# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/03/24 06:34:29 Wed, 08 Apr 2015 15:00:43 GMT Daniel Hellstrom [1b645c3] * doc/user/conf.t (modified) * doc/user/libpci.t (modified) LIBPCI: corrected documentation Wed, 08 Apr 2015 08:51:45 GMT Daniel Hellstrom [f4bf22c] * cpukit/libpci/Makefile.am (modified) * cpukit/libpci/pci_cfg_auto.c (modified) * cpukit/libpci/pci_cfg_peripheral.c (modified) * cpukit/libpci/pci_cfg_read.c (modified) * cpukit/libpci/pci_cfg_static.c (modified) * cpukit/libpci/pci_dev_create.c (added) * cpukit/libpci/pci_internal.h (added) LIBPCI: new implementation private header file - new ... Wed, 08 Apr 2015 08:39:41 GMT Daniel Hellstrom [1f4f1e2e] * cpukit/libpci/pci_cfg_auto.c (modified) LIBPCI: various comment/unsed clean-ups Wed, 08 Apr 2015 08:16:51 GMT Daniel Hellstrom [346a9a5] * cpukit/libpci/pci.h (modified) * cpukit/libpci/pci_cfg.c (modified) LIBPCI: use enum with pci_system_type Wed, 08 Apr 2015 08:03:45 GMT Daniel Hellstrom [15620f5b] * cpukit/libpci/pci/access.h (modified) * cpukit/libpci/pci/irq.h (modified) LIBPCI: use RTEMS_INLINE_ROUTINE Wed, 08 Apr 2015 08:01:48 GMT Daniel Hellstrom [dc623099] * cpukit/libpci/pci/cfg.h (modified) LIBPCI: moved comment out of license header Wed, 08 Apr 2015 08:00:48 GMT Daniel Hellstrom [e189f241] * cpukit/libpci/pci_bus.c (modified) * cpukit/libpci/pci_bus.h (modified) PCI BUS: moved comment out of license header Wed, 08 Apr 2015 07:50:28 GMT Daniel Hellstrom [2fb0912] * cpukit/libdrvmgr/Makefile.am (modified) DRVMGR: clean-up Makefile.am Wed, 08 Apr 2015 07:49:11 GMT Daniel Hellstrom [eff69891] * cpukit/libdrvmgr/drvmgr.h (modified) DRVMGR: use RTEMS_INLINE_ROUTINE Tue, 07 Apr 2015 14:35:53 GMT Daniel Hellstrom [39937b6c] * cpukit/libpci/pci/ids.h (modified) LIBPCI: added license and auto-gen comment to pci/ids.h To be Merged. Tue, 07 Apr 2015 14:19:39 GMT Daniel Hellstrom [07e5a0e] * cpukit/libpci/pci/cfg.h (modified) LIBPCI: clean-up pci_for_each_child() search arg Tue, 07 Apr 2015 14:08:05 GMT Daniel Hellstrom [4ab9296] * cpukit/libpci/Makefile.am (modified) LIBPCI: remove $Id in makefile.am Tue, 07 Apr 2015 14:05:04 GMT Daniel Hellstrom [159ee990] * c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c (modified) leon3,ngmp: cpucounter initialization use proper names To be merged ... Tue, 07 Apr 2015 14:04:13 GMT Daniel Hellstrom [5564b5a] * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) leon3: timer config updated to use proper naming To be merged with ... Tue, 07 Apr 2015 12:31:22 GMT Daniel Hellstrom [9b292ea] * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (modified) LEON: converted LEON4-N2X to BSD header Tue, 07 Apr 2015 12:31:07 GMT Daniel Hellstrom [8b29637c] * c/src/lib/libbsp/sparc/shared/pci/gr_701.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c (modified) LEON: converted PCI peripherals to BSD header Tue, 07 Apr 2015 12:28:29 GMT Daniel Hellstrom [d5ca821] * c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) * c/src/lib/libbsp/sparc/shared/pci/pcif.c (modified) LEON: converted AT697,GRPCi,GRPCI2,PCIF to BSD header Tue, 07 Apr 2015 12:25:49 GMT Daniel Hellstrom [c1c37a1] * cpukit/libpci/Makefile.am (modified) * cpukit/libpci/pci.h (modified) * cpukit/libpci/pci/access.h (modified) * cpukit/libpci/pci/ids.h (modified) * cpukit/libpci/pci/pcireg.h (added) * cpukit/libpci/pci_access.c (modified) * cpukit/libpci/pci_cfg_auto.c (modified) * cpukit/libpci/pci_cfg_read.c (modified) * cpukit/libpci/pci_cfg_static.c (modified) * cpukit/libpci/pci_find.c (modified) * cpukit/libpci/pci_for_each.c (modified) * cpukit/libpci/pci_irq.c (modified) * cpukit/libpci/pci_print.c (modified) * cpukit/libpci/preinstall.am (modified) LIBPCI: converted to BSD header Tue, 07 Apr 2015 12:25:23 GMT Daniel Hellstrom [56ea46ba] * cpukit/libpci/pci_bus.c (modified) DRVMGR: PCI BUS converted to BSD header Mon, 13 Apr 2015 08:12:08 GMT Daniel Hellstrom [1f66914] * cpukit/libpci/pci_bus.c (modified) * cpukit/libpci/pci_bus.h (modified) LIBPCI: moved pci_bus copyright into a single line Fri, 27 Feb 2015 15:45:59 GMT Daniel Hellstrom [71e8a5c] * cpukit/libpci/pci/access.h (modified) * cpukit/libpci/pci/cfg.h (modified) * cpukit/libpci/pci/cfg_auto.h (modified) * cpukit/libpci/pci/cfg_peripheral.h (modified) * cpukit/libpci/pci/cfg_read.h (modified) * cpukit/libpci/pci/cfg_static.h (modified) * cpukit/libpci/pci/irq.h (modified) * cpukit/libpci/pci_access.c (modified) * cpukit/libpci/pci_access_func.c (modified) * cpukit/libpci/pci_access_io.c (modified) * cpukit/libpci/pci_access_mem.c (modified) * cpukit/libpci/pci_access_mem_be.c (modified) * cpukit/libpci/pci_access_mem_le.c (modified) * cpukit/libpci/pci_cfg.c (modified) * cpukit/libpci/pci_cfg_auto.c (modified) * cpukit/libpci/pci_cfg_peripheral.c (modified) * cpukit/libpci/pci_cfg_print_code.c (modified) * cpukit/libpci/pci_cfg_read.c (modified) * cpukit/libpci/pci_cfg_static.c (modified) * cpukit/libpci/pci_find.c (modified) * cpukit/libpci/pci_find_dev.c (modified) * cpukit/libpci/pci_for_each.c (modified) * cpukit/libpci/pci_for_each_child.c (modified) * cpukit/libpci/pci_for_each_dev.c (modified) * cpukit/libpci/pci_get_dev.c (modified) * cpukit/libpci/pci_irq.c (modified) * cpukit/libpci/pci_print.c (modified) LIBPCI: moved copyright into a single line Fri, 27 Feb 2015 15:45:20 GMT Daniel Hellstrom [358b8543] * cpukit/libpci/CHANGES (deleted) LIBPCI: removed unused changes file Fri, 27 Feb 2015 15:44:48 GMT Daniel Hellstrom [a2e0e6e] * cpukit/libpci/pci/cfg.h (modified) LIBPCI: fixed RES2DEV in pci/cfg.h Fri, 27 Feb 2015 15:42:36 GMT Daniel Hellstrom [65d1f35] * cpukit/libdrvmgr/drvmgr.c (modified) * cpukit/libdrvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_by_id.c (modified) * cpukit/libdrvmgr/drvmgr_by_name.c (modified) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) * cpukit/libdrvmgr/drvmgr_dev_by_name.c (modified) * cpukit/libdrvmgr/drvmgr_drvinf.c (modified) * cpukit/libdrvmgr/drvmgr_for_each_dev.c (modified) * cpukit/libdrvmgr/drvmgr_for_each_list_dev.c (modified) * cpukit/libdrvmgr/drvmgr_func.c (modified) * cpukit/libdrvmgr/drvmgr_func_call.c (modified) * cpukit/libdrvmgr/drvmgr_init.c (modified) * cpukit/libdrvmgr/drvmgr_internal.h (modified) * cpukit/libdrvmgr/drvmgr_list.c (modified) * cpukit/libdrvmgr/drvmgr_list.h (modified) * cpukit/libdrvmgr/drvmgr_lock.c (modified) * cpukit/libdrvmgr/drvmgr_print.c (modified) * cpukit/libdrvmgr/drvmgr_res.c (modified) * cpukit/libdrvmgr/drvmgr_rw.c (modified) * cpukit/libdrvmgr/drvmgr_translate.c (modified) * cpukit/libdrvmgr/drvmgr_translate_check.c (modified) * cpukit/libdrvmgr/drvmgr_unregister.c (modified) DRVMGR: updated copyright into one line only Fri, 27 Feb 2015 13:03:15 GMT Daniel Hellstrom [5823bae8] * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/timer/watchdog.c (modified) * c/src/lib/libbsp/sparc/shared/1553/b1553brm.c (modified) * c/src/lib/libbsp/sparc/shared/1553/b1553rt.c (modified) * c/src/lib/libbsp/sparc/shared/1553/gr1553b.c (modified) * c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c (modified) * c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c (modified) * c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) * c/src/lib/libbsp/sparc/shared/analog/gradcdac.c (modified) * c/src/lib/libbsp/sparc/shared/ascs/grascs.c (modified) * c/src/lib/libbsp/sparc/shared/can/canmux.c (modified) * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/can/occan.c (modified) * c/src/lib/libbsp/sparc/shared/can/satcan.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * c/src/lib/libbsp/sparc/shared/gpio/gpiolib.c (modified) * c/src/lib/libbsp/sparc/shared/gpio/grgpio.c (modified) * c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c (modified) * c/src/lib/libbsp/sparc/shared/include/gr1553bc.h (modified) * c/src/lib/libbsp/sparc/shared/include/gr1553bc_list.h (modified) * c/src/lib/libbsp/sparc/shared/irq/genirq.c (modified) * c/src/lib/libbsp/sparc/shared/mem/mctrl.c (modified) * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) * c/src/lib/libbsp/sparc/shared/net/network_interface_add.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_701.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) * c/src/lib/libbsp/sparc/shared/pci/pcif.c (modified) * c/src/lib/libbsp/sparc/shared/pwm/grpwm.c (modified) * c/src/lib/libbsp/sparc/shared/slink/grslink.c (modified) * c/src/lib/libbsp/sparc/shared/spi/spictrl.c (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_router.c (modified) * c/src/lib/libbsp/sparc/shared/time/grctm.c (modified) * c/src/lib/libbsp/sparc/shared/time/spwcuc.c (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib.c (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) * c/src/lib/libbsp/sparc/shared/tmtc/grtc.c (modified) * c/src/lib/libbsp/sparc/shared/tmtc/grtm.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (modified) * c/src/lib/libbsp/sparc/shared/uart/cons.c (modified) LEON: move driver headers to bsp/ directory Fri, 06 Feb 2015 09:07:19 GMT Daniel Hellstrom [445e253] * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/mctrl.h (added) * c/src/lib/libbsp/sparc/shared/mem/mctrl.c (modified) MCTRL: fix build warnings in MCTRL driver Wed, 11 Feb 2015 11:56:03 GMT Daniel Hellstrom [dbfa7c98] * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus_grlib.h (modified) AMBAPP GRLIB: fix build warnings Wed, 11 Feb 2015 11:55:32 GMT Daniel Hellstrom [62fb1778] * c/src/lib/libbsp/sparc/shared/drvmgr/leon2_amba_bus.c (modified) LEON2: fix build warnings Wed, 11 Feb 2015 11:54:57 GMT Daniel Hellstrom [43613a90] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) AMBAPP_BUS: fix build warnings Wed, 11 Feb 2015 11:52:14 GMT Daniel Hellstrom [56662f5c] * c/src/lib/libbsp/sparc/shared/uart/cons.c (modified) LEON CONS: fix build warnings Wed, 11 Feb 2015 11:50:35 GMT Daniel Hellstrom [103bbde] * c/src/lib/libbsp/sparc/shared/include/gr_tmtc_1553.h (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c (modified) GR-TMTC-1553: fix build warnings Wed, 11 Feb 2015 11:40:17 GMT Daniel Hellstrom [dd8abfc] * c/src/lib/libbsp/sparc/shared/include/gr_rasta_tmtc.h (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c (modified) GR-RASTA-TMTC: fix build warnings Wed, 11 Feb 2015 11:39:40 GMT Daniel Hellstrom [90fd587] * c/src/lib/libbsp/sparc/shared/include/gr_rasta_spw_router.h (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c (modified) GR-RASTA-SPW-ROUTER: fix build warnings Wed, 11 Feb 2015 11:39:04 GMT Daniel Hellstrom [960aebf] * c/src/lib/libbsp/sparc/shared/include/gr_rasta_io.h (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c (modified) GR-RASTA-IO: fix build warnings Wed, 11 Feb 2015 11:38:22 GMT Daniel Hellstrom [03037b4] * c/src/lib/libbsp/sparc/shared/include/gr_rasta_adcdac.h (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c (modified) GR-RASTA-ADCDAC: fix build warnings Wed, 11 Feb 2015 11:37:28 GMT Daniel Hellstrom [ef7a009] * c/src/lib/libbsp/sparc/shared/include/gr_leon4_n2x.h (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (modified) GR-LEON4-N2X: fix build warnings Wed, 11 Feb 2015 11:36:50 GMT Daniel Hellstrom [05a45c79] * c/src/lib/libbsp/sparc/shared/include/gr_701.h (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_701.c (modified) GR_701: fix build warnings Wed, 11 Feb 2015 11:35:53 GMT Daniel Hellstrom [cb64b862] * c/src/lib/libbsp/sparc/shared/gpio/grgpio.c (modified) GRGPIO: fix buld warnings Wed, 11 Feb 2015 11:35:36 GMT Daniel Hellstrom [c39de3c4] * c/src/lib/libbsp/sparc/shared/gpio/gpiolib.c (modified) GPIOLIB: fix build warnings Wed, 11 Feb 2015 11:34:48 GMT Daniel Hellstrom [7bc74ed] * c/src/lib/libbsp/sparc/shared/analog/gradcdac.c (modified) GRADCDAC: fix build warnings Wed, 11 Feb 2015 11:34:02 GMT Daniel Hellstrom [0355ad4] * c/src/lib/libbsp/sparc/shared/irq/genirq.c (modified) GENIRQ: fix build warnings Wed, 11 Feb 2015 11:32:22 GMT Daniel Hellstrom [9d05c6df] * c/src/lib/libbsp/sparc/shared/pwm/grpwm.c (modified) GRPWM: fix build warnings Wed, 11 Feb 2015 11:31:26 GMT Daniel Hellstrom [126b25d] * c/src/lib/libbsp/sparc/shared/time/spwcuc.c (modified) SPWCUC: fix build warnings Wed, 11 Feb 2015 11:27:05 GMT Daniel Hellstrom [8c6c53d] * c/src/lib/libbsp/sparc/shared/spi/spictrl.c (modified) SPICTRL: fix build warnings Wed, 11 Feb 2015 11:23:45 GMT Daniel Hellstrom [9b90342] * c/src/lib/libbsp/sparc/shared/include/grspw_router.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_router.c (modified) GRSPW router: fix build warnings Wed, 11 Feb 2015 11:23:04 GMT Daniel Hellstrom [b6292a0b] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) GRSPW_PKT: fix build warnings Wed, 11 Feb 2015 08:40:15 GMT Daniel Hellstrom [fd7eaa2] * c/src/lib/libbsp/sparc/shared/include/tlib.h (modified) TLIB: fix build warnings Wed, 11 Feb 2015 08:39:48 GMT Daniel Hellstrom [6048035] * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) TLIB Clock: fix build warnings Wed, 11 Feb 2015 08:37:50 GMT Daniel Hellstrom [a93b3aa4] * c/src/lib/libbsp/sparc/shared/include/grascs.h (modified) GRASCS: fix build warnings Wed, 11 Feb 2015 08:20:40 GMT Daniel Hellstrom [3823f5c] * c/src/lib/libbsp/sparc/shared/include/grctm.h (modified) * c/src/lib/libbsp/sparc/shared/time/grctm.c (modified) GRCTM: fix build warnings Wed, 11 Feb 2015 08:19:53 GMT Daniel Hellstrom [60d392b7] * c/src/lib/libbsp/sparc/shared/include/grtm.h (modified) * c/src/lib/libbsp/sparc/shared/tmtc/grtm.c (modified) GRTM: fix build warnings Wed, 11 Feb 2015 08:18:53 GMT Daniel Hellstrom [e21a5b0] * c/src/lib/libbsp/sparc/shared/include/grtc.h (modified) * c/src/lib/libbsp/sparc/shared/tmtc/grtc.c (modified) GRTC: fix build warnings Tue, 10 Feb 2015 15:33:16 GMT Daniel Hellstrom [6657a3d] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) LEON: GRPCI2 driver warning fixes Tue, 10 Feb 2015 15:29:39 GMT Daniel Hellstrom [48191662] * c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c (modified) * c/src/lib/libbsp/sparc/shared/include/i2cmst.h (modified) LEON: I2CMST driver warnings fixes Tue, 10 Feb 2015 15:28:55 GMT Daniel Hellstrom [c9f75435] * c/src/lib/libbsp/sparc/shared/can/occan.c (modified) LEON: OCCAN driver warnings fixes Tue, 10 Feb 2015 15:28:19 GMT Daniel Hellstrom [be815e78] * c/src/lib/libbsp/sparc/shared/1553/b1553brm.c (modified) * c/src/lib/libbsp/sparc/shared/include/b1553brm.h (modified) LEON: B1553BRM driver warnings fixes Tue, 10 Feb 2015 15:28:03 GMT Daniel Hellstrom [44e514f] * c/src/lib/libbsp/sparc/shared/1553/b1553rt.c (modified) * c/src/lib/libbsp/sparc/shared/include/b1553rt.h (modified) LEON: B1553RT driver warnings fixes Tue, 10 Feb 2015 15:05:38 GMT Daniel Hellstrom [3f38335b] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/get_resarray_count.c (added) * c/src/lib/libbsp/sparc/shared/include/drvmgr/bspcommon.h (added) LEON: added get_resarray_count() helper routine Tue, 10 Feb 2015 08:23:48 GMT Daniel Hellstrom [b787bead] * c/src/lib/libbsp/sparc/shared/1553/gr1553b.c (modified) * c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c (modified) * c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c (modified) * c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c (modified) * c/src/lib/libbsp/sparc/shared/include/gr1553b.h (modified) GR1553B: fixed build warnings Tue, 10 Feb 2015 07:32:42 GMT Daniel Hellstrom [05ce8bd5] * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/at697_pci.h (added) * c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) AT697PCI: fix build warnings Wed, 18 Feb 2015 14:34:39 GMT Daniel Hellstrom [e3c9937] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) GPTIMER: move ISR install from init1 To avoid install ISRs during ... Fri, 06 Feb 2015 10:10:17 GMT Daniel Hellstrom [f37a3c2] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/gptimer.h (added) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) GPTIMER: fix build warnings Fri, 06 Feb 2015 08:59:13 GMT Daniel Hellstrom [7a03ac29] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_cons.h (added) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) APBUART_CONS: fix build warning Fri, 06 Feb 2015 08:27:08 GMT Daniel Hellstrom [d77b16d] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/gr_rasta_spw_router.h (added) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c (modified) GR-RASTA-SPW-ROUTER: fix build warnings Thu, 05 Feb 2015 13:35:33 GMT Daniel Hellstrom [28950f0b] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/pcif.h (added) * c/src/lib/libbsp/sparc/shared/pci/pcif.c (modified) PCIF: fixed build warnings Thu, 05 Feb 2015 13:31:42 GMT Daniel Hellstrom [f407c51] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/grpci.h (added) * c/src/lib/libbsp/sparc/shared/pci/grpci.c (modified) GRPCI: fixed build warnings Thu, 05 Feb 2015 08:52:00 GMT Daniel Hellstrom [0d9bc25] * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) GRSPW: fix build warnings Thu, 05 Feb 2015 07:07:15 GMT Daniel Hellstrom [b55aa49] * c/src/lib/libbsp/sparc/leon3/timer/watchdog.c (modified) LEON3: watchdog use common timer defines Thu, 05 Feb 2015 07:06:26 GMT Daniel Hellstrom [5ba49066] * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) LEON3: export debug uart to console uart driver Thu, 05 Feb 2015 07:05:56 GMT Daniel Hellstrom [aedc9849] * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) GRETH: fix build warnings with GCC-4.9 Wed, 04 Feb 2015 15:22:59 GMT Daniel Hellstrom [bf6fe958] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) GPTIMER: avoid build warnings Wed, 04 Feb 2015 15:22:41 GMT Daniel Hellstrom [0fcd4b33] * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) * c/src/lib/libbsp/sparc/shared/include/ahbstat.h (modified) AHBSTAT: fix build warnings Tue, 04 Nov 2014 07:57:55 GMT Daniel Hellstrom [bb689e6] * c/src/lib/libbsp/sparc/shared/include/grtm.h (modified) GRTM: fixed descriptor TS bit declaration Tue, 04 Nov 2014 07:52:39 GMT Daniel Hellstrom [5f4028b] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) GRSPW_PKT: grspw_status renamed in header Fri, 08 Aug 2014 08:01:41 GMT Daniel Hellstrom [e8f6005f] * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c (modified) GR-RASTA-TMTC,rev1: add GRGPIO[0] register init Fri, 08 Aug 2014 07:59:36 GMT Daniel Hellstrom [fed905c8] * c/src/lib/libbsp/sparc/shared/1553/b1553brm.c (modified) * c/src/lib/libbsp/sparc/shared/include/b1553brm.h (modified) B1553BRM: change the init of the RT legalization registers Fri, 02 May 2014 12:28:44 GMT Daniel Hellstrom [d2a94ab] * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) GRSPW: added clock cycles after GRSPW reset added clock cycles ... Wed, 03 Jul 2013 08:16:30 GMT Andreas Larsson [56fc7809] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) GRSPW_PKT: Add support for Interrupt-codes Update: Daniel Hellstrom ... Wed, 03 Jul 2013 08:06:37 GMT Andreas Larsson [c119c0e] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) GRSPW: Fix incorrect register defines - presently functionally ... Fri, 20 Dec 2013 09:17:22 GMT Daniel Hellstrom [f1b1668] * c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h (modified) AMBAPP: updated PnP IDs database with SPWTDP Fri, 29 Nov 2013 13:58:58 GMT Daniel Hellstrom [fa12bb43] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) GRTIMER: added to GPTIMER driver GRTIMER is compatible with ... Tue, 22 Oct 2013 10:03:41 GMT Daniel Hellstrom [9b8e04e2] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) GRETH: avoid hw generated UDP/TCP cksum generation Hardware ... Fri, 20 Dec 2013 13:03:10 GMT Daniel Hellstrom [80b9c8ac] * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c (modified) GR-RASTA-IO: updated for new version From this driver's point of ... Fri, 20 Dec 2013 13:01:12 GMT Daniel Hellstrom [fc76056e] * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c (modified) GR-RASTA-TMTC: updated for new version From this driver's point of ... Wed, 18 Dec 2013 15:42:16 GMT Daniel Hellstrom [9d88008] * c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c (modified) AT697PCI: fix PCI cfg writes Fri, 22 Nov 2013 09:22:56 GMT Daniel Hellstrom [ddc4002] * c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c (modified) AT697 PCI: abort whhen a peripheral PCI system detected Wed, 05 Feb 2014 16:17:53 GMT Daniel Hellstrom [3c236cc] * c/src/lib/libbsp/sparc/shared/pci/grpci.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) * c/src/lib/libbsp/sparc/shared/pci/pcif.c (modified) LEON PCI: fix for PCI host bridge driver CFG space access Tue, 10 Sep 2013 11:46:29 GMT Daniel Hellstrom [acf7047e] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) GPTIMER: timer probing must not be on timer0 Timers are identical ... Mon, 01 Jul 2013 13:00:21 GMT Daniel Hellstrom [51347053] * c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) * c/src/lib/libbsp/sparc/shared/pci/pcif.c (modified) LEON PCI: host bridge driver support for probing dev0=AD16 Before ... Mon, 03 Jun 2013 12:12:08 GMT Daniel Hellstrom [d936c1a] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) APBUART: debug bit was cleared incorrectly Tue, 21 May 2013 08:10:21 GMT Daniel Hellstrom [ab907e8e] * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (modified) * cpukit/libpci/pci/ids_extra.h (modified) NGMP PCI: added support for NGMP prototype boards Wed, 11 Feb 2015 13:39:34 GMT Daniel Hellstrom [bc89145] * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) LEON GRSPW: updated to new DRVMGR translation interface Wed, 08 May 2013 12:41:13 GMT Daniel Hellstrom [ffd8002d] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/gr_leon4_n2x.h (added) * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) * cpukit/libpci/pci/ids_extra.h (modified) * cpukit/libpci/pci_bus.h (modified) GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device ... Wed, 08 May 2013 12:38:10 GMT Daniel Hellstrom [8aa446a] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) GRPCI2: updated register layout to newer specification Tue, 30 Apr 2013 07:49:32 GMT Daniel Hellstrom [ecbd577] * c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h (modified) AMBAPP: update AMBA PnP ID database Wed, 24 Apr 2013 15:36:44 GMT Daniel Hellstrom [175b9a64] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) GRPCI2: work-around for rev0 bug by limiting prefetching Mon, 18 Mar 2013 07:29:39 GMT Daniel Hellstrom [819de55b] * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c (modified) PCI-RASTA: set GRPCI1 target cache-line-size to avoid poor performance Thu, 14 Mar 2013 09:20:15 GMT Daniel Hellstrom [37ac3b86] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) GRETH: cleaned up parts of PHY init code Wed, 13 Mar 2013 15:40:05 GMT Daniel Hellstrom [107c5aea] * c/src/lib/libbsp/sparc/shared/include/greth.h (modified) * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) GRETH: changed the PHY initialization sequence 1. read_mii() now ... Tue, 12 Mar 2013 14:30:09 GMT Daniel Hellstrom [a79c36ad] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) GRETH: forcing autonegotiation during PHY initialization Looking at ...
