# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 01:11:51 Mon, 20 Apr 2009 06:06:51 GMT Ralf Corsepius [3f7a06d2] * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) Experimental changes. Sun, 19 Apr 2009 15:49:20 GMT Joel Sherrill [967eceb] * doc/ChangeLog (modified) * doc/cpu_supplement/.cvsignore (modified) * doc/cpu_supplement/Makefile.am (modified) * doc/cpu_supplement/avr.t (added) * doc/cpu_supplement/cpu_supplement.texi (modified) 2009-04-19 Joel Sherrill * ... Fri, 17 Apr 2009 16:54:47 GMT Ralf Corsepius [77aa429] * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) Upgrade to gdb-6.8.50.20090329. Fri, 17 Apr 2009 16:51:53 GMT Ralf Corsepius [ca8cbc4e] * contrib/crossrpms/patches/gdb-6.8.50.20090329-rtems4.10-20090417.diff (added) Add avr-sim. Fri, 17 Apr 2009 02:23:14 GMT Ralf Corsepius [1bb1f322] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Fri, 17 Apr 2009 02:21:42 GMT Ralf Corsepius [b68a3f1] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) GCC_RPMREL = 2. Fri, 17 Apr 2009 02:09:59 GMT Ralf Corsepius [d41660f9] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) gcc-core-4.4.0-RC-20090414-rtems4.10-20090415.diff Wed, 15 Apr 2009 08:36:13 GMT Ralf Corsepius [89ddf516] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) 2009-04-15 Ralf Corsepius * ... Wed, 15 Apr 2009 08:34:45 GMT Ralf Corsepius [8a024240] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) 2009-04-15 Wei-Tsun Sun * ... Wed, 15 Apr 2009 08:31:09 GMT Ralf Corsepius [1cb06710] * c/src/make/ChangeLog (modified) * c/src/make/leaf.cfg (modified) 2009-04-15 Ralf Corsépius * ... Wed, 15 Apr 2009 03:44:41 GMT Till Straumann [db93c2f] * cpukit/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl_kern.c (modified) 2009-04-14 Till Straumann ... Tue, 14 Apr 2009 17:32:07 GMT Ralf Corsepius [9937a7a] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Tue, 14 Apr 2009 17:31:37 GMT Ralf Corsepius [edbbbf28] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) GCC-4.4.0--RC-20090414. Tue, 14 Apr 2009 17:26:05 GMT Ralf Corsepius [af86b82] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) Preps. for gcc-4.4.0 Tue, 14 Apr 2009 13:44:29 GMT Joel Sherrill [7c4c284c] * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/cpu_asm.S (modified) * cpukit/score/cpu/lm32/irq.c (added) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) 2009-04-14 Michael Walle * cpu.h: ... Tue, 14 Apr 2009 13:41:33 GMT Joel Sherrill [67ae7bb6] * cpukit/libmisc/shell/main_halt.c (modified) Fix attribution. Tue, 14 Apr 2009 10:22:53 GMT Thomas Doerfler [e4bd96ec] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/preinstall.am (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/fileio/init.c (modified) removed obsolete references to login.h Tue, 14 Apr 2009 09:46:58 GMT Thomas Doerfler [07001bab] * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/psim-gdb-bottom (modified) adapt name of assert function for breakpoint Tue, 14 Apr 2009 09:22:34 GMT Thomas Doerfler [7dad664] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/login.h (deleted) *** empty log message *** Tue, 14 Apr 2009 08:50:03 GMT Thomas Doerfler [cbd1e87] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/login_check.c (modified) * cpukit/libmisc/shell/login_prompt.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/telnetd/check_passwd.c (modified) * cpukit/telnetd/telnetd.c (modified) * cpukit/telnetd/telnetd.h (modified) adapt copyright statements Tue, 14 Apr 2009 08:49:12 GMT Thomas Doerfler [1cb5aa14] * cpukit/libnetworking/lib/ftpfs.c (modified) Fixed return codes of open handler. Request reply after data write ... Wed, 08 Apr 2009 11:25:28 GMT Ralf Corsepius [c85f252d] * contrib/repo-conf/yum.repos.d/rtems.repo.in (modified) Fix yet another typo. Wed, 08 Apr 2009 11:10:23 GMT Ralf Corsepius [49e0a59e] * contrib/repo-conf/configure.ac (modified) New filessystem layout. Wed, 08 Apr 2009 05:16:24 GMT Ralf Corsepius [858efb6f] * contrib/repo-conf/configure.ac (modified) * contrib/repo-conf/yum.repos.d/rtems.repo.in (modified) Use versioned mirrorlists. Wed, 08 Apr 2009 01:48:36 GMT Ralf Corsepius [7dff884] * contrib/repo-conf/configure.ac (modified) * contrib/repo-conf/yum.repos.d/rtems.repo.in (modified) Use distro-version independent mirrorlist url. Tue, 07 Apr 2009 17:03:57 GMT Ralf Corsepius [305b9e7] * contrib/repo-conf/configure.ac (modified) * contrib/repo-conf/yum.repos.d/rtems.repo.in (modified) Use mirrorlists. Tue, 07 Apr 2009 08:15:56 GMT Ralf Corsepius [46d35409] * contrib/repo-conf/configure.ac (modified) * contrib/repo-conf/yum.repos.d/rtems.repo.in (modified) Fix stupid typo Tue, 07 Apr 2009 06:56:57 GMT Ralf Corsepius [f30abadc] * contrib/repo-conf/configure.ac (modified) Add fedora-11* Tue, 07 Apr 2009 06:56:44 GMT Ralf Corsepius [92e552e4] * contrib/repo-conf/yum.repos.d/rtems.repo.in (modified) Add ftp://ftp.rtems.eu. Mon, 06 Apr 2009 21:33:48 GMT Joel Sherrill [ca23484] * c/src/lib/libbsp/lm32/ChangeLog (modified) * c/src/lib/libbsp/lm32/shared/start/start.S (modified) 2009-04-06 Michael Walle * ... Mon, 06 Apr 2009 21:23:51 GMT Joel Sherrill [504fadb] * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/cpu_asm.S (modified) 2009-04-06 Michael Walle * ... Mon, 06 Apr 2009 15:25:56 GMT Joel Sherrill [69722ac9] * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/linkcmds (modified) 2009-04-06 Joel Sherrill * ... Fri, 03 Apr 2009 12:55:23 GMT Ralf Corsepius [8732f1b] * testsuites/mptests/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:55:13 GMT Ralf Corsepius [3d54837] * testsuites/itrontests/itronhello/Makefile.am (modified) * testsuites/itrontests/itronmbf01/Makefile.am (modified) * testsuites/itrontests/itronmbox01/Makefile.am (modified) * testsuites/itrontests/itronsem01/Makefile.am (modified) * testsuites/itrontests/itrontask01/Makefile.am (modified) * testsuites/itrontests/itrontask02/Makefile.am (modified) * testsuites/itrontests/itrontask03/Makefile.am (modified) * testsuites/itrontests/itrontask04/Makefile.am (modified) * testsuites/itrontests/itrontime01/Makefile.am (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/monitor02/Makefile.am (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/libtests/tztest/Makefile.am (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psx14/Makefile.am (modified) * testsuites/psxtests/psxbarrier01/Makefile.am (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxchroot01/Makefile.am (modified) * testsuites/psxtests/psxcleanup/Makefile.am (modified) * testsuites/psxtests/psxenosys/Makefile.am (modified) * testsuites/psxtests/psxfatal01/Makefile.am (modified) * testsuites/psxtests/psxfatal02/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxkey01/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxmsgq02/Makefile.am (modified) * testsuites/psxtests/psxrdwrv/Makefile.am (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxrwlock01/Makefile.am (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxsignal01/Makefile.am (modified) * testsuites/psxtests/psxspin01/Makefile.am (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxsysconf/Makefile.am (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtimer01/Makefile.am (modified) * testsuites/psxtests/psxtimer02/Makefile.am (modified) * testsuites/psxtests/psxualarm/Makefile.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_sp/Makefile.am (modified) * testsuites/samples/capture/Makefile.am (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/fileio/Makefile.am (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/iostream/Makefile.am (modified) * testsuites/samples/loopback/Makefile.am (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/nsecs/Makefile.am (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/pppd/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/sp30/Makefile.am (modified) * testsuites/sptests/sp31/Makefile.am (modified) * testsuites/sptests/sp32/Makefile.am (modified) * testsuites/sptests/sp33/Makefile.am (modified) * testsuites/sptests/sp34/Makefile.am (modified) * testsuites/sptests/sp35/Makefile.am (modified) * testsuites/sptests/sp36/Makefile.am (modified) * testsuites/sptests/sp37/Makefile.am (modified) * testsuites/sptests/sp38/Makefile.am (modified) * testsuites/sptests/sp39/Makefile.am (modified) * testsuites/sptests/sp40/Makefile.am (modified) * testsuites/sptests/sp41/Makefile.am (modified) * testsuites/sptests/sp42/Makefile.am (modified) * testsuites/sptests/sp43/Makefile.am (modified) * testsuites/sptests/sp44/Makefile.am (modified) * testsuites/sptests/sp45/Makefile.am (modified) * testsuites/sptests/sp46/Makefile.am (modified) * testsuites/sptests/sp47/Makefile.am (modified) * testsuites/sptests/sp48/Makefile.am (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spfatal01/Makefile.am (modified) * testsuites/sptests/spfatal02/Makefile.am (modified) * testsuites/sptests/spfatal03/Makefile.am (modified) * testsuites/sptests/spfatal04/Makefile.am (modified) * testsuites/sptests/spfatal05/Makefile.am (modified) * testsuites/sptests/spfatal06/Makefile.am (modified) * testsuites/sptests/spfatal07/Makefile.am (modified) * testsuites/sptests/spfatal08/Makefile.am (modified) * testsuites/sptests/spfatal09/Makefile.am (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/sptests/spwatchdog/Makefile.am (modified) * testsuites/tmitrontests/tmitronsem01/Makefile.am (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) Eliminate _exe_/.exe. Fri, 03 Apr 2009 12:53:02 GMT Ralf Corsepius [eae45e23] * testsuites/tmitrontests/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:51:19 GMT Ralf Corsepius [230c879] * testsuites/tmtests/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:48:04 GMT Ralf Corsepius [8e1f626] * testsuites/sptests/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:46:29 GMT Ralf Corsepius [1f52d0e] * testsuites/libtests/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:45:33 GMT Ralf Corsepius [d024b773] * testsuites/itrontests/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:44:48 GMT Ralf Corsepius [b9665ca] * testsuites/psxtests/ChangeLog (modified) 2009-04-03 Ralf Corsépius ... Fri, 03 Apr 2009 12:43:50 GMT Ralf Corsepius [3414f307] * testsuites/samples/ChangeLog (modified) 2009-04-03 Ralf Corsépius * ... Fri, 03 Apr 2009 12:43:40 GMT Ralf Corsepius [dea3a9ca] * testsuites/ChangeLog (modified) * testsuites/aclocal/prog-cc.m4 (modified) 2009-04-03 Ralf Corsépius * ... Thu, 02 Apr 2009 11:49:51 GMT Ralf Corsepius [52f8e7aa] * cpukit/ChangeLog (modified) * cpukit/aclocal/check-rtems-debug.m4 (modified) 2009-04-02 Ralf Corsépius * ... Mon, 30 Mar 2009 17:05:23 GMT Joel Sherrill [9eab99a] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/symlink.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) 2009-03-30 Sebastian Huber ... Mon, 30 Mar 2009 17:05:04 GMT Joel Sherrill [9fb97de] * doc/ChangeLog (modified) * doc/shell/confinit.t (modified) 2009-03-30 Sebastian Huber ... Mon, 30 Mar 2009 14:10:54 GMT Joel Sherrill [7c48db8d] * c/src/lib/libbsp/lm32/lm32_evr/ChangeLog (modified) * c/src/lib/libbsp/lm32/lm32_evr/startup/linkcmds (modified) 2009-03-30 Joel Sherrill * ... Mon, 30 Mar 2009 05:55:09 GMT Ralf Corsepius [241a259d] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Mon, 30 Mar 2009 05:54:34 GMT Ralf Corsepius [68946ac7] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Mon, 30 Mar 2009 05:52:23 GMT Ralf Corsepius [e8b6f1e5] * contrib/crossrpms/gcc/install.add (modified) Also remove @tool_target@/include/bits for c-only targets. Sun, 29 Mar 2009 23:14:58 GMT Joel Sherrill [6dcb3b0] * testsuites/samples/fileio/init.c (modified) Fix Id string typo. Sun, 29 Mar 2009 23:04:19 GMT Joel Sherrill [06ac2e6f] * testsuites/samples/ChangeLog (modified) * testsuites/samples/fileio/init.c (modified) 2009-03-29 Joel Sherrill * ... Sun, 29 Mar 2009 04:49:10 GMT Ralf Corsepius [006eafe] * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) Update to gdb-6.8.50.20090329 Sun, 29 Mar 2009 03:28:22 GMT Ralf Corsepius [49a5e79] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Sun, 29 Mar 2009 03:27:15 GMT Ralf Corsepius [88ad0c9] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Sun, 29 Mar 2009 03:26:22 GMT Ralf Corsepius [0539334d] * contrib/crossrpms/gcc/install.add (modified) rmdir ${RPM_BUILD_ROOT}%{_prefix}/@tool_target@/include/bits Fri, 27 Mar 2009 15:31:52 GMT Joel Sherrill [2649eef] * cpukit/libmisc/shell/login.h (added) * cpukit/libmisc/shell/login_check.c (added) * cpukit/libmisc/shell/login_prompt.c (added) 2009-03-27 Sebastian Huber ... Fri, 27 Mar 2009 13:45:31 GMT Joel Sherrill [8a775c27] * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/libcsupport/src/libio_sockets.c (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libnetworking/rtems/ftpfs.h (modified) * cpukit/preinstall.am (modified) * cpukit/telnetd/check_passwd.c (modified) * cpukit/telnetd/telnetd.c (modified) * cpukit/telnetd/telnetd.h (modified) 2009-03-27 Sebastian Huber ... Thu, 26 Mar 2009 14:11:53 GMT Thomas Doerfler [8916bdc7] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/main_mount_ftp.c (modified) * cpukit/libmisc/shell/shell.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/rtems/ftpfs.h (modified) * libmisc/shell/shell.h: Pointer to oparations table for ... Thu, 26 Mar 2009 11:18:03 GMT Joel Sherrill [d785ce4a] * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/console/console.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/linkcmds (modified) 2009-03-26 Joel Sherrill * ... Wed, 25 Mar 2009 17:56:04 GMT Joel Sherrill [8b074ee6] * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds (modified) 2009-03-25 Joel Sherrill * ... Thu, 19 Mar 2009 10:49:55 GMT Thomas Doerfler [ce7d6e62] * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/hwreg_vals.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/cpuinit.c (modified) * start/start.S, include/hwreg_vals.h, startup/cpuinit.c: ... Thu, 12 Mar 2009 21:13:15 GMT Joel Sherrill [434bc85b] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) 2009-03-12 Santosh G Vattam ... Thu, 12 Mar 2009 15:42:51 GMT Joel Sherrill [a33af586] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-memdrv.c (modified) 2009-03-12 Daniel Hellstrom PR ... Thu, 12 Mar 2009 15:34:29 GMT Joel Sherrill [47261f4] * cpukit/ChangeLog (modified) * cpukit/ftpd/ftpd.h (modified) 2009-03-12 Joel Sherrill * ... Thu, 12 Mar 2009 15:32:58 GMT Joel Sherrill [a1bc6751] * cpukit/ChangeLog (modified) * cpukit/posix/src/mutextranslatereturncode.c (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:33:14 GMT Joel Sherrill [f0a90bb] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_asm.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:33:05 GMT Joel Sherrill [b321b10e] * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:18:32 GMT Joel Sherrill [01d1ae3] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:18:28 GMT Joel Sherrill [1ba9d1bb] * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq_asm.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:18:21 GMT Joel Sherrill [d2c730f8] * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/startup/exception.S (modified) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/exception.S (modified) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/startup/exception.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 14:16:50 GMT Joel Sherrill [0067feb] * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/cpu_asm.S (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/cpu_asm.S (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) 2009-03-12 Joel Sherrill ... Thu, 12 Mar 2009 09:01:09 GMT Ralf Corsepius [fb0a7e9] * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) Regenerate. Thu, 12 Mar 2009 09:00:39 GMT Ralf Corsepius [c6c6b00] * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) gdb-6.8-rtems4.10-20090312.diff Thu, 12 Mar 2009 09:00:21 GMT Ralf Corsepius [d0e1a7f6] * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) Bump GDB_RPMREL. Thu, 12 Mar 2009 08:59:26 GMT Ralf Corsepius [4022445] * contrib/crossrpms/patches/gdb-6.8-rtems4.10-20090312.diff (added) Add psim/configure. Wed, 11 Mar 2009 17:27:01 GMT Ralf Corsepius [d0b8001] * cpukit/libcsupport/src/__assert.c (modified) Conditionally build __assert(). Wed, 11 Mar 2009 17:26:47 GMT Ralf Corsepius [d020f6f] * cpukit/configure.ac (modified) Check for __assert(). Wed, 11 Mar 2009 17:26:27 GMT Ralf Corsepius [947e877] * cpukit/ChangeLog (modified) Fix typo. Wed, 11 Mar 2009 17:25:54 GMT Ralf Corsepius [986f39b3] * cpukit/ChangeLog (modified) 2009-03-11 Ralf Corsépius * ... Wed, 11 Mar 2009 08:48:22 GMT Ralf Corsepius [c033221] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/lm32/rtems-4.10-lm32-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Wed, 11 Mar 2009 08:45:05 GMT Ralf Corsepius [cf3e180] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.17.0-rtems4.10-20090311.diff. Wed, 11 Mar 2009 08:44:37 GMT Ralf Corsepius [2eb41aee] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL. Wed, 11 Mar 2009 08:41:22 GMT Ralf Corsepius [9e3d90d] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090311.diff (added) Address __assert etc. Tue, 10 Mar 2009 17:40:06 GMT Joel Sherrill [96f2d87] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) 2009-03-10 Eric Norum * ... Tue, 10 Mar 2009 10:56:03 GMT Ralf Corsepius [aab8725] * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) Disable sim on mingw32. Tue, 10 Mar 2009 10:55:03 GMT Ralf Corsepius [8e5d175] * contrib/crossrpms/gdb/gdb.add (modified) Disable m32c simulator. Tue, 10 Mar 2009 09:38:36 GMT Ralf Corsepius [f29c64b] * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (modified) Upgrade to gdb-6.8.50 Tue, 10 Mar 2009 07:13:19 GMT Ralf Corsepius [d2730232] * cpukit/ChangeLog (modified) 2009-03-10 Ralf Corsépius * ... Tue, 10 Mar 2009 07:13:08 GMT Ralf Corsepius [a746013] * cpukit/configure.ac (modified) Check for creat(). Tue, 10 Mar 2009 07:12:50 GMT Ralf Corsepius [0ba07a0] * cpukit/libcsupport/src/creat.c (modified) Build conditionally. Mon, 09 Mar 2009 17:00:20 GMT Joel Sherrill [cdb6eae] * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/bsp.h (modified) 2009-03-09 Sebastian Huber ... Mon, 09 Mar 2009 16:53:27 GMT Joel Sherrill [94da794] * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) 2009-03-09 Antoine Lacroix ... Mon, 09 Mar 2009 14:11:23 GMT Joel Sherrill [f855b9e3] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) 2009-03-09 Joel Sherrill ... Mon, 09 Mar 2009 13:57:53 GMT Ralf Corsepius [57224657] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090309.diff (modified) Update. Mon, 09 Mar 2009 12:40:23 GMT Ralf Corsepius [59369291] * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) Bump release. Mon, 09 Mar 2009 12:37:55 GMT Ralf Corsepius [0c614d16] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090309.diff (added) newlib/libc/machine/powerpc/times.c: Remove. Fri, 06 Mar 2009 20:08:20 GMT Joel Sherrill [17175bbd] * cpukit/ChangeLog (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) 2009-03-06 Joel Sherrill * ... Thu, 05 Mar 2009 22:27:19 GMT Eric Norum [ac4dd0b] * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) With Till, Joel and Eric all trying to fix this file things seem to ... Thu, 05 Mar 2009 21:17:55 GMT Till Straumann [05b0c8a] * c/src/lib/libbsp/powerpc/mvme3100/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/start/start.S (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) 2009-03-05 Till Straumann ... Thu, 05 Mar 2009 21:15:17 GMT Till Straumann [0f2852d] * c/src/lib/libbsp/powerpc/mvme3100/ChangeLog (modified) 2009-03-05 Till Straumann ...
