# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 03/29/24 13:06:43 Tue, 12 Feb 2019 09:26:34 GMT Sebastian Huber [7fdcd023] * testsuites/psxtests/psxhdrs/math/expm1. (deleted) psxtests: Remove bogus file This file is unused and makes trouble ... Mon, 11 Feb 2019 06:34:14 GMT Sebastian Huber [eec706e2] * bsps/powerpc/include/bsp/linker-symbols.h (modified) * bsps/powerpc/psim/start/linkcmds (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) bsps/powerpc: Fix small data area section Fix small data area in ... Sat, 02 Feb 2019 04:09:53 GMT Chris Johns [6c9f017] * bsps/powerpc/psim/start/linkcmds (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-bit-alloc.c (added) * cpukit/libdl/rtl-bit-alloc.h (added) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/dl01/dl-load.c (modified) * testsuites/libtests/dl02/dl-load.c (modified) * testsuites/libtests/dl02/dl-o1.c (modified) * testsuites/libtests/dl02/dl-o2.c (modified) * testsuites/libtests/dl03/dl-bit-alloc.c (added) * testsuites/libtests/dl03/dl-bit-alloc.h (added) * testsuites/libtests/dl03/init.c (modified) * testsuites/libtests/dl05/dl-load.c (modified) * testsuites/libtests/dl07/dl-load.c (modified) * testsuites/libtests/dl07/dl-o1.c (modified) * testsuites/libtests/dl07/dl-o2.c (modified) * testsuites/libtests/dl07/dl-o3.c (modified) * testsuites/libtests/dl07/dl-o4.c (modified) * testsuites/libtests/dl07/dl-o5.c (modified) * testsuites/libtests/dl07/init.c (modified) * testsuites/libtests/dl08/dl-o1.c (modified) * testsuites/libtests/dl08/dl-o2.c (modified) * testsuites/libtests/dl08/dl-o3.c (modified) * testsuites/libtests/dl08/dl-o4.c (modified) * testsuites/libtests/dl08/dl-o5.c (modified) * testsuites/libtests/dl08/dl-o6-123456789-123456789.c (modified) * testsuites/libtests/dl09/dl-load.c (modified) * testsuites/libtests/dl09/dl-o1.c (modified) * testsuites/libtests/dl09/dl-o2.c (modified) * testsuites/libtests/dl09/dl-o3.c (modified) * testsuites/libtests/dl09/dl-o4.c (modified) * testsuites/libtests/dl09/dl-o5.c (modified) libdl: Add powerpc large memory and small data support. - Add ... Mon, 21 Jan 2019 21:48:19 GMT Chris Johns [194eb403] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/dl08/dl-load.c (modified) * testsuites/libtests/dl09/dl-load.c (modified) * testsuites/libtests/dl09/dl-o5.c (modified) libdl: Add support for large memory programs - Add trampolines to ... Tue, 15 Jan 2019 06:47:41 GMT Chris Johns [d8c70ba6] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl01/dl-load.c (modified) * testsuites/libtests/dl08/dl-load.c (modified) * testsuites/libtests/dl09/dl-load.c (added) * testsuites/libtests/dl09/dl-load.h (added) * testsuites/libtests/dl09/dl-o1.c (added) * testsuites/libtests/dl09/dl-o1.h (added) * testsuites/libtests/dl09/dl-o2.c (added) * testsuites/libtests/dl09/dl-o2.h (added) * testsuites/libtests/dl09/dl-o3.c (added) * testsuites/libtests/dl09/dl-o3.h (added) * testsuites/libtests/dl09/dl-o4.c (added) * testsuites/libtests/dl09/dl-o4.h (added) * testsuites/libtests/dl09/dl-o5.c (added) * testsuites/libtests/dl09/dl-o5.h (added) * testsuites/libtests/dl09/dl09.doc (added) * testsuites/libtests/dl09/dl09.scn (added) * testsuites/libtests/dl09/init.c (added) libdl: Add support for trampolines - Trampolines or fixups for ... Wed, 09 Jan 2019 11:14:11 GMT Chris Johns [4408603] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * cpukit/score/cpu/arm/include/machine/elf_machdep.h (modified) * testsuites/libtests/dl08/dl-load.c (modified) libdl: Fix the support for constructors and desctructors. - Fix the ... Mon, 17 Dec 2018 06:48:30 GMT Chris Johns [a7c6176] * cpukit/headers.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl08/dl-load.c (added) * testsuites/libtests/dl08/dl-load.h (added) * testsuites/libtests/dl08/dl-o1.c (added) * testsuites/libtests/dl08/dl-o1.h (added) * testsuites/libtests/dl08/dl-o2.c (added) * testsuites/libtests/dl08/dl-o2.h (added) * testsuites/libtests/dl08/dl-o3.c (added) * testsuites/libtests/dl08/dl-o3.h (added) * testsuites/libtests/dl08/dl-o4.c (added) * testsuites/libtests/dl08/dl-o4.h (added) * testsuites/libtests/dl08/dl-o5.c (added) * testsuites/libtests/dl08/dl-o5.h (added) * testsuites/libtests/dl08/dl-o6-123456789-123456789.c (added) * testsuites/libtests/dl08/dl-o6.h (added) * testsuites/libtests/dl08/dl08.doc (added) * testsuites/libtests/dl08/dl08.scn (added) * testsuites/libtests/dl08/init.c (added) libtest/dl08: Add a test for archives. - Create 2 archives. - Load ... Mon, 17 Dec 2018 06:40:46 GMT Chris Johns [bac53634] * testsuites/libtests/dl07/dl-load.c (modified) libtests/dl02: Update the rtl-shell path. More verbose test. ... Mon, 17 Dec 2018 06:40:25 GMT Chris Johns [85b59974] * testsuites/libtests/dl02/dl-load.c (modified) libtests/dl02: Update the rtl-shell path. Updates #3686 Mon, 17 Dec 2018 05:36:48 GMT Chris Johns [89c59be] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtl/rtl-archive.h (added) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-shell.h (moved) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rtl-archive.c (added) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-string.h (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) libdl: Add symbol searching and loading from archives. - Load ... Sat, 02 Feb 2019 04:32:38 GMT Chris Johns [b08278e] * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/psim/start/device-tree (modified) * bsps/powerpc/psim/start/linkcmds (modified) powerpc/psim: Increase the psim memory to 256M This allows test ... Sat, 02 Feb 2019 04:19:59 GMT Chris Johns [e2f13430] * cpukit/libdl/dlfcn.c (modified) libdl: Fix dlerror non-conformance Closes #3298 Sat, 02 Feb 2019 04:22:04 GMT Chris Johns [2d8a9c79] * cpukit/libmisc/dumpbuf/dumpbuf.c (modified) libmisc: Fix rtems_print_buffer Closes #3684 Fri, 08 Feb 2019 11:40:45 GMT Jiri Gaisler [568490a] * bsps/riscv/griscv/config/griscv.cfg (modified) * bsps/riscv/griscv/config/grv32i.cfg (added) * bsps/riscv/griscv/config/grv32im.cfg (added) * bsps/riscv/griscv/config/grv32imac.cfg (added) * bsps/riscv/griscv/config/grv32imafdc.cfg (added) griscv: add additional cpu configurations * Also switch ... Fri, 08 Feb 2019 09:16:07 GMT Sebastian Huber [26333f2a] * cpukit/include/rtems/score/userextimpl.h (modified) score: Fix _User_extensions_Thread_switch() (SMP) We have to read ... Thu, 07 Feb 2019 10:13:01 GMT Sebastian Huber [4e686261] * bsps/shared/irq/irq-server.c (modified) bsps/irq: Fix interrupt server init (SMP) Thu, 07 Feb 2019 06:46:38 GMT Sebastian Huber [fbd08066] * cpukit/score/src/threadqops.c (modified) * testsuites/smptests/smpmutex01/init.c (modified) score: Fix plain priority thread queues (SMP) We must add/remove ... Thu, 07 Feb 2019 06:45:58 GMT Sebastian Huber [0fb52ce] * bsps/arm/shared/clock/clock-generic-timer.c (modified) bsps/arm: Fix generic timer frequency Update #3456. Tue, 27 Nov 2018 11:45:53 GMT Sebastian Huber [03fcbb1] * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/imfs/imfs_dir_default.c (modified) * cpukit/libfs/src/jffs2/include/linux/fs.h (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * testsuites/fstests/fsscandir01/init.c (modified) fs: Add struct dirent::d_type support Sat, 02 Feb 2019 10:03:13 GMT Sebastian Huber [9399473c] * cpukit/score/cpu/riscv/riscv-context-validate.S (modified) riscv: Fix misaligned access in context validate Mon, 28 Jan 2019 11:26:25 GMT Sebastian Huber [b015c01] * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/benchmarks/Makefile.am (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtmtests/Makefile.am (modified) * testsuites/rhealstone/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/tmtests/Makefile.am (modified) build: Do not install test programs Wed, 30 Jan 2019 08:41:49 GMT Sebastian Huber [03cdd5ea] * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record.c (modified) * testsuites/libtests/record01/init.c (modified) * testsuites/libtests/record02/init.c (modified) record: Add enum value for each event Update #3665. Sat, 28 Apr 2018 09:36:11 GMT Sebastian Huber [dca6184] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/record.h (added) * cpukit/include/rtems/recordclient.h (added) * cpukit/include/rtems/recorddata.h (added) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/libtrace/record/record-client.c (added) * cpukit/libtrace/record/record-server.c (added) * cpukit/libtrace/record/record-sysinit.c (added) * cpukit/libtrace/record/record-text.c (added) * cpukit/libtrace/record/record-userext.c (added) * cpukit/libtrace/record/record.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/record01/init.c (added) * testsuites/libtests/record01/record01.doc (added) * testsuites/libtests/record01/record01.scn (added) * testsuites/libtests/record02/init.c (added) * testsuites/libtests/record02/record02.doc (added) * testsuites/libtests/record02/record02.scn (added) Add low level event recording support Add low level event recording ... Thu, 17 Jan 2019 06:33:08 GMT Sebastian Huber [f0ae613b] * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) m68k: Avoid _Addresses_Add_offset() This prevents a cyclic ... Tue, 29 Jan 2019 12:26:12 GMT Sebastian Huber [e74a3fd] * testsuites/samples/pppd/system.h (modified) samples/pppd: Use less memory hungry configuration This avoids ... Mon, 28 Jan 2019 13:16:39 GMT Sebastian Huber [4f3a253] * testsuites/psxtmtests/psxtmbarrierattr01/init.c (modified) * testsuites/psxtmtests/psxtmcleanup01/init.c (modified) * testsuites/psxtmtests/psxtmmutexattr01/init.c (modified) * testsuites/psxtmtests/psxtmonce01/init.c (modified) psxtmtests: Fix format warnings Update #3384. Fri, 25 Jan 2019 14:50:14 GMT Sebastian Huber [b1381ae] * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/shared/exceptions/ppc_exc_initialize.c (modified) bsps/powerpc: Fix warnings Thu, 24 Jan 2019 13:29:03 GMT Sebastian Huber [81aec18] * bsps/powerpc/include/libcpu/powerpc-utility.h (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/powerpc/shared/cpu_asm.S (modified) * bsps/powerpc/shared/start/bsp-start-zero.S (modified) bsps/powerpc: Fix 64-bit issues in assembler files We have to be ... Wed, 23 Jan 2019 12:17:44 GMT Maksim E. Kozlov [afd50b3] * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) libmisc: Fix swapped parameters and enable floating point usage. Fri, 18 Jan 2019 11:37:55 GMT Jiri Gaisler [d3d4e77] * bsps/riscv/griscv/clock/clockdrv.c (added) * bsps/riscv/griscv/config/griscv.cfg (added) * bsps/riscv/griscv/console/console.c (added) * bsps/riscv/griscv/console/printk_support.c (added) * bsps/riscv/griscv/headers.am (added) * bsps/riscv/griscv/include/amba.h (added) * bsps/riscv/griscv/include/bsp.h (added) * bsps/riscv/griscv/include/bsp/irq.h (added) * bsps/riscv/griscv/include/tm27.h (added) * bsps/riscv/griscv/irq/irq.c (added) * bsps/riscv/griscv/start/amba.c (added) * bsps/riscv/griscv/start/bsp_fatal_halt.c (added) * bsps/riscv/griscv/start/bsp_specs (added) * bsps/riscv/griscv/start/bspsmp.c (added) * bsps/riscv/griscv/start/bspstart.c (added) * bsps/riscv/griscv/start/linkcmds.in (added) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/shared/start/linkcmds.base (moved) * bsps/riscv/shared/start/start.S (moved) * c/src/lib/libbsp/riscv/acinclude.m4 (modified) * c/src/lib/libbsp/riscv/griscv/Makefile.am (added) * c/src/lib/libbsp/riscv/griscv/configure.ac (added) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: add griscv bsp Update #3678. Mon, 21 Jan 2019 10:27:07 GMT Jiri Gaisler [c1dcd6af] * bsps/include/grlib/grlib_impl.h (modified) * bsps/shared/grlib/spw/grspw.c (modified) grlib: make memory coherency cpu-independent Update #3678. Fri, 18 Jan 2019 17:00:47 GMT Jiri Gaisler [9b2b389] * bsps/include/grlib/grlib_impl.h (modified) * bsps/shared/grlib/1553/b1553brm.c (modified) * bsps/shared/grlib/1553/b1553rt.c (modified) * bsps/shared/grlib/can/grcan.c (modified) * bsps/shared/grlib/pci/grpci2dma.c (modified) * bsps/shared/grlib/spw/grspw.c (modified) * bsps/shared/grlib/spw/grspw_pkt.c (modified) * cpukit/score/cpu/riscv/headers.am (modified) * cpukit/score/cpu/riscv/include/libcpu/access.h (added) * cpukit/score/cpu/riscv/include/libcpu/byteorder.h (added) grlib: use cpu-independent routines for uncached access Update #3678. Fri, 18 Jan 2019 10:29:08 GMT Jiri Gaisler [5981c8ca] * bsps/shared/grlib/ascs/grascs.c (modified) * bsps/shared/grlib/can/satcan.c (modified) * bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c (modified) * bsps/shared/grlib/slink/grslink.c (modified) grlib: use rtems_interrupt_handler_install() Update #3678. Fri, 18 Jan 2019 10:24:18 GMT Jiri Gaisler [411c297] * bsps/include/grlib/apbuart.h (modified) * bsps/shared/grlib/uart/apbuart_cons.c (modified) * bsps/sparc/leon2/include/leon.h (modified) grlib: make apbuart driver independent of bsp Update #3678. Sat, 22 Dec 2018 17:31:04 GMT Sebastian Huber [7eb606d3] * bsps/shared/grlib-sources.am (added) * bsps/shared/grlib/1553/b1553brm.c (moved) * bsps/shared/grlib/1553/b1553rt.c (moved) * bsps/shared/grlib/1553/gr1553b.c (moved) * bsps/shared/grlib/1553/gr1553bc.c (moved) * bsps/shared/grlib/1553/gr1553bm.c (moved) * bsps/shared/grlib/1553/gr1553rt.c (moved) * bsps/shared/grlib/amba/ahbstat.c (moved) * bsps/shared/grlib/amba/ambapp.c (moved) * bsps/shared/grlib/amba/ambapp_alloc.c (moved) * bsps/shared/grlib/amba/ambapp_count.c (moved) * bsps/shared/grlib/amba/ambapp_depth.c (moved) * bsps/shared/grlib/amba/ambapp_find_by_idx.c (moved) * bsps/shared/grlib/amba/ambapp_freq.c (moved) * bsps/shared/grlib/amba/ambapp_names.c (moved) * bsps/shared/grlib/amba/ambapp_old.c (moved) * bsps/shared/grlib/amba/ambapp_parent.c (moved) * bsps/shared/grlib/amba/ambapp_show.c (moved) * bsps/shared/grlib/analog/gradcdac.c (moved) * bsps/shared/grlib/ascs/grascs.c (moved) * bsps/shared/grlib/btimer/gptimer.c (moved) * bsps/shared/grlib/btimer/tlib.c (moved) * bsps/shared/grlib/btimer/tlib_ckinit.c (moved) * bsps/shared/grlib/can/canmux.c (moved) * bsps/shared/grlib/can/grcan.c (moved) * bsps/shared/grlib/can/occan.c (moved) * bsps/shared/grlib/can/satcan.c (moved) * bsps/shared/grlib/drvmgr/ambapp_bus.c (moved) * bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c (moved) * bsps/shared/grlib/drvmgr/get_resarray_count.c (moved) * bsps/shared/grlib/gpio/gpiolib.c (moved) * bsps/shared/grlib/gpio/grgpio.c (moved) * bsps/shared/grlib/i2c/i2cmst.c (moved) * bsps/shared/grlib/iommu/griommu.c (moved) * bsps/shared/grlib/irq/genirq.c (moved) * bsps/shared/grlib/l2c/l2c.c (moved) * bsps/shared/grlib/mem/mctrl.c (moved) * bsps/shared/grlib/net/README (moved) * bsps/shared/grlib/net/greth.c (moved) * bsps/shared/grlib/net/network_interface_add.c (moved) * bsps/shared/grlib/pci/gr_701.c (moved) * bsps/shared/grlib/pci/gr_rasta_adcdac.c (moved) * bsps/shared/grlib/pci/gr_rasta_io.c (moved) * bsps/shared/grlib/pci/gr_rasta_spw_router.c (moved) * bsps/shared/grlib/pci/gr_rasta_tmtc.c (moved) * bsps/shared/grlib/pci/gr_tmtc_1553.c (moved) * bsps/shared/grlib/pci/grpci.c (moved) * bsps/shared/grlib/pci/grpci2.c (moved) * bsps/shared/grlib/pci/grpci2dma.c (moved) * bsps/shared/grlib/pci/pcif.c (moved) * bsps/shared/grlib/pwm/grpwm.c (moved) * bsps/shared/grlib/scrub/memscrub.c (moved) * bsps/shared/grlib/slink/grslink.c (moved) * bsps/shared/grlib/spi/spictrl.c (moved) * bsps/shared/grlib/spw/grspw.c (moved) * bsps/shared/grlib/spw/grspw_pkt.c (moved) * bsps/shared/grlib/spw/grspw_router.c (moved) * bsps/shared/grlib/spw/spwtdp.c (moved) * bsps/shared/grlib/stat/l4stat.c (moved) * bsps/shared/grlib/time/grctm.c (moved) * bsps/shared/grlib/time/spwcuc.c (moved) * bsps/shared/grlib/tmtc/grtc.c (moved) * bsps/shared/grlib/tmtc/grtm.c (moved) * bsps/shared/grlib/uart/apbuart_cons.c (moved) * bsps/shared/grlib/uart/apbuart_polled.c (moved) * bsps/shared/grlib/uart/apbuart_termios.c (moved) * bsps/shared/grlib/uart/cons.c (moved) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) grlib: Move source files Update #3678. Sat, 22 Dec 2018 06:13:44 GMT Sebastian Huber [31720925] * bsps/headers.am (modified) * bsps/include/grlib/ahbstat.h (moved) * bsps/include/grlib/ambapp.h (moved) * bsps/include/grlib/ambapp_bus.h (moved) * bsps/include/grlib/ambapp_bus_grlib.h (moved) * bsps/include/grlib/ambapp_ids.h (moved) * bsps/include/grlib/apbuart.h (moved) * bsps/include/grlib/apbuart_cons.h (moved) * bsps/include/grlib/apbuart_termios.h (moved) * bsps/include/grlib/b1553brm.h (moved) * bsps/include/grlib/b1553rt.h (moved) * bsps/include/grlib/bspcommon.h (moved) * bsps/include/grlib/canmux.h (moved) * bsps/include/grlib/cons.h (moved) * bsps/include/grlib/debug_defs.h (moved) * bsps/include/grlib/genirq.h (moved) * bsps/include/grlib/gpiolib.h (moved) * bsps/include/grlib/gptimer.h (moved) * bsps/include/grlib/gr1553b.h (moved) * bsps/include/grlib/gr1553bc.h (moved) * bsps/include/grlib/gr1553bc_list.h (moved) * bsps/include/grlib/gr1553bm.h (moved) * bsps/include/grlib/gr1553rt.h (moved) * bsps/include/grlib/gr_701.h (moved) * bsps/include/grlib/gr_cpci_gr740.h (moved) * bsps/include/grlib/gr_rasta_adcdac.h (moved) * bsps/include/grlib/gr_rasta_io.h (moved) * bsps/include/grlib/gr_rasta_spw_router.h (moved) * bsps/include/grlib/gr_rasta_tmtc.h (moved) * bsps/include/grlib/gr_tmtc_1553.h (moved) * bsps/include/grlib/gradcdac.h (moved) * bsps/include/grlib/grascs.h (moved) * bsps/include/grlib/grcan.h (moved) * bsps/include/grlib/grctm.h (moved) * bsps/include/grlib/greth.h (moved) * bsps/include/grlib/grgpio.h (moved) * bsps/include/grlib/griommu.h (moved) * bsps/include/grlib/grlib.h (moved) * bsps/include/grlib/grlib_impl.h (moved) * bsps/include/grlib/grpci.h (moved) * bsps/include/grlib/grpci2.h (moved) * bsps/include/grlib/grpci2dma.h (moved) * bsps/include/grlib/grpwm.h (moved) * bsps/include/grlib/grslink.h (moved) * bsps/include/grlib/grspw.h (moved) * bsps/include/grlib/grspw_pkt.h (moved) * bsps/include/grlib/grspw_router.h (moved) * bsps/include/grlib/grtc.h (moved) * bsps/include/grlib/grtm.h (moved) * bsps/include/grlib/i2cmst.h (moved) * bsps/include/grlib/l2c.h (moved) * bsps/include/grlib/l4stat.h (moved) * bsps/include/grlib/mctrl.h (moved) * bsps/include/grlib/memscrub.h (moved) * bsps/include/grlib/network_interface_add.h (moved) * bsps/include/grlib/occan.h (moved) * bsps/include/grlib/pcif.h (moved) * bsps/include/grlib/satcan.h (moved) * bsps/include/grlib/spictrl.h (moved) * bsps/include/grlib/spwcuc.h (moved) * bsps/include/grlib/spwtdp.h (moved) * bsps/include/grlib/tlib.h (moved) * bsps/sparc/headers.am (modified) * bsps/sparc/include/drvmgr/leon2_amba_bus.h (modified) * bsps/sparc/leon2/include/leon.h (modified) * bsps/sparc/leon3/btimer/watchdog.c (modified) * bsps/sparc/leon3/clock/ckinit.c (modified) * bsps/sparc/leon3/console/console.c (modified) * bsps/sparc/leon3/console/printk_support.c (modified) * bsps/sparc/leon3/include/amba.h (modified) * bsps/sparc/leon3/net/leon_smc91111.c (modified) * bsps/sparc/leon3/start/amba.c (modified) * bsps/sparc/shared/1553/b1553brm.c (modified) * bsps/sparc/shared/1553/b1553rt.c (modified) * bsps/sparc/shared/1553/gr1553b.c (modified) * bsps/sparc/shared/1553/gr1553bc.c (modified) * bsps/sparc/shared/1553/gr1553bm.c (modified) * bsps/sparc/shared/1553/gr1553rt.c (modified) * bsps/sparc/shared/amba/ahbstat.c (modified) * bsps/sparc/shared/amba/ambapp.c (modified) * bsps/sparc/shared/amba/ambapp_alloc.c (modified) * bsps/sparc/shared/amba/ambapp_count.c (modified) * bsps/sparc/shared/amba/ambapp_depth.c (modified) * bsps/sparc/shared/amba/ambapp_find_by_idx.c (modified) * bsps/sparc/shared/amba/ambapp_freq.c (modified) * bsps/sparc/shared/amba/ambapp_names.c (modified) * bsps/sparc/shared/amba/ambapp_old.c (modified) * bsps/sparc/shared/amba/ambapp_parent.c (modified) * bsps/sparc/shared/amba/ambapp_show.c (modified) * bsps/sparc/shared/analog/gradcdac.c (modified) * bsps/sparc/shared/ascs/grascs.c (modified) * bsps/sparc/shared/btimer/gptimer.c (modified) * bsps/sparc/shared/btimer/tlib.c (modified) * bsps/sparc/shared/btimer/tlib_ckinit.c (modified) * bsps/sparc/shared/can/canmux.c (modified) * bsps/sparc/shared/can/grcan.c (modified) * bsps/sparc/shared/can/occan.c (modified) * bsps/sparc/shared/can/satcan.c (modified) * bsps/sparc/shared/drvmgr/ambapp_bus.c (modified) * bsps/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * bsps/sparc/shared/drvmgr/ambapp_bus_leon2.c (modified) * bsps/sparc/shared/drvmgr/get_resarray_count.c (modified) * bsps/sparc/shared/gpio/gpiolib.c (modified) * bsps/sparc/shared/gpio/grgpio.c (modified) * bsps/sparc/shared/i2c/i2cmst.c (modified) * bsps/sparc/shared/iommu/griommu.c (modified) * bsps/sparc/shared/irq/genirq.c (modified) * bsps/sparc/shared/l2c/l2c.c (modified) * bsps/sparc/shared/mem/mctrl.c (modified) * bsps/sparc/shared/net/greth.c (modified) * bsps/sparc/shared/net/network_interface_add.c (modified) * bsps/sparc/shared/pci/gr_701.c (modified) * bsps/sparc/shared/pci/gr_cpci_gr740.c (modified) * bsps/sparc/shared/pci/gr_leon4_n2x.c (modified) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (modified) * bsps/sparc/shared/pci/gr_rasta_io.c (modified) * bsps/sparc/shared/pci/gr_rasta_spw_router.c (modified) * bsps/sparc/shared/pci/gr_rasta_tmtc.c (modified) * bsps/sparc/shared/pci/gr_tmtc_1553.c (modified) * bsps/sparc/shared/pci/grpci.c (modified) * bsps/sparc/shared/pci/grpci2.c (modified) * bsps/sparc/shared/pci/grpci2dma.c (modified) * bsps/sparc/shared/pci/pcif.c (modified) * bsps/sparc/shared/pwm/grpwm.c (modified) * bsps/sparc/shared/scrub/memscrub.c (modified) * bsps/sparc/shared/slink/grslink.c (modified) * bsps/sparc/shared/spi/spictrl.c (modified) * bsps/sparc/shared/spw/grspw.c (modified) * bsps/sparc/shared/spw/grspw_pkt.c (modified) * bsps/sparc/shared/spw/grspw_router.c (modified) * bsps/sparc/shared/spw/spwtdp.c (modified) * bsps/sparc/shared/stat/l4stat.c (modified) * bsps/sparc/shared/time/grctm.c (modified) * bsps/sparc/shared/time/spwcuc.c (modified) * bsps/sparc/shared/tmtc/grtc.c (modified) * bsps/sparc/shared/tmtc/grtm.c (modified) * bsps/sparc/shared/uart/apbuart_cons.c (modified) * bsps/sparc/shared/uart/apbuart_polled.c (modified) * bsps/sparc/shared/uart/apbuart_termios.c (modified) * bsps/sparc/shared/uart/cons.c (modified) grlib: Move header files Update #3678. Mon, 21 Jan 2019 08:17:05 GMT Sebastian Huber [95c1921] * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv (modified) * bsps/arm/beagle/start/linkcmds.beagle (modified) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx (modified) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_phycore (modified) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu (modified) * bsps/arm/shared/start/linkcmds.armv4 (modified) bsps/arm: Remove unused bsp_stack_irq_size Update #3459. Fri, 18 Jan 2019 12:32:51 GMT Sebastian Huber [926ed2b0] * cpukit/include/rtems/score/isrlock.h (modified) * testsuites/sptests/sp37/init.c (modified) score: Remove unused _ISR_lock_Flash() Fri, 18 Jan 2019 12:16:29 GMT Sebastian Huber [41310c02] * cpukit/include/rtems/rtems/intr.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * testsuites/sptests/sp37/init.c (modified) score: Improve debug support for ISR locks Ensure that interrupts ... Fri, 18 Jan 2019 11:54:05 GMT Sebastian Huber [b5bdecf] * cpukit/score/src/smpmulticastaction.c (modified) score: Avoid internal API and use ISR lock Mon, 14 Jan 2019 06:50:26 GMT Sebastian Huber [93e3b341] * cpukit/include/rtems/score/address.h (modified) score: Simplify _Addresses_Is_aligned() The CPU_ALIGNMENT must not ... Wed, 16 Jan 2019 21:42:18 GMT Joel Sherrill [12dfe5dc] * bsps/i386/shared/cache/cache.c (modified) bsps/i386/shared/cache/cache.c: Make compile Thu, 10 Jan 2019 19:14:03 GMT Joel Sherrill [4596127] * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) m68k/include/rtems/score/cpu.h: Add include of address.h Mon, 14 Jan 2019 08:38:02 GMT Sebastian Huber [47d5aee] * testsuites/benchmarks/Makefile.am (modified) build: Add missing $(LDADD) for dependencies Mon, 14 Jan 2019 08:07:16 GMT Sebastian Huber [d1fff86] * testsuites/sptests/Makefile.am (modified) build: Remove bogus spqreslib_LDADD Mon, 14 Jan 2019 08:06:30 GMT Sebastian Huber [dc0285f] * testsuites/libtests/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) build: Add missing $(LDADD) for dependencies Thu, 10 Jan 2019 10:35:12 GMT Sebastian Huber [8eaf136d] * cpukit/libcsupport/src/alignedalloc.c (modified) memalign: Add missing attributes to fix warning Update #3666. Thu, 10 Jan 2019 08:05:49 GMT Sebastian Huber [7bde91b] * cpukit/include/rtems/inttypes.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libmisc/shell/main_rm.c (modified) * cpukit/libmisc/shell/print-ls.c (modified) * testsuites/psxtests/psxreaddir/test.c (modified) Fix format warnings due to ino_t changes Thu, 10 Jan 2019 07:10:17 GMT Sebastian Huber [3a5c71de] * testsuites/psxtests/psxconfig01/init.c (modified) psxconfig01: Fix pre-processor conditions Do not rely on compiler ... Thu, 10 Jan 2019 06:57:36 GMT Sebastian Huber [e7d623e7] * bsps/arm/shared/cache/cache-v7ar-disable-data.S (modified) bsps/arm: Conditional ARMv7-AR data cache disable Update #3667. ... Thu, 10 Jan 2019 06:29:54 GMT Thomas Dörfler [0abe47f] * bsps/arm/shared/cache/cache-v7ar-disable-data.S (modified) bsps/arm: Fix typo in disable cache for ARMv7-AR Update #3667. Tue, 08 Jan 2019 08:50:50 GMT Sebastian Huber [b9ffc41c] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Enable robust thread dispatch It must be enabled, since the ... Tue, 08 Jan 2019 08:53:26 GMT Sebastian Huber [3bd39999] * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp37/init.c (modified) Adjust interrupt mode tests for some CPU ports In case the robust ... Tue, 08 Jan 2019 07:39:42 GMT Sebastian Huber [1f285186] * cpukit/rtems/src/taskmode.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) rtems: Allow to set ISR level 0 in SMP config Update #3000. Tue, 08 Jan 2019 07:36:31 GMT Sebastian Huber [38cb59e] * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threadinitialize.c (modified) Separate task mode checks Update #3000. Tue, 08 Jan 2019 08:08:27 GMT Sebastian Huber [feddcde0] * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/spcbssched01/init.c (modified) * testsuites/sptests/spedfsched01/init.c (modified) * testsuites/sptests/spfifo03/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) tests: Remove bogus RTEMS_INTERRUPT_LEVEL(31) It is unnecessary to ... Wed, 09 Jan 2019 09:04:01 GMT Sebastian Huber [fe48400d] * testsuites/libtests/stackchk/blow.c (modified) libtests/stackchk: Fix for 64-bit targets Tue, 08 Jan 2019 04:14:21 GMT Jacob Shin [e4a19f5] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/errno/errno.c (added) psxhdrs: Add POSIX API Signature Compliance Tests for errno.h Tue, 08 Jan 2019 13:43:02 GMT Sebastian Huber [9aee88a] * bsps/riscv/riscv/start/start.S (modified) bsp/riscv: Clear boot command line Mon, 07 Jan 2019 12:40:00 GMT Sebastian Huber [07fb7667] * testsuites/libtests/Makefile.am (modified) build: Call rtems-ld with the $(CC) of the build This enables ... Mon, 07 Jan 2019 12:35:48 GMT Sebastian Huber [7802bb9] * testsuites/libtests/Makefile.am (modified) build: Call rtems-syms with the $(CC) of the build This enables ... Mon, 07 Jan 2019 13:22:22 GMT Jiri Gaisler [5b951175] * testsuites/psxtests/psxfile01/test.c (modified) psxfile01: Fix one second sleep Checking of atime in psxfile01 ... Mon, 07 Jan 2019 08:32:16 GMT Sebastian Huber [9c12bcfd] * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c (modified) * cpukit/libmisc/shell/main_pci.c (modified) * cpukit/libpci/pci_bus.c (modified) * cpukit/libpci/pci_cfg_print_code.c (modified) * cpukit/libpci/pci_print.c (modified) * testsuites/fstests/fsrfsbitmap01/test.c (modified) Fix format warnings Mon, 07 Jan 2019 08:30:43 GMT Sebastian Huber [956d76cc] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/score/src/objectinitializeinformation.c (modified) score: Remove superfluous include from chainimpl.h Fri, 21 Dec 2018 20:09:53 GMT Sebastian Huber [a7e8996] * cpukit/include/drvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_dev_by_name.c (modified) * cpukit/libdrvmgr/drvmgr_for_each_dev.c (modified) * cpukit/libdrvmgr/drvmgr_print.c (modified) * cpukit/libmisc/shell/main_drvmgr.c (modified) drvmgr: Improve LP64 compatibility Fri, 21 Dec 2018 20:09:15 GMT Sebastian Huber [6073c71d] * cpukit/configure.ac (modified) drvmgr: Enable build for riscv Fri, 21 Dec 2018 19:47:06 GMT Himanshu40 [8f5abea] * testsuites/psxtmtests/psxtmbarrierattr01/init.c (modified) * testsuites/psxtmtests/psxtmbarrierattr01/psxtmbarrierattr01.doc (modified) * testsuites/psxtmtests/psxtmcleanup01/init.c (modified) * testsuites/psxtmtests/psxtmcleanup01/psxtmcleanup01.doc (modified) * testsuites/psxtmtests/psxtmmqrcvblock02/init.c (modified) * testsuites/psxtmtests/psxtmmqrcvblock02/psxtmmqrcvblock02.doc (modified) * testsuites/psxtmtests/psxtmmutexattr01/init.c (modified) * testsuites/psxtmtests/psxtmmutexattr01/psxtmmutexattr01.doc (modified) * testsuites/psxtmtests/psxtmonce01/init.c (modified) * testsuites/psxtmtests/psxtmonce01/psxtmonce01.doc (modified) psxtmtests: Changed the copyright license to BSD-2-Clause (GCI 2018) Fri, 21 Dec 2018 20:43:27 GMT Sebastian Huber [c05d7a9d] * bsps/sparc/shared/amba/ahbstat.c (modified) * bsps/sparc/shared/net/greth.c (modified) * bsps/sparc/shared/pci/gr_701.c (modified) * bsps/sparc/shared/pci/gr_cpci_gr740.c (modified) * bsps/sparc/shared/pci/gr_leon4_n2x.c (modified) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (modified) * bsps/sparc/shared/pci/gr_rasta_io.c (modified) * bsps/sparc/shared/pci/gr_rasta_spw_router.c (modified) * bsps/sparc/shared/pci/gr_rasta_tmtc.c (modified) * bsps/sparc/shared/pci/gr_tmtc_1553.c (modified) bsps/sparc: Fix warnings Fri, 21 Dec 2018 20:42:09 GMT Sebastian Huber [75e1009f] * bsps/sparc/shared/net/greth.c (modified) bsps/sparc: Fix typo Mon, 26 Nov 2018 14:55:38 GMT Sebastian Huber [11f3b9a] * bsps/sparc/include/bsp/gr1553rt.h (modified) * bsps/sparc/include/grlib_impl.h (modified) * bsps/sparc/shared/1553/b1553brm.c (modified) * bsps/sparc/shared/1553/b1553rt.c (modified) * bsps/sparc/shared/1553/gr1553b.c (modified) * bsps/sparc/shared/1553/gr1553bc.c (modified) * bsps/sparc/shared/1553/gr1553bm.c (modified) * bsps/sparc/shared/1553/gr1553rt.c (modified) * bsps/sparc/shared/amba/ambapp.c (modified) * bsps/sparc/shared/analog/gradcdac.c (modified) * bsps/sparc/shared/ascs/grascs.c (modified) * bsps/sparc/shared/btimer/gptimer.c (modified) * bsps/sparc/shared/can/canmux.c (modified) * bsps/sparc/shared/can/grcan.c (modified) * bsps/sparc/shared/can/occan.c (modified) * bsps/sparc/shared/can/satcan.c (modified) * bsps/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * bsps/sparc/shared/gpio/gpiolib.c (modified) * bsps/sparc/shared/gpio/grgpio.c (modified) * bsps/sparc/shared/i2c/i2cmst.c (modified) * bsps/sparc/shared/iommu/griommu.c (modified) * bsps/sparc/shared/irq/genirq.c (modified) * bsps/sparc/shared/mem/mctrl.c (modified) * bsps/sparc/shared/net/greth.c (modified) * bsps/sparc/shared/pci/gr_701.c (modified) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (modified) * bsps/sparc/shared/pci/gr_rasta_io.c (modified) * bsps/sparc/shared/pci/gr_tmtc_1553.c (modified) * bsps/sparc/shared/pci/grpci2dma.c (modified) * bsps/sparc/shared/pwm/grpwm.c (modified) * bsps/sparc/shared/slink/grslink.c (modified) * bsps/sparc/shared/spi/spictrl.c (modified) * bsps/sparc/shared/spw/grspw.c (modified) * bsps/sparc/shared/spw/grspw_pkt.c (modified) * bsps/sparc/shared/time/grctm.c (modified) * bsps/sparc/shared/time/spwcuc.c (modified) * bsps/sparc/shared/tmtc/grtc.c (modified) * bsps/sparc/shared/tmtc/grtm.c (modified) bsps/sparc: Add grlib_malloc(), grlib_calloc() This avoids a ... Fri, 21 Dec 2018 12:31:32 GMT Sebastian Huber [8b59916] * testsuites/sptests/spcxx01/init.cc (modified) spcxx01: Add test case Fri, 21 Dec 2018 10:57:26 GMT Sebastian Huber [c37807e9] * bsps/arm/shared/cache/cache-cp15.c (modified) bsps/arm: Add cache size support for CP15 Fri, 21 Dec 2018 07:39:33 GMT Sebastian Huber [41a557bc] * bsps/arm/shared/cache/cache-cp15.c (modified) * bsps/arm/shared/cache/cache-v7ar-disable-data.S (added) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) bsps/arm: Add ARMv7-AR disable data cache Close #3667. Fri, 21 Dec 2018 06:49:47 GMT Sebastian Huber [b0c2d48] * bsps/shared/cache/cacheimpl.h (modified) bsps: Add CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA Update #3667. Fri, 21 Dec 2018 06:46:58 GMT Sebastian Huber [5e0ab02] * bsps/shared/cache/cacheimpl.h (modified) bsps: Update cache manager documentation Update #3667. Fri, 21 Dec 2018 06:14:42 GMT Sebastian Huber [a6f70e1] * bsps/shared/cache/cacheimpl.h (modified) bsps: Remove superfluous comments in cacheimpl.h Remove superfluous ... Fri, 21 Dec 2018 09:16:02 GMT Sebastian Huber [ba85655] * bsps/arm/shared/cache/cache-cp15.c (modified) * bsps/arm/shared/cache/cache-cp15.h (modified) * bsps/arm/shared/cache/cache-l2c-310.c (modified) ARM_CACHE_L1_CPU_SUPPORT_PROVIDES_RANGE_FUNCTIONS Remove this ... Fri, 21 Dec 2018 06:27:16 GMT Sebastian Huber [750e795] * bsps/i386/shared/cache/cache.c (modified) bsps/i386: Enable instruction cache support Wed, 19 Dec 2018 08:25:29 GMT Sebastian Huber [2158621] * cpukit/Makefile.am (modified) * cpukit/libcsupport/src/alignedalloc.c (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spcxx01/init.cc (added) * testsuites/sptests/spcxx01/spcxx01.doc (added) * testsuites/sptests/spcxx01/spcxx01.scn (added) Add aligned_alloc() and memalign() Ensure that the C++17 aligned ... Thu, 20 Dec 2018 13:26:50 GMT Thomas Dörfler [10135fa] * cpukit/libnetworking/lib/tftpDriver.c (modified) tftpfs: Some bug fixes Fix for: - tftpfs did not mount, when ... Thu, 20 Dec 2018 20:37:47 GMT Jacob Shin [8af51b0] * testsuites/psxtests/psxhdrs/assert/assert.c (modified) * testsuites/psxtests/psxhdrs/fnmatch/fnmatch.c (modified) * testsuites/psxtests/psxhdrs/ftw/ftw.c (modified) * testsuites/psxtests/psxhdrs/ftw/nftw.c (modified) * testsuites/psxtests/psxhdrs/iconv/iconv.c (modified) * testsuites/psxtests/psxhdrs/iconv/iconv_close.c (modified) * testsuites/psxtests/psxhdrs/iconv/iconv_open.c (modified) * testsuites/psxtests/psxhdrs/langinfo/nl_langinfo.c (modified) * testsuites/psxtests/psxhdrs/langinfo/nl_langinfo_l.c (modified) * testsuites/psxtests/psxhdrs/monetary/strfmon.c (modified) * testsuites/psxtests/psxhdrs/monetary/strfmon_l.c (modified) * testsuites/psxtests/psxhdrs/stdlib/_Exit.c (modified) * testsuites/psxtests/psxhdrs/stdlib/a64l.c (modified) * testsuites/psxtests/psxhdrs/stdlib/abort.c (modified) * testsuites/psxtests/psxhdrs/stdlib/abs.c (modified) * testsuites/psxtests/psxhdrs/stdlib/atexit.c (modified) * testsuites/psxtests/psxhdrs/stdlib/atof.c (modified) * testsuites/psxtests/psxhdrs/stdlib/atoi.c (modified) * testsuites/psxtests/psxhdrs/stdlib/atol.c (modified) * testsuites/psxtests/psxhdrs/stdlib/atoll.c (modified) * testsuites/psxtests/psxhdrs/stdlib/bsearch.c (modified) * testsuites/psxtests/psxhdrs/stdlib/calloc.c (modified) * testsuites/psxtests/psxhdrs/stdlib/div.c (modified) * testsuites/psxtests/psxhdrs/stdlib/drand48.c (modified) * testsuites/psxtests/psxhdrs/stdlib/erand48.c (modified) * testsuites/psxtests/psxhdrs/stdlib/exit.c (modified) * testsuites/psxtests/psxhdrs/stdlib/free.c (modified) * testsuites/psxtests/psxhdrs/stdlib/getenv.c (modified) * testsuites/psxtests/psxhdrs/stdlib/getsubopt.c (modified) * testsuites/psxtests/psxhdrs/stdlib/grantpt.c (modified) * testsuites/psxtests/psxhdrs/stdlib/initstate.c (modified) * testsuites/psxtests/psxhdrs/stdlib/jrand48.c (modified) * testsuites/psxtests/psxhdrs/stdlib/l64a.c (modified) * testsuites/psxtests/psxhdrs/stdlib/labs.c (modified) * testsuites/psxtests/psxhdrs/stdlib/lcong48.c (modified) * testsuites/psxtests/psxhdrs/stdlib/ldiv.c (modified) * testsuites/psxtests/psxhdrs/stdlib/llabs.c (modified) * testsuites/psxtests/psxhdrs/stdlib/lldiv.c (modified) * testsuites/psxtests/psxhdrs/stdlib/lrand48.c (modified) * testsuites/psxtests/psxhdrs/stdlib/malloc.c (modified) * testsuites/psxtests/psxhdrs/stdlib/mblen.c (modified) * testsuites/psxtests/psxhdrs/stdlib/mbstowcs.c (modified) * testsuites/psxtests/psxhdrs/stdlib/mbtowc.c (modified) * testsuites/psxtests/psxhdrs/stdlib/mkdtemp.c (modified) * testsuites/psxtests/psxhdrs/stdlib/mkstemp.c (modified) * testsuites/psxtests/psxhdrs/stdlib/mrand48.c (modified) * testsuites/psxtests/psxhdrs/stdlib/nrand48.c (modified) * testsuites/psxtests/psxhdrs/stdlib/posix_memalign.c (modified) * testsuites/psxtests/psxhdrs/stdlib/posix_openpt.c (modified) * testsuites/psxtests/psxhdrs/stdlib/ptsname.c (modified) * testsuites/psxtests/psxhdrs/stdlib/putenv.c (modified) * testsuites/psxtests/psxhdrs/stdlib/qsort.c (modified) * testsuites/psxtests/psxhdrs/stdlib/rand.c (modified) * testsuites/psxtests/psxhdrs/stdlib/rand_r.c (modified) * testsuites/psxtests/psxhdrs/stdlib/random.c (modified) * testsuites/psxtests/psxhdrs/stdlib/realloc.c (modified) * testsuites/psxtests/psxhdrs/stdlib/realpath.c (modified) * testsuites/psxtests/psxhdrs/stdlib/seed48.c (modified) * testsuites/psxtests/psxhdrs/stdlib/setenv.c (modified) * testsuites/psxtests/psxhdrs/stdlib/setkey.c (modified) * testsuites/psxtests/psxhdrs/stdlib/setstate.c (modified) * testsuites/psxtests/psxhdrs/stdlib/srand.c (modified) * testsuites/psxtests/psxhdrs/stdlib/srand48.c (modified) * testsuites/psxtests/psxhdrs/stdlib/srandom.c (modified) * testsuites/psxtests/psxhdrs/stdlib/strtod.c (modified) * testsuites/psxtests/psxhdrs/stdlib/strtof.c (modified) * testsuites/psxtests/psxhdrs/stdlib/strtol.c (modified) * testsuites/psxtests/psxhdrs/stdlib/strtold.c (modified) * testsuites/psxtests/psxhdrs/stdlib/strtoll.c (modified) * testsuites/psxtests/psxhdrs/stdlib/strtoul.c (modified) * testsuites/psxtests/psxhdrs/stdlib/strtoull.c (modified) * testsuites/psxtests/psxhdrs/stdlib/system.c (modified) * testsuites/psxtests/psxhdrs/stdlib/unlockpt.c (modified) * testsuites/psxtests/psxhdrs/stdlib/unsetenv.c (modified) * testsuites/psxtests/psxhdrs/stdlib/wcstombs.c (modified) * testsuites/psxtests/psxhdrs/stdlib/wctomb.c (modified) * testsuites/psxtests/psxhdrs/sys/resource/getpriority.c (modified) * testsuites/psxtests/psxhdrs/sys/resource/getrlimit.c (modified) * testsuites/psxtests/psxhdrs/sys/resource/getrusage.c (modified) * testsuites/psxtests/psxhdrs/sys/resource/setpriority.c (modified) * testsuites/psxtests/psxhdrs/sys/resource/setrlimit.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/chmod.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/fchmod.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/fchmodat.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/fstat.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/fstatat.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/futimens.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/lstat.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/mkdir.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/mkdirat.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/mkfifo.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/mkfifoat.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/mknod.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/mknodat.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/stat.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/umask.c (modified) * testsuites/psxtests/psxhdrs/sys/stat/utimensat.c (modified) * testsuites/psxtests/psxhdrs/sys/utsname/uname.c (modified) * testsuites/psxtests/psxhdrs/ucontext/getcontext.c (modified) * testsuites/psxtests/psxhdrs/ucontext/makecontext.c (modified) * testsuites/psxtests/psxhdrs/ucontext/setcontext.c (modified) * testsuites/psxtests/psxhdrs/ucontext/swapcontext.c (modified) * testsuites/psxtests/psxhdrs/ulimit/ulimit.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswalnum.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswalnum_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswalpha.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswalpha_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswblank.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswblank_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswcntrl.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswcntrl_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswctype.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswctype_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswdigit.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswdigit_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswgraph.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswgraph_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswlower.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswlower_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswprint.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswprint_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswpunct.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswpunct_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswspace.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswspace_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswupper.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswupper_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswxdigit.c (modified) * testsuites/psxtests/psxhdrs/wctype/iswxdigit_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/towctrans.c (modified) * testsuites/psxtests/psxhdrs/wctype/towctrans_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/towlower.c (modified) * testsuites/psxtests/psxhdrs/wctype/towlower_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/towupper.c (modified) * testsuites/psxtests/psxhdrs/wctype/towupper_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/wctrans.c (modified) * testsuites/psxtests/psxhdrs/wctype/wctrans_l.c (modified) * testsuites/psxtests/psxhdrs/wctype/wctype.c (modified) * testsuites/psxtests/psxhdrs/wctype/wctype_l.c (modified) psxhdrs: Changing copyright license to BSD-2-Clause Thu, 20 Dec 2018 13:21:40 GMT Sebastian Huber [9edc558d] * bsps/arm/imx/start/bspstarthooks.c (modified) bsp/imx: Fix for RAM end at 4GiB Fri, 23 Nov 2018 11:00:35 GMT Sebastian Huber [6164fd8] * LICENSE.GPL-2.0 (moved) Move COPYING file to LICENSE.GPL-2.0 Use the latest plain text ... Tue, 11 Dec 2018 09:15:11 GMT Sebastian Huber [cde5e8d] * LICENSE.BSD-2-Clause (modified) LICENSE.BSD-2-Clause: Clarify copyright format Update #3053. Tue, 18 Dec 2018 07:45:06 GMT Sebastian Huber [7c19e50] * cpukit/include/rtems/score/interr.h (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpfatal09/init.c (added) * testsuites/smptests/smpfatal09/smpfatal09.doc (added) * testsuites/smptests/smpfatal09/smpfatal09.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) score: Fix per-CPU data allocation Allocate the per-CPU data for ... Fri, 14 Dec 2018 07:07:08 GMT Sebastian Huber [e7b0a72] * cpukit/include/rtems/confdefs.h (modified) config: Remove CONFIGURE_CONFDEFS_DEBUG This configuration option ... Mon, 10 Dec 2018 18:44:45 GMT Marçal Comajoan Cara [cfa82b3] * testsuites/psxtests/psxhdrs/c11/uchar/c16rtomb.c (modified) * testsuites/psxtests/psxhdrs/c11/uchar/c32rtomb.c (modified) * testsuites/psxtests/psxhdrs/c11/uchar/mbrtoc16.c (modified) * testsuites/psxtests/psxhdrs/c11/uchar/mbrtoc32.c (modified) * testsuites/psxtests/psxhdrs/inttypes/imaxabs.c (modified) * testsuites/psxtests/psxhdrs/inttypes/imaxdiv.c (modified) * testsuites/psxtests/psxhdrs/inttypes/strtoimax.c (modified) * testsuites/psxtests/psxhdrs/inttypes/strtoumax.c (modified) * testsuites/psxtests/psxhdrs/inttypes/wcstoimax.c (modified) * testsuites/psxtests/psxhdrs/inttypes/wcstoumax.c (modified) * testsuites/psxtests/psxhdrs/stddef/offsetof.c (modified) * testsuites/psxtests/psxhdrs/sys/times/times.c (modified) psxhdrs: Update licenses to 2-Clause BSD (GCI 2018) Updated ... Thu, 13 Dec 2018 19:23:11 GMT Himanshu40 [4bd2f802] * testsuites/psxtests/psxhdrs/semaphore/sem_open.c (modified) * testsuites/psxtests/psxhdrs/strings/bcopy.c (modified) * testsuites/psxtests/psxhdrs/strings/index.c (modified) * testsuites/psxtests/psxhdrs/strings/rindex.c (modified) Some minor fix on psxhdrs Thu, 13 Dec 2018 18:13:31 GMT Himanshu40 [c1912df] * testsuites/psxtests/psxhdrs/c11/threads/call_once.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/cnd_broadcast.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/cnd_destroy.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/cnd_init.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/cnd_signal.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/cnd_timedwait.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/cnd_wait.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/mtx_destroy.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/mtx_init.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/mtx_lock.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/mtx_timedlock.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/mtx_trylock.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/mtx_unlock.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/thrd_create.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/thrd_current.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/thrd_detach.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/thrd_equal.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/thrd_exit.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/thrd_join.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/thrd_sleep.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/thrd_yield.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/tss_create.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/tss_delete.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/tss_get.c (modified) * testsuites/psxtests/psxhdrs/c11/threads/tss_set.c (modified) * testsuites/psxtests/psxhdrs/dirent/alphasort.c (modified) * testsuites/psxtests/psxhdrs/dirent/closedir.c (modified) * testsuites/psxtests/psxhdrs/dirent/dirfd.c (modified) * testsuites/psxtests/psxhdrs/dirent/fdopendir.c (modified) * testsuites/psxtests/psxhdrs/dirent/opendir.c (modified) * testsuites/psxtests/psxhdrs/dirent/readdir.c (modified) * testsuites/psxtests/psxhdrs/dirent/readdir_r.c (modified) * testsuites/psxtests/psxhdrs/dirent/rewinddir.c (modified) * testsuites/psxtests/psxhdrs/dirent/scandir.c (modified) * testsuites/psxtests/psxhdrs/dirent/seekdir.c (modified) * testsuites/psxtests/psxhdrs/dirent/telldir.c (modified) * testsuites/psxtests/psxhdrs/dlfcn/dlclose.c (modified) * testsuites/psxtests/psxhdrs/dlfcn/dlerror.c (modified) * testsuites/psxtests/psxhdrs/dlfcn/dlopen.c (modified) * testsuites/psxtests/psxhdrs/dlfcn/dlsym.c (modified) * testsuites/psxtests/psxhdrs/libgen/basename.c (modified) * testsuites/psxtests/psxhdrs/libgen/dirname.c (modified) * testsuites/psxtests/psxhdrs/locale/duplocale.c (modified) * testsuites/psxtests/psxhdrs/locale/freelocale.c (modified) * testsuites/psxtests/psxhdrs/locale/localeconv.c (modified) * testsuites/psxtests/psxhdrs/locale/newlocale.c (modified) * testsuites/psxtests/psxhdrs/locale/setlocale.c (modified) * testsuites/psxtests/psxhdrs/locale/uselocale.c (modified) * testsuites/psxtests/psxhdrs/mqueue/mq_close.c (modified) * testsuites/psxtests/psxhdrs/mqueue/mq_getattr.c (modified) * testsuites/psxtests/psxhdrs/mqueue/mq_notify.c (modified) * testsuites/psxtests/psxhdrs/mqueue/mq_open.c (modified) * testsuites/psxtests/psxhdrs/mqueue/mq_receive.c (modified) * testsuites/psxtests/psxhdrs/mqueue/mq_send.c (modified) * testsuites/psxtests/psxhdrs/mqueue/mq_setattr.c (modified) * testsuites/psxtests/psxhdrs/mqueue/mq_timedreceive.c (modified) * testsuites/psxtests/psxhdrs/mqueue/mq_timedsend.c (modified) * testsuites/psxtests/psxhdrs/mqueue/mq_unlink.c (modified) * testsuites/psxtests/psxhdrs/netdb/endhostent.c (modified) * testsuites/psxtests/psxhdrs/netdb/endnetent.c (modified) * testsuites/psxtests/psxhdrs/netdb/endprotoent.c (modified) * testsuites/psxtests/psxhdrs/netdb/endservent.c (modified) * testsuites/psxtests/psxhdrs/netdb/freeaddrinfo.c (modified) * testsuites/psxtests/psxhdrs/netdb/gai_strerror.c (modified) * testsuites/psxtests/psxhdrs/netdb/getaddrinfo.c (modified) * testsuites/psxtests/psxhdrs/netdb/gethostbyaddr.c (modified) * testsuites/psxtests/psxhdrs/netdb/gethostbyname.c (modified) * testsuites/psxtests/psxhdrs/netdb/gethostent.c (modified) * testsuites/psxtests/psxhdrs/netdb/getnameinfo.c (modified) * testsuites/psxtests/psxhdrs/netdb/getnetbyaddr.c (modified) * testsuites/psxtests/psxhdrs/netdb/getnetbyname.c (modified) * testsuites/psxtests/psxhdrs/netdb/getnetent.c (modified) * testsuites/psxtests/psxhdrs/netdb/getprotobyname.c (modified) * testsuites/psxtests/psxhdrs/netdb/getprotobynumber.c (modified) * testsuites/psxtests/psxhdrs/netdb/getprotoent.c (modified) * testsuites/psxtests/psxhdrs/netdb/getservbyname.c (modified) * testsuites/psxtests/psxhdrs/netdb/getservbyport.c (modified) * testsuites/psxtests/psxhdrs/netdb/getservent.c (modified) * testsuites/psxtests/psxhdrs/netdb/h_errno.c (modified) * testsuites/psxtests/psxhdrs/netdb/sethostent.c (modified) * testsuites/psxtests/psxhdrs/netdb/setnetent.c (modified) * testsuites/psxtests/psxhdrs/netdb/setprotoent.c (modified) * testsuites/psxtests/psxhdrs/netdb/setservent.c (modified) * testsuites/psxtests/psxhdrs/pwd/endpwent.c (modified) * testsuites/psxtests/psxhdrs/pwd/getpwent.c (modified) * testsuites/psxtests/psxhdrs/pwd/getpwnam.c (modified) * testsuites/psxtests/psxhdrs/pwd/getpwnam_r.c (modified) * testsuites/psxtests/psxhdrs/pwd/getpwuid.c (modified) * testsuites/psxtests/psxhdrs/pwd/getpwuid_r.c (modified) * testsuites/psxtests/psxhdrs/pwd/setpwent.c (modified) * testsuites/psxtests/psxhdrs/regex/regcomp.c (modified) * testsuites/psxtests/psxhdrs/regex/regerror.c (modified) * testsuites/psxtests/psxhdrs/regex/regexec.c (modified) * testsuites/psxtests/psxhdrs/regex/regfree.c (modified) * testsuites/psxtests/psxhdrs/semaphore/sem_close.c (modified) * testsuites/psxtests/psxhdrs/semaphore/sem_destroy.c (modified) * testsuites/psxtests/psxhdrs/semaphore/sem_getvalue.c (modified) * testsuites/psxtests/psxhdrs/semaphore/sem_init.c (modified) * testsuites/psxtests/psxhdrs/semaphore/sem_open.c (modified) * testsuites/psxtests/psxhdrs/semaphore/sem_post.c (modified) * testsuites/psxtests/psxhdrs/semaphore/sem_timedwait.c (modified) * testsuites/psxtests/psxhdrs/semaphore/sem_trywait.c (modified) * testsuites/psxtests/psxhdrs/semaphore/sem_unlink.c (modified) * testsuites/psxtests/psxhdrs/semaphore/sem_wait.c (modified) * testsuites/psxtests/psxhdrs/stdio/clearerr.c (modified) * testsuites/psxtests/psxhdrs/stdio/ctermid.c (modified) * testsuites/psxtests/psxhdrs/stdio/dprintf.c (modified) * testsuites/psxtests/psxhdrs/stdio/fclose.c (modified) * testsuites/psxtests/psxhdrs/stdio/fdopen.c (modified) * testsuites/psxtests/psxhdrs/stdio/feof.c (modified) * testsuites/psxtests/psxhdrs/stdio/ferror.c (modified) * testsuites/psxtests/psxhdrs/stdio/fflush.c (modified) * testsuites/psxtests/psxhdrs/stdio/fgetc.c (modified) * testsuites/psxtests/psxhdrs/stdio/fgetpos.c (modified) * testsuites/psxtests/psxhdrs/stdio/fgets.c (modified) * testsuites/psxtests/psxhdrs/stdio/fileno.c (modified) * testsuites/psxtests/psxhdrs/stdio/flockfile.c (modified) * testsuites/psxtests/psxhdrs/stdio/fmemopen.c (modified) * testsuites/psxtests/psxhdrs/stdio/fopen.c (modified) * testsuites/psxtests/psxhdrs/stdio/fprintf.c (modified) * testsuites/psxtests/psxhdrs/stdio/fputc.c (modified) * testsuites/psxtests/psxhdrs/stdio/fputs.c (modified) * testsuites/psxtests/psxhdrs/stdio/fread.c (modified) * testsuites/psxtests/psxhdrs/stdio/freopen.c (modified) * testsuites/psxtests/psxhdrs/stdio/fscanf.c (modified) * testsuites/psxtests/psxhdrs/stdio/fseek.c (modified) * testsuites/psxtests/psxhdrs/stdio/fseeko.c (modified) * testsuites/psxtests/psxhdrs/stdio/fsetpos.c (modified) * testsuites/psxtests/psxhdrs/stdio/ftell.c (modified) * testsuites/psxtests/psxhdrs/stdio/ftello.c (modified) * testsuites/psxtests/psxhdrs/stdio/ftrylockfile.c (modified) * testsuites/psxtests/psxhdrs/stdio/funlockfile.c (modified) * testsuites/psxtests/psxhdrs/stdio/fwrite.c (modified) * testsuites/psxtests/psxhdrs/stdio/getc.c (modified) * testsuites/psxtests/psxhdrs/stdio/getc_unlocked.c (modified) * testsuites/psxtests/psxhdrs/stdio/getchar.c (modified) * testsuites/psxtests/psxhdrs/stdio/getchar_unlocked.c (modified) * testsuites/psxtests/psxhdrs/stdio/getdelim.c (modified) * testsuites/psxtests/psxhdrs/stdio/getline.c (modified) * testsuites/psxtests/psxhdrs/stdio/gets.c (modified) * testsuites/psxtests/psxhdrs/stdio/open_memstream.c (modified) * testsuites/psxtests/psxhdrs/stdio/pclose.c (modified) * testsuites/psxtests/psxhdrs/stdio/perror.c (modified) * testsuites/psxtests/psxhdrs/stdio/popen.c (modified) * testsuites/psxtests/psxhdrs/stdio/printf.c (modified) * testsuites/psxtests/psxhdrs/stdio/putc.c (modified) * testsuites/psxtests/psxhdrs/stdio/putc_unlocked.c (modified) * testsuites/psxtests/psxhdrs/stdio/putchar.c (modified) * testsuites/psxtests/psxhdrs/stdio/putchar_unlocked.c (modified) * testsuites/psxtests/psxhdrs/stdio/puts.c (modified) * testsuites/psxtests/psxhdrs/stdio/remove.c (modified) * testsuites/psxtests/psxhdrs/stdio/rename.c (modified) * testsuites/psxtests/psxhdrs/stdio/renameat.c (modified) * testsuites/psxtests/psxhdrs/stdio/rewind.c (modified) * testsuites/psxtests/psxhdrs/stdio/scanf.c (modified) * testsuites/psxtests/psxhdrs/stdio/setbuf.c (modified) * testsuites/psxtests/psxhdrs/stdio/setvbuf.c (modified) * testsuites/psxtests/psxhdrs/stdio/snprintf.c (modified) * testsuites/psxtests/psxhdrs/stdio/sprintf.c (modified) * testsuites/psxtests/psxhdrs/stdio/sscanf.c (modified) * testsuites/psxtests/psxhdrs/stdio/stderr.c (modified) * testsuites/psxtests/psxhdrs/stdio/stdin.c (modified) * testsuites/psxtests/psxhdrs/stdio/stdout.c (modified) * testsuites/psxtests/psxhdrs/stdio/tempnam.c (modified) * testsuites/psxtests/psxhdrs/stdio/tmpfile.c (modified) * testsuites/psxtests/psxhdrs/stdio/tmpnam.c (modified) * testsuites/psxtests/psxhdrs/stdio/ungetc.c (modified) * testsuites/psxtests/psxhdrs/stdio/vdprintf.c (modified) * testsuites/psxtests/psxhdrs/stdio/vfprintf.c (modified) * testsuites/psxtests/psxhdrs/stdio/vfscanf.c (modified) * testsuites/psxtests/psxhdrs/stdio/vprintf.c (modified) * testsuites/psxtests/psxhdrs/stdio/vscanf.c (modified) * testsuites/psxtests/psxhdrs/stdio/vsnprintf.c (modified) * testsuites/psxtests/psxhdrs/stdio/vsprintf.c (modified) * testsuites/psxtests/psxhdrs/stdio/vsscanf.c (modified) * testsuites/psxtests/psxhdrs/string/memccpy.c (modified) * testsuites/psxtests/psxhdrs/string/memchr.c (modified) * testsuites/psxtests/psxhdrs/string/memcmp.c (modified) * testsuites/psxtests/psxhdrs/string/memcpy.c (modified) * testsuites/psxtests/psxhdrs/string/memmove.c (modified) * testsuites/psxtests/psxhdrs/string/memset.c (modified) * testsuites/psxtests/psxhdrs/string/stpcpy.c (modified) * testsuites/psxtests/psxhdrs/string/stpncpy.c (modified) * testsuites/psxtests/psxhdrs/string/strcat.c (modified) * testsuites/psxtests/psxhdrs/string/strchr.c (modified) * testsuites/psxtests/psxhdrs/string/strcmp.c (modified) * testsuites/psxtests/psxhdrs/string/strcoll.c (modified) * testsuites/psxtests/psxhdrs/string/strcoll_l.c (modified) * testsuites/psxtests/psxhdrs/string/strcpy.c (modified) * testsuites/psxtests/psxhdrs/string/strcspn.c (modified) * testsuites/psxtests/psxhdrs/string/strdup.c (modified) * testsuites/psxtests/psxhdrs/string/strerror.c (modified) * testsuites/psxtests/psxhdrs/string/strerror_l.c (modified) * testsuites/psxtests/psxhdrs/string/strerror_r.c (modified) * testsuites/psxtests/psxhdrs/string/strlen.c (modified) * testsuites/psxtests/psxhdrs/string/strncat.c (modified) * testsuites/psxtests/psxhdrs/string/strncmp.c (modified) * testsuites/psxtests/psxhdrs/string/strncpy.c (modified) * testsuites/psxtests/psxhdrs/string/strndup.c (modified) * testsuites/psxtests/psxhdrs/string/strnlen.c (modified) * testsuites/psxtests/psxhdrs/string/strpbrk.c (modified) * testsuites/psxtests/psxhdrs/string/strrchr.c (modified) * testsuites/psxtests/psxhdrs/string/strsignal.c (modified) * testsuites/psxtests/psxhdrs/string/strspn.c (modified) * testsuites/psxtests/psxhdrs/string/strstr.c (modified) * testsuites/psxtests/psxhdrs/string/strtok.c (modified) * testsuites/psxtests/psxhdrs/string/strtok_r.c (modified) * testsuites/psxtests/psxhdrs/string/strxfrm.c (modified) * testsuites/psxtests/psxhdrs/string/strxfrm_l.c (modified) * testsuites/psxtests/psxhdrs/strings/bcmp.c (modified) * testsuites/psxtests/psxhdrs/strings/bcopy.c (modified) * testsuites/psxtests/psxhdrs/strings/ffs.c (modified) * testsuites/psxtests/psxhdrs/strings/index.c (modified) * testsuites/psxtests/psxhdrs/strings/rindex.c (modified) * testsuites/psxtests/psxhdrs/strings/strcasecmp.c (modified) * testsuites/psxtests/psxhdrs/strings/strcasecmp_l.c (modified) * testsuites/psxtests/psxhdrs/strings/strncasecmp.c (modified) * testsuites/psxtests/psxhdrs/strings/strncasecmp_l.c (modified) psxhdrs: Changed the copyright license to BSD-2-Clause (GCI 2018) Thu, 13 Dec 2018 08:39:20 GMT Sebastian Huber [6b0a729b] * ampolish3 (deleted) * c/src/aclocal/project-root.m4 (modified) * c/src/aclocal/rtems-ampolish.m4 (deleted) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * cpukit/aclocal/rtems-ampolish.m4 (deleted) * cpukit/configure.ac (modified) build: Remove ampolish3 Update #3254. Thu, 22 Nov 2018 18:14:51 GMT Sebastian Huber [21275b58] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/extensiondata.h (modified) * cpukit/include/rtems/extensionimpl.h (modified) * cpukit/include/rtems/posix/key.h (modified) * cpukit/include/rtems/posix/keyimpl.h (modified) * cpukit/include/rtems/posix/mqueue.h (modified) * cpukit/include/rtems/posix/mqueueimpl.h (modified) * cpukit/include/rtems/posix/pthread.h (modified) * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/include/rtems/posix/semaphore.h (modified) * cpukit/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/include/rtems/posix/shm.h (modified) * cpukit/include/rtems/posix/shmimpl.h (modified) * cpukit/include/rtems/posix/sigset.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/include/rtems/posix/timerimpl.h (modified) * cpukit/include/rtems/rtems/barrierdata.h (modified) * cpukit/include/rtems/rtems/barrierimpl.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/dpmemdata.h (modified) * cpukit/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/include/rtems/rtems/messagedata.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/rtems/msgmp.h (modified) * cpukit/include/rtems/rtems/partdata.h (modified) * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/rtems/partmp.h (modified) * cpukit/include/rtems/rtems/ratemondata.h (modified) * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/rtems/regiondata.h (modified) * cpukit/include/rtems/rtems/regionimpl.h (modified) * cpukit/include/rtems/rtems/semdata.h (modified) * cpukit/include/rtems/rtems/semimpl.h (modified) * cpukit/include/rtems/rtems/semmp.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/include/rtems/rtems/timerdata.h (modified) * cpukit/include/rtems/rtems/timerimpl.h (modified) * cpukit/include/rtems/score/freechain.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadq.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keycreate.c (modified) * cpukit/posix/src/keyzerokvp.c (added) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/psxsemaphore.c (modified) * cpukit/posix/src/psxtimercreate.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/shm.c (modified) * cpukit/posix/src/shmopen.c (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/score/src/freechain.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/psxtests/psxobj01/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal13/spfatal13.doc (deleted) * testsuites/sptests/spfatal13/spfatal13.scn (deleted) * testsuites/sptests/spfatal13/testcase.h (deleted) * testsuites/sptests/spfreechain01/init.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) score: Static Objects_Information initialization Statically ... Mon, 10 Dec 2018 11:51:33 GMT Sebastian Huber [0f5b2c09] * cpukit/Makefile.am (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/getconfigmax.c (added) rtems: Use object information to get config max Use functions ... Mon, 10 Dec 2018 12:44:53 GMT Sebastian Huber [8b0e752f] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * testsuites/samples/unlimited/test1.c (modified) score: Remove Objects_Information::auto_extend Use ... Thu, 13 Dec 2018 15:17:25 GMT Pritish Jain [877048c] * testsuites/psxtests/psxhdrs/fmtmsg/fmtmsg.c (modified) * testsuites/psxtests/psxhdrs/math/acos.c (modified) * testsuites/psxtests/psxhdrs/math/acosf.c (modified) * testsuites/psxtests/psxhdrs/math/acosh.c (modified) * testsuites/psxtests/psxhdrs/math/acoshf.c (modified) * testsuites/psxtests/psxhdrs/math/acoshl.c (modified) * testsuites/psxtests/psxhdrs/math/acosl.c (modified) * testsuites/psxtests/psxhdrs/math/asin.c (modified) * testsuites/psxtests/psxhdrs/math/asinf.c (modified) * testsuites/psxtests/psxhdrs/math/asinh.c (modified) * testsuites/psxtests/psxhdrs/math/asinhf.c (modified) * testsuites/psxtests/psxhdrs/math/asinhl.c (modified) * testsuites/psxtests/psxhdrs/math/asinl.c (modified) * testsuites/psxtests/psxhdrs/math/atan.c (modified) * testsuites/psxtests/psxhdrs/math/atan2.c (modified) * testsuites/psxtests/psxhdrs/math/atan2f.c (modified) * testsuites/psxtests/psxhdrs/math/atan2l.c (modified) * testsuites/psxtests/psxhdrs/math/atanf.c (modified) * testsuites/psxtests/psxhdrs/math/atanh.c (modified) * testsuites/psxtests/psxhdrs/math/atanhf.c (modified) * testsuites/psxtests/psxhdrs/math/atanhl.c (modified) * testsuites/psxtests/psxhdrs/math/atanl.c (modified) * testsuites/psxtests/psxhdrs/math/cbrt.c (modified) * testsuites/psxtests/psxhdrs/math/cbrtf.c (modified) * testsuites/psxtests/psxhdrs/math/cbrtl.c (modified) * testsuites/psxtests/psxhdrs/math/ceil.c (modified) * testsuites/psxtests/psxhdrs/math/ceilf.c (modified) * testsuites/psxtests/psxhdrs/math/ceill.c (modified) * testsuites/psxtests/psxhdrs/math/copysign.c (modified) * testsuites/psxtests/psxhdrs/math/copysignf.c (modified) * testsuites/psxtests/psxhdrs/math/copysignl.c (modified) * testsuites/psxtests/psxhdrs/math/cos.c (modified) * testsuites/psxtests/psxhdrs/math/cosf.c (modified) * testsuites/psxtests/psxhdrs/math/cosh.c (modified) * testsuites/psxtests/psxhdrs/math/coshf.c (modified) * testsuites/psxtests/psxhdrs/math/coshl.c (modified) * testsuites/psxtests/psxhdrs/math/cosl.c (modified) * testsuites/psxtests/psxhdrs/math/erf.c (modified) * testsuites/psxtests/psxhdrs/math/erfc.c (modified) * testsuites/psxtests/psxhdrs/math/erfcf.c (modified) * testsuites/psxtests/psxhdrs/math/erfcl.c (modified) * testsuites/psxtests/psxhdrs/math/erff.c (modified) * testsuites/psxtests/psxhdrs/math/erfl.c (modified) * testsuites/psxtests/psxhdrs/math/exp.c (modified) * testsuites/psxtests/psxhdrs/math/exp2.c (modified) * testsuites/psxtests/psxhdrs/math/exp2f.c (modified) * testsuites/psxtests/psxhdrs/math/exp2l.c (modified) * testsuites/psxtests/psxhdrs/math/expf.c (modified) * testsuites/psxtests/psxhdrs/math/expl.c (modified) * testsuites/psxtests/psxhdrs/math/expm1.c (modified) * testsuites/psxtests/psxhdrs/math/expm1f.c (modified) * testsuites/psxtests/psxhdrs/math/expm1l.c (modified) * testsuites/psxtests/psxhdrs/math/fabs.c (modified) * testsuites/psxtests/psxhdrs/math/fabsf.c (modified) * testsuites/psxtests/psxhdrs/math/fabsl.c (modified) * testsuites/psxtests/psxhdrs/math/fdim.c (modified) * testsuites/psxtests/psxhdrs/math/fdimf.c (modified) * testsuites/psxtests/psxhdrs/math/fdiml.c (modified) * testsuites/psxtests/psxhdrs/math/floor.c (modified) * testsuites/psxtests/psxhdrs/math/floorf.c (modified) * testsuites/psxtests/psxhdrs/math/floorl.c (modified) * testsuites/psxtests/psxhdrs/math/fma.c (modified) * testsuites/psxtests/psxhdrs/math/fmaf.c (modified) * testsuites/psxtests/psxhdrs/math/fmal.c (modified) * testsuites/psxtests/psxhdrs/math/fmax.c (modified) * testsuites/psxtests/psxhdrs/math/fmaxf.c (modified) * testsuites/psxtests/psxhdrs/math/fmaxl.c (modified) * testsuites/psxtests/psxhdrs/math/fmin.c (modified) * testsuites/psxtests/psxhdrs/math/fminf.c (modified) * testsuites/psxtests/psxhdrs/math/fminl.c (modified) * testsuites/psxtests/psxhdrs/math/fmod.c (modified) * testsuites/psxtests/psxhdrs/math/fmodf.c (modified) * testsuites/psxtests/psxhdrs/math/fmodl.c (modified) * testsuites/psxtests/psxhdrs/math/fpclassify.c (modified) * testsuites/psxtests/psxhdrs/math/frexp.c (modified) * testsuites/psxtests/psxhdrs/math/frexpf.c (modified) * testsuites/psxtests/psxhdrs/math/frexpl.c (modified) * testsuites/psxtests/psxhdrs/math/hypot.c (modified) * testsuites/psxtests/psxhdrs/math/hypotf.c (modified) * testsuites/psxtests/psxhdrs/math/hypotl.c (modified) * testsuites/psxtests/psxhdrs/math/ilogb.c (modified) * testsuites/psxtests/psxhdrs/math/ilogbf.c (modified) * testsuites/psxtests/psxhdrs/math/ilogbl.c (modified) * testsuites/psxtests/psxhdrs/math/isfinite.c (modified) * testsuites/psxtests/psxhdrs/math/isgreater.c (modified) * testsuites/psxtests/psxhdrs/math/isgreaterequal.c (modified) * testsuites/psxtests/psxhdrs/math/isinf.c (modified) * testsuites/psxtests/psxhdrs/math/isless.c (modified) * testsuites/psxtests/psxhdrs/math/islessequal.c (modified) * testsuites/psxtests/psxhdrs/math/islessgreater.c (modified) * testsuites/psxtests/psxhdrs/math/isnan.c (modified) * testsuites/psxtests/psxhdrs/math/isnormal.c (modified) * testsuites/psxtests/psxhdrs/math/isunordered.c (modified) * testsuites/psxtests/psxhdrs/math/ldexp.c (modified) * testsuites/psxtests/psxhdrs/math/ldexpf.c (modified) * testsuites/psxtests/psxhdrs/math/ldexpl.c (modified) * testsuites/psxtests/psxhdrs/math/lgamma.c (modified) * testsuites/psxtests/psxhdrs/math/lgammaf.c (modified) * testsuites/psxtests/psxhdrs/math/lgammal.c (modified) * testsuites/psxtests/psxhdrs/math/llrint.c (modified) * testsuites/psxtests/psxhdrs/math/llrintf.c (modified) * testsuites/psxtests/psxhdrs/math/llrintl.c (modified) * testsuites/psxtests/psxhdrs/math/llround.c (modified) * testsuites/psxtests/psxhdrs/math/llroundf.c (modified) * testsuites/psxtests/psxhdrs/math/llroundl.c (modified) * testsuites/psxtests/psxhdrs/math/log.c (modified) * testsuites/psxtests/psxhdrs/math/log10.c (modified) * testsuites/psxtests/psxhdrs/math/log10f.c (modified) * testsuites/psxtests/psxhdrs/math/log10l.c (modified) * testsuites/psxtests/psxhdrs/math/log1p.c (modified) * testsuites/psxtests/psxhdrs/math/log1pf.c (modified) * testsuites/psxtests/psxhdrs/math/log1pl.c (modified) * testsuites/psxtests/psxhdrs/math/log2.c (modified) * testsuites/psxtests/psxhdrs/math/log2f.c (modified) * testsuites/psxtests/psxhdrs/math/log2l.c (modified) * testsuites/psxtests/psxhdrs/math/logb.c (modified) * testsuites/psxtests/psxhdrs/math/logbf.c (modified) * testsuites/psxtests/psxhdrs/math/logbl.c (modified) * testsuites/psxtests/psxhdrs/math/logf.c (modified) * testsuites/psxtests/psxhdrs/math/logl.c (modified) * testsuites/psxtests/psxhdrs/math/lrint.c (modified) * testsuites/psxtests/psxhdrs/math/lrintf.c (modified) * testsuites/psxtests/psxhdrs/math/lrintl.c (modified) * testsuites/psxtests/psxhdrs/math/lround.c (modified) * testsuites/psxtests/psxhdrs/math/lroundf.c (modified) * testsuites/psxtests/psxhdrs/math/lroundl.c (modified) * testsuites/psxtests/psxhdrs/math/modf.c (modified) * testsuites/psxtests/psxhdrs/math/modff.c (modified) * testsuites/psxtests/psxhdrs/math/modfl.c (modified) * testsuites/psxtests/psxhdrs/math/nan.c (modified) * testsuites/psxtests/psxhdrs/math/nanf.c (modified) * testsuites/psxtests/psxhdrs/math/nanl.c (modified) * testsuites/psxtests/psxhdrs/math/nearbyint.c (modified) * testsuites/psxtests/psxhdrs/math/nearbyintf.c (modified) * testsuites/psxtests/psxhdrs/math/nearbyintl.c (modified) * testsuites/psxtests/psxhdrs/math/nextafter.c (modified) * testsuites/psxtests/psxhdrs/math/nextafterf.c (modified) * testsuites/psxtests/psxhdrs/math/nextafterl.c (modified) * testsuites/psxtests/psxhdrs/math/nexttoward.c (modified) * testsuites/psxtests/psxhdrs/math/nexttowardf.c (modified) * testsuites/psxtests/psxhdrs/math/nexttowardl.c (modified) * testsuites/psxtests/psxhdrs/math/pow.c (modified) * testsuites/psxtests/psxhdrs/math/powf.c (modified) * testsuites/psxtests/psxhdrs/math/powl.c (modified) * testsuites/psxtests/psxhdrs/math/remainder.c (modified) * testsuites/psxtests/psxhdrs/math/remainderf.c (modified) * testsuites/psxtests/psxhdrs/math/remainderl.c (modified) * testsuites/psxtests/psxhdrs/math/remquo.c (modified) * testsuites/psxtests/psxhdrs/math/remquof.c (modified) * testsuites/psxtests/psxhdrs/math/remquol.c (modified) * testsuites/psxtests/psxhdrs/math/rint.c (modified) * testsuites/psxtests/psxhdrs/math/rintf.c (modified) * testsuites/psxtests/psxhdrs/math/rintl.c (modified) * testsuites/psxtests/psxhdrs/math/round.c (modified) * testsuites/psxtests/psxhdrs/math/roundf.c (modified) * testsuites/psxtests/psxhdrs/math/roundl.c (modified) * testsuites/psxtests/psxhdrs/math/scalbln.c (modified) * testsuites/psxtests/psxhdrs/math/scalblnf.c (modified) * testsuites/psxtests/psxhdrs/math/scalblnl.c (modified) * testsuites/psxtests/psxhdrs/math/scalbn.c (modified) * testsuites/psxtests/psxhdrs/math/scalbnf.c (modified) * testsuites/psxtests/psxhdrs/math/scalbnl.c (modified) * testsuites/psxtests/psxhdrs/math/signbit.c (modified) * testsuites/psxtests/psxhdrs/math/sin.c (modified) * testsuites/psxtests/psxhdrs/math/sinf.c (modified) * testsuites/psxtests/psxhdrs/math/sinh.c (modified) * testsuites/psxtests/psxhdrs/math/sinhf.c (modified) * testsuites/psxtests/psxhdrs/math/sinhl.c (modified) * testsuites/psxtests/psxhdrs/math/sinl.c (modified) * testsuites/psxtests/psxhdrs/math/sqrt.c (modified) * testsuites/psxtests/psxhdrs/math/sqrtf.c (modified) * testsuites/psxtests/psxhdrs/math/sqrtl.c (modified) * testsuites/psxtests/psxhdrs/math/tan.c (modified) * testsuites/psxtests/psxhdrs/math/tanf.c (modified) * testsuites/psxtests/psxhdrs/math/tanh.c (modified) * testsuites/psxtests/psxhdrs/math/tanhf.c (modified) * testsuites/psxtests/psxhdrs/math/tanhl.c (modified) * testsuites/psxtests/psxhdrs/math/tanl.c (modified) * testsuites/psxtests/psxhdrs/math/tgamma.c (modified) * testsuites/psxtests/psxhdrs/math/tgammaf.c (modified) * testsuites/psxtests/psxhdrs/math/tgammal.c (modified) * testsuites/psxtests/psxhdrs/math/trunc.c (modified) * testsuites/psxtests/psxhdrs/math/truncf.c (modified) * testsuites/psxtests/psxhdrs/math/truncl.c (modified) * testsuites/psxtests/psxhdrs/math/y0.c (modified) * testsuites/psxtests/psxhdrs/math/y0f.c (modified) * testsuites/psxtests/psxhdrs/math/y0l.c (modified) * testsuites/psxtests/psxhdrs/math/y1.c (modified) * testsuites/psxtests/psxhdrs/math/y1f.c (modified) * testsuites/psxtests/psxhdrs/math/y1l.c (modified) * testsuites/psxtests/psxhdrs/math/yn.c (modified) * testsuites/psxtests/psxhdrs/math/ynf.c (modified) * testsuites/psxtests/psxhdrs/math/ynl.c (modified) * testsuites/psxtests/psxhdrs/sys/ipc/ftok.c (modified) * testsuites/psxtests/psxhdrs/utime/utime.c (modified) psxhdrs: Changed the Copyright license to BSD-2-Clause . The ... Thu, 13 Dec 2018 15:42:57 GMT Jacob Shin [cb8281f] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/sys/msg/msgctl.c (added) * testsuites/psxtests/psxhdrs/sys/msg/msgget.c (added) * testsuites/psxtests/psxhdrs/sys/msg/msgrcv.c (added) * testsuites/psxtests/psxhdrs/sys/msg/msgsnd.c (added) psxhdrs: Add POSIX API Signature Compliance Tests for sys/msg.h (GCI ... Thu, 13 Dec 2018 00:46:38 GMT Jacob Shin [28f23eb] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/sys/select/FD_CLR.c (added) * testsuites/psxtests/psxhdrs/sys/select/FD_ISSET.c (added) * testsuites/psxtests/psxhdrs/sys/select/FD_SET.c (added) * testsuites/psxtests/psxhdrs/sys/select/FD_ZERO.c (added) * testsuites/psxtests/psxhdrs/sys/select/pselect.c (added) * testsuites/psxtests/psxhdrs/sys/select/select.c (added) psxhdrs: Add POSIX API Signature Compliance Tests for sys/select.h ... Wed, 12 Dec 2018 15:33:22 GMT ABR290B [86b0ac9f] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/sys/shm/shmat.c (added) * testsuites/psxtests/psxhdrs/sys/shm/shmctl.c (added) * testsuites/psxtests/psxhdrs/sys/shm/shmdt.c (added) * testsuites/psxtests/psxhdrs/sys/shm/shmget.c (added) psxhdrs: Add POSIX Signature Compliance Test for sys/shm.h (GCI 2018) Wed, 12 Dec 2018 14:23:35 GMT ABR290B [a0353ea2] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/utmpx/endutxent.c (added) * testsuites/psxtests/psxhdrs/utmpx/getutxent.c (added) * testsuites/psxtests/psxhdrs/utmpx/getutxid.c (added) * testsuites/psxtests/psxhdrs/utmpx/getutxline.c (added) * testsuites/psxtests/psxhdrs/utmpx/pututxline.c (added) * testsuites/psxtests/psxhdrs/utmpx/setutxent.c (added) POSIX Signature Compliance Test for utmpx.h (GCI2018) Wed, 12 Dec 2018 14:14:40 GMT ABR290B [0af5ede] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/sys/statvfs/fstatvfs.c (added) * testsuites/psxtests/psxhdrs/sys/statvfs/statvfs.c (added) POSIX Signature Compliance Test for sys/statvfs.h (GCI 2018) Wed, 12 Dec 2018 21:00:10 GMT Jacob Shin [b770665f] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/net/if/if_freenameindex.c (added) * testsuites/psxtests/psxhdrs/net/if/if_indextoname.c (added) * testsuites/psxtests/psxhdrs/net/if/if_nameindex.c (added) * testsuites/psxtests/psxhdrs/net/if/if_nametoindex.c (added) psxhdrs: Add POSIX API Signature Compliance Tests for net/if.h
