# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/17/24 06:55:47 Thu, 06 Nov 2014 14:37:54 GMT Jennifer Averett [66bf2af2] * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/capture/captureimpl.h (modified) capture: Add SMP support. To support smp data was broken into ... Thu, 06 Nov 2014 14:26:38 GMT Jennifer Averett [04a13bd] * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture_support.c (added) * cpukit/libmisc/capture/captureimpl.h (modified) capture: Move print methods out of cli for reuse. Methods to print ... Fri, 03 Oct 2014 19:01:44 GMT Jennifer Averett [3d5bcded] * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/capture/capture_user_extension.c (modified) capture: Move logging of task record to occur after filter check. ... Mon, 24 Nov 2014 19:57:21 GMT Joel Sherrill [f7d2795] * testsuites/support/include/tmacros.h (modified) testsuites/.../tmacros.h: Add parentheses to fix warning Mon, 24 Nov 2014 10:55:44 GMT Sebastian Huber [cfc53c1] * cpukit/dev/i2c/gpio-nxp-pca9535.c (modified) i2c: Fix endian issue Mon, 24 Nov 2014 08:44:50 GMT Sebastian Huber [55db0e5] * c/src/lib/libbsp/sparc/leon3/make/custom/ngmp.cfg (modified) bsp/ngmp: Use -muser-mode GCC option This option is necessary to ... Mon, 24 Nov 2014 07:35:45 GMT Sebastian Huber [26f4cdd] * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/src/threadq.c (modified) _Scheduler_FIXME_thread_priority_queues_are_broken Delete this ... Fri, 21 Nov 2014 10:01:34 GMT Luca Bonato [cceb19f4] * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmrsp01/smpmrsp01.scn (modified) smp: Fix scheduler helping protocol New test case for ... Sun, 23 Nov 2014 16:40:14 GMT Joel Sherrill [6570876] * testsuites/libtests/termios05/termios_testdriver_taskdriven.c (deleted) * testsuites/libtests/termios05/termios_testdriver_taskdriven.h (deleted) termio05: Remove unreferenced files The functionality was ... Sun, 23 Nov 2014 15:48:17 GMT Joel Sherrill [b46a31e] * c/src/lib/libbsp/sparc/leon2/console/console.c (modified) leon2: include not close #2113 Sun, 23 Nov 2014 00:25:12 GMT Santosh G Vattam [89be4e7] * cpukit/score/include/rtems/score/object.h (modified) rtems/score/object.h: Correct types on _Objects_Build_id close 1423 Fri, 21 Nov 2014 19:11:57 GMT Joel Sherrill [ff1c613] * c/src/lib/libbsp/powerpc/haleakala/mmu/mmu_405.c (modified) * c/src/lib/libbsp/powerpc/haleakala/network/network.c (modified) powerpc/haleakala: Fix warnings Fri, 21 Nov 2014 17:15:22 GMT Nigel Spon [502609c8] * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/include/mmu_405.h (added) * c/src/lib/libbsp/powerpc/haleakala/mmu/mmu_405.c (added) * c/src/lib/libbsp/powerpc/haleakala/mmu/mmu_405asm.S (added) * c/src/lib/libbsp/powerpc/haleakala/network/network.c (added) * c/src/lib/libbsp/powerpc/haleakala/preinstall.am (modified) * c/src/lib/libcpu/powerpc/ppc403/include/ppc405ex.h (modified) * c/src/lib/libcpu/powerpc/ppc403/include/ppc405gp.h (modified) powerpc/haleakala: Add network driver close 1405 Thu, 20 Nov 2014 23:25:15 GMT Joel Sherrill [ed4c556] * cpukit/score/src/objectsetname.c (modified) objectsetname.c: Fix always true condition (Coverity ID 1063874) ... Thu, 20 Nov 2014 23:22:22 GMT Joel Sherrill [abf3892c] * cpukit/libfs/src/pipe/fifo.c (modified) pipe/fifo.c: NULL dereference flagged by Coverity ID 1063889 It ... Thu, 20 Nov 2014 23:21:05 GMT Joel Sherrill [e8abdfb] * cpukit/libfs/src/dosfs/fat_fat_operations.c (modified) dosfs/fat_fat_operations.c: Explicitly ignore return (Coverity ID ... Thu, 20 Nov 2014 23:19:13 GMT Joel Sherrill [8f73af85] * cpukit/libfs/src/dosfs/msdos_format.c (modified) dosfs/msdos_format.c: Dead code removal (Coverity ID 1255325) ... Thu, 20 Nov 2014 23:17:18 GMT Joel Sherrill [5dff7425] * cpukit/libcsupport/src/termios.c (modified) libcsupport/src/termios.c: Explicitly ignore return value (Coverity ... Fri, 21 Nov 2014 07:49:57 GMT Sebastian Huber [11925eef] * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260eth.c (modified) * c/src/libchip/ide/ata_internal.h (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libmisc/untar/untar.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/pppd/pppd.h (modified) * testsuites/psxtests/psxaio02/init.c (modified) * testsuites/psxtests/psxaio03/init.c (modified) * testsuites/samples/fileio/init.c (modified) * testsuites/sptests/sp48/init.c (modified) * testsuites/sptests/sp63/init.c (modified) Delete or rename MIN/MAX macros and defines Include ... Tue, 11 Nov 2014 16:21:02 GMT Jennifer Averett [db44590c] * testsuites/smptests/smpschedaffinity05/init.c (modified) smpschedaffinity05: Change semaphore attributes. Change semaphore ... Wed, 12 Nov 2014 14:42:13 GMT Jennifer Averett [1960dcb9] * testsuites/smptests/smpschedaffinity04/init.c (modified) smpschedaffinity04: Change semaphore attributes. Change semaphore ... Wed, 12 Nov 2014 14:42:48 GMT Jennifer Averett [bc95f816] * testsuites/smptests/smpschedaffinity02/init.c (modified) smpschedaffinity02: Change semaphore attributes. Change semaphore ... Wed, 19 Nov 2014 19:57:37 GMT Joel Sherrill [163519a0] * testsuites/libtests/malloctest/init.c (modified) * testsuites/support/include/tmacros.h (modified) libtests/malloctest/init.c: Fix warning posix_memalign() is ... Wed, 19 Nov 2014 19:57:21 GMT Joel Sherrill [a5201ea] * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) libdl/rtl-mdreloc-powerpc.c: Fix warnings This patch addresses the ... Thu, 06 Nov 2014 22:16:56 GMT Joel Sherrill [287843f] * cpukit/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/sys/mman.h (added) * cpukit/posix/src/mmap.c (added) * cpukit/posix/src/mprotect.c (modified) * cpukit/posix/src/munmap.c (added) * cpukit/preinstall.am (modified) sys/mman.h: New file. Clean up and add supporting stubs * ... Thu, 06 Nov 2014 16:03:11 GMT Joel Sherrill [c8784667] * cpukit/libdl/include/arch/mips/machine/elf_machdep.h (modified) libdl/.../mips/machine/elf_machdep.h: Fix typo so compiles Thu, 20 Nov 2014 16:05:02 GMT Gedare Bloom [280f4ecc] * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) autotools: regenerate preinstall.am for pc386 Thu, 20 Nov 2014 14:00:33 GMT Jan Dolezal [067da5c] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (added) * c/src/lib/libbsp/i386/pc386/include/fb_vesa.h (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/start/start.S (modified) i386/pc386: VESA based frame buffer utilizing real mode interrupt 10h Thu, 20 Nov 2014 14:00:32 GMT Jan Dolezal [c5a74946] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/edid.h (added) * c/src/lib/libbsp/i386/pc386/include/vbe3.h (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) i386/pc386/include: header files for VESA BIOS EXTENSIONS and VESA ... Thu, 20 Nov 2014 14:00:31 GMT Jan Dolezal [586c86c7] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c (added) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (added) i386/shared/realmode_int: real mode interrupt interface Thu, 20 Nov 2014 14:00:30 GMT Jan Dolezal [74d2d940] * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * c/src/lib/libcpu/i386/cpu.h (modified) i386: global descriptor table manipulation functions Thu, 20 Nov 2014 14:00:29 GMT Jan Dolezal [b2db1f5c] * cpukit/score/include/rtems/score/basedefs.h (modified) cpukit: basedefs: macro for packed attribute Thu, 20 Nov 2014 14:00:28 GMT Jan Dolezal [d885b2b2] * c/src/lib/libcpu/i386/cpu.h (modified) * c/src/lib/libcpu/i386/idtr.S (modified) i386: GDTR manipulation functions parameters changed to use explicit ... Thu, 20 Nov 2014 14:00:27 GMT Jan Dolezal [58af50d] * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) score: i386: functions converting real mode pointer to physical ... Thu, 20 Nov 2014 14:00:26 GMT Jan Dolezal [ec494ff] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) i386/pc386: configurable size of descriptor tables Thu, 20 Nov 2014 08:15:19 GMT Sebastian Huber [a634feb] * testsuites/libtests/dl01/Makefile.am (modified) * testsuites/libtests/dl02/Makefile.am (modified) dl01,dl02: Avoid non-runnable $(EXEEXT) files Thu, 20 Nov 2014 08:03:50 GMT Sebastian Huber [3bb9c61c] * cpukit/libblock/src/bdbuf.c (modified) bdbuf: Use rtems_cache_get_data_line_size() Wed, 19 Nov 2014 14:30:24 GMT Sebastian Huber [50440c0] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspsmp.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspsmp.c (added) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspsmp.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) bsps/arm: Enable L2C for Cortex-A9 MPCore BSPs Wed, 19 Nov 2014 14:07:58 GMT Sebastian Huber [d1eb7b1] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 drop exclusive cache support Optimize locking. Wed, 19 Nov 2014 13:55:53 GMT Sebastian Huber [5f4f828] * c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h (modified) bsps/arm: L1 cache support changes Wed, 19 Nov 2014 13:37:11 GMT Sebastian Huber [e492e7f8] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 compile-time errata 588369 Wed, 19 Nov 2014 13:29:27 GMT Sebastian Huber [52d24b00] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 compile-time errata 753970 Wed, 19 Nov 2014 13:19:13 GMT Sebastian Huber [55741886] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsps/arm: L2C 310 exclusive config is fatal Wed, 19 Nov 2014 13:08:44 GMT Sebastian Huber [d53de34] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 use l2c_310_* prefix throughout Wed, 19 Nov 2014 13:05:36 GMT Sebastian Huber [861d315] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 use L2C_310_* prefix throughout Wed, 19 Nov 2014 11:24:07 GMT Sebastian Huber [f2fed0c1] * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsps/arm: L2C 310 add compile time checks Simplify initialization. ... Wed, 19 Nov 2014 11:07:04 GMT Sebastian Huber [13f1462f] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 delete invalid link Wed, 19 Nov 2014 11:23:02 GMT Sebastian Huber [a9d6c20] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 simplify and remove white space Wed, 19 Nov 2014 10:51:33 GMT Sebastian Huber [957c075] * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) bsps/arm: L2C 310 rename BSP_ARM_L2CC_BASE Rename BSP_ARM_L2CC_BASE ... Wed, 19 Nov 2014 09:46:16 GMT Sebastian Huber [6b4a22e3] * cpukit/libmisc/shell/main_ping.c (modified) shell: Include early This avoids a conflict with ... Tue, 18 Nov 2014 14:33:33 GMT Sebastian Huber [8dbc612] * doc/shell/Makefile.am (modified) * doc/shell/confinit.t (modified) shell: Documentation Tue, 18 Nov 2014 13:05:15 GMT Sebastian Huber [3fe5d01] * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_cmdchmod.c (added) * cpukit/libmisc/shell/main_cmdchown.c (added) * cpukit/libmisc/shell/main_cmdls.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) * doc/shell/general.t (modified) shell: Add CMDLS, CMDCHOWN, CMDCHMOD commands Tue, 18 Nov 2014 11:03:11 GMT Sebastian Huber [478455e0] * cpukit/libmisc/shell/main_help.c (modified) shell: Fix help topic header Tue, 18 Nov 2014 06:35:30 GMT Sebastian Huber [7eada71] * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_alias.c (modified) * cpukit/libmisc/shell/main_help.c (modified) * cpukit/libmisc/shell/main_time.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) shell: Add mode, UID and GID to shell commands Use this information ... Tue, 18 Nov 2014 10:07:36 GMT Sebastian Huber [ffd5285] * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) shell: Inherit UID and GID if no login check Use the UID and GID of ... Tue, 18 Nov 2014 09:36:27 GMT Sebastian Huber [5c141d6a] * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_time.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) shell: Add and use rtems_shell_execute_cmd() Tue, 18 Nov 2014 09:13:55 GMT Sebastian Huber [1227858] * cpukit/libmisc/shell/shell_script.c (modified) shell: Make rtems_shell_main_joel() static Tue, 18 Nov 2014 09:09:30 GMT Sebastian Huber [66da4844] * cpukit/libmisc/shell/main_time.c (modified) shell: Print to stderr in TIME command Tue, 18 Nov 2014 09:03:24 GMT Sebastian Huber [7840b66] * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) * cpukit/libmisc/shell/shellconfig.h (modified) shell: Add initial commands and aliases only once Make tables read-only. Mon, 17 Nov 2014 14:58:26 GMT Sebastian Huber [7a2c30f] * cpukit/libmisc/shell/shell_cmdset.c (modified) shell: Simplify rtems_shell_add_cmd_struct() Mon, 17 Nov 2014 14:42:57 GMT Sebastian Huber [bac3d6d] * cpukit/libmisc/shell/main_halt.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shellconfig.h (modified) * doc/shell/rtems.t (modified) shell: Rename HALT to SHUTDOWN command Use a normal command for ... Mon, 17 Nov 2014 12:35:58 GMT Sebastian Huber [e02d5dd9] * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/pwdgrp.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/pwdgrp02/Makefile.am (added) * testsuites/libtests/pwdgrp02/init.c (added) * testsuites/libtests/pwdgrp02/pwdgrp02.doc (added) * testsuites/libtests/pwdgrp02/pwdgrp02.scn (added) Ensure security of default user environment Mon, 17 Nov 2014 10:55:27 GMT Sebastian Huber [fa028bb] * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/shell.c (modified) * testsuites/libtests/shell01/init.c (modified) * testsuites/samples/fileio/init.c (modified) shell: Do chroot() after successful login Mon, 17 Nov 2014 13:55:38 GMT Sebastian Huber [373ccbb9] * cpukit/libmisc/shell/shell.c (modified) shell: Use exiting once initialization Avoid TOCTOU issues. Avoid ... Mon, 17 Nov 2014 09:19:00 GMT Sebastian Huber [065d72ce] * cpukit/libmisc/shell/login_check.c (modified) * testsuites/libtests/shell01/init.c (modified) shell: Get supplementary group IDs in login check Mon, 17 Nov 2014 08:01:53 GMT Sebastian Huber [b8bd90f6] * cpukit/include/rtems/userenv.h (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/sup_fs_check_permissions.c (modified) * cpukit/libcsupport/src/uenvgetgroups.c (added) * testsuites/fstests/fsnofs01/init.c (modified) Add supplementary groups to user environment Tue, 18 Nov 2014 09:42:45 GMT Sebastian Huber [0b3fcf5] * testsuites/samples/fileio/system.h (modified) samples/fileio: Use unlimited objects Tue, 18 Nov 2014 09:42:34 GMT Sebastian Huber [ab085c9] * testsuites/samples/fileio/init.c (modified) samples/fileio: Fix warning Mon, 17 Nov 2014 12:00:17 GMT Sebastian Huber [7bfa0970] * cpukit/libfs/src/dosfs/fat.h (modified) dosfs: Avoid MIN() re-definition Tue, 18 Nov 2014 06:39:47 GMT Sebastian Huber [c3350e7d] * cpukit/libcsupport/include/rtems/libio_.h (modified) Filesystem: Typo Mon, 17 Nov 2014 06:53:01 GMT Sebastian Huber [ffa71f1] * cpukit/libcsupport/src/getgroups.c (modified) * testsuites/libtests/pwdgrp01/init.c (modified) * testsuites/libtests/pwdgrp01/pwdgrp01.doc (modified) * testsuites/psxtests/psxid01/init.c (modified) * testsuites/psxtests/psxid01/psxid01.scn (modified) libcsupport: Implement getgroups() Fri, 14 Nov 2014 14:33:57 GMT Sebastian Huber [395e5d4] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/getgrent.c (modified) * cpukit/libcsupport/src/getgrnam.c (added) * testsuites/psxtests/psxpasswd01/init.c (modified) * testsuites/psxtests/psxpasswd02/init.c (modified) libcsupport: Use POSIX key for getgrent() Fri, 14 Nov 2014 13:31:54 GMT Sebastian Huber [acf9a8d] * cpukit/libmisc/shell/login_check.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/shell01/Makefile.am (added) * testsuites/libtests/shell01/init.c (added) * testsuites/libtests/shell01/shell01.doc (added) * testsuites/libtests/shell01/shell01.scn (added) * testsuites/samples/fileio/init.c (modified) shell: Use crypt_r() in rtems_shell_login_check() Use '*" to ... Fri, 14 Nov 2014 13:30:36 GMT Sebastian Huber [002f351] * cpukit/libcsupport/src/pwdgrp.c (modified) * testsuites/psxtests/psxpasswd01/init.c (modified) * testsuites/psxtests/psxpasswd01/psxpasswd01.scn (modified) libcsupport: Minimal /etc/passwd and /etc/group Create a minimal ... Fri, 14 Nov 2014 10:30:50 GMT Sebastian Huber [6935428] * cpukit/libcsupport/src/pwdgrp.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/pwdgrp01/Makefile.am (added) * testsuites/libtests/pwdgrp01/init.c (added) * testsuites/libtests/pwdgrp01/pwdgrp01.doc (added) * testsuites/libtests/pwdgrp01/pwdgrp01.scn (added) libcsupport: Avoid TOCTOU and format errors Fri, 14 Nov 2014 10:09:39 GMT Sebastian Huber [80055514] * cpukit/libcsupport/src/pwdgrp.c (modified) libcsupport: Use pthread_once() Fri, 14 Nov 2014 10:01:48 GMT Sebastian Huber [b471854b] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/getgrent.c (added) * cpukit/libcsupport/src/getpwent.c (modified) * cpukit/libcsupport/src/pwdgrp.c (added) * cpukit/libcsupport/src/pwdgrp.h (added) libcsupport: Split passwd/group support Fri, 14 Nov 2014 09:28:15 GMT Sebastian Huber [d82f9de1] * cpukit/libcsupport/src/getpwent.c (modified) libcsupport: Add copyrights according to rev hist Thu, 13 Nov 2014 14:13:24 GMT Sebastian Huber [4466321] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/include/crypt.h (added) * cpukit/libcrypt/Makefile.am (added) * cpukit/libcrypt/crypt-md5.c (added) * cpukit/libcrypt/crypt-sha256.c (added) * cpukit/libcrypt/crypt-sha512.c (added) * cpukit/libcrypt/crypt.c (added) * cpukit/libcrypt/misc.c (added) * cpukit/libcrypt/preinstall.am (added) * cpukit/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/crypt01/Makefile.am (added) * testsuites/libtests/crypt01/crypt01.doc (added) * testsuites/libtests/crypt01/crypt01.scn (added) * testsuites/libtests/crypt01/init.c (added) Add crypt_r(), etc. Add crypt_add_format(), crypt_r(), ... Thu, 13 Nov 2014 12:18:24 GMT Sebastian Huber [1bcd0378] * cpukit/Makefile.am (modified) * cpukit/libmd/Makefile.am (modified) * cpukit/libmd/preinstall.am (modified) * cpukit/libmd/sha256.h (added) * cpukit/libmd/sha256c.c (added) * cpukit/libmd/sha512.h (added) * cpukit/libmd/sha512c.c (added) * cpukit/preinstall.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/sha/Makefile.am (added) * testsuites/libtests/sha/init.c (added) * testsuites/libtests/sha/sha.doc (added) * testsuites/libtests/sha/sha.scn (added) Add SHA256 and SHA512 support Thu, 13 Nov 2014 10:55:51 GMT Sebastian Huber [a2b6895] * cpukit/Makefile.am (modified) * cpukit/include/sys/endian.h (added) * cpukit/preinstall.am (modified) Add Mon, 10 Nov 2014 12:46:32 GMT Sebastian Huber [45a63ee] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/i2c.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) bsp/xilinx-zynq: Add Cadence I2C bus driver Thu, 13 Nov 2014 09:12:32 GMT Sebastian Huber [bdf8fa76] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (modified) bsp/xilinx-zynq: Add zync_clock_cpu_1x() Thu, 13 Nov 2014 09:15:41 GMT Sebastian Huber [234d5c40] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) bsp/xilinx-zynq: Rename BSP_ARM_A9MPCORE_UARTCLK Rename ... Wed, 12 Nov 2014 13:02:53 GMT Sebastian Huber [8100e71] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) bsp/xilinx-zynq: Adjust BSP_ARM_A9MPCORE_PERIPHCLK Tue, 11 Nov 2014 11:41:58 GMT Sebastian Huber [0510cfd8] * cpukit/dev/Makefile.am (modified) * cpukit/dev/i2c/switch-nxp-pca9548a.c (added) * cpukit/dev/include/dev/i2c/switch-nxp-pca9548a.h (added) * cpukit/dev/preinstall.am (modified) * testsuites/libtests/i2c01/init.c (modified) Add NXP PCA9548A 8-channel switch I2C driver Fri, 07 Nov 2014 12:50:01 GMT Sebastian Huber [67ac69fc] * cpukit/dev/Makefile.am (modified) * cpukit/dev/i2c/gpio-nxp-pca9535.c (added) * cpukit/dev/include/dev/i2c/gpio-nxp-pca9535.h (added) * cpukit/dev/preinstall.am (modified) * testsuites/libtests/i2c01/init.c (modified) Add NXP PCA9535 16-bit GPIO I2C driver Fri, 07 Nov 2014 12:49:29 GMT Sebastian Huber [cce46780] * cpukit/dev/Makefile.am (modified) * cpukit/dev/i2c/eeprom.c (added) * cpukit/dev/include/dev/i2c/eeprom.h (added) * cpukit/dev/preinstall.am (modified) * testsuites/libtests/i2c01/init.c (modified) Add generic EEPROM I2C device driver Fri, 07 Nov 2014 12:47:39 GMT Sebastian Huber [41c5f1b7] * cpukit/dev/Makefile.am (modified) * cpukit/dev/i2c/i2c-bus.c (added) * cpukit/dev/i2c/i2c-dev.c (added) * cpukit/dev/include/dev/i2c/i2c.h (added) * cpukit/dev/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/i2c01/Makefile.am (added) * testsuites/libtests/i2c01/i2c01.doc (added) * testsuites/libtests/i2c01/i2c01.scn (added) * testsuites/libtests/i2c01/init.c (added) Add I2C driver framework This I2C driver framework has some major ... Wed, 05 Nov 2014 09:21:34 GMT Sebastian Huber [b6f21886] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/dev/Makefile.am (added) * cpukit/dev/include/linux/i2c-dev.h (added) * cpukit/dev/include/linux/i2c.h (added) * cpukit/dev/preinstall.am (added) Add RTEMS port of Linux I2C user-space API Wed, 12 Nov 2014 12:57:24 GMT Sebastian Huber [f0c564c] * c/src/lib/libbsp/arm/shared/startup/linkcmds.armv4 (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Adjust stacks for ARMv4 Reduce non-IRQ stacks to size ... Thu, 20 Nov 2014 07:52:50 GMT Sebastian Huber [3eade710] * testsuites/libtests/top/init.c (modified) libtests/top: End test after some time if no input Wed, 12 Nov 2014 13:00:05 GMT Alan Cudmore [96a9f4c] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (modified) * c/src/lib/libbsp/arm/shared/abort/abort.h (added) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (modified) ARM removed shared/abort from several ARM BSPs Thu, 20 Nov 2014 02:52:12 GMT Chris Johns [580466c] * cpukit/libdl/rtl-elf.c (modified) libdl: Update comment with details about the error fix. See refs #2192. Wed, 19 Nov 2014 23:19:46 GMT Chris Johns [2ae58c69] * cpukit/libdl/rtl-allocator.c (modified) libdl: Update the comments. See refs #2191. Wed, 19 Nov 2014 23:18:16 GMT Chris Johns [fc523ac8] * cpukit/libdl/rtl-elf.c (modified) libdl: Fix possible 16-bit overflow (Coverity 1255339) refs #2192. ... Wed, 19 Nov 2014 21:43:15 GMT Chris Johns [4f1bbbfc] * cpukit/libdl/rtl-allocator.c (modified) libdl: Add a comment. See ref #2191. Wed, 19 Nov 2014 21:38:28 GMT Chris Johns [80590a8] * cpukit/libdl/rtl-allocator.c (modified) libdl: Add a comment to the previous fix. The fix is ref #2191. Wed, 19 Nov 2014 21:30:01 GMT Chris Johns [90f65007] * cpukit/libdl/rtl-allocator.c (modified) libdl: Fix allocator NULL check (Coverity 1255328) refs #2191 The ... Wed, 19 Nov 2014 20:27:34 GMT Chris Johns [724eb8c4] * MAINTAINERS (modified) Fix type in MAINTAINERS.
