# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/24/24 15:39:57 Sun, 13 Dec 2015 12:22:53 GMT Chris Johns [431140ae] * rtems-bsps (modified) Display only valid BSPs, ignore other .cfg files. Show the ... Sat, 28 Nov 2015 11:01:36 GMT Pavel Pisa [2a9db26] * c/src/lib/libbsp/arm/tms570/startup/bspstart.c (modified) bsp/tms570: ensure that linker symbol comparison to NULL is not ... Wed, 25 Nov 2015 06:55:00 GMT Sebastian Huber [7828f1c3] * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/score/src/threadtimeout.c (modified) Fix _Assert() statement Mon, 23 Nov 2015 09:09:06 GMT Pavel Pisa [a6d176f] * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libmisc/untar/untar.c (modified) untar: do not exit with error when created directory already exists. ... Wed, 18 Nov 2015 17:45:32 GMT Premysl Houdek [f8bbbdd] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h (modified) * c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c (modified) bsp/tms570: unite code duplication in pinmux and clean SCI close per ... Thu, 12 Nov 2015 22:11:33 GMT Pavel Pisa [dec479b] * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137.inc (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_with_loader.cfg (modified) bsp/tms570: use common tms570ls3137.inc file for all board ling ... Thu, 12 Nov 2015 22:11:32 GMT Premysl Houdek [85750d1] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/README (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_with_loader.cfg (added) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_with_loader (added) bsp/tms570: separate Flash variants to one which boots directly and ... Thu, 12 Nov 2015 22:11:31 GMT Pavel Pisa [416cd88] * c/src/lib/libbsp/arm/tms570/include/tms570-pom.h (modified) * c/src/lib/libbsp/arm/tms570/irq/irq.c (modified) * c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c (modified) * c/src/lib/libbsp/arm/tms570/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram (modified) bsp/tms570: use POM only when application image does not start at ... Thu, 12 Nov 2015 22:11:30 GMT Premysl Houdek [572f5df] * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram (modified) bsp/tms570: updated reserved space for vector overlay in internal RAM Thu, 12 Nov 2015 22:11:29 GMT Premysl Houdek [08a98f7] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) bsp/tms570: fixed sci driver freeze when closing terminal bug ... Thu, 12 Nov 2015 22:11:28 GMT Premysl Houdek [e73d932] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h (added) * c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c (added) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) bsp/tms570: Pinmux support and EMAC pin definition added ... Thu, 12 Nov 2015 22:11:27 GMT Premysl Houdek [fb5d60d] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/include/irq.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emac.h (deleted) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emacc.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570.h (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) bsp/tms570: EMAC control header file corrected and EMAC interrupt ... Mon, 16 Nov 2015 13:13:28 GMT Daniel Cederman [2d7aad73] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) sparc: Fix context switch on SMP We must not load registers (e.g. ... Tue, 10 Nov 2015 16:23:12 GMT Sebastian Huber [72857659] * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/score/src/threadtimeout.c (modified) score: Fix race condition on SMP We must ensure that the ... Wed, 11 Nov 2015 10:49:45 GMT Sebastian Huber [0c9bf40b] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) Fix interrupt epilogue for ARMv7-AR and PowerPC Close #2470. Fri, 30 Oct 2015 12:00:01 GMT Sebastian Huber [12b5264] * cpukit/libblock/src/media.c (modified) libblock: Avoid NULL pointer access Thu, 29 Oct 2015 21:10:31 GMT Jan Sommer [b2d788b3] * cpukit/libgnat/adasupp.c (modified) ada: Add missing include Include stackimpl.h otherwise ... Tue, 20 Oct 2015 19:47:10 GMT Joel Sherrill [cb9bb9d1] * cpukit/sapi/include/confdefs.h (modified) * doc/user/conf.t (modified) * testsuites/psxtests/psximfs02/init.c (modified) CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK was undocumented and not error ... Wed, 21 Oct 2015 07:52:36 GMT Sebastian Huber [ad659ff8] * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) RFS: Fix resource leak Update #2433. Thu, 22 Oct 2015 19:53:36 GMT Ben Gras [bad82027] * testsuites/libtests/configure.ac (modified) Fail gracefully if pax is not found The $(PAX) variable is used ... Tue, 20 Oct 2015 23:07:00 GMT Joel Sherrill [ec6f20fc] * c/src/lib/libbsp/moxie/moxiesim/configure.ac (modified) moxiesim/configure.ac: Fix typo Tue, 20 Oct 2015 21:35:46 GMT Joel Sherrill [13e705c] * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim-testsuite.tcfg (modified) h8sim-testsuite.tcfg: Add fsdosfsname01 closes #2432. Tue, 20 Oct 2015 09:16:12 GMT Sebastian Huber [9c96ea7] * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) bsp/leon3: Fix Termios context usage Only the context of the ... Fri, 11 Sep 2015 08:42:06 GMT Sebastian Huber [edf7732] * cpukit/sapi/src/rbheap.c (modified) * testsuites/libtests/rbheap01/init.c (modified) rbheap: Fix rtems_rbheap_free() Remove unused descriptor of merged ... Fri, 11 Sep 2015 08:21:15 GMT Sebastian Huber [deb3f29] * testsuites/libtests/rbheap01/init.c (modified) libtests/rbheap01: Simplify Update #2417. Thu, 10 Sep 2015 15:20:41 GMT Marcos Diaz [44eb9893] * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) Beaglebone: fix missing clobber in inline assembly. ... Thu, 03 Sep 2015 20:55:52 GMT Martin Galvan [ccebc571] * cpukit/libmisc/dumpbuf/dumpbuf.c (modified) cpukit/libmisc/dumpbuf/dumpbuf.c: Fix compilation warnings ... Thu, 03 Sep 2015 20:25:35 GMT Martin Galvan [efb798e] * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) cpukit/libnetworking/rtems/rtems_dhcp.c: Fix compilation error ... Wed, 02 Sep 2015 21:54:24 GMT Martin Galvan [9e2197d] * cpukit/libmisc/dumpbuf/dumpbuf.c (modified) cpukit/libmisc/dumpbuf/dumpbuf.c: Fix undefined behavior for ... Wed, 02 Sep 2015 21:54:23 GMT Martin Galvan [631d254] * tools/cpu/nios2/ptf.c (modified) tools/cpu/nios2/ptf.c: Fix leak of memory pointed to by new_prefix ... Wed, 02 Sep 2015 21:54:25 GMT Martin Galvan [c62129c5] * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) cpukit/libnetworking/rtems/rtems_dhcp.c: Fix leak on realloc failure ... Wed, 02 Sep 2015 21:54:22 GMT Martin Galvan [1491f694] * tools/cpu/nios2/memory.c (modified) tools/cpu/nios2/memory.c: Fix uninitialized use of variable memory ... Wed, 02 Sep 2015 21:54:21 GMT Martin Galvan [d781ad5] * c/src/lib/libbsp/shared/umon/umon.h (modified) * cpukit/posix/include/rtems/posix/ptimer.h (modified) * cpukit/rtems/include/rtems/rtems/dpmemimpl.h (modified) various .h files: Add missing C++ extern wrappers Updates #2405. Tue, 01 Sep 2015 07:47:12 GMT Sebastian Huber [6d734bae] * cpukit/score/cpu/arm/armv4-sync-synchronize.c (modified) arm: Replace __sync_synchronize() implementation Tue, 01 Sep 2015 07:42:46 GMT Sebastian Huber [35e0394] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Use compiler memory barrier by default Tue, 18 Aug 2015 04:21:17 GMT Sebastian Huber [9ccdb1d] * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * doc/user/rbtree.t (modified) * testsuites/sptests/sprbtree01/init.c (modified) rbtree: Delete rtems_rbtree_find_control() This function is hard to ... Thu, 06 Aug 2015 02:17:41 GMT Nick Withers [7a0df6b] * cpukit/libfs/src/nfsclient/src/nfs.c (modified) Respect 2^32 - 1 B NFSv2 maximum file size closes #2384 Mon, 03 Aug 2015 16:34:40 GMT Joel Sherrill [c9318aa] * doc/user/c_user.texi (modified) user/c_user.texi: Correct info index entry closes #2380. Sun, 02 Aug 2015 15:31:09 GMT Joel Sherrill [652888c] * c/src/ada-tests/support/init.c (modified) ada-tests/support/init.c: Fix compile errors and warnings closes #2379. Sat, 01 Aug 2015 10:43:12 GMT Jan Sommer [1cf91e0b] * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/armv4-sync-synchronize.c (added) Add __synch_synchronize function for arm Fixes link failure when ... Sat, 01 Aug 2015 16:58:56 GMT Nick Withers [dc47565] * ampolish3 (modified) ampolish3: Use env to find perl more reliably Fixes breakage on at ... Sun, 26 Jul 2015 13:27:10 GMT Michael Davidsaver [8da63adc] * cpukit/libnetworking/lib/tftpDriver.c (modified) tftpDriver: close() false error closes #2376. Fri, 24 Jul 2015 08:47:25 GMT Sebastian Huber [3984a0e1] * cpukit/score/cpu/m68k/__m68k_read_tp.c (modified) m68k: Include proper header file Thu, 23 Jul 2015 18:34:19 GMT Sebastian Huber [2f43241] * cpukit/score/cpu/arm/__tls_get_addr.c (modified) arm: Include proper header file Thu, 23 Jul 2015 07:00:31 GMT Sebastian Huber [0ad8a33] * cpukit/dev/i2c/i2c-dev.c (modified) * testsuites/libtests/i2c01/init.c (modified) i2c: Fix return status of i2c dev read/write Thu, 23 Jul 2015 06:36:30 GMT Sebastian Huber [f9a59795] * doc/cpu_supplement/arm.t (modified) * doc/cpu_supplement/avr.t (modified) * doc/cpu_supplement/bfin.t (modified) * doc/cpu_supplement/epiphany.t (modified) * doc/cpu_supplement/general.t (modified) * doc/cpu_supplement/h8300.t (modified) * doc/cpu_supplement/i386.t (modified) * doc/cpu_supplement/lm32.t (modified) * doc/cpu_supplement/m32c.t (modified) * doc/cpu_supplement/m32r.t (modified) * doc/cpu_supplement/m68k.t (modified) * doc/cpu_supplement/microblaze.t (modified) * doc/cpu_supplement/mips.t (modified) * doc/cpu_supplement/nios2.t (modified) * doc/cpu_supplement/or1k.t (modified) * doc/cpu_supplement/powerpc.t (modified) * doc/cpu_supplement/sh.t (modified) * doc/cpu_supplement/sparc.t (modified) * doc/cpu_supplement/sparc64.t (modified) * doc/cpu_supplement/v850.t (modified) doc: Add SMP section to CPU Arch Supplement Tue, 21 Jul 2015 07:29:56 GMT Sebastian Huber [8b14cbd9] * c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h (modified) bsps/arm: Update due to API changes Fri, 17 Jul 2015 15:04:06 GMT Premysl Houdek [49c1d25d] * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c (modified) bsp/tms570 Use bitfields instead of hard-coded values ... Fri, 17 Jul 2015 15:04:05 GMT Premysl Houdek [9a84f983] * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_adc.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_ccmsr.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_crc.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dcan.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dcc.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dma.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dmm.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_efuse.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emac.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emacm.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emif.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_esm.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_flash.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_flex_ray.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_gio.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_htu.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_i2c.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_iomm.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_lin.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_mdio.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_n2het.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pbist.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pcr.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pll.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pmm.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pom.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_rti.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_rtp.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sci.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_spi.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_stc.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sys.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sys2.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_tcr.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_tcram.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_vim.h (modified) bsp/tms570: skipped 32bit field definitions and corrected single bit ... Fri, 17 Jul 2015 14:42:35 GMT Joel Sherrill [3f923fd2] * doc/ada_user/version.texi (modified) * doc/bsp_howto/version.texi (modified) * doc/common/cpright.texi (modified) * doc/cpu_supplement/version.texi (modified) * doc/develenv/version.texi (modified) * doc/filesystem/version.texi (modified) * doc/networking/version.texi (modified) * doc/new_chapters/version.texi (modified) * doc/porting/version.texi (modified) * doc/posix1003.1/version.texi (modified) * doc/posix_users/version.texi (modified) * doc/relnotes/version.texi (modified) * doc/shell/version.texi (modified) * doc/started/version.texi (modified) * doc/user/version.texi (modified) Update date Fri, 17 Jul 2015 08:53:22 GMT Sebastian Huber [9154c3f9] * doc/user/smp.t (modified) doc: Add thread dispatch details for SMP Fri, 17 Jul 2015 09:55:51 GMT Sebastian Huber [3bb342ca] * doc/user/smp.t (modified) doc: Clarify interrupts disable problems on SMP Fri, 17 Jul 2015 07:16:37 GMT Sebastian Huber [b56ddbb] * doc/user/smp.t (modified) doc: Fix SMP task variables section Fri, 17 Jul 2015 05:56:09 GMT Sebastian Huber [e5a79e54] * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.h (modified) bsp/mpc83xx: Update due to header guard change Close #2373. Thu, 16 Jul 2015 18:15:10 GMT Joel Sherrill [db01d0c] * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) sparc64/rtems/score/cpu.h: Delete dead declaration Thu, 16 Jul 2015 18:14:48 GMT Joel Sherrill [7e14385] * c/src/lib/libbsp/sh/shared/startup/bspstart.c (modified) sh/shared/startup/bspstart.c: Add include of percpu.h Thu, 16 Jul 2015 12:14:32 GMT Premysl Houdek [069560a] * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/system-clocks.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-pom.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-rti.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-vim.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570.h (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) * c/src/lib/libbsp/arm/tms570/startup/bspreset.c (modified) bsp/tms570: source changes reflecting new headers. Signed-off-by: ... Thu, 16 Jul 2015 12:14:30 GMT Pavel Pisa [602e395] * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) bsp/tms570: fix get time resolution after infrastructure change to ... Thu, 16 Jul 2015 14:26:09 GMT Premysl Houdek [bea49c9] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_adc.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_ccmsr.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_crc.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dcan.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dcc.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dma.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dmm.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_efuse.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emac.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emacm.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emif.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_esm.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_flash.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_flex_ray.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_gio.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_htu.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_i2c.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_iomm.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_lin.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_mdio.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_n2het.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pbist.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pcr.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pll.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pmm.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pom.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_rti.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_rtp.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sci.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_spi.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_stc.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sys.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sys2.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_tcr.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_tcram.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_vim.h (added) bsp/tms570: New/generated header files for TMS570 SoC peripherals ... Thu, 16 Jul 2015 15:43:51 GMT Joel Sherrill [4784214a] * c/src/lib/libbsp/arm/gba/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/include/bsp.h (modified) * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h (modified) remaining bsp.h: Fix by hand to LIBBSP_@CPU@_@BSP_FAMILY@_BSP_H ... Thu, 16 Jul 2015 15:40:05 GMT Joel Sherrill [9cff822a] * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb337/include/bsp.h (modified) * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) * c/src/lib/libbsp/avr/avrtest/include/bsp.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/include/bsp.h (modified) * c/src/lib/libbsp/bfin/bf537Stamp/include/bsp.h (modified) * c/src/lib/libbsp/bfin/eZKit533/include/bsp.h (modified) * c/src/lib/libbsp/h8300/h8sim/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h (modified) * c/src/lib/libbsp/lm32/milkymist/include/bsp.h (modified) * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (modified) * c/src/lib/libbsp/m32r/m32rsim/include/bsp.h (modified) * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf52235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5329/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/bsp.h (modified) * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) * c/src/lib/libbsp/mips/malta/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (modified) * c/src/lib/libbsp/moxie/moxiesim/include/bsp.h (modified) * c/src/lib/libbsp/nios2/nios2_iss/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ep1a/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/haleakala/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qemuppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ss555/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh4/include/bsp.h (modified) * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/v850/gdbv850sim/include/bsp.h (modified) Most bsp.h: Switch to LIBBSP_@CPU@_@BSP_FAMILY@_H for guard This ... Wed, 15 Jul 2015 08:51:12 GMT Sebastian Huber [93f5adb] * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Do not use the ATB for e500 multilib The e500v1 has no ... Wed, 15 Jul 2015 06:55:42 GMT Nick Withers [e2fcb7d] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix _CPU_Counter_read() The mftb is not available on Book ... Mon, 13 Jul 2015 08:19:04 GMT Sebastian Huber [c5d0ca9] * cpukit/libcsupport/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) libcsupport: Workaround for GCC 5.1 and later Disable an ... Wed, 20 May 2015 05:21:53 GMT Chris Johns [083e6d6] * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) libnetworking: Send the hostname if set in the network configuration. ... Sat, 11 Jul 2015 19:14:46 GMT Sebastian Huber [f5d4570f] * cpukit/score/include/rtems/score/threadimpl.h (modified) score: Simplify _Thread_Lock_set() Exploit the fact that the ... Sat, 11 Jul 2015 20:04:32 GMT Sebastian Huber [9341773] * cpukit/score/include/rtems/score/threadqimpl.h (modified) * testsuites/sptests/spthreadq01/init.c (modified) score: Typo Thu, 09 Jul 2015 07:59:59 GMT Sebastian Huber [c2596df] * c/src/lib/libbsp/powerpc/shared/startup/bspgetworkarea.c (modified) bsps/powerpc: Fix small-data area issue Update #2369. Wed, 01 Jul 2015 09:05:37 GMT Sebastian Huber [8406d94] * cpukit/libmisc/dummy/default-configuration.c (modified) libmisc: Use SMP application by default on SMP Wed, 08 Jul 2015 08:10:09 GMT Sebastian Huber [b9a7dc3b] * doc/user/conf.t (modified) doc: Clarify SMP configuration defines Wed, 08 Jul 2015 08:04:39 GMT Sebastian Huber [b171982] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) bsps/powerpc: Provide debug and trace symbols Thu, 02 Jul 2015 10:04:50 GMT Sebastian Huber [3e02a47] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Enable branch prediction for T series Thu, 02 Jul 2015 07:14:47 GMT Sebastian Huber [994d7e1] * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t2080rdb.cfg (modified) bsp/qoriq: Use -O2 for T series Thu, 02 Jul 2015 11:11:14 GMT Sebastian Huber [4c68431] * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Add BUCSR register defines Tue, 07 Jul 2015 20:33:51 GMT Jan Sommer [e77f6254] * c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c (modified) RaspberryPi: Use rtems_configuration_get_microseconds_per_tick to set ... Wed, 01 Jul 2015 09:13:26 GMT Sebastian Huber [635ed82] * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) bsp/qoriq: Update due to API changes Fri, 26 Jun 2015 13:51:28 GMT Sebastian Huber [372bee84] * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) score: Simplify _SMP_ticket_lock_Release() Add a SMP lock ... Thu, 25 Jun 2015 04:50:04 GMT Sebastian Huber [f59f2fe9] * cpukit/score/include/rtems/score/freechain.h (modified) * cpukit/score/src/freechain.c (modified) * testsuites/sptests/spfreechain01/init.c (modified) score: Accept NULL pointer in _Freechain_Put() With this a ... Wed, 24 Jun 2015 12:00:08 GMT Sebastian Huber [fdb45d6] * cpukit/posix/include/rtems/posix/keyimpl.h (modified) * cpukit/posix/src/key.c (modified) * cpukit/score/include/rtems/score/freechain.h (modified) * cpukit/score/src/freechain.c (modified) * testsuites/sptests/spfreechain01/init.c (modified) * testsuites/sptests/spfreechain01/spfreechain01.scn (modified) score: Freechain handler API changes Replace the extend function ... Fri, 26 Jun 2015 19:39:16 GMT Sebastian Huber [cb2b8f0] * doc/cpu_supplement/arm.t (modified) doc: Fix interrupt level ARM documentation Fri, 26 Jun 2015 19:28:06 GMT Sebastian Huber [d84408a9] * doc/cpu_supplement/arm.t (modified) doc: Update ARM documentation Fri, 26 Jun 2015 07:40:24 GMT Sebastian Huber [32005a72] * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) bsp/mpc55xxevb: Fix configure script This was the only configure.ac ... Fri, 26 Jun 2015 07:40:03 GMT Sebastian Huber [27f08f5b] * c/src/lib/libbsp/arm/shared/arm-cp15-set-exception-handler.c (modified) bsps/arm: Update due to API changes Thu, 25 Jun 2015 09:24:44 GMT Sebastian Huber [d811dac] * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/src/profilingsmplock.c (modified) * cpukit/score/src/smp.c (modified) * testsuites/sptests/sp37/init.c (modified) score: Hide SMP lock profiling impl if disabled The problem is that ... Thu, 25 Jun 2015 12:22:31 GMT Sebastian Huber [5f31bbe] * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * testsuites/libtests/stackchk/blow.c (modified) libmisc: Simplify Drop the ... Fri, 26 Jun 2015 07:15:36 GMT Sebastian Huber [96316d1b] * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulersmp.h (modified) score: Simplify Drop the ... Thu, 25 Jun 2015 12:11:53 GMT Sebastian Huber [48fed9a] * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/posix/src/pthreadself.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/profilingiterate.c (modified) * cpukit/score/cpu/arm/arm_exc_handler_high.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/src/corespinlockrelease.c (modified) score: Simplify Drop the ... Thu, 25 Jun 2015 12:10:57 GMT Sebastian Huber [270ccc59] * cpukit/score/include/rtems/score/heap.h (modified) score: Fix extern "C" in Thu, 25 Jun 2015 11:48:00 GMT Sebastian Huber [bd67d7d2] * cpukit/posix/include/rtems/posix/psignalimpl.h (modified) * cpukit/rtems/include/rtems/rtems/signalimpl.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) score: Simplify Avoid Thread_Control typedef ... Thu, 25 Jun 2015 11:37:40 GMT Sebastian Huber [0b268b8b] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/src/isrisinprogress.c (added) score: Move default _ISR_Is_in_progress() Thu, 25 Jun 2015 09:28:59 GMT Sebastian Huber [8042107a] * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/src/smp.c (modified) score: Move SMP CPU_USE_DEFERRED_FP_SWITCH check Wed, 24 Jun 2015 11:36:40 GMT Sebastian Huber [a3fc33f] * cpukit/score/src/chain.c (modified) score: Assert proper node size Tue, 23 Jun 2015 12:20:11 GMT Sebastian Huber [df8341a] * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) bsp/gen5200: Simplify interrupt write support Fri, 19 Jun 2015 12:57:44 GMT Sebastian Huber [cdf30f05] * c/src/lib/libbsp/shared/bootcard.c (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/src/intrbody.c (modified) * doc/user/intr.t (modified) * testsuites/libtests/heapwalk/init.c (modified) * testsuites/samples/Makefile.am (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/sp37/init.c (modified) * testsuites/sptests/sp40/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) rtems: Add rtems_interrupt_local_disable|enable() Add ... Fri, 19 Jun 2015 19:38:20 GMT Sebastian Huber [f9090ac] * testsuites/tmtests/tm27/task1.c (modified) tmtests/tm27: Use scheduler lock Fri, 19 Jun 2015 19:17:55 GMT Sebastian Huber [f22af606] * testsuites/sptests/sp37/init.c (modified) sptests/sp37: Fix type and simplify Fri, 19 Jun 2015 12:24:27 GMT Sebastian Huber [1cfe012] * cpukit/libfs/src/nfsclient/src/nfs.c (modified) nfsclient: Use an interrupt lock Mon, 15 Jun 2015 18:45:56 GMT Sebastian Huber [9d838902] * cpukit/score/cpu/arm/armv7m-isr-level-get.c (modified) arm: Implement _CPU_ISR_Get_level() for ARMv7-M Mon, 15 Jun 2015 18:22:31 GMT Joel Sherrill [e0938c2] * doc/user/conf.t (modified) user/conf.t: Fix names for CONFIGURE_UNLIMITED_OBJECTS and ... Wed, 27 May 2015 15:13:58 GMT Joel Sherrill [e6b31b27] * cpukit/configure.ac (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libmisc/cpuuse/cpuusagedata.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/cpuuse/cpuuse.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemonreportstatistics.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/schedulerdefaulttick.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/sptests/sp69/init.c (modified) Remove use ticks for statistics configure option. This was obsolete ...
