# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/27/24 16:28:29 Fri, 03 Oct 2008 06:18:17 GMT Ralf Corsepius [2abe16dd] * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (added) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (added) New. Fri, 03 Oct 2008 06:17:04 GMT Ralf Corsepius [933e34a6] * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) GCC_RPMREL = 6. Disable cxx, infos. Fri, 03 Oct 2008 06:16:38 GMT Ralf Corsepius [bba70f4] * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) GCC_RPMREL = 6. Fri, 03 Oct 2008 06:15:57 GMT Ralf Corsepius [dc7c0df] * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) gcc-core-4.3.2-rtems4.10-20081003.diff, ... Fri, 03 Oct 2008 06:14:31 GMT Ralf Corsepius [525b90e5] * contrib/crossrpms/patches/newlib-1.16.0-rtems4.10-20081003.diff (added) Add m32r/m32c. Undef __ATTRIBUTE_IMPURE_PTR__ for mips only. Fri, 03 Oct 2008 06:13:17 GMT Ralf Corsepius [f4bacae] * contrib/crossrpms/patches/gcc-core-4.3.2-rtems4.10-20081003.diff (added) Add m32r/m32c. Fri, 03 Oct 2008 03:41:40 GMT Ralf Corsepius [b38ae26b] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gdb.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/mipstx39/rtems-4.10-mipstx39-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gdb.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gdb.spec (modified) Regenerate. Fri, 03 Oct 2008 03:40:27 GMT Ralf Corsepius [df339c2] * contrib/crossrpms/rtems4.10/arm/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gdb-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gdb-sources.add (modified) gdb-6.8-rtems4.10-20081003.diff. Abandon _without_sources. Fri, 03 Oct 2008 03:39:44 GMT Ralf Corsepius [30e604d] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GDB_RPMREL. Fri, 03 Oct 2008 03:35:23 GMT Ralf Corsepius [241aa252] * contrib/crossrpms/patches/gdb-6.8-rtems4.10-20081003.diff (added) Add m32r-*-rtems*, m32c-*-rtems*. Fri, 03 Oct 2008 02:59:19 GMT Ralf Corsepius [3d0a3acb] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-binutils.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-binutils.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (modified) Regenerate. Fri, 03 Oct 2008 02:58:08 GMT Ralf Corsepius [e0c7ecf] * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) Build binutils infos. Fri, 03 Oct 2008 02:55:10 GMT Ralf Corsepius [175b145c] * contrib/crossrpms/patches/binutils-2.18.91-rtems4.10-20081003.diff (added) * contrib/crossrpms/rtems4.10/m32c/.cvsignore (added) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (added) * contrib/crossrpms/rtems4.10/m32c/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/m32c/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/m32c/gdb-sources.add (added) * contrib/crossrpms/rtems4.10/m32r/.cvsignore (added) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (added) * contrib/crossrpms/rtems4.10/m32r/binutils-sources.add (added) * contrib/crossrpms/rtems4.10/m32r/cpukit-sources.add (added) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (added) * contrib/crossrpms/rtems4.10/m32r/gdb-sources.add (added) New. Fri, 03 Oct 2008 02:54:04 GMT Ralf Corsepius [b2fd3b7] * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/rtems4.10/Makefile.am (modified) Add m32r, m32c. Fri, 03 Oct 2008 02:53:26 GMT Ralf Corsepius [24d6e0b] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump BINUTILS_RPMREL Fri, 03 Oct 2008 02:52:48 GMT Ralf Corsepius [7d28f71] * contrib/crossrpms/rtems4.10/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/binutils-sources.add (modified) Add binutils-2.18.91-rtems4.10-20081003.diff Fri, 03 Oct 2008 00:00:38 GMT Joel Sherrill [dbd85b21] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 22:33:44 GMT Joel Sherrill [3fc13ac9] * ChangeLog (modified) * README.configure (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 22:09:00 GMT Joel Sherrill [7f5ea3c6] * doc/ChangeLog (modified) * doc/user/region.t (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:57:48 GMT Joel Sherrill [9cf93da] * make/ChangeLog (modified) * make/custom/m32rsim.cfg (added) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:57:44 GMT Joel Sherrill [1c16744] * c/ChangeLog (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:56:33 GMT Joel Sherrill [8fc9e12] * c/src/lib/libbsp/m32r/ChangeLog (added) * c/src/lib/libbsp/m32r/Makefile.am (added) * c/src/lib/libbsp/m32r/acinclude.m4 (added) * c/src/lib/libbsp/m32r/configure.ac (added) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:56:30 GMT Joel Sherrill [ea1116d] * c/src/lib/libbsp/m32r/m32rsim/.cvsignore (added) * c/src/lib/libbsp/m32r/m32rsim/ChangeLog (added) * c/src/lib/libbsp/m32r/m32rsim/Makefile.am (added) * c/src/lib/libbsp/m32r/m32rsim/bsp_specs (added) * c/src/lib/libbsp/m32r/m32rsim/configure.ac (added) * c/src/lib/libbsp/m32r/m32rsim/console/console-io.c (added) * c/src/lib/libbsp/m32r/m32rsim/console/syscalls.S (added) * c/src/lib/libbsp/m32r/m32rsim/console/trap0.S (added) * c/src/lib/libbsp/m32r/m32rsim/include/.cvsignore (added) * c/src/lib/libbsp/m32r/m32rsim/include/bsp.h (added) * c/src/lib/libbsp/m32r/m32rsim/include/tm27.h (added) * c/src/lib/libbsp/m32r/m32rsim/preinstall.am (added) * c/src/lib/libbsp/m32r/m32rsim/start/start.S (added) * c/src/lib/libbsp/m32r/m32rsim/startup/linkcmds (added) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:56:06 GMT Joel Sherrill [7059d8f] * cpukit/ChangeLog (modified) * cpukit/score/cpu/Makefile.am (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:55:54 GMT Joel Sherrill [463454b] * cpukit/score/cpu/m32r/.cvsignore (added) * cpukit/score/cpu/m32r/ChangeLog (added) * cpukit/score/cpu/m32r/Makefile.am (added) * cpukit/score/cpu/m32r/preinstall.am (added) * cpukit/score/cpu/m32r/rtems/asm.h (added) * cpukit/score/cpu/m32r/rtems/score/cpu.h (added) * cpukit/score/cpu/m32r/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/m32r/rtems/score/m32r.h (added) * cpukit/score/cpu/m32r/rtems/score/types.h (added) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:49:39 GMT Joel Sherrill [339fd66] * testsuites/samples/ChangeLog (modified) * testsuites/samples/fileio/init.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:47:29 GMT Joel Sherrill [640e9128] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:44:50 GMT Joel Sherrill [a2a4027] * ChangeLog (modified) * README.configure (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:41:53 GMT Joel Sherrill [e2e736b] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:39:45 GMT Joel Sherrill [99f0d19b] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/include/tm27.h (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:39:40 GMT Joel Sherrill [9957dbf] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/include/tm27.h (deleted) * c/src/lib/libbsp/arm/csb336/preinstall.am (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/include/tm27.h (deleted) * c/src/lib/libbsp/arm/csb337/preinstall.am (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/include/tm27.h (deleted) * c/src/lib/libbsp/arm/edb7312/preinstall.am (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/Makefile.am (modified) * c/src/lib/libbsp/arm/gba/include/tm27.h (deleted) * c/src/lib/libbsp/arm/gba/preinstall.am (modified) * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/Makefile.am (modified) * c/src/lib/libbsp/arm/gp32/include/tm27.h (deleted) * c/src/lib/libbsp/arm/gp32/preinstall.am (modified) * c/src/lib/libbsp/arm/nds/ChangeLog (modified) * c/src/lib/libbsp/arm/nds/Makefile.am (modified) * c/src/lib/libbsp/arm/nds/include/tm27.h (deleted) * c/src/lib/libbsp/arm/nds/preinstall.am (modified) * c/src/lib/libbsp/arm/rtl22xx/ChangeLog (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/include/tm27.h (deleted) * c/src/lib/libbsp/arm/rtl22xx/preinstall.am (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/include/tm27.h (deleted) * c/src/lib/libbsp/bare/preinstall.am (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/Makefile.am (modified) * c/src/lib/libbsp/h8300/h8sim/include/tm27.h (deleted) * c/src/lib/libbsp/h8300/h8sim/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/tm27.h (deleted) * c/src/lib/libbsp/m68k/gen68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/include/tm27.h (deleted) * c/src/lib/libbsp/m68k/gen68340/preinstall.am (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/tm27.h (deleted) * c/src/lib/libbsp/m68k/idp/preinstall.am (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/include/tm27.h (deleted) * c/src/lib/libbsp/m68k/mrm332/preinstall.am (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/tm27.h (deleted) * c/src/lib/libbsp/m68k/ods68302/preinstall.am (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/Makefile.am (modified) * c/src/lib/libbsp/m68k/sim68000/include/tm27.h (deleted) * c/src/lib/libbsp/m68k/sim68000/preinstall.am (modified) * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/include/tm27.h (deleted) * c/src/lib/libbsp/mips/hurricane/preinstall.am (modified) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/include/tm27.h (deleted) * c/src/lib/libbsp/mips/rbtx4925/preinstall.am (modified) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/include/tm27.h (deleted) * c/src/lib/libbsp/mips/rbtx4938/preinstall.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/include/tm27.h (deleted) * c/src/lib/libbsp/nios2/nios2_iss/preinstall.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/tm27.h (deleted) * c/src/lib/libbsp/no_cpu/no_bsp/preinstall.am (modified) * c/src/lib/libbsp/powerpc/haleakala/ChangeLog (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/include/tm27.h (deleted) * c/src/lib/libbsp/powerpc/haleakala/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/tm27.h (deleted) * c/src/lib/libbsp/powerpc/mbx8xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/tm27.h (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/tm27.h (deleted) * c/src/lib/libbsp/powerpc/tqm8xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex/ChangeLog (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/include/tm27.h (deleted) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/tm27.h (deleted) * c/src/lib/libbsp/sh/gensh1/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/tm27.h (deleted) * c/src/lib/libbsp/sh/gensh2/preinstall.am (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/include/tm27.h (deleted) * c/src/lib/libbsp/sh/shsim/preinstall.am (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:36:13 GMT Joel Sherrill [c7b9ed35] * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/preinstall.am (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:35:57 GMT Joel Sherrill [eb15b89] * c/src/lib/libbsp/m32c/.cvsignore (added) * c/src/lib/libbsp/m32c/ChangeLog (added) * c/src/lib/libbsp/m32c/Makefile.am (added) * c/src/lib/libbsp/m32c/acinclude.m4 (added) * c/src/lib/libbsp/m32c/configure.ac (added) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:35:46 GMT Joel Sherrill [41e58bb] * c/src/lib/libbsp/m32c/m32cbsp/ChangeLog (modified) * c/src/lib/libbsp/m32c/m32cbsp/README (added) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:34:36 GMT Joel Sherrill [0fd07a10] * c/src/lib/libbsp/m32c/m32cbsp/.cvsignore (added) * c/src/lib/libbsp/m32c/m32cbsp/ChangeLog (added) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (added) * c/src/lib/libbsp/m32c/m32cbsp/bsp_specs (added) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (added) * c/src/lib/libbsp/m32c/m32cbsp/console/console-io.c (added) * c/src/lib/libbsp/m32c/m32cbsp/console/syscalls.S (added) * c/src/lib/libbsp/m32c/m32cbsp/include/.cvsignore (added) * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (added) * c/src/lib/libbsp/m32c/m32cbsp/preinstall.am (added) * c/src/lib/libbsp/m32c/m32cbsp/start/start.S (added) * c/src/lib/libbsp/m32c/m32cbsp/startup/bspstart.c (added) * c/src/lib/libbsp/m32c/m32cbsp/startup/crtn.S (added) * c/src/lib/libbsp/m32c/m32cbsp/startup/linkcmds (added) * c/src/lib/libbsp/m32c/m32cbsp/timer/timer.c (added) * c/src/lib/libbsp/m32c/m32cbsp/tools/.cvsignore (added) * c/src/lib/libbsp/m32c/m32cbsp/tools/Makefile.am (added) * c/src/lib/libbsp/m32c/m32cbsp/tools/configure.ac (added) * c/src/lib/libbsp/m32c/m32cbsp/tools/runtest.in (added) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:34:05 GMT Joel Sherrill [d92d42e] * make/ChangeLog (modified) * make/custom/m32csim.cfg (added) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:33:09 GMT Joel Sherrill [0c34b176] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/score/cpu/Makefile.am (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:32:44 GMT Joel Sherrill [ed6e947] * cpukit/score/cpu/m32c/.cvsignore (added) * cpukit/score/cpu/m32c/ChangeLog (added) * cpukit/score/cpu/m32c/Makefile.am (added) * cpukit/score/cpu/m32c/context_init.c (added) * cpukit/score/cpu/m32c/context_switch.S (added) * cpukit/score/cpu/m32c/cpu.c (added) * cpukit/score/cpu/m32c/cpu_asm.c (added) * cpukit/score/cpu/m32c/preinstall.am (added) * cpukit/score/cpu/m32c/rtems/asm.h (added) * cpukit/score/cpu/m32c/rtems/score/cpu.h (added) * cpukit/score/cpu/m32c/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/m32c/rtems/score/m32c.h (added) * cpukit/score/cpu/m32c/rtems/score/types.h (added) * cpukit/score/cpu/m32c/varvects.S (added) * cpukit/score/cpu/m32c/varvects.h (added) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:31:54 GMT Joel Sherrill [9a79f1b4] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/utils-cp.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:31:08 GMT Joel Sherrill [b28b126] * testsuites/samples/ChangeLog (modified) * testsuites/samples/unlimited/system.h (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:03:44 GMT Joel Sherrill [12a0a525] * cpukit/ChangeLog (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:01:58 GMT Joel Sherrill [1d7a927] * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tmck/task1.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 21:00:37 GMT Joel Sherrill [2cc1b43] * cpukit/ChangeLog (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 20:57:28 GMT Joel Sherrill [82478ffc] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp09/screen01.c (modified) * testsuites/sptests/sp09/screen12.c (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp25/task1.c (modified) * testsuites/sptests/sp28/init.c (modified) * testsuites/sptests/sp39/init.c (modified) * testsuites/sptests/sp41/init.c (modified) * testsuites/sptests/spfatal01/testcase.h (modified) * testsuites/sptests/spfatal08/testcase.h (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 20:56:55 GMT Joel Sherrill [4c09f4b] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/malloc_statistics_helpers.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionresizesegment.c (modified) * cpukit/rtems/src/workspace.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/protectedheap.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapallocatealigned.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/pheapgetblocksize.c (modified) * cpukit/score/src/wkspace.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 20:20:17 GMT Joel Sherrill [3d0e458] * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/types.h (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 20:16:16 GMT Joel Sherrill [b079fe33] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/main_cp.c (modified) * cpukit/libmisc/shell/main_ls.c (modified) * cpukit/libmisc/shell/main_mv.c (modified) * cpukit/libmisc/shell/main_netstats.c (modified) * cpukit/libmisc/shell/main_rm.c (modified) * cpukit/libmisc/shell/shell_script.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 19:48:51 GMT Joel Sherrill [5d209d6] * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspclean.c (deleted) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 19:46:12 GMT Joel Sherrill [beff4c6] * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/console/init68360.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 19:13:05 GMT Joel Sherrill [61814f9] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bspgetworkarea.c (modified) * c/src/lib/libbsp/shared/bsppretaskinghook.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 19:12:59 GMT Joel Sherrill [12838f75] * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/arm/nds/ChangeLog (modified) * c/src/lib/libbsp/arm/nds/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/startup/bspgetworkarea.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 19:12:54 GMT Joel Sherrill [c7932ded] * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/shared/bspgetworkarea.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 19:12:40 GMT Joel Sherrill [b4fa916b] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspgetworkarea.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 17:27:07 GMT Joel Sherrill [de49de6] * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/console/config.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/console.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/console.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/debugio.c (deleted) * c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.h (modified) * c/src/lib/libbsp/powerpc/ep1a/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ep1a/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/ep1a/irq/openpic_xxx_irq.c (modified) * c/src/lib/libbsp/powerpc/ep1a/pci/no_host_bridge.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 16:39:15 GMT Joel Sherrill [4e4dc3a] * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/av5282/preinstall.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/ChangeLog (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/genmcf548x/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf52235/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/mcf52235/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/mcf5235/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5329/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/mcf5329/preinstall.am (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/uC5282/preinstall.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/include/coverhd.h (deleted) * c/src/lib/libbsp/nios2/nios2_iss/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/include/coverhd.h (deleted) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/coverhd.h (deleted) * c/src/lib/libbsp/powerpc/gen83xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/coverhd.h (deleted) * c/src/lib/libbsp/powerpc/mpc8260ads/preinstall.am (modified) * c/src/lib/libbsp/powerpc/ss555/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/include/coverhd.h (deleted) * c/src/lib/libbsp/powerpc/ss555/preinstall.am (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/include/coverhd.h (deleted) * c/src/lib/libbsp/sh/gensh4/preinstall.am (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 16:38:19 GMT Joel Sherrill [76428fd] * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/coverhd.h (deleted) * c/src/lib/libbsp/sparc/erc32/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/coverhd.h (deleted) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/include/coverhd.h (deleted) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 14:53:31 GMT Joel Sherrill [b5f6cf3] * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/preinstall.am (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/preinstall.am (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/preinstall.am (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 14:26:17 GMT Joel Sherrill [1004c3c1] * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.h (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.h (modified) * c/src/lib/libbsp/powerpc/score603e/console/console.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolebsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/console/tbl85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/gen2.h (modified) * c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c (modified) * c/src/lib/libbsp/powerpc/score603e/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/score603e/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/score603e/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/score603e/pci/no_host_bridge.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/vmeintr.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 13:51:27 GMT Joel Sherrill [1666253f] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) Revert. Thu, 02 Oct 2008 13:50:44 GMT Joel Sherrill [92b338c0] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) 2008-10-02 Joel Sherrill * ... Thu, 02 Oct 2008 10:28:32 GMT Ralf Corsepius [7cb9e438] * make/ChangeLog (modified) 2008-10-02 Ralf Corsepius * ... Thu, 02 Oct 2008 10:28:19 GMT Ralf Corsepius [20a53db] * make/custom/virtex.cfg (modified) Remove -Dvirtex. Thu, 02 Oct 2008 08:13:18 GMT Ralf Corsepius [10de6e19] * make/ChangeLog (modified) 2008-10-02 Ralf Corsepius * ... Thu, 02 Oct 2008 08:13:09 GMT Ralf Corsepius [8f9acb2] * make/custom/pghplus.cfg (modified) * make/custom/tqm8xx.cfg (modified) * make/custom/tqm8xx_stk8xx.cfg (modified) Remove RTEMS_TQM_MODEL. Thu, 02 Oct 2008 08:10:13 GMT Ralf Corsepius [2aff96b6] * make/ChangeLog (modified) 2008-10-02 Ralf Corsepius * ... Thu, 02 Oct 2008 08:09:55 GMT Ralf Corsepius [913f3e9] * make/custom/mpc5566evb.cfg (modified) * make/custom/mpc55xx.cfg (modified) * make/custom/pgh360.cfg (modified) Remove RTEMS_BOARD_MODEL. Thu, 02 Oct 2008 08:08:28 GMT Ralf Corsepius [9723df84] * make/ChangeLog (modified) 2008-10-02 Ralf Corsepius * ... Thu, 02 Oct 2008 07:44:27 GMT Ralf Corsepius [adc6349] * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) 2008-10-02 Ralf Corsépius * ... Thu, 02 Oct 2008 07:15:27 GMT Ralf Corsepius [f8bf656] * make/ChangeLog (modified) 2008-10-02 Ralf Corsepius * ... Thu, 02 Oct 2008 07:15:17 GMT Ralf Corsepius [618b18f] * make/custom/m5484FireEngine.cfg (modified) Remove RTEMS_BOARD_MODEL. Remove RTEMS_54XX_DERIVATE (Unused). Thu, 02 Oct 2008 07:14:58 GMT Ralf Corsepius [e90653d7] * make/custom/genmcf548x.cfg (modified) Remove RTEMS_BOARD_MODEL. Thu, 02 Oct 2008 07:07:38 GMT Ralf Corsepius [b465b0f] * c/src/lib/libbsp/m68k/genmcf548x/ChangeLog (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) 2008-10-02 Ralf Corsépius * ... Thu, 02 Oct 2008 04:39:53 GMT Ralf Corsepius [c43e350a] * make/ChangeLog (modified) 2008-10-02 Ralf Corsepius * ... Thu, 02 Oct 2008 04:38:37 GMT Ralf Corsepius [461e18c7] * make/custom/brs5l.cfg (modified) * make/custom/gen5200.cfg (modified) * make/custom/icecube.cfg (modified) * make/custom/pm520_cr825.cfg (modified) * make/custom/pm520_ze30.cfg (modified) Remove RTEMS_BOARD_MODEL. Thu, 02 Oct 2008 04:11:37 GMT Ralf Corsepius [8d3d0455] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) 2008-10-02 Ralf Corsépius * ... Thu, 02 Oct 2008 04:10:08 GMT Ralf Corsepius [3760a5d] * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) 2008-10-02 Ralf Corsépius * ... Thu, 02 Oct 2008 04:01:28 GMT Ralf Corsepius [62df126] * make/ChangeLog (modified) 2008-10-02 Ralf Corsepius * ... Thu, 02 Oct 2008 04:01:00 GMT Ralf Corsepius [77a1304d] * make/custom/gen83xx.cfg (modified) * make/custom/hsc_cm01.cfg (modified) * make/custom/mpc8313erdb.cfg (modified) * make/custom/mpc8349eamds.cfg (modified) Remove RTEMS_BOARD_MODEL, RTEMS_83XX_DERIVATE. Thu, 02 Oct 2008 03:57:09 GMT Ralf Corsepius [d5d8f10] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) 2008-10-02 Ralf Corsépius * ... Wed, 01 Oct 2008 20:02:34 GMT Joel Sherrill [caf0e53] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/main_mdump.c (modified) * cpukit/libmisc/shell/main_mwdump.c (modified) 2008-10-01 Gene Smith PR ... Wed, 01 Oct 2008 17:17:52 GMT Joel Sherrill [27a0015f] * ChangeLog (modified) * VERSION (modified) 2008-10-01 Joel Sherrill * ... Wed, 01 Oct 2008 17:17:22 GMT Joel Sherrill [943b7d9] * contrib/repo-conf/ChangeLog (modified) * contrib/repo-conf/aclocal/version.m4 (modified) 2008-10-01 Joel Sherrill * ... Wed, 01 Oct 2008 17:16:37 GMT Joel Sherrill [7d2aaa6f] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psx01/psx01.scn (modified) 2008-10-01 Joel Sherrill * ... Wed, 01 Oct 2008 17:16:33 GMT Joel Sherrill [df518cb] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp43/sp43.scn (modified) 2008-10-01 Joel Sherrill * ... Wed, 01 Oct 2008 17:16:29 GMT Joel Sherrill [b7c75137] * doc/ChangeLog (modified) * doc/shell/preface.texi (modified) 2008-10-01 Joel Sherrill * ... Wed, 01 Oct 2008 17:03:45 GMT Joel Sherrill [8000c52] * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/genpvec.c (modified) 2008-10-01 Joel Sherrill * ... Wed, 01 Oct 2008 16:09:23 GMT Joel Sherrill [d59e9b9] * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.h (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.h (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolebsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/console/tbl85c30.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/coverhd.h (deleted) * c/src/lib/libbsp/powerpc/score603e/include/gen2.h (modified) * c/src/lib/libbsp/powerpc/score603e/preinstall.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/vmeintr.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/score603e/tod/tod.c (modified) * c/src/lib/libbsp/powerpc/score603e/vme/VMEConfig.h (modified) 2008-10-01 Joel Sherrill * ... Wed, 01 Oct 2008 13:19:51 GMT Joel Sherrill [049b893] * make/ChangeLog (modified) * make/custom/erc32.cfg (modified) 2008-10-01 Joel Sherrill * ... Wed, 01 Oct 2008 11:23:07 GMT Ralf Corsepius [b1866be8] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc83xx/include/mpc83xx.h (modified) 2008-10-01 Ralf Corsépius * ... Wed, 01 Oct 2008 09:35:40 GMT Ralf Corsepius [68f39d58] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h (modified) 2008-10-01 Ralf Corsépius * ... Wed, 01 Oct 2008 09:33:09 GMT Ralf Corsepius [c5a7f1a9] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) 2008-10-01 Ralf Corsépius * ... Wed, 01 Oct 2008 09:31:46 GMT Ralf Corsepius [ce1dfbe] * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) 2008-10-01 Ralf Corsépius * ... Wed, 01 Oct 2008 06:42:55 GMT Ralf Corsepius [75e10892] * make/ChangeLog (modified) 2008-10-01 Ralf Corsepius * ... Wed, 01 Oct 2008 06:42:48 GMT Ralf Corsepius [f59f6489] * make/custom/brs5l.cfg (modified) * make/custom/gen5200.cfg (modified) * make/custom/gen83xx.cfg (modified) * make/custom/genmcf548x.cfg (modified) * make/custom/hsc_cm01.cfg (modified) * make/custom/icecube.cfg (modified) * make/custom/m5484FireEngine.cfg (modified) * make/custom/mpc5566evb.cfg (modified) * make/custom/mpc55xx.cfg (modified) * make/custom/mpc8313erdb.cfg (modified) * make/custom/mpc8349eamds.cfg (modified) * make/custom/pgh360.cfg (modified) * make/custom/pghplus.cfg (modified) * make/custom/pm520_cr825.cfg (modified) * make/custom/pm520_ze30.cfg (modified) * make/custom/tqm8xx.cfg (modified) * make/custom/tqm8xx_stk8xx.cfg (modified) Back out parts of yesterdays changes. Wed, 01 Oct 2008 01:20:46 GMT Ralf Corsepius [edc1ce3c] * make/ChangeLog (modified) * make/custom/gen83xx.cfg (modified) * make/custom/lpc2478.cfg (modified) 2008-10-01 Ralf Corsepius * ... Wed, 01 Oct 2008 01:12:15 GMT Ralf Corsepius [08ecdaa] * ChangeLog (modified) * aclocal/check-bsps.m4 (modified) 2008-10-01 Ralf Corsépius ... Tue, 30 Sep 2008 23:16:21 GMT Joel Sherrill [909adce] * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/include/irq-config.h (added) * c/src/lib/libbsp/powerpc/score603e/startup/spurious.c (deleted) 2008-09-30 Jennifer Averett ... Tue, 30 Sep 2008 23:15:10 GMT Joel Sherrill [bbb7cca6] * make/ChangeLog (modified) * make/custom/score603e.cfg (modified) 2008-09-30 Jennifer Averett ... Tue, 30 Sep 2008 23:13:54 GMT Joel Sherrill [3d50574] * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c (modified) * c/src/lib/libbsp/powerpc/score603e/console/console.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c (modified) * c/src/lib/libbsp/powerpc/score603e/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/score603e/preinstall.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/vmeintr.c (modified) 2008-09-30 Jennifer Averett ... Tue, 30 Sep 2008 17:17:30 GMT Ralf Corsepius [06b5d63] * make/ChangeLog (modified) 2008-09-30 Ralf Corsepius * ...
