# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 21:32:24 Sat, 07 Dec 2002 13:06:23 GMT Ralf Corsepius [6fea3824] * ChangeLog (modified) * aclocal/bsp-configure.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-12-07 Ralf Corsepius * ... Sat, 07 Dec 2002 12:59:43 GMT Ralf Corsepius [09e391d] * scripts/ChangeLog (modified) * scripts/autotools/autoconf-rtems.spec.in (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2002-12-07 Ralf Corsepius * ... Sat, 07 Dec 2002 10:26:07 GMT Ralf Corsepius [da153c86] * c/src/optman/ChangeLog (modified) * c/src/optman/Makefile.am (modified) 2002-12-07 Ralf Corsepius * ... Fri, 06 Dec 2002 13:51:35 GMT Joel Sherrill [07bf9f9d] * scripts/ChangeLog (modified) 2002-12-06 Joel Sherrill * ... Fri, 06 Dec 2002 13:51:15 GMT Joel Sherrill [4f7ee21] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/setup.def (modified) 2002-12-06 Joel Sherrill * ... Fri, 06 Dec 2002 13:51:12 GMT Joel Sherrill [e09c5c59] * scripts/ChangeLog (modified) 2002-12-06 Joel Sherrill * ... Fri, 06 Dec 2002 13:49:57 GMT Joel Sherrill [83333e9] * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/src/malloc.c (modified) 2002-12-06 Joel Sherrill * ... Fri, 06 Dec 2002 13:48:27 GMT Joel Sherrill [2837a5e] * cpukit/posix/ChangeLog (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/macros/rtems/posix/cond.inl (modified) 2002-12-06 Vladimir Nesic * ... Fri, 06 Dec 2002 13:07:15 GMT Ralf Corsepius [baa8dd7c] * ChangeLog (modified) * automake/compile.am (modified) * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 11:22:05 GMT Ralf Corsepius [028792e8] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 11:21:57 GMT Ralf Corsepius [f04c916] * ChangeLog (modified) * automake/compile.am (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 11:21:50 GMT Ralf Corsepius [8e4cd5a] * cpukit/ChangeLog (modified) * cpukit/aclocal/env-rtemsbsp.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/automake/compile.am (modified) * cpukit/automake/multilib.am (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 11:21:45 GMT Ralf Corsepius [9bd78e3e] * make/ChangeLog (modified) * make/custom/posix.cfg (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 08:23:08 GMT Ralf Corsepius [dfa8fe34] * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/a29k/ChangeLog (modified) * c/src/lib/libbsp/a29k/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/a29k/configure.ac (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/i960/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/configure.ac (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/configure.ac (modified) * c/src/lib/libcpu/sh/sh7750/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7750/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 07:13:50 GMT Ralf Corsepius [c2113d3] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 06:48:05 GMT Ralf Corsepius [f69283e2] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * c/src/optman/ChangeLog (modified) * c/src/optman/configure.ac (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 06:25:58 GMT Ralf Corsepius [c707861] * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libcsupport/src/termios.c (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 04:44:40 GMT Ralf Corsepius [382e1eb3] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 04:40:18 GMT Ralf Corsepius [8b38a769] * ChangeLog (modified) * aclocal/rtems-flags.m4 (added) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-flags.m4 (added) 2002-12-06 Ralf Corsepius * ... Wed, 04 Dec 2002 16:38:50 GMT Ralf Corsepius [82b1805] * ChangeLog (modified) * bootstrap (modified) 2002-12-04 Ralf Corsepius * ... Tue, 03 Dec 2002 00:47:10 GMT Joel Sherrill [e819fefc] * c/src/libmisc/ChangeLog (modified) * c/src/libmisc/stackchk/check.c (modified) * cpukit/libmisc/ChangeLog (modified) * cpukit/libmisc/stackchk/check.c (modified) 2002-12-02 Joel Sherrill * ... Tue, 03 Dec 2002 00:46:40 GMT Joel Sherrill [5a5b0b52] * c/src/tests/libtests/ChangeLog (modified) * c/src/tests/libtests/malloctest/init.c (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/malloctest/init.c (modified) 2002-12-02 Joel Sherrill * ... Mon, 02 Dec 2002 19:17:27 GMT Joel Sherrill [2e332a9] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/setup.def (modified) 2002-12-02 Joel Sherrill * ... Mon, 02 Dec 2002 19:16:37 GMT Joel Sherrill [2728d9cf] * cpukit/score/ChangeLog (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) 2002-12-02 Joel Sherrill * ... Mon, 02 Dec 2002 19:15:58 GMT Joel Sherrill [bbad6f0] * cpukit/rtems/ChangeLog (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) 2002-12-02 Joel Sherrill * ... Mon, 02 Dec 2002 19:15:24 GMT Joel Sherrill [35ee867] * cpukit/posix/ChangeLog (modified) * cpukit/posix/include/rtems/posix/timer.h (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/posixtimespecsubtract.c (modified) * cpukit/posix/src/ptimer1.c (modified) * cpukit/posix/src/semunlink.c (modified) 2002-12-02 Joel Sherrill * ... Mon, 02 Dec 2002 19:14:27 GMT Joel Sherrill [a36e988] * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) 2002-12-02 Joel Sherrill * ... Mon, 02 Dec 2002 19:13:38 GMT Joel Sherrill [36ea4c2a] * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/network/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/startup/linkcmds (modified) 2002-12-02 Joel Sherrill * ... Mon, 02 Dec 2002 19:13:26 GMT Joel Sherrill [7e476f0] * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/sys/ioccom.h (modified) 2002-12-02 Joel Sherrill * ... Mon, 02 Dec 2002 19:11:40 GMT Joel Sherrill [25f37e8] * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2002-12-02 Joel Sherrill * ... Mon, 02 Dec 2002 17:47:47 GMT Joel Sherrill [aed317ab] * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/pxfl/.cvsignore (deleted) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/pxfl/README (deleted) * c/src/lib/libbsp/hppa1.1/pxfl/floss-bsp.h (deleted) 2002-12-02 Joel Sherrill * ... Mon, 02 Dec 2002 15:14:36 GMT Ralf Corsepius [0dcf8597] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/mpc8260/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc8260/include/Makefile.am (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc8xx/include/Makefile.am (deleted) 2002-12-02 Ralf Corsepius * ... Mon, 02 Dec 2002 15:01:10 GMT Joel Sherrill [0535d92e] * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/i960/shared/soft_reset_asm.S (deleted) 2002-12-02 Joel Sherrill * ... Sun, 01 Dec 2002 12:21:17 GMT Ralf Corsepius [aa8b17e] * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) 2002-12-01 Ralf Corsepius * ... Sun, 01 Dec 2002 12:14:38 GMT Ralf Corsepius [0730209] * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/configure.ac (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/configure.ac (modified) 2002-12-01 Ralf Corsepius * ... Sun, 01 Dec 2002 12:00:26 GMT Ralf Corsepius [a6ebf56] * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/a29k/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) 2002-12-01 Ralf Corsepius * ... Sun, 01 Dec 2002 11:48:27 GMT Ralf Corsepius [6b20f44] * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) 2002-12-01 Ralf Corsepius * ... Sun, 01 Dec 2002 11:45:50 GMT Ralf Corsepius [c47c12b] * ChangeLog (modified) * aclocal/prog-cc.m4 (modified) 2002-12-01 Ralf Corsepius * ... Sun, 01 Dec 2002 08:01:04 GMT Ralf Corsepius [29d82b25] * ChangeLog (modified) * automake/compile.am (modified) 2002-12-01 Ralf Corsepius * ... Fri, 29 Nov 2002 21:18:29 GMT Joel Sherrill [472f35a] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2002-11-29 Joel Sherrill * ... Fri, 29 Nov 2002 19:06:54 GMT Eric Norum [c7cba294] * cpukit/posix/ChangeLog (modified) * cpukit/posix/src/sysconf.c (modified) Return error rather than panic if argument is unsupported. Fri, 29 Nov 2002 11:18:58 GMT Ralf Corsepius [f1de6bc] * make/ChangeLog (modified) * make/custom/default.cfg (modified) 2002-11-29 Ralf Corsepius * ... Fri, 29 Nov 2002 11:16:45 GMT Ralf Corsepius [fc195b2b] * c/make/.cvsignore (deleted) 2002-11-29 Ralf Corsepius * ... Fri, 29 Nov 2002 11:15:05 GMT Ralf Corsepius [b1cf0c7] * c/make/ChangeLog (deleted) * c/make/Makefile.am (deleted) * c/make/configure.ac (deleted) * c/make/target.cfg.in (deleted) 2002-11-29 Ralf Corsepius * ... Fri, 29 Nov 2002 11:13:12 GMT Ralf Corsepius [87ecb88c] * ChangeLog (modified) * configure.ac (modified) 2002-11-29 Ralf Corsepius * ... Fri, 29 Nov 2002 11:10:57 GMT Ralf Corsepius [8da1074] * c/src/make/ChangeLog (modified) * c/src/make/Makefile.am (modified) * c/src/make/configure.ac (modified) * c/src/make/target.cfg.in (added) 2002-11-29 Ralf Corsepius * ... Fri, 29 Nov 2002 08:27:53 GMT Ralf Corsepius [ff65620] * ChangeLog (modified) * aclocal/canonicalize-tools.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/check-custom-bsp.m4 (added) * aclocal/prog-ccas.m4 (added) 2002-11-29 Ralf Corsepius * ... Thu, 28 Nov 2002 21:12:23 GMT Joel Sherrill [f7e1564] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/setup.def (modified) 2002-11-28 Joel Sherrill * ... Mon, 25 Nov 2002 15:24:05 GMT Ralf Corsepius [d35b77f] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2002-11-25 Ralf Corsepius * ... Fri, 22 Nov 2002 18:15:43 GMT Ralf Corsepius [e4eb1be] * scripts/ChangeLog (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) 2002-11-22 Ralf Corsepius * ... Wed, 20 Nov 2002 14:21:25 GMT Ralf Corsepius [cccb7e0] * c/src/optman/ChangeLog (modified) * c/src/optman/Makefile.am (modified) * c/src/optman/configure.ac (modified) * c/src/optman/rel.am (deleted) * c/src/optman/rtems/Makefile.am (deleted) * c/src/optman/sapi/Makefile.am (deleted) 2002-11-20 Ralf Corsepius * ... Wed, 20 Nov 2002 13:41:51 GMT Ralf Corsepius [b6cc40a] * ChangeLog (modified) * acinclude.m4 (modified) 2002-11-20 Ralf Corsepius * ... Wed, 20 Nov 2002 02:59:35 GMT Ralf Corsepius [6fa25bcd] * c/src/make/ChangeLog (modified) * c/src/make/Makefile.am (modified) 2002-11-19 Ralf Corsepius * ... Wed, 20 Nov 2002 02:57:45 GMT Ralf Corsepius [fd5e23a] * cpukit/ChangeLog (modified) * cpukit/automake/compile.am (modified) 2002-11-19 Ralf Corsepius * ... Wed, 20 Nov 2002 02:57:38 GMT Ralf Corsepius [0a9a0f5] * ChangeLog (modified) * aclocal/quoting.m4 (modified) 2002-11-19 Ralf Corsepius * ... Wed, 20 Nov 2002 01:37:49 GMT Ralf Corsepius [cd1fac6] * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) 2002-11-19 Ralf Corsepius * ... Wed, 20 Nov 2002 01:22:20 GMT Ralf Corsepius [3bebc79] * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) 2002-11-19 Ralf Corsepius * ... Wed, 20 Nov 2002 01:12:53 GMT Ralf Corsepius [3f4382fe] * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) 2002-11-19 Ralf Corsepius * ... Wed, 20 Nov 2002 01:12:43 GMT Ralf Corsepius [4f210c04] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 22:37:21 GMT Ralf Corsepius [9d721178] * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 22:23:50 GMT Ralf Corsepius [47c0220] * c/src/ada/ChangeLog (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/configure.ac (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) * cpukit/score/cpu/a29k/ChangeLog (modified) * cpukit/score/cpu/a29k/configure.ac (modified) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/configure.ac (modified) * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/configure.ac (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/configure.ac (modified) * cpukit/score/cpu/hppa1.1/ChangeLog (modified) * cpukit/score/cpu/hppa1.1/configure.ac (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/configure.ac (modified) * cpukit/score/cpu/i960/ChangeLog (modified) * cpukit/score/cpu/i960/configure.ac (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/configure.ac (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/configure.ac (modified) * cpukit/score/cpu/mips64orion/ChangeLog (modified) * cpukit/score/cpu/mips64orion/configure.ac (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/configure.ac (modified) * cpukit/score/cpu/or32/ChangeLog (modified) * cpukit/score/cpu/or32/configure.ac (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/configure.ac (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/configure.ac (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/configure.ac (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/configure.ac (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 17:10:36 GMT Ralf Corsepius [1f64ebf] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-newlib.m4 (modified) * cpukit/aclocal/sysv-ipc.m4 (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 17:05:34 GMT Ralf Corsepius [86f12bc] * ChangeLog (modified) * aclocal/check-newlib.m4 (modified) * automake/compile.am (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 14:55:56 GMT Ralf Corsepius [20d7ed37] * ChangeLog (modified) * Makefile.am (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 14:54:45 GMT Ralf Corsepius [984123f] * ChangeLog (modified) * aclocal/sysv-ipc.m4 (deleted) * aclocal/target.m4 (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 14:17:00 GMT Ralf Corsepius [9e4d710] * ChangeLog (modified) * acinclude.m4 (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 00:31:31 GMT Ralf Corsepius [824bf2e4] * ChangeLog (modified) * aclocal/target.m4 (modified) 2002-11-18 Ralf Corsepius * ... Mon, 18 Nov 2002 23:55:24 GMT Ralf Corsepius [97831b7] * cpukit/ChangeLog (modified) * cpukit/include/rtems/libio_.h (deleted) 2002-11-18 Ralf Corsepius * ... Mon, 18 Nov 2002 23:53:14 GMT Ralf Corsepius [6c39eca4] * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/configure.ac (modified) 2002-11-18 Ralf Corsepius * ... Mon, 18 Nov 2002 13:57:55 GMT Joel Sherrill [5395172] * ChangeLog (modified) * VERSION (modified) 2002-11-18 Joel Sherrill * VERSION: ... Mon, 18 Nov 2002 13:57:54 GMT Joel Sherrill [b5a59c3f] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-11-18 Joel Sherrill * ... Mon, 18 Nov 2002 03:38:46 GMT Joel Sherrill [cf3d0ac0] * make/ChangeLog (modified) * make/custom/mtx603e.cfg (added) 2002-11-17 Greg Menke * ... Mon, 18 Nov 2002 03:31:27 GMT Joel Sherrill [174eed8c] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) 2002-11-17 Joel Sherrill * ... Mon, 18 Nov 2002 03:22:09 GMT Joel Sherrill [5d740bb] * c/src/lib/libbsp/powerpc/shared/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.c (modified) 2002-11-17 Greg Menke * ... Mon, 18 Nov 2002 03:07:54 GMT Joel Sherrill [3ae9de1] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/README.mtx603e (added) 002-11-17 Greg Menke * ... Mon, 18 Nov 2002 02:55:01 GMT Ralf Corsepius [bcf4d5bc] * ChangeLog (modified) * acinclude.m4 (modified) * configure.ac (modified) 2002-11-18 Ralf Corsepius * ... Mon, 18 Nov 2002 02:36:06 GMT Ralf Corsepius [f934a9d6] * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/configure.ac (modified) 2002-11-18 Ralf Corsepius * ... Mon, 18 Nov 2002 02:21:19 GMT Ralf Corsepius [9eadce0] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) 2002-11-18 Ralf Corsepius * ... Mon, 18 Nov 2002 00:52:17 GMT Joel Sherrill [5d81ce9] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bsp_specs (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/linkcmds (modified) 2002-11-14 Greg Menke * ... Mon, 18 Nov 2002 00:43:55 GMT Joel Sherrill [69efcbc1] * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/network/network.c (modified) 2002-11-17 Joel Sherrill * ... Mon, 18 Nov 2002 00:43:21 GMT Joel Sherrill [db28d621] * c/src/make/ChangeLog (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) 2002-11-17 Joel Sherrill * ... Mon, 18 Nov 2002 00:42:53 GMT Joel Sherrill [c2646c8] * make/ChangeLog (modified) * make/compilers/gcc-target-default.cfg (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) 2002-11-17 Joel Sherrill * ... Fri, 15 Nov 2002 15:00:13 GMT Ralf Corsepius [789a953] * cpukit/automake/compile.am (modified) 2002-11-15 Ralf Corsepius * ... Fri, 15 Nov 2002 14:55:12 GMT Ralf Corsepius [471bcf0] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (deleted) * cpukit/libnetworking/configure.ac (modified) * cpukit/libnetworking/machine/Makefile.am (deleted) * cpukit/libnetworking/sys/Makefile.am (deleted) * cpukit/libnetworking/vm/Makefile.am (deleted) 2002-11-15 Ralf Corsepius * ... Fri, 15 Nov 2002 14:50:44 GMT Ralf Corsepius [2d3c472b] * cpukit/ChangeLog (modified) * cpukit/include/rtems/userenv.h (modified) 2002-11-15 Ralf Corsepius * ... Fri, 15 Nov 2002 14:45:37 GMT Ralf Corsepius [8a2e2aaa] * ChangeLog (modified) * automake/compile.am (modified) 2002-11-15 Ralf Corsepius * ... Fri, 15 Nov 2002 14:41:54 GMT Ralf Corsepius [e9fc7e5] * ChangeLog (modified) * bootstrap (modified) 2002-11-15 Ralf Corsepius * ... Fri, 15 Nov 2002 14:41:06 GMT Ralf Corsepius [69b2703] * c/src/lib/libbsp/m68k/shared/gdbstub/ChangeLog (modified) * c/src/lib/libbsp/m68k/shared/gdbstub/Makefile.am (modified) 2002-11-15 Ralf Corsepius * ... Fri, 15 Nov 2002 14:28:55 GMT Ralf Corsepius [c9dcf77c] * make/ChangeLog (modified) * make/custom/Cygwin-posix.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) 2002-11-15 Ralf Corsepius * ... Fri, 15 Nov 2002 14:18:28 GMT Ralf Corsepius [f1c22e0] * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/src/diskdevs.c (modified) 2002-11-15 Ralf Corsepius * ... Fri, 15 Nov 2002 14:17:09 GMT Ralf Corsepius [1417e2b4] * cpukit/ChangeLog (modified) * cpukit/aclocal/prog-cc.m4 (modified) 2002-11-15 Ralf Corsepius * ... Fri, 15 Nov 2002 14:14:36 GMT Ralf Corsepius [cef22e87] * c/src/libmisc/ChangeLog (modified) * c/src/libmisc/monitor/mon-command.c (modified) * cpukit/libmisc/ChangeLog (modified) * cpukit/libmisc/monitor/mon-command.c (modified) 2002-11-15 Ralf Corsepius * ... Fri, 15 Nov 2002 14:13:01 GMT Ralf Corsepius [f289c09] * ChangeLog (modified) * acinclude.m4 (modified) * aclocal/prog-cc.m4 (modified) 2002-11-15 Ralf Corsepius * ... Fri, 15 Nov 2002 13:24:03 GMT Ralf Corsepius [b04b5ca7] * scripts/ChangeLog (modified) * scripts/autotools/autoconf-rtems.spec.in (modified) 2002-11-15 Ralf Corsepius * ... Thu, 14 Nov 2002 18:31:49 GMT Joel Sherrill [1d6e0f99] * cpukit/score/ChangeLog (modified) * cpukit/score/macros/rtems/score/object.inl (modified) 2002-11-14 Joel Sherrill * ... Thu, 14 Nov 2002 17:36:48 GMT Joel Sherrill [6da99727] * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/psxtests/psx01/psx01.scn (modified) * c/src/tests/psxtests/psx02/psx02.scn (modified) * c/src/tests/psxtests/psx03/psx03.scn (modified) * c/src/tests/psxtests/psx04/psx04.scn (modified) * c/src/tests/psxtests/psx05/psx05.scn (modified) * c/src/tests/psxtests/psx06/psx06.scn (modified) * c/src/tests/psxtests/psx07/psx07.scn (modified) * c/src/tests/psxtests/psx08/psx08.scn (modified) * c/src/tests/psxtests/psx09/psx09.scn (modified) * c/src/tests/psxtests/psx10/psx10.scn (modified) * c/src/tests/psxtests/psx11/psx11.scn (modified) * c/src/tests/psxtests/psx12/psx12.scn (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psx01/psx01.scn (modified) * testsuites/psxtests/psx02/psx02.scn (modified) * testsuites/psxtests/psx03/psx03.scn (modified) * testsuites/psxtests/psx04/psx04.scn (modified) * testsuites/psxtests/psx05/psx05.scn (modified) * testsuites/psxtests/psx06/psx06.scn (modified) * testsuites/psxtests/psx07/psx07.scn (modified) * testsuites/psxtests/psx08/psx08.scn (modified) * testsuites/psxtests/psx09/psx09.scn (modified) * testsuites/psxtests/psx10/psx10.scn (modified) * testsuites/psxtests/psx11/psx11.scn (modified) * testsuites/psxtests/psx12/psx12.scn (modified) 2002-11-14 Joel Sherrill * ... Thu, 14 Nov 2002 17:36:14 GMT Joel Sherrill [afcd563] * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/sp02/sp02.scn (modified) * c/src/tests/sptests/sp15/sp15.scn (modified) * c/src/tests/sptests/sp16/sp16.scn (modified) * c/src/tests/sptests/sp20/sp20.scn (modified) * c/src/tests/sptests/sp22/sp22.scn (modified) * c/src/tests/sptests/sp23/sp23.scn (modified) * c/src/tests/sptests/sp25/sp25.scn (modified) * c/src/tests/sptests/sp31/sp31.scn (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp02/sp02.scn (modified) * testsuites/sptests/sp15/sp15.scn (modified) * testsuites/sptests/sp16/sp16.scn (modified) * testsuites/sptests/sp20/sp20.scn (modified) * testsuites/sptests/sp22/sp22.scn (modified) * testsuites/sptests/sp23/sp23.scn (modified) * testsuites/sptests/sp25/sp25.scn (modified) * testsuites/sptests/sp31/sp31.scn (modified) 2002-11-14 Joel Sherrill * ... Thu, 14 Nov 2002 13:04:05 GMT Ralf Corsepius [6184265d] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2002-11-14 Ralf Corsepius * ... Thu, 14 Nov 2002 12:13:26 GMT Ralf Corsepius [22b689b] * c/src/libmisc/ChangeLog (modified) * c/src/libmisc/capture/Makefile.am (modified) * c/src/libmisc/configure.ac (modified) * c/src/libmisc/serdbg/Makefile.am (modified) * c/src/libmisc/serdbg/serdbgio.c (modified) * c/src/libmisc/shell/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * cpukit/libmisc/ChangeLog (modified) * cpukit/libmisc/capture/Makefile.am (modified) * cpukit/libmisc/configure.ac (modified) * cpukit/libmisc/serdbg/Makefile.am (modified) * cpukit/libmisc/serdbg/serdbgio.c (modified) * cpukit/libmisc/shell/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) 2002-11-14 Ralf Corsepius * ... Thu, 14 Nov 2002 01:47:12 GMT Ralf Corsepius [6a31b7c0] * ChangeLog (modified) * acinclude.m4 (modified) 2002-11-13 Ralf Corsepius * ...
