# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 12:36:21 Mon, 12 Sep 2005 13:32:42 GMT Joel Sherrill [22f1f670] * make/ChangeLog (modified) * make/custom/mbx860_001b.cfg (added) * make/custom/mbx860_1b.cfg (added) 2005-09-12 Thomas Doerfler ... Fri, 09 Sep 2005 11:45:24 GMT Ralf Corsepius [e05f675f] * doc/FAQ/endoftime.texi (deleted) Remove Thu, 08 Sep 2005 12:47:42 GMT Ralf Corsepius [f7d7d63] * doc/FAQ/endoftime.texi (added) Experimental commit. Mon, 05 Sep 2005 14:26:02 GMT Ralf Corsepius [9dc154f] * scripts/ChangeLog (modified) * scripts/binutils/target-binutils.add (modified) 2005-09-05 Ralf Corsepius * ... Sat, 03 Sep 2005 06:48:15 GMT Ralf Corsepius [ac61c5c2] * doc/ChangeLog (modified) 2005-09-03 Ralf Corsepius * ... Sat, 03 Sep 2005 06:47:43 GMT Ralf Corsepius [43fe862a] * doc/FAQ/basic.texi (deleted) * doc/FAQ/bsp.texi (deleted) * doc/FAQ/build45.texi (deleted) * doc/FAQ/concepts.texi (deleted) * doc/FAQ/debug.texi (deleted) * doc/FAQ/endoftime.texi (deleted) * doc/FAQ/freesw.texi (deleted) * doc/FAQ/hwdebugaids.texi (deleted) * doc/FAQ/projects.texi (deleted) * doc/FAQ/tools.texi (deleted) Remove (Generated files) Sat, 03 Sep 2005 04:32:52 GMT Ralf Corsepius [1d18ba4e] * scripts/ChangeLog (modified) 2005-09-03 Ralf Corsepius * ... Sat, 03 Sep 2005 04:32:32 GMT Ralf Corsepius [eb9604d3] * scripts/binutils/binutils.add (modified) Remove dlltool, nlmconv, windres man pages. Sat, 03 Sep 2005 04:30:28 GMT Ralf Corsepius [885bf584] * scripts/acinclude.m4 (added) New. Fri, 02 Sep 2005 20:29:22 GMT Joel Sherrill [50189556] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/console.c (modified) 2005-09-02 Joel Sherrill PR ... Fri, 02 Sep 2005 19:32:27 GMT Joel Sherrill [1da36189] * cpukit/ChangeLog (modified) Remove dupe entries. Fri, 02 Sep 2005 16:25:51 GMT Joel Sherrill [da8c85d] * doc/ChangeLog (modified) * doc/FAQ/basic.texi (modified) * doc/FAQ/build45.texi (modified) * doc/FAQ/stamp-vti (modified) * doc/FAQ/version.texi (modified) * doc/bsp_howto/rtc.t (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/user/Makefile.am (modified) * doc/user/region.t (modified) 2005-09-02 Joel Sherrill * ... Fri, 02 Sep 2005 15:10:57 GMT Joel Sherrill [ed73c256] * ChangeLog (modified) 2005-09-02 Joel Sherrill * VERSION: ... Fri, 02 Sep 2005 15:10:56 GMT Joel Sherrill [1a8f056c] * ChangeLog (modified) * c/src/ChangeLog (modified) * cpukit/ChangeLog (modified) * testsuites/ChangeLog (modified) 2005-09-02 Joel Sherrill * ... Fri, 02 Sep 2005 15:05:31 GMT Joel Sherrill [2729dae1] * ChangeLog (modified) 2005-09-02 Joel Sherrill * VERSION: ... Fri, 02 Sep 2005 15:05:30 GMT Joel Sherrill [e698e68] * ChangeLog (modified) * c/src/ChangeLog (modified) * cpukit/ChangeLog (modified) * testsuites/ChangeLog (modified) 2005-09-02 Joel Sherrill * ... Fri, 02 Sep 2005 14:50:06 GMT Joel Sherrill [c4338c8] * ChangeLog (modified) * VERSION (modified) 2005-09-02 Joel Sherrill * VERSION: ... Fri, 02 Sep 2005 14:50:05 GMT Joel Sherrill [95f9447] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2005-09-02 Joel Sherrill * ... Fri, 02 Sep 2005 14:49:13 GMT Joel Sherrill [8a6570d0] * c/src/lib/libbsp/sparc/shared/ChangeLog (modified) * c/src/lib/libbsp/sparc/shared/start.S (modified) 2005-09-02 Joel Sherrill PR ... Fri, 02 Sep 2005 09:00:49 GMT Ralf Corsepius [54fd16be] * scripts/ChangeLog (modified) * scripts/common/common.add.in (modified) 2005-09-02 Ralf Corsepius * ... Fri, 02 Sep 2005 07:30:20 GMT Ralf Corsepius [28d6b865] * scripts/ChangeLog (modified) 2005-09-02 Ralf Corsepius * ... Fri, 02 Sep 2005 07:29:55 GMT Ralf Corsepius [9175815] * scripts/Makefile.am (modified) * scripts/autotools/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/cpukit/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) * scripts/rtems/Makefile.am (modified) Rename *.spec into @rpmprefix@*.spec. Fri, 02 Sep 2005 07:27:40 GMT Ralf Corsepius [7b15ca88] * scripts/ChangeLog (modified) 2005-09-02 Ralf Corsepius * ... Fri, 02 Sep 2005 07:25:15 GMT Ralf Corsepius [cb228cf] * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/common/common.add.in (modified) * scripts/cpukit/rtems-cpukit.add (modified) * scripts/cpukit/target-cpukit.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/base-gfortran.add (modified) * scripts/gccnewlib/base-gnat.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-c++.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-gfortran.add (modified) * scripts/gccnewlib/target-gnat.add (modified) * scripts/gccnewlib/target-libc.add (modified) * scripts/gccnewlib/target-objc.add (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) * scripts/rtems/rtems-source.add (modified) * scripts/rtemsdoc/rtemsdoc.add (modified) * scripts/rtemsdoc/supplement.add.in (modified) * scripts/rtemsdoc/templ.add.in (modified) Replace %{rpmprefix} with @rpmprefix@ Fri, 02 Sep 2005 07:24:01 GMT Ralf Corsepius [51af42d] * scripts/ChangeLog (modified) Fix typo Fri, 02 Sep 2005 07:22:33 GMT Ralf Corsepius [ab7fe1f] * scripts/ChangeLog (modified) 2005-09-02 Ralf Corsepius * ... Fri, 02 Sep 2005 07:22:13 GMT Ralf Corsepius [f12782e] * scripts/cpukit/mkspec.in (modified) * scripts/rtems/mkspec.in (modified) Propagate @rpmprefi@. Fri, 02 Sep 2005 05:09:03 GMT Ralf Corsepius [fe7541a2] * scripts/ChangeLog (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-libc.add (modified) 2005-09-02 Ralf Corsepius * ... Thu, 01 Sep 2005 16:32:06 GMT Joel Sherrill [2bbe78a2] * cpukit/ChangeLog (modified) * cpukit/score/inline/rtems/score/coremsg.inl (modified) * cpukit/score/macros/rtems/score/coremsg.inl (modified) * cpukit/score/src/coremsginsert.c (modified) 2005-09-01 Joel Sherrill PR ... Thu, 01 Sep 2005 16:15:33 GMT Joel Sherrill [a98ea87] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/psx04.scn (modified) 2005-09-01 Joel Sherrill PR ... Thu, 01 Sep 2005 14:44:04 GMT Joel Sherrill [84b6c050] * cpukit/ChangeLog (modified) * cpukit/posix/src/semtimedwait.c (modified) 2005-09-01 Joel Sherrill PR ... Thu, 01 Sep 2005 13:49:29 GMT Joel Sherrill [04ae040] * c/src/lib/libcpu/powerpc/ChangeLog (modified) Added PR number to existing ChangeLog entry. Thu, 01 Sep 2005 13:28:00 GMT Joel Sherrill [8c51e48c] * cpukit/ChangeLog (modified) * cpukit/sapi/include/confdefs.h (modified) 2005-09-01 Nuno Costa PR 804 ... Thu, 01 Sep 2005 08:18:30 GMT Ralf Corsepius [2dc0cb2e] * scripts/ChangeLog (modified) * scripts/gdb/gdb.add (modified) 2005-09-01 Ralf Corsepius * ... Thu, 01 Sep 2005 08:17:17 GMT Ralf Corsepius [765046a] * scripts/ChangeLog (modified) 2005-09-01 Ralf Corsepius * ... Thu, 01 Sep 2005 08:16:57 GMT Ralf Corsepius [4372b60] * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/target-c++.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-gfortran.add (modified) * scripts/gccnewlib/target-gnat.add (modified) * scripts/gccnewlib/target-objc.add (modified) Switch to using %gcc_version. Thu, 01 Sep 2005 07:20:39 GMT Ralf Corsepius [7e9b763] * scripts/ChangeLog (modified) 2005-09-01 Ralf Corsepius * ... Thu, 01 Sep 2005 07:20:24 GMT Ralf Corsepius [7bca3702] * scripts/binutils/target-binutils.add (modified) Further adaptations to /usr. Thu, 01 Sep 2005 07:20:06 GMT Ralf Corsepius [3e297d0] * scripts/binutils/binutils.add (modified) Remove Packager:. Thu, 01 Sep 2005 07:17:26 GMT Ralf Corsepius [d135e875] * scripts/ChangeLog (modified) Add missing entry Thu, 01 Sep 2005 06:45:13 GMT Ralf Corsepius [3ead5b65] * scripts/ChangeLog (modified) 2005-09-01 Ralf Corsepius * ... Thu, 01 Sep 2005 06:44:56 GMT Ralf Corsepius [f6c4e41] * scripts/gccnewlib/target-c++.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-gfortran.add (modified) * scripts/gccnewlib/target-gnat.add (modified) * scripts/gccnewlib/target-objc.add (modified) Fix directory ownerships. Wed, 31 Aug 2005 18:51:30 GMT Joel Sherrill [1131dfe] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) 2005-08-23 Karel Gardas > * ... Wed, 31 Aug 2005 15:29:48 GMT Ralf Corsepius [54791b8] * scripts/gccnewlib/target-libc.add (added) 2005-08-31 Ralf Corsepius * ... Wed, 31 Aug 2005 04:29:39 GMT Ralf Corsepius [182c101e] * cpukit/ChangeLog (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/src/ttyname.c (modified) * cpukit/libcsupport/src/ttyname_r.c (deleted) 2005-08-31 Ralf Corsepius PR ... Tue, 30 Aug 2005 14:59:44 GMT Ralf Corsepius [4266e821] * scripts/gccnewlib/target-gfortran.add (modified) Remove dep on *-base-gfortran for prefix=/usr. Tue, 30 Aug 2005 14:56:43 GMT Ralf Corsepius [e2dd61b] * scripts/gccnewlib/target-c++.add (modified) Remove dep on *-base-gcc for prefix=/usr. Tue, 30 Aug 2005 12:27:19 GMT Ralf Corsepius [40c60eee] * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/target-objc.add (modified) Cosmetics. Tue, 30 Aug 2005 12:22:01 GMT Ralf Corsepius [e057182] * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-gnat.add (modified) * scripts/gccnewlib/target-objc.add (modified) Cosmetics. Tue, 30 Aug 2005 12:14:46 GMT Ralf Corsepius [5cef6bd2] * scripts/ChangeLog (modified) * scripts/gccnewlib/target-gcc.add (modified) 2005-08-30 Ralf Corsepius * ... Tue, 30 Aug 2005 12:13:52 GMT Ralf Corsepius [e15fbe5] * scripts/ChangeLog (modified) 2005-08-30 Ralf Corsepius * ... Tue, 30 Aug 2005 08:18:47 GMT Ralf Corsepius [1bc4b77] * scripts/gccnewlib/target-gcc.add (modified) cleanups Tue, 30 Aug 2005 05:52:30 GMT Ralf Corsepius [eff4dd75] * scripts/gccnewlib/gccnewlib.add (modified) Minor cleanups. Tue, 30 Aug 2005 05:45:21 GMT Ralf Corsepius [8b544468] * scripts/ChangeLog (modified) 2005-08-30 Ralf Corsepius * ... Tue, 30 Aug 2005 05:44:56 GMT Ralf Corsepius [86c81eec] * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-c++.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-gfortran.add (modified) * scripts/gccnewlib/target-gnat.add (modified) * scripts/gccnewlib/target-objc.add (modified) Use gccnewlib_version. Cosmetics. Minor cleanups. Tue, 30 Aug 2005 04:52:57 GMT Ralf Corsepius [3a12683d] * scripts/ChangeLog (modified) 2005-08-30 Ralf Corsepius * ... Tue, 30 Aug 2005 04:52:02 GMT Ralf Corsepius [de44905] * scripts/gccnewlib/base-gcc.add (modified) Remove _includedir Tue, 30 Aug 2005 04:45:35 GMT Ralf Corsepius [9ed43a2] * scripts/ChangeLog (modified) 2005-08-30 Ralf Corsepius * ... Tue, 30 Aug 2005 04:45:10 GMT Ralf Corsepius [d128ca29] * scripts/gccnewlib/target-c++.add (modified) * scripts/gccnewlib/target-gnat.add (modified) Remove %_bindir. Tue, 30 Aug 2005 04:44:44 GMT Ralf Corsepius [7cee1ce] * scripts/gccnewlib/target-gfortran.add (modified) Remove %_bindir. Add %{gcc_target}-gfortran.1. Tue, 30 Aug 2005 04:44:20 GMT Ralf Corsepius [4b74fa6c] * scripts/gccnewlib/target-gcj.add (modified) Remove %_bindir. Remove %_mandir. Tue, 30 Aug 2005 04:44:01 GMT Ralf Corsepius [6cab86f] * scripts/gccnewlib/target-g77.add (modified) Add %{gcc_target}-g77.1. Tue, 30 Aug 2005 04:43:23 GMT Ralf Corsepius [5d04b30] * scripts/gccnewlib/gccnewlib.add (modified) Remove Packager:. Add %gccnewlib_version. Tue, 30 Aug 2005 04:42:54 GMT Ralf Corsepius [3d8ba80] * scripts/gccnewlib/base-gfortran.add (modified) Remove %_mandir. Remove %{gcc_target}-gfortran.1. Tue, 30 Aug 2005 04:42:34 GMT Ralf Corsepius [a708977] * scripts/gccnewlib/base-g77.add (modified) Remove %_mandir. Remove %{gcc_target}-g77.1. Mon, 29 Aug 2005 17:18:16 GMT Joel Sherrill [7bcebf1] * scripts/ChangeLog (modified) * scripts/gdb/gdb.add (modified) * scripts/setup.def (modified) 2005-08-29 Joel Sherrill * ... Thu, 25 Aug 2005 11:36:06 GMT Ralf Corsepius [9bd1f4e] * scripts/ChangeLog (modified) * scripts/gccnewlib/gccnewlib.add (modified) 2005-08-25 Ralf Corsepius * ... Mon, 22 Aug 2005 13:31:30 GMT Joel Sherrill [213810b3] * c/src/ChangeLog (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/if_dc.c (modified) * c/src/libchip/network/if_fxp.c (modified) 2005-08-18 Karel Gardas * ... Mon, 22 Aug 2005 13:26:42 GMT Joel Sherrill [cee7620] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) Remove duplicate comment. Fri, 19 Aug 2005 16:19:48 GMT Joel Sherrill [e7d06758] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/console.c (modified) 2005-08-19 Cedric Aubert PR ... Thu, 18 Aug 2005 22:24:46 GMT Joel Sherrill [71319f77] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) 2005-08-18 Karel Gardas * ... Thu, 18 Aug 2005 13:46:38 GMT Joel Sherrill [60bf9c0] * cpukit/ChangeLog (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) 2005-08-18 Andrew Sinclair ... Wed, 17 Aug 2005 22:57:41 GMT Joel Sherrill [49b7b17] * cpukit/ChangeLog (modified) * cpukit/posix/include/rtems/posix/timer.h (modified) 2005-08-17 Nuno Costa PR 805/rtems ... Wed, 17 Aug 2005 22:49:56 GMT Joel Sherrill [55e01299] * cpukit/ChangeLog (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/score/src/watchdoginsert.c (modified) 2005-08-17 Andrew Sinclair ... Wed, 17 Aug 2005 22:07:46 GMT Joel Sherrill [27178a81] * c/src/lib/libbsp/m68k/av5282/ChangeLog (added) New file. Wed, 17 Aug 2005 22:04:36 GMT Joel Sherrill [15c15c89] * make/ChangeLog (modified) * make/custom/av5282.cfg (added) 2005-08-17 Mike Bertosh * ... Wed, 17 Aug 2005 22:03:45 GMT Joel Sherrill [a3aac67] * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/acinclude.m4 (modified) 2005-08-17 Mike Bertosh * ... Wed, 17 Aug 2005 22:03:22 GMT Joel Sherrill [1b269c56] * c/src/lib/libbsp/m68k/av5282/.cvsignore (added) * c/src/lib/libbsp/m68k/av5282/Makefile.am (added) * c/src/lib/libbsp/m68k/av5282/README (added) * c/src/lib/libbsp/m68k/av5282/bsp_specs (added) * c/src/lib/libbsp/m68k/av5282/clock/clock.c (added) * c/src/lib/libbsp/m68k/av5282/configure.ac (added) * c/src/lib/libbsp/m68k/av5282/console/console.c (added) * c/src/lib/libbsp/m68k/av5282/include/bsp.h (added) * c/src/lib/libbsp/m68k/av5282/include/bspopts.h.in (added) * c/src/lib/libbsp/m68k/av5282/include/coverhd.h (added) * c/src/lib/libbsp/m68k/av5282/include/tm27.h (added) * c/src/lib/libbsp/m68k/av5282/network/network.c (added) * c/src/lib/libbsp/m68k/av5282/start/start.S (added) * c/src/lib/libbsp/m68k/av5282/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/av5282/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/av5282/startup/init5282.c (added) * c/src/lib/libbsp/m68k/av5282/startup/linkcmds (added) * c/src/lib/libbsp/m68k/av5282/startup/linkcmdsflash (added) * c/src/lib/libbsp/m68k/av5282/startup/linkcmdsram (added) * c/src/lib/libbsp/m68k/av5282/timer/timer.c (added) 2005-08-17 Mike Bertosh * ... Wed, 17 Aug 2005 19:25:00 GMT Joel Sherrill [77bb84e] * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) 2005-08-17 Lars Munch PR 727/bsps ... Wed, 17 Aug 2005 19:11:46 GMT Joel Sherrill [b3b78ec] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) 2005-08-17 Nickolay Semyonov PR ... Wed, 17 Aug 2005 02:52:18 GMT Ralf Corsepius [7930bde1] * scripts/ChangeLog (modified) 2005-08-16 Ralf Corsepius * ... Wed, 17 Aug 2005 02:51:30 GMT Ralf Corsepius [2c680594] * scripts/binutils/binutils.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/base-gfortran.add (modified) * scripts/gccnewlib/base-gnat.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) Special-case _prefix == /usr Tue, 16 Aug 2005 07:35:39 GMT Ralf Corsepius [4cf0f1c] * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) Add special treatment for _prefix=/usr Mon, 15 Aug 2005 15:13:04 GMT Ralf Corsepius [ba0e55a9] * cpukit/ChangeLog (modified) 2005-08-15 Ralf Corsepius * ... Mon, 15 Aug 2005 15:12:27 GMT Ralf Corsepius [fffda815] * cpukit/posix/include/mqueue.h (modified) * cpukit/posix/src/mqueuetimedreceive.c (modified) ssize_t mq_timedreceive() (POSIX compliance) Mon, 15 Aug 2005 15:07:26 GMT Ralf Corsepius [f04bf2d] * scripts/ChangeLog (modified) 2005-08-15 Ralf Corsepius * ... Mon, 15 Aug 2005 15:06:40 GMT Ralf Corsepius [fb242b0c] * scripts/binutils/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) Remove h8300-rtemscoff Mon, 15 Aug 2005 13:54:16 GMT Ralf Corsepius [2604a54] * c/src/ChangeLog (modified) * c/src/optman/Makefile.am (modified) 2005-08-15 Ralf Corsepius * ... Mon, 15 Aug 2005 13:51:49 GMT Ralf Corsepius [34381f9a] * c/src/librtems++/preinstall.am (added) * c/src/optman/preinstall.am (added) New. Mon, 15 Aug 2005 13:49:27 GMT Ralf Corsepius [c0c868b] * c/src/librtems++/ChangeLog (modified) 2005-08-15 Ralf Corsepius * ... Mon, 15 Aug 2005 13:49:19 GMT Ralf Corsepius [86c63a04] * c/src/librtems++/configure.ac (modified) Add AMPOLISH3. Mon, 15 Aug 2005 13:49:03 GMT Ralf Corsepius [5c5c238] * c/src/librtems++/Makefile.am (modified) Add preinstall.am. Mon, 15 Aug 2005 08:47:57 GMT Ralf Corsepius [2fd0878c] * cpukit/wrapup/preinstall.am (modified) Regenerate. Mon, 15 Aug 2005 08:47:20 GMT Ralf Corsepius [61d1060b] * cpukit/ChangeLog (modified) * cpukit/wrapup/Makefile.am (modified) 2005-08-15 Ralf Corsepius * ... Mon, 15 Aug 2005 08:38:26 GMT Ralf Corsepius [7f041264] * c/src/libchip/preinstall.am (modified) Regenerate. Fri, 12 Aug 2005 23:56:16 GMT Joel Sherrill [c949d6b0] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/printk.c (modified) 2005-08-12 Chris Johns PR ... Fri, 12 Aug 2005 23:44:27 GMT Joel Sherrill [db0cf9fc] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc8xx/include/mpc8xx.h (modified) 2005-08-12 Phil Torre PR 816/bsps ... Sat, 06 Aug 2005 03:28:49 GMT Ralf Corsepius [a605cec] * cpukit/ChangeLog (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) 2005-08-06 Ralf Corsepius * ... Fri, 05 Aug 2005 10:38:41 GMT Ralf Corsepius [da6d75f] * cpukit/ChangeLog (modified) 2005-08-05 Ralf Corsepius * ... Fri, 05 Aug 2005 10:38:05 GMT Ralf Corsepius [a72c454] * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_free.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) Introduce msdos_status_t.
