# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 23:46:38 Thu, 21 Aug 2014 14:57:47 GMT Pavel Pisa [66f1ca6] * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram-testsuite.tcfg (added) bsp/tms570: disable huge memory demanding tests for internal RAM ... Thu, 21 Aug 2014 13:38:24 GMT Pavel Pisa [46265063] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c (added) * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/arm/tms570/include/system-clocks.h (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg (modified) * c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c (added) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) bsp/tms570: implemented support functions to satisfy complete tests ... Wed, 20 Aug 2014 23:47:02 GMT Joel Sherrill [5787188] * cpukit/configure.ac (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Add configuration to detect toolset has sigaltstack() prototype Wed, 20 Aug 2014 22:08:23 GMT Peter Dufault [dc661c8] * c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c (modified) mpc55xx/misc/flash_support.c: Properly flush cache when writing. ... Wed, 20 Aug 2014 20:49:42 GMT Joel Sherrill [a7ec6fa] * doc/cpu_supplement/or1k.t (modified) or1k.t: Fix spelling errors Sat, 16 Aug 2014 16:30:19 GMT Hesham ALMatary [b088292] * doc/cpu_supplement/Makefile.am (modified) * doc/cpu_supplement/cpu_supplement.texi (modified) * doc/cpu_supplement/or1k.t (added) Add new documentation section for OpenRISC CPU architecture. Wed, 20 Aug 2014 19:53:18 GMT Joel Sherrill [2ed97d9] * c/src/lib/libbsp/arm/acinclude.m4 (modified) libbsp/arm/acinclude.m4: Regenerate for tms570 Wed, 20 Aug 2014 17:23:20 GMT Hesham ALMatary [fd57015] * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/or1k/Makefile.am (added) * c/src/lib/libbsp/or1k/acinclude.m4 (added) * c/src/lib/libbsp/or1k/configure.ac (added) * c/src/lib/libbsp/or1k/or1ksim/Makefile.am (added) * c/src/lib/libbsp/or1k/or1ksim/README (added) * c/src/lib/libbsp/or1k/or1ksim/bsp_specs (added) * c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c (added) * c/src/lib/libbsp/or1k/or1ksim/configure.ac (added) * c/src/lib/libbsp/or1k/or1ksim/console/console-config.c (added) * c/src/lib/libbsp/or1k/or1ksim/console/uart.c (added) * c/src/lib/libbsp/or1k/or1ksim/include/bsp.h (added) * c/src/lib/libbsp/or1k/or1ksim/include/irq.h (added) * c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h (added) * c/src/lib/libbsp/or1k/or1ksim/include/uart.h (added) * c/src/lib/libbsp/or1k/or1ksim/irq/irq.c (added) * c/src/lib/libbsp/or1k/or1ksim/make/custom/or1k_or1ksim.cfg (added) * c/src/lib/libbsp/or1k/or1ksim/preinstall.am (added) * c/src/lib/libbsp/or1k/or1ksim/start/start.S (added) * c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds (added) * c/src/lib/libbsp/or1k/or1ksim/timer/timer.c (added) * c/src/lib/libbsp/or1k/preinstall.am (added) * c/src/lib/libbsp/or1k/shared/include/linker-symbols.h (added) * c/src/lib/libbsp/or1k/shared/startup/linkcmds.base (added) Add new (first) OpenRISC BSP called or1ksim. This BSP is intended ... Wed, 20 Aug 2014 15:24:23 GMT Premysl Houdek [4407ee6] * c/src/lib/libbsp/arm/tms570/Makefile.am (added) * c/src/lib/libbsp/arm/tms570/README (added) * c/src/lib/libbsp/arm/tms570/bsp_specs (added) * c/src/lib/libbsp/arm/tms570/clock/clock.c (added) * c/src/lib/libbsp/arm/tms570/configure.ac (added) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (added) * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (added) * c/src/lib/libbsp/arm/tms570/include/bsp.h (added) * c/src/lib/libbsp/arm/tms570/include/irq.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-pom.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-rti.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-sci.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-vim.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570.h (added) * c/src/lib/libbsp/arm/tms570/irq/irq.c (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg (added) * c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c (added) * c/src/lib/libbsp/arm/tms570/preinstall.am (added) * c/src/lib/libbsp/arm/tms570/startup/bspreset.c (added) * c/src/lib/libbsp/arm/tms570/startup/bspstart.c (added) * c/src/lib/libbsp/arm/tms570/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk (added) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram (added) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram (added) BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137) ... Sat, 16 Aug 2014 14:15:17 GMT Pavel Pisa [0a66c126] * c/src/lib/libbsp/arm/lpc24xx/misc/io.c (modified) lpc24xx/lpc17xx: lpc24xx_pin_set_function() keep LPC4088 W type pin ... Tue, 19 Aug 2014 15:43:36 GMT Sebastian Huber [bba3507] * cpukit/score/src/coremutex.c (modified) * testsuites/sptests/sp51/init.c (modified) * testsuites/sptests/sp51/sp51.doc (modified) score: PR2179: Fix initially locked PI mutex Thu, 14 Aug 2014 15:02:29 GMT Kolja Waschk [3654667f] * cpukit/libcsupport/src/termios.c (modified) rtems_termios_puts: Copy and write more than one char at once ... Mon, 18 Aug 2014 21:06:46 GMT Hesham ALMatary [de62e5d8] * cpukit/score/cpu/or1k/rtems/score/or1k-utility.h (modified) Add or1k tick timer register definitions Thu, 14 Aug 2014 12:27:40 GMT Sebastian Huber [1a2d3497] * cpukit/score/cpu/arm/armv7m-context-switch.c (modified) arm: PR2186: Fix compile error Tue, 12 Aug 2014 18:46:49 GMT Joel Sherrill [700f97e] * cpukit/score/cpu/or1k/preinstall.am (added) or1k/.../preinstall.am: Add missing file Tue, 12 Aug 2014 15:57:42 GMT Hesham ALMatary [94d45f6] * cpukit/configure.ac (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/or1k/Makefile.am (added) * cpukit/score/cpu/or1k/cpu.c (added) * cpukit/score/cpu/or1k/or1k-context-initialize.c (added) * cpukit/score/cpu/or1k/or1k-context-switch.S (added) * cpukit/score/cpu/or1k/or1k-exception-default.c (added) * cpukit/score/cpu/or1k/or1k-exception-frame-print.c (added) * cpukit/score/cpu/or1k/or1k-exception-handler-low.S (added) * cpukit/score/cpu/or1k/rtems/asm.h (added) * cpukit/score/cpu/or1k/rtems/score/cpu.h (added) * cpukit/score/cpu/or1k/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/or1k/rtems/score/or1k-utility.h (added) * cpukit/score/cpu/or1k/rtems/score/or1k.h (added) * cpukit/score/cpu/or1k/rtems/score/types.h (added) Add support for OpenRISC - Fixed issues This work is based on the ... Sun, 10 Aug 2014 16:35:27 GMT Sebastian Huber [6cdc090] * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx.inc (added) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_ram.cfg (added) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_rom_int.cfg (added) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc40xx_ea_ram (added) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc40xx_ea_rom_int (added) bsp/lpc24xx: Add LPC40XX variants Sun, 10 Aug 2014 16:36:30 GMT Sebastian Huber [8ae37323] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/arm/armv7m-context-switch.c (modified) * cpukit/score/cpu/arm/armv7m-exception-default.c (modified) * cpukit/score/cpu/arm/armv7m-isr-dispatch.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Add support for FPv4-SP floating point unit This floating ... Tue, 15 Jul 2014 14:20:37 GMT Christian Mauderer [81329f9] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/README (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/rtc/rtc.c (added) bsp/altera-cyclone-v: Add RTC driver. Mon, 14 Jul 2014 14:33:52 GMT Christian Mauderer [3f9cd87d] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/README.txt (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_i2c.h (added) * c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_i2c.h (added) * c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/src/hwmgr/alt_i2c.c (added) * c/src/lib/libbsp/arm/altera-cyclone-v/i2c/i2cdrv-config.c (added) * c/src/lib/libbsp/arm/altera-cyclone-v/i2c/i2cdrv-config.h (added) * c/src/lib/libbsp/arm/altera-cyclone-v/i2c/i2cdrv.c (added) * c/src/lib/libbsp/arm/altera-cyclone-v/include/i2cdrv.h (added) * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (modified) bsp/altera-cyclone-v: Add a simple I2C driver. Fri, 18 Jul 2014 10:29:29 GMT Christian Mauderer [1642d27e] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (modified) bsp/altera-cyclone-v: Add socal from hwlib. Some of the headers ... Thu, 07 Aug 2014 17:41:25 GMT Sebastian Huber [0b9fe3ec] * testsuites/sptests/sprbtree01/init.c (modified) * testsuites/sptests/sprbtree01/sprbtree01.scn (modified) sptests/sprbtree01: Add random ops test case Thu, 24 Jul 2014 15:50:58 GMT Sebastian Huber [0ef6e3bf] * cpukit/score/src/rbtreeextract.c (modified) rbtree: Simplify _RBTree_Extract() Wed, 23 Jul 2014 11:03:54 GMT Sebastian Huber [993f5ac] * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtreeimpl.h (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Simplify insert and extract Simplify _RBTree_Insert() and ... Wed, 23 Jul 2014 11:19:09 GMT Sebastian Huber [4752550f] * cpukit/score/include/rtems/score/rbtreeimpl.h (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Simplify _RBTree_Rotate() Add and use _RBTree_Direction(). Tue, 05 Aug 2014 12:07:07 GMT Sebastian Huber [d472d21] * testsuites/sptests/sprbtree01/init.c (modified) sptests/sprbtree01: Check tree layout Tue, 05 Aug 2014 11:52:45 GMT Sebastian Huber [888edf6] * testsuites/sptests/sprbtree01/init.c (modified) sptests/sprbtree01: Reduce stack usage Sat, 02 Aug 2014 13:49:26 GMT Sebastian Huber [390cfcd] * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keysetspecific.c (modified) posix: Simplify key implementation Sun, 03 Aug 2014 11:02:58 GMT Sebastian Huber [60fe374] * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/sapi/include/rtems/rbheap.h (modified) * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtreeimpl.h (modified) * cpukit/score/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/rbtreefind.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/threadq.c (modified) * testsuites/libtests/rbheap01/init.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Add and use RBTree_Compare_result Sat, 02 Aug 2014 14:22:31 GMT Sebastian Huber [40dcafa] * cpukit/libblock/src/bdbuf.c (modified) * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keyfreememory.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/sapi/include/rtems/rbheap.h (modified) * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/resourceiterate.c (modified) * cpukit/score/src/schedulerchangeroot.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqdequeue.c (modified) * cpukit/score/src/threadqfirst.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) Add and use RTEMS_CONTAINER_OF() Tue, 22 Jul 2014 20:49:09 GMT Sebastian Huber [b767683a] * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * testsuites/sptests/sprbtree01/init.c (modified) * testsuites/sptests/sprbtree01/sprbtree01.scn (modified) rbtree: Rename find header in find control Simplify ... Tue, 22 Jul 2014 17:42:54 GMT Sebastian Huber [6e93c836] * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Simplify off-tree handling Only use the parent pointer, ... Sat, 26 Jul 2014 10:52:22 GMT Sebastian Huber [4cd55724] * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) * cpukit/posix/include/rtems/posix/muteximpl.h (modified) * cpukit/posix/include/rtems/posix/pthreadimpl.h (modified) * cpukit/posix/include/rtems/posix/rwlockimpl.h (modified) * cpukit/posix/include/rtems/posix/spinlockimpl.h (modified) * cpukit/posix/include/rtems/posix/timerimpl.h (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/include/rtems/rtems/regionimpl.h (modified) * cpukit/rtems/include/rtems/rtems/timerimpl.h (modified) * cpukit/sapi/include/rtems/extensionimpl.h (modified) * cpukit/score/include/rtems/score/chainimpl.h (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/include/rtems/score/rbtreeimpl.h (modified) Delete unused *_Is_null() functions Tue, 22 Jul 2014 12:50:07 GMT Sebastian Huber [639117f] * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/src/rbtreeinsert.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) * testsuites/sptests/sprbtree01/sprbtree01.scn (modified) rbtree: Update maximum node in LIFO order The test sptests/sp35 ... Wed, 23 Jul 2014 20:39:17 GMT Joel Sherrill [9113798c] * cpukit/score/include/rtems/score/todimpl.h (modified) todimpl.h: Add missing Doxygen Wed, 23 Jul 2014 20:37:03 GMT Joel Sherrill [0a84c298] * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodget.c (modified) * cpukit/score/src/coretodgetuptimetimespec.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/coretodtickspersec.c (modified) coretod*.c: Fix Doxygen group and comment formatting Wed, 23 Jul 2014 20:35:35 GMT Joel Sherrill [875fff0a] * cpukit/posix/src/adjtime.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/todimpl.h (modified) * cpukit/score/src/coretodadjust.c (added) * testsuites/psxtests/psxtime/psxtime.scn (modified) * testsuites/psxtests/psxtime/test.c (modified) Add _TOD_Adjust to SCORE TOD Handler. This lays the proper ... Sat, 19 Jul 2014 00:46:59 GMT Joel Sherrill [3b6352d] * cpukit/posix/src/adjtime.c (modified) adjtime.c: Use timestamp math and simplify Mon, 21 Jul 2014 16:29:00 GMT Sebastian Huber [8abbbdde] * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/src/rbtreeextract.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Do not set node off-tree in extract Mon, 21 Jul 2014 16:16:47 GMT Sebastian Huber [d7a94693] * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/src/rbtree.c (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Remove superfluous NULL pointer checks Mon, 21 Jul 2014 16:08:07 GMT Sebastian Huber [6b0a7efc] * cpukit/score/src/rbtree.c (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreefind.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreenext.c (modified) rbtree: Format Fri, 11 Jul 2014 11:29:53 GMT Sebastian Huber [87894c0] * doc/bsp_howto/console.t (modified) doc: Update console driver documentation Wed, 16 Jul 2014 20:45:49 GMT Joel Sherrill [742402b5] * c/src/lib/libbsp/m68k/gen68360/include/tm27.h (modified) m68k/gen68360/include/tm27.h: Correct comment Wed, 16 Jul 2014 20:43:05 GMT Joel Sherrill [6e868d87] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg (added) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram.tcfg (added) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx_stage_1-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f105rc-testsuite.tcfg (modified) * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim-testsuite.tcfg (modified) * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim-testsuite.tcfg (modified) * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf5206elite/make/custom/mcf5206elite-testsuite.tcfg (added) * c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136-testsuite.tcfg (added) * c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162-testsuite.tcfg (added) * c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx-testsuite.tcfg (added) Add More Testsuite Configuration Files and Update Existing Ones The ... Wed, 16 Jul 2014 00:45:32 GMT Chris Johns [6832a560] * c/src/lib/libbsp/arm/shared/include/arm-a8core-start.h (added) Common ARM A8 code. Wed, 09 Jul 2014 18:22:28 GMT Joel Sherrill [0ea6d07] * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadblockingoperationcancel.c (modified) * cpukit/score/src/threadqdequeue.c (modified) * cpukit/score/src/threadqextract.c (modified) Use Shared Method for Thread Unblock Cleanup When a thread is ... Tue, 15 Jul 2014 17:37:36 GMT Joel Sherrill [3250664] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadqdequeue.c (modified) * cpukit/score/src/threadqdequeuefifo.c (deleted) * cpukit/score/src/threadqdequeuepriority.c (deleted) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqenqueuefifo.c (deleted) * cpukit/score/src/threadqenqueuepriority.c (deleted) * cpukit/score/src/threadqextract.c (modified) * cpukit/score/src/threadqextractfifo.c (deleted) * cpukit/score/src/threadqextractpriority.c (deleted) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqfirstfifo.c (deleted) * cpukit/score/src/threadqfirstpriority.c (deleted) * cpukit/score/src/threadqrequeue.c (added) Thread Queue: Merge discipline subroutines into main methods There ... Mon, 07 Jul 2014 19:26:13 GMT Joel Sherrill [ed7a028] * cpukit/configure.ac (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqdequeuepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqenqueuepriority.c (modified) * cpukit/score/src/threadqextractpriority.c (modified) * cpukit/score/src/threadqfirstpriority.c (modified) Thread Queue Priority Discipline Reimplemented with RBTree Sat, 12 Jul 2014 19:22:22 GMT Sebastian Huber [64939bc] * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/posix/src/keyfreememory.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/sapi/src/rbheap.c (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/score/src/rbtree.c (modified) * cpukit/score/src/rbtreefind.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/scheduleredf.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Reduce RBTree_Control size Remove compare function and is ... Sat, 12 Jul 2014 19:22:21 GMT Sebastian Huber [7e119990] * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) rbtree: Delete unused functions Sat, 12 Jul 2014 22:04:19 GMT Ben Gras [7e60b7d] * c/src/lib/libbsp/shared/include/uart-output-char.h (modified) uart-output-char.h: extra offset definition. All, This patch is ... Mon, 07 Jul 2014 22:42:28 GMT Joel Sherrill [9ba76ed8] * testsuites/sptests/sp59/init.c (modified) * testsuites/sptests/sp59/sp59.scn (modified) sp59: Fix typos Mon, 07 Jul 2014 19:23:24 GMT Joel Sherrill [764e8b11] * cpukit/score/src/scheduleredfunblock.c (modified) scheduleredfunblock.c: Correct spacing Mon, 07 Jul 2014 19:22:57 GMT Joel Sherrill [3a01e8b] * cpukit/rtems/src/semdelete.c (modified) semdelete.c: Correct spacing Thu, 10 Jul 2014 19:20:39 GMT Joel Sherrill [b6343c6] * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm02/tm02.doc (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm03/tm03.doc (modified) * testsuites/tmtests/tm31/Makefile.am (added) * testsuites/tmtests/tm31/tm31.doc (added) * testsuites/tmtests/tm32/Makefile.am (added) * testsuites/tmtests/tm32/tm32.doc (added) * testsuites/tmtests/tm33/Makefile.am (added) * testsuites/tmtests/tm33/tm33.doc (added) * testsuites/tmtests/tm34/Makefile.am (added) * testsuites/tmtests/tm34/tm34.doc (added) * testsuites/tmtests/tm35/Makefile.am (added) * testsuites/tmtests/tm35/tm35.doc (added) * testsuites/tmtests/tm36/Makefile.am (added) * testsuites/tmtests/tm36/tm36.doc (added) * testsuites/tmtests/tmtests_plan.csv (modified) Enhance Semaphore Blocking and Readying Time Test Cases tm02 and ... Mon, 14 Jul 2014 18:12:31 GMT Jennifer Averett [648c86c] * testsuites/libtests/capture01/init.c (modified) capture01: Add include of assert.h. Thu, 10 Jul 2014 16:55:04 GMT Jennifer Averett [247118bf] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedsem01/Makefile.am (added) * testsuites/smptests/smpschedsem01/init.c (added) * testsuites/smptests/smpschedsem01/smpschedsem01.doc (added) * testsuites/smptests/smpschedsem01/smpschedsem01.scn (added) smpschedsem01: new test. This test verifies priority is inherited ... Thu, 10 Jul 2014 16:45:58 GMT Jennifer Averett [7eb3fd47] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedaffinity05/Makefile.am (added) * testsuites/smptests/smpschedaffinity05/init.c (added) * testsuites/smptests/smpschedaffinity05/smpschedaffinity05.doc (added) * testsuites/smptests/smpschedaffinity05/smpschedaffinity05.scn (added) smpschedaffinity05: Add test for worst case migration for affintiy ... Thu, 10 Jul 2014 16:36:40 GMT Jennifer Averett [61d26f93] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedaffinity04/Makefile.am (added) * testsuites/smptests/smpschedaffinity04/init.c (added) * testsuites/smptests/smpschedaffinity04/smpschedaffinity04.doc (added) * testsuites/smptests/smpschedaffinity04/smpschedaffinity04.scn (added) smpschedaffinity04: New test. This test walks a secondary high ... Thu, 10 Jul 2014 16:18:02 GMT Jennifer Averett [28d66749] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedaffinity03/Makefile.am (added) * testsuites/smptests/smpschedaffinity03/init.c (added) * testsuites/smptests/smpschedaffinity03/smpschedaffinity03.doc (added) * testsuites/smptests/smpschedaffinity03/smpschedaffinity03.scn (added) smpschedaffinity03: New test. This task walks the affinity of self ... Thu, 10 Jul 2014 15:19:06 GMT Jennifer Averett [09293069] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedaffinity02/Makefile.am (added) * testsuites/smptests/smpschedaffinity02/init.c (added) * testsuites/smptests/smpschedaffinity02/smpschedaffinity02.doc (added) * testsuites/smptests/smpschedaffinity02/smpschedaffinity02.scn (added) smpschedaffinity02: New test. This test checks setting the affinity ... Thu, 22 May 2014 14:00:14 GMT Jennifer Averett [d88b0e7f] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedaffinity01/Makefile.am (added) * testsuites/smptests/smpschedaffinity01/init.c (added) * testsuites/smptests/smpschedaffinity01/smpschedaffinity01.doc (added) * testsuites/smptests/smpschedaffinity01/smpschedaffinity01.scn (added) smpschedaffinity01: New test. This test verifies that affinity is ... Wed, 23 Apr 2014 20:08:26 GMT Jennifer Averett [82d137ae] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/capture01/Makefile.am (added) * testsuites/libtests/capture01/capture01.doc (added) * testsuites/libtests/capture01/capture01.scn (added) * testsuites/libtests/capture01/init.c (added) * testsuites/libtests/capture01/system.h (added) * testsuites/libtests/capture01/test1.c (added) * testsuites/libtests/configure.ac (modified) capture01: New non-interactive test for capture engine. Wed, 16 Apr 2014 14:42:37 GMT Jennifer Averett [463de59] * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/capture.h (modified) capture: Fix capture engine to handle new extensions. Fri, 11 Apr 2014 15:18:20 GMT Jennifer Averett [1af8634a] * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/capture.h (modified) capture: Update comment block style in capture engine. Doxygen ... Fri, 11 Jul 2014 07:47:05 GMT Sebastian Huber [f0c8501] * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) score: Scheduler helping proto for affinity sched The priority ... Thu, 10 Jul 2014 12:27:42 GMT Sebastian Huber [27783f6] * cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmp.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmrsp01/smpmrsp01.scn (modified) score: Fix scheduler helping implementation Do not extract the idle ... Thu, 10 Jul 2014 10:49:43 GMT Sebastian Huber [333f9426] * cpukit/score/include/rtems/score/schedulerpriorityimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulersimplesmp.c (modified) score: Fix assertions Thu, 10 Jul 2014 05:56:11 GMT Chris Johns [76ad756c] * rtems-bsps (modified) FreeBSD standard shell does not support substring expansion. Switch ... Wed, 09 Jul 2014 13:53:31 GMT Sebastian Huber [e1f446d3] * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (modified) bsps/sparc: Set best baud in APBUART driver This prevents failures ... Wed, 09 Jul 2014 13:44:13 GMT Sebastian Huber [93726e5] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (added) * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios01.doc (modified) termios: Add rtems_termios_set_best_baud() Thu, 03 Jul 2014 10:55:42 GMT Christian Mauderer [8074342c] * cpukit/libcsupport/include/rtems/termiostypes.h (modified) termios: Add rtems_termios_get_termios() Tue, 01 Jul 2014 13:09:49 GMT Christian Mauderer [8448a4d] * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_termios.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (modified) bsps/sparc: Move APBUART printk support Mon, 30 Jun 2014 07:33:36 GMT Sebastian Huber [21abc43] * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_termios.h (added) * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (added) bsps/sparc: Add and use shared APBUART console Move the APBUART ... Fri, 27 Jun 2014 14:20:44 GMT Sebastian Huber [a0eb21e] * c/src/lib/libbsp/shared/console-termios.c (added) bsps: Basic console driver for Termios devices Wed, 09 Jul 2014 09:52:56 GMT Sebastian Huber [a0fb29f] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios01/init.c (modified) termios: PR1279: Use first open status Wed, 09 Jul 2014 09:15:53 GMT Sebastian Huber [32fc6a3] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios01/init.c (modified) termios: PR1279: Use set attributes status Fri, 27 Jun 2014 11:10:15 GMT Sebastian Huber [ef8c00bc] * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios01.doc (modified) termios: PR2153: New low-level device API Add a new low-level ... Wed, 09 Jul 2014 09:20:23 GMT Sebastian Huber [c6048ee] * cpukit/score/include/rtems/score/schedulerimpl.h (modified) score: _Scheduler_Thread_get_own_node() Provide this function also ... Tue, 24 Jun 2014 08:00:06 GMT Sebastian Huber [9f228bea] * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmrsp01/smpmrsp01.scn (modified) smptests/smpmrsp01: Add and update test cases Fri, 04 Jul 2014 12:34:23 GMT Sebastian Huber [5c3d250] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/schedulersmp.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/schedulercbsnodeinit.c (modified) * cpukit/score/src/schedulerchangeroot.c (added) * cpukit/score/src/schedulerdefaultaskforhelp.c (added) * cpukit/score/src/schedulerdefaultnodeinit.c (modified) * cpukit/score/src/scheduleredfnodeinit.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersmpdebug.c (moved) * cpukit/score/src/schedulersmpstartidle.c (modified) * cpukit/score/src/threadinitialize.c (modified) * doc/user/smp.t (modified) score: Implement scheduler helping protocol The following scheduler ... Tue, 08 Jul 2014 16:42:05 GMT Joel Sherrill [52f8e90d] * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) schedulerpriorityaffinitysmp.c: Add period at end of sentence Wed, 11 Jun 2014 12:31:03 GMT Sebastian Huber [8568341] * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritychangepriority.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimplechangepriority.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) score: Need for help indicator for scheduler ops Return a thread in ... Fri, 04 Jul 2014 11:40:10 GMT Sebastian Huber [ac532f3] * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) score: Add _Scheduler_Help() Manage the help state of threads with ... Tue, 08 Jul 2014 12:25:55 GMT Sebastian Huber [08d9760] * cpukit/score/include/rtems/score/schedulercbsimpl.h (modified) * cpukit/score/include/rtems/score/scheduleredfimpl.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityimpl.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsnodeinit.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/scheduleredfchangepriority.c (modified) * cpukit/score/src/scheduleredfnodeinit.c (modified) * cpukit/score/src/scheduleredfupdate.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritychangepriority.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityupdate.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersmpstartidle.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) score: Rename *_Node_get() to *_Thread_get_node() This emphasizes ... Tue, 08 Jul 2014 08:38:19 GMT Sebastian Huber [19e41767] * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) score: Simplify SMP processor allocation Avoid copy and paste and ... Mon, 07 Jul 2014 14:41:03 GMT Sebastian Huber [835b88b] * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) score: Rename _Scheduler_SMP_Update_heir() Rename and move ... Mon, 07 Jul 2014 11:31:07 GMT Sebastian Huber [5c632c4] * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) score: Fix warning Fri, 04 Jul 2014 12:32:35 GMT Sebastian Huber [46cd17a] * cpukit/score/include/rtems/score/mrspimpl.h (modified) score: Fix MrsP resource root change Use the root of the owner for ... Tue, 01 Jul 2014 08:48:28 GMT Sebastian Huber [fbda4a8] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/asm.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) score: PR2183: Fix context switch on SMP Fix context switch on SMP ... Mon, 30 Jun 2014 14:47:06 GMT Sebastian Huber [f28f5c4] * cpukit/score/cpu/arm/cpu_asm.S (modified) arm: Use local label in _CPU_Context_restore() Mon, 30 Jun 2014 10:55:50 GMT Sebastian Huber [bec4730] * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/src/percpuasm.c (modified) score: Add PER_CPU_OFFSET_EXECUTING Add PER_CPU_OFFSET_HEIR. Move ... Tue, 01 Jul 2014 13:30:07 GMT Sebastian Huber [7ab6046] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/mmu-config.c (added) bsp/altera-cyclone-v: Move MMU configuration table This makes it ... Tue, 01 Jul 2014 13:17:40 GMT Sebastian Huber [9eb1994f] * c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) * c/src/lib/libbsp/arm/shared/mminit.c (modified) bsps/arm: Rename bsp_mm_config_table Rename bsp_mm_config_table to ... Tue, 01 Jul 2014 10:02:24 GMT Sebastian Huber [8852594] * testsuites/sptests/spcontext01/init.c (modified) sptests/spcontext01: Avoid NULL pointer access Mon, 30 Jun 2014 11:34:09 GMT Sebastian Huber [516a60a] * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart.c (modified) bsps/sparc: Reduce copy and paste Wed, 04 Jun 2014 12:22:00 GMT Daniel Hellstrom [47cf1add] * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) LEON3: devfs free nodes must be sized .. according to the maximum ... Fri, 13 Jun 2014 13:14:54 GMT Daniel Hellstrom [9f99232] * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) LEON3: fix console close handling On SMP ... Mon, 30 Jun 2014 10:30:12 GMT Sebastian Huber [0b4ec4d] * testsuites/smptests/smpfatal08/init.c (modified) smptests/smpfatal08: Support RTEMS_PARAVIRT Fri, 27 Jun 2014 11:08:28 GMT Sebastian Huber [f6b1e063] * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termiosinitialize.c (modified) termios: Make tty list static
