# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/18/24 23:12:39 Wed, 19 Nov 2014 13:29:27 GMT Sebastian Huber [52d24b00] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 compile-time errata 753970 Wed, 19 Nov 2014 13:19:13 GMT Sebastian Huber [55741886] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsps/arm: L2C 310 exclusive config is fatal Wed, 19 Nov 2014 13:08:44 GMT Sebastian Huber [d53de34] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 use l2c_310_* prefix throughout Wed, 19 Nov 2014 13:05:36 GMT Sebastian Huber [861d315] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 use L2C_310_* prefix throughout Wed, 19 Nov 2014 11:24:07 GMT Sebastian Huber [f2fed0c1] * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsps/arm: L2C 310 add compile time checks Simplify initialization. ... Wed, 19 Nov 2014 11:07:04 GMT Sebastian Huber [13f1462f] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 delete invalid link Wed, 19 Nov 2014 11:23:02 GMT Sebastian Huber [a9d6c20] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 simplify and remove white space Wed, 19 Nov 2014 10:51:33 GMT Sebastian Huber [957c075] * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) bsps/arm: L2C 310 rename BSP_ARM_L2CC_BASE Rename BSP_ARM_L2CC_BASE ... Wed, 19 Nov 2014 09:46:16 GMT Sebastian Huber [6b4a22e3] * cpukit/libmisc/shell/main_ping.c (modified) shell: Include early This avoids a conflict with ... Tue, 18 Nov 2014 14:33:33 GMT Sebastian Huber [8dbc612] * doc/shell/Makefile.am (modified) * doc/shell/confinit.t (modified) shell: Documentation Tue, 18 Nov 2014 13:05:15 GMT Sebastian Huber [3fe5d01] * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_cmdchmod.c (added) * cpukit/libmisc/shell/main_cmdchown.c (added) * cpukit/libmisc/shell/main_cmdls.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) * doc/shell/general.t (modified) shell: Add CMDLS, CMDCHOWN, CMDCHMOD commands Tue, 18 Nov 2014 11:03:11 GMT Sebastian Huber [478455e0] * cpukit/libmisc/shell/main_help.c (modified) shell: Fix help topic header Tue, 18 Nov 2014 06:35:30 GMT Sebastian Huber [7eada71] * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_alias.c (modified) * cpukit/libmisc/shell/main_help.c (modified) * cpukit/libmisc/shell/main_time.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) shell: Add mode, UID and GID to shell commands Use this information ... Tue, 18 Nov 2014 10:07:36 GMT Sebastian Huber [ffd5285] * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) shell: Inherit UID and GID if no login check Use the UID and GID of ... Tue, 18 Nov 2014 09:36:27 GMT Sebastian Huber [5c141d6a] * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/main_time.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) shell: Add and use rtems_shell_execute_cmd() Tue, 18 Nov 2014 09:13:55 GMT Sebastian Huber [1227858] * cpukit/libmisc/shell/shell_script.c (modified) shell: Make rtems_shell_main_joel() static Tue, 18 Nov 2014 09:09:30 GMT Sebastian Huber [66da4844] * cpukit/libmisc/shell/main_time.c (modified) shell: Print to stderr in TIME command Tue, 18 Nov 2014 09:03:24 GMT Sebastian Huber [7840b66] * cpukit/libmisc/shell/internal.h (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) * cpukit/libmisc/shell/shellconfig.h (modified) shell: Add initial commands and aliases only once Make tables read-only. Mon, 17 Nov 2014 14:58:26 GMT Sebastian Huber [7a2c30f] * cpukit/libmisc/shell/shell_cmdset.c (modified) shell: Simplify rtems_shell_add_cmd_struct() Mon, 17 Nov 2014 14:42:57 GMT Sebastian Huber [bac3d6d] * cpukit/libmisc/shell/main_halt.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shellconfig.h (modified) * doc/shell/rtems.t (modified) shell: Rename HALT to SHUTDOWN command Use a normal command for ... Mon, 17 Nov 2014 12:35:58 GMT Sebastian Huber [e02d5dd9] * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/pwdgrp.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/pwdgrp02/Makefile.am (added) * testsuites/libtests/pwdgrp02/init.c (added) * testsuites/libtests/pwdgrp02/pwdgrp02.doc (added) * testsuites/libtests/pwdgrp02/pwdgrp02.scn (added) Ensure security of default user environment Mon, 17 Nov 2014 10:55:27 GMT Sebastian Huber [fa028bb] * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/shell.c (modified) * testsuites/libtests/shell01/init.c (modified) * testsuites/samples/fileio/init.c (modified) shell: Do chroot() after successful login Mon, 17 Nov 2014 13:55:38 GMT Sebastian Huber [373ccbb9] * cpukit/libmisc/shell/shell.c (modified) shell: Use exiting once initialization Avoid TOCTOU issues. Avoid ... Mon, 17 Nov 2014 09:19:00 GMT Sebastian Huber [065d72ce] * cpukit/libmisc/shell/login_check.c (modified) * testsuites/libtests/shell01/init.c (modified) shell: Get supplementary group IDs in login check Mon, 17 Nov 2014 08:01:53 GMT Sebastian Huber [b8bd90f6] * cpukit/include/rtems/userenv.h (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/sup_fs_check_permissions.c (modified) * cpukit/libcsupport/src/uenvgetgroups.c (added) * testsuites/fstests/fsnofs01/init.c (modified) Add supplementary groups to user environment Tue, 18 Nov 2014 09:42:45 GMT Sebastian Huber [0b3fcf5] * testsuites/samples/fileio/system.h (modified) samples/fileio: Use unlimited objects Tue, 18 Nov 2014 09:42:34 GMT Sebastian Huber [ab085c9] * testsuites/samples/fileio/init.c (modified) samples/fileio: Fix warning Mon, 17 Nov 2014 12:00:17 GMT Sebastian Huber [7bfa0970] * cpukit/libfs/src/dosfs/fat.h (modified) dosfs: Avoid MIN() re-definition Tue, 18 Nov 2014 06:39:47 GMT Sebastian Huber [c3350e7d] * cpukit/libcsupport/include/rtems/libio_.h (modified) Filesystem: Typo Mon, 17 Nov 2014 06:53:01 GMT Sebastian Huber [ffa71f1] * cpukit/libcsupport/src/getgroups.c (modified) * testsuites/libtests/pwdgrp01/init.c (modified) * testsuites/libtests/pwdgrp01/pwdgrp01.doc (modified) * testsuites/psxtests/psxid01/init.c (modified) * testsuites/psxtests/psxid01/psxid01.scn (modified) libcsupport: Implement getgroups() Fri, 14 Nov 2014 14:33:57 GMT Sebastian Huber [395e5d4] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/getgrent.c (modified) * cpukit/libcsupport/src/getgrnam.c (added) * testsuites/psxtests/psxpasswd01/init.c (modified) * testsuites/psxtests/psxpasswd02/init.c (modified) libcsupport: Use POSIX key for getgrent() Fri, 14 Nov 2014 13:31:54 GMT Sebastian Huber [acf9a8d] * cpukit/libmisc/shell/login_check.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/shell01/Makefile.am (added) * testsuites/libtests/shell01/init.c (added) * testsuites/libtests/shell01/shell01.doc (added) * testsuites/libtests/shell01/shell01.scn (added) * testsuites/samples/fileio/init.c (modified) shell: Use crypt_r() in rtems_shell_login_check() Use '*" to ... Fri, 14 Nov 2014 13:30:36 GMT Sebastian Huber [002f351] * cpukit/libcsupport/src/pwdgrp.c (modified) * testsuites/psxtests/psxpasswd01/init.c (modified) * testsuites/psxtests/psxpasswd01/psxpasswd01.scn (modified) libcsupport: Minimal /etc/passwd and /etc/group Create a minimal ... Fri, 14 Nov 2014 10:30:50 GMT Sebastian Huber [6935428] * cpukit/libcsupport/src/pwdgrp.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/pwdgrp01/Makefile.am (added) * testsuites/libtests/pwdgrp01/init.c (added) * testsuites/libtests/pwdgrp01/pwdgrp01.doc (added) * testsuites/libtests/pwdgrp01/pwdgrp01.scn (added) libcsupport: Avoid TOCTOU and format errors Fri, 14 Nov 2014 10:09:39 GMT Sebastian Huber [80055514] * cpukit/libcsupport/src/pwdgrp.c (modified) libcsupport: Use pthread_once() Fri, 14 Nov 2014 10:01:48 GMT Sebastian Huber [b471854b] * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/getgrent.c (added) * cpukit/libcsupport/src/getpwent.c (modified) * cpukit/libcsupport/src/pwdgrp.c (added) * cpukit/libcsupport/src/pwdgrp.h (added) libcsupport: Split passwd/group support Fri, 14 Nov 2014 09:28:15 GMT Sebastian Huber [d82f9de1] * cpukit/libcsupport/src/getpwent.c (modified) libcsupport: Add copyrights according to rev hist Thu, 13 Nov 2014 14:13:24 GMT Sebastian Huber [4466321] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/include/crypt.h (added) * cpukit/libcrypt/Makefile.am (added) * cpukit/libcrypt/crypt-md5.c (added) * cpukit/libcrypt/crypt-sha256.c (added) * cpukit/libcrypt/crypt-sha512.c (added) * cpukit/libcrypt/crypt.c (added) * cpukit/libcrypt/misc.c (added) * cpukit/libcrypt/preinstall.am (added) * cpukit/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/crypt01/Makefile.am (added) * testsuites/libtests/crypt01/crypt01.doc (added) * testsuites/libtests/crypt01/crypt01.scn (added) * testsuites/libtests/crypt01/init.c (added) Add crypt_r(), etc. Add crypt_add_format(), crypt_r(), ... Thu, 13 Nov 2014 12:18:24 GMT Sebastian Huber [1bcd0378] * cpukit/Makefile.am (modified) * cpukit/libmd/Makefile.am (modified) * cpukit/libmd/preinstall.am (modified) * cpukit/libmd/sha256.h (added) * cpukit/libmd/sha256c.c (added) * cpukit/libmd/sha512.h (added) * cpukit/libmd/sha512c.c (added) * cpukit/preinstall.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/sha/Makefile.am (added) * testsuites/libtests/sha/init.c (added) * testsuites/libtests/sha/sha.doc (added) * testsuites/libtests/sha/sha.scn (added) Add SHA256 and SHA512 support Thu, 13 Nov 2014 10:55:51 GMT Sebastian Huber [a2b6895] * cpukit/Makefile.am (modified) * cpukit/include/sys/endian.h (added) * cpukit/preinstall.am (modified) Add Mon, 10 Nov 2014 12:46:32 GMT Sebastian Huber [45a63ee] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/i2c.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) bsp/xilinx-zynq: Add Cadence I2C bus driver Thu, 13 Nov 2014 09:12:32 GMT Sebastian Huber [bdf8fa76] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (modified) bsp/xilinx-zynq: Add zync_clock_cpu_1x() Thu, 13 Nov 2014 09:15:41 GMT Sebastian Huber [234d5c40] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) bsp/xilinx-zynq: Rename BSP_ARM_A9MPCORE_UARTCLK Rename ... Wed, 12 Nov 2014 13:02:53 GMT Sebastian Huber [8100e71] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) bsp/xilinx-zynq: Adjust BSP_ARM_A9MPCORE_PERIPHCLK Tue, 11 Nov 2014 11:41:58 GMT Sebastian Huber [0510cfd8] * cpukit/dev/Makefile.am (modified) * cpukit/dev/i2c/switch-nxp-pca9548a.c (added) * cpukit/dev/include/dev/i2c/switch-nxp-pca9548a.h (added) * cpukit/dev/preinstall.am (modified) * testsuites/libtests/i2c01/init.c (modified) Add NXP PCA9548A 8-channel switch I2C driver Fri, 07 Nov 2014 12:50:01 GMT Sebastian Huber [67ac69fc] * cpukit/dev/Makefile.am (modified) * cpukit/dev/i2c/gpio-nxp-pca9535.c (added) * cpukit/dev/include/dev/i2c/gpio-nxp-pca9535.h (added) * cpukit/dev/preinstall.am (modified) * testsuites/libtests/i2c01/init.c (modified) Add NXP PCA9535 16-bit GPIO I2C driver Fri, 07 Nov 2014 12:49:29 GMT Sebastian Huber [cce46780] * cpukit/dev/Makefile.am (modified) * cpukit/dev/i2c/eeprom.c (added) * cpukit/dev/include/dev/i2c/eeprom.h (added) * cpukit/dev/preinstall.am (modified) * testsuites/libtests/i2c01/init.c (modified) Add generic EEPROM I2C device driver Fri, 07 Nov 2014 12:47:39 GMT Sebastian Huber [41c5f1b7] * cpukit/dev/Makefile.am (modified) * cpukit/dev/i2c/i2c-bus.c (added) * cpukit/dev/i2c/i2c-dev.c (added) * cpukit/dev/include/dev/i2c/i2c.h (added) * cpukit/dev/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/i2c01/Makefile.am (added) * testsuites/libtests/i2c01/i2c01.doc (added) * testsuites/libtests/i2c01/i2c01.scn (added) * testsuites/libtests/i2c01/init.c (added) Add I2C driver framework This I2C driver framework has some major ... Wed, 05 Nov 2014 09:21:34 GMT Sebastian Huber [b6f21886] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/dev/Makefile.am (added) * cpukit/dev/include/linux/i2c-dev.h (added) * cpukit/dev/include/linux/i2c.h (added) * cpukit/dev/preinstall.am (added) Add RTEMS port of Linux I2C user-space API Wed, 12 Nov 2014 12:57:24 GMT Sebastian Huber [f0c564c] * c/src/lib/libbsp/arm/shared/startup/linkcmds.armv4 (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Adjust stacks for ARMv4 Reduce non-IRQ stacks to size ... Thu, 20 Nov 2014 07:52:50 GMT Sebastian Huber [3eade710] * testsuites/libtests/top/init.c (modified) libtests/top: End test after some time if no input Wed, 12 Nov 2014 13:00:05 GMT Alan Cudmore [96a9f4c] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (modified) * c/src/lib/libbsp/arm/shared/abort/abort.h (added) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (modified) ARM removed shared/abort from several ARM BSPs Thu, 20 Nov 2014 02:52:12 GMT Chris Johns [580466c] * cpukit/libdl/rtl-elf.c (modified) libdl: Update comment with details about the error fix. See refs #2192. Wed, 19 Nov 2014 23:19:46 GMT Chris Johns [2ae58c69] * cpukit/libdl/rtl-allocator.c (modified) libdl: Update the comments. See refs #2191. Wed, 19 Nov 2014 23:18:16 GMT Chris Johns [fc523ac8] * cpukit/libdl/rtl-elf.c (modified) libdl: Fix possible 16-bit overflow (Coverity 1255339) refs #2192. ... Wed, 19 Nov 2014 21:43:15 GMT Chris Johns [4f1bbbfc] * cpukit/libdl/rtl-allocator.c (modified) libdl: Add a comment. See ref #2191. Wed, 19 Nov 2014 21:38:28 GMT Chris Johns [80590a8] * cpukit/libdl/rtl-allocator.c (modified) libdl: Add a comment to the previous fix. The fix is ref #2191. Wed, 19 Nov 2014 21:30:01 GMT Chris Johns [90f65007] * cpukit/libdl/rtl-allocator.c (modified) libdl: Fix allocator NULL check (Coverity 1255328) refs #2191 The ... Wed, 19 Nov 2014 20:27:34 GMT Chris Johns [724eb8c4] * MAINTAINERS (modified) Fix type in MAINTAINERS. Wed, 19 Nov 2014 20:21:28 GMT Chris Johns [f04dff4] * MAINTAINERS (modified) Update MAINTAINERS with blanket commits for Daniel and SPARC. Wed, 19 Nov 2014 18:32:17 GMT Chris Johns [c87ff97] * MAINTAINERS (modified) Update maintainers with Daniel. Wed, 19 Nov 2014 18:25:40 GMT Chris Johns [ab8a9ad] * MAINTAINERS (modified) Update the maintainers list. Wed, 19 Nov 2014 09:09:54 GMT Chris Johns [7ecd1fc] * cpukit/wrapup/Makefile.am (modified) libmisc: Add the libmisc/redirector to the wrap up. Thu, 06 Nov 2014 02:08:48 GMT Chris Johns [f98abbe] * cpukit/configure.ac (modified) * cpukit/libdl/rtl-mdreloc-nios2.c (deleted) * testsuites/libtests/configure.ac (modified) libdl: Disable building libdl for the NIOS2. No relocation support. ... Wed, 05 Nov 2014 23:52:23 GMT Joel Sherrill [a373dc37] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) lpc23xx_tli800-testsuite.tcfg: Add dl02 Wed, 05 Nov 2014 23:52:05 GMT Joel Sherrill [091c610] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) lpc2362-testsuite.tcfg: Add dl02 Wed, 05 Nov 2014 23:51:43 GMT Joel Sherrill [0b91cfbf] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add a handful more tests Wed, 05 Nov 2014 21:31:36 GMT Joel Sherrill [f9e4139] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) lm3s3749-testsuite.tcfg: Add dl02 Tue, 04 Nov 2014 22:05:44 GMT Joel Sherrill [54998f6] * cpukit/libmisc/shell/main_edit.c (modified) shell/main_edit.c: Fix warnings Tue, 04 Nov 2014 21:05:08 GMT Joel Sherrill [8d74b80e] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) lpc23xx_tli800-testsuite.tcfg: Add dl01 Tue, 04 Nov 2014 21:04:46 GMT Joel Sherrill [6d84a9f] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) lpc2362-testsuite.tcfg: Add dl01 Tue, 04 Nov 2014 21:04:28 GMT Joel Sherrill [a7812cdc] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add rbheap01 Tue, 04 Nov 2014 21:02:03 GMT Joel Sherrill [643e7cb8] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) lm3s3749-testsuite.tcfg: Add dl01 Tue, 04 Nov 2014 20:55:43 GMT Joel Sherrill [1a3c611c] * cpukit/sapi/src/testextension.c (modified) sapi/src/testextension.c: Fix warnings Tue, 04 Nov 2014 20:55:21 GMT Joel Sherrill [1dc5b0e0] * cpukit/libdl/rtl-mdreloc-bfin.c (modified) libdl/rtl-mdreloc-bfin.c: Include rtems/rtl/rtl.h not rtl.h Tue, 04 Nov 2014 20:54:48 GMT Joel Sherrill [598a1f4a] * cpukit/libdl/Makefile.am (modified) libdl/Makefile.am: Need preinstall on all targets Tue, 04 Nov 2014 05:34:37 GMT Chris Johns [028ed6c3] * cpukit/libdl/dlfcn.c (modified) libdl: RTLD_DEFAULT searches the global symbol table. Tue, 04 Nov 2014 05:31:50 GMT Chris Johns [540b7b41] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl02/Makefile.am (added) * testsuites/libtests/dl02/dl-load.c (added) * testsuites/libtests/dl02/dl-load.h (added) * testsuites/libtests/dl02/dl-o1.c (added) * testsuites/libtests/dl02/dl-o2.c (added) * testsuites/libtests/dl02/dl-o2.h (added) * testsuites/libtests/dl02/dl02.doc (added) * testsuites/libtests/dl02/dl02.scn (added) * testsuites/libtests/dl02/init.c (added) libtests: Add libdl test dl02. Loads 2 interdependent ELF object files. Tue, 04 Nov 2014 05:30:08 GMT Chris Johns [d52c9e4d] * testsuites/libtests/dl01/dl01.doc (modified) * testsuites/libtests/dl01/dl01.scn (modified) * testsuites/libtests/dl01/init.c (modified) libtests: Update dl01 documentation. Tue, 04 Nov 2014 02:02:03 GMT Chris Johns [de5596b] * c/src/lib/libbsp/arm/beagle/preinstall.am (modified) Regenerated preinstall.am file. Tue, 04 Nov 2014 01:12:25 GMT Chris Johns [a2e1e30d] * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-obj.h (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-sym.h (modified) * cpukit/libdl/rtl-trace.h (modified) libdl: Add a local symbol table to the object module. Adding a ... Mon, 03 Nov 2014 18:53:40 GMT Ben Gras [53dd6d61] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/README (modified) * c/src/lib/libbsp/arm/beagle/README.JTAG (added) * c/src/lib/libbsp/arm/beagle/TESTING (added) * c/src/lib/libbsp/arm/beagle/clock.c (added) * c/src/lib/libbsp/arm/beagle/clock/beagle-clock-config.c (deleted) * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/console/console-config.c (modified) * c/src/lib/libbsp/arm/beagle/include/beagle-clock-config.h (deleted) * c/src/lib/libbsp/arm/beagle/include/beagle-timer.h (deleted) * c/src/lib/libbsp/arm/beagle/include/beagle.h (deleted) * c/src/lib/libbsp/arm/beagle/include/boot.h (deleted) * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) * c/src/lib/libbsp/arm/beagle/include/i2c.h (modified) * c/src/lib/libbsp/arm/beagle/include/irq.h (modified) * c/src/lib/libbsp/arm/beagle/irq.c (added) * c/src/lib/libbsp/arm/beagle/irq/irq.c (deleted) * c/src/lib/libbsp/arm/beagle/make/custom/beagleboardorig.cfg (added) * c/src/lib/libbsp/arm/beagle/make/custom/beagleboardxm.cfg (moved) * c/src/lib/libbsp/arm/beagle/make/custom/beagleboneblack.cfg (added) * c/src/lib/libbsp/arm/beagle/make/custom/beaglebonewhite.cfg (added) * c/src/lib/libbsp/arm/beagle/misc/boot.c (deleted) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (modified) * c/src/lib/libbsp/arm/beagle/misc/restart.c (deleted) * c/src/lib/libbsp/arm/beagle/misc/system-clocks.c (deleted) * c/src/lib/libbsp/arm/beagle/misc/timer.c (deleted) * c/src/lib/libbsp/arm/beagle/preinstall.am (modified) * c/src/lib/libbsp/arm/beagle/rtc/rtc-config.c (deleted) * c/src/lib/libbsp/arm/beagle/simscripts/bbxm.cfg (added) * c/src/lib/libbsp/arm/beagle/simscripts/gdbinit.bbxm (added) * c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh (added) * c/src/lib/libbsp/arm/beagle/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/beagle/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/beagle/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c (added) * c/src/lib/libbsp/arm/beagle/startup/linkcmds.beagle (modified) BSP for several Beagle products Specifically the beagleboard, ... Wed, 22 Aug 2012 12:39:02 GMT Claas Ziemke [7a66986] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (added) * c/src/lib/libbsp/arm/beagle/README (added) * c/src/lib/libbsp/arm/beagle/bsp_specs (added) * c/src/lib/libbsp/arm/beagle/clock/beagle-clock-config.c (added) * c/src/lib/libbsp/arm/beagle/configure.ac (added) * c/src/lib/libbsp/arm/beagle/console/console-config.c (added) * c/src/lib/libbsp/arm/beagle/include/beagle-clock-config.h (added) * c/src/lib/libbsp/arm/beagle/include/beagle-timer.h (added) * c/src/lib/libbsp/arm/beagle/include/beagle.h (added) * c/src/lib/libbsp/arm/beagle/include/boot.h (added) * c/src/lib/libbsp/arm/beagle/include/bsp.h (added) * c/src/lib/libbsp/arm/beagle/include/i2c.h (added) * c/src/lib/libbsp/arm/beagle/include/irq.h (added) * c/src/lib/libbsp/arm/beagle/irq/irq.c (added) * c/src/lib/libbsp/arm/beagle/make/custom/beagle.cfg (added) * c/src/lib/libbsp/arm/beagle/make/custom/beagle.inc (added) * c/src/lib/libbsp/arm/beagle/misc/boot.c (added) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (added) * c/src/lib/libbsp/arm/beagle/misc/restart.c (added) * c/src/lib/libbsp/arm/beagle/misc/system-clocks.c (added) * c/src/lib/libbsp/arm/beagle/misc/timer.c (added) * c/src/lib/libbsp/arm/beagle/preinstall.am (added) * c/src/lib/libbsp/arm/beagle/rtc/rtc-config.c (added) * c/src/lib/libbsp/arm/beagle/simscripts/qemu-beagleboard.in (added) * c/src/lib/libbsp/arm/beagle/startup/bspreset.c (added) * c/src/lib/libbsp/arm/beagle/startup/bspstart.c (added) * c/src/lib/libbsp/arm/beagle/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/beagle/startup/linkcmds.beagle (added) Added BeagleBoard BSP Coding done in course of GSoC2012. Commit ... Mon, 03 Nov 2014 18:52:03 GMT Ben Gras [b51842b] * c/src/lib/libcpu/arm/shared/include/am335x.h (added) * c/src/lib/libcpu/arm/shared/include/omap3.h (added) * c/src/lib/libcpu/arm/shared/include/omap_timer.h (added) Add some generic ARM am335x and omap definitions Mon, 03 Nov 2014 12:56:00 GMT Jennifer Averett [4123e244] * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) cpuuse: Resolve compile errors. Mon, 03 Nov 2014 00:54:55 GMT Joel Sherrill [c58f90b] * testsuites/libtests/dl01/dl-load.c (modified) dl01/dl-load.c: Add missing const Fri, 31 Oct 2014 14:11:13 GMT Joel Sherrill [def1337] * c/src/lib/libcpu/bfin/clock/tod.h (deleted) libcpu/bfin/clock/tod.h: Delete - missed on previous commits Thu, 30 Oct 2014 13:29:09 GMT Sebastian Huber [e08b0b9] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-flash.S (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/reg-defs.h (modified) bsp/mpc55xxevb: Fix flash settings for MPC5510 Fri, 31 Oct 2014 05:20:02 GMT Chris Johns [7ae1c30] * cpukit/libnetworking/libc/res_config.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/sghostname.c (modified) libnetworking: Fix the sethostname decl to match newlib. Mon, 27 Oct 2014 01:09:41 GMT Chris Johns [ae5fe7e6] * cpukit/Makefile.am (modified) * cpukit/configure.ac (modified) * cpukit/libdl/Makefile.am (added) * cpukit/libdl/dlfcn-shell.c (added) * cpukit/libdl/dlfcn-shell.h (added) * cpukit/libdl/dlfcn.c (added) * cpukit/libdl/dlfcn.h (added) * cpukit/libdl/fastlz.c (added) * cpukit/libdl/fastlz.h (added) * cpukit/libdl/include/arch/arm/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/bfin/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/h8300/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/i386/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/lm32/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/m32r/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/m68k/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/mips/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/moxie/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/nios2/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/powerpc/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/sparc/machine/elf_machdep.h (added) * cpukit/libdl/include/arch/v850/machine/elf_machdep.h (added) * cpukit/libdl/include/link.h (added) * cpukit/libdl/include/link_elf.h (added) * cpukit/libdl/include/sys/cdefs_elf.h (added) * cpukit/libdl/include/sys/exec_elf.h (added) * cpukit/libdl/preinstall.am (added) * cpukit/libdl/rap-shell.c (added) * cpukit/libdl/rap-shell.h (added) * cpukit/libdl/rap.c (added) * cpukit/libdl/rap.h (added) * cpukit/libdl/rtl-alloc-heap.c (added) * cpukit/libdl/rtl-alloc-heap.h (added) * cpukit/libdl/rtl-allocator.c (added) * cpukit/libdl/rtl-allocator.h (added) * cpukit/libdl/rtl-chain-iterator.c (added) * cpukit/libdl/rtl-chain-iterator.h (added) * cpukit/libdl/rtl-debugger.c (added) * cpukit/libdl/rtl-elf.c (added) * cpukit/libdl/rtl-elf.h (added) * cpukit/libdl/rtl-error.c (added) * cpukit/libdl/rtl-error.h (added) * cpukit/libdl/rtl-find-file.c (added) * cpukit/libdl/rtl-find-file.h (added) * cpukit/libdl/rtl-fwd.h (added) * cpukit/libdl/rtl-indirect-ptr.h (added) * cpukit/libdl/rtl-mdreloc-arm.c (added) * cpukit/libdl/rtl-mdreloc-bfin.c (added) * cpukit/libdl/rtl-mdreloc-h8300.c (added) * cpukit/libdl/rtl-mdreloc-i386.c (added) * cpukit/libdl/rtl-mdreloc-lm32.c (added) * cpukit/libdl/rtl-mdreloc-m32r.c (added) * cpukit/libdl/rtl-mdreloc-m68k.c (added) * cpukit/libdl/rtl-mdreloc-mips.c (added) * cpukit/libdl/rtl-mdreloc-moxie.c (added) * cpukit/libdl/rtl-mdreloc-nios2.c (added) * cpukit/libdl/rtl-mdreloc-powerpc.c (added) * cpukit/libdl/rtl-mdreloc-sparc.c (added) * cpukit/libdl/rtl-mdreloc-v850.c (added) * cpukit/libdl/rtl-obj-cache.c (added) * cpukit/libdl/rtl-obj-cache.h (added) * cpukit/libdl/rtl-obj-comp.c (added) * cpukit/libdl/rtl-obj-comp.h (added) * cpukit/libdl/rtl-obj-fwd.h (added) * cpukit/libdl/rtl-obj.c (added) * cpukit/libdl/rtl-obj.h (added) * cpukit/libdl/rtl-rap.c (added) * cpukit/libdl/rtl-rap.h (added) * cpukit/libdl/rtl-shell.c (added) * cpukit/libdl/rtl-shell.h (added) * cpukit/libdl/rtl-string.c (added) * cpukit/libdl/rtl-string.h (added) * cpukit/libdl/rtl-sym.c (added) * cpukit/libdl/rtl-sym.h (added) * cpukit/libdl/rtl-trace.c (added) * cpukit/libdl/rtl-trace.h (added) * cpukit/libdl/rtl-unresolved.c (added) * cpukit/libdl/rtl-unresolved.h (added) * cpukit/libdl/rtl.c (added) * cpukit/libdl/rtl.h (added) * cpukit/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/dl01/Makefile.am (added) * testsuites/libtests/dl01/dl-load.c (added) * testsuites/libtests/dl01/dl-load.h (added) * testsuites/libtests/dl01/dl-o1.c (added) * testsuites/libtests/dl01/dl01.doc (added) * testsuites/libtests/dl01/dl01.scn (added) * testsuites/libtests/dl01/init.c (added) cpukit: Add libdl with the Runtime Loader (RTL) code. This is a ... Wed, 29 Oct 2014 16:07:20 GMT Chris Nott [513668f6] * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_adc.h (added) Added missing stm32f4xxxx_adc.h Mon, 29 Sep 2014 19:31:18 GMT Jennifer Averett [410bcdfe] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/top/Makefile.am (added) * testsuites/libtests/top/init.c (added) * testsuites/libtests/top/system.h (added) * testsuites/libtests/top/task1.c (added) * testsuites/libtests/top/task2.c (added) * testsuites/libtests/top/task3.c (added) * testsuites/libtests/top/top.scn (added) top: Add new test. Tue, 28 Oct 2014 12:58:28 GMT Jennifer Averett [8b11ff67] * cpukit/libmisc/capture/capture-cli.c (modified) capture: Remove ctload command. rtems_cpu_usage_top should be used ... Mon, 29 Sep 2014 15:21:00 GMT Jennifer Averett [a7817010] * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_top.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) libmisc: Add top to shell. Mon, 29 Sep 2014 15:20:27 GMT Jennifer Averett [6031da4] * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (added) * cpukit/libmisc/cpuuse/cpuuse.h (modified) libmisc: Add top to cpuusage. Mon, 08 Sep 2014 14:47:13 GMT Jennifer Averett [254b7db0] * testsuites/libtests/capture01/init.c (modified) capture01: Remove capture task tracking. This involved adding a new ... Thu, 04 Sep 2014 18:49:04 GMT Jennifer Averett [05e4e599] * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/capture/capture_user_extension.c (modified) * cpukit/libmisc/capture/captureimpl.h (modified) capture: Removal of capture task tracking. This patch removes ... Fri, 19 Sep 2014 19:05:49 GMT Jennifer Averett [7c797a1] * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) cpuuse: Move is_executing_on_a_core to threadimpl.h Fri, 19 Sep 2014 19:04:49 GMT Jennifer Averett [f9b19d9] * cpukit/score/include/rtems/score/threadimpl.h (modified) score: Move is_executing_on_a_core from cpuusagereport.c to threadimpl.h Mon, 08 Sep 2014 14:46:43 GMT Jennifer Averett [134a181] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadinitialize.c (modified) score: Add capture data to tcb.
