GMT Joel Sherrill [70e9af9] * c/src/tests/samples/paranoia/paranoia.c (modified) * testsuites/samples/paranoia/paranoia.c (modified) Changed B, H, and W variables to BVar, HVar, and WVar to avoid ... Tue, 09 Nov 1999 22:25:55 GMT Joel Sherrill [e18ba7f] * c/src/exec/itron/include/itronsys/types.h (modified) * cpukit/itron/include/itronsys/types.h (modified) Commented out single letter type names since they conflict with ... Tue, 09 Nov 1999 22:18:43 GMT Joel Sherrill [c73b8ac2] * aclocal/check-itron.m4 (added) * aclocal/enable-itron.m4 (added) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/Makefile.inc.in (modified) * c/src/make/bsp.cfg.in (modified) * c/src/make/configure.in (modified) * c/src/make/target.cfg.in (modified) * c/src/wrapup/Makefile.in (modified) * configure.in (modified) * make/target.cfg.in (modified) * tools/update/cipolish (modified) This patch adds the basic framework for the ITRON 3.0 API ... Tue, 09 Nov 1999 22:16:16 GMT Joel Sherrill [c8cad188] * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/Makefile (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/Makefile (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/adasockets/Makefile (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/Makefile (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/Makefile (deleted) Removed. Tue, 09 Nov 1999 22:14:21 GMT Joel Sherrill [ad502d18] * c/src/tests/samples/cdtest/main.cc (modified) * testsuites/samples/cdtest/main.cc (modified) Renamed classes to avoid single letter class names. Tue, 09 Nov 1999 22:07:23 GMT Joel Sherrill [352c9b2] * c/src/exec/Makefile.am (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/Makefile.am (added) * c/src/exec/itron/configure.in (added) * c/src/exec/itron/include/Makefile.am (added) * c/src/exec/itron/include/itron.h (added) * c/src/exec/itron/include/itronsys/Makefile.am (added) * c/src/exec/itron/include/itronsys/README (added) * c/src/exec/itron/include/itronsys/eventflags.h (added) * c/src/exec/itron/include/itronsys/fmempool.h (added) * c/src/exec/itron/include/itronsys/intr.h (added) * c/src/exec/itron/include/itronsys/mbox.h (added) * c/src/exec/itron/include/itronsys/msgbuffer.h (added) * c/src/exec/itron/include/itronsys/network.h (added) * c/src/exec/itron/include/itronsys/port.h (added) * c/src/exec/itron/include/itronsys/semaphore.h (added) * c/src/exec/itron/include/itronsys/status.h (added) * c/src/exec/itron/include/itronsys/sysmgmt.h (added) * c/src/exec/itron/include/itronsys/task.h (added) * c/src/exec/itron/include/itronsys/time.h (added) * c/src/exec/itron/include/itronsys/types.h (added) * c/src/exec/itron/include/itronsys/vmempool.h (added) * c/src/exec/itron/include/rtems/Makefile.am (added) * c/src/exec/itron/include/rtems/itron/Makefile.am (added) * c/src/exec/itron/include/rtems/itron/README (added) * c/src/exec/itron/include/rtems/itron/config.h (added) * c/src/exec/itron/include/rtems/itron/eventflags.h (added) * c/src/exec/itron/include/rtems/itron/fmempool.h (added) * c/src/exec/itron/include/rtems/itron/intr.h (added) * c/src/exec/itron/include/rtems/itron/itronapi.h (added) * c/src/exec/itron/include/rtems/itron/mbox.h (added) * c/src/exec/itron/include/rtems/itron/msgbuffer.h (added) * c/src/exec/itron/include/rtems/itron/network.h (added) * c/src/exec/itron/include/rtems/itron/object.h (added) * c/src/exec/itron/include/rtems/itron/port.h (added) * c/src/exec/itron/include/rtems/itron/semaphore.h (added) * c/src/exec/itron/include/rtems/itron/sysmgmt.h (added) * c/src/exec/itron/include/rtems/itron/task.h (added) * c/src/exec/itron/include/rtems/itron/time.h (added) * c/src/exec/itron/include/rtems/itron/vmempool.h (added) * c/src/exec/itron/inline/Makefile.am (added) * c/src/exec/itron/inline/rtems/Makefile.am (added) * c/src/exec/itron/inline/rtems/itron/Makefile.am (added) * c/src/exec/itron/inline/rtems/itron/eventflags.inl (added) * c/src/exec/itron/inline/rtems/itron/fmempool.inl (added) * c/src/exec/itron/inline/rtems/itron/intr.inl (added) * c/src/exec/itron/inline/rtems/itron/mbox.inl (added) * c/src/exec/itron/inline/rtems/itron/msgbuffer.inl (added) * c/src/exec/itron/inline/rtems/itron/network.inl (added) * c/src/exec/itron/inline/rtems/itron/port.inl (added) * c/src/exec/itron/inline/rtems/itron/semaphore.inl (added) * c/src/exec/itron/inline/rtems/itron/sysmgmt.inl (added) * c/src/exec/itron/inline/rtems/itron/task.inl (added) * c/src/exec/itron/inline/rtems/itron/time.inl (added) * c/src/exec/itron/inline/rtems/itron/vmempool.inl (added) * c/src/exec/itron/src/Makefile.in (added) * c/src/exec/itron/src/can_wup.c (added) * c/src/exec/itron/src/chg_pri.c (added) * c/src/exec/itron/src/cre_tsk.c (added) * c/src/exec/itron/src/del_tsk.c (added) * c/src/exec/itron/src/dis_dsp.c (added) * c/src/exec/itron/src/ena_dsp.c (added) * c/src/exec/itron/src/eventflags.c (added) * c/src/exec/itron/src/exd_tsk.c (added) * c/src/exec/itron/src/ext_tsk.c (added) * c/src/exec/itron/src/fmempool.c (added) * c/src/exec/itron/src/frsm_tsk.c (added) * c/src/exec/itron/src/get_tid.c (added) * c/src/exec/itron/src/itronintr.c (added) * c/src/exec/itron/src/itronsem.c (added) * c/src/exec/itron/src/itrontime.c (added) * c/src/exec/itron/src/mbox.c (added) * c/src/exec/itron/src/msgbuffer.c (added) * c/src/exec/itron/src/network.c (added) * c/src/exec/itron/src/port.c (added) * c/src/exec/itron/src/ref_tsk.c (added) * c/src/exec/itron/src/rel_wai.c (added) * c/src/exec/itron/src/rot_rdq.c (added) * c/src/exec/itron/src/rsm_tsk.c (added) * c/src/exec/itron/src/slp_tsk.c (added) * c/src/exec/itron/src/sta_tsk.c (added) * c/src/exec/itron/src/sus_tsk.c (added) * c/src/exec/itron/src/sysmgmt.c (added) * c/src/exec/itron/src/task.c (added) * c/src/exec/itron/src/ter_tsk.c (added) * c/src/exec/itron/src/tslp_tsk.c (added) * c/src/exec/itron/src/vmempool.c (added) * c/src/exec/itron/src/wup_tsk.c (added) * c/src/exec/posix/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/itronapi.c (added) * c/src/exec/score/cpu/configure.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/score/interr.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/wrapup/Makefile.am (modified) * c/src/exec/wrapup/itron/Makefile.in (added) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/Makefile.am (added) * c/src/tests/itrontests/README (added) * c/src/tests/itrontests/configure.in (added) * c/src/tests/itrontests/itronhello/init.c (added) * c/src/tests/itrontests/itronhello/system.h (added) * c/src/tests/itrontests/itronmbf01/init.c (added) * c/src/tests/itrontests/itronmbf01/system.h (added) * c/src/tests/itrontests/itronsem01/init.c (added) * c/src/tests/itrontests/itronsem01/system.h (added) * c/src/tests/itrontests/itrontask01/init.c (added) * c/src/tests/itrontests/itrontask01/system.h (added) * c/src/tests/samples/configure.in (modified) * c/src/tests/tmitrontests/Makefile.am (added) * c/src/tests/tmitrontests/README (added) * c/src/tests/tmitrontests/configure.in (added) * c/src/tests/tmitrontests/include/Makefile.am (added) * c/src/tests/tmitrontests/include/timesys.h (added) * c/src/tests/tmitrontests/tmitronsem01/Makefile.in (added) * c/src/tests/tmitrontests/tmitronsem01/init.c (added) * c/src/tests/tmitrontests/tmitronsem01/system.h (added) * c/src/tests/tmitrontests/tmitronsem01/tmitronsem01.doc (added) * cpukit/Makefile.am (modified) * cpukit/itron/Makefile.am (added) * cpukit/itron/include/Makefile.am (added) * cpukit/itron/include/itron.h (added) * cpukit/itron/include/itronsys/README (added) * cpukit/itron/include/itronsys/eventflags.h (added) * cpukit/itron/include/itronsys/fmempool.h (added) * cpukit/itron/include/itronsys/intr.h (added) * cpukit/itron/include/itronsys/mbox.h (added) * cpukit/itron/include/itronsys/msgbuffer.h (added) * cpukit/itron/include/itronsys/network.h (added) * cpukit/itron/include/itronsys/port.h (added) * cpukit/itron/include/itronsys/semaphore.h (added) * cpukit/itron/include/itronsys/status.h (added) * cpukit/itron/include/itronsys/sysmgmt.h (added) * cpukit/itron/include/itronsys/task.h (added) * cpukit/itron/include/itronsys/time.h (added) * cpukit/itron/include/itronsys/types.h (added) * cpukit/itron/include/itronsys/vmempool.h (added) * cpukit/itron/include/rtems/itron/README (added) * cpukit/itron/include/rtems/itron/config.h (added) * cpukit/itron/include/rtems/itron/eventflags.h (added) * cpukit/itron/include/rtems/itron/fmempool.h (added) * cpukit/itron/include/rtems/itron/intr.h (added) * cpukit/itron/include/rtems/itron/itronapi.h (added) * cpukit/itron/include/rtems/itron/mbox.h (added) * cpukit/itron/include/rtems/itron/msgbuffer.h (added) * cpukit/itron/include/rtems/itron/network.h (added) * cpukit/itron/include/rtems/itron/object.h (added) * cpukit/itron/include/rtems/itron/port.h (added) * cpukit/itron/include/rtems/itron/semaphore.h (added) * cpukit/itron/include/rtems/itron/sysmgmt.h (added) * cpukit/itron/include/rtems/itron/task.h (added) * cpukit/itron/include/rtems/itron/time.h (added) * cpukit/itron/include/rtems/itron/vmempool.h (added) * cpukit/itron/inline/Makefile.am (added) * cpukit/itron/inline/rtems/itron/eventflags.inl (added) * cpukit/itron/inline/rtems/itron/fmempool.inl (added) * cpukit/itron/inline/rtems/itron/intr.inl (added) * cpukit/itron/inline/rtems/itron/mbox.inl (added) * cpukit/itron/inline/rtems/itron/msgbuffer.inl (added) * cpukit/itron/inline/rtems/itron/network.inl (added) * cpukit/itron/inline/rtems/itron/port.inl (added) * cpukit/itron/inline/rtems/itron/semaphore.inl (added) * cpukit/itron/inline/rtems/itron/sysmgmt.inl (added) * cpukit/itron/inline/rtems/itron/task.inl (added) * cpukit/itron/inline/rtems/itron/time.inl (added) * cpukit/itron/inline/rtems/itron/vmempool.inl (added) * cpukit/itron/src/can_wup.c (added) * cpukit/itron/src/chg_pri.c (added) * cpukit/itron/src/cre_tsk.c (added) * cpukit/itron/src/del_tsk.c (added) * cpukit/itron/src/dis_dsp.c (added) * cpukit/itron/src/ena_dsp.c (added) * cpukit/itron/src/eventflags.c (added) * cpukit/itron/src/exd_tsk.c (added) * cpukit/itron/src/ext_tsk.c (added) * cpukit/itron/src/fmempool.c (added) * cpukit/itron/src/frsm_tsk.c (added) * cpukit/itron/src/get_tid.c (added) * cpukit/itron/src/itronintr.c (added) * cpukit/itron/src/itronsem.c (added) * cpukit/itron/src/itrontime.c (added) * cpukit/itron/src/mbox.c (added) * cpukit/itron/src/msgbuffer.c (added) * cpukit/itron/src/network.c (added) * cpukit/itron/src/port.c (added) * cpukit/itron/src/ref_tsk.c (added) * cpukit/itron/src/rel_wai.c (added) * cpukit/itron/src/rot_rdq.c (added) * cpukit/itron/src/rsm_tsk.c (added) * cpukit/itron/src/slp_tsk.c (added) * cpukit/itron/src/sta_tsk.c (added) * cpukit/itron/src/sus_tsk.c (added) * cpukit/itron/src/sysmgmt.c (added) * cpukit/itron/src/task.c (added) * cpukit/itron/src/ter_tsk.c (added) * cpukit/itron/src/tslp_tsk.c (added) * cpukit/itron/src/vmempool.c (added) * cpukit/itron/src/wup_tsk.c (added) * cpukit/posix/Makefile.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/itronapi.c (added) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/itrontests/Makefile.am (added) * testsuites/itrontests/README (added) * testsuites/itrontests/itronhello/init.c (added) * testsuites/itrontests/itronhello/system.h (added) * testsuites/itrontests/itronmbf01/init.c (added) * testsuites/itrontests/itronmbf01/system.h (added) * testsuites/itrontests/itronsem01/init.c (added) * testsuites/itrontests/itronsem01/system.h (added) * testsuites/itrontests/itrontask01/init.c (added) * testsuites/itrontests/itrontask01/system.h (added) * testsuites/tmitrontests/Makefile.am (added) * testsuites/tmitrontests/README (added) * testsuites/tmitrontests/include/Makefile.am (added) * testsuites/tmitrontests/include/timesys.h (added) * testsuites/tmitrontests/tmitronsem01/init.c (added) * testsuites/tmitrontests/tmitronsem01/system.h (added) * testsuites/tmitrontests/tmitronsem01/tmitronsem01.doc (added) This patch adds the basic framework for the ITRON 3.0 API ... Tue, 09 Nov 1999 19:54:40 GMT Joel Sherrill [1007c3c] * c/src/exec/sapi/src/posixapi.c (modified) * cpukit/sapi/src/posixapi.c (modified) Fixed warning where initialized default POSIX API structure did have ... Tue, 09 Nov 1999 19:45:23 GMT Joel Sherrill [bd0b378] * c/src/exec/rtems/src/semflush.c (modified) * cpukit/rtems/src/semflush.c (modified) Removed unused variable warning. Tue, 09 Nov 1999 16:40:44 GMT Joel Sherrill [1baa059] * doc/itron3.0/eventflags.t (modified) * doc/itron3.0/fixedblock.t (modified) * doc/itron3.0/memorypool.t (modified) Converted from DOS to UNIX filemode. Tue, 09 Nov 1999 16:23:29 GMT Joel Sherrill [aebc7aa5] * doc/itron3.0/eventflags.t (modified) * doc/itron3.0/semaphore.t (modified) Corrected lines that were too long. Tue, 09 Nov 1999 16:23:20 GMT Joel Sherrill [6457fae2] * doc/itron3.0/status.t (modified) Fixed formatting error. Tue, 09 Nov 1999 16:23:10 GMT Joel Sherrill [6682008] * doc/itron3.0/itron.texi (modified) Corrected manual name. Tue, 09 Nov 1999 16:22:36 GMT Joel Sherrill [15c8c37] * doc/itron3.0/Makefile (modified) Integrated into main tree. Tue, 09 Nov 1999 15:49:45 GMT Joel Sherrill [b671c6a] * doc/itron3.0/status.t (modified) Update from Jennifer. Tue, 09 Nov 1999 15:38:47 GMT Joel Sherrill [d55af6d] * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/config.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/i8042.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550.c (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550.h (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550_p.h (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30.c (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30.h (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30_p.h (deleted) Now using libchip instead of local precursor to libchip. Untested. Tue, 09 Nov 1999 13:40:57 GMT Joel Sherrill [53b1847] * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) Removed reaching "up and over" to install BSP header files. Tue, 09 Nov 1999 13:40:30 GMT Joel Sherrill [b440e57b] * c/src/exec/libfs/src/imfs/imfs_unixstub.c (added) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/imfs_unixstub.c (added) * c/src/libfs/src/imfs/imfs_unixstub.c (added) * cpukit/libfs/src/imfs/imfs_unixstub.c (added) Added imfs_unixstub.c to satisfy linker problems on UNIX port. Tue, 09 Nov 1999 13:39:42 GMT Joel Sherrill [3fb8909a] * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/src/semclose.c (added) * cpukit/posix/src/semclose.c (added) sem_close was accidentally lost in the split. Tue, 09 Nov 1999 13:38:00 GMT Joel Sherrill [a8df60b] * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.in (added) * c/src/tests/psxtests/psxmsgq01/init.c (added) * c/src/tests/psxtests/psxmsgq01/psxmsgq01.scn (added) * c/src/tests/psxtests/psxmsgq01/system.h (added) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/init.c (added) * testsuites/psxtests/psxmsgq01/psxmsgq01.scn (added) * testsuites/psxtests/psxmsgq01/system.h (added) New test for POSIX Message Queues added. Tue, 09 Nov 1999 13:36:26 GMT Joel Sherrill [27eb3ec] * c/src/tests/psxtests/psxsem01/Makefile.in (added) * c/src/tests/psxtests/psxsem01/init.c (added) * c/src/tests/psxtests/psxsem01/psxsem01.scn (added) * c/src/tests/psxtests/psxsem01/system.h (added) * testsuites/psxtests/psxsem01/init.c (added) * testsuites/psxtests/psxsem01/psxsem01.scn (added) * testsuites/psxtests/psxsem01/system.h (added) New files.
