# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/12/24 12:00:47 Thu, 20 Feb 2020 21:45:54 GMT Simon Glass [23fe4d7b] * cpukit/dtc/libfdt/fdt_rw.c (modified) libfdt: Add support for disabling rollback handling Allow enabling ... Thu, 20 Feb 2020 21:45:53 GMT Simon Glass [52d4c65] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_ro.c (modified) libfdt: Add support for disabling sanity checks Allow enabling ... Thu, 20 Feb 2020 21:45:52 GMT Simon Glass [e9ebc6ab] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/fdt_rw.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: Add support for disabling dtb checks Support ... Thu, 20 Feb 2020 21:45:51 GMT Simon Glass [b44c574d] * cpukit/dtc/libfdt/libfdt_internal.h (modified) Add a way to control the level of checks in the code Add a new ... Thu, 20 Feb 2020 21:45:50 GMT Simon Glass [461c7354] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/include/libfdt.h (modified) libfdt: De-inline fdt_header_size() There does not seem to be a ... Fri, 08 Nov 2019 14:42:53 GMT David Gibson [7217a4f] * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Correct prototype for fdt_ro_probe_() This function returns ... Tue, 10 Sep 2019 10:48:24 GMT Luc Michel [94d5b6ea] * cpukit/include/libfdt.h (modified) libfdt.h: add explicit cast from void* to uint8_t* in fdt(32|64)_st ... Sun, 28 Jul 2019 06:25:51 GMT David Gibson [39f64e08] * cpukit/dtc/libfdt/fdt_addresses.c (modified) libfdt: Allow #size-cells of 0 c12b2b0c20eb "libfdt: ... Fri, 05 Jul 2019 03:42:40 GMT David Gibson [1a5c324] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/libfdt_internal.h (modified) libfdt: Tweak data handling to satisfy Coverity In libfdt we often ... Thu, 20 Jun 2019 21:19:39 GMT Rob Herring [0b83b822] * cpukit/dtc/libfdt/fdt.c (modified) * cpukit/dtc/libfdt/fdt_addresses.c (modified) * cpukit/dtc/libfdt/fdt_empty_tree.c (modified) * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/dtc/libfdt/fdt_rw.c (modified) * cpukit/dtc/libfdt/fdt_strerror.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) * cpukit/dtc/libfdt/fdt_wip.c (modified) * cpukit/dtc/libfdt/libfdt_internal.h (modified) * cpukit/include/fdt.h (modified) * cpukit/include/libfdt.h (modified) * cpukit/include/libfdt_env.h (modified) libfdt: Replace GPL/BSD boilerplate/reference with SPDX tags ... Thu, 09 May 2019 09:41:22 GMT Nicholas Piggin [b00040b2] * cpukit/dtc/libfdt/fdt_sw.c (modified) * cpukit/include/libfdt.h (modified) libfdt: Add FDT_CREATE_FLAG_NO_NAME_DEDUP flag that trades size for ... Thu, 09 May 2019 09:41:21 GMT Nicholas Piggin [adb403b9] * cpukit/dtc/libfdt/fdt_strerror.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) * cpukit/include/libfdt.h (modified) libfdt: Introduce fdt_create_with_flags() There is a need to be ... Thu, 09 May 2019 09:41:20 GMT Nicholas Piggin [4902d42] * cpukit/dtc/libfdt/fdt_rw.c (modified) * cpukit/dtc/libfdt/fdt_sw.c (modified) libfdt: Ensure fdt_add_property frees allocated name string on ... Fri, 29 Mar 2019 02:59:04 GMT David Gibson [3d4c1c89] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/include/libfdt.h (modified) libfdt: Make fdt_get_max_phandle() an inline It's now a trivial ... Tue, 26 Mar 2019 15:33:02 GMT Thierry Reding [5a45775] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/include/libfdt.h (modified) libfdt: Add phandle generation helper The new ... Tue, 26 Mar 2019 15:33:00 GMT Thierry Reding [6505fe0e] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/include/libfdt.h (modified) * cpukit/include/libfdt_env.h (modified) libfdt: Add new maximum phandle lookup function The ... Wed, 27 Mar 2019 06:15:52 GMT AKASHI Takahiro [d5203fe] * cpukit/dtc/libfdt/fdt_addresses.c (modified) * cpukit/include/libfdt.h (modified) libfdt: add fdt_append_addrrange() This function will append an ... Mon, 25 Mar 2019 03:51:27 GMT David Gibson [3d75d7c] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/include/libfdt.h (modified) * cpukit/include/libfdt_env.h (modified) Revert "libfdt: Add phandle generation helper" This reverts commit ... Wed, 20 Mar 2019 15:10:03 GMT Thierry Reding [a0dea644] * cpukit/dtc/libfdt/fdt_ro.c (modified) * cpukit/include/libfdt.h (modified) * cpukit/include/libfdt_env.h (modified) libfdt: Add phandle generation helper The new ... Fri, 21 Dec 2018 16:32:23 GMT Geert Uytterhoeven [18a7759] * cpukit/include/libfdt.h (modified) libfdt: Fix FDT_ERR_NOTFOUND typos in documentation The actual ... Fri, 21 Dec 2018 13:01:32 GMT Geert Uytterhoeven [ab3efcc] * cpukit/include/libfdt.h (modified) libfdt: Fix fdt_getprop_by_offset() parameter name in documentation ... Mon, 19 Nov 2018 05:36:15 GMT David Gibson [bef6dfc5] * cpukit/include/libfdt.h (modified) libfdt: Don't use memcpy to handle unaligned reads on ARM 6dcb8ba4 ... Fri, 02 Nov 2018 01:46:22 GMT John Clarke [8bd3915] * cpukit/dtc/libfdt/fdt_addresses.c (modified) * cpukit/include/libfdt.h (modified) libfdt: return correct value if #size-cells property is not present ... Wed, 26 Feb 2020 09:02:37 GMT Sebastian Huber [fcb11510] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/userextimpl.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/userextaddset.c (modified) * testsuites/sptests/spextensions01/init.c (modified) score: Fix context switch extensions (SMP) In uniprocessor and SMP ... Tue, 25 Feb 2020 13:07:35 GMT Jan Sommer [2220a53] * bsps/i386/pc386/clock/ckinit.c (modified) bsp/pc386: Fix interrupt enable to make debug option work again Thu, 27 Feb 2020 07:21:17 GMT Sebastian Huber [61e2d73f] * bsps/powerpc/mpc55xxevb/config/mpc5643l_dpu-testsuite.tcfg (modified) * bsps/powerpc/mpc55xxevb/config/mpc5643l_evb-testsuite.tcfg (modified) bsp/mpc5643l_*: Exclude some tests These tests do not fit into the ... Tue, 25 Feb 2020 12:47:59 GMT Sebastian Huber [c36fae22] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/iodrivers.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/iodefault.c (added) * testsuites/sptests/spsysinit01/init.c (modified) config: Initialize IO drivers on demand Tue, 25 Feb 2020 13:43:52 GMT Sebastian Huber [01c97e64] * cpukit/score/src/threadinitialize.c (modified) score: Fix label defined but not used warning Update #3835. Tue, 25 Feb 2020 12:49:45 GMT Sebastian Huber [470dfa1f] * cpukit/include/rtems/confdefs/iodrivers.h (modified) config: Resurrect NULL_DRIVER_TABLE_ENTRY This define may be used ... Fri, 21 Feb 2020 07:08:57 GMT Sebastian Huber [a78495ed] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/wkspace.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 14:26:40 GMT Sebastian Huber [1fb1cf1] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/objectsposix.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 14:13:16 GMT Sebastian Huber [35e58c45] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/wkspacesupport.h (added) config: Add Remove all comments ... Thu, 20 Feb 2020 12:59:30 GMT Sebastian Huber [d20209b] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/objectsclassic.h (added) config: Add Remove all comments ... Thu, 20 Feb 2020 13:24:46 GMT Sebastian Huber [f5a2fd86] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/threads.h (added) * cpukit/posix/src/pthread.c (modified) config: Add Remove all comments and ... Thu, 20 Feb 2020 12:33:07 GMT Sebastian Huber [40db051] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/unlimited.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 12:22:54 GMT Sebastian Huber [7b6596f5] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/iodrivers.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 12:10:52 GMT Sebastian Huber [fe84ab5] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/console.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 11:58:13 GMT Sebastian Huber [8314933] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/initthread.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 11:02:39 GMT Sebastian Huber [b15d1cb] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/inittask.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 10:39:30 GMT Sebastian Huber [8f3419b] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/extensions.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 10:39:05 GMT Sebastian Huber [fb0caca] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/newlib.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 06:55:18 GMT Sebastian Huber [32561f5] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/clock.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 06:45:57 GMT Sebastian Huber [1d35bf2a] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/mpci.h (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 06:33:59 GMT Sebastian Huber [03aff2c] * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/malloc.h (added) * cpukit/libcsupport/src/mallocdirtydefault.c (added) * cpukit/libcsupport/src/mallocextenddefault.c (added) config: Add Remove all comments and ... Thu, 20 Feb 2020 06:22:48 GMT Sebastian Huber [691b614] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/bdbuf.h (added) config: Add Remove all comments and ... Wed, 19 Feb 2020 13:14:46 GMT Sebastian Huber [591e9736] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/scheduler.h (added) config: Add Remove all comments and ... Sat, 15 Feb 2020 17:57:57 GMT Sebastian Huber [1608221] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/libio.h (added) config: Add Remove all comments and ... Sat, 15 Feb 2020 13:00:08 GMT Sebastian Huber [0f8e139e] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/percpu.h (added) config: Add Remove comments and ... Sat, 15 Feb 2020 13:16:58 GMT Sebastian Huber [f45d0b2f] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/bsp.h (added) config: Add Remove all comments and ... Fri, 14 Feb 2020 16:20:36 GMT Sebastian Huber [55a7316] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/libpci.h (added) config: Add Derive copyright and license ... Fri, 14 Feb 2020 15:50:18 GMT Sebastian Huber [cadd8d1] * cpukit/header-dirs.am (modified) * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/confdefs/obsolete.h (added) config: Add Unify handling of obsolete ... Fri, 21 Feb 2020 06:34:50 GMT Sebastian Huber [0561cc1] * cpukit/include/rtems/confdefs.h (modified) config: Remove _Configure_Max_Objects() Use ... Fri, 21 Feb 2020 06:28:13 GMT Sebastian Huber [cfe68385] * cpukit/include/rtems/confdefs.h (modified) config: Improve _Configure_From_workspace() Commit ... Sat, 15 Feb 2020 11:07:28 GMT Sebastian Huber [c7f748a] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/smp.h (modified) * testsuites/ada/support/initimpl.h (modified) * testsuites/libtests/block08/system.h (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/termios05/init.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp37/system.h (modified) * testsuites/sptests/sp65/sp65impl.h (modified) * testsuites/sptests/spcbssched01/system.h (modified) * testsuites/sptests/spcbssched02/system.h (modified) * testsuites/sptests/spcbssched03/system.h (modified) * testsuites/sptests/spedfsched01/system.h (modified) * testsuites/sptests/spedfsched02/system.h (modified) * testsuites/sptests/spedfsched03/system.h (modified) * testsuites/sptests/spfatal29/init.c (modified) * testsuites/sptests/spfifo03/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) * testsuites/sptests/spintrcritical06/spintrcritical06impl.h (modified) * testsuites/sptests/spintrcritical15/init.c (modified) * testsuites/sptests/spmrsp01/init.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm24/system.h (modified) config: Remove CONFIGURE_DISABLE_SMP_CONFIGURATION The ... Sat, 15 Feb 2020 11:03:39 GMT Sebastian Huber [ca82a603] * cpukit/rtems/src/timerserver.c (modified) rtems: Change timer server task mode setting Use the non-preempt ... Sat, 15 Feb 2020 10:52:00 GMT Sebastian Huber [e50e42b8] * cpukit/include/rtems/scheduler.h (modified) * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: _Scheduler_Is_non_preempt_mode_supported() If the ... Sat, 15 Feb 2020 10:23:08 GMT Sebastian Huber [5b8d80d7] * cpukit/include/rtems/confdefs.h (modified) * testsuites/sptests/sp66/init.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) config: CONFIGURE_INIT_TASK_INITIAL_MODES Determine the default for ... Sat, 15 Feb 2020 10:14:32 GMT Sebastian Huber [51614bd5] * bsps/shared/dev/clock/clockimpl.h (modified) bsps/clock: Use _SMP_Get_processor_maximum() Use a specific test to ... Sat, 15 Feb 2020 10:09:16 GMT Sebastian Huber [1ada3e55] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Add _SMP_Need_inter_processor_interrupts() Test for the ... Fri, 14 Feb 2020 18:09:56 GMT Sebastian Huber [ba74ebde] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/include/rtems/userenv.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/sapi/src/sysinitverbose.c (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) * testsuites/fstests/imfs_support/fs_support.c (modified) * testsuites/fstests/jffs2_support/fs_support.c (modified) * testsuites/fstests/mdosfs_support/fs_support.c (modified) * testsuites/fstests/mimfs_support/fs_support.c (modified) * testsuites/fstests/mrfs_support/fs_support.c (modified) * testsuites/libtests/ftp01/init.c (modified) * testsuites/psxtests/psxchroot01/main.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal27/init.c (deleted) * testsuites/sptests/spfatal27/spfatal27.doc (deleted) * testsuites/sptests/spfatal27/spfatal27.scn (deleted) * testsuites/sptests/spprivenv01/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) libio: Add POSIX user environment pointer to TCB The IO library ... Fri, 14 Feb 2020 13:04:21 GMT Sebastian Huber [ba46b936] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/smp.h (modified) * cpukit/libmisc/monitor/mon-mpci.c (modified) config: Add _SMP_Is_enabled Move the is SMP enabled configuration ... Fri, 14 Feb 2020 12:57:20 GMT Sebastian Huber [567455b6] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/smp.h (modified) config: Add _SMP_Processor_configure_maximum Move the processor ... Fri, 14 Feb 2020 12:48:18 GMT Sebastian Huber [ad85c00] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/wkspacedata.h (modified) * cpukit/score/src/wkspaceisunifieddefault.c (added) config: Add _Workspace_Is_unified Move the unified workspace ... Fri, 14 Feb 2020 12:43:58 GMT Sebastian Huber [ba7b2df7] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/wkspacedata.h (added) config: Add _Workspace_Size Move the workspace size configuration ... Fri, 14 Feb 2020 12:36:30 GMT Sebastian Huber [5180762c] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/threadidledata.h (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadidledefault.c (added) config: Add _Thread_Idle_body Move the idle thread body ... Fri, 14 Feb 2020 12:26:17 GMT Sebastian Huber [c70d112] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/threadidledata.h (added) * cpukit/score/src/threadcreateidle.c (modified) config: Add _Thread_Idle_stack_size Move the idle thread stack size ... Fri, 14 Feb 2020 11:58:21 GMT Sebastian Huber [308a2e0f] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/watchdogticks.h (modified) * cpukit/score/src/watchdogtimeslicedefault.c (added) config: Add _Watchdog_Ticks_per_timeslice Move the ticks per ... Thu, 13 Feb 2020 16:16:15 GMT Sebastian Huber [b8648bd] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/watchdogticks.h (modified) config: Add _Watchdog_Microseconds_per_tick Move the microseconds ... Fri, 14 Feb 2020 10:20:42 GMT Sebastian Huber [3b4795b4] * cpukit/headers.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/posix/config.h (deleted) * cpukit/include/rtems/posix/pthread.h (modified) * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * testsuites/psxtests/psxfatal01/init.c (modified) * testsuites/psxtests/psxfatal02/init.c (modified) config: Remove CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE The ... Fri, 14 Feb 2020 08:48:41 GMT Sebastian Huber [9bdb6aa3] * cpukit/include/rtems/rtems/config.h (modified) * cpukit/rtems/src/getapiconfig.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) config: Bring back RTEMS 4.11 configuration table This improves API ... Fri, 14 Feb 2020 08:34:03 GMT Sebastian Huber [a9bc7a5] * cpukit/rtems/src/taskinitusers.c (modified) rtems: Simplify _RTEMS_tasks_Initialize_user_task() Due to the ... Fri, 14 Feb 2020 08:31:44 GMT Sebastian Huber [9520ec3] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/tasksdata.h (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/rtems/src/getapiconfig.c (added) * cpukit/rtems/src/taskinitdefault.c (added) * cpukit/rtems/src/taskinitusers.c (modified) config: Simplify initialization task config With the removal of the ... Fri, 14 Feb 2020 07:40:41 GMT Sebastian Huber [6b0873f] * cpukit/include/rtems/confdefs.h (modified) * testsuites/sptests/sp54/init.c (modified) * testsuites/sptests/spfatal01/init.c (modified) * testsuites/sptests/spfatal02/init.c (modified) * testsuites/sptests/spfatal04/init.c (modified) * testsuites/sptests/spfatal05/init.c (modified) * testsuites/sptests/spfatal06/init.c (modified) config: Remove CONFIGURE_HAS_OWN_INIT_TASK_TABLE The ... Tue, 25 Feb 2020 06:14:13 GMT Sebastian Huber [77ee827] * testsuites/sptests/spcbssched03/tasks_periodic.c (modified) sptests/spcbssched03: Include missing header file Update #3875. Tue, 25 Feb 2020 06:13:55 GMT Sebastian Huber [5d1d348] * testsuites/libtests/stackchk/init.c (modified) libtests/stackchk: Include missing header file Update #3875. Fri, 21 Feb 2020 14:12:13 GMT Sebastian Huber [f6fcfea1] * testsuites/mptests/mp14/exit.c (modified) mptests/mp14: Include missing header file Include for ... Fri, 21 Feb 2020 13:21:33 GMT Sebastian Huber [e58ecb84] * bsps/arm/shared/irq/irq-gic.c (modified) bsps/arm: Initialize priorities of PPIs At least on GICv1 the ... Fri, 21 Feb 2020 04:30:32 GMT Amaan Cheval [486829b2] * MAINTAINERS (modified) Add Amaan to MAINTAINERS Wed, 12 Feb 2020 14:09:39 GMT Dennis Pfau [7006f08] * bsps/shared/grlib/uart/apbuart_cons.c (modified) drvmgr: Fix determination of prefix in grlib uart driver ... Fri, 14 Feb 2020 03:16:17 GMT Chris Johns [3f7ebdd] * testsuites/libtests/newlib01/init.c (modified) testsuite/newlib: Check newlib does not touch an assigned std FILE ... Fri, 14 Feb 2020 16:24:45 GMT Sebastian Huber [58864627] * cpukit/include/rtems/confdefs.h (modified) config: Remove unused declaration and defines Update #3875. Fri, 14 Feb 2020 10:23:12 GMT Sebastian Huber [dbb7ac6f] * cpukit/headers.am (modified) * cpukit/include/rtems/posix/ptimer.h (deleted) * cpukit/posix/src/timersettime.c (modified) posix: Remove This file contained duplicate ... Thu, 13 Feb 2020 16:15:33 GMT Sebastian Huber [c621c11b] * cpukit/libmisc/monitor/mon-config.c (modified) monitor: Use proper API for all config constants Thu, 13 Feb 2020 15:56:20 GMT Sebastian Huber [e85f168] * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) config: Remove unused configuration constant Thu, 13 Feb 2020 15:15:30 GMT Sebastian Huber [f613778] * cpukit/include/rtems/config.h (modified) Remove rtems_configuration_get_posix_api_configuration() The ... Thu, 13 Feb 2020 12:39:43 GMT Sebastian Huber [f1baeb0] * bootstrap (modified) bootstrap: Add special case for clean command The ... Thu, 13 Feb 2020 10:37:02 GMT Sebastian Huber [2807d556] * cpukit/score/src/wkspace.c (modified) score: Clean up wkspace.c Remove DEBUG_WORKSPACE support. There ... Thu, 13 Feb 2020 10:34:34 GMT Sebastian Huber [88c40ef8] * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/sptests/spwkspace/init.c (modified) score: Remove unused _Workspace_Allocate_aligned() Sun, 09 Feb 2020 19:21:44 GMT G S Niteesh [f53473f] * bsps/arm/raspberrypi/console/console-config.c (modified) * bsps/arm/raspberrypi/include/bsp/usart.h (modified) bsp/raspberrypi: Mini UART driver This patch adds driver for Mini ... Sun, 09 Feb 2020 19:21:43 GMT G S Niteesh [5857e83c] * bsps/include/libchip/ns16550.h (modified) * bsps/shared/dev/serial/ns16550-context.c (modified) libchip/ns16550: Allow user calculate baud divisor This patch will ... Fri, 14 Feb 2020 14:51:01 GMT Sebastian Huber [b89b442] * testsuites/smptests/smpschededf02/init.c (modified) smpschededf02: Improve readability Fri, 14 Feb 2020 09:05:21 GMT Sebastian Huber [33d89af] * testsuites/smptests/smpfatal09/init.c (modified) smpfatal09: Fix test case Update #3838. Thu, 13 Feb 2020 00:15:56 GMT Joel Sherrill [3f732f0] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/objectimpl.h (modified) objectdata.h, objectimpl.h: Change structure member from free to ... Tue, 10 Dec 2019 10:13:18 GMT Sebastian Huber [d252e20a] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/threadallocateunlimited.c (added) * cpukit/score/src/threadinitialize.c (modified) * testsuites/samples/unlimited/test1.c (modified) score: Simplify _Thread_Initialize() Allocate new thread queue ... Fri, 03 Jan 2020 06:19:47 GMT Sebastian Huber [fc32904] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectallocateunlimited.c (modified) score: Add _Objects_Allocate_with_extend() Update #3835. Tue, 10 Dec 2019 10:26:20 GMT Sebastian Huber [dd9e501] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectallocateunlimited.c (modified) score: Add _Objects_Activate_unlimited() Update #3835. Tue, 10 Dec 2019 10:09:32 GMT Sebastian Huber [8a43adb] * cpukit/include/rtems/score/freechain.h (modified) * cpukit/score/src/freechain.c (modified) score: Add _Freechain_Extend() Update #3835. Tue, 10 Dec 2019 09:59:02 GMT Sebastian Huber [4eab96b] * cpukit/include/rtems/score/freechain.h (modified) * testsuites/sptests/spfreechain01/init.c (modified) score: Add _Freechain_Pop() Update #3835. Tue, 10 Dec 2019 09:58:42 GMT Sebastian Huber [8ff1af1] * cpukit/include/rtems/score/freechain.h (modified) * testsuites/sptests/spfreechain01/init.c (modified) score: Add _Freechain_Is_empty() Update #3835. Tue, 10 Dec 2019 09:46:52 GMT Sebastian Huber [36e59b2] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectextendinformation.c (modified) score: _Objects_Extend_information() Return block index in ...
