# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/29/24 22:02:06 Tue, 31 Mar 2020 08:05:51 GMT Sebastian Huber [762425e] * cpukit/include/rtems/ftpd.h (modified) ftpd: Remove superfluous defines These defines are not used and ... Tue, 31 Mar 2020 08:03:20 GMT Sebastian Huber [eb92b1f] * cpukit/ftpd/ftpd-init.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/include/rtems/ftpd.h (modified) ftpd: Fix return types Mon, 30 Mar 2020 08:30:06 GMT Sebastian Huber [5608e89] * cpukit/include/rtems/confdefs/bsp.h (modified) config: Remove BSP_DEFAULT_UNIFIED_WORK_AREAS Do not undefine this ... Tue, 24 Mar 2020 19:33:01 GMT Vijay Kumar Banerjee [4bae9c31] * MAINTAINERS (modified) MAINTAINERS: Add myself to Write After Approval Mon, 23 Mar 2020 15:16:18 GMT Sebastian Huber [96402b74] * cpukit/include/rtems/score/tls.h (modified) score: Document _TLS_Alignment Mon, 23 Mar 2020 14:54:59 GMT Sebastian Huber [24c2179] * cpukit/include/rtems/score/tls.h (modified) score: Fix size of TLS_Thread_control_block On most architectures, ... Mon, 23 Mar 2020 14:44:41 GMT Sebastian Huber [d05a900a] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/sptls02/init.cc (modified) * testsuites/sptests/sptls02/sptls02.h (added) * testsuites/sptests/sptls02/var.cc (added) sptests/sptls02: Add test case Add a test case which requires the ... Mon, 23 Mar 2020 06:21:42 GMT Sebastian Huber [3fd4889] * cpukit/include/rtems/confdefs/extensions.h (modified) conf: Improve evaluation of event recording opts Check for ... Thu, 19 Mar 2020 20:55:26 GMT Joel Sherrill [37e7cc5] * bsps/arm/gdbarmsim/config/arm1136jfs-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm1136jfs.cfg (deleted) * bsps/arm/gdbarmsim/config/arm1136js-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm1136js.cfg (deleted) * bsps/arm/gdbarmsim/config/arm7tdmi-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm7tdmi.cfg (deleted) * bsps/arm/gdbarmsim/config/arm920-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm920.cfg (deleted) * bsps/arm/gdbarmsim/config/armcortexa9-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/armcortexa9.cfg (deleted) * bsps/arm/gdbarmsim/console/console-io.c (deleted) * bsps/arm/gdbarmsim/headers.am (deleted) * bsps/arm/gdbarmsim/include/bsp.h (deleted) * bsps/arm/gdbarmsim/include/bsp/irq.h (deleted) * bsps/arm/gdbarmsim/include/bsp/swi.h (deleted) * bsps/arm/gdbarmsim/include/tm27.h (deleted) * bsps/arm/gdbarmsim/irq/irq-dispatch.c (deleted) * bsps/arm/gdbarmsim/irq/irq.c (deleted) * bsps/arm/gdbarmsim/start/bsp_specs (deleted) * bsps/arm/gdbarmsim/start/bspreset.c (deleted) * bsps/arm/gdbarmsim/start/bspstart.c (deleted) * bsps/arm/gdbarmsim/start/bspstarthooks.c (deleted) * bsps/arm/gdbarmsim/start/linkcmds (deleted) * bsps/arm/gdbarmsim/start/syscalls.c (deleted) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (deleted) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (deleted) gdbarmsim: Remove Closes #3611. Thu, 12 Mar 2020 17:29:48 GMT Sebastian Huber [ab42b3e] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs/extensions.h (modified) * cpukit/include/rtems/record.h (modified) * cpukit/include/rtems/recorddump.h (added) * cpukit/libtrace/record/record-dump-base64.c (added) * cpukit/libtrace/record/record-dump-fatal.c (added) * cpukit/libtrace/record/record-dump-zbase64.c (added) * cpukit/libtrace/record/record-dump-zfatal.c (added) * cpukit/libtrace/record/record-dump.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/record02/init.c (modified) record: Add rtems_record_dump() Add rtems_record_dump_base64() and ... Fri, 13 Mar 2020 09:14:04 GMT Sebastian Huber [c584d4e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/libcsupport/src/rtems_put_char.c (added) * cpukit/libcsupport/src/vprintk.c (modified) rtems: Add rtems_put_char() Update #3904. Thu, 12 Mar 2020 14:43:17 GMT Sebastian Huber [a6b36334] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/io.h (modified) * cpukit/score/src/iobase64.c (added) * testsuites/sptests/spprintk/init.c (modified) score: Add _IO_Base64() Update #3904. Fri, 13 Mar 2020 14:14:04 GMT Sebastian Huber [5662210] * bsps/shared/irq-default-sources.am (modified) bsps: Remove legacy interrupt API from default This fixes linker ... Fri, 13 Mar 2020 14:13:30 GMT Sebastian Huber [aa2d5d93] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) bsp/virtex: Remove duplicate include Tue, 10 Mar 2020 16:07:19 GMT Sebastian Huber [c2287ba2] * cpukit/include/rtems/libio.h (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/sup_fs_deviceio.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/posix/src/shmopen.c (modified) * testsuites/fstests/fsclose01/init.c (modified) libio: Robust file descriptor reference counting There was a race ... Thu, 12 Mar 2020 21:00:25 GMT Joel Sherrill [2ff83634] * bsps/m68k/mrm332/config/mrm332-testsuite.tcfg (modified) mrm332-testsuite.tcfg: Add dl01 Thu, 12 Mar 2020 21:00:05 GMT Joel Sherrill [a5187956] * bsps/arm/rtl22xx/config/rtl22xx-testsuite.tcfg (modified) rtl22xx-testsuite.tcfg: Add dl10 and ttest01 Thu, 12 Mar 2020 20:59:35 GMT Joel Sherrill [9bbfb2b6] * bsps/arm/lpc24xx/config/lpc23xx_tli800-testsuite.tcfg (modified) lpc23xx_tli800-testsuite.tcfg: Add ttest01 Thu, 12 Mar 2020 20:59:10 GMT Joel Sherrill [ae6597f] * bsps/arm/lpc24xx/config/lpc2362-testsuite.tcfg (modified) lpc2362-testsuite.tcfg: Add ttest01 Thu, 12 Mar 2020 20:53:51 GMT Joel Sherrill [16ed7f64] * bsps/arm/lm3s69xx/config/lm3s3749-testsuite.tcfg (modified) lm3s3749-testsuite.tcfg: Add ttest01 Tue, 03 Mar 2020 18:23:53 GMT Sebastian Huber [0161b93d] * bsps/i386/pc386/include/bsp.h (modified) * bsps/riscv/griscv/include/bsp.h (modified) * bsps/sparc/leon3/include/bsp.h (modified) * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs/bsp.h (modified) * cpukit/include/rtems/confdefs/libio.h (modified) * cpukit/include/rtems/confdefs/obsolete.h (modified) * cpukit/include/rtems/devfs.h (deleted) * cpukit/include/rtems/imfs.h (modified) * cpukit/libfs/src/devfs/devclose.c (deleted) * cpukit/libfs/src/devfs/devfs_eval.c (deleted) * cpukit/libfs/src/devfs/devfs_init.c (deleted) * cpukit/libfs/src/devfs/devfs_mknod.c (deleted) * cpukit/libfs/src/devfs/devfs_show.c (deleted) * cpukit/libfs/src/devfs/devioctl.c (deleted) * cpukit/libfs/src/devfs/devopen.c (deleted) * cpukit/libfs/src/devfs/devread.c (deleted) * cpukit/libfs/src/devfs/devstat.c (deleted) * cpukit/libfs/src/devfs/devwrite.c (deleted) * cpukit/libfs/src/imfs/imfs_eval_devfs.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/devfs01/init.c (modified) * testsuites/libtests/devfs02/devfs02.doc (deleted) * testsuites/libtests/devfs02/devfs02.scn (deleted) * testsuites/libtests/devfs02/init.c (deleted) * testsuites/libtests/devfs03/devfs03.doc (deleted) * testsuites/libtests/devfs03/devfs03.scn (deleted) * testsuites/libtests/devfs03/init.c (deleted) * testsuites/libtests/devfs04/init.c (modified) * testsuites/libtests/deviceio01/init.c (modified) imfs: Replace devfs with an IMFS specialization Add a simplified ... Thu, 05 Mar 2020 20:56:31 GMT Sebastian Huber [103a371] * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) imfs: Simplify code generation Update #3894. Thu, 05 Mar 2020 20:49:50 GMT Sebastian Huber [277b9dd] * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) imfs: Remove unused handlers Update #3894. Thu, 05 Mar 2020 20:48:10 GMT Sebastian Huber [83994913] * cpukit/include/rtems/confdefs/libio.h (modified) * cpukit/include/rtems/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_stat_file.c (modified) imfs: Constify imfs_memfile_bytes_per_block The ... Thu, 05 Mar 2020 20:32:29 GMT Sebastian Huber [85c9145f] * cpukit/libfs/src/imfs/imfs_node.c (modified) imfs: Use _IMFS_get_time() Update #3894. Tue, 03 Mar 2020 18:23:27 GMT Sebastian Huber [624d691b] * cpukit/include/rtems/libio_.h (modified) libio: Constify some functions Thu, 05 Mar 2020 23:51:12 GMT Joel Sherrill [097ea1e] * bsps/powerpc/psim/README (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/psim/start/device-tree (deleted) * bsps/powerpc/psim/start/linkcmds (modified) psim: Rework device tree so devices do not conflict with 256MB RAM ... Sun, 01 Mar 2020 10:56:08 GMT Sebastian Huber [fa3005f] * cpukit/libcsupport/src/consolesimpletask.c (modified) console: Use IMFS_add_node() for simple task cons Change license to ... Sat, 29 Feb 2020 18:41:18 GMT Sebastian Huber [7e3b5c0] * cpukit/libcsupport/src/consolesimple.c (modified) console: Use IMFS_add_node() for simple console Change license to ... Sat, 29 Feb 2020 15:14:31 GMT Sebastian Huber [fa44c39] * cpukit/Makefile.am (modified) * cpukit/include/rtems/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_add_node.c (added) * cpukit/libfs/src/imfs/imfs_node.c (modified) * cpukit/libfs/src/imfs/imfs_node_destroy_default.c (added) * testsuites/fstests/fsimfsgeneric01/init.c (modified) imfs: Add IMFS_add_node() Update #3894. Sat, 29 Feb 2020 10:43:42 GMT Sebastian Huber [13b71f8] * cpukit/libfs/src/imfs/imfs_creat.c (modified) imfs: Simplify IMFS_create_node() Update #3894. Sat, 29 Feb 2020 10:15:43 GMT Sebastian Huber [0b0cd93] * cpukit/include/rtems/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_node.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (modified) imfs: Remove IMFS_NODE_FLAG_NAME_ALLOCATED Remove ... Tue, 03 Mar 2020 12:45:50 GMT Sebastian Huber [8b73ee5] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/getcurrentprocessor.c (deleted) * cpukit/rtems/src/getprocessorcount.c (deleted) rtems: rtems_scheduler_get_processor_maximum() In uniprocessor ... Tue, 03 Mar 2020 12:01:56 GMT Sebastian Huber [fdeaa64] * cpukit/include/rtems/confdefs/iodrivers.h (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm02/tm02impl.h (modified) * testsuites/tmtests/tm03/tm03impl.h (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm28/task1.c (modified) * testsuites/tmtests/tm29/task1.c (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) config: Remove include The use of ... Tue, 03 Mar 2020 11:46:36 GMT Sebastian Huber [60b76933] * testsuites/sptests/spheapprot/init.c (modified) sptests/spheapprot: Fix warning Sat, 29 Feb 2020 10:34:53 GMT Sebastian Huber [c4d5a34] * testsuites/fstests/fsrename/test.c (modified) fstests/fsrename: Rename a file twice Tue, 03 Mar 2020 06:30:04 GMT Sebastian Huber [198c07e5] * testsuites/sptests/spextensions01/init.c (modified) sptests/spextensions01: Add comment Update #3885. Mon, 24 Feb 2020 13:06:41 GMT Sebastian Huber [18020109] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/schedulermapfromposix.c (added) * testsuites/sptests/spscheduler01/init.c (modified) rtems: Add rtems_scheduler_map_priority_from_posix() Update #3881. Mon, 24 Feb 2020 13:06:16 GMT Sebastian Huber [38736c6] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/schedulermaptoposix.c (added) * testsuites/sptests/spscheduler01/init.c (modified) rtems: Add rtems_scheduler_map_priority_to_posix() Update #3881. Fri, 28 Feb 2020 06:49:40 GMT Sebastian Huber [fd8c87a] * cpukit/dtc/VERSION (modified) dtc: Update VERSION Thu, 20 Feb 2020 21:45:57 GMT Simon Glass [5fa49fa] * cpukit/dtc/libfdt/fdt_ro.c (modified) libfdt: Allow exclusion of fdt_check_full() This function is used ... Thu, 20 Feb 2020 21:45:56 GMT Simon Glass [83cd341] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: Add support for disabling ordering check/fixup Add a way to ... Thu, 20 Feb 2020 21:45:55 GMT Simon Glass [0791bdf] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: Add support for disabling version checks Allow enabling ... Thu, 20 Feb 2020 21:45:54 GMT Simon Glass [23fe4d7b] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: Add support for disabling rollback handling Allow enabling ... Thu, 20 Feb 2020 21:45:53 GMT Simon Glass [52d4c65] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_ro.c (modified) libfdt: Add support for disabling sanity checks Allow enabling ... Thu, 20 Feb 2020 21:45:52 GMT Simon Glass [e9ebc6ab] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/fdt_rw.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: Add support for disabling dtb checks Support ... Thu, 20 Feb 2020 21:45:51 GMT Simon Glass [b44c574d] * cpukit/dtc/libfdt/libfdt_internal.h (modified) Add a way to control the level of checks in the code Add a new ... Thu, 20 Feb 2020 21:45:50 GMT Simon Glass [461c7354] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/include/libfdt.h (modified) libfdt: De-inline fdt_header_size() There does not seem to be a ... Fri, 08 Nov 2019 14:42:53 GMT David Gibson [7217a4f] * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Correct prototype for fdt_ro_probe_() This function returns ... Tue, 10 Sep 2019 10:48:24 GMT Luc Michel [94d5b6ea] * cpukit/include/libfdt.h (modified) libfdt.h: add explicit cast from void* to uint8_t* in fdt(32|64)_st ... Sun, 28 Jul 2019 06:25:51 GMT David Gibson [39f64e08] * cpukit/dtc/libfdt/fdt_addresses.c (modified) libfdt: Allow #size-cells of 0 c12b2b0c20eb "libfdt: ... Fri, 05 Jul 2019 03:42:40 GMT David Gibson [1a5c324] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Tweak data handling to satisfy Coverity In libfdt we often ... Thu, 20 Jun 2019 21:19:39 GMT Rob Herring [0b83b822] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_addresses.c (modified) * cpukit/dtc/libfdt/fdt_empty_tree.c (modified) * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/fdt_rw.c (modified) * cpukit/dtc/libfdt/fdt_strerror.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) * cpukit/dtc/libfdt/fdt_wip.c (modified) * cpukit/dtc/libfdt/libfdt_internal.h (modified) * cpukit/include/fdt.h (modified) * cpukit/include/libfdt.h (modified) * cpukit/include/libfdt_env.h (modified) libfdt: Replace GPL/BSD boilerplate/reference with SPDX tags ... Thu, 09 May 2019 09:41:22 GMT Nicholas Piggin [b00040b2] * cpukit/dtc/libfdt/fdt_sw.c (modified) * cpukit/include/libfdt.h (modified) libfdt: Add FDT_CREATE_FLAG_NO_NAME_DEDUP flag that trades size for ... Thu, 09 May 2019 09:41:21 GMT Nicholas Piggin [adb403b9] * cpukit/dtc/libfdt/fdt_strerror.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) * cpukit/include/libfdt.h (modified) libfdt: Introduce fdt_create_with_flags() There is a need to be ... Thu, 09 May 2019 09:41:20 GMT Nicholas Piggin [4902d42] * cpukit/dtc/libfdt/fdt_rw.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: Ensure fdt_add_property frees allocated name string on ... Fri, 29 Mar 2019 02:59:04 GMT David Gibson [3d4c1c89] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/include/libfdt.h (modified) libfdt: Make fdt_get_max_phandle() an inline It's now a trivial ... Tue, 26 Mar 2019 15:33:02 GMT Thierry Reding [5a45775] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/include/libfdt.h (modified) libfdt: Add phandle generation helper The new ... Tue, 26 Mar 2019 15:33:00 GMT Thierry Reding [6505fe0e] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/include/libfdt.h (modified) * cpukit/include/libfdt_env.h (modified) libfdt: Add new maximum phandle lookup function The ... Wed, 27 Mar 2019 06:15:52 GMT AKASHI Takahiro [d5203fe] * cpukit/dtc/libfdt/fdt_addresses.c (modified) * cpukit/include/libfdt.h (modified) libfdt: add fdt_append_addrrange() This function will append an ... Mon, 25 Mar 2019 03:51:27 GMT David Gibson [3d75d7c] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/include/libfdt.h (modified) * cpukit/include/libfdt_env.h (modified) Revert "libfdt: Add phandle generation helper" This reverts commit ... Wed, 20 Mar 2019 15:10:03 GMT Thierry Reding [a0dea644] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/include/libfdt.h (modified) * cpukit/include/libfdt_env.h (modified) libfdt: Add phandle generation helper The new ... Fri, 21 Dec 2018 16:32:23 GMT Geert Uytterhoeven [18a7759] * cpukit/include/libfdt.h (modified) libfdt: Fix FDT_ERR_NOTFOUND typos in documentation The actual ... Fri, 21 Dec 2018 13:01:32 GMT Geert Uytterhoeven [ab3efcc] * cpukit/include/libfdt.h (modified) libfdt: Fix fdt_getprop_by_offset() parameter name in documentation ... Mon, 19 Nov 2018 05:36:15 GMT David Gibson [bef6dfc5] * cpukit/include/libfdt.h (modified) libfdt: Don't use memcpy to handle unaligned reads on ARM 6dcb8ba4 ... Fri, 02 Nov 2018 01:46:22 GMT John Clarke [8bd3915] * cpukit/dtc/libfdt/fdt_addresses.c (modified) * cpukit/include/libfdt.h (modified) libfdt: return correct value if #size-cells property is not present ... Wed, 26 Feb 2020 09:02:37 GMT Sebastian Huber [fcb11510] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/userextaddset.c (modified) * testsuites/sptests/spextensions01/init.c (modified) score: Fix context switch extensions (SMP) In uniprocessor and SMP ... Tue, 25 Feb 2020 13:07:35 GMT Jan Sommer [2220a53] * bsps/i386/pc386/clock/ckinit.c (modified) bsp/pc386: Fix interrupt enable to make debug option work again Thu, 27 Feb 2020 07:21:17 GMT Sebastian Huber [61e2d73f] * bsps/powerpc/mpc55xxevb/config/mpc5643l_dpu-testsuite.tcfg (modified) * bsps/powerpc/mpc55xxevb/config/mpc5643l_evb-testsuite.tcfg (modified) bsp/mpc5643l_*: Exclude some tests These tests do not fit into the ... Tue, 25 Feb 2020 12:47:59 GMT Sebastian Huber [c36fae22] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/iodrivers.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/iodefault.c (added) * testsuites/sptests/spsysinit01/init.c (modified) config: Initialize IO drivers on demand Tue, 25 Feb 2020 13:43:52 GMT Sebastian Huber [01c97e64] * cpukit/score/src/threadinitialize.c (modified) score: Fix label defined but not used warning Update #3835. Tue, 25 Feb 2020 12:49:45 GMT Sebastian Huber [470dfa1f] * cpukit/include/rtems/confdefs/iodrivers.h (modified) config: Resurrect NULL_DRIVER_TABLE_ENTRY This define may be used ... Fri, 21 Feb 2020 07:08:57 GMT Sebastian Huber [a78495ed] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/wkspace.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 14:26:40 GMT Sebastian Huber [1fb1cf1] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/objectsposix.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 14:13:16 GMT Sebastian Huber [35e58c45] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/wkspacesupport.h (added) config: Add Remove all comments ... Thu, 20 Feb 2020 12:59:30 GMT Sebastian Huber [d20209b] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/objectsclassic.h (added) config: Add Remove all comments ... Thu, 20 Feb 2020 13:24:46 GMT Sebastian Huber [f5a2fd86] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/threads.h (added) * cpukit/posix/src/pthread.c (modified) config: Add Remove all comments and ... Thu, 20 Feb 2020 12:33:07 GMT Sebastian Huber [40db051] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/unlimited.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 12:22:54 GMT Sebastian Huber [7b6596f5] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/iodrivers.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 12:10:52 GMT Sebastian Huber [fe84ab5] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/console.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 11:58:13 GMT Sebastian Huber [8314933] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/initthread.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 11:02:39 GMT Sebastian Huber [b15d1cb] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/inittask.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 10:39:30 GMT Sebastian Huber [8f3419b] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/extensions.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 10:39:05 GMT Sebastian Huber [fb0caca] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/newlib.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 06:55:18 GMT Sebastian Huber [32561f5] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/clock.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 06:45:57 GMT Sebastian Huber [1d35bf2a] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/mpci.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 06:33:59 GMT Sebastian Huber [03aff2c] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/malloc.h (added) * cpukit/libcsupport/src/mallocdirtydefault.c (added) * cpukit/libcsupport/src/mallocextenddefault.c (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 06:22:48 GMT Sebastian Huber [691b614] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/bdbuf.h (added) config: Add Remove all comments and ... Wed, 19 Feb 2020 13:14:46 GMT Sebastian Huber [591e9736] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/scheduler.h (added) config: Add Remove all comments and ... Sat, 15 Feb 2020 17:57:57 GMT Sebastian Huber [1608221] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/libio.h (added) config: Add Remove all comments and ... Sat, 15 Feb 2020 13:00:08 GMT Sebastian Huber [0f8e139e] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/percpu.h (added) config: Add Remove comments and ... Sat, 15 Feb 2020 13:16:58 GMT Sebastian Huber [f45d0b2f] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/bsp.h (added) config: Add Remove all comments and ... Fri, 14 Feb 2020 16:20:36 GMT Sebastian Huber [55a7316] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/libpci.h (added) config: Add Derive copyright and license ... Fri, 14 Feb 2020 15:50:18 GMT Sebastian Huber [cadd8d1] * cpukit/header-dirs.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/obsolete.h (added) config: Add Unify handling of obsolete ... Fri, 21 Feb 2020 06:34:50 GMT Sebastian Huber [0561cc1] * cpukit/include/rtems/confdefs.h (modified) config: Remove _Configure_Max_Objects() Use ... Fri, 21 Feb 2020 06:28:13 GMT Sebastian Huber [cfe68385] * cpukit/include/rtems/confdefs.h (modified) config: Improve _Configure_From_workspace() Commit ... Sat, 15 Feb 2020 11:07:28 GMT Sebastian Huber [c7f748a] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/smp.h (modified) * testsuites/ada/support/initimpl.h (modified) * testsuites/libtests/block08/system.h (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/termios05/init.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp37/system.h (modified) * testsuites/sptests/sp65/sp65impl.h (modified) * testsuites/sptests/spcbssched01/system.h (modified) * testsuites/sptests/spcbssched02/system.h (modified) * testsuites/sptests/spcbssched03/system.h (modified) * testsuites/sptests/spedfsched01/system.h (modified) * testsuites/sptests/spedfsched02/system.h (modified) * testsuites/sptests/spedfsched03/system.h (modified) * testsuites/sptests/spfatal29/init.c (modified) * testsuites/sptests/spfifo03/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) * testsuites/sptests/spintrcritical06/spintrcritical06impl.h (modified) * testsuites/sptests/spintrcritical15/init.c (modified) * testsuites/sptests/spmrsp01/init.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm24/system.h (modified) config: Remove CONFIGURE_DISABLE_SMP_CONFIGURATION The ... Sat, 15 Feb 2020 11:03:39 GMT Sebastian Huber [ca82a603] * cpukit/rtems/src/timerserver.c (modified) rtems: Change timer server task mode setting Use the non-preempt ... Sat, 15 Feb 2020 10:52:00 GMT Sebastian Huber [e50e42b8] * cpukit/include/rtems/scheduler.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: _Scheduler_Is_non_preempt_mode_supported() If the ... Sat, 15 Feb 2020 10:23:08 GMT Sebastian Huber [5b8d80d7] * cpukit/include/rtems/confdefs.h (modified) * testsuites/sptests/sp66/init.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) config: CONFIGURE_INIT_TASK_INITIAL_MODES Determine the default for ...
