# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 17:28:35 Mon, 25 Feb 2019 14:33:31 GMT Sebastian Huber [6016894e] * bsps/arm/lpc176x/config/lpc1768_mbed-testsuite.tcfg (modified) * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram-testsuite.tcfg (modified) * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) bsp/lpc1768_mbed*: Disable unsupported tests Mon, 25 Feb 2019 13:37:45 GMT Sebastian Huber [5ff61810] * bsps/powerpc/mpc55xxevb/config/mpc5643l_dpu-testsuite.tcfg (modified) * bsps/powerpc/mpc55xxevb/config/mpc5643l_evb-testsuite.tcfg (modified) bsp/mpc5643l_*: Disable unsupported tests Mon, 25 Feb 2019 12:47:42 GMT Sebastian Huber [77971b6] * bsps/arm/lm3s69xx/config/lm4f120-testsuite.tcfg (modified) bsp/lm4f120: Disable unsupported tests Fri, 01 Mar 2019 10:00:35 GMT Sebastian Huber [e6dd36ca] * bsps/powerpc/gen5200/bestcomm/bestcomm_api.c (modified) bsp/gen5200: Remove offending @mainpage Update #3705. Fri, 01 Mar 2019 09:10:19 GMT Sebastian Huber [03b2163] * cpukit/score/src/scheduleredfreleasejob.c (modified) * testsuites/sptests/spedfsched02/init.c (modified) * testsuites/sptests/spedfsched02/spedfsched02.doc (modified) score: Fix _Scheduler_EDF_Cancel_job() Remove the priority node ... Thu, 28 Feb 2019 10:21:40 GMT Sebastian Huber [a3db5001] * bsps/arm/altera-cyclone-v/include/bsp.h (modified) bsp/altera-cyclone-v: Enable FIQ for group 0 irqs Thu, 28 Feb 2019 09:40:10 GMT Sebastian Huber [76918e1] * bsps/arm/include/bsp/arm-gic-irq.h (modified) * bsps/arm/shared/irq/irq-gic.c (modified) bsps/arm: Add BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0 The following ... Thu, 28 Feb 2019 10:35:53 GMT Sebastian Huber [8e8e269] * bsps/arm/include/bsp/arm-gic-regs.h (modified) bsps/arm: Fix typo Wed, 27 Feb 2019 14:10:53 GMT Sebastian Huber [e33be09] * bsps/arm/include/bsp/arm-gic-irq.h (modified) * bsps/arm/include/bsp/arm-gic-regs.h (modified) * bsps/arm/include/bsp/arm-gic.h (modified) * bsps/arm/shared/irq/irq-gic.c (modified) bsps/arm: Support GIC group 0/1 Wed, 27 Feb 2019 09:53:30 GMT Sebastian Huber [feea03b6] * bsps/arm/include/bsp/arm-errata.h (modified) * bsps/arm/include/bsp/arm-release-id.h (modified) * bsps/arm/include/cmsis_gcc.h (modified) * bsps/arm/include/core_cm7.h (modified) * bsps/arm/include/core_cmFunc.h (modified) * bsps/arm/include/core_cmInstr.h (modified) * bsps/arm/include/core_cmSimd.h (modified) * bsps/arm/lpc176x/btimer/btimer.c (modified) * bsps/arm/lpc176x/can/can.c (modified) * bsps/arm/lpc176x/gpio/lpc-gpio.c (modified) * bsps/arm/lpc176x/include/bsp/adc-defs.h (modified) * bsps/arm/lpc176x/include/bsp/adc.h (modified) * bsps/arm/lpc176x/include/bsp/can-defs.h (modified) * bsps/arm/lpc176x/include/bsp/can.h (modified) * bsps/arm/lpc176x/include/bsp/common-types.h (modified) * bsps/arm/lpc176x/include/bsp/gpio-defs.h (modified) * bsps/arm/lpc176x/include/bsp/io-defs.h (modified) * bsps/arm/lpc176x/include/bsp/io.h (modified) * bsps/arm/lpc176x/include/bsp/lpc-gpio.h (modified) * bsps/arm/lpc176x/include/bsp/lpc176x.h (modified) * bsps/arm/lpc176x/include/bsp/mbed-pinmap.h (modified) * bsps/arm/lpc176x/include/bsp/pwmout-defs.h (modified) * bsps/arm/lpc176x/include/bsp/pwmout.h (modified) * bsps/arm/lpc176x/include/bsp/timer-defs.h (modified) * bsps/arm/lpc176x/include/bsp/timer.h (modified) * bsps/arm/lpc176x/include/bsp/watchdog-defs.h (modified) * bsps/arm/lpc176x/include/bsp/watchdog.h (modified) * bsps/arm/lpc176x/pwm/pwmout.c (modified) * bsps/arm/lpc176x/start/adc.c (modified) * bsps/arm/lpc176x/start/bspstarthooks.c (modified) * bsps/arm/lpc176x/start/io.c (modified) * bsps/arm/lpc176x/start/watchdog.c (modified) * bsps/arm/lpc176x/timer/timer.c (modified) * bsps/arm/lpc32xx/include/tm27.h (modified) * bsps/arm/raspberrypi/gpio/gpio-interfaces-pi1-rev2.c (modified) * bsps/arm/raspberrypi/gpio/rpi-gpio.c (modified) * bsps/arm/raspberrypi/i2c/i2c.c (modified) * bsps/arm/raspberrypi/include/bsp/i2c.h (modified) * bsps/arm/raspberrypi/include/bsp/raspberrypi.h (modified) * bsps/arm/raspberrypi/include/bsp/rpi-gpio.h (modified) * bsps/arm/raspberrypi/include/bsp/spi.h (modified) * bsps/arm/raspberrypi/irq/irq.c (modified) * bsps/arm/raspberrypi/spi/spi.c (modified) * bsps/arm/shared/start/bsp-start-init-registers.S (modified) * bsps/arm/tms570/clock/clock.c (modified) * bsps/arm/tms570/console/printk-support.c (modified) * bsps/arm/tms570/console/tms570-sci.c (modified) * bsps/arm/tms570/include/bsp.h (modified) * bsps/arm/tms570/include/bsp/irq.h (modified) * bsps/arm/tms570/include/bsp/system-clocks.h (modified) * bsps/arm/tms570/include/bsp/tms570-pinmux.h (modified) * bsps/arm/tms570/include/bsp/tms570-pins.h (modified) * bsps/arm/tms570/include/bsp/tms570-pom.h (modified) * bsps/arm/tms570/include/bsp/tms570-rti.h (modified) * bsps/arm/tms570/include/bsp/tms570-sci-driver.h (modified) * bsps/arm/tms570/include/bsp/tms570-sci.h (modified) * bsps/arm/tms570/include/bsp/tms570-vim.h (modified) * bsps/arm/tms570/include/bsp/tms570_selftest.h (modified) * bsps/arm/tms570/include/bsp/tms570_selftest_parity.h (modified) * bsps/arm/tms570/include/bsp/tms570lc4357-pins.h (modified) * bsps/arm/tms570/include/bsp/tms570ls3137zwt-pins.h (modified) * bsps/arm/tms570/irq/irq.c (modified) * bsps/arm/tms570/start/bspreset.c (modified) * bsps/arm/tms570/start/bspstart.c (modified) * bsps/arm/tms570/start/bspstarthooks.c (modified) * bsps/arm/tms570/start/init_emif_sdram.c (modified) * bsps/arm/tms570/start/init_esm.c (modified) * bsps/arm/tms570/start/init_pinmux.c (modified) * bsps/arm/tms570/start/init_system.c (modified) * bsps/arm/tms570/start/pinmux.c (modified) * bsps/arm/tms570/start/tms570-pom.c (modified) * bsps/arm/tms570/start/tms570_selftest.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_can.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_mibspi.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_std.c (modified) * bsps/arm/tms570/start/tms570_selftest_parity.c (modified) * bsps/arm/tms570/start/tms570_tcram_tests.c (modified) * bsps/bfin/TLL6527M/console/console.c (modified) * bsps/bfin/TLL6527M/include/bsp.h (modified) * bsps/bfin/TLL6527M/start/interrupt.c (modified) * bsps/bfin/include/bf52x.h (modified) * bsps/bfin/include/bsp/interrupt.h (modified) * bsps/i386/include/bsp/realmode_int.h (modified) * bsps/i386/include/libcpu/page.h (modified) * bsps/i386/pc386/console/fb_vesa_rm.c (modified) * bsps/i386/pc386/include/bsp/fb_default_mode.h (modified) * bsps/i386/pc386/include/bsp/fb_vesa.h (modified) * bsps/i386/pc386/include/bsp/vbe3.h (modified) * bsps/i386/pc386/include/edid.h (modified) * bsps/i386/pc386/start/realmode_int.c (modified) * bsps/include/bsp/gpio.h (modified) * bsps/powerpc/include/rtems/powerpc/powerpc.h (modified) * bsps/powerpc/virtex4/start/start.S (modified) * bsps/powerpc/virtex5/start/start.S (modified) * bsps/shared/dev/gpio/gpio-support.c (modified) * cpukit/include/memory.h (modified) * cpukit/include/rtems/assoc.h (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/include/rtems/bspcmdline.h (modified) * cpukit/include/rtems/btimer.h (modified) * cpukit/include/rtems/capture-cli.h (modified) * cpukit/include/rtems/capture.h (modified) * cpukit/include/rtems/captureimpl.h (modified) * cpukit/include/rtems/concat.h (modified) * cpukit/include/rtems/cpuuse.h (modified) * cpukit/include/rtems/devfs.h (modified) * cpukit/include/rtems/devzero.h (modified) * cpukit/include/rtems/endian.h (modified) * cpukit/include/rtems/error.h (modified) * cpukit/include/rtems/fb.h (modified) * cpukit/include/rtems/framebuffer.h (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/include/rtems/fsmount.h (modified) * cpukit/include/rtems/gxx_wrappers.h (modified) * cpukit/include/rtems/inttypes.h (modified) * cpukit/include/rtems/iosupp.h (modified) * cpukit/include/rtems/irq.h (modified) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/monitor.h (modified) * cpukit/include/rtems/mouse_parser.h (modified) * cpukit/include/rtems/mw_uid.h (modified) * cpukit/include/rtems/nvdisk-sram.h (modified) * cpukit/include/rtems/nvdisk.h (modified) * cpukit/include/rtems/pci.h (modified) * cpukit/include/rtems/posix/timer.h (modified) * cpukit/include/rtems/print.h (modified) * cpukit/include/rtems/printer.h (modified) * cpukit/include/rtems/qreslib.h (modified) * cpukit/include/rtems/rtems/asr.h (modified) * cpukit/include/rtems/rtems/attr.h (modified) * cpukit/include/rtems/rtems/clock.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/eventmp.h (modified) * cpukit/include/rtems/rtems/intr.h (modified) * cpukit/include/rtems/rtems/mainpage.h (modified) * cpukit/include/rtems/rtems/modes.h (modified) * cpukit/include/rtems/rtems/mp.h (modified) * cpukit/include/rtems/rtems/msgmp.h (modified) * cpukit/include/rtems/rtems/object.h (modified) * cpukit/include/rtems/rtems/options.h (modified) * cpukit/include/rtems/rtems/partmp.h (modified) * cpukit/include/rtems/rtems/ratemon.h (modified) * cpukit/include/rtems/rtems/semmp.h (modified) * cpukit/include/rtems/rtems/signalmp.h (modified) * cpukit/include/rtems/rtems/status.h (modified) * cpukit/include/rtems/rtems/taskmp.h (modified) * cpukit/include/rtems/score/address.h (modified) * cpukit/include/rtems/score/context.h (modified) * cpukit/include/rtems/score/copyrt.h (modified) * cpukit/include/rtems/score/corebarrier.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coresem.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/isr.h (modified) * cpukit/include/rtems/score/isrlevel.h (modified) * cpukit/include/rtems/score/mppkt.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/include/rtems/score/objectmp.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/prioritybitmap.h (modified) * cpukit/include/rtems/score/rbtree.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulercbs.h (modified) * cpukit/include/rtems/score/scheduleredf.h (modified) * cpukit/include/rtems/score/schedulerpriority.h (modified) * cpukit/include/rtems/score/schedulersimple.h (modified) * cpukit/include/rtems/score/stack.h (modified) * cpukit/include/rtems/score/states.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/include/rtems/score/threadqimpl.h (modified) * cpukit/include/rtems/score/timespec.h (modified) * cpukit/include/rtems/score/timestamp.h (modified) * cpukit/include/rtems/score/timestampimpl.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/include/rtems/seterr.h (modified) * cpukit/include/rtems/shell.h (modified) * cpukit/include/rtems/shellconfig.h (modified) * cpukit/include/rtems/spurious.h (modified) * cpukit/include/rtems/stackchk.h (modified) * cpukit/include/rtems/stringto.h (modified) * cpukit/include/rtems/termiostypes.h (modified) * cpukit/include/rtems/watchdogdrv.h (modified) * cpukit/include/sys/statvfs.h (modified) * cpukit/libfs/src/dosfs/msdos_statvfs.c (modified) * cpukit/libmisc/capture/capture_buffer.h (modified) * cpukit/libnetworking/rtems/bsdnet/servers.h (modified) * cpukit/libnetworking/rtems/mkrootfs.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/rtems/include/rtems/rtems/barriermp.h (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/score/cpu/epiphany/include/rtems/asm.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/epiphany.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/include/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/mips/include/rtems/score/mips.h (modified) * cpukit/score/cpu/moxie/include/rtems/asm.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/moxie.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/asm.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/asm.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/or1k.h (modified) * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/riscv.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) Remove explicit file names from @file This makes the @file ... Wed, 27 Feb 2019 10:43:49 GMT Sebastian Huber [262cb534] * bsps/arm/altera-cyclone-v/contrib/hwlib/src/hwmgr/alt_qspi.h (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) bsp/altera-cyclone-v: Move header file This gets rid of a special ... Thu, 21 Feb 2019 06:01:22 GMT Christian Mauderer [e99847bf] * cpukit/dev/serial/sc16is752.c (modified) dev/sc16is752: Fix parity generation. Mon, 25 Feb 2019 22:30:11 GMT Pierre-Louis Garnier [68a5f751] * bsps/arm/beagle/simscripts/sdcard.sh (modified) arm/beagle: Fix sdcard.sh tool Mon, 25 Feb 2019 22:30:09 GMT Pierre-Louis Garnier [ecf62845] * bsps/arm/beagle/headers.am (modified) * bsps/arm/beagle/include/bsp.h (modified) * bsps/arm/beagle/include/bsp/spi.h (added) * bsps/arm/beagle/spi/spi.c (added) * bsps/arm/include/libcpu/am335x.h (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) arm/beagle: SPI driver Thu, 21 Feb 2019 22:13:58 GMT Kinsey Moore [7abc497] * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) bsps/arm: Fix system register for virtual timer The system register ... Mon, 18 Feb 2019 02:28:10 GMT Chris Johns [c5615ddc] * cpukit/libdl/rtl-unresolved.c (modified) libdl/unresolved: Fix return value for rtems_rtl_unresolved_remove ... Mon, 18 Feb 2019 01:37:05 GMT Chris Johns [7aa0530] * cpukit/libdl/rtl-archive.c (modified) libdl/archive: Check for an overflow of the symbol table. Coverty ... Mon, 18 Feb 2019 01:18:50 GMT Chris Johns [62b01ab] * cpukit/include/rtems/rtl/rtl-archive.h (modified) * cpukit/libdl/rtl-archive.c (modified) libdl/archive: Fix the config file string index while removing ... Mon, 18 Feb 2019 01:12:53 GMT Chris Johns [be62def9] * cpukit/libdl/rtl-archive.c (modified) libdl/archive: Return false on read failure. Coverity issue 1442641 ... Mon, 18 Feb 2019 00:46:22 GMT Chris Johns [22afb034] * cpukit/include/rtems/rtl/rtl-allocator.h (modified) * cpukit/libdl/rtl-alloc-heap.c (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-elf.c (modified) libdl/alloc: Add a locking interface to the allocator. - Allow an ... Mon, 18 Feb 2019 08:01:27 GMT Sebastian Huber [bdec62c4] * bsps/arm/shared/start/start.S (modified) bsps/arm: Move device tree copy Move device tree copy operation ... Mon, 18 Feb 2019 07:24:37 GMT Sebastian Huber [af80b0a] * bsps/arm/altera-cyclone-v/include/bsp.h (modified) * bsps/arm/altera-cyclone-v/start/bspstart.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) bsp/altera-cyclone-v: Use FDT for clock frequency Fri, 15 Feb 2019 11:07:23 GMT Sebastian Huber [43fbb50f] * bsps/arm/altera-cyclone-v/include/bsp.h (modified) * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (modified) * bsps/arm/altera-cyclone-v/start/bspstart.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) bsp/altera-cyclone-v: Make FDT support optional Mon, 18 Feb 2019 07:32:42 GMT Sebastian Huber [3d65f45] * testsuites/psxtests/psxonce01/init.c (modified) psxtests/psxonce01: Fix typo Update #3334. Tue, 12 Feb 2019 11:19:38 GMT Sebastian Huber [e4ad14cc] * cpukit/include/rtems/score/onceimpl.h (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/score/src/once.c (modified) * testsuites/psxtests/psxonce01/init.c (modified) * testsuites/psxtests/psxonce01/psxonce01.scn (modified) * testsuites/psxtests/psxonce01/system.h (modified) * testsuites/sptests/spcxx01/init.cc (modified) * testsuites/sptests/spcxx01/spcxx01.doc (modified) score: Avoid some deadlocks in _Once() Recursive usage of the same ... Thu, 14 Feb 2019 23:38:41 GMT Chris Johns [3ecb207] * cpukit/libdl/rtl-rap.c (modified) libdl/rap: Add the section alloc call after section load was split ... Thu, 14 Feb 2019 03:00:05 GMT Chris Johns [e309f77] * cpukit/include/rtems/rtl/rtl-allocator.h (modified) * cpukit/libdl/rtl-alloc-heap.c (modified) * cpukit/libdl/rtl-alloc-heap.h (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-obj.c (modified) libdl: Allocator does not unlock and lock memory on loading. Close #3692 Tue, 12 Feb 2019 12:18:56 GMT Sebastian Huber [e214ff4b] * cpukit/include/rtems/posix/posixapi.h (modified) posix: Remove unused _POSIX_Get_object_body() Tue, 12 Feb 2019 09:26:34 GMT Sebastian Huber [7fdcd023] * testsuites/psxtests/psxhdrs/math/expm1. (deleted) psxtests: Remove bogus file This file is unused and makes trouble ... Mon, 11 Feb 2019 06:34:14 GMT Sebastian Huber [eec706e2] * bsps/powerpc/include/bsp/linker-symbols.h (modified) * bsps/powerpc/psim/start/linkcmds (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) bsps/powerpc: Fix small data area section Fix small data area in ... Sat, 02 Feb 2019 04:09:53 GMT Chris Johns [6c9f017] * bsps/powerpc/psim/start/linkcmds (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-bit-alloc.c (added) * cpukit/libdl/rtl-bit-alloc.h (added) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/dl01/dl-load.c (modified) * testsuites/libtests/dl02/dl-load.c (modified) * testsuites/libtests/dl02/dl-o1.c (modified) * testsuites/libtests/dl02/dl-o2.c (modified) * testsuites/libtests/dl03/dl-bit-alloc.c (added) * testsuites/libtests/dl03/dl-bit-alloc.h (added) * testsuites/libtests/dl03/init.c (modified) * testsuites/libtests/dl05/dl-load.c (modified) * testsuites/libtests/dl07/dl-load.c (modified) * testsuites/libtests/dl07/dl-o1.c (modified) * testsuites/libtests/dl07/dl-o2.c (modified) * testsuites/libtests/dl07/dl-o3.c (modified) * testsuites/libtests/dl07/dl-o4.c (modified) * testsuites/libtests/dl07/dl-o5.c (modified) * testsuites/libtests/dl07/init.c (modified) * testsuites/libtests/dl08/dl-o1.c (modified) * testsuites/libtests/dl08/dl-o2.c (modified) * testsuites/libtests/dl08/dl-o3.c (modified) * testsuites/libtests/dl08/dl-o4.c (modified) * testsuites/libtests/dl08/dl-o5.c (modified) * testsuites/libtests/dl08/dl-o6-123456789-123456789.c (modified) * testsuites/libtests/dl09/dl-load.c (modified) * testsuites/libtests/dl09/dl-o1.c (modified) * testsuites/libtests/dl09/dl-o2.c (modified) * testsuites/libtests/dl09/dl-o3.c (modified) * testsuites/libtests/dl09/dl-o4.c (modified) * testsuites/libtests/dl09/dl-o5.c (modified) libdl: Add powerpc large memory and small data support. - Add ... Mon, 21 Jan 2019 21:48:19 GMT Chris Johns [194eb403] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/rtl-archive.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/dl08/dl-load.c (modified) * testsuites/libtests/dl09/dl-load.c (modified) * testsuites/libtests/dl09/dl-o5.c (modified) libdl: Add support for large memory programs - Add trampolines to ... Tue, 15 Jan 2019 06:47:41 GMT Chris Johns [d8c70ba6] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl01/dl-load.c (modified) * testsuites/libtests/dl08/dl-load.c (modified) * testsuites/libtests/dl09/dl-load.c (added) * testsuites/libtests/dl09/dl-load.h (added) * testsuites/libtests/dl09/dl-o1.c (added) * testsuites/libtests/dl09/dl-o1.h (added) * testsuites/libtests/dl09/dl-o2.c (added) * testsuites/libtests/dl09/dl-o2.h (added) * testsuites/libtests/dl09/dl-o3.c (added) * testsuites/libtests/dl09/dl-o3.h (added) * testsuites/libtests/dl09/dl-o4.c (added) * testsuites/libtests/dl09/dl-o4.h (added) * testsuites/libtests/dl09/dl-o5.c (added) * testsuites/libtests/dl09/dl-o5.h (added) * testsuites/libtests/dl09/dl09.doc (added) * testsuites/libtests/dl09/dl09.scn (added) * testsuites/libtests/dl09/init.c (added) libdl: Add support for trampolines - Trampolines or fixups for ... Wed, 09 Jan 2019 11:14:11 GMT Chris Johns [4408603] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * cpukit/score/cpu/arm/include/machine/elf_machdep.h (modified) * testsuites/libtests/dl08/dl-load.c (modified) libdl: Fix the support for constructors and desctructors. - Fix the ... Mon, 17 Dec 2018 06:48:30 GMT Chris Johns [a7c6176] * cpukit/headers.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl08/dl-load.c (added) * testsuites/libtests/dl08/dl-load.h (added) * testsuites/libtests/dl08/dl-o1.c (added) * testsuites/libtests/dl08/dl-o1.h (added) * testsuites/libtests/dl08/dl-o2.c (added) * testsuites/libtests/dl08/dl-o2.h (added) * testsuites/libtests/dl08/dl-o3.c (added) * testsuites/libtests/dl08/dl-o3.h (added) * testsuites/libtests/dl08/dl-o4.c (added) * testsuites/libtests/dl08/dl-o4.h (added) * testsuites/libtests/dl08/dl-o5.c (added) * testsuites/libtests/dl08/dl-o5.h (added) * testsuites/libtests/dl08/dl-o6-123456789-123456789.c (added) * testsuites/libtests/dl08/dl-o6.h (added) * testsuites/libtests/dl08/dl08.doc (added) * testsuites/libtests/dl08/dl08.scn (added) * testsuites/libtests/dl08/init.c (added) libtest/dl08: Add a test for archives. - Create 2 archives. - Load ... Mon, 17 Dec 2018 06:40:46 GMT Chris Johns [bac53634] * testsuites/libtests/dl07/dl-load.c (modified) libtests/dl02: Update the rtl-shell path. More verbose test. ... Mon, 17 Dec 2018 06:40:25 GMT Chris Johns [85b59974] * testsuites/libtests/dl02/dl-load.c (modified) libtests/dl02: Update the rtl-shell path. Updates #3686 Mon, 17 Dec 2018 05:36:48 GMT Chris Johns [89c59be] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtl/rtl-archive.h (added) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-shell.h (moved) * cpukit/include/rtems/rtl/rtl-trace.h (modified) * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rtl-archive.c (added) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-string.h (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) libdl: Add symbol searching and loading from archives. - Load ... Sat, 02 Feb 2019 04:32:38 GMT Chris Johns [b08278e] * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/psim/start/device-tree (modified) * bsps/powerpc/psim/start/linkcmds (modified) powerpc/psim: Increase the psim memory to 256M This allows test ... Sat, 02 Feb 2019 04:19:59 GMT Chris Johns [e2f13430] * cpukit/libdl/dlfcn.c (modified) libdl: Fix dlerror non-conformance Closes #3298 Sat, 02 Feb 2019 04:22:04 GMT Chris Johns [2d8a9c79] * cpukit/libmisc/dumpbuf/dumpbuf.c (modified) libmisc: Fix rtems_print_buffer Closes #3684 Fri, 08 Feb 2019 11:40:45 GMT Jiri Gaisler [568490a] * bsps/riscv/griscv/config/griscv.cfg (modified) * bsps/riscv/griscv/config/grv32i.cfg (added) * bsps/riscv/griscv/config/grv32im.cfg (added) * bsps/riscv/griscv/config/grv32imac.cfg (added) * bsps/riscv/griscv/config/grv32imafdc.cfg (added) griscv: add additional cpu configurations * Also switch ... Fri, 08 Feb 2019 09:16:07 GMT Sebastian Huber [26333f2a] * cpukit/include/rtems/score/userextimpl.h (modified) score: Fix _User_extensions_Thread_switch() (SMP) We have to read ... Thu, 07 Feb 2019 10:13:01 GMT Sebastian Huber [4e686261] * bsps/shared/irq/irq-server.c (modified) bsps/irq: Fix interrupt server init (SMP) Thu, 07 Feb 2019 06:46:38 GMT Sebastian Huber [fbd08066] * cpukit/score/src/threadqops.c (modified) * testsuites/smptests/smpmutex01/init.c (modified) score: Fix plain priority thread queues (SMP) We must add/remove ... Thu, 07 Feb 2019 06:45:58 GMT Sebastian Huber [0fb52ce] * bsps/arm/shared/clock/clock-generic-timer.c (modified) bsps/arm: Fix generic timer frequency Update #3456. Tue, 27 Nov 2018 11:45:53 GMT Sebastian Huber [03fcbb1] * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/imfs/imfs_dir_default.c (modified) * cpukit/libfs/src/jffs2/include/linux/fs.h (modified) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * testsuites/fstests/fsscandir01/init.c (modified) fs: Add struct dirent::d_type support Sat, 02 Feb 2019 10:03:13 GMT Sebastian Huber [9399473c] * cpukit/score/cpu/riscv/riscv-context-validate.S (modified) riscv: Fix misaligned access in context validate Mon, 28 Jan 2019 11:26:25 GMT Sebastian Huber [b015c01] * testsuites/aclocal/env-rtemsbsp.m4 (modified) * testsuites/benchmarks/Makefile.am (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtmtests/Makefile.am (modified) * testsuites/rhealstone/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/tmtests/Makefile.am (modified) build: Do not install test programs Wed, 30 Jan 2019 08:41:49 GMT Sebastian Huber [03cdd5ea] * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record.c (modified) * testsuites/libtests/record01/init.c (modified) * testsuites/libtests/record02/init.c (modified) record: Add enum value for each event Update #3665. Sat, 28 Apr 2018 09:36:11 GMT Sebastian Huber [dca6184] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/record.h (added) * cpukit/include/rtems/recordclient.h (added) * cpukit/include/rtems/recorddata.h (added) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/libtrace/record/record-client.c (added) * cpukit/libtrace/record/record-server.c (added) * cpukit/libtrace/record/record-sysinit.c (added) * cpukit/libtrace/record/record-text.c (added) * cpukit/libtrace/record/record-userext.c (added) * cpukit/libtrace/record/record.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/record01/init.c (added) * testsuites/libtests/record01/record01.doc (added) * testsuites/libtests/record01/record01.scn (added) * testsuites/libtests/record02/init.c (added) * testsuites/libtests/record02/record02.doc (added) * testsuites/libtests/record02/record02.scn (added) Add low level event recording support Add low level event recording ... Thu, 17 Jan 2019 06:33:08 GMT Sebastian Huber [f0ae613b] * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) m68k: Avoid _Addresses_Add_offset() This prevents a cyclic ... Tue, 29 Jan 2019 12:26:12 GMT Sebastian Huber [e74a3fd] * testsuites/samples/pppd/system.h (modified) samples/pppd: Use less memory hungry configuration This avoids ... Mon, 28 Jan 2019 13:16:39 GMT Sebastian Huber [4f3a253] * testsuites/psxtmtests/psxtmbarrierattr01/init.c (modified) * testsuites/psxtmtests/psxtmcleanup01/init.c (modified) * testsuites/psxtmtests/psxtmmutexattr01/init.c (modified) * testsuites/psxtmtests/psxtmonce01/init.c (modified) psxtmtests: Fix format warnings Update #3384. Fri, 25 Jan 2019 14:50:14 GMT Sebastian Huber [b1381ae] * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/shared/exceptions/ppc_exc_initialize.c (modified) bsps/powerpc: Fix warnings Thu, 24 Jan 2019 13:29:03 GMT Sebastian Huber [81aec18] * bsps/powerpc/include/libcpu/powerpc-utility.h (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/powerpc/shared/cpu_asm.S (modified) * bsps/powerpc/shared/start/bsp-start-zero.S (modified) bsps/powerpc: Fix 64-bit issues in assembler files We have to be ... Wed, 23 Jan 2019 12:17:44 GMT Maksim E. Kozlov [afd50b3] * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) libmisc: Fix swapped parameters and enable floating point usage. Fri, 18 Jan 2019 11:37:55 GMT Jiri Gaisler [d3d4e77] * bsps/riscv/griscv/clock/clockdrv.c (added) * bsps/riscv/griscv/config/griscv.cfg (added) * bsps/riscv/griscv/console/console.c (added) * bsps/riscv/griscv/console/printk_support.c (added) * bsps/riscv/griscv/headers.am (added) * bsps/riscv/griscv/include/amba.h (added) * bsps/riscv/griscv/include/bsp.h (added) * bsps/riscv/griscv/include/bsp/irq.h (added) * bsps/riscv/griscv/include/tm27.h (added) * bsps/riscv/griscv/irq/irq.c (added) * bsps/riscv/griscv/start/amba.c (added) * bsps/riscv/griscv/start/bsp_fatal_halt.c (added) * bsps/riscv/griscv/start/bsp_specs (added) * bsps/riscv/griscv/start/bspsmp.c (added) * bsps/riscv/griscv/start/bspstart.c (added) * bsps/riscv/griscv/start/linkcmds.in (added) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/shared/start/linkcmds.base (moved) * bsps/riscv/shared/start/start.S (moved) * c/src/lib/libbsp/riscv/acinclude.m4 (modified) * c/src/lib/libbsp/riscv/griscv/Makefile.am (added) * c/src/lib/libbsp/riscv/griscv/configure.ac (added) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: add griscv bsp Update #3678. Mon, 21 Jan 2019 10:27:07 GMT Jiri Gaisler [c1dcd6af] * bsps/include/grlib/grlib_impl.h (modified) * bsps/shared/grlib/spw/grspw.c (modified) grlib: make memory coherency cpu-independent Update #3678. Fri, 18 Jan 2019 17:00:47 GMT Jiri Gaisler [9b2b389] * bsps/include/grlib/grlib_impl.h (modified) * bsps/shared/grlib/1553/b1553brm.c (modified) * bsps/shared/grlib/1553/b1553rt.c (modified) * bsps/shared/grlib/can/grcan.c (modified) * bsps/shared/grlib/pci/grpci2dma.c (modified) * bsps/shared/grlib/spw/grspw.c (modified) * bsps/shared/grlib/spw/grspw_pkt.c (modified) * cpukit/score/cpu/riscv/headers.am (modified) * cpukit/score/cpu/riscv/include/libcpu/access.h (added) * cpukit/score/cpu/riscv/include/libcpu/byteorder.h (added) grlib: use cpu-independent routines for uncached access Update #3678. Fri, 18 Jan 2019 10:29:08 GMT Jiri Gaisler [5981c8ca] * bsps/shared/grlib/ascs/grascs.c (modified) * bsps/shared/grlib/can/satcan.c (modified) * bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c (modified) * bsps/shared/grlib/slink/grslink.c (modified) grlib: use rtems_interrupt_handler_install() Update #3678. Fri, 18 Jan 2019 10:24:18 GMT Jiri Gaisler [411c297] * bsps/include/grlib/apbuart.h (modified) * bsps/shared/grlib/uart/apbuart_cons.c (modified) * bsps/sparc/leon2/include/leon.h (modified) grlib: make apbuart driver independent of bsp Update #3678. Sat, 22 Dec 2018 17:31:04 GMT Sebastian Huber [7eb606d3] * bsps/shared/grlib-sources.am (added) * bsps/shared/grlib/1553/b1553brm.c (moved) * bsps/shared/grlib/1553/b1553rt.c (moved) * bsps/shared/grlib/1553/gr1553b.c (moved) * bsps/shared/grlib/1553/gr1553bc.c (moved) * bsps/shared/grlib/1553/gr1553bm.c (moved) * bsps/shared/grlib/1553/gr1553rt.c (moved) * bsps/shared/grlib/amba/ahbstat.c (moved) * bsps/shared/grlib/amba/ambapp.c (moved) * bsps/shared/grlib/amba/ambapp_alloc.c (moved) * bsps/shared/grlib/amba/ambapp_count.c (moved) * bsps/shared/grlib/amba/ambapp_depth.c (moved) * bsps/shared/grlib/amba/ambapp_find_by_idx.c (moved) * bsps/shared/grlib/amba/ambapp_freq.c (moved) * bsps/shared/grlib/amba/ambapp_names.c (moved) * bsps/shared/grlib/amba/ambapp_old.c (moved) * bsps/shared/grlib/amba/ambapp_parent.c (moved) * bsps/shared/grlib/amba/ambapp_show.c (moved) * bsps/shared/grlib/analog/gradcdac.c (moved) * bsps/shared/grlib/ascs/grascs.c (moved) * bsps/shared/grlib/btimer/gptimer.c (moved) * bsps/shared/grlib/btimer/tlib.c (moved) * bsps/shared/grlib/btimer/tlib_ckinit.c (moved) * bsps/shared/grlib/can/canmux.c (moved) * bsps/shared/grlib/can/grcan.c (moved) * bsps/shared/grlib/can/occan.c (moved) * bsps/shared/grlib/can/satcan.c (moved) * bsps/shared/grlib/drvmgr/ambapp_bus.c (moved) * bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c (moved) * bsps/shared/grlib/drvmgr/get_resarray_count.c (moved) * bsps/shared/grlib/gpio/gpiolib.c (moved) * bsps/shared/grlib/gpio/grgpio.c (moved) * bsps/shared/grlib/i2c/i2cmst.c (moved) * bsps/shared/grlib/iommu/griommu.c (moved) * bsps/shared/grlib/irq/genirq.c (moved) * bsps/shared/grlib/l2c/l2c.c (moved) * bsps/shared/grlib/mem/mctrl.c (moved) * bsps/shared/grlib/net/README (moved) * bsps/shared/grlib/net/greth.c (moved) * bsps/shared/grlib/net/network_interface_add.c (moved) * bsps/shared/grlib/pci/gr_701.c (moved) * bsps/shared/grlib/pci/gr_rasta_adcdac.c (moved) * bsps/shared/grlib/pci/gr_rasta_io.c (moved) * bsps/shared/grlib/pci/gr_rasta_spw_router.c (moved) * bsps/shared/grlib/pci/gr_rasta_tmtc.c (moved) * bsps/shared/grlib/pci/gr_tmtc_1553.c (moved) * bsps/shared/grlib/pci/grpci.c (moved) * bsps/shared/grlib/pci/grpci2.c (moved) * bsps/shared/grlib/pci/grpci2dma.c (moved) * bsps/shared/grlib/pci/pcif.c (moved) * bsps/shared/grlib/pwm/grpwm.c (moved) * bsps/shared/grlib/scrub/memscrub.c (moved) * bsps/shared/grlib/slink/grslink.c (moved) * bsps/shared/grlib/spi/spictrl.c (moved) * bsps/shared/grlib/spw/grspw.c (moved) * bsps/shared/grlib/spw/grspw_pkt.c (moved) * bsps/shared/grlib/spw/grspw_router.c (moved) * bsps/shared/grlib/spw/spwtdp.c (moved) * bsps/shared/grlib/stat/l4stat.c (moved) * bsps/shared/grlib/time/grctm.c (moved) * bsps/shared/grlib/time/spwcuc.c (moved) * bsps/shared/grlib/tmtc/grtc.c (moved) * bsps/shared/grlib/tmtc/grtm.c (moved) * bsps/shared/grlib/uart/apbuart_cons.c (moved) * bsps/shared/grlib/uart/apbuart_polled.c (moved) * bsps/shared/grlib/uart/apbuart_termios.c (moved) * bsps/shared/grlib/uart/cons.c (moved) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) grlib: Move source files Update #3678. Sat, 22 Dec 2018 06:13:44 GMT Sebastian Huber [31720925] * bsps/headers.am (modified) * bsps/include/grlib/ahbstat.h (moved) * bsps/include/grlib/ambapp.h (moved) * bsps/include/grlib/ambapp_bus.h (moved) * bsps/include/grlib/ambapp_bus_grlib.h (moved) * bsps/include/grlib/ambapp_ids.h (moved) * bsps/include/grlib/apbuart.h (moved) * bsps/include/grlib/apbuart_cons.h (moved) * bsps/include/grlib/apbuart_termios.h (moved) * bsps/include/grlib/b1553brm.h (moved) * bsps/include/grlib/b1553rt.h (moved) * bsps/include/grlib/bspcommon.h (moved) * bsps/include/grlib/canmux.h (moved) * bsps/include/grlib/cons.h (moved) * bsps/include/grlib/debug_defs.h (moved) * bsps/include/grlib/genirq.h (moved) * bsps/include/grlib/gpiolib.h (moved) * bsps/include/grlib/gptimer.h (moved) * bsps/include/grlib/gr1553b.h (moved) * bsps/include/grlib/gr1553bc.h (moved) * bsps/include/grlib/gr1553bc_list.h (moved) * bsps/include/grlib/gr1553bm.h (moved) * bsps/include/grlib/gr1553rt.h (moved) * bsps/include/grlib/gr_701.h (moved) * bsps/include/grlib/gr_cpci_gr740.h (moved) * bsps/include/grlib/gr_rasta_adcdac.h (moved) * bsps/include/grlib/gr_rasta_io.h (moved) * bsps/include/grlib/gr_rasta_spw_router.h (moved) * bsps/include/grlib/gr_rasta_tmtc.h (moved) * bsps/include/grlib/gr_tmtc_1553.h (moved) * bsps/include/grlib/gradcdac.h (moved) * bsps/include/grlib/grascs.h (moved) * bsps/include/grlib/grcan.h (moved) * bsps/include/grlib/grctm.h (moved) * bsps/include/grlib/greth.h (moved) * bsps/include/grlib/grgpio.h (moved) * bsps/include/grlib/griommu.h (moved) * bsps/include/grlib/grlib.h (moved) * bsps/include/grlib/grlib_impl.h (moved) * bsps/include/grlib/grpci.h (moved) * bsps/include/grlib/grpci2.h (moved) * bsps/include/grlib/grpci2dma.h (moved) * bsps/include/grlib/grpwm.h (moved) * bsps/include/grlib/grslink.h (moved) * bsps/include/grlib/grspw.h (moved) * bsps/include/grlib/grspw_pkt.h (moved) * bsps/include/grlib/grspw_router.h (moved) * bsps/include/grlib/grtc.h (moved) * bsps/include/grlib/grtm.h (moved) * bsps/include/grlib/i2cmst.h (moved) * bsps/include/grlib/l2c.h (moved) * bsps/include/grlib/l4stat.h (moved) * bsps/include/grlib/mctrl.h (moved) * bsps/include/grlib/memscrub.h (moved) * bsps/include/grlib/network_interface_add.h (moved) * bsps/include/grlib/occan.h (moved) * bsps/include/grlib/pcif.h (moved) * bsps/include/grlib/satcan.h (moved) * bsps/include/grlib/spictrl.h (moved) * bsps/include/grlib/spwcuc.h (moved) * bsps/include/grlib/spwtdp.h (moved) * bsps/include/grlib/tlib.h (moved) * bsps/sparc/headers.am (modified) * bsps/sparc/include/drvmgr/leon2_amba_bus.h (modified) * bsps/sparc/leon2/include/leon.h (modified) * bsps/sparc/leon3/btimer/watchdog.c (modified) * bsps/sparc/leon3/clock/ckinit.c (modified) * bsps/sparc/leon3/console/console.c (modified) * bsps/sparc/leon3/console/printk_support.c (modified) * bsps/sparc/leon3/include/amba.h (modified) * bsps/sparc/leon3/net/leon_smc91111.c (modified) * bsps/sparc/leon3/start/amba.c (modified) * bsps/sparc/shared/1553/b1553brm.c (modified) * bsps/sparc/shared/1553/b1553rt.c (modified) * bsps/sparc/shared/1553/gr1553b.c (modified) * bsps/sparc/shared/1553/gr1553bc.c (modified) * bsps/sparc/shared/1553/gr1553bm.c (modified) * bsps/sparc/shared/1553/gr1553rt.c (modified) * bsps/sparc/shared/amba/ahbstat.c (modified) * bsps/sparc/shared/amba/ambapp.c (modified) * bsps/sparc/shared/amba/ambapp_alloc.c (modified) * bsps/sparc/shared/amba/ambapp_count.c (modified) * bsps/sparc/shared/amba/ambapp_depth.c (modified) * bsps/sparc/shared/amba/ambapp_find_by_idx.c (modified) * bsps/sparc/shared/amba/ambapp_freq.c (modified) * bsps/sparc/shared/amba/ambapp_names.c (modified) * bsps/sparc/shared/amba/ambapp_old.c (modified) * bsps/sparc/shared/amba/ambapp_parent.c (modified) * bsps/sparc/shared/amba/ambapp_show.c (modified) * bsps/sparc/shared/analog/gradcdac.c (modified) * bsps/sparc/shared/ascs/grascs.c (modified) * bsps/sparc/shared/btimer/gptimer.c (modified) * bsps/sparc/shared/btimer/tlib.c (modified) * bsps/sparc/shared/btimer/tlib_ckinit.c (modified) * bsps/sparc/shared/can/canmux.c (modified) * bsps/sparc/shared/can/grcan.c (modified) * bsps/sparc/shared/can/occan.c (modified) * bsps/sparc/shared/can/satcan.c (modified) * bsps/sparc/shared/drvmgr/ambapp_bus.c (modified) * bsps/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * bsps/sparc/shared/drvmgr/ambapp_bus_leon2.c (modified) * bsps/sparc/shared/drvmgr/get_resarray_count.c (modified) * bsps/sparc/shared/gpio/gpiolib.c (modified) * bsps/sparc/shared/gpio/grgpio.c (modified) * bsps/sparc/shared/i2c/i2cmst.c (modified) * bsps/sparc/shared/iommu/griommu.c (modified) * bsps/sparc/shared/irq/genirq.c (modified) * bsps/sparc/shared/l2c/l2c.c (modified) * bsps/sparc/shared/mem/mctrl.c (modified) * bsps/sparc/shared/net/greth.c (modified) * bsps/sparc/shared/net/network_interface_add.c (modified) * bsps/sparc/shared/pci/gr_701.c (modified) * bsps/sparc/shared/pci/gr_cpci_gr740.c (modified) * bsps/sparc/shared/pci/gr_leon4_n2x.c (modified) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (modified) * bsps/sparc/shared/pci/gr_rasta_io.c (modified) * bsps/sparc/shared/pci/gr_rasta_spw_router.c (modified) * bsps/sparc/shared/pci/gr_rasta_tmtc.c (modified) * bsps/sparc/shared/pci/gr_tmtc_1553.c (modified) * bsps/sparc/shared/pci/grpci.c (modified) * bsps/sparc/shared/pci/grpci2.c (modified) * bsps/sparc/shared/pci/grpci2dma.c (modified) * bsps/sparc/shared/pci/pcif.c (modified) * bsps/sparc/shared/pwm/grpwm.c (modified) * bsps/sparc/shared/scrub/memscrub.c (modified) * bsps/sparc/shared/slink/grslink.c (modified) * bsps/sparc/shared/spi/spictrl.c (modified) * bsps/sparc/shared/spw/grspw.c (modified) * bsps/sparc/shared/spw/grspw_pkt.c (modified) * bsps/sparc/shared/spw/grspw_router.c (modified) * bsps/sparc/shared/spw/spwtdp.c (modified) * bsps/sparc/shared/stat/l4stat.c (modified) * bsps/sparc/shared/time/grctm.c (modified) * bsps/sparc/shared/time/spwcuc.c (modified) * bsps/sparc/shared/tmtc/grtc.c (modified) * bsps/sparc/shared/tmtc/grtm.c (modified) * bsps/sparc/shared/uart/apbuart_cons.c (modified) * bsps/sparc/shared/uart/apbuart_polled.c (modified) * bsps/sparc/shared/uart/apbuart_termios.c (modified) * bsps/sparc/shared/uart/cons.c (modified) grlib: Move header files Update #3678. Mon, 21 Jan 2019 08:17:05 GMT Sebastian Huber [95c1921] * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv (modified) * bsps/arm/beagle/start/linkcmds.beagle (modified) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx (modified) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_phycore (modified) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu (modified) * bsps/arm/shared/start/linkcmds.armv4 (modified) bsps/arm: Remove unused bsp_stack_irq_size Update #3459. Fri, 18 Jan 2019 12:32:51 GMT Sebastian Huber [926ed2b0] * cpukit/include/rtems/score/isrlock.h (modified) * testsuites/sptests/sp37/init.c (modified) score: Remove unused _ISR_lock_Flash() Fri, 18 Jan 2019 12:16:29 GMT Sebastian Huber [41310c02] * cpukit/include/rtems/rtems/intr.h (modified) * cpukit/include/rtems/score/isrlock.h (modified) * testsuites/sptests/sp37/init.c (modified) score: Improve debug support for ISR locks Ensure that interrupts ... Fri, 18 Jan 2019 11:54:05 GMT Sebastian Huber [b5bdecf] * cpukit/score/src/smpmulticastaction.c (modified) score: Avoid internal API and use ISR lock Mon, 14 Jan 2019 06:50:26 GMT Sebastian Huber [93e3b341] * cpukit/include/rtems/score/address.h (modified) score: Simplify _Addresses_Is_aligned() The CPU_ALIGNMENT must not ... Wed, 16 Jan 2019 21:42:18 GMT Joel Sherrill [12dfe5dc] * bsps/i386/shared/cache/cache.c (modified) bsps/i386/shared/cache/cache.c: Make compile Thu, 10 Jan 2019 19:14:03 GMT Joel Sherrill [4596127] * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) m68k/include/rtems/score/cpu.h: Add include of address.h Mon, 14 Jan 2019 08:38:02 GMT Sebastian Huber [47d5aee] * testsuites/benchmarks/Makefile.am (modified) build: Add missing $(LDADD) for dependencies Mon, 14 Jan 2019 08:07:16 GMT Sebastian Huber [d1fff86] * testsuites/sptests/Makefile.am (modified) build: Remove bogus spqreslib_LDADD Mon, 14 Jan 2019 08:06:30 GMT Sebastian Huber [dc0285f] * testsuites/libtests/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) build: Add missing $(LDADD) for dependencies Thu, 10 Jan 2019 10:35:12 GMT Sebastian Huber [8eaf136d] * cpukit/libcsupport/src/alignedalloc.c (modified) memalign: Add missing attributes to fix warning Update #3666. Thu, 10 Jan 2019 08:05:49 GMT Sebastian Huber [7bde91b] * cpukit/include/rtems/inttypes.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/libmisc/shell/main_rm.c (modified) * cpukit/libmisc/shell/print-ls.c (modified) * testsuites/psxtests/psxreaddir/test.c (modified) Fix format warnings due to ino_t changes Thu, 10 Jan 2019 07:10:17 GMT Sebastian Huber [3a5c71de] * testsuites/psxtests/psxconfig01/init.c (modified) psxconfig01: Fix pre-processor conditions Do not rely on compiler ... Thu, 10 Jan 2019 06:57:36 GMT Sebastian Huber [e7d623e7] * bsps/arm/shared/cache/cache-v7ar-disable-data.S (modified) bsps/arm: Conditional ARMv7-AR data cache disable Update #3667. ... Thu, 10 Jan 2019 06:29:54 GMT Thomas Dörfler [0abe47f] * bsps/arm/shared/cache/cache-v7ar-disable-data.S (modified) bsps/arm: Fix typo in disable cache for ARMv7-AR Update #3667. Tue, 08 Jan 2019 08:50:50 GMT Sebastian Huber [b9ffc41c] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Enable robust thread dispatch It must be enabled, since the ... Tue, 08 Jan 2019 08:53:26 GMT Sebastian Huber [3bd39999] * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp37/init.c (modified) Adjust interrupt mode tests for some CPU ports In case the robust ... Tue, 08 Jan 2019 07:39:42 GMT Sebastian Huber [1f285186] * cpukit/rtems/src/taskmode.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) rtems: Allow to set ISR level 0 in SMP config Update #3000. Tue, 08 Jan 2019 07:36:31 GMT Sebastian Huber [38cb59e] * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threadinitialize.c (modified) Separate task mode checks Update #3000. Tue, 08 Jan 2019 08:08:27 GMT Sebastian Huber [feddcde0] * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/spcbssched01/init.c (modified) * testsuites/sptests/spedfsched01/init.c (modified) * testsuites/sptests/spfifo03/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) tests: Remove bogus RTEMS_INTERRUPT_LEVEL(31) It is unnecessary to ... Wed, 09 Jan 2019 09:04:01 GMT Sebastian Huber [fe48400d] * testsuites/libtests/stackchk/blow.c (modified) libtests/stackchk: Fix for 64-bit targets Tue, 08 Jan 2019 04:14:21 GMT Jacob Shin [e4a19f5] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/errno/errno.c (added) psxhdrs: Add POSIX API Signature Compliance Tests for errno.h Tue, 08 Jan 2019 13:43:02 GMT Sebastian Huber [9aee88a] * bsps/riscv/riscv/start/start.S (modified) bsp/riscv: Clear boot command line Mon, 07 Jan 2019 12:40:00 GMT Sebastian Huber [07fb7667] * testsuites/libtests/Makefile.am (modified) build: Call rtems-ld with the $(CC) of the build This enables ... Mon, 07 Jan 2019 12:35:48 GMT Sebastian Huber [7802bb9] * testsuites/libtests/Makefile.am (modified) build: Call rtems-syms with the $(CC) of the build This enables ... Mon, 07 Jan 2019 13:22:22 GMT Jiri Gaisler [5b951175] * testsuites/psxtests/psxfile01/test.c (modified) psxfile01: Fix one second sleep Checking of atime in psxfile01 ... Mon, 07 Jan 2019 08:32:16 GMT Sebastian Huber [9c12bcfd] * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c (modified) * cpukit/libmisc/shell/main_pci.c (modified) * cpukit/libpci/pci_bus.c (modified) * cpukit/libpci/pci_cfg_print_code.c (modified) * cpukit/libpci/pci_print.c (modified) * testsuites/fstests/fsrfsbitmap01/test.c (modified) Fix format warnings Mon, 07 Jan 2019 08:30:43 GMT Sebastian Huber [956d76cc] * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/score/src/objectinitializeinformation.c (modified) score: Remove superfluous include from chainimpl.h Fri, 21 Dec 2018 20:09:53 GMT Sebastian Huber [a7e8996] * cpukit/include/drvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_dev_by_name.c (modified) * cpukit/libdrvmgr/drvmgr_for_each_dev.c (modified) * cpukit/libdrvmgr/drvmgr_print.c (modified) * cpukit/libmisc/shell/main_drvmgr.c (modified) drvmgr: Improve LP64 compatibility Fri, 21 Dec 2018 20:09:15 GMT Sebastian Huber [6073c71d] * cpukit/configure.ac (modified) drvmgr: Enable build for riscv Fri, 21 Dec 2018 19:47:06 GMT Himanshu40 [8f5abea] * testsuites/psxtmtests/psxtmbarrierattr01/init.c (modified) * testsuites/psxtmtests/psxtmbarrierattr01/psxtmbarrierattr01.doc (modified) * testsuites/psxtmtests/psxtmcleanup01/init.c (modified) * testsuites/psxtmtests/psxtmcleanup01/psxtmcleanup01.doc (modified) * testsuites/psxtmtests/psxtmmqrcvblock02/init.c (modified) * testsuites/psxtmtests/psxtmmqrcvblock02/psxtmmqrcvblock02.doc (modified) * testsuites/psxtmtests/psxtmmutexattr01/init.c (modified) * testsuites/psxtmtests/psxtmmutexattr01/psxtmmutexattr01.doc (modified) * testsuites/psxtmtests/psxtmonce01/init.c (modified) * testsuites/psxtmtests/psxtmonce01/psxtmonce01.doc (modified) psxtmtests: Changed the copyright license to BSD-2-Clause (GCI 2018) Fri, 21 Dec 2018 20:43:27 GMT Sebastian Huber [c05d7a9d] * bsps/sparc/shared/amba/ahbstat.c (modified) * bsps/sparc/shared/net/greth.c (modified) * bsps/sparc/shared/pci/gr_701.c (modified) * bsps/sparc/shared/pci/gr_cpci_gr740.c (modified) * bsps/sparc/shared/pci/gr_leon4_n2x.c (modified) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (modified) * bsps/sparc/shared/pci/gr_rasta_io.c (modified) * bsps/sparc/shared/pci/gr_rasta_spw_router.c (modified) * bsps/sparc/shared/pci/gr_rasta_tmtc.c (modified) * bsps/sparc/shared/pci/gr_tmtc_1553.c (modified) bsps/sparc: Fix warnings Fri, 21 Dec 2018 20:42:09 GMT Sebastian Huber [75e1009f] * bsps/sparc/shared/net/greth.c (modified) bsps/sparc: Fix typo Mon, 26 Nov 2018 14:55:38 GMT Sebastian Huber [11f3b9a] * bsps/sparc/include/bsp/gr1553rt.h (modified) * bsps/sparc/include/grlib_impl.h (modified) * bsps/sparc/shared/1553/b1553brm.c (modified) * bsps/sparc/shared/1553/b1553rt.c (modified) * bsps/sparc/shared/1553/gr1553b.c (modified) * bsps/sparc/shared/1553/gr1553bc.c (modified) * bsps/sparc/shared/1553/gr1553bm.c (modified) * bsps/sparc/shared/1553/gr1553rt.c (modified) * bsps/sparc/shared/amba/ambapp.c (modified) * bsps/sparc/shared/analog/gradcdac.c (modified) * bsps/sparc/shared/ascs/grascs.c (modified) * bsps/sparc/shared/btimer/gptimer.c (modified) * bsps/sparc/shared/can/canmux.c (modified) * bsps/sparc/shared/can/grcan.c (modified) * bsps/sparc/shared/can/occan.c (modified) * bsps/sparc/shared/can/satcan.c (modified) * bsps/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * bsps/sparc/shared/gpio/gpiolib.c (modified) * bsps/sparc/shared/gpio/grgpio.c (modified) * bsps/sparc/shared/i2c/i2cmst.c (modified) * bsps/sparc/shared/iommu/griommu.c (modified) * bsps/sparc/shared/irq/genirq.c (modified) * bsps/sparc/shared/mem/mctrl.c (modified) * bsps/sparc/shared/net/greth.c (modified) * bsps/sparc/shared/pci/gr_701.c (modified) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (modified) * bsps/sparc/shared/pci/gr_rasta_io.c (modified) * bsps/sparc/shared/pci/gr_tmtc_1553.c (modified) * bsps/sparc/shared/pci/grpci2dma.c (modified) * bsps/sparc/shared/pwm/grpwm.c (modified) * bsps/sparc/shared/slink/grslink.c (modified) * bsps/sparc/shared/spi/spictrl.c (modified) * bsps/sparc/shared/spw/grspw.c (modified) * bsps/sparc/shared/spw/grspw_pkt.c (modified) * bsps/sparc/shared/time/grctm.c (modified) * bsps/sparc/shared/time/spwcuc.c (modified) * bsps/sparc/shared/tmtc/grtc.c (modified) * bsps/sparc/shared/tmtc/grtm.c (modified) bsps/sparc: Add grlib_malloc(), grlib_calloc() This avoids a ... Fri, 21 Dec 2018 12:31:32 GMT Sebastian Huber [8b59916] * testsuites/sptests/spcxx01/init.cc (modified) spcxx01: Add test case Fri, 21 Dec 2018 10:57:26 GMT Sebastian Huber [c37807e9] * bsps/arm/shared/cache/cache-cp15.c (modified) bsps/arm: Add cache size support for CP15
