# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/03/24 05:41:26 Mon, 13 Aug 2018 10:25:51 GMT Amaan Cheval [6eccd0c] * bsps/x86_64/amd64/start/linkcmds (modified) bsps/x86_64: Reduce default RamSize to 1GiB Simulators may not ... Mon, 13 Aug 2018 10:21:47 GMT Amaan Cheval [ab971bf5] * bsps/x86_64/amd64/config/amd64.cfg (modified) * cpukit/score/cpu/x86_64/headers.am (modified) * cpukit/score/cpu/x86_64/include/rtems/asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (modified) * cpukit/score/cpu/x86_64/x86_64-context-switch.S (modified) bsps/x86_64: Reorganize header files and compile-options Updates #2898. Fri, 10 Aug 2018 13:23:01 GMT Joel Sherrill [382d653] * testsuites/libtests/POSIX/close.c (modified) * testsuites/libtests/POSIX/dup2.c (modified) * testsuites/libtests/POSIX/fcntl.c (modified) * testsuites/libtests/POSIX/flockfile.c (modified) * testsuites/libtests/POSIX/fork.c (modified) * testsuites/libtests/POSIX/free.c (modified) * testsuites/libtests/POSIX/fstat.c (modified) * testsuites/libtests/POSIX/ftrylockfile.c (modified) * testsuites/libtests/POSIX/funlockfile.c (modified) * testsuites/libtests/POSIX/getdents.c (modified) * testsuites/libtests/POSIX/getlogin.c (modified) * testsuites/libtests/POSIX/getpwnam.c (modified) * testsuites/libtests/POSIX/getpwuid.c (modified) * testsuites/libtests/POSIX/gettimeofday.c (modified) * testsuites/libtests/POSIX/getuid.c (modified) * testsuites/libtests/POSIX/htonl.c (modified) * testsuites/libtests/POSIX/iconv.c (modified) * testsuites/libtests/POSIX/iconv_close.c (modified) * testsuites/libtests/POSIX/iconv_open.c (modified) * testsuites/libtests/POSIX/issetugid.c (modified) * testsuites/libtests/POSIX/kill.c (modified) * testsuites/libtests/POSIX/longjmp.c (modified) * testsuites/libtests/POSIX/lseek.c (modified) * testsuites/libtests/POSIX/lstat.c (modified) * testsuites/libtests/POSIX/malloc.c (modified) * testsuites/libtests/POSIX/nanosleep.c (modified) * testsuites/libtests/POSIX/open.c (modified) * testsuites/libtests/POSIX/pipe.c (modified) * testsuites/libtests/POSIX/posix_memalign.c (modified) * testsuites/libtests/POSIX/read.c (modified) * testsuites/libtests/POSIX/readv.c (modified) * testsuites/libtests/POSIX/realloc.c (modified) * testsuites/libtests/POSIX/setjmp.c (modified) * testsuites/libtests/POSIX/sigaddset.c (modified) * testsuites/libtests/POSIX/sigdelset.c (modified) * testsuites/libtests/POSIX/sigemptyset.c (modified) * testsuites/libtests/POSIX/sigfillset.c (modified) * testsuites/libtests/POSIX/sigismember.c (modified) * testsuites/libtests/POSIX/sigprocmask.c (modified) * testsuites/libtests/POSIX/stat.c (modified) * testsuites/libtests/POSIX/unlink.c (modified) * testsuites/libtests/POSIX/vfork.c (modified) * testsuites/libtests/POSIX/wait.c (modified) * testsuites/libtests/POSIX/waitpid.c (modified) * testsuites/libtests/POSIX/write.c (modified) * testsuites/libtests/POSIX/writev.c (modified) libtests/POSIX: Fix warnings and style. Fri, 10 Aug 2018 13:22:49 GMT Joel Sherrill [b3693f5] * bsps/sparc/include/bsp/gradcdac.h (modified) bsps/sparc/include/bsp/gradcdac.h: Fix nested comment warning Fri, 10 Aug 2018 13:22:02 GMT Joel Sherrill [d071d9a] * bsps/powerpc/qoriq/include/tm27.h (modified) qoriq/include/tm27.h: Fix prototype warning Fri, 10 Aug 2018 13:21:36 GMT Joel Sherrill [ebd1937] * bsps/powerpc/motorola_powerpc/include/tm27.h (modified) motorola_powerpc/include/tm27.h: Fix prototype warning Fri, 10 Aug 2018 13:21:09 GMT Joel Sherrill [3cff531f] * bsps/powerpc/include/mpc83xx/mpc83xx.h (modified) bsps/powerpc/include/mpc83xx/mpc83xx.h: Fix nested comment warning Fri, 10 Aug 2018 13:20:38 GMT Joel Sherrill [5896da4] * bsps/powerpc/include/bsp/tictac.h (modified) bsps/powerpc/include/bsp/tictac.h: Fix protototype warnings Fri, 10 Aug 2018 13:20:07 GMT Joel Sherrill [ae4fbf3b] * bsps/powerpc/gen83xx/include/tm27.h (modified) gen83xx/include/tm27.h: Fix prototype warning Fri, 10 Aug 2018 13:19:40 GMT Joel Sherrill [ec8c955d] * bsps/powerpc/gen5200/include/tm27.h (modified) gen5200/include/tm27.h: Fix prototype warning Fri, 10 Aug 2018 13:18:59 GMT Joel Sherrill [7de51829] * bsps/powerpc/gen5200/include/bsp/ata.h (modified) gen5200/include/bsp/ata.h: Fix warning Fri, 10 Aug 2018 13:18:40 GMT Joel Sherrill [0fc87d47] * bsps/arm/csb337/include/at91rm9200_dbgu.h (modified) csb337/include/at91rm9200_dbgu.h: Fix nested comment warning Mon, 06 Aug 2018 09:53:42 GMT Sebastian Huber [b2de426] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/score/address.h (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) score: Fix _Addresses_Subtract() Use architecture-specific integer ... Mon, 06 Aug 2018 08:51:00 GMT Sebastian Huber [66cb142] * cpukit/include/rtems/rtems/part.h (modified) * cpukit/rtems/src/partcreate.c (modified) rtems: Parameter types in rtems_partition_create() Use uintptr_t to ... Fri, 10 Aug 2018 05:11:56 GMT Sebastian Huber [b8eae140] * cpukit/include/sys/priority.h (modified) Add dummy PRI_MIN_KERN to Update #3472. Fri, 10 Aug 2018 05:10:20 GMT Sebastian Huber [0e6f7dc4] * bsps/sparc/include/bsp/apbuart_termios.h (modified) bsps/sparc: Fix external variable declarations Thu, 09 Aug 2018 07:20:33 GMT Sebastian Huber [f4424cfb] * bsps/sparc/include/bsp/apbuart.h (modified) * bsps/sparc/include/bsp/apbuart_termios.h (modified) * bsps/sparc/leon3/console/printk_support.c (modified) * bsps/sparc/shared/uart/apbuart_cons.c (modified) * bsps/sparc/shared/uart/apbuart_polled.c (added) * bsps/sparc/shared/uart/apbuart_termios.c (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps/sparc: Move polled APBUART functions This reduces the ... Wed, 08 Aug 2018 09:17:36 GMT Sebastian Huber [aac36d15] * cpukit/configure.ac (modified) * cpukit/posix/src/mprotect.c (modified) posix: Add configure check for mprotect() Update #3491. Mon, 06 Aug 2018 08:29:14 GMT Christian Mauderer [8e6cfcc] * bsps/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Fix handling of slow SPI speeds. This patch fixes an ... Wed, 08 Aug 2018 05:52:18 GMT Sebastian Huber [71948f76] * cpukit/include/sys/event.h (modified) sys/event.h: Update version FreeBSD tag Update #3472. Wed, 18 Jul 2018 13:04:03 GMT dab [ac824ff] * cpukit/include/sys/event.h (modified) Make the definition of struct kevent in event.h match what the man ... Wed, 11 Jul 2018 02:09:11 GMT dab [96b32773] * cpukit/include/sys/event.h (modified) Address some (although not all) style(9) issues in event.h after ... Thu, 28 Jun 2018 20:37:17 GMT dab [1d00acb1] * cpukit/include/sys/event.h (modified) Fix compilation error in r335765 under gcc 4.2.1. The anonymous ... Thu, 28 Jun 2018 17:01:04 GMT dab [b37ef68] * cpukit/include/sys/event.h (modified) Remove potential identifier conflict in the EV_SET macro. PR43905 ... Mon, 27 Nov 2017 15:01:59 GMT pfg [bf026dd4] * cpukit/include/sys/event.h (modified) sys/sys: further adoption of SPDX licensing ID tags. Mainly focus ... Sat, 25 Nov 2017 04:49:12 GMT jhb [57c03363] * cpukit/include/sys/event.h (modified) Decode kevent structures logged via ktrace(2) in kdump. - Add a new ... Sat, 17 Jun 2017 00:57:26 GMT kib [e9b708a] * cpukit/include/sys/event.h (modified) Add abstime kqueue(2) timers and expand struct kevent members. This ... Sat, 08 Apr 2017 04:34:18 GMT pkelsey [f51aec8] * cpukit/include/sys/event.h (modified) Fix typo. hist -> hint MFC after: 3 days Tue, 07 Aug 2018 04:25:47 GMT Sebastian Huber [fd27bae] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/posix/pthread.h (modified) * cpukit/include/rtems/posix/pthreadimpl.h (modified) * testsuites/psxtests/psxconfig01/init.c (modified) CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE Make ... Tue, 07 Aug 2018 05:09:55 GMT Sebastian Huber [97417bb] * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/devfs04/init.c (modified) * testsuites/libtests/deviceio01/init.c (modified) * testsuites/libtests/ftp01/init.c (modified) * testsuites/libtests/networking01/init.c (modified) * testsuites/libtests/termios03/init.c (modified) * testsuites/libtests/termios04/init.c (modified) * testsuites/libtests/termios05/init.c (modified) * testsuites/libtests/termios07/init.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/sptests/spheapprot/init.c (modified) * testsuites/sptests/spmkdir/init.c (modified) * testsuites/sptests/spnsext01/init.c (modified) tests: Remove CONFIGURE_MAXIMUM_DRIVERS This configuration is ... Sat, 04 Aug 2018 08:38:48 GMT Sebastian Huber [0b038bd4] * cpukit/include/rtems/blkdev.h (modified) * cpukit/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libblock/src/blkdev-ops.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/diskdevs.c (modified) * testsuites/libtests/block01/init.c (modified) * testsuites/libtests/block11/init.c (modified) libblock: Add RTEMS_DEPRECATED Close #3358. Mon, 06 Aug 2018 04:26:50 GMT Sebastian Huber [b152d33] * testsuites/samples/fileio/init.c (modified) fileio: Avoid deprecated rtems_disk_obtain() Update #3358. Sat, 04 Aug 2018 08:56:46 GMT Sebastian Huber [ab96aec] * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) dosfs: Avoid deprecated routine Update #3358. Sat, 04 Aug 2018 08:47:56 GMT Sebastian Huber [dd66fda] * testsuites/fstests/fsdosfsformat01/init.c (modified) * testsuites/fstests/fsdosfssync01/init.c (modified) * testsuites/fstests/fsdosfswrite01/init.c (modified) * testsuites/libtests/block11/init.c (modified) * testsuites/libtests/block16/init.c (modified) * testsuites/libtests/sparsedisk01/init.c (modified) tests: Avoid deprecated rtems_disk_io_initialize() Update #3358. Sat, 04 Aug 2018 08:45:19 GMT Sebastian Huber [1836c6a] * bsps/powerpc/gen5200/ata/ata-instance.c (modified) bsp/gen5200: Avoid deprecated routine Update #3358. Fri, 03 Aug 2018 20:53:40 GMT Sebastian Huber [f7cecc33] * bsps/include/libchip/ata_internal.h (modified) * bsps/shared/dev/ide/ata.c (modified) libchip/ata: Use rtems_blkdev_create() Update #3358. Fri, 03 Aug 2018 20:39:42 GMT Sebastian Huber [698093d] * cpukit/include/rtems/ide_part_table.h (modified) * cpukit/libblock/src/ide_part_table.c (modified) libblock: Use rtems_blkdev_create_partition() Update #3358. Fri, 03 Aug 2018 20:30:55 GMT Sebastian Huber [bf80279] * testsuites/libtests/block15/init.c (modified) libtests/block15: Use rtems_blkdev_create() Update #3358. Fri, 03 Aug 2018 20:28:31 GMT Sebastian Huber [fa12e06d] * testsuites/libtests/block14/init.c (modified) libtests/block14: Use rtems_blkdev_create() Update #3358. Fri, 03 Aug 2018 20:25:40 GMT Sebastian Huber [3278d20] * testsuites/libtests/block13/init.c (modified) libtests/block13: Use rtems_blkdev_create() Update #3358. Fri, 03 Aug 2018 20:21:20 GMT Sebastian Huber [5e4bab7] * testsuites/libtests/block12/init.c (modified) libtests/block12: Use rtems_blkdev_create() Update #3358. Fri, 03 Aug 2018 20:16:32 GMT Sebastian Huber [6f34f13] * testsuites/libtests/block10/init.c (modified) libtests/block10: Use rtems_blkdev_create() Update #3358. Fri, 03 Aug 2018 19:19:19 GMT Sebastian Huber [5005bfc] * testsuites/libtests/block09/init.c (modified) libtests/block09: Use rtems_blkdev_create() Update #3358. Fri, 03 Aug 2018 16:18:56 GMT Sebastian Huber [117f7b1] * testsuites/libtests/block08/bdbuf_tests.c (modified) * testsuites/libtests/block08/bdbuf_tests.h (modified) * testsuites/libtests/block08/system.h (modified) * testsuites/libtests/block08/test_disk.c (modified) libtests/block08: Use rtems_blkdev_create() Update #3358. Wed, 01 Aug 2018 04:38:41 GMT Sebastian Huber [bde8be2] * testsuites/libtests/block06/block06.scn (modified) * testsuites/libtests/block06/init.c (modified) libtests/block06: Use rtems_blkdev_create() Update #3358. Sat, 04 Aug 2018 12:24:05 GMT Sebastian Huber [6782771] * testsuites/libtests/block05/init.c (modified) libtests/block05: Avoid uninitialized variable Update #3358. Wed, 01 Aug 2018 04:14:14 GMT Sebastian Huber [d279e74] * bsps/arm/smdk2410/smc/smc.c (modified) bsp/smdk2410: Use rtems_blkdev_create() Update #3358. Tue, 31 Jul 2018 14:05:49 GMT Sebastian Huber [1dec54f9] * bsps/lm32/shared/milkymist_memcard/memcard.c (modified) bsps/lm32: Use rtems_blkdev_create() Update #3358. Tue, 31 Jul 2018 14:01:17 GMT Sebastian Huber [0fe7133] * cpukit/libblock/src/flashdisk.c (modified) * testsuites/libtests/flashdisk01/init.c (modified) flashdisk: Use rtems_blkdev_create() Update #3358. Tue, 31 Jul 2018 13:54:29 GMT Sebastian Huber [16f3f10] * cpukit/libblock/src/nvdisk.c (modified) * testsuites/samples/fileio/init.c (modified) * testsuites/samples/fileio/system.h (modified) nvdisk: Use rtems_blkdev_create() Update #3358. Mon, 30 Jul 2018 04:39:09 GMT Sebastian Huber [24b94c4] * cpukit/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/ramdisk-config.c (modified) * cpukit/libblock/src/ramdisk-register.c (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) * testsuites/fstests/mdosfs_support/fs_support.c (modified) * testsuites/fstests/mrfs_support/fs_support.c (modified) * testsuites/fstests/support/ramdisk_support.c (modified) * testsuites/libtests/block01/init.c (modified) * testsuites/libtests/block02/init.c (modified) * testsuites/libtests/block03/init.c (modified) * testsuites/libtests/block04/init.c (modified) * testsuites/libtests/block07/init.c (modified) * testsuites/samples/fileio/init.c (modified) ramdisk: Use rtems_blkdev_create() Update #3358. Sat, 04 Aug 2018 12:27:38 GMT Sebastian Huber [d56e68b] * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) rfs: Remove erroneous call of rtems_disk_release() The function ... Fri, 03 Aug 2018 12:03:39 GMT Sebastian Huber [32ccc01] * bsps/shared/irq-sources.am (modified) * bsps/shared/irq/irq-generic.c (modified) * bsps/shared/irq/irq-lock.c (added) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) bsps: Fix the generic IRQ support The genmcf548x partly uses is own ... Fri, 03 Aug 2018 05:58:07 GMT Sebastian Huber [42f9963d] * cpukit/include/rtems/score/basedefs.h (modified) score: Remove superfluous semicolon This avoids warnings like this: ... Thu, 02 Aug 2018 12:52:12 GMT Sebastian Huber [83ca9f0a] * cpukit/rtems/src/partcreate.c (modified) rtems: Relax partition buffer area alignment The partition buffer ... Thu, 02 Aug 2018 12:49:01 GMT Sebastian Huber [27bbc05] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) score: Remove CPU_PARTITION_ALIGNMENT Use the CPU_SIZEOF_POINTER ... Thu, 02 Aug 2018 11:23:26 GMT Sebastian Huber [141d502] * bsps/riscv/riscv/config/rv32imafdc.cfg (added) bsp/riscv: Add missing BSP variant Update #3433. Thu, 02 Aug 2018 12:13:25 GMT Sebastian Huber [4c740de] * bsps/riscv/riscv/include/bsp/riscv.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspstart.c (modified) bsp/riscv: Fix build with RTEMS_SMP undefined Update #3433. Thu, 02 Aug 2018 07:41:08 GMT Sebastian Huber [28b8cf9b] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Fix CPU_ALIGNMENT Update #3433. Wed, 01 Aug 2018 08:06:37 GMT Sebastian Huber [3d11c1e] * bsps/riscv/riscv/irq/irq.c (modified) bsp/riscv: Fix a synchronization issue for PLIC Update #3433. Wed, 01 Aug 2018 09:15:55 GMT Sebastian Huber [dee2ebb] * bsps/riscv/riscv/irq/irq.c (modified) bsp/riscv: Remove unused variable Update #3433. Wed, 01 Aug 2018 06:13:39 GMT Sebastian Huber [56b0387] * bsps/riscv/riscv/console/console-config.c (modified) bsp/riscv: Add NS16750 support to console driver Update #3433. Tue, 31 Jul 2018 09:38:56 GMT Sebastian Huber [a7cd4b73] * bsps/include/libchip/ns16550.h (modified) * bsps/shared/dev/serial/ns16550-context.c (modified) serial/ns16550: Precision clock synthesizer Set the FIFO control ... Tue, 31 Jul 2018 08:45:41 GMT Sebastian Huber [8a78b784] * bsps/shared/dev/serial/ns16550-context.c (modified) serial/ns16550: Use standard register names Use the standard ... Tue, 31 Jul 2018 07:15:00 GMT Sebastian Huber [529154b] * bsps/riscv/riscv/start/start.S (modified) bsp/riscv: Initialize FPU depending on ISA Initialize fcsr to zero ... Tue, 31 Jul 2018 05:19:33 GMT Sebastian Huber [48cbd63] * bsps/riscv/riscv/clock/clockdrv.c (modified) bsp/riscv: Fix clock driver Do not assume that mtime is zero at ... Wed, 01 Aug 2018 05:41:49 GMT Sebastian Huber [71284ce] * bsps/sparc/shared/start/start.S (modified) bsps/sparc: Fix typo in start.S Fix typo in start.S introduced by ... Mon, 30 Jul 2018 05:51:39 GMT Sebastian Huber [d906ce3] * testsuites/libtests/dl01/init.c (modified) * testsuites/libtests/dl02/init.c (modified) * testsuites/libtests/dl03/init.c (modified) * testsuites/libtests/dl04/init.c (modified) * testsuites/libtests/dl05/init.c (modified) * testsuites/libtests/dl06/init.c (modified) * testsuites/libtests/flashdisk01/init.c (modified) libtests: Use CONFIGURE_INIT_TASK_TABLE_SIZE Using ... Mon, 30 Jul 2018 05:35:26 GMT Sebastian Huber [334e1d2] * cpukit/include/rtems/confdefs.h (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) confdefs: Fix uniprocessor configuration Introduce a new internal ... Fri, 27 Jul 2018 13:04:38 GMT Sebastian Huber [44c2d393] * bsps/riscv/riscv/irq/irq.c (modified) bsp/riscv: Fix inter-processor interrupts The previous version ... Fri, 27 Jul 2018 12:47:17 GMT Sebastian Huber [cfc9573] * bsps/riscv/riscv/clock/clockdrv.c (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-counter.S (added) riscv: Rework CPU counter support Update #3433. Wed, 25 Jul 2018 09:25:30 GMT Sebastian Huber [65f52d0] * testsuites/samples/minimum/init.c (modified) samples/minimum: Use default interrupt stack size Update #3433. Tue, 24 Jul 2018 12:47:05 GMT Sebastian Huber [581a0f88] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/console/console-config.c (modified) bsp/riscv: Use interrupt driven NS16550 driver Update #3433. Tue, 24 Jul 2018 11:27:54 GMT Sebastian Huber [adede135] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/include/bsp.h (modified) * bsps/riscv/riscv/include/bsp/irq.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspsmp.c (modified) bsp/riscv: Add PLIC support Update #3433. Mon, 23 Jul 2018 11:50:02 GMT Sebastian Huber [bd560386] * bsps/riscv/riscv/clock/clockdrv.c (modified) bsp/riscv: Add simple SMP support to clock driver This is a hack. ... Tue, 24 Jul 2018 08:10:12 GMT Sebastian Huber [6552ba8] * bsps/riscv/riscv/btimer/btimer.c (deleted) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsp/riscv: Use CPU counter btimer Update #3433. Fri, 20 Jul 2018 11:11:04 GMT Sebastian Huber [447fd89] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/include/bsp/riscv.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspsmp.c (added) * bsps/riscv/riscv/start/bspstart.c (modified) * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsp/riscv: Add basic SMP startup Update #3433. Fri, 20 Jul 2018 08:57:59 GMT Sebastian Huber [6b9ef09] * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/headers.am (modified) * bsps/riscv/riscv/include/dev/irq/clint.h (deleted) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) riscv: Add CLINT and PLIC support The CLINT and PLIC need some ... Fri, 20 Jul 2018 07:07:40 GMT Sebastian Huber [c2670de] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Use wfi instruction for idle task Update #3433. Thu, 19 Jul 2018 13:12:11 GMT Sebastian Huber [f5fd8eb] * bsps/riscv/include/bsp/linker-symbols.h (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsps/riscv: Update linker-symbols.h Update #3433. Thu, 19 Jul 2018 12:45:47 GMT Sebastian Huber [dda6e06] * bsps/riscv/riscv/start/bsp_fatal_halt.c (modified) bsp/riscv: Add reset via for SiFive Test Finisher Update #3433. Thu, 19 Jul 2018 12:38:44 GMT Sebastian Huber [3a263a9b] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/console/console-config.c (modified) * bsps/riscv/riscv/include/bsp/riscv.h (modified) * bsps/riscv/riscv/start/bspstart.c (modified) bsp/riscv: Add and use riscv_fdt_get_address() Update #3433. Thu, 19 Jul 2018 12:06:10 GMT Sebastian Huber [791d9ac5] * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Disable HTIF support by default The HTIF is a legacy ... Thu, 19 Jul 2018 11:58:12 GMT Sebastian Huber [7fe4855] * bsps/riscv/riscv/console/console-config.c (modified) * bsps/riscv/riscv/console/htif.c (modified) * bsps/riscv/riscv/headers.am (modified) * bsps/riscv/riscv/include/bsp/riscv.h (added) * bsps/riscv/riscv/start/bsp_fatal_halt.c (modified) bsp/riscv: Fix HTIF warnings Update #3433. Thu, 19 Jul 2018 10:11:19 GMT Sebastian Huber [8db3f0e] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/include/bsp/linker-symbols.h (modified) * bsps/riscv/riscv/btimer/btimer.c (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/include/bsp/irq.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspstart.c (moved) * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Rework exception handling Remove ... Thu, 19 Jul 2018 08:15:53 GMT Sebastian Huber [5694b0c] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-exception-frame-print.c (modified) riscv: New CPU_Exception_frame Use the CPU_Interrupt_frame for the ... Thu, 19 Jul 2018 07:35:54 GMT Sebastian Huber [d779a1e2] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Add exception codes Update #3433. Tue, 24 Jul 2018 07:09:06 GMT Sebastian Huber [5677883] * cpukit/include/rtems/score/smpimpl.h (modified) score: _SMP_Inter_processor_interrupt_handler() Optimize ... Tue, 24 Jul 2018 07:00:18 GMT Sebastian Huber [a1f7d7d] * cpukit/include/rtems/score/basedefs.h (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semtimedwait.c (modified) * cpukit/posix/src/semtrywait.c (modified) * cpukit/score/src/condition.c (modified) * cpukit/score/src/futex.c (modified) * cpukit/score/src/mutex.c (modified) * cpukit/score/src/semaphore.c (modified) * testsuites/sptests/spmisc01/init.c (modified) score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE() Add ... Tue, 24 Jul 2018 09:18:27 GMT Sebastian Huber [406dd62] * bsps/arm/include/bsp/arm-a9mpcore-start.h (modified) * bsps/arm/raspberrypi/start/bspsmp_init.c (modified) * bsps/i386/pc386/start/smp-imps.c (modified) * bsps/powerpc/qoriq/start/bspsmp.c (modified) * bsps/sparc/leon3/start/bspsmp.c (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) _SMP_Start_multitasking_on_secondary_processor() Pass current ... Tue, 24 Jul 2018 08:50:39 GMT Sebastian Huber [4678d1a] * bsps/include/bsp/bootcard.h (modified) * bsps/powerpc/qoriq/include/bsp.h (modified) * bsps/powerpc/qoriq/start/bspsmp.c (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/sparc/leon3/start/bspsmp.c (modified) * bsps/sparc/shared/start/start.S (modified) * testsuites/smptests/smpfatal08/init.c (modified) bsps: bsp_start_on_secondary_processor() Pass current processor ... Mon, 23 Jul 2018 12:54:51 GMT Sebastian Huber [0d362ff3] * bsps/arm/raspberrypi/irq/irq.c (modified) * bsps/arm/shared/start/arm-a9mpcore-smp.c (modified) * bsps/i386/pc386/start/smp-imps.c (modified) * bsps/powerpc/qoriq/irq/irq.c (modified) * bsps/powerpc/qoriq/start/bspsmp.c (modified) * bsps/sparc/leon3/start/bspsmp.c (modified) * cpukit/include/rtems/score/smpimpl.h (modified) score: _SMP_Inter_processor_interrupt_handler() Pass current ... Wed, 25 Jul 2018 06:00:22 GMT Sebastian Huber [f8d00a3] * cpukit/include/rtems/tm27-default.h (modified) tm27: Fix prototype warnings Wed, 25 Jul 2018 07:54:56 GMT Sebastian Huber [05259de1] * cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h (modified) powerpc: Fix _CPU_Instruction_illegal() Apparently the .word ... Tue, 24 Jul 2018 09:35:09 GMT Sebastian Huber [caccc5b] * bsps/arm/include/uart.h (modified) * bsps/include/bsp/VME.h (modified) * bsps/mips/malta/include/bsp/pci.h (modified) * bsps/powerpc/beatnik/include/bsp/bsp_bsdnet_attach.h (modified) * bsps/powerpc/haleakala/include/mmu_405.h (modified) * bsps/powerpc/include/bsp/flashPgmPvt.h (modified) * bsps/powerpc/include/bsp/pci.h (modified) * bsps/powerpc/motorola_powerpc/include/bsp.h (modified) * bsps/powerpc/mvme5500/include/bsp.h (modified) * bsps/powerpc/mvme5500/pci/pci.c (modified) bsps: Fix function declaration warnings Tue, 24 Jul 2018 09:56:25 GMT Sebastian Huber [91f39a5] * testsuites/smptests/smpschedaffinity01/init.c (modified) * testsuites/smptests/smpschedaffinity05/init.c (modified) smptests: Fix format warnings Tue, 24 Jul 2018 10:47:26 GMT Sebastian Huber [bf199e0c] * testsuites/libtests/block05/init.c (modified) block05: Remove unused variable Tue, 24 Jul 2018 10:46:32 GMT Sebastian Huber [bded3f05] * testsuites/psxtests/psxthreadname01/init.c (modified) psxthreadname01: Fix out of bounds memory access Tue, 24 Jul 2018 10:46:02 GMT Sebastian Huber [001b9925] * testsuites/psxtests/psxtimer02/psxtimer.c (modified) psxtimer02: Fix parameter type cast Tue, 24 Jul 2018 10:45:43 GMT Sebastian Huber [f133386] * testsuites/sptests/sp20/init.c (modified) sptests/sp20: Remove unused variable
