# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/16/24 15:24:12 Wed, 20 Mar 2002 18:24:51 GMT Joel Sherrill [3e0c94f] * doc/started/ChangeLog (modified) * doc/started/buildc.t (modified) 2002-03-20 Chris Johns * PR137 ... Wed, 20 Mar 2002 18:16:07 GMT Joel Sherrill [25d3d4d] * c/src/exec/score/cpu/mips/ChangeLog (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) 2002-03-20 Greg Menke * ... Wed, 20 Mar 2002 17:59:12 GMT Joel Sherrill [eaeb467] * c/src/exec/libcsupport/include/rtems/termiostypes.h (modified) * c/src/lib/ChangeLog (modified) * c/src/lib/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) 2001-03-20 Joel Sherrill * PR143 ... Wed, 20 Mar 2002 14:56:45 GMT Joel Sherrill [fabacfe] * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/sp04/task1.c (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp04/tswitch.c (modified) 2002-03-20 Chris Johns * PR145. ... Wed, 20 Mar 2002 14:33:00 GMT Joel Sherrill [ab09d083] * c/src/libmisc/ChangeLog (modified) * c/src/libmisc/monitor/mon-prmisc.c (modified) * cpukit/libmisc/ChangeLog (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) 2002-03-20 Chris Johns * PR148. ... Wed, 20 Mar 2002 14:24:46 GMT Joel Sherrill [cb8e48e] * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/m68k/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) 2002-03-20 Ralf Corsepius PR ... Wed, 20 Mar 2002 14:23:51 GMT Joel Sherrill [be499b0d] * scripts/autotools/automake-rtems.spec.in (moved) 2002-03-06 Ralf Corsepius * ... Wed, 20 Mar 2002 14:21:42 GMT Joel Sherrill [c31deeb] * c/src/exec/libfs/.cvsignore (modified) * c/src/exec/libfs/ChangeLog (modified) * c/src/exec/libfs/configure.ac (modified) * c/src/exec/libfs/src/dosfs/Makefile.am (modified) * c/src/exec/libfs/src/imfs/Makefile.am (modified) * c/src/libfs/.cvsignore (modified) * c/src/libfs/ChangeLog (modified) * c/src/libfs/configure.ac (modified) * c/src/libfs/src/dosfs/Makefile.am (modified) * c/src/libfs/src/imfs/Makefile.am (modified) * cpukit/libfs/.cvsignore (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libfs/src/dosfs/Makefile.am (modified) * cpukit/libfs/src/imfs/Makefile.am (modified) 2002-03-16 Ralf Corsepius ... Wed, 20 Mar 2002 14:20:44 GMT Joel Sherrill [7ed57bd] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) 2002-03-16 Ralf Corsepius * ... Wed, 20 Mar 2002 14:19:42 GMT Joel Sherrill [658ad222] * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) 2002-03-16 Ralf Corsepius * ... Wed, 20 Mar 2002 14:17:17 GMT Joel Sherrill [353dbe95] * scripts/ChangeLog (modified) * scripts/binutils/binutils.add (modified) * scripts/configure.ac (modified) * scripts/setup.def (modified) 2002-03-06 Ralf Corsepius * ... Wed, 20 Mar 2002 14:12:33 GMT Joel Sherrill [5cf3f41] * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/cpuModel.h (modified) 2002-03-19 Ralf Corsepius * ... Fri, 15 Mar 2002 19:47:36 GMT Joel Sherrill [293c0e30] * c/src/exec/score/cpu/mips/ChangeLog (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) 2002-03-13 Greg Menke * ... Fri, 15 Mar 2002 19:03:52 GMT Joel Sherrill [5ab8aef] * doc/user/ChangeLog (modified) * doc/user/rtmon.t (modified) 2002-03-15 Eric Norum * rtmon.t: ... Fri, 15 Mar 2002 18:57:17 GMT Joel Sherrill [dee576c0] * ChangeLog (modified) * aclocal/env-rtemscpu.m4 (modified) 2002-03-14 Ralf Corsepius * ... Fri, 15 Mar 2002 18:55:09 GMT Joel Sherrill [2de2bec] * c/src/exec/libfs/ChangeLog (modified) * c/src/exec/libfs/src/dosfs/Makefile.am (modified) * c/src/exec/libfs/wrapup/Makefile.am (modified) * c/src/libfs/ChangeLog (modified) * c/src/libfs/src/dosfs/Makefile.am (modified) * c/src/libfs/wrapup/Makefile.am (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/src/dosfs/Makefile.am (modified) * cpukit/libfs/wrapup/Makefile.am (modified) 2002-03-14 Ralf Corsepius ... Fri, 15 Mar 2002 14:32:22 GMT Joel Sherrill [ac97074f] * c/src/exec/sapi/ChangeLog (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/sapi/src/extension.c (modified) * c/src/exec/sapi/src/extensioncreate.c (added) * c/src/exec/sapi/src/extensiondelete.c (added) * c/src/exec/sapi/src/extensionident.c (added) * cpukit/sapi/ChangeLog (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/extensioncreate.c (added) * cpukit/sapi/src/extensiondelete.c (added) * cpukit/sapi/src/extensionident.c (added) 2001-03-15 Joel Sherrill * ... Fri, 15 Mar 2002 13:58:29 GMT Joel Sherrill [082972a] * c/src/wrapup/ChangeLog (modified) * c/src/wrapup/Makefile.am (modified) * c/src/wrapup/configure.ac (modified) 2002-03-15 Ralf Corsepius * ... Fri, 15 Mar 2002 13:56:21 GMT Joel Sherrill [544a600] * c/src/exec/score/cpu/m68k/ChangeLog (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) 2002-03-15 Ralf Corsepius * ... Fri, 08 Mar 2002 17:37:30 GMT Joel Sherrill [5800e142] * ChangeLog (modified) * VERSION (modified) 2002-03-08 Joel Sherrill * VERSION: ... Fri, 08 Mar 2002 17:36:58 GMT Joel Sherrill [db6cc07] * c/src/lib/libbsp/mips/shared/gdbstub/ChangeLog (modified) * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (modified) 2001-03-08 Joel Sherrill * ... Fri, 08 Mar 2002 17:35:39 GMT Joel Sherrill [9d64bc73] * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/start/start.S (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c (modified) 2001-03-08 Joel Sherrill * ... Fri, 08 Mar 2002 16:32:39 GMT Joel Sherrill [34f5067] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/shared/interrupts/installisrentries.c (modified) * c/src/lib/libcpu/mips/shared/interrupts/isr_entries.S (modified) 2002-03-05 Greg Menke * ... Fri, 08 Mar 2002 16:32:07 GMT Joel Sherrill [2f89140] * c/src/lib/libbsp/mips/shared/gdbstub/ChangeLog (modified) * c/src/lib/libbsp/mips/shared/gdbstub/README (modified) * c/src/lib/libbsp/mips/shared/gdbstub/gdb_if.h (modified) * c/src/lib/libbsp/mips/shared/gdbstub/memlimits.h (modified) * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (modified) * c/src/lib/libbsp/mips/shared/gdbstub/rtems-stub-glue.c (modified) * c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c (modified) 2001-03-05 Greg Menke * ... Fri, 08 Mar 2002 16:26:03 GMT Joel Sherrill [ffdc659] * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c (modified) 2002-03-05 Greg Menke * ... Fri, 08 Mar 2002 16:24:48 GMT Joel Sherrill [8264d23] * c/src/exec/score/cpu/mips/ChangeLog (modified) * c/src/exec/score/cpu/mips/cpu.c (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/idtcpu.h (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) 2002-03-05 Greg Menke * ... Wed, 06 Mar 2002 14:37:38 GMT Joel Sherrill [9f9871f] * c/src/exec/score/cpu/m68k/ChangeLog (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) 2002-03-06 Victor V. Vengerov * ... Fri, 01 Mar 2002 17:49:57 GMT Joel Sherrill [b04ee63] * c/src/exec/posix/ChangeLog (modified) * c/src/exec/posix/src/pthreadonce.c (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/src/pthreadonce.c (modified) 2002-03-01 Eric Norum * ... Fri, 01 Mar 2002 17:45:33 GMT Joel Sherrill [49155d9] * c/src/exec/libcsupport/src/gxx_wrappers.c (modified) * c/src/lib/ChangeLog (modified) * c/src/lib/libc/gxx_wrappers.c (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) 2002-03-01 Eric Norum * ... Fri, 01 Mar 2002 17:15:42 GMT Joel Sherrill [41debfd] * ChangeLog (modified) * VERSION (modified) 2002-03-01 Joel Sherrill * VERSION: ... Fri, 01 Mar 2002 16:29:15 GMT Joel Sherrill [7f794ac7] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/mongoosev/vectorisrs/vectorisrs.c (modified) 2002-02-27 Greg Menke * ... Fri, 01 Mar 2002 16:25:00 GMT Joel Sherrill [3a78c2a4] * c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h (modified) 2002-02-27 Greg Menke * ... Fri, 01 Mar 2002 16:24:36 GMT Joel Sherrill [5fa68868] * c/src/lib/libbsp/mips/shared/gdbstub/ChangeLog (modified) 2001-03-01 Joel Sherrill * ... Fri, 01 Mar 2002 16:22:59 GMT Joel Sherrill [cd6bec6] * c/src/lib/libbsp/mips/shared/gdbstub/ChangeLog (modified) * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (modified) 2002-02-27 Greg Menke * ... Fri, 01 Mar 2002 16:21:52 GMT Joel Sherrill [0ea3293] * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/README (modified) * c/src/lib/libbsp/mips/genmongoosev/bsp_specs (modified) * c/src/lib/libbsp/mips/genmongoosev/start/start.S (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/linkcmds (modified) 2002-02-27 Greg Menke * ... Fri, 01 Mar 2002 16:21:12 GMT Joel Sherrill [bd1ecb0] * c/src/exec/score/cpu/mips/ChangeLog (modified) * c/src/exec/score/cpu/mips/cpu.c (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/idtcpu.h (modified) * c/src/exec/score/cpu/mips/iregdef.h (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/iregdef.h (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) 2002-02-27 Greg Menke * ... Fri, 01 Mar 2002 16:17:53 GMT Joel Sherrill [f9d1afc] * c/src/exec/libfs/ChangeLog (modified) * c/src/exec/libfs/src/imfs/.cvsignore (modified) * c/src/libfs/ChangeLog (modified) * c/src/libfs/src/imfs/.cvsignore (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/src/imfs/.cvsignore (modified) 2001-03-01 Joel Sherrill * ... Fri, 01 Mar 2002 16:17:00 GMT Joel Sherrill [a9106e1] * doc/supplements/mips/.cvsignore (added) * doc/supplements/mips/ChangeLog (modified) 2001-03-01 Joel Sherrill * ... Thu, 28 Feb 2002 23:10:39 GMT Joel Sherrill [274fa77] * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/console/console.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.c (added) * c/src/lib/libbsp/m68k/mrm332/console/sci.h (added) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/include/mrm332.h (modified) * c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c (modified) * c/src/lib/libbsp/m68k/mrm332/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/start/start.S (added) * c/src/lib/libbsp/m68k/mrm332/start/start.c (deleted) * c/src/lib/libbsp/m68k/mrm332/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mrm332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mrm332/startup/start_c.c (added) 2002-02-28 Mike Panetta * ... Thu, 28 Feb 2002 20:50:34 GMT Joel Sherrill [098cdaf6] * c/src/wrapup/ChangeLog (modified) * c/src/wrapup/Makefile.am (modified) 2002-02-28 Victor V. Vengerov * DOS ... Thu, 28 Feb 2002 20:44:18 GMT Joel Sherrill [1d42dcbc] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2002-02-28 Victor V. Vengerov * DOS ... Thu, 28 Feb 2002 20:43:50 GMT Joel Sherrill [f36a7bfc] * c/src/exec/libfs/ChangeLog (modified) * c/src/exec/libfs/configure.ac (modified) * c/src/exec/libfs/src/Makefile.am (modified) * c/src/exec/libfs/src/dosfs/.cvsignore (added) * c/src/exec/libfs/src/dosfs/Makefile.am (added) * c/src/exec/libfs/src/dosfs/dosfs.h (added) * c/src/exec/libfs/src/dosfs/fat.c (added) * c/src/exec/libfs/src/dosfs/fat.h (added) * c/src/exec/libfs/src/dosfs/fat_fat_operations.c (added) * c/src/exec/libfs/src/dosfs/fat_fat_operations.h (added) * c/src/exec/libfs/src/dosfs/fat_file.c (added) * c/src/exec/libfs/src/dosfs/fat_file.h (added) * c/src/exec/libfs/src/dosfs/msdos.h (added) * c/src/exec/libfs/src/dosfs/msdos_create.c (added) * c/src/exec/libfs/src/dosfs/msdos_dir.c (added) * c/src/exec/libfs/src/dosfs/msdos_eval.c (added) * c/src/exec/libfs/src/dosfs/msdos_file.c (added) * c/src/exec/libfs/src/dosfs/msdos_free.c (added) * c/src/exec/libfs/src/dosfs/msdos_fsunmount.c (added) * c/src/exec/libfs/src/dosfs/msdos_handlers_dir.c (added) * c/src/exec/libfs/src/dosfs/msdos_handlers_file.c (added) * c/src/exec/libfs/src/dosfs/msdos_init.c (added) * c/src/exec/libfs/src/dosfs/msdos_initsupp.c (added) * c/src/exec/libfs/src/dosfs/msdos_misc.c (added) * c/src/exec/libfs/src/dosfs/msdos_mknod.c (added) * c/src/exec/libfs/src/dosfs/msdos_node_type.c (added) * c/src/exec/libfs/wrapup/Makefile.am (modified) * c/src/libfs/ChangeLog (modified) * c/src/libfs/configure.ac (modified) * c/src/libfs/src/Makefile.am (modified) * c/src/libfs/src/dosfs/.cvsignore (added) * c/src/libfs/src/dosfs/Makefile.am (added) * c/src/libfs/src/dosfs/config.h.in (added) * c/src/libfs/src/dosfs/dosfs.h (added) * c/src/libfs/src/dosfs/fat.c (added) * c/src/libfs/src/dosfs/fat.h (added) * c/src/libfs/src/dosfs/fat_fat_operations.c (added) * c/src/libfs/src/dosfs/fat_fat_operations.h (added) * c/src/libfs/src/dosfs/fat_file.c (added) * c/src/libfs/src/dosfs/fat_file.h (added) * c/src/libfs/src/dosfs/msdos.h (added) * c/src/libfs/src/dosfs/msdos_create.c (added) * c/src/libfs/src/dosfs/msdos_dir.c (added) * c/src/libfs/src/dosfs/msdos_eval.c (added) * c/src/libfs/src/dosfs/msdos_file.c (added) * c/src/libfs/src/dosfs/msdos_free.c (added) * c/src/libfs/src/dosfs/msdos_fsunmount.c (added) * c/src/libfs/src/dosfs/msdos_handlers_dir.c (added) * c/src/libfs/src/dosfs/msdos_handlers_file.c (added) * c/src/libfs/src/dosfs/msdos_init.c (added) * c/src/libfs/src/dosfs/msdos_initsupp.c (added) * c/src/libfs/src/dosfs/msdos_misc.c (added) * c/src/libfs/src/dosfs/msdos_mknod.c (added) * c/src/libfs/src/dosfs/msdos_node_type.c (added) * c/src/libfs/src/dosfs/stamp-h2.in (added) * c/src/libfs/wrapup/Makefile.am (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libfs/src/Makefile.am (modified) * cpukit/libfs/src/dosfs/.cvsignore (added) * cpukit/libfs/src/dosfs/Makefile.am (added) * cpukit/libfs/src/dosfs/dosfs.h (added) * cpukit/libfs/src/dosfs/fat.c (added) * cpukit/libfs/src/dosfs/fat.h (added) * cpukit/libfs/src/dosfs/fat_fat_operations.c (added) * cpukit/libfs/src/dosfs/fat_fat_operations.h (added) * cpukit/libfs/src/dosfs/fat_file.c (added) * cpukit/libfs/src/dosfs/fat_file.h (added) * cpukit/libfs/src/dosfs/msdos.h (added) * cpukit/libfs/src/dosfs/msdos_create.c (added) * cpukit/libfs/src/dosfs/msdos_dir.c (added) * cpukit/libfs/src/dosfs/msdos_eval.c (added) * cpukit/libfs/src/dosfs/msdos_file.c (added) * cpukit/libfs/src/dosfs/msdos_free.c (added) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (added) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (added) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (added) * cpukit/libfs/src/dosfs/msdos_init.c (added) * cpukit/libfs/src/dosfs/msdos_initsupp.c (added) * cpukit/libfs/src/dosfs/msdos_misc.c (added) * cpukit/libfs/src/dosfs/msdos_mknod.c (added) * cpukit/libfs/src/dosfs/msdos_node_type.c (added) * cpukit/libfs/wrapup/Makefile.am (modified) 2002-02-28 Victor V. Vengerov * DOS ... Thu, 28 Feb 2002 20:39:54 GMT Joel Sherrill [e51bd96] * c/src/exec/libblock/.cvsignore (added) * c/src/exec/libblock/ChangeLog (added) * c/src/exec/libblock/Makefile.am (added) * c/src/exec/libblock/README (added) * c/src/exec/libblock/configure.ac (added) * c/src/exec/libblock/include/.cvsignore (added) * c/src/exec/libblock/include/Makefile.am (added) * c/src/exec/libblock/include/rtems/.cvsignore (added) * c/src/exec/libblock/include/rtems/bdbuf.h (added) * c/src/exec/libblock/include/rtems/blkdev.h (added) * c/src/exec/libblock/include/rtems/diskdevs.h (added) * c/src/exec/libblock/include/rtems/ramdisk.h (added) * c/src/exec/libblock/src/.cvsignore (added) * c/src/exec/libblock/src/Makefile.am (added) * c/src/exec/libblock/src/bdbuf.c (added) * c/src/exec/libblock/src/blkdev.c (added) * c/src/exec/libblock/src/diskdevs.c (added) * c/src/exec/libblock/src/ramdisk.c (added) * c/src/libblock/.cvsignore (added) * c/src/libblock/ChangeLog (added) * c/src/libblock/Makefile.am (added) * c/src/libblock/README (added) * c/src/libblock/configure.ac (added) * c/src/libblock/include/.cvsignore (added) * c/src/libblock/include/Makefile.am (added) * c/src/libblock/include/rtems/.cvsignore (added) * c/src/libblock/include/rtems/bdbuf.h (added) * c/src/libblock/include/rtems/blkdev.h (added) * c/src/libblock/include/rtems/diskdevs.h (added) * c/src/libblock/include/rtems/ramdisk.h (added) * c/src/libblock/src/.cvsignore (added) * c/src/libblock/src/Makefile.am (added) * c/src/libblock/src/bdbuf.c (added) * c/src/libblock/src/blkdev.c (added) * c/src/libblock/src/diskdevs.c (added) * c/src/libblock/src/ramdisk.c (added) * cpukit/libblock/.cvsignore (added) * cpukit/libblock/ChangeLog (added) * cpukit/libblock/Makefile.am (added) * cpukit/libblock/README (added) * cpukit/libblock/configure.ac (added) * cpukit/libblock/include/.cvsignore (added) * cpukit/libblock/include/rtems/.cvsignore (added) * cpukit/libblock/include/rtems/bdbuf.h (added) * cpukit/libblock/include/rtems/blkdev.h (added) * cpukit/libblock/include/rtems/diskdevs.h (added) * cpukit/libblock/include/rtems/ramdisk.h (added) * cpukit/libblock/src/.cvsignore (added) * cpukit/libblock/src/Makefile.am (added) * cpukit/libblock/src/bdbuf.c (added) * cpukit/libblock/src/blkdev.c (added) * cpukit/libblock/src/diskdevs.c (added) * cpukit/libblock/src/ramdisk.c (added) 2002-02-28 Joel Sherrill * ... Wed, 27 Feb 2002 22:43:31 GMT Joel Sherrill [cb1e8a46] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/net/if_ppp.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/net/if_ppp.c (modified) * c/src/libnetworking/pppd/auth.c (modified) * c/src/libnetworking/pppd/chat.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/sys-rtems.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/pppd/auth.c (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/pppd/sys-rtems.c (modified) 2002-02-27 Ilya Alexeev * ... Wed, 27 Feb 2002 22:39:18 GMT Joel Sherrill [c52f1c7] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/net/radix.c (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/net/radix.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/net/radix.c (modified) 2002-02-27 Eric Norum * ... Wed, 27 Feb 2002 22:32:15 GMT Joel Sherrill [1bbe2e1] * c/src/lib/libbsp/mips/shared/gdbstub/ChangeLog (modified) * c/src/lib/libbsp/mips/shared/gdbstub/gdb_if.h (modified) * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (modified) * c/src/lib/libbsp/mips/shared/gdbstub/rtems-stub-glue.c (added) * c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c (added) 2001-02-27 Joel Sherrill * ... Wed, 27 Feb 2002 22:18:47 GMT Joel Sherrill [3f1c124] * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/Makefile.am (modified) 2001-02-27 Joel Sherrill * ... Wed, 27 Feb 2002 21:56:41 GMT Joel Sherrill [0694dbab] * scripts/ChangeLog (modified) * scripts/configure.ac (modified) 2001-02-27 Joel Sherrill * ... Wed, 27 Feb 2002 21:45:19 GMT Joel Sherrill [2433bcaf] * c/src/exec/score/cpu/or32/ChangeLog (modified) * c/src/exec/score/cpu/or32/rtems/score/or32.h (modified) * cpukit/score/cpu/or32/ChangeLog (modified) * cpukit/score/cpu/or32/rtems/score/or32.h (modified) 2001-02-27 Joel Sherrill * ... Fri, 15 Feb 2002 14:09:57 GMT Joel Sherrill [7f87dd3] * ChangeLog (modified) * VERSION (modified) 2002-02-15 Joel Sherrill * VERSION: ... Thu, 14 Feb 2002 22:16:25 GMT Joel Sherrill [b40b8808] * doc/ChangeLog (modified) * doc/configure.ac (modified) 2001-02-14 Joel Sherrill * ... Thu, 14 Feb 2002 22:15:39 GMT Joel Sherrill [32636ec7] * doc/supplements/ChangeLog (modified) * doc/supplements/Makefile.am (modified) 2001-02-14 Joel Sherrill * mips: ... Thu, 14 Feb 2002 22:14:59 GMT Joel Sherrill [891d63bd] * doc/supplements/mips/BSP_TIMES (added) * doc/supplements/mips/ChangeLog (added) * doc/supplements/mips/Makefile.am (added) * doc/supplements/mips/bsp.t (added) * doc/supplements/mips/callconv.t (added) * doc/supplements/mips/cpumodel.t (added) * doc/supplements/mips/cputable.t (added) * doc/supplements/mips/fatalerr.t (added) * doc/supplements/mips/intr_NOTIMES.t (added) * doc/supplements/mips/memmodel.t (added) * doc/supplements/mips/mips.texi (added) * doc/supplements/mips/preface.texi (added) * doc/supplements/mips/stamp-vti (added) * doc/supplements/mips/timeBSP.t (added) * doc/supplements/mips/version.texi (added) 2002-02-04 Joel Sherrill * bsp.t, ... Wed, 13 Feb 2002 14:29:42 GMT Joel Sherrill [afb802cd] * c/src/exec/score/cpu/unix/ChangeLog (modified) * c/src/exec/score/cpu/unix/configure.ac (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/configure.ac (modified) 2002-02-13 Ralf Corsepius * ... Fri, 08 Feb 2002 23:27:26 GMT Joel Sherrill [6953e68e] * c/src/lib/libbsp/mips/shared/gdbstub/ChangeLog (modified) * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (modified) 2002-02-08 Joel Sherrill * ... Fri, 08 Feb 2002 23:25:33 GMT Joel Sherrill [63bce63] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/mongoosev/vectorisrs/vectorisrs.c (modified) 2002-02-08 Joel Sherrill * ... Fri, 08 Feb 2002 23:05:35 GMT Joel Sherrill [d88661c] * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c (added) 2002-02-08 Joel Sherrill * ... Fri, 08 Feb 2002 23:04:03 GMT Joel Sherrill [9099a85] * c/src/exec/score/cpu/mips/ChangeLog (modified) * c/src/exec/score/cpu/mips/iregdef.h (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/iregdef.h (modified) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) 2002-02-08 Joel Sherrill * ... Fri, 08 Feb 2002 23:02:33 GMT Joel Sherrill [14c2084] * contrib/solaris/.cvsignore (added) * contrib/solaris/ChangeLog (modified) 2002-02-08 Joel Sherrill * ... Fri, 08 Feb 2002 21:26:00 GMT Joel Sherrill [fc82e71] * c/src/lib/libbsp/mips/shared/gdbstub/ChangeLog (modified) * c/src/lib/libbsp/mips/shared/gdbstub/Makefile (deleted) * c/src/lib/libbsp/mips/shared/gdbstub/README (modified) * c/src/lib/libbsp/mips/shared/gdbstub/gdb_if.h (modified) * c/src/lib/libbsp/mips/shared/gdbstub/ioaddr.h (deleted) * c/src/lib/libbsp/mips/shared/gdbstub/memlimits.h (moved) * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (moved) * c/src/lib/libbsp/mips/shared/gdbstub/r4600.h (deleted) * c/src/lib/libbsp/mips/shared/gdbstub/r46kstub.ld (deleted) * c/src/lib/libbsp/mips/shared/gdbstub/stubinit.S (deleted) 2002-02-08 Joel Sherrill * ... Fri, 08 Feb 2002 20:03:26 GMT Joel Sherrill [fb63984] * c/src/lib/libbsp/mips/shared/gdbstub/ChangeLog (added) * c/src/lib/libbsp/mips/shared/gdbstub/Makefile (added) * c/src/lib/libbsp/mips/shared/gdbstub/README (added) * c/src/lib/libbsp/mips/shared/gdbstub/gdb_if.h (added) * c/src/lib/libbsp/mips/shared/gdbstub/ioaddr.h (added) * c/src/lib/libbsp/mips/shared/gdbstub/limits.h (added) * c/src/lib/libbsp/mips/shared/gdbstub/mips_opcode.h (added) * c/src/lib/libbsp/mips/shared/gdbstub/r4600.h (added) * c/src/lib/libbsp/mips/shared/gdbstub/r46kstub.c (added) * c/src/lib/libbsp/mips/shared/gdbstub/r46kstub.ld (added) * c/src/lib/libbsp/mips/shared/gdbstub/stubinit.S (added) 2002-02-08 Joel Sherrill * Merged ... Wed, 06 Feb 2002 16:41:37 GMT Joel Sherrill [9b11632] * ChangeLog (modified) * aclocal/subdirs.m4 (modified) 2002-02-06 Ralf Corsepius * ... Tue, 05 Feb 2002 21:20:17 GMT Joel Sherrill [5bca94b] * ChangeLog (modified) * VERSION (modified) 2002-02-05 Joel Sherrill * VERSION: ... Tue, 05 Feb 2002 21:08:15 GMT Joel Sherrill [4b3af7a4] * scripts/ChangeLog (modified) * scripts/gccnewlib/base-chill.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-chill.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-objc.add (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkgccnewlibspec.in (modified) 2002-01-29 Ralf Corsepius * ... Tue, 05 Feb 2002 21:06:13 GMT Joel Sherrill [0ab87349] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/shared/interrupts/isr_entries.S (modified) * c/src/lib/libcpu/mips/shared/interrupts/vectorexceptions.c (modified) 2001-02-05 Joel Sherrill * ... Tue, 05 Feb 2002 21:04:39 GMT Joel Sherrill [a37b8f95] * c/src/exec/score/cpu/mips/ChangeLog (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/idtcpu.h (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) 2001-02-05 Joel Sherrill * ... Tue, 05 Feb 2002 20:07:35 GMT Joel Sherrill [7d7e9fb] * c/src/exec/score/cpu/unix/.cvsignore (modified) * c/src/exec/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/.cvsignore (modified) * cpukit/score/cpu/unix/ChangeLog (modified) 2001-02-05 Joel Sherrill * ... Tue, 05 Feb 2002 20:04:25 GMT Joel Sherrill [17e99b3f] * contrib/cygwin/ChangeLog (modified) * contrib/cygwin/i386-cygwin-libs.spec.in (modified) * contrib/cygwin/i386-cygwin-mingw.spec.in (modified) * contrib/cygwin/i386-cygwin-w32api.spec.in (modified) 2001-02-05 Joel Sherrill * ... Tue, 05 Feb 2002 20:02:11 GMT Joel Sherrill [a3049e9] * contrib/solaris/ChangeLog (modified) * contrib/solaris/Makefile.am (added) 2001-02-05 Joel Sherrill * ... Tue, 05 Feb 2002 20:01:45 GMT Joel Sherrill [68babc6] * contrib/solaris/ChangeLog (added) * contrib/solaris/configure.ac (added) * contrib/solaris/setup (added) * contrib/solaris/setup.def (added) * contrib/solaris/sparc-solaris-binutils.spec.in (added) * contrib/solaris/sparc-solaris-gcc.spec.in (added) * contrib/solaris/sparc-solaris-libs.spec.in (added) 2004-02-05 Joel Sherrill * ... Tue, 05 Feb 2002 16:17:37 GMT Joel Sherrill [9535ba4] * c/src/exec/score/cpu/i386/ChangeLog (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/mips/ChangeLog (modified) * c/src/exec/score/cpu/mips/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/mips/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/or16/ChangeLog (modified) * c/src/exec/score/cpu/or16/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/or16/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/or32/ChangeLog (modified) * c/src/exec/score/cpu/or32/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/or32/rtems/score/Makefile.am (deleted) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/or16/ChangeLog (modified) * cpukit/score/cpu/or32/ChangeLog (modified) 2001-02-05 Joel Sherrill * ... Mon, 04 Feb 2002 20:05:30 GMT Joel Sherrill [0bc5329] * c/src/exec/score/cpu/mips/ChangeLog (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) 2001-02-04 Joel Sherrill * ... Mon, 04 Feb 2002 19:49:08 GMT Joel Sherrill [96ecd879] * c/src/exec/score/cpu/arm/ChangeLog (modified) * c/src/exec/score/cpu/arm/configure.ac (modified) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/configure.ac (modified) 2001-02-04 Joel Sherrill * ... Sat, 02 Feb 2002 19:28:13 GMT Joel Sherrill [2276d255] * c/src/lib/libbsp/mips/genmongoosev/include/lr33000.h (added) * c/src/lib/libbsp/mips/genmongoosev/include/lr333x0.h (added) * c/src/lib/libbsp/mips/genmongoosev/include/r3000.h (added) * c/src/lib/libbsp/mips/genmongoosev/start/mg5.h (added) 2001-02-01 Greg Menke * ... Fri, 01 Feb 2002 19:36:57 GMT Joel Sherrill [f562815] * c/src/librdbg/ChangeLog (modified) Fixed ChangeLog again :( Fri, 01 Feb 2002 19:34:33 GMT Joel Sherrill [6966421] * c/src/librdbg/ChangeLog (modified) Fixed ChangeLog Fri, 01 Feb 2002 19:33:15 GMT Joel Sherrill [97f6256] * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/src/i386/any/remdeb.h (modified) * c/src/librdbg/src/i386/any/remdeb_svc.c (modified) * c/src/librdbg/src/i386/any/remdeb_xdr.c (modified) * c/src/librdbg/src/m68k/any/remdeb.h (modified) * c/src/librdbg/src/m68k/any/remdeb_svc.c (modified) * c/src/librdbg/src/m68k/any/remdeb_xdr.c (modified) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb.h (modified) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_svc.c (modified) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c (modified) 2002-02-01 Eric Valette * So ... Fri, 01 Feb 2002 19:32:57 GMT Joel Sherrill [bdb86b4] * c/src/librdbg/ChangeLog (modified) Fixed ChangeLog Fri, 01 Feb 2002 19:32:23 GMT Joel Sherrill [4cecaf6] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/mongoosev/vectorisrs/vectorisrs.c (modified) * c/src/lib/libcpu/mips/shared/interrupts/vectorexceptions.c (modified) 2001-02-01 Greg Menke * ... Fri, 01 Feb 2002 19:30:54 GMT Joel Sherrill [3774c7f] * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/timer/timer.c (modified) 2001-02-01 Greg Menke * ... Fri, 01 Feb 2002 18:58:21 GMT Joel Sherrill [7003847] * c/src/ada/ChangeLog (modified) * c/src/ada/rtems-multiprocessing.adb (added) * c/src/ada/rtems-multiprocessing.ads (added) * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/rtems-multiprocessing.adb (added) * cpukit/ada/rtems-multiprocessing.ads (added) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) 2001-02-01 Joel Sherrill * ... Fri, 01 Feb 2002 18:57:11 GMT Joel Sherrill [569a01f] * c/src/ada/ChangeLog (added) * cpukit/ada/ChangeLog (added) 2001-02-01 Joel Sherrill * ... Fri, 01 Feb 2002 17:00:01 GMT Joel Sherrill [40cf43ea] * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/include/rdbg/i386/rdbg_f.h (modified) * c/src/librdbg/include/rdbg/m68k/rdbg_f.h (modified) * c/src/librdbg/include/rdbg/powerpc/rdbg_f.h (modified) * c/src/librdbg/include/rdbg/servrpc.h (modified) * c/src/librdbg/src/_servtgt.c (modified) * c/src/librdbg/src/awk.svc (modified) * c/src/librdbg/src/excep.c (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/i386/any/remdeb.h (modified) * c/src/librdbg/src/i386/any/remdeb_svc.c (modified) * c/src/librdbg/src/i386/any/remdeb_xdr.c (modified) * c/src/librdbg/src/i386/excep_f.c (modified) * c/src/librdbg/src/i386/rdbg_f.c (modified) * c/src/librdbg/src/m68k/any/Makefile.am (modified) * c/src/librdbg/src/m68k/any/remdeb.h (modified) * c/src/librdbg/src/m68k/any/remdeb_svc.c (modified) * c/src/librdbg/src/m68k/any/remdeb_xdr.c (modified) * c/src/librdbg/src/m68k/excep_f.c (modified) * c/src/librdbg/src/m68k/rdbg_f.c (modified) * c/src/librdbg/src/powerpc/excep_f.c (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb.h (modified) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_svc.c (modified) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c (modified) * c/src/librdbg/src/powerpc/rdbg_f.c (modified) * c/src/librdbg/src/ptrace.c (modified) * c/src/librdbg/src/rdbg.c (modified) * c/src/librdbg/src/remdeb.x (modified) * c/src/librdbg/src/servbkpt.c (modified) * c/src/librdbg/src/servcon.c (modified) * c/src/librdbg/src/servrpc.c (modified) * c/src/librdbg/src/servtgt.c (modified) * c/src/librdbg/src/servtsp.c (modified) * c/src/librdbg/src/servutil.c (modified) * So many patches have been posted recently on the mailing list and ... Fri, 01 Feb 2002 16:51:07 GMT Joel Sherrill [8e3caa5] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/rtemspppd.c (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/pppd/rtemspppd.c (modified) 2001-02-01 Mike Siers * ... Fri, 01 Feb 2002 16:45:18 GMT Joel Sherrill [7de58239] * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/README (modified) * c/src/lib/libbsp/mips/genmongoosev/include/bsp.h (modified) * c/src/lib/libbsp/mips/genmongoosev/start/regs.S (modified) * c/src/lib/libbsp/mips/genmongoosev/start/start.S (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/linkcmds (modified) * c/src/lib/libbsp/mips/genmongoosev/timer/timer.c (modified) 2001-02-01 Greg Menke * ... Fri, 01 Feb 2002 15:15:02 GMT Joel Sherrill [2835b3a5] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/mongoosev/README (modified) * c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h (modified) * c/src/lib/libcpu/mips/mongoosev/vectorisrs/vectorisrs.c (modified) * c/src/lib/libcpu/mips/shared/interrupts/vectorexceptions.c (modified) 2001-02-01 Greg Menke * ... Fri, 01 Feb 2002 15:00:30 GMT Joel Sherrill [e6dec71c] * c/src/exec/score/cpu/mips/ChangeLog (modified) * c/src/exec/score/cpu/mips/cpu.c (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) 2001-02-01 Greg Menke * ... Fri, 01 Feb 2002 14:11:39 GMT Joel Sherrill [6d41a874] * c/src/exec/score/cpu/sh/ChangeLog (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/Makefile.am (modified) 2002-01-31 Ralf Corsepius * ... Fri, 01 Feb 2002 14:09:51 GMT Joel Sherrill [be1feee] * c/src/exec/rtems/ChangeLog (modified) * c/src/exec/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/ChangeLog (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) 2001-01-31 Joel Sherrill * ... Fri, 01 Feb 2002 14:04:45 GMT Joel Sherrill [485ed5cc] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/pppd/rtemsdialer.h (added) * cpukit/libnetworking/ChangeLog (modified) * cpukit/pppd/rtemsdialer.h (added) 2001-01-31 Mike Siers * ... Thu, 31 Jan 2002 21:42:36 GMT Joel Sherrill [5ec6f09] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/ChangeLog (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) 2001-01-31 Mike Siers * Nice Update ... Thu, 31 Jan 2002 21:42:11 GMT Joel Sherrill [0286b9f] * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/configure.ac (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/net/bsd-comp.c (added) * c/src/exec/libnetworking/net/if_ppp.c (added) * c/src/exec/libnetworking/net/if_ppp.h (modified) * c/src/exec/libnetworking/net/if_pppvar.h (modified) * c/src/exec/libnetworking/net/ppp-comp.h (modified) * c/src/exec/libnetworking/net/ppp-deflate.c (added) * c/src/exec/libnetworking/net/ppp.h (added) * c/src/exec/libnetworking/net/ppp_defs.h (modified) * c/src/exec/libnetworking/net/ppp_tty.c (added) * c/src/exec/libnetworking/net/pppcompress.c (moved) * c/src/exec/libnetworking/net/zlib.c (added) * c/src/exec/libnetworking/net/zlib.h (added) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.ac (modified) * c/src/libnetworking/modem/.cvsignore (deleted) * c/src/libnetworking/modem/Makefile.am (deleted) * c/src/libnetworking/modem/ppp.h (deleted) * c/src/libnetworking/modem/ppp_tty.c (deleted) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/net/bsd-comp.c (added) * c/src/libnetworking/net/if_ppp.c (moved) * c/src/libnetworking/net/if_ppp.h (modified) * c/src/libnetworking/net/if_pppvar.h (modified) * c/src/libnetworking/net/ppp-comp.h (modified) * c/src/libnetworking/net/ppp-deflate.c (added) * c/src/libnetworking/net/ppp.h (added) * c/src/libnetworking/net/ppp_defs.h (modified) * c/src/libnetworking/net/ppp_tty.c (added) * c/src/libnetworking/net/pppcompress.c (added) * c/src/libnetworking/net/zlib.c (added) * c/src/libnetworking/net/zlib.h (added) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/README (modified) * c/src/libnetworking/pppd/STATUS (modified) * c/src/libnetworking/pppd/chap.h (modified) * c/src/libnetworking/pppd/chat.c (modified) * c/src/libnetworking/pppd/example/netconfig.h (modified) * c/src/libnetworking/pppd/fsm.c (modified) * c/src/libnetworking/pppd/fsm.h (modified) * c/src/libnetworking/pppd/ipcp.c (modified) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtemsmain.c (modified) * c/src/libnetworking/pppd/rtemspppd.c (modified) * c/src/libnetworking/pppd/rtemspppd.h (modified) * c/src/libnetworking/pppd/sys-rtems.c (modified) * c/src/libnetworking/pppd/upap.h (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/net/bsd-comp.c (added) * cpukit/libnetworking/net/if_ppp.c (added) * cpukit/libnetworking/net/if_ppp.h (modified) * cpukit/libnetworking/net/if_pppvar.h (modified) * cpukit/libnetworking/net/ppp-comp.h (modified) * cpukit/libnetworking/net/ppp-deflate.c (added) * cpukit/libnetworking/net/ppp.h (added) * cpukit/libnetworking/net/ppp_defs.h (modified) * cpukit/libnetworking/net/ppp_tty.c (added) * cpukit/libnetworking/net/pppcompress.c (added) * cpukit/libnetworking/net/zlib.c (added) * cpukit/libnetworking/net/zlib.h (added) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/README (modified) * cpukit/pppd/STATUS (modified) * cpukit/pppd/chap.h (modified) * cpukit/pppd/chat.c (modified) * cpukit/pppd/example/netconfig.h (modified) * cpukit/pppd/fsm.c (modified) * cpukit/pppd/fsm.h (modified) * cpukit/pppd/ipcp.c (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/pppd/rtemsmain.c (modified) * cpukit/pppd/rtemspppd.c (modified) * cpukit/pppd/rtemspppd.h (modified) * cpukit/pppd/sys-rtems.c (modified) * cpukit/pppd/upap.h (modified) 2001-01-31 Mike Siers * Nice Update ... Thu, 31 Jan 2002 21:33:38 GMT Joel Sherrill [d8a78f4f] * c/src/exec/score/cpu/sh/ChangeLog (modified) * c/src/exec/score/cpu/sparc/ChangeLog (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) 2002-01-31 Ralf Corsepius * ... Thu, 31 Jan 2002 21:33:01 GMT Joel Sherrill [1e69b294] * c/src/exec/score/cpu/i386/ChangeLog (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i386/configure.ac (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/configure.ac (modified) 2002-01-31 Ralf Corsepius * ... Wed, 30 Jan 2002 22:46:17 GMT Joel Sherrill [845fac33] * c/src/exec/score/cpu/i386/ChangeLog (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/Makefile.am (modified) 2001-01-30 Joel Sherrill * ... Wed, 30 Jan 2002 22:18:04 GMT Joel Sherrill [1dba8de0] * c/src/exec/score/cpu/sparc/ChangeLog (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) 2001-01-30 Joel Sherrill * ... Wed, 30 Jan 2002 20:05:56 GMT Joel Sherrill [279a6da] * doc/Makefile.am (modified) fixing branch Wed, 30 Jan 2002 20:04:24 GMT Joel Sherrill [033d167] * doc/Makefile.am (modified) fixing branch Wed, 30 Jan 2002 17:48:22 GMT Joel Sherrill [14926c2e] * c/src/exec/score/cpu/a29k/ChangeLog (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/a29k/configure.ac (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/arm/ChangeLog (modified) * c/src/exec/score/cpu/arm/Makefile.am (modified) * c/src/exec/score/cpu/arm/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/arm/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/c4x/ChangeLog (modified) * c/src/exec/score/cpu/c4x/Makefile.am (modified) * c/src/exec/score/cpu/c4x/configure.ac (modified) * c/src/exec/score/cpu/c4x/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/c4x/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/h8300/ChangeLog (modified) * c/src/exec/score/cpu/h8300/Makefile.am (modified) * c/src/exec/score/cpu/h8300/configure.ac (modified) * c/src/exec/score/cpu/h8300/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/h8300/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/i960/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (deleted) * cpukit/score/cpu/a29k/ChangeLog (modified) * cpukit/score/cpu/a29k/Makefile.am (modified) * cpukit/score/cpu/a29k/configure.ac (modified) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/Makefile.am (modified) * cpukit/score/cpu/c4x/configure.ac (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/Makefile.am (modified) * cpukit/score/cpu/h8300/configure.ac (modified) * cpukit/score/cpu/mips64orion/ChangeLog (modified) * cpukit/score/cpu/mips64orion/Makefile.am (modified) * cpukit/score/cpu/mips64orion/configure.ac (modified) 2002-01-29 Ralf Corsepius * ... Wed, 30 Jan 2002 17:45:23 GMT Joel Sherrill [8b25dc6] * c/src/exec/score/cpu/hppa1.1/ChangeLog (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/configure.ac (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i960/ChangeLog (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/configure.ac (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/m68k/ChangeLog (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/m68k/configure.ac (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/ChangeLog (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/configure.ac (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/ChangeLog (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/configure.ac (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/ChangeLog (modified) * cpukit/score/cpu/hppa1.1/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/configure.ac (modified) * cpukit/score/cpu/i960/ChangeLog (modified) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/i960/configure.ac (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/configure.ac (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/configure.ac (modified) 2002-01-29 Ralf Corsepius * ...
