# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 10:07:25 Wed, 11 Jun 2014 12:37:03 GMT Sebastian Huber [647859e] * testsuites/samples/pppd/system.h (modified) samples/pppd: Fix extra drivers initializer Tue, 10 Jun 2014 14:48:54 GMT Martin Galvan [cb42c9a] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg (modified) lm3s6965-testsuite.cfg: Add pppd. When trying to compile RTEMS for ... Tue, 10 Jun 2014 12:30:47 GMT Sebastian Huber [e473f3c] * cpukit/score/include/rtems/score/mrspimpl.h (modified) score: Fix MrsP root node update Set the new root after the ... Tue, 10 Jun 2014 09:42:19 GMT Sebastian Huber [2a2a1695] * testsuites/smptests/smpfatal03/init.c (modified) smptest/smpfatal03: Update due to API changes Mon, 09 Jun 2014 14:27:18 GMT Martin Boretto [19260fb] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (added) * c/src/lib/libbsp/arm/lpc176x/README (added) * c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c (added) * c/src/lib/libbsp/arm/lpc176x/bsp_specs (added) * c/src/lib/libbsp/arm/lpc176x/configure.ac (added) * c/src/lib/libbsp/arm/lpc176x/console/console-config.c (added) * c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c (added) * c/src/lib/libbsp/arm/lpc176x/include/bsp.h (added) * c/src/lib/libbsp/arm/lpc176x/include/common-types.h (added) * c/src/lib/libbsp/arm/lpc176x/include/dma.h (added) * c/src/lib/libbsp/arm/lpc176x/include/gpio-defs.h (added) * c/src/lib/libbsp/arm/lpc176x/include/gpio.h (added) * c/src/lib/libbsp/arm/lpc176x/include/io-defs.h (added) * c/src/lib/libbsp/arm/lpc176x/include/io.h (added) * c/src/lib/libbsp/arm/lpc176x/include/irq.h (added) * c/src/lib/libbsp/arm/lpc176x/include/lpc-clock-config.h (added) * c/src/lib/libbsp/arm/lpc176x/include/lpc176x.h (added) * c/src/lib/libbsp/arm/lpc176x/include/system-clocks.h (added) * c/src/lib/libbsp/arm/lpc176x/include/timer-defs.h (added) * c/src/lib/libbsp/arm/lpc176x/include/timer.h (added) * c/src/lib/libbsp/arm/lpc176x/include/watchdog-defs.h (added) * c/src/lib/libbsp/arm/lpc176x/include/watchdog.h (added) * c/src/lib/libbsp/arm/lpc176x/irq/irq.c (added) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (added) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg (added) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram.cfg (added) * c/src/lib/libbsp/arm/lpc176x/misc/bspidle.c (added) * c/src/lib/libbsp/arm/lpc176x/misc/dma-copy.c (added) * c/src/lib/libbsp/arm/lpc176x/misc/dma.c (added) * c/src/lib/libbsp/arm/lpc176x/misc/io.c (added) * c/src/lib/libbsp/arm/lpc176x/misc/restart.c (added) * c/src/lib/libbsp/arm/lpc176x/misc/system-clocks.c (added) * c/src/lib/libbsp/arm/lpc176x/preinstall.am (added) * c/src/lib/libbsp/arm/lpc176x/rtc/rtc-config.c (added) * c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c (added) * c/src/lib/libbsp/arm/lpc176x/startup/bspstart.c (added) * c/src/lib/libbsp/arm/lpc176x/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed (added) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed_ahb_ram (added) * c/src/lib/libbsp/arm/lpc176x/timer/timer.c (added) * c/src/lib/libbsp/arm/lpc176x/watchdog/watchdog.c (added) bsp/lpc176x: New BSP Fri, 06 Jun 2014 12:54:37 GMT Sebastian Huber [c1072919] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h (modified) Revert "bsps/powerpc: Fix potential relocation truncation" This ... Fri, 06 Jun 2014 11:35:56 GMT Sebastian Huber [d9ff8b3e] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h (modified) bsps/powerpc: Fix potential relocation truncation See also ... Thu, 05 Jun 2014 14:38:29 GMT Sebastian Huber [dc44de7] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Fix TLB invalidation for ARMv7-A Thu, 05 Jun 2014 14:19:21 GMT Sebastian Huber [c19342a7] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) bsps/arm: Fix Cortex-A9 MPCore clock driver The nanoseconds ... Thu, 05 Jun 2014 08:03:55 GMT Sebastian Huber [1468d70] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspsmp.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c (modified) bsp/altera-cyclone-v: Enable unified L2 cache Thu, 05 Jun 2014 08:03:06 GMT Sebastian Huber [2a1d86c] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspsmp.c (added) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstart.c (modified) bsp/altera-cyclone-v: Move SMP support Thu, 05 Jun 2014 08:01:42 GMT Sebastian Huber [40599e7e] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h (modified) bsps/arm: Change L2 cache initialization Do not touch the L1 caches ... Thu, 05 Jun 2014 06:41:56 GMT Sebastian Huber [8fb685b] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c (modified) bsp/altera-cyclone-v: Simplify start hooks Use ... Wed, 04 Jun 2014 13:34:10 GMT Sebastian Huber [330ccc5] * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) bsp/altera-cyclone-v: Change default baud Use value for standard U-Boot. Wed, 04 Jun 2014 13:33:42 GMT Sebastian Huber [82054c80] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv_devkit (modified) bsp/altera-cyclone-v: Use NOLOAD for nocache sec Wed, 04 Jun 2014 09:12:01 GMT Sebastian Huber [9fa88124] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c (modified) bsp/altera-cyclone-v: Simplify MMU config table Thu, 05 Jun 2014 11:22:08 GMT Sebastian Huber [2d3caccf] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) * c/src/lib/libbsp/arm/shared/mminit.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstartmmu.c (modified) bsps/arm: Define ARM_CP15_TEXT_SECTION Define ARM_CP15_TEXT_SECTION ... Thu, 05 Jun 2014 09:40:48 GMT Sebastian Huber [66a2409d] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add ARM_CP15_TEXT_SECTION Allow users of this header file ... Wed, 04 Jun 2014 09:21:43 GMT Sebastian Huber [44fbca3] * c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h (modified) bsps/arm: Simplify L1 caches support Delete superfluous/incorrect ... Thu, 05 Jun 2014 06:32:15 GMT Sebastian Huber [d0a8f513] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add all level data cache invalidation Thu, 05 Jun 2014 06:31:45 GMT Sebastian Huber [def03ae] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Typo Wed, 04 Jun 2014 09:07:11 GMT Sebastian Huber [82850b8] * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) bsps/arm: Cortex-A9 MPCore start Invalidate entire branch predictor ... Wed, 04 Jun 2014 08:05:14 GMT Sebastian Huber [e87ccf5] * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) bsps/arm: Cortex-A9 MPCore start Enable SCU only on the boot processor. Wed, 04 Jun 2014 08:03:40 GMT Sebastian Huber [b938108b] * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) bsps/arm: Cortex-A9 MPCore start Add ... Wed, 04 Jun 2014 07:56:49 GMT Sebastian Huber [041bf16] * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) bsps/arm: Simplify Cortex-A9 MPCore start Add ... Thu, 05 Jun 2014 09:19:32 GMT Sebastian Huber [9a1bab2] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/src/percpustatewait.c (added) score: _Per_CPU_State_wait_for_non_initial_state() Replace ... Thu, 05 Jun 2014 09:17:26 GMT Sebastian Huber [be3c257] * cpukit/score/include/rtems/score/schedulerimpl.h (modified) score: Avoid NULL pointer access Check that the executing thread is ... Thu, 05 Jun 2014 08:28:08 GMT Sebastian Huber [c952ecab] * cpukit/score/include/rtems/score/smpimpl.h (modified) score: Delete SMP_FATAL_SHUTDOWN_EARLY Sort enum lexicographically. Mon, 02 Jun 2014 11:26:48 GMT Daniel Hellstrom [e640a88] * cpukit/NEWS (deleted) remove not updated NEWS file Tue, 27 May 2014 14:02:22 GMT Daniel Hellstrom [537f7271] * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) LEON2: enable exception prinout by default Tue, 27 May 2014 07:15:42 GMT Daniel Hellstrom [8343aa41] * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) LEON3: enable exception prinout by default Tue, 27 May 2014 09:42:44 GMT Daniel Hellstrom [a20c114] * c/src/libchip/network/greth.c (modified) GRETH: remove TCP/UDP HW checksum generation The GRETH doesn't ... Thu, 29 May 2014 05:05:56 GMT Chris Johns [bb58190] * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/main_logoff.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) shell: Add rtems_shell_dup_current_env to get a default env. Remove ... Tue, 03 Jun 2014 13:58:30 GMT Sebastian Huber [4d1f500] * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/src/schedulerdefaultupdate.c (modified) * cpukit/score/src/scheduleredfupdate.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityupdate.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadsetpriority.c (modified) score: Rename _Scheduler_Update() Rename _Scheduler_Update() to ... Tue, 03 Jun 2014 08:29:30 GMT Sebastian Huber [8e467384] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/src/schedulercbsnodeinit.c (moved) * cpukit/score/src/schedulerdefaultnodedestroy.c (added) * cpukit/score/src/schedulerdefaultnodeinit.c (moved) * cpukit/score/src/scheduleredfnodeinit.c (moved) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Replace _Scheduler_Allocate/Free() Replace ... Tue, 03 Jun 2014 10:00:53 GMT Sebastian Huber [f6fc6359] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spsem03/Makefile.am (added) * testsuites/sptests/spsem03/init.c (added) * testsuites/sptests/spsem03/spsem03.doc (added) * testsuites/sptests/spsem03/spsem03.scn (added) sptests/spsem03: New test Tue, 03 Jun 2014 08:24:55 GMT Sebastian Huber [1d799ad] * testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c (modified) * testsuites/rhealstone/rhilatency/ilatency.c (modified) * testsuites/rhealstone/rhmlatency/mlatency.c (modified) * testsuites/rhealstone/rhsemshuffle/semshuffle.c (modified) * testsuites/rhealstone/rhtaskpreempt/taskpreempt.c (modified) * testsuites/rhealstone/rhtaskswitch/taskswitch.c (modified) rhealstone: Produce proper begin/end messages Mon, 02 Jun 2014 14:31:51 GMT Christian Mauderer [8df1f408] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c (modified) * c/src/lib/libbsp/sparc/shared/cpu.c (added) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) score/sparc: Add support for paravirtualization Guest systems in ... Tue, 03 Jun 2014 06:28:46 GMT Sebastian Huber [98f2d5c] * cpukit/libblock/src/bdbuf.c (modified) libblock: Avoid recursive mutex Mon, 02 Jun 2014 14:15:15 GMT Christian Mauderer [5abe5a8] * testsuites/smptests/smpthreadlife01/init.c (modified) smptests/smpthreadlife01: Fix for debug enabled Mon, 02 Jun 2014 14:15:14 GMT Christian Mauderer [1ee0d5f] * testsuites/smptests/smpmrsp01/init.c (modified) smptests/smpmrsp01: Fix scheduler ids Mon, 26 May 2014 14:02:58 GMT Sebastian Huber [9553e7a6] * cpukit/score/include/rtems/score/mrsp.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * doc/user/sem.t (modified) * testsuites/smptests/smpmrsp01/init.c (modified) score: Use Resource Handler for MrsP semaphores This enables proper ... Wed, 28 May 2014 11:38:48 GMT Sebastian Huber [3045738] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadinitialize.c (modified) score: Add resource node to thread control block Wed, 28 May 2014 11:37:54 GMT Sebastian Huber [6c7caa1a] * cpukit/posix/src/pthread.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Add and use _Thread_Owns_resources() Fri, 23 May 2014 08:00:33 GMT Sebastian Huber [3e201139] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/resource.h (added) * cpukit/score/include/rtems/score/resourceimpl.h (added) * cpukit/score/preinstall.am (modified) * cpukit/score/src/resourceiterate.c (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spresource01/Makefile.am (added) * testsuites/sptests/spresource01/init.c (added) * testsuites/sptests/spresource01/spresource01.doc (added) * testsuites/sptests/spresource01/spresource01.scn (added) score: Add Resource Handler A resource is something that has at ... Mon, 02 Jun 2014 12:46:18 GMT Ralf Kirchner [1fc2e960] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/sapi/include/confdefs.h (modified) libblock: Add RTEMS_BDBUF_USE_PTHREAD Use the PTHREAD mutexes and ... Mon, 02 Jun 2014 12:42:18 GMT Ralf Kirchner [d8ac087] * cpukit/sapi/include/confdefs.h (modified) rtems: Avoid copy and paste in confdefs.h Add and use ... Mon, 02 Jun 2014 11:23:07 GMT Sebastian Huber [7c90670] * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Add ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS Fri, 23 May 2014 15:09:22 GMT Ralf Kirchner [606ed52] * cpukit/libblock/src/bdbuf.c (modified) libblock: Use pthread_once() for initialization Enabling and ... Wed, 28 May 2014 16:11:51 GMT Sebastian Huber [25f5730f] * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/src/schedulersetaffinity.c (modified) * doc/user/smp.t (modified) * testsuites/smptests/smpscheduler02/init.c (modified) score: _Scheduler_Set_affinity() Do not change the scheduler with ... Wed, 28 May 2014 15:56:45 GMT Sebastian Huber [a92c488] * cpukit/posix/src/pthreadgetaffinitynp.c (modified) * cpukit/rtems/src/taskgetaffinity.c (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/src/schedulergetaffinity.c (modified) score: _Scheduler_Get_affinity() Drop scheduler parameter. Coding ... Wed, 28 May 2014 15:23:27 GMT Sebastian Huber [d7a1863b] * cpukit/rtems/src/schedulergetprocessorset.c (modified) rtems: Coding style Sun, 01 Jun 2014 23:18:28 GMT Joel Sherrill [3660154] * c/src/lib/libbsp/m68k/mrm332/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.c (modified) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/startup/bsppredriverhook.c (modified) mrm332: Tests now build and fewer warnings Sun, 01 Jun 2014 23:18:00 GMT Joel Sherrill [6ddc4da] * c/src/lib/libcpu/m68k/shared/misc/memProbe.c (modified) m68k/shared/misc/memProbe.c: Add prototype to eliminate warning Mon, 19 May 2014 20:25:15 GMT Joel Sherrill [e91ab8c] * cpukit/score/include/rtems/score/cpusetimpl.h (modified) cpusetimpl.h: Add _CPU_set_Set() and improve Doxygen Mon, 14 Apr 2014 21:05:04 GMT Joel Sherrill [8e7db68c] * cpukit/score/include/rtems/score/assert.h (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) Minor conditionals to enable building Scheduler Simulator on ... Thu, 29 May 2014 23:11:30 GMT Chris Johns [4d58458] * c/src/lib/libbsp/arm/gdbarmsim/startup/bspstarthooks.c (added) bsps/gdbarmsim: Add the missing bspstarthooks.c. Thu, 29 May 2014 22:38:09 GMT Chris Johns [9cec7add] * .gitignore (modified) Revert "Ignore emacs backfiles and TAGS." This reverts commit ... Wed, 28 May 2014 21:53:58 GMT Joel Sherrill [69c3f076] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) rtems/score/thread*.h: Really correct spelling error Wed, 28 May 2014 21:42:33 GMT Joel Sherrill [27caaa6] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) rtems/score/thread*.h: TERMINTING to TERMINATING Wed, 28 May 2014 15:17:29 GMT Sebastian Huber [5f0ab5cf] * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) shell: Make rtems_global_shell_env public Provide ... Mon, 26 May 2014 13:22:12 GMT Daniel Hellstrom [d6f1ec91] * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) SPARC: syscall optimizations and PSR-write fix The last ... Mon, 26 May 2014 15:08:34 GMT Daniel Hellstrom [70eff78] * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) LEON3: coding style clean bsp_irq_fixup() Mon, 19 May 2014 20:52:18 GMT Daniel Hellstrom [3a76d830] * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) LEON3: add support for IRQ16..31 for CPU!=0 Sat, 24 May 2014 00:17:11 GMT Chris Johns [5b45d51] * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136jfs-testsuite.tcfg (added) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136js-testsuite.tcfg (added) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm7tdmi-testsuite.tcfg (added) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm920-testsuite.tcfg (added) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/armcortexa9-testsuite.tcfg (added) * c/src/lib/libbsp/avr/avrtest/make/custom/avrtest-testsuite.tcfg (added) * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim-testsuite.tcfg (added) * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim-testsuite.tcfg (added) * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg (added) * c/src/lib/libbsp/m32r/m32rsim/make/custom/m32rsim-testsuite.tcfg (added) * c/src/lib/libbsp/moxie/moxiesim/make/custom/moxiesim-testsuite.tcfg (added) * c/src/lib/libbsp/sh/shsim/make/custom/simsh1-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2e-testsuite.tcfg (added) * c/src/lib/libbsp/sh/shsim/make/custom/simsh4-testsuite.tcfg (added) * c/src/lib/libbsp/v850/gdbv850sim/make/custom/v850e1sim-testsuite.tcfg (added) * c/src/lib/libbsp/v850/gdbv850sim/make/custom/v850e2sim-testsuite.tcfg (added) * c/src/lib/libbsp/v850/gdbv850sim/make/custom/v850e2v3sim-testsuite.tcfg (added) * c/src/lib/libbsp/v850/gdbv850sim/make/custom/v850esim-testsuite.tcfg (added) * c/src/lib/libbsp/v850/gdbv850sim/make/custom/v850essim-testsuite.tcfg (added) * c/src/lib/libbsp/v850/gdbv850sim/make/custom/v850sim-testsuite.tcfg (added) bsps: Do not build tests that require a tick interrupt. The ... Mon, 19 May 2014 13:07:22 GMT Chris Johns [431bb85d] * testsuites/automake/test-subdirs.am (modified) * testsuites/testdata/require-tick-isr.tcfg (added) * tools/build/rtems-test-check (modified) rtems-test-check: Ignore tests which require real ISR based clock ... Wed, 28 May 2014 13:42:44 GMT Chris Johns [dac5696] * .gitignore (modified) Ignore emacs backfiles and TAGS. Wed, 28 May 2014 12:47:07 GMT Ralf Kirchner [7280fe3f] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c (modified) bsp/altera-cyclone-v: Cleanup Wed, 28 May 2014 12:47:06 GMT Ralf Kirchner [12a4d085] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv_devkit (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c (modified) bsp/altera-cyclone-v: Reduce size of nocache heap Network mbufs and ... Wed, 28 May 2014 12:47:05 GMT Ralf Kirchner [bb70bea1] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstart.c (modified) bsp/altera-cyclone-v: Cache mbufs and clusters Wed, 28 May 2014 12:47:03 GMT Ralf Kirchner [32c8960] * c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c (modified) bsp/altera-cyclone-v: Enable L2 cache for network driver Wed, 28 May 2014 12:47:01 GMT Ralf Kirchner [dda78f43] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c (modified) bsp/altera-vyclone-v: Broadcast cache maintenances Wed, 28 May 2014 12:47:02 GMT Ralf Kirchner [5fd4e35f] * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) bsp/arm: Broadcast cache maintenances Wed, 21 May 2014 08:33:43 GMT Sebastian Huber [8fcafdd5] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/attrimpl.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (added) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/mrsp.h (added) * cpukit/score/include/rtems/score/mrspimpl.h (added) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/preinstall.am (modified) * doc/user/Makefile.am (modified) * doc/user/conf.t (modified) * doc/user/sem.t (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpmrsp01/Makefile.am (added) * testsuites/smptests/smpmrsp01/init.c (added) * testsuites/smptests/smpmrsp01/smpmrsp01.doc (added) * testsuites/smptests/smpmrsp01/smpmrsp01.scn (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spmrsp01/Makefile.am (added) * testsuites/sptests/spmrsp01/init.c (added) * testsuites/sptests/spmrsp01/spmrsp01.doc (added) * testsuites/sptests/spmrsp01/spmrsp01.scn (added) score: Multiprocessor Resource Sharing Protocol Add basic support ... Thu, 08 May 2014 15:08:04 GMT Daniel Cederman [9f058fb] * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/console/erc32_console.c (modified) * c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/cchip/cchip.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/console/console.c (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon2/include/rasta.h (modified) * c/src/lib/libbsp/sparc/leon2/rasta/rasta.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) bsps/sparc: Change tabs to spaces. Thu, 08 May 2014 14:33:08 GMT Daniel Cederman [c903fc2] * c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/erc32/include/tm27.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/boardinit.S (modified) * c/src/lib/libbsp/sparc/leon2/cchip/cchip.c (modified) * c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon2/include/cchip.h (modified) * c/src/lib/libbsp/sparc/leon2/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon2/include/rasta.h (modified) * c/src/lib/libbsp/sparc/leon2/include/tm27.h (modified) * c/src/lib/libbsp/sparc/leon2/leon_open_eth/leon_open_eth.c (modified) * c/src/lib/libbsp/sparc/leon2/leon_smc91111/leon_smc91111.c (modified) * c/src/lib/libbsp/sparc/leon2/rasta/rasta.c (modified) * c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon3/include/tm27.h (modified) * c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c (modified) * c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c (modified) bsps/sparc: Add copyright and license information Thu, 08 May 2014 13:42:12 GMT Daniel Cederman [363b1f7] * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/console/erc32_console.c (modified) * c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/erc32.h (modified) * c/src/lib/libbsp/sparc/leon2/cchip/cchip.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon2/include/rasta.h (modified) * c/src/lib/libbsp/sparc/leon2/pci/pci.c (modified) * c/src/lib/libbsp/sparc/leon2/rasta/rasta.c (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c (modified) * c/src/lib/libbsp/sparc/leon3/pci/pci.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c (modified) bsps/sparc: Make lines in SPARC BSPs adhere to 80 character limit. Mon, 26 May 2014 11:48:36 GMT Chris Johns [97d0b9b] * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/irq/irq-dispatch.c (added) * c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c (added) * c/src/lib/libbsp/arm/gdbarmsim/preinstall.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/start/start.S (deleted) bsp/gdbarmsim: Switch to the standard arm/shared/startup. Switch to ... Fri, 23 May 2014 13:32:32 GMT Sebastian Huber [d134adeb] * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpfatal07/Makefile.am (deleted) * testsuites/smptests/smpfatal07/init.c (deleted) * testsuites/smptests/smpfatal07/smpfatal07.doc (deleted) * testsuites/smptests/smpfatal07/smpfatal07.scn (deleted) score: Fix race condition in SMP startup Do not use the ... Mon, 26 May 2014 01:44:48 GMT Chris Johns [b3fb2ff] * c/src/lib/libbsp/arm/gdbarmsim/console/console-io.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) * c/src/lib/libbsp/arm/gdbarmsim/startup/syscalls.c (modified) bsp/gdbarmsim: Change syscall functions to not clash with RTEMS ... Sat, 24 May 2014 01:01:34 GMT Chris Johns [5c123985] * rtems-bsps (added) tools: Add rtems-bsp to list BSPs in the source tree. This is a ... Fri, 23 May 2014 13:52:16 GMT Daniel Hellstrom [6a740c2] * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) SPARC: add syscall 1 (exit) function entry point The exit SPARC ... Fri, 23 May 2014 13:52:15 GMT Daniel Hellstrom [434e7f7] * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) SPARC: syscall code clean-up and minor optimizations Fri, 23 May 2014 13:51:51 GMT Sebastian Huber [b3049a1d] * cpukit/score/include/rtems/score/smpimpl.h (modified) score: Use _SMP_Fatal() Fri, 23 May 2014 12:27:12 GMT Daniel Hellstrom [0af322c] * cpukit/score/include/rtems/score/smpimpl.h (modified) SMP: make IPI fatal code unique The same smp fatal code is used in ... Thu, 22 May 2014 07:31:13 GMT Sebastian Huber [4edf348c] * cpukit/score/src/coremutex.c (modified) * testsuites/sptests/sp65/init.c (modified) * testsuites/sptests/sp65/sp65.doc (modified) score: PR2179: Fix initially locked PCP mutexes Elevate the ... Thu, 22 May 2014 23:05:46 GMT Joel Sherrill [decff888] * c/src/aclocal/check-smp.m4 (modified) c/src/aclocal/check-smp.m4: Use HAS_SMP not HAS_POSIX_API Mon, 19 May 2014 20:26:20 GMT Joel Sherrill [40741c44] * cpukit/score/src/cpuset.c (modified) cpuset.c: Fix formatting Thu, 22 May 2014 09:56:50 GMT Chris Johns [3cbedb1] * testsuites/samples/pppd/init.c (modified) testsuite: Add a user keypress to start pppd. Allow the test to run ... Thu, 22 May 2014 06:21:38 GMT Chris Johns [e9d98071] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) bsp/zynq: Add BSP_ZYNQ_RAM_LENGTH to allow a user to override the RAM ... Thu, 22 May 2014 06:15:34 GMT Chris Johns [18bd35bc] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) bsps/zynq: Add BSP_ARM_A9MPCORE_UARTCLK to set the UART clock rate. ... Sun, 27 Apr 2014 08:11:09 GMT Chris Johns [eae0863] * cpukit/rtems/src/clockgettod.c (modified) * testsuites/sptests/sp2038/init.c (modified) rtems: Fix sp2038 test. Avoid using newlib's gmtime_r call which ... Wed, 21 May 2014 07:30:14 GMT Sebastian Huber [a070c8b] * cpukit/rtems/src/semobtain.c (modified) rtems: Simplify rtems_semaphore_obtain() Wed, 21 May 2014 20:08:23 GMT Joel Sherrill [1bf0666] * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) schedulersmpimpl.h: Fix spacing Wed, 21 May 2014 08:30:34 GMT Sebastian Huber [82f90743] * cpukit/score/src/threadrestart.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/sptests/spthreadlife01/init.c (modified) score: _Thread_Set_life_protection() Enable usage of ... Wed, 21 May 2014 08:29:59 GMT Sebastian Huber [c8e83288] * cpukit/score/include/rtems/score/schedulerimpl.h (modified) score: Add and use _Scheduler_Get_index_by_id() Wed, 21 May 2014 08:29:36 GMT Sebastian Huber [4ddc3b5] * cpukit/score/include/rtems/score/schedulerimpl.h (modified) score: Add const qualifier Wed, 21 May 2014 07:18:29 GMT Sebastian Huber [884a6c59] * cpukit/score/src/wkspace.c (modified) score: Add comment regarding TLS workspace size Wed, 21 May 2014 06:30:25 GMT Sebastian Huber [40f2eafe] * cpukit/score/include/rtems/score/schedulerimpl.h (modified) score: Simplify _Scheduler_Set() Tue, 20 May 2014 08:03:35 GMT Sebastian Huber [e5274df] * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/taskgetscheduler.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * doc/user/smp.t (modified) rtems: Clarify task set/get scheduler parameters
