# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/20/24 18:34:50 Wed, 26 Feb 2014 02:27:40 GMT Brian Norris [4dc16ea] * cpukit/libfs/src/jffs2/src/readinode.c (modified) jffs2: fix unbalanced locking Li Zefan reported an unbalanced ... Tue, 10 Feb 2015 20:49:48 GMT Chen Jie [8e55f0d] * cpukit/libfs/src/jffs2/src/scan.c (modified) jffs2: fix handling of corrupted summary length sm->offset maybe ... Sun, 11 Jan 2015 16:36:48 GMT Rickard Strandqvist [8bcd5a22] * cpukit/libfs/src/jffs2/src/compr_rubin.c (modified) jffs2: compr_rubin: Remove unused function Remove the function ... Thu, 27 Nov 2014 11:05:46 GMT Geert Uytterhoeven [2c5980f] * cpukit/libfs/src/jffs2/src/readinode.c (modified) jffs2: Drop bogus if in comment Signed-off-by: Geert Uytterhoeven ... Fri, 01 Aug 2014 19:13:40 GMT Al Viro [e315b460] * cpukit/libfs/src/jffs2/src/jffs2_fs_sb.h (modified) kill wbuf_queued/wbuf_dwork_lock schedule_delayed_work() happening ... Fri, 08 Aug 2014 21:23:14 GMT Yinghai Lu [9da567b2] * cpukit/libfs/src/jffs2/src/compr_zlib.c (modified) initramfs: support initramfs that is bigger than 2GiB Now with ... Mon, 06 Jan 2014 13:36:55 GMT Ajesh Kunhipurayil Vijayan [a60ac5ca] * cpukit/libfs/src/jffs2/src/nodelist.h (modified) jffs2: Fix crash due to truncation of csize mounting JFFS2 ... Mon, 06 Jan 2014 13:36:54 GMT Kamlakant Patel [03cba49d] * cpukit/libfs/src/jffs2/src/compr_rtime.c (modified) jffs2: Fix segmentation fault found in stress test Creating a large ... Wed, 12 Feb 2014 20:44:56 GMT Li Zefan [d60c1665] * cpukit/libfs/src/jffs2/src/nodemgmt.c (modified) jffs2: avoid soft-lockup in jffs2_reserve_space_gc() We triggered ... Wed, 12 Feb 2014 20:44:57 GMT Li Zefan [52c50c78] * cpukit/libfs/src/jffs2/src/nodemgmt.c (modified) jffs2: remove from wait queue after schedule() @wait is a local ... Fri, 20 Dec 2013 13:16:47 GMT Christoph Hellwig [e650f4fc] * cpukit/libfs/src/jffs2/src/acl.h (modified) jffs2: use generic posix ACL infrastructure Also don't bother to ... Thu, 23 Jan 2014 23:56:11 GMT Cody P Schafer [1465e70c] * cpukit/libfs/src/jffs2/src/nodelist.c (modified) * cpukit/libfs/src/jffs2/src/readinode.c (modified) fs/jffs2: use rbtree postorder iteration helper instead of opencoding ... Wed, 04 Jul 2018 14:12:14 GMT Sebastian Huber [22d9575] * cpukit/include/linux/rbtree.h (modified) * testsuites/sptests/sprbtree01/init.c (modified) linux: Add rbtree_postorder_for_each_entry_safe() Update #3465. Tue, 03 Jul 2018 18:32:31 GMT Sebastian Huber [0cb4257] * cpukit/include/linux/rbtree.h (modified) * cpukit/libfs/src/jffs2/src/readinode.c (modified) linux: Simplify Remove the placeholder struct ... Wed, 04 Jul 2018 14:14:35 GMT Sebastian Huber [877aeab] * cpukit/headers.am (modified) * cpukit/include/linux/rbtree.h (moved) linux: Install This makes it possible to test this ... Fri, 29 Jun 2018 18:00:28 GMT Sebastian Huber [6539bea] * cpukit/include/rtems/score/rbtree.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/src/rbtreepostorder.c (added) * testsuites/sptests/sprbtree01/init.c (modified) score: Add postorder tree iteration support Update #3465. Mon, 09 Jul 2018 11:12:57 GMT Amaan Cheval [cf811a4] * bsps/x86_64/amd64/console/console.c (modified) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (modified) x86_64/console: Add NS16550 polled console driver This addition ... Mon, 09 Jul 2018 11:12:56 GMT Amaan Cheval [76c03152] * bsps/x86_64/amd64/config/amd64.cfg (added) * bsps/x86_64/amd64/console/console.c (added) * bsps/x86_64/amd64/headers.am (added) * bsps/x86_64/amd64/include/bsp.h (added) * bsps/x86_64/amd64/include/start.h (added) * bsps/x86_64/amd64/include/tm27.h (added) * bsps/x86_64/amd64/start/bsp_specs (added) * bsps/x86_64/amd64/start/bspstart.c (added) * bsps/x86_64/amd64/start/linkcmds (added) * bsps/x86_64/amd64/start/start.c (added) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/x86_64/Makefile.am (added) * c/src/lib/libbsp/x86_64/acinclude.m4 (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (added) * c/src/lib/libbsp/x86_64/amd64/configure.ac (added) * c/src/lib/libbsp/x86_64/configure.ac (added) * cpukit/configure.ac (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/x86_64/Makefile.am (added) * cpukit/score/cpu/x86_64/cpu.c (added) * cpukit/score/cpu/x86_64/headers.am (added) * cpukit/score/cpu/x86_64/include/machine/elf_machdep.h (added) * cpukit/score/cpu/x86_64/include/rtems/asm.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (added) * cpukit/score/cpu/x86_64/x86_64-context-initialize.c (added) * cpukit/score/cpu/x86_64/x86_64-context-switch.S (added) bsp/x86_64: Minimal bootable BSP Current state: - Basic context ... Fri, 06 Jul 2018 09:20:31 GMT Sebastian Huber [1a19239] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/console/console-config.c (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add console support for NS16550 devices Update #3433. Fri, 06 Jul 2018 11:52:22 GMT Sebastian Huber [31f90a2] * bsps/riscv/riscv/console/console-config.c (modified) * bsps/riscv/riscv/console/htif.c (modified) * bsps/riscv/riscv/include/dev/serial/htif.h (modified) bsp/riscv: Simplify printk() support This is a prepartion to add ... Fri, 06 Jul 2018 09:07:20 GMT Sebastian Huber [bca36d9] * bsps/riscv/riscv/start/start.S (modified) * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Add LADDR assembler define An address must be loaded to a ... Fri, 06 Jul 2018 06:12:40 GMT Sebastian Huber [dd32e2b2] * bsps/riscv/riscv/clock/clockdrv.c (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Implement CPU counter Update #3433. Fri, 06 Jul 2018 07:25:57 GMT Sebastian Huber [6418c91d] * config.guess (modified) * config.sub (modified) Update config.guess and config.sub Update via: wget -O ... Thu, 05 Jul 2018 06:54:34 GMT Sebastian Huber [fc5cc9a] * bsps/arm/include/bsp/arm-a9mpcore-start.h (modified) bsps/arm: Include missing header file Wed, 04 Jul 2018 14:15:22 GMT Sebastian Huber [d3dff40] * bsps/arm/headers.am (modified) * bsps/riscv/riscv/headers.am (modified) bsps: Update headers.am Tue, 03 Jul 2018 07:54:47 GMT Sebastian Huber [e755782] * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Clear reservations See also RISC-V User-Level ISA V2.3, ... Tue, 03 Jul 2018 09:50:53 GMT Sebastian Huber [77fbbd6] * cpukit/configure.ac (modified) * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) posix: Check for new prototypes Update #3342. Update #3343. Mon, 02 Jul 2018 13:21:36 GMT Sebastian Huber [e07b51a7] * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Fix fcsr initialization Update #3433. Fri, 29 Jun 2018 10:55:28 GMT Sebastian Huber [b36bf5b] * cpukit/include/rtems/score/percpu.h (modified) score: Increase PER_CPU_CONTROL_SIZE_APPROX Increase the ... Fri, 29 Jun 2018 10:08:01 GMT Sebastian Huber [79d69ae] * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) riscv: Fix SMP context switch support Update #3433. Fri, 29 Jun 2018 06:07:02 GMT Sebastian Huber [109bc1c7] * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) riscv: Add SMP context switch support Update #3433. Thu, 28 Jun 2018 07:32:26 GMT Sebastian Huber [52352387] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-context-validate.S (modified) * cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Add floating-point support Update #3433. Thu, 28 Jun 2018 06:21:44 GMT Sebastian Huber [995e91e8] * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/src/threadhandler.c (modified) riscv: Fix global construction Update #3433. Thu, 28 Jun 2018 06:20:47 GMT Sebastian Huber [694e79a0] * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) riscv: Add TLS support Update #3433. Wed, 27 Jun 2018 12:46:06 GMT Sebastian Huber [afb60eb] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Remove dead code Update #3433. Wed, 27 Jun 2018 08:05:50 GMT Sebastian Huber [e43994d] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Optimize context switch and interrupts Save/restore ... Wed, 27 Jun 2018 07:43:39 GMT Sebastian Huber [a8188730] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Fix _CPU_Context_Initialize() prototype Update #3433. Thu, 28 Jun 2018 11:55:29 GMT Sebastian Huber [dffc08c] * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Fix interrupt save/restore Update #3433. Wed, 27 Jun 2018 10:18:09 GMT Sebastian Huber [40f81ce6] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-validate.S (modified) riscv: Implement _CPU_Context_validate() Update #3433. Wed, 27 Jun 2018 10:17:21 GMT Sebastian Huber [71af1a4] * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Make some CPU port defines visible to asm Move SREG and LREG ... Wed, 27 Jun 2018 06:57:08 GMT Sebastian Huber [8f035cb] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S (modified) riscv: Implement _CPU_Context_volatile_clobber() Update #3433. Wed, 27 Jun 2018 06:54:13 GMT Sebastian Huber [b706b4a] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) riscv: Remove mstatus from thread context The mstatus register ... Wed, 27 Jun 2018 06:43:25 GMT Sebastian Huber [2987c4f] * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Remove x8 initialization The RISC-V psABI ... Wed, 27 Jun 2018 06:42:48 GMT Sebastian Huber [04698eb] * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Properly align the thread stack Update #3433. Wed, 27 Jun 2018 06:37:34 GMT Sebastian Huber [a49a3c8e] * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Do not clear thread context Do not clear the complete thread ... Wed, 27 Jun 2018 06:35:13 GMT Sebastian Huber [9510742] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Fix CPU_STACK_ALIGNMENT According to the RISC-V psABI ... Wed, 27 Jun 2018 06:08:10 GMT Sebastian Huber [98f051e] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-initialize.c (modified) riscv: Remove RISCV_GCC_RED_ZONE_SIZE The current ABI says that ... Tue, 26 Jun 2018 06:53:28 GMT Sebastian Huber [9704d86f] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Enable interrupts during dispatch after ISR The code ... Tue, 26 Jun 2018 05:15:28 GMT Sebastian Huber [0fd8287] * bsps/riscv/riscv/start/start.S (modified) * cpukit/score/cpu/riscv/include/rtems/asm.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) riscv: Add _CPU_Get_current_per_CPU_control() Update #3433. Tue, 26 Jun 2018 05:13:28 GMT Sebastian Huber [3be4478f] * bsps/riscv/riscv/clock/clockdrv.c (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) riscv: Avoid namespace pollution Remove ... Thu, 28 Jun 2018 12:59:38 GMT Sebastian Huber [bc3bdf2] * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Optimize and fix interrupt disable/enable Use the atomic ... Wed, 27 Jun 2018 05:47:33 GMT Sebastian Huber [ff7b104] * bsps/riscv/riscv/irq/irq.c (modified) bsp/riscv: Remove bsp_interrupt_handler_default() It duplicated the ... Mon, 25 Jun 2018 09:12:24 GMT Sebastian Huber [cdfed94f] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/include/bsp.h (modified) * bsps/riscv/riscv/include/dev/irq/clint.h (added) bsp/riscv: Rework clock driver Use device tree provided timebase ... Mon, 25 Jun 2018 06:44:16 GMT Sebastian Huber [1232cd46] * bsps/riscv/riscv/console/console-config.c (added) * bsps/riscv/riscv/console/htif.c (moved) * bsps/riscv/riscv/include/dev/serial/htif.h (added) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add device tree support for console Update #3433. Thu, 28 Jun 2018 11:04:58 GMT Sebastian Huber [c558cc4] * bsps/riscv/riscv/start/start.S (modified) bsp/riscv: Fix vector table for lp64 Update #3433. Fri, 22 Jun 2018 11:58:11 GMT Sebastian Huber [5f5c450] * bsps/riscv/riscv/start/start.S (modified) bsp/riscv: Add SMP startup synchronization Update #3433. Fri, 22 Jun 2018 06:01:48 GMT Sebastian Huber [fe2cd01b] * bsps/riscv/riscv/include/bsp.h (modified) * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add device tree support Update #3433. Fri, 11 May 2018 04:54:59 GMT Sebastian Huber [2086948a] * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * testsuites/smptests/smpfatal08/init.c (modified) riscv: Add dummy SMP support Update #3433. Fri, 11 May 2018 04:25:47 GMT Sebastian Huber [853c5ef] * aclocal/enable-smp.m4 (modified) * c/src/aclocal/enable-smp.m4 (modified) * cpukit/aclocal/enable-smp.m4 (modified) build: Enable RISC-V SMP build Update #3433. Fri, 22 Jun 2018 11:30:49 GMT Sebastian Huber [7c3b0df1] * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) riscv: Implement ISR set/get level Fix prototypes. Update #3433. Fri, 22 Jun 2018 11:30:21 GMT Sebastian Huber [9b2ef07f] * bsps/riscv/riscv/start/start.S (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) bsp/riscv: Load global pointer Update #3433. Fri, 22 Jun 2018 09:14:07 GMT Sebastian Huber [b0ee789] * bsps/riscv/riscv/start/start.S (modified) bsp/riscv: Use memset() to clear .bss Update #3433. Tue, 26 Jun 2018 05:48:06 GMT Sebastian Huber [52f4fb6] * bsps/riscv/riscv/start/start.S (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/riscv/riscv-context-validate.S (modified) * cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S (modified) * cpukit/score/cpu/riscv/riscv-exception-handler.S (modified) riscv: Format assembler files Use tabs to match the GCC generated ... Fri, 22 Jun 2018 07:03:19 GMT Sebastian Huber [fef0a41] * bsps/riscv/riscv/start/start.S (modified) bsp/riscv: Do not clear integer registers at start There is no need ... Fri, 22 Jun 2018 09:00:01 GMT Sebastian Huber [38024362] * bsps/riscv/riscv/console/console-io.c (modified) bsp/riscv: Fix some warnings Update #3444. Fri, 22 Jun 2018 05:51:08 GMT Sebastian Huber [16d905f] * bsps/riscv/riscv/start/linkcmds.in (moved) * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Add BSP options to define RAM region Update #3433. Fri, 22 Jun 2018 05:35:27 GMT Sebastian Huber [37a1fc2] * c/src/lib/libbsp/riscv/riscv/configure.ac (modified) bsp/riscv: Remove unused BSP options Update #3433. Fri, 22 Jun 2018 05:10:44 GMT Sebastian Huber [f3da074a] * bsps/riscv/riscv/config/rv32imafd.cfg (added) * bsps/riscv/riscv/config/rv64imac_medany.cfg (added) * bsps/riscv/riscv/config/rv64imafd.cfg (added) * bsps/riscv/riscv/config/rv64imafd_medany.cfg (added) * bsps/riscv/riscv/config/rv64imafdc_medany.cfg (added) bsp/riscv: Add new BSP variants The latest RISC-V tool chain ... Fri, 22 Jun 2018 05:06:57 GMT Sebastian Huber [6f5d88a] * bsps/riscv/riscv/btimer/btimer.c (moved) * bsps/riscv/riscv/clock/clockdrv.c (moved) * bsps/riscv/riscv/config/rv32i.cfg (moved) * bsps/riscv/riscv/config/rv32iac.cfg (moved) * bsps/riscv/riscv/config/rv32im.cfg (moved) * bsps/riscv/riscv/config/rv32imac.cfg (moved) * bsps/riscv/riscv/config/rv32imafc.cfg (moved) * bsps/riscv/riscv/config/rv64imac.cfg (moved) * bsps/riscv/riscv/config/rv64imafdc.cfg (moved) * bsps/riscv/riscv/console/console-io.c (moved) * bsps/riscv/riscv/headers.am (added) * bsps/riscv/riscv/include/bsp.h (moved) * bsps/riscv/riscv/include/bsp/irq.h (moved) * bsps/riscv/riscv/include/tm27.h (moved) * bsps/riscv/riscv/irq/irq.c (moved) * bsps/riscv/riscv/start/bsp_fatal_halt.c (moved) * bsps/riscv/riscv/start/bsp_specs (moved) * bsps/riscv/riscv/start/linkcmds (moved) * bsps/riscv/riscv/start/linkcmds.base (moved) * bsps/riscv/riscv/start/start.S (moved) * bsps/riscv/riscv_generic/headers.am (deleted) * c/src/lib/libbsp/riscv/acinclude.m4 (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (moved) * c/src/lib/libbsp/riscv/riscv/configure.ac (moved) bsp/riscv_generic: Rename to "riscv" Update #3433. Fri, 22 Jun 2018 05:04:12 GMT Sebastian Huber [41e2295] * bsps/riscv/riscv_generic/config/rv32i.cfg (modified) * bsps/riscv/riscv_generic/config/rv32iac.cfg (modified) * bsps/riscv/riscv_generic/config/rv32im.cfg (modified) * bsps/riscv/riscv_generic/config/rv32imac.cfg (modified) * bsps/riscv/riscv_generic/config/rv32imafc.cfg (modified) * bsps/riscv/riscv_generic/config/rv64imac.cfg (modified) * bsps/riscv/riscv_generic/config/rv64imafdc.cfg (modified) bsp/riscv_generic: Use standard optimization flags Update #3433. Mon, 28 May 2018 11:14:12 GMT Hesham Almatary [92388f6] * bsps/riscv/riscv_generic/config/rv32i.cfg (moved) * bsps/riscv/riscv_generic/config/rv32iac.cfg (added) * bsps/riscv/riscv_generic/config/rv32im.cfg (added) * bsps/riscv/riscv_generic/config/rv32imac.cfg (added) * bsps/riscv/riscv_generic/config/rv32imafc.cfg (added) * bsps/riscv/riscv_generic/config/rv64imac.cfg (moved) * bsps/riscv/riscv_generic/config/rv64imafdc.cfg (added) bsps/riscv_generic: Rename and add variants Add BSP variants to ... Tue, 29 May 2018 07:14:24 GMT Sebastian Huber [9e3bb45] * bsps/riscv/riscv_generic/console/console-io.c (modified) * bsps/riscv/riscv_generic/start/linkcmds (modified) * bsps/riscv/riscv_generic/start/linkcmds.base (added) * bsps/riscv/riscv_generic/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) bsp/riscv_generic: New linker command file This linker command file ... Tue, 19 Jun 2018 07:09:51 GMT Sebastian Huber [511dc4b] * bsps/arm/altera-cyclone-v/config/altcycv_devkit_smp.cfg (deleted) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp (deleted) * bsps/arm/csb336/start/start.S (modified) * bsps/arm/csb337/start/start.S (modified) * bsps/arm/edb7312/start/start.S (modified) * bsps/arm/gumstix/start/start.S (modified) * bsps/arm/imx/start/linkcmds.imx7 (modified) * bsps/arm/include/bsp/linker-symbols.h (modified) * bsps/arm/raspberrypi/start/bspsmp.c (modified) * bsps/arm/raspberrypi/start/linkcmds (moved) * bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu_smp.cfg (deleted) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp (deleted) * bsps/arm/rtl22xx/start/start.S (modified) * bsps/arm/shared/start/arm-a9mpcore-smp.c (modified) * bsps/arm/shared/start/linkcmds.base (modified) * bsps/arm/shared/start/start.S (modified) * bsps/arm/smdk2410/start/start.S (modified) * bsps/arm/xilinx-zynq/start/linkcmds.in (modified) * bsps/bfin/TLL6527M/start/linkcmds (modified) * bsps/bfin/bf537Stamp/start/linkcmds (modified) * bsps/bfin/eZKit533/start/linkcmds (modified) * bsps/lm32/lm32_evr/start/linkcmds (modified) * bsps/lm32/milkymist/start/linkcmds (modified) * bsps/lm32/shared/start/start.S (modified) * bsps/m32c/m32cbsp/start/linkcmds (modified) * bsps/m32c/m32cbsp/start/start.S (modified) * bsps/m68k/gen68340/start/linkcmds (modified) * bsps/m68k/gen68340/start/start.S (modified) * bsps/m68k/gen68360/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds.bootp (modified) * bsps/m68k/gen68360/start/linkcmds.prom (modified) * bsps/m68k/gen68360/start/start.S (modified) * bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash (modified) * bsps/m68k/genmcf548x/start/start.S (modified) * bsps/m68k/mcf52235/start/linkcmds (modified) * bsps/m68k/mcf52235/start/start.S (modified) * bsps/m68k/mcf5225x/start/linkcmds (modified) * bsps/m68k/mcf5225x/start/start.S (modified) * bsps/m68k/mcf5329/start/linkcmds (modified) * bsps/m68k/mcf5329/start/linkcmdsflash (modified) * bsps/m68k/mcf5329/start/start.S (modified) * bsps/m68k/mrm332/start/linkcmds (modified) * bsps/m68k/mrm332/start/start.S (modified) * bsps/m68k/shared/start/linkcmds.base (modified) * bsps/m68k/shared/start/start.S (modified) * bsps/mips/csb350/start/linkcmds (modified) * bsps/mips/csb350/start/start.S (modified) * bsps/mips/hurricane/start/linkcmds (modified) * bsps/mips/jmr3904/start/linkcmds (modified) * bsps/mips/jmr3904/start/start.S (modified) * bsps/mips/malta/start/linkcmds (modified) * bsps/mips/malta/start/start.S (modified) * bsps/mips/rbtx4925/start/linkcmds (modified) * bsps/mips/rbtx4938/start/linkcmds (modified) * bsps/mips/shared/irq/exception.S (modified) * bsps/nios2/nios2_iss/start/linkcmds (modified) * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/gen5200/include/bsp.h (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (modified) * bsps/powerpc/gen83xx/include/bsp.h (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/haleakala/start/bspstart.c (modified) * bsps/powerpc/haleakala/start/dlentry.S (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/start.S (modified) * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) * bsps/powerpc/mpc8260ads/start/linkcmds (modified) * bsps/powerpc/mvme3100/start/bspstart.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/psim/start/start.S (modified) * bsps/powerpc/qemuppc/start/bspstart.c (modified) * bsps/powerpc/qemuppc/start/start.S (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * bsps/powerpc/ss555/start/bspstart.c (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/ss555/start/start.S (modified) * bsps/powerpc/t32mppc/start/start.S (modified) * bsps/powerpc/tqm8xx/include/bsp.h (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/start.S (modified) * bsps/powerpc/virtex4/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex4/start/start.S (modified) * bsps/powerpc/virtex5/start/bspstart.c (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * bsps/powerpc/virtex5/start/start.S (modified) * bsps/riscv/riscv_generic/start/start.S (modified) * bsps/sh/gensh1/include/bsp.h (modified) * bsps/sh/gensh1/start/cpu_asm.c (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh1/start/start.S (modified) * bsps/sh/gensh2/include/bsp.h (modified) * bsps/sh/gensh2/start/cpu_asm.c (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * bsps/sh/gensh2/start/start.S (modified) * bsps/sh/gensh2/start/start.ram (modified) * bsps/sh/gensh2/start/start.rom (modified) * bsps/sh/gensh4/include/bsp.h (modified) * bsps/sh/gensh4/start/cpu_asm.c (modified) * bsps/sh/gensh4/start/linkcmds (modified) * bsps/sh/gensh4/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds.rom2ram (modified) * bsps/sh/gensh4/start/start.S (modified) * bsps/sh/shared/start/bspstart.c (modified) * bsps/sh/shsim/include/bsp.h (modified) * bsps/sh/shsim/start/cpu_asm.c (modified) * bsps/sh/shsim/start/linkcmds (modified) * bsps/sh/shsim/start/start.S (modified) * bsps/sparc/shared/start/bspgetworkarea.c (modified) * bsps/sparc/shared/start/start.S (modified) * bsps/v850/gdbv850sim/start/linkcmds (modified) * bsps/v850/gdbv850sim/start/start.S (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/cpu.c (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/cpu_asm.c (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/cpu.c (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/cpu_asm.S (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/percpuasm.c (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spsize/size.c (modified) Rework initialization and interrupt stack support Statically ... Tue, 19 Jun 2018 13:10:36 GMT Sebastian Huber [715d616] * bsps/arm/shared/start/linkcmds.base (modified) * bsps/bfin/TLL6527M/start/linkcmds (modified) * bsps/bfin/bf537Stamp/start/linkcmds (modified) * bsps/bfin/eZKit533/start/linkcmds (modified) * bsps/epiphany/epiphany_sim/start/linkcmds (modified) * bsps/i386/pc386/start/linkcmds (modified) * bsps/lm32/lm32_evr/start/linkcmds (modified) * bsps/lm32/milkymist/start/linkcmds (modified) * bsps/m32c/m32cbsp/start/linkcmds (modified) * bsps/m68k/av5282/start/linkcmds (modified) * bsps/m68k/av5282/start/linkcmdsflash (modified) * bsps/m68k/av5282/start/linkcmdsram (modified) * bsps/m68k/csb360/start/linkcmds (modified) * bsps/m68k/gen68340/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds.bootp (modified) * bsps/m68k/gen68360/start/linkcmds.prom (modified) * bsps/m68k/mcf5206elite/start/linkcmds (modified) * bsps/m68k/mcf5206elite/start/linkcmds.flash (modified) * bsps/m68k/mcf52235/start/linkcmds (modified) * bsps/m68k/mcf5225x/start/linkcmds (modified) * bsps/m68k/mcf5235/start/linkcmds (modified) * bsps/m68k/mcf5235/start/linkcmdsflash (modified) * bsps/m68k/mcf5235/start/linkcmdsram (modified) * bsps/m68k/mcf5329/start/linkcmds (modified) * bsps/m68k/mcf5329/start/linkcmdsflash (modified) * bsps/m68k/mrm332/start/linkcmds (modified) * bsps/m68k/shared/start/linkcmds.base (modified) * bsps/m68k/uC5282/start/linkcmds (modified) * bsps/mips/csb350/start/linkcmds (modified) * bsps/mips/hurricane/start/linkcmds (modified) * bsps/mips/jmr3904/start/linkcmds (modified) * bsps/mips/malta/start/linkcmds (modified) * bsps/mips/rbtx4925/start/linkcmds (modified) * bsps/mips/rbtx4938/start/linkcmds (modified) * bsps/moxie/moxiesim/start/linkcmds (modified) * bsps/nios2/nios2_iss/start/linkcmds (modified) * bsps/or1k/shared/start/linkcmds.base (modified) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (modified) * bsps/powerpc/gen83xx/start/linkcmds.mpc83xx (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/include/bsp/linker-symbols.h (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.gwlcfm (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5566evb (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5643l_evb (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5668g (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508 (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6_base (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674fevb (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.phycore_mpc5554 (modified) * bsps/powerpc/mpc8260ads/start/linkcmds (modified) * bsps/powerpc/psim/start/linkcmds (modified) * bsps/powerpc/qemuppc/start/linkcmds (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_0 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_1 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (modified) * bsps/powerpc/qoriq/start/mmu-config.c (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * bsps/powerpc/shared/start/linkcmds.share (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/t32mppc/start/linkcmds.t32mppc (modified) * bsps/powerpc/tqm8xx/start/linkcmds (modified) * bsps/powerpc/virtex/start/linkcmds.in (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * bsps/riscv/riscv_generic/start/linkcmds (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds (modified) * bsps/sh/gensh4/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds.rom2ram (modified) * bsps/sh/shsim/start/linkcmds (modified) * bsps/sparc/shared/start/linkcmds.base (modified) * bsps/sparc64/shared/start/linkcmds (modified) * bsps/v850/gdbv850sim/start/linkcmds (modified) bsps: Support .rtemsstack.* linker input sections Use a dedicated ... Tue, 19 Jun 2018 12:59:51 GMT Sebastian Huber [c8df844] * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) score: Add CPU_INTERRUPT_STACK_ALIGNMENT Add CPU port define for ... Thu, 21 Jun 2018 10:54:06 GMT Sebastian Huber [196ce18] * cpukit/libcsupport/src/consolesimpletask.c (modified) console: Add missing return status Update #3320. Fri, 01 Jun 2018 05:11:12 GMT Sebastian Huber [7ee59313] * bsps/arm/beagle/clock/clock.c (modified) * bsps/arm/csb336/clock/clockdrv.c (modified) * bsps/arm/csb337/clock/clock.c (modified) * bsps/arm/edb7312/clock/clockdrv.c (modified) * bsps/arm/gumstix/clock/clock.c (modified) * bsps/arm/raspberrypi/clock/clockdrv.c (modified) * bsps/arm/rtl22xx/clock/clockdrv.c (modified) * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-armv7m.c (modified) * bsps/arm/shared/clock/clock-nxp-lpc.c (modified) * bsps/arm/smdk2410/clock/clockdrv.c (modified) * bsps/arm/tms570/clock/clock.c (modified) * bsps/i386/pc386/clock/ckinit.c (modified) * bsps/lm32/shared/clock/ckinit.c (modified) * bsps/lm32/shared/milkymist_clock/ckinit.c (modified) * bsps/m68k/av5282/clock/clock.c (modified) * bsps/m68k/gen68360/clock/clock.c (modified) * bsps/m68k/genmcf548x/clock/clock.c (modified) * bsps/m68k/mcf52235/clock/clock.c (modified) * bsps/m68k/mcf5225x/clock/clock.c (modified) * bsps/m68k/mcf5235/clock/clock.c (modified) * bsps/m68k/mcf5329/clock/clock.c (modified) * bsps/m68k/uC5282/clock/clock.c (modified) * bsps/mips/csb350/clock/clockdrv.c (modified) * bsps/mips/jmr3904/clock/clockdrv.c (modified) * bsps/mips/rbtx4925/clock/clockdrv.c (modified) * bsps/mips/rbtx4938/clock/clockdrv.c (modified) * bsps/mips/shared/clock/clockdrv.c (modified) * bsps/nios2/nios2_iss/clock/clock.c (modified) * bsps/or1k/generic_or1k/clock/clockdrv.c (modified) * bsps/powerpc/mpc55xxevb/clock/clock-config.c (modified) * bsps/powerpc/qoriq/clock/clock-config.c (modified) * bsps/riscv/riscv_generic/clock/clockdrv.c (modified) * bsps/shared/dev/clock/clock-simidle.c (modified) * bsps/shared/dev/clock/clockimpl.h (modified) * bsps/sparc/erc32/clock/ckinit.c (modified) * bsps/sparc/leon2/clock/ckinit.c (modified) * bsps/sparc/leon3/clock/ckinit.c (modified) * bsps/sparc/shared/btimer/tlib_ckinit.c (modified) * bsps/sparc64/shared/clock/ckinit.c (modified) Remove Clock_driver_support_shutdown_hardware() The aim of this ... Wed, 27 Jun 2018 06:17:26 GMT Sebastian Huber [718a84af] * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) Remove unused CPU_MODES_INTERRUPT_LEVEL Mon, 18 Jun 2018 05:06:01 GMT Sebastian Huber [ebc5cfd] * testsuites/sptests/spmisc01/init.c (modified) * testsuites/sptests/spmisc01/spmisc01.doc (modified) spmisc01: Add test cases for basedefs.h stuff Fri, 15 Jun 2018 14:53:27 GMT Sebastian Huber [fe46647e] * cpukit/include/rtems/score/basedefs.h (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spmisc01/init.c (added) * testsuites/sptests/spmisc01/spmisc01.doc (added) * testsuites/sptests/spmisc01/spmisc01.scn (added) score: Macros to declare and define global symbols Add ... Wed, 20 Jun 2018 10:03:54 GMT Sebastian Huber [c47ad8e] * cpukit/include/rtems/stackchk.h (modified) * cpukit/libmisc/stackchk/check.c (modified) stackchk: Add SMP support Check the interrupt stacks of all ... Wed, 20 Jun 2018 09:29:46 GMT Sebastian Huber [1cb2e748] * cpukit/libmisc/stackchk/check.c (modified) stackchk: Refactor Stack_check_Dump_threads_usage Update #3459. Wed, 20 Jun 2018 09:13:19 GMT Sebastian Huber [8ff5916c] * cpukit/include/rtems/stackchk.h (modified) * cpukit/libmisc/stackchk/check.c (modified) stackchk: Remove dead code Update #3459. Wed, 20 Jun 2018 07:55:32 GMT Sebastian Huber [cc3edaa] * cpukit/libmisc/dummy/default-configuration.c (modified) config: SMP only CONFIGURE_MAXIMUM_PROCESSORS Do not set the ... Tue, 19 Jun 2018 13:20:52 GMT Sebastian Huber [b0c3ba2f] * bsps/epiphany/epiphany_sim/start/linkcmds (modified) * bsps/epiphany/include/bsp/linker-symbols.h (modified) * bsps/or1k/shared/start/linkcmds.base (modified) * bsps/riscv/include/bsp/linker-symbols.h (modified) * bsps/riscv/riscv_generic/start/linkcmds (modified) bsps: Remove superfluous bsp_processor_count This is unused copy ... Tue, 22 May 2018 06:52:13 GMT Sebastian Huber [762fa62] * bsps/arm/include/bsp/clock-armv7m.h (added) * bsps/arm/lpc176x/start/system-clocks.c (modified) * bsps/arm/shared/clock/clock-armv7m.c (modified) * bsps/arm/shared/cpucounter/cpucounter-armv7m.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) arm: Simplify CPU counter support Use the standard ARMv7-M systick ... Wed, 23 May 2018 12:17:25 GMT Sebastian Huber [65f868c] * bsps/arm/altera-cyclone-v/start/bspstart.c (modified) * bsps/arm/include/bsp/arm-a9mpcore-clock.h (modified) * bsps/arm/lpc176x/start/system-clocks.c (modified) * bsps/arm/lpc24xx/start/system-clocks.c (modified) * bsps/arm/lpc32xx/start/bspstart.c (modified) * bsps/arm/realview-pbx-a9/start/bspstart.c (modified) * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * bsps/arm/shared/cpucounter/cpucounter-armv7m.c (modified) * bsps/arm/tms570/cpucounter/cpucounterread.c (modified) * bsps/arm/xilinx-zynq/start/bspstart.c (modified) * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen83xx/start/bspstart.c (modified) * bsps/powerpc/haleakala/start/bspstart.c (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) * bsps/powerpc/mvme3100/start/bspstart.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/qemuppc/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/ss555/start/bspstart.c (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/bspstart.c (modified) * bsps/powerpc/virtex5/start/bspstart.c (modified) * bsps/shared/dev/cpucounter/cpucounterfrequency.c (added) * bsps/sparc/erc32/clock/ckinit.c (modified) * bsps/sparc/leon3/start/cpucounter.c (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * cpukit/include/rtems/counter.h (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/Makefile.am (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpucounterfrequency.c (added) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/Makefile.am (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) Add _CPU_Counter_frequency() Add rtems_counter_frequency() API ... Tue, 22 May 2018 07:14:07 GMT Sebastian Huber [4c7b18e3] * cpukit/include/rtems/sysinit.h (modified) * testsuites/sptests/spsysinit01/init.c (modified) Add RTEMS_SYSINIT_CPU_COUNTER Add initialization step for the CPU ... Tue, 22 May 2018 07:10:06 GMT Sebastian Huber [5ec5503] * cpukit/include/rtems/sysinit.h (modified) Reassign system initilization order numbers Assign each system ... Fri, 15 Jun 2018 06:18:26 GMT Sebastian Huber [bac8d934] * Makefile.am (modified) * c/src/make/README (modified) * c/src/make/host.cfg.in (modified) * configure.ac (modified) * tools/build/Makefile.am (deleted) * tools/build/README (deleted) * tools/build/config.h.in (deleted) * tools/build/configure.ac (deleted) * tools/build/install-if-change.in (deleted) tools: Remove install-if-change program The last installed tool in ... Fri, 15 Jun 2018 06:07:17 GMT Sebastian Huber [1f283f17] * bsps/powerpc/beatnik/config/beatnik.cfg (modified) bsp/beatnik: Remove CFLAGS_DEBUG_V This was the only BSP setting ... Fri, 15 Jun 2018 06:05:27 GMT Sebastian Huber [6fb0223] * c/src/make/configure.ac (modified) make: Remove obsolete AC_SUBST() Fri, 15 Jun 2018 05:53:42 GMT Sebastian Huber [5ff9547a] * c/src/make/README (modified) make: Remove CFLAGS_DEBUG_OPTIMIZE_V Do not document ... Thu, 14 Jun 2018 11:12:31 GMT Sebastian Huber [ae535b84] * tools/build/Makefile.am (modified) * tools/build/doxy-filter (deleted) tools: Remove duplicate doxy-filter This is a duplicate of ... Thu, 07 Jun 2018 04:37:39 GMT Sebastian Huber [e8b28ba] * aclocal/project-root.m4 (modified) * bsps/m68k/mrm332/config/mrm332.cfg (modified) * bsps/m68k/mvme147/config/mvme147.cfg (modified) * bsps/m68k/mvme147s/config/mvme147s.cfg (modified) * bsps/mips/hurricane/config/hurricane.cfg (modified) * bsps/mips/rbtx4925/config/rbtx4925.cfg (modified) * c/src/make/host.cfg.in (modified) * testsuites/aclocal/project-root.m4 (modified) * tools/build/Makefile.am (modified) * tools/build/configure.ac (modified) * tools/build/packhex.c (deleted) tools: Remove packhex All tools should be removed from the RTEMS ... Thu, 07 Jun 2018 06:13:20 GMT Sebastian Huber [df7f0ac6] * tools/build/rtems-testsuite-autostuff (deleted) tools: Remove rtems-testsuite-autostuff It is not used. Close #3447. Thu, 07 Jun 2018 05:54:51 GMT Sebastian Huber [a94a0f5] * tools/build/Makefile.am (modified) * tools/build/cvsignore-add.sh (deleted) tools: Remove cvsignore-add.sh This script is obsolete since moving ... Thu, 07 Jun 2018 05:52:56 GMT Sebastian Huber [1346d27] * tools/build/Makefile.am (modified) * tools/build/multigen (deleted) tools: Remove multigen This script is unused and out dated. Close ... Thu, 07 Jun 2018 04:18:40 GMT Sebastian Huber [31f0eb9e] * tools/build/Makefile.am (modified) * tools/build/compat.c (deleted) * tools/build/unhex.c (deleted) tools: Remove unhex This program has no license information and is ... Thu, 07 Jun 2018 04:17:45 GMT Sebastian Huber [64fa76bb] * tools/build/Makefile.am (modified) * tools/build/eolstrip.c (deleted) tools: Remove eolstrip This program has no license information and ...
