# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 08:13:56 Tue, 04 Dec 2018 22:55:53 GMT Joel Sherrill [55719ba] * testsuites/psxtests/psxhdrs/dlfcn/dlsym.c (modified) * testsuites/psxtests/psxhdrs/sys/time/getitimer.c (modified) * testsuites/psxtests/psxhdrs/sys/time/gettimeofday.c (modified) * testsuites/psxtests/psxhdrs/sys/time/setitimer.c (modified) psxhdrs: Fix warnings Tue, 04 Dec 2018 22:29:37 GMT Jacob Shin [b0b095c] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/ulimit/ulimit.c (added) psxhdrs: POSIX API Signature Compliance Tests for ulimit.h (GCI 2018) Tue, 04 Dec 2018 22:05:10 GMT Marçal Comajoan Cara [99de42c] * bsps/powerpc/beatnik/irq/irq_init.c (modified) * bsps/powerpc/mvme5500/irq/irq_init.c (modified) * bsps/powerpc/psim/irq/irq_init.c (modified) * bsps/powerpc/ss555/start/irq_init.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) Capitalize Rtems to RTEMS Mon, 03 Dec 2018 20:37:32 GMT Marçal Comajoan Cara [0446f680] * bsps/i386/pc386/start/README-SMP (modified) * bsps/powerpc/shared/exceptions/ppc_exc_address.c (modified) * bsps/sparc/leon3/start/bspclean.c (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/rtems/mainpage.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libfs/src/defaults/default_rename.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libi2c/README_libi2c (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * testsuites/smptests/smpmutex01/init.c (modified) Spelling and grammar fixes in source code comments (GCI 2018) Tue, 04 Dec 2018 16:43:59 GMT zehata [e25acd8] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/sys/time/getitimer.c (added) * testsuites/psxtests/psxhdrs/sys/time/gettimeofday.c (added) * testsuites/psxtests/psxhdrs/sys/time/select.c (added) * testsuites/psxtests/psxhdrs/sys/time/setitimer.c (added) * testsuites/psxtests/psxhdrs/sys/time/utimes.c (added) psxhdrs: Added POSIX Compliance Test fot sys/time.h (GCI 2018) Tue, 04 Dec 2018 04:42:01 GMT Jacob Shin [adc11af9] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/iconv/iconv.c (added) * testsuites/psxtests/psxhdrs/iconv/iconv_close.c (added) * testsuites/psxtests/psxhdrs/iconv/iconv_open.c (added) psxhdrs: Implement POSIX API Signature Compliance Tests for iconv.h ... Tue, 04 Dec 2018 14:26:55 GMT Sebastian Huber [fdcba406] * bsps/sparc/leon3/start/cpucounter.c (modified) bsp/leon3: Fix CPU counter frequency Tue, 04 Dec 2018 02:57:47 GMT Jacob Shin [8f79854] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/fnmatch/fnmatch.c (added) psxhdrs: Implement POSIX API Signature Compliance Tests for fnmatch.h ... Mon, 03 Dec 2018 17:04:04 GMT Himanshu40 [b055da27] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/regex/regcomp.c (added) * testsuites/psxtests/psxhdrs/regex/regerror.c (added) * testsuites/psxtests/psxhdrs/regex/regexec.c (added) * testsuites/psxtests/psxhdrs/regex/regfree.c (added) psxhdrs: add POSIX API Signature Compliance Tests for regex.h (GCI 2018) Mon, 03 Dec 2018 12:34:28 GMT Sebastian Huber [577d9a5] * cpukit/libmisc/testsupport/testextension.c (modified) testsupport: Include missing Fri, 30 Nov 2018 12:57:04 GMT Sebastian Huber [b9ffb624] * cpukit/include/rtems/counter.h (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * testsuites/sptests/spcpucounter01/init.c (modified) Convert CPU counter ticks to/from sbintime_t The sbintime_t is an ... Mon, 03 Dec 2018 03:13:23 GMT Jacob Shin [d0a7f03] * aclocal/project-root.m4 (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) 5 spelling errors for a Google Code-In task. Username: ... Mon, 03 Dec 2018 01:36:54 GMT Shashvat Jain [7383632c] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/utime/utime.c (added) psxhdrs:Add POSIX conformance test for utime.h (GCI 2018) Sun, 02 Dec 2018 14:36:39 GMT kaidoho [b8e8d0d] * aclocal/enable-rtemsbsp.m4 (modified) Fix wrong command hint in case of error Sun, 02 Dec 2018 11:01:18 GMT Himanshu40 [0888bfd5] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/locale/duplocale.c (added) * testsuites/psxtests/psxhdrs/locale/freelocale.c (added) * testsuites/psxtests/psxhdrs/locale/localeconv.c (added) * testsuites/psxtests/psxhdrs/locale/newlocale.c (added) * testsuites/psxtests/psxhdrs/locale/setlocale.c (added) * testsuites/psxtests/psxhdrs/locale/uselocale.c (added) psxhdrs: add POSIX API Signature Compliance Tests for locale.h (GCI 2018) Sat, 01 Dec 2018 18:41:19 GMT Himanshu40 [903c57a] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/dlfcn/dlclose.c (added) * testsuites/psxtests/psxhdrs/dlfcn/dlerror.c (added) * testsuites/psxtests/psxhdrs/dlfcn/dlopen.c (added) * testsuites/psxtests/psxhdrs/dlfcn/dlsym.c (added) psxhdrs: add POSIX API Signature Compliance Tests for dlfcn.h File ... Sat, 01 Dec 2018 17:53:06 GMT Himanshu40 [e3086c9c] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/strings/bcmp.c (added) * testsuites/psxtests/psxhdrs/strings/bcopy.c (added) * testsuites/psxtests/psxhdrs/strings/ffs.c (added) * testsuites/psxtests/psxhdrs/strings/index.c (added) * testsuites/psxtests/psxhdrs/strings/rindex.c (added) * testsuites/psxtests/psxhdrs/strings/strcasecmp.c (added) * testsuites/psxtests/psxhdrs/strings/strcasecmp_l.c (added) * testsuites/psxtests/psxhdrs/strings/strncasecmp.c (added) * testsuites/psxtests/psxhdrs/strings/strncasecmp_l.c (added) psxhdrs: add POSIX API signature tests for strings.h file (GCI 2018) Fri, 30 Nov 2018 19:01:50 GMT Shashvat Jain [f40f86d] * bsps/powerpc/haleakala/config/haleakala.cfg (modified) powerpc/haleakala:Add per-section compilation and linking support ... Fri, 30 Nov 2018 18:07:17 GMT Shashvat Jain [c056f21] * bsps/powerpc/mpc8260ads/config/mpc8260ads.cfg (modified) powerpc/mpc8260ads:Add per-section compilation and linking support ... Fri, 30 Nov 2018 16:39:29 GMT Shashvat Jain [8b3ca0c] * bsps/powerpc/qemuppc/config/qemuppc.cfg (modified) powerpc/qemuppc:Add per-section compilation and linking support (GCI ... Fri, 30 Nov 2018 15:03:25 GMT Shashvat Jain [8b6273a8] * bsps/powerpc/ss555/config/ss555.cfg (modified) powerpc/ss555:Add per-section compilation and linking support(GCI ... Fri, 30 Nov 2018 14:33:45 GMT Joel Sherrill [e54a266e] * testsuites/psxtests/psxmsgq01/init.c (modified) psxmsgq01/init.c: Disable signal usage when POSIX disabled closes #3626. Fri, 30 Nov 2018 14:33:31 GMT Joel Sherrill [10e7d87] * bsps/m68k/mcf52235/config/mcf52235-testsuite.tcfg (modified) mcf52235-testsuite.tcfg: Add dl07 Thu, 29 Nov 2018 22:46:06 GMT Joel Sherrill [e447d4c0] * bsps/or1k/generic_or1k/config/generic_or1k-testsuite.tcfg (modified) generic_or1k-testsuite.tcfg: Enable sptls01 now that GCC is from FSF ... Thu, 29 Nov 2018 20:39:47 GMT Shashvat Jain [8b28fdd] * bsps/m68k/mrm332/config/mrm332.cfg (modified) m68k/mrm332:Add per-section compilation and linking support (GCI ... Thu, 29 Nov 2018 18:32:46 GMT Shashvat Jain [f57d4d5] * bsps/m68k/mcf5206elite/config/mcf5206elite.cfg (modified) m68k/mcf5206elite:Add per-section compilation and linking support ... Thu, 29 Nov 2018 17:03:19 GMT Himanshu40 [7ea4c02] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/semaphore/sem_close.c (added) * testsuites/psxtests/psxhdrs/semaphore/sem_destroy.c (added) * testsuites/psxtests/psxhdrs/semaphore/sem_getvalue.c (added) * testsuites/psxtests/psxhdrs/semaphore/sem_init.c (added) * testsuites/psxtests/psxhdrs/semaphore/sem_open.c (added) * testsuites/psxtests/psxhdrs/semaphore/sem_post.c (added) * testsuites/psxtests/psxhdrs/semaphore/sem_timedwait.c (added) * testsuites/psxtests/psxhdrs/semaphore/sem_trywait.c (added) * testsuites/psxtests/psxhdrs/semaphore/sem_unlink.c (added) * testsuites/psxtests/psxhdrs/semaphore/sem_wait.c (added) psxtests : Add POSIX API Signature Compliance Tests for semaphore.h ... Thu, 29 Nov 2018 16:54:12 GMT Joel Sherrill [d6d4002] * bsps/bfin/shared/dev/clock.c (modified) bfin/shared/dev/clock.c: Include rtems/score/thread.h Thu, 29 Nov 2018 16:53:48 GMT Joel Sherrill [b56edf1] * bsps/arm/lpc24xx/config/lpc23xx_tli800-testsuite.tcfg (modified) lpc23xx_tli800-testsuite.tcfg: Add dl07 Thu, 29 Nov 2018 16:53:32 GMT Joel Sherrill [9002859] * bsps/arm/lpc24xx/config/lpc2362-testsuite.tcfg (modified) lpc2362-testsuite.tcfg: Add dl07 Thu, 29 Nov 2018 15:19:44 GMT Joel Sherrill [7ed1e618] * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add dl07 Thu, 29 Nov 2018 15:19:06 GMT Joel Sherrill [1491db5b] * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram-testsuite.tcfg: Add dl07 Thu, 29 Nov 2018 15:18:48 GMT Joel Sherrill [1d78d66] * bsps/arm/lpc176x/config/lpc1768_mbed-testsuite.tcfg (modified) lpc1768_mbed-testsuite.tcfg: Add dl07 Wed, 28 Nov 2018 17:53:36 GMT Shashvat Jain [1fe6d11] * bsps/m68k/mcf52235/config/mcf52235.cfg (modified) m68k/mcf52235:Add per-section compilation and linking support(GCI ... Wed, 28 Nov 2018 20:07:41 GMT Shashvat Jain [9c4dc7b0] * bsps/m68k/mcf5225x/config/mcf5225x.cfg (modified) m68k/mcf5225x:Add per-section compilation and linking support(GCI ... Wed, 28 Nov 2018 15:36:31 GMT Shashvat Jain [cc119eb] * bsps/m68k/mcf5329/config/mcf5329.cfg (modified) m68k/mcf5329:Add per-section compilation and linking support (GCI ... Wed, 28 Nov 2018 13:15:38 GMT Shashvat Jain [e80d34e] * bsps/m68k/mcf5235/config/mcf5235.cfg (modified) m68k/mcf5235:Add per-section compilation and linking support (GCI ... Wed, 28 Nov 2018 08:04:34 GMT Himanshu40 [93ccf479] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/mqueue/mq_close.c (added) * testsuites/psxtests/psxhdrs/mqueue/mq_getattr.c (added) * testsuites/psxtests/psxhdrs/mqueue/mq_notify.c (added) * testsuites/psxtests/psxhdrs/mqueue/mq_open.c (added) * testsuites/psxtests/psxhdrs/mqueue/mq_receive.c (added) * testsuites/psxtests/psxhdrs/mqueue/mq_send.c (added) * testsuites/psxtests/psxhdrs/mqueue/mq_setattr.c (added) * testsuites/psxtests/psxhdrs/mqueue/mq_timedreceive.c (added) * testsuites/psxtests/psxhdrs/mqueue/mq_timedsend.c (added) * testsuites/psxtests/psxhdrs/mqueue/mq_unlink.c (added) psxtests: add POSIX API signature compliance tests for mqueue.h file ... Wed, 28 Nov 2018 16:43:23 GMT Joel Sherrill [a919807] * bsps/arm/lm3s69xx/config/lm3s3749-testsuite.tcfg (modified) lm3s3749-testsuite.tcfg: Add dl07 Wed, 28 Nov 2018 13:52:22 GMT Sebastian Huber [5bf0c1a] * bsps/shared/cache/cacheimpl.h (modified) bsps/sparc: Fix SMP build Update #3622. Wed, 28 Nov 2018 09:32:46 GMT Chris Johns [aa5c462] * testsuites/rtems-test-check.py (modified) testsuite: Parse TCFG path based on OS path separator. Tue, 27 Nov 2018 17:10:30 GMT Himanshu40 [27a8fc5] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxhdrs/dirent/alphasort.c (added) * testsuites/psxtests/psxhdrs/dirent/closedir.c (added) * testsuites/psxtests/psxhdrs/dirent/dirfd.c (added) * testsuites/psxtests/psxhdrs/dirent/fdopendir.c (added) * testsuites/psxtests/psxhdrs/dirent/opendir.c (added) * testsuites/psxtests/psxhdrs/dirent/readdir.c (added) * testsuites/psxtests/psxhdrs/dirent/readdir_r.c (added) * testsuites/psxtests/psxhdrs/dirent/rewinddir.c (added) * testsuites/psxtests/psxhdrs/dirent/scandir.c (added) * testsuites/psxtests/psxhdrs/dirent/seekdir.c (added) * testsuites/psxtests/psxhdrs/dirent/telldir.c (added) psxtests: add POSIX API signature compliance tests for dirent.h file ... Tue, 27 Nov 2018 02:29:49 GMT Shashvat Jain [89bff5a] * bsps/m68k/av5282/config/av5282.cfg (modified) m68k/av5282: Add per-section compilation and linking support (GCI ... Tue, 27 Nov 2018 10:56:01 GMT Sebastian Huber [06331e4] * cpukit/libfs/src/dosfs/fat.c (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) dosfs: Fix device identifier Update #3358. Mon, 26 Nov 2018 14:44:25 GMT Sebastian Huber [a7267241] * bsps/sparc/headers.am (modified) * bsps/sparc/include/grlib_impl.h (added) * bsps/sparc/shared/1553/gr1553bc.c (modified) * bsps/sparc/shared/1553/gr1553bm.c (modified) * bsps/sparc/shared/1553/gr1553rt.c (modified) * bsps/sparc/shared/amba/ahbstat.c (modified) * bsps/sparc/shared/can/grcan.c (modified) * bsps/sparc/shared/can/occan.c (modified) * bsps/sparc/shared/net/greth.c (modified) * bsps/sparc/shared/pci/gr_701.c (modified) * bsps/sparc/shared/pci/gr_cpci_gr740.c (modified) * bsps/sparc/shared/pci/gr_leon4_n2x.c (modified) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (modified) * bsps/sparc/shared/pci/gr_rasta_io.c (modified) * bsps/sparc/shared/pci/gr_rasta_spw_router.c (modified) * bsps/sparc/shared/pci/gr_rasta_tmtc.c (modified) * bsps/sparc/shared/pci/gr_tmtc_1553.c (modified) * bsps/sparc/shared/pci/grpci2.c (modified) * bsps/sparc/shared/pci/grpci2dma.c (modified) * bsps/sparc/shared/spw/grspw_pkt.c (modified) * bsps/sparc/shared/spw/grspw_router.c (modified) * bsps/sparc/shared/spw/spwtdp.c (modified) * bsps/sparc/shared/tmtc/grtc.c (modified) * bsps/sparc/shared/tmtc/grtm.c (modified) bsps/sparc: Add and use Reduce copy and paste. Mon, 15 Oct 2018 05:46:27 GMT Sebastian Huber [c1864a0a] * LICENSE.BSD-2-Clause (added) Add LICENSE.BSD-2-Clause Copied from: ... Mon, 26 Nov 2018 13:04:59 GMT Sebastian Huber [0a75a4aa] * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/rtems/cache.h (modified) * testsuites/smptests/smpcache01/init.c (modified) Remove rtems_cache_*_processor_set() functions The following ... Mon, 26 Nov 2018 09:14:00 GMT Sebastian Huber [6378978] * cpukit/rtems/src/semmp.c (modified) rtems: Fix semaphore MPCI support Mon, 26 Nov 2018 07:25:36 GMT Sebastian Huber [5fc727f] * cpukit/include/rtems/score/smplockstats.h (modified) * cpukit/score/src/profilingsmplock.c (modified) score: Remove ... Tue, 20 Nov 2018 15:22:56 GMT Sebastian Huber [eaa5ea84] * cpukit/headers.am (modified) * cpukit/include/rtems/rtems/types.h (modified) * cpukit/include/rtems/score/heap.h (modified) * cpukit/include/rtems/score/heapinfo.h (added) * testsuites/libtests/stackchk/blow.c (modified) score: Introduce Move ... Sun, 25 Nov 2018 20:17:54 GMT Shashvat Jain [1947449] * bsps/m68k/uC5282/config/uC5282.cfg (modified) m68k/uC5282: Add per-section compilation and linking (GCI 2018) The ... Sun, 25 Nov 2018 15:49:30 GMT Himanshu40 [183b0ae] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmmqrcvblock02/init.c (added) * testsuites/psxtmtests/psxtmmqrcvblock02/psxtmmqrcvblock02.doc (added) * testsuites/psxtmtests/psxtmtests_plan.csv (modified) psxtmtests: add psxtmmqrcvblock02 (GCI 2018) Sat, 24 Nov 2018 20:11:50 GMT ABR290B [16d5e394] * testsuites/psxtests/psxhdrs/pthread/pthread_attr_destroy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getdetachstate.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getguardsize.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getinheritsched.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedparam.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedpolicy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getscope.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstack.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstackaddr.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstacksize.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_init.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setguardsize.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setinheritsched.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setschedparam.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setschedpolicy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setscope.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setstack.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setstackaddr.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setstacksize.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cancel.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cleanup.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_broadcast.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_destroy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_init.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_signal.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_timedwait.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_wait.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_destroy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_getpshared.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_init.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_setpshared.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_create.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_detach.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_equal.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_exit.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_getconcurrency.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_getcpuclockid.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_getschedparam.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_getspecific.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_join.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_key_create.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_key_delete.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_destroy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_getprioceiling.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_init.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_lock.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_setprioceiling.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_timedlock.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_trylock.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_unlock.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_destroy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprioceiling.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprotocol.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getpshared.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_init.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_setprioceiling.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_setprotocol.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_setpshared.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_once.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_self.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_setcancelstate.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_setcanceltype.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_setconcurrency.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_setschedparam.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_setspecific.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_testcancel.c (modified) psxtests/psxhdrs patch (GCI 2018) Sun, 25 Nov 2018 07:37:01 GMT Shashvat Jain [ffe9e7a] * bsps/m68k/gen68360/config/gen68360.cfg (modified) * bsps/m68k/gen68360/config/gen68360_040.cfg (modified) * bsps/m68k/gen68360/config/pgh360.cfg (modified) m68k/gen68360:Add per-section compilation and linking support The ... Sat, 24 Nov 2018 20:55:07 GMT pritishjain [1b2124d] * bsps/m68k/gen68340/config/gen68340.cfg (modified) m68k/gen68340:Add per-section compilation and linking support The ... Thu, 22 Nov 2018 01:25:43 GMT zehata [2ce44de] * bsps/x86_64/amd64/start/linkcmds (modified) Changed slightly awkward sentence structure Thu, 22 Nov 2018 00:46:35 GMT Joel Sherrill [9dfb9a98] * cpukit/libfs/src/pipe/fifo.c (modified) pipe/fifo.c: Remove dead code (CID 1437649) Closes #3581. Tue, 20 Nov 2018 03:56:11 GMT Chris Johns [03139d5b] * cpukit/include/rtems/rtl/rtl-obj-fwd.h (modified) * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/include/rtems/rtl/rtl-sym.h (modified) * cpukit/include/rtems/rtl/rtl.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl02/dl-load.c (modified) * testsuites/libtests/dl07/dl-load.c (added) * testsuites/libtests/dl07/dl-load.h (added) * testsuites/libtests/dl07/dl-o1.c (added) * testsuites/libtests/dl07/dl-o1.h (added) * testsuites/libtests/dl07/dl-o2.c (added) * testsuites/libtests/dl07/dl-o2.h (added) * testsuites/libtests/dl07/dl-o3.c (added) * testsuites/libtests/dl07/dl-o4.c (added) * testsuites/libtests/dl07/dl-o4.h (added) * testsuites/libtests/dl07/dl-o5.c (added) * testsuites/libtests/dl07/dl-o5.h (added) * testsuites/libtests/dl07/dl07.doc (added) * testsuites/libtests/dl07/dl07.scn (added) * testsuites/libtests/dl07/init.c (added) libdl: Add object file dependencies to track references Tracking ... Tue, 20 Nov 2018 03:00:48 GMT Chris Johns [8e7c72a7] * cpukit/include/rtems/rtl/rtl-unresolved.h (modified) * cpukit/libdl/rtl-unresolved.c (modified) libdl: Reindex unresolved names after removing used records. ... Tue, 13 Nov 2018 06:26:17 GMT Chris Johns [803eac9] * cpukit/include/rtems/rtl/rtl-obj.h (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-obj.c (modified) libdl: Manage the allocation of common uninitialised variables. The ... Wed, 21 Nov 2018 16:00:35 GMT Himanshu40 [69812aa] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmbarrierattr01/init.c (added) * testsuites/psxtmtests/psxtmbarrierattr01/psxtmbarrierattr01.doc (added) * testsuites/psxtmtests/psxtmtests_plan.csv (modified) psxtmbarrierattr01: Added new POSIX timing suite (GCI 2018) Wed, 21 Nov 2018 16:30:22 GMT Sebastian Huber [52c7cb1] * cpukit/score/src/wkstringduplicate.c (modified) score: Simplify _Workspace_String_duplicate() Fri, 16 Nov 2018 06:06:12 GMT Sebastian Huber [59e7209f] * cpukit/include/rtems/inttypes.h (modified) * cpukit/include/rtems/score/object.h (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) score: Remove support for RTEMS_USE_16_BIT_OBJECT The ... Tue, 20 Nov 2018 12:09:53 GMT Sebastian Huber [e0caabe] * bsps/arm/shared/start/start.S (modified) bsps/arm: Avoid short range branch in start.S Tue, 20 Nov 2018 12:06:04 GMT Sebastian Huber [faafc229] * bsps/arm/shared/start/start.S (modified) bsps/arm: Use local labels in start.S Tue, 20 Nov 2018 12:03:20 GMT Sebastian Huber [94529131] * bsps/arm/shared/start/start.S (modified) bsps/arm: Simplify start.S The boot_card() function does not return. Tue, 20 Nov 2018 15:45:51 GMT kuaLeYi [bde6ac20] * cpukit/ftpd/ftpd.c (modified) * cpukit/libdrvmgr/README (modified) * make/leaf.cfg (modified) * testsuites/libtests/POSIX/README (modified) Misc: Minor English fixes (GCI 2018) Tue, 20 Nov 2018 01:11:58 GMT Himanshu40 [edae517] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmmutexattr01/init.c (added) * testsuites/psxtmtests/psxtmmutexattr01/psxtmmutexattr01.doc (added) * testsuites/psxtmtests/psxtmtests_plan.csv (modified) psxtmutexattr01: Added new POSIX timing suite (GCI 2018) Fri, 16 Nov 2018 06:46:16 GMT Sebastian Huber [0a6a4ddb] * bsps/moxie/moxiesim/start/linkcmds (modified) * bsps/moxie/moxiesim/start/start.S (modified) bsps/moxie: Use interrupt stack for init stack Update #3459. Fri, 16 Nov 2018 07:01:24 GMT Sebastian Huber [38f81bfc] * bsps/nios2/nios2_iss/start/start.S (modified) bsps/nios2: Use interrupt stack for init stack Update #3459. Thu, 15 Nov 2018 05:40:35 GMT Sebastian Huber [0989001] * bsps/sparc64/shared/start/start.S (modified) bsps/sparc64: Use interrupt stack for init stack Update #3459. Fri, 16 Nov 2018 07:55:30 GMT Sebastian Huber [5f5bbd1] * bsps/x86_64/amd64/start/linkcmds (modified) * bsps/x86_64/amd64/start/start.S (added) * bsps/x86_64/amd64/start/start.c (deleted) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) bsps/x86_64: Use interrupt stack for init stack Update #3459. Fri, 16 Nov 2018 05:39:49 GMT Sebastian Huber [0ce6bf3] * bsps/epiphany/epiphany_sim/start/start.S (modified) bsps/epiphany: Use interrupt stack for init stack Update #3459. Fri, 16 Nov 2018 05:36:28 GMT Sebastian Huber [a74ee417] * bsps/bfin/bf537Stamp/start/start.S (modified) * bsps/bfin/shared/start/start.S (modified) bsps/bfin: Use interrupt stack for init stack Update #3459. Fri, 16 Nov 2018 06:43:51 GMT Sebastian Huber [508f319e] * bsps/mips/hurricane/start/start.S (modified) * bsps/mips/rbtx4925/start/start.S (modified) * bsps/mips/rbtx4938/start/start.S (modified) bsps/mips: Use interrupt stack for init stack Update #3459. Thu, 15 Nov 2018 19:47:22 GMT Sebastian Huber [84e59b7c] * bsps/powerpc/gen5200/start/start.S (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/haleakala/start/start.S (moved) * bsps/powerpc/mpc8260ads/start/start.S (modified) * bsps/powerpc/mvme3100/start/start.S (modified) * bsps/powerpc/mvme5500/start/start.S (modified) * bsps/powerpc/shared/start/linkcmds.share (modified) * bsps/powerpc/shared/start/start.S (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/virtex/start/start.S (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) bsps/powerpc: Use interrupt stack for init stack Move start.o to ... Fri, 16 Nov 2018 06:36:04 GMT Sebastian Huber [cc61d5c] * bsps/m68k/av5282/start/start.S (modified) * bsps/m68k/csb360/start/start.S (modified) * bsps/m68k/mcf5206elite/start/start.S (modified) * bsps/m68k/mcf5235/start/start.S (modified) * bsps/m68k/uC5282/start/start.S (modified) bsps/m68k: Use interrupt stack for init stack Update #3459. Sat, 17 Nov 2018 17:09:05 GMT Himanshu40 [edd366c] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmcleanup01/init.c (added) * testsuites/psxtmtests/psxtmcleanup01/psxtmcleanup01.doc (added) * testsuites/psxtmtests/psxtmtests_plan.csv (modified) psxtmcleanup01: new POSIX timing suite (GCI 2018) Fri, 16 Nov 2018 17:17:13 GMT shashvatjain [f06c436] * testsuites/psxtmtests/psxtmtests_plan.csv (modified) psxtmtests_plan.csv: Update to reflect psxtmmqrcvblock01 (GCI 2018) Thu, 15 Nov 2018 18:55:11 GMT shashvatjain [ccf11ce] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmmqrcvblock01/init.c (added) * testsuites/psxtmtests/psxtmmqrcvblock01/psxtmmqrcvblock01.doc (added) psxtmmqrcvblock01: Add new POSIX timing test (GCI 2018) Thu, 15 Nov 2018 22:31:21 GMT Himanshu40 [841b54e] * testsuites/psxtmtests/psxtmtests_plan.csv (modified) * testsuites/psxtmtests/psxtmthreadattr01/init.c (modified) psxtmthreadattr01: Correct mistakes in previous merge (GCI 2018) ... Thu, 15 Nov 2018 06:18:48 GMT Himanshu40 [8abb230b] * testsuites/psxtmtests/Makefile.am (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/psxtmtests/psxtmtests_plan.csv (modified) * testsuites/psxtmtests/psxtmthreadattr01/init.c (added) * testsuites/psxtmtests/psxtmthreadattr01/psxtmthreadattr01.doc (added) psxtmthreadattr01: Add new test (GCI 2018) Wed, 14 Nov 2018 23:30:57 GMT Joel Sherrill [68c8a197] * testsuites/psxtests/psxhdrs/pthread/pthread_attr_destroy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getdetachstate.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getguardsize.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getinheritsched.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedparam.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedpolicy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getscope.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstack.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstackaddr.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstacksize.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_init.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setdetachstate.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setguardsize.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setinheritsched.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setschedparam.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setschedpolicy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setscope.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setstack.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setstackaddr.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_attr_setstacksize.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cancel.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cleanup.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_broadcast.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_destroy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_init.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_signal.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_timedwait.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_cond_wait.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_destroy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_getpshared.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_init.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_condattr_setpshared.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_create.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_detach.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_equal.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_exit.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_getcpuclockid.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_getschedparam.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_getspecific.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_join.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_key_create.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_key_delete.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_destroy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_getprioceiling.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_init.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_lock.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_setprioceiling.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_timedlock.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_trylock.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutex_unlock.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_destroy.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprioceiling.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprotocol.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getpshared.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_init.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_setprioceiling.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_setprotocol.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_setpshared.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_once.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_self.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_setcancelstate.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_setcanceltype.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_setschedparam.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_setspecific.c (modified) * testsuites/psxtests/psxhdrs/pthread/pthread_testcancel.c (modified) * testsuites/psxtests/psxhdrs/sched/sched_get_priority_max.c (modified) * testsuites/psxtests/psxhdrs/sched/sched_get_priority_min.c (modified) * testsuites/psxtests/psxhdrs/sched/sched_getparam.c (modified) * testsuites/psxtests/psxhdrs/sched/sched_getscheduler.c (modified) * testsuites/psxtests/psxhdrs/sched/sched_rr_get_interval.c (modified) * testsuites/psxtests/psxhdrs/sched/sched_setparam.c (modified) * testsuites/psxtests/psxhdrs/sched/sched_setscheduler.c (modified) * testsuites/psxtests/psxhdrs/sched/sched_yield.c (modified) * testsuites/psxtests/psxhdrs/signal/pthread_sigmask.c (modified) * testsuites/psxtests/psxhdrs/signal/raise.c (modified) * testsuites/psxtests/psxhdrs/signal/signal.c (modified) * testsuites/psxtests/psxhdrs/signal/sigpending.c (modified) * testsuites/psxtests/psxhdrs/signal/sigprocmask.c (modified) * testsuites/psxtests/psxhdrs/signal/sigsuspend.c (modified) * testsuites/psxtests/psxhdrs/signal/sigtimedwait.c (modified) * testsuites/psxtests/psxhdrs/signal/sigwait.c (modified) * testsuites/psxtests/psxhdrs/signal/sigwaitinfo.c (modified) * testsuites/psxtests/psxhdrs/sys/mman/mlock.c (modified) * testsuites/psxtests/psxhdrs/sys/mman/mlockall.c (modified) * testsuites/psxtests/psxhdrs/sys/mman/mmap.c (modified) * testsuites/psxtests/psxhdrs/sys/mman/mprotect.c (modified) * testsuites/psxtests/psxhdrs/sys/mman/msync.c (modified) * testsuites/psxtests/psxhdrs/sys/mman/munlock.c (modified) * testsuites/psxtests/psxhdrs/sys/mman/munlockall.c (modified) * testsuites/psxtests/psxhdrs/sys/mman/munmap.c (modified) * testsuites/psxtests/psxhdrs/sys/mman/posix_madvise.c (modified) * testsuites/psxtests/psxhdrs/sys/mman/shm_open.c (modified) * testsuites/psxtests/psxhdrs/sys/mman/shm_unlink.c (modified) * testsuites/psxtests/psxhdrs/time/asctime.c (modified) * testsuites/psxtests/psxhdrs/time/asctime_r.c (modified) * testsuites/psxtests/psxhdrs/time/clock.c (modified) * testsuites/psxtests/psxhdrs/time/clock_getcpuclockid.c (modified) * testsuites/psxtests/psxhdrs/time/clock_getres.c (modified) * testsuites/psxtests/psxhdrs/time/clock_gettime.c (modified) * testsuites/psxtests/psxhdrs/time/clock_nanosleep.c (modified) * testsuites/psxtests/psxhdrs/time/clock_settime.c (modified) * testsuites/psxtests/psxhdrs/time/ctime.c (modified) * testsuites/psxtests/psxhdrs/time/ctime_r.c (modified) * testsuites/psxtests/psxhdrs/time/difftime.c (modified) * testsuites/psxtests/psxhdrs/time/gmtime.c (modified) * testsuites/psxtests/psxhdrs/time/gmtime_r.c (modified) * testsuites/psxtests/psxhdrs/time/localtime.c (modified) * testsuites/psxtests/psxhdrs/time/localtime_r.c (modified) * testsuites/psxtests/psxhdrs/time/mktime.c (modified) * testsuites/psxtests/psxhdrs/time/nanosleep.c (modified) * testsuites/psxtests/psxhdrs/time/strftime.c (modified) * testsuites/psxtests/psxhdrs/time/time.c (modified) * testsuites/psxtests/psxhdrs/time/timer_create.c (modified) * testsuites/psxtests/psxhdrs/time/timer_delete.c (modified) * testsuites/psxtests/psxhdrs/time/timer_getoverrun.c (modified) * testsuites/psxtests/psxhdrs/time/timer_gettime.c (modified) * testsuites/psxtests/psxhdrs/time/timer_settime.c (modified) * testsuites/psxtests/psxhdrs/unistd/alarm.c (modified) * testsuites/psxtests/psxhdrs/unistd/fdatasync.c (modified) * testsuites/psxtests/psxhdrs/unistd/fsync.c (modified) * testsuites/psxtests/psxhdrs/unistd/getegid.c (modified) * testsuites/psxtests/psxhdrs/unistd/geteuid.c (modified) * testsuites/psxtests/psxhdrs/unistd/getgid.c (modified) * testsuites/psxtests/psxhdrs/unistd/getgroups.c (modified) * testsuites/psxtests/psxhdrs/unistd/getlogin.c (modified) * testsuites/psxtests/psxhdrs/unistd/getlogin_r.c (modified) * testsuites/psxtests/psxhdrs/unistd/getpgrp.c (modified) * testsuites/psxtests/psxhdrs/unistd/getpid.c (modified) * testsuites/psxtests/psxhdrs/unistd/getppid.c (modified) * testsuites/psxtests/psxhdrs/unistd/getuid.c (modified) * testsuites/psxtests/psxhdrs/unistd/pause.c (modified) * testsuites/psxtests/psxhdrs/unistd/setgid.c (modified) * testsuites/psxtests/psxhdrs/unistd/setgroups.c (modified) * testsuites/psxtests/psxhdrs/unistd/setpgid.c (modified) * testsuites/psxtests/psxhdrs/unistd/setsid.c (modified) * testsuites/psxtests/psxhdrs/unistd/setuid.c (modified) * testsuites/psxtests/psxhdrs/unistd/sleep.c (modified) * testsuites/psxtests/psxhdrs/unistd/sync.c (modified) * testsuites/psxtests/psxhdrs/unistd/ualarm.c (modified) * testsuites/psxtests/psxhdrs/unistd/usleep.c (modified) testsuites/psxtests/psxhdrs: Fix comment so copyright block is separate Wed, 14 Nov 2018 22:48:56 GMT Pavel Pisa [5247a214] * bsps/arm/tms570/console/tms570-sci.c (modified) bsp/tms570: correct baudrate calculation. Wed, 14 Nov 2018 22:46:43 GMT Pavel Pisa [aefd4a2] * bsps/arm/tms570/start/bspstarthooks-hwinit.c (modified) * bsps/arm/tms570/start/fail_notification.c (modified) * bsps/arm/tms570/start/init_emif_sdram.c (modified) * bsps/arm/tms570/start/init_esm.c (modified) * bsps/arm/tms570/start/init_pinmux.c (modified) * bsps/arm/tms570/start/init_system.c (modified) * bsps/arm/tms570/start/tms570_selftest.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_can.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_mibspi.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_std.c (modified) * bsps/arm/tms570/start/tms570_selftest_parity.c (modified) * bsps/arm/tms570/start/tms570_tcram_tests.c (modified) bsp/tms570: correct inclusion of header files for build with HW init. ... Wed, 14 Nov 2018 07:42:22 GMT Sebastian Huber [a13b89b] * bsps/i386/pc386/start/bspgetworkarea.c (modified) * bsps/i386/pc386/start/start.S (modified) bsp/i386: Use interrupt stack for init stack Update #3459. Wed, 14 Nov 2018 06:58:38 GMT Sebastian Huber [5f32da0] * bsps/or1k/generic_or1k/start/start.S (modified) bsp/or1k: Use interrupt stack for init stack Update #3459. Wed, 14 Nov 2018 06:23:21 GMT Sebastian Huber [dc563556] * cpukit/include/rtems/rtems/cache.h (modified) Include missing Update #3598. Wed, 14 Nov 2018 06:00:59 GMT Sebastian Huber [28bf4ca] * bsps/or1k/generic_or1k/start/bsp_specs (modified) * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/score/src/threadhandler.c (modified) or1k: Support GCC 9 Close #3602. Fri, 09 Nov 2018 12:06:52 GMT Sebastian Huber [9a029ce] * bsps/shared/irq/irq-generic.c (modified) bsps/irq: Use rtems_malloc() Fri, 09 Nov 2018 11:11:11 GMT Sebastian Huber [6efc831] * cpukit/include/rtems/malloc.h (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * testsuites/libtests/malloctest/init.c (modified) Add rtems_malloc() and rtems_calloc() Close #3583. Fri, 09 Nov 2018 10:20:09 GMT Sebastian Huber [c1f3c2b8] * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/score/basedefs.h (modified) score: Add and use malloc() family attributes Update #3583. Thu, 08 Nov 2018 15:06:44 GMT Sebastian Huber [4539e307] * cpukit/score/cpu/x86_64/cpu.c (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/x86_64-context-initialize.c (modified) x86_64: Remove use of proc_ptr Update #3585. Fri, 09 Nov 2018 07:12:49 GMT Sebastian Huber [70928bc9] * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) sparc64: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 05:41:15 GMT Sebastian Huber [ce37237f] * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) sparc: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:31:03 GMT Sebastian Huber [510fbfc3] * bsps/sh/gensh1/start/cpu_asm.c (modified) * bsps/sh/gensh1/start/ispsh7032.c (modified) * bsps/sh/gensh2/start/cpu_asm.c (modified) * bsps/sh/gensh2/start/ispsh7045.c (modified) * bsps/sh/gensh4/start/cpu_asm.c (modified) * bsps/sh/shared/start/setvec.c (modified) * bsps/sh/shsim/start/ispshgdb.c (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) sh: Remove use of proc_ptr Update #3585. Fri, 09 Nov 2018 06:56:48 GMT Sebastian Huber [ed9da8e] * cpukit/Makefile.am (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/ppc-isr-vector-install.c (deleted) powerpc: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:05:22 GMT Sebastian Huber [54c5ffc] * bsps/or1k/generic_or1k/clock/clockdrv.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) or1k: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 15:03:10 GMT Sebastian Huber [12dfa5e2] * cpukit/Makefile.am (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-isr-install-raw-handler.c (deleted) * cpukit/score/cpu/nios2/nios2-isr-install-vector.c (modified) nios2: Remove use of proc_ptr Update #3585. Fri, 09 Nov 2018 07:04:23 GMT Sebastian Huber [264e128] * cpukit/score/cpu/moxie/cpu.c (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) moxie: Remove use of proc_ptr Update #3585.
